very impressive. lets see some video of that thing in action!
I agree, can we see a video of your fabulous machine working? Great job!
[ame="http://www.youtube.com/watch?v=uvtMqh05fsQ"]YouTube - Home Made CNC Plasma Cutter with Plate Marker - Part 1[/ame]
Fast forward to about 1:40 to see the plate marker!
One more....
[ame="http://www.youtube.com/watch?v=14QfBJQ_fy4"]YouTube - CNC Plasma Cutter - Part 2[/ame]
[ame="http://www.youtube.com/watch?v=rcFCBnO9g_E"]YouTube - CNC Motion and Plate Marking Demo[/ame]
I wonder what causes that brown looking foam?
I don't know what causes it but it disappears.
Fiero,
After cut, Do you get a free dross in the bottom of material?
Mongkol
I get a normal amount of dross that is easy to clean off. If I have the speed and height just right, and a new tip, it does really well with hardly any dross. I have my 10ga settings down pretty good, the video is 1/4" and judging by the sparks it looks like something wasn't quite right, but it still cut fine.
Wow, nice job! Tell us more about the plate maker...How do you interface the two. Did you build it yourself? WE (group) need to know more!!!!!!
I re-read the post and missed it! I'm really impressed, your cuts are fantastic. I'm looking to build but will only cut 1/8 steel, what would you recommend for a plasma?
Hypertherm has a good track record, I will spent the extra money in the long run it will same me aggravation.
thanks!
Hey thanks for sharing and for the videos, nice build. I especially liked the marking device. I work in 2mm (14 guage) sheet cutting large pieces from 3000 x 1500mm (10' x 5') sheets and would love to build a suitable machine with a marking device for the rivet holes. Yours is a very inspiring project!
By the way, anyone know if plasma cuts pre-galvanised sheet without problems?
Fiero, really nice build, you're a tallented man.
If you built again would you still use the same "210 oz/in NEMA 23 stepping motors" or would go a bit bigger ? You do refer to them as smal.
Thanks for the videos, inspiring, great machine!
A quick question for Fiero Addiction or anyone else who may be able to help; where do you source the multiwire plugs used to connect and quick disconnect the motors to the controller we see in the photos of your machine in the first couple of posts.
thanks!
Mark
