587,837 active members*
3,693 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Share your 3D Carving files, Parts or Art
Results 1 to 20 of 600
Threaded View
  1. #6
    Jan 2006
    758
    A few places to look....
    Quote Originally Posted by wood elf View Post
    New to CNC milling. I've handcrafted wooden toys and furniture for years ..... now interested in finding affordable 2d and 3d models primarily toys, carvings and art.
    Any suggestions?
    Hi there,
    You have similar background and interests to my own. For carving and art resources I suggest regular visits to cnc4free.org... I host 25+ FREE Art or carving type models/reliefs every month, also 10 art type .DXFs... content is changed monthly, usually around the 15th or so... FreeMill is a good free option for relief carving if you dont have existing software to generate the 3D carving code
    You might also be interested in learning to create your own relief or carving type content from bitmaps using FREE tools.. there are many FREE utilities that can perform this function to a very high standard.. it's just a matter of tuning the input images.. see the chapter 9 overview in the 'Tutorial' section of the same site.
    For Toy's I'd reccomend a prowl of the FREE plans type sites.. it's usually fairly easy to adapt this kind of plan for CNC use.. thats how I made the ride on toy's pictured below... The plans were essentially an influence rather than a blueprint for the final toys, but they are a useful starting point for construction techniques etc. Again There are quite a few links to this kind of (FREE) plan on the links page at http://cnc4free.org
    The design process employed making the motorbike type toy is shown in the chapter 13 overview as a 'CNC_Toolkit' case study. Gmax /CnC_toolkit is ideal for this kind of work. You can build the toy virtually using spline outlines or imported .DXF as starting point.. then apply the same oulines/splines to generate the cutting code.. It's an excellent, FREE, integrated solution...
    hope this helps
    Danny
    What one man can do another man can do..
    BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
  1. Share Your Files Part or Art
    By lakeside in forum MetalWork Discussion
    Last Post: 05-09-2024, 04:01 AM
  2. Lada
    By multiple in forum MetalWork Discussion
    Last Post: 01-18-2014, 11:00 AM
  3. Lets Share!!!!! (cut files)
    By Dustin407 in forum Waterjet General Topics
    Last Post: 08-24-2011, 11:46 PM
  4. Relief carving small detailed parts - V-carving from greyscale image
    By ALAN2525 in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 12:01 AM
