588,272 active members*
11,141 visitors online*
IndustryArena Forum > CAM Software > CamWorks > obslete camworks post sources sharing
Page 1 of 2 12
Results 1 to 20 of 31
    Oct 2006
    12
    Lightbulb obslete camworks post sources sharing
    i have all the obslete camworks post sources sharing for both mill-turn and turning sections which Teksoft removed from there website recently
    i only seeking the milling post sources and can share the both mill-turn and turning post files
    Oct 2006
    12
    post referance files
    available for sharing
    Attached Files Attached Files
    Oct 2006
    12
    needed posts reference file
    reference file of needed posts
    Oct 2005
    40
    Were are the post files
    this is only a list were can i find lsrc14.zip the post file also were can i find a post that will work with deskcnc for my sherline lathe and mill.
    Feb 2009
    do you have prototrack smx post
    thank you
    Mar 2007
    114
    Haas Lathe Post
    Do you have access to the Haas lathe post file
    [email protected]
    thanks
    Oct 2010
    Hi Samirabaza
    can i have the sources file for camworks millturn please
    [email protected]
    Jun 2005
    need Fanuc OT Hardinge LSRC441.ZIP please.
    [email protected]
    Feb 2011
    5
    Do you have Siemens840D?
    Dec 2005
    47
    Where can I get the Heidenhain TNC 150 Post?
    Thanks!
    May 2009
    71
    Heidenhain TNC360 post - doesn't work for TNC2500 very well.
    Apr 2011
    Hi
    I need
    HEIDENHAIN TNC 530
    Apr 2011
    Hi
    Need postprocessor for
    Mazak quick turn 250
    Jul 2011
    Hello, i would very much appreciate this post - FANUC OT TAKISAWA LSRC802.ZIP. I have been looking for one for a long time. [email protected]
    Nov 2008
    47
    dynapath delta 20 post
    Hi, your list shows you have a camworks post for a Dynapath Delta 20 for use on a TREE VMC 1050. Is ther any way I could get that?
    [email protected]
    Oct 2006
    12
    backe with links
    hello CNC friends
    sorry i am too late to reply
    i will attach here a text file contains all what i got of the obsolete camworks post sources i still in need of the All_mill_source.zip
    please if anyone can add it please do it
    one thing more
    please share your customized posts and its source files here cuz may be it will be useful for someone else
    files are:
    LATHE_LIB_FILES.zip
    MASTER_LATHE_POSTS.zip
    MASTER_MILL_SOURCE.zip
    MASTER_MILL_TURN_SOURCE.zip
    New_Lathe_Sections.txt
    MILL_LIB_FILES.zip
    New_Lathe-Mill_Sextions.txt
    New_Mill_Sections.txt
    Post_Processor_Reference.pdf
    all_mill-turn_source.zip
    all_lathe_source.zip
    Oct 2006
    12
    Quote Originally Posted by rrbmachining829396
    [email protected]
    thanks
    please check the following
    hello CNC friends
    i will attach here all i got of the obsolete camworks post sources i
    one thing more
    files are:
    LATHE_LIB_FILES.zip
    MILL_LIB_FILES.zip
    https://rapidshare.com/files/3682376..._LIB_FILES.zip
    https://rapidshare.com/files/3500457...ATHE_POSTS.zip
    https://rapidshare.com/files/2612745...ILL_SOURCE.zip
    https://rapidshare.com/files/5225518...URN_SOURCE.zip
    https://rapidshare.com/files/1745137...e_Sections.txt
    https://rapidshare.com/files/3884283..._LIB_FILES.zip
    https://rapidshare.com/files/4163525...l_Sextions.txt
    https://rapidshare.com/files/2593628...l_Sections.txt
    https://rapidshare.com/files/3182069..._Reference.pdf
    https://rapidshare.com/files/4146045...urn_source.zip
    https://rapidshare.com/files/8188341...the_source.zip
    Oct 2006
    12
    finally with the help of another forum member
    all mill posts are here
    https://rapidshare.com/#!download|33...rce.rar|112469
    Apr 2006
    3
    Hi Samirabaza, can you please repost allmillsource.rar- can't download from rapidshare - says file is there, but it won't dl
    TIA,
    K
    Jul 2013
    Im looking for a Camworks post for a Haas ST20 ssy lathe and a Hurco TM6 Lathe
Page 1 of 2 12
  1. UPG learning sources - Universal post generator
    By gmolteni in forum CamWorks
    Last Post: 02-01-2016, 03:49 AM
  2. hurco post for camworks
    By nofearnem in forum Post Processor Files
    Last Post: 05-21-2015, 11:47 AM
  3. Mach3 Post for CAMWorks
    By juengelj in forum CamWorks
    Last Post: 10-08-2012, 07:00 PM
