588,227 active members*
4,386 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > NEED FANUC 11M KEYPAD SUPER MAX 1982 VMC
Results 1 to 3 of 3
    Jul 2009
    22
    I am looking for a Fanuc 11m keypad, for a 1982-88 not sure of the year, Supermax, Max 1. The key pad is at the top right of the console, it has the numbers and letters.
    See picture.
    Also I have to use an orgining program to set X0Y0.
    I would like to put the X0Y0 in the work offsets page.
    G54, G55, G56, ect... thanks.
    Jan 2006
    59
    Keypad
    Around the keypad/membrane is a frame. Remove the screws and gently "pop" the frame off. If i remember correctly the part number in the lower right corner.
    FYI,The membrane has an adhesive back. So when you get the new one it will be a little bit of a task to remove the old one.
    RRL
    :wave:
    Jun 2005
    232
    If your just looking for the key sheet yoy can buy them from.
    CNC Electronics ,phone 434-971-1689
    Tim
  1. 1982 fanuc CNC CK2
    By mark oz in forum DNC Problems and Solutions
    Last Post: 01-30-2009, 12:09 PM
  2. Replies: 7
    Last Post: 10-26-2008, 08:51 PM
  3. Fanuc O-M keypad cover replacement
    By HapSmo19 in forum Want To Buy...Need help!
    Last Post: 08-06-2008, 05:42 PM
  4. Keypad trouble, Fanuc 10M
    By the professor in forum Fanuc
    Last Post: 09-17-2007, 08:07 PM
  5. Fanuc OT Keypad replacement
    By thardy in forum Fanuc
    Last Post: 11-09-2006, 05:39 AM
