588,496 active members*
4,539 visitors online*
Results 1 to 10 of 10
    Oct 2008
    2106
    Mach 3 Crashing PC
    I have not fired up my mini mill for a couple weeks, but I need to engrave some replacement number chips for a club I help run. Anyway, turned on the PC and started my controller the other day, and I have been dinking with it off and on for about a week now.
    Nothing seems to be wrong with the PC. All other software works. AVAST says it has a clean bill of health. Memory tests are ok, but when I start Mach 3 the PC reboots. Not always instantly, but everytime. Usually prety quickly.
    Following diagnostics were done.
    Memory test
    Re-install Mach 3
    Install latest version of Mach 3
    Unplug controller from LPT port
    Start Mach 3 with different setup file.
    Still crashes. I can run multiple other aps... no crash.
    HELP!!!
    I'll try another PC when I have more time to set one up, but this one is driving me nuts.
    Bob La Londe
    http://www.YumaBassMan.com
    Mar 2005
    59
    Vista or XP ?
    "Bslater
    try this,reboot-go to the mach directory look for a file called special driver double click ,you will see a quick dos screen come
    and go.then reboot.i believe that will get it.
    bill " http://www.machsupport.com/forum/ind...ic,4201.0.html
    Try that...
    Oct 2008
    2106
    XP Pro
    Bob La Londe
    Oct 2008
    2106
    Quote Originally Posted by Juka View Post
    Vista or XP ?
    "Bslater
    Try that...
    I tried this and the software no-longer causes the machine to reboot, but now it doesn't control my machine.
    Bob La Londe
    35538
    Did it work OK before? Try removing the anti -virus software.
    Oct 2008
    2106
    Yes it worked fine from the when I first set it up for over a year. I did a bunch pf projects with the machine. Then I haven't started it for a month or so, and last week I booted it up to make some replacement parts and everytime I started Mach 3 the PC would reboot.
    Bob La Londe
    Jul 2005
    2415
    Does this occur when you call up your Profile (via the Load Profile) or from a profile you have customized (changed settings)? See if you can get it to load the generic Mach Mill (copy your XML profiles off to another folder before you bring any new ones in).
    Use a generic Mach Mill and if it runs then you can suspect it's something in your profile. Typically a hardware problem (incompatibility) shows up at the first not a year later. A hardware (PC) failure would evidence itself in other applications or your tests.
    Run the DriverTest.exe in the Mach folder and see if it complains about anything.
    If you have added or enabled any hardware or services since it was setup (i.e. network cards, wireless networking, etc) then disable that and see if it makes any difference.
    TOM Caudle
    www.CandCNC.com
    Oct 2008
    2106
    I have one question. What is the best pulse time for the deepgroove1 controller and the 280oz motors?
    I shut down everything except critical services necessary to keep Windows running, and the darn thing still reboots. Its not as bad at 25000, but I was running 35000 before. I can sometimes load a small file and execute it before it boots, but I started noticing glitches in the file loads now too.
    I was able to run the software and controller just fine, using my accounting machine (exact same computer) without disabling anything.
    I think this PC has established itself in a new mammaries elevated dispostion.
    The Taig1 profile seems to work better than the deepgroove1 profile or maybe its just that I finally isolated it to the PC itself. I think its having processor issues. The LPT port diagnostics show no errors.
    I guess I need to buy a new computer to run this. Maybe from one of those guys who provides them ready to go for CNC stuff, and then just plug in my license files and machine profile.
    Bob La Londe
    35538
    How fast is this PC?
    Generally, you want to use the lowest Kernel Frequency that'll give you the speed you need. For most, that's 25Khz.
    Oct 2008
    2106
    FOUND IT!
    There are a whole bunch of caps on the MB right next to the CPU. 2 of them are leaking. Blown power filtration cap will certainly cause a CPU to act flaky. Dang. Oh, well. I had already ordered a couple cheap PCs in for spares anyway. I'll be back up and running in a couple days.
    Thanks for all your help. It didn't solve the problem, but did help set the whole setup more firmly in my mind to make any future trouble shooting a lot easier.
    Bob La Londe
  1. V23 crashing
    By RCE in forum BobCad-Cam
    Last Post: 03-12-2009, 01:47 PM
  2. Rhino keeps crashing
    By seunao in forum Rhino 3D
    Last Post: 02-09-2009, 11:40 AM
  3. MCX crashing
    By baran3 in forum Mastercam
    Last Post: 03-27-2007, 01:09 AM
  4. Help! Mach limit switches - Z crashing, X & Y okay...
    By InspirationTool in forum Mach Mill
    Last Post: 03-14-2007, 05:25 PM
  5. mach 3 CRASHING!
    By pleasuretool in forum Mach Software (ArtSoft software)
    Last Post: 09-03-2005, 01:28 AM
