588,398 active members*
4,375 visitors online*
Results 1 to 3 of 3
    Jun 2009
    4
    Spindle will not start!
    Hi guys. I’m hoping someone might understand our problem and provide a solution!
    Apparently we were due to repeat a job from the previous day and after turning the mill on, booting the PC ad loading the job mill’s the spindle just wouldn’t start. We have tried running .tap files which worked fine previously with no success. There has been no software or hardware change.
    These are the settings our operator has asked me to mention:
    -> Spindle lockout is off
    -> Switch is set to Auto not Manual
    -> XML tweak is reading correctly
    The Mach 3 software will run the G-code as normal with all axes moving, but no spindle revolution. The technician has found that if he edits the G-code and replaces the M3 commands with M4 the spindle activates and runs as it should, however he states this is no good, as we don’t use any left hand cutting tools!
    Anyone have any ideas?
    Many thanks
    Dan
    332
    you might look at the M3.m1s file and compare to M4.m1s. They're in the macro folder I think.
    Jun 2009
    4
    AHA!
    M3.m1s was missing somehow! we created a new one based on M4.m1s and bang! off he went....
    Many thanks! saved a massive headache!
  1. spindle start/stop through VFD
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 01-09-2009, 04:47 PM
  2. Spindle won't start!
    By gamila in forum Fadal
    Last Post: 04-08-2008, 05:07 PM
  3. Sometimes spindle won't start, and ...
    By david_geng in forum Syil Products
    Last Post: 09-01-2007, 01:34 AM
  4. Spindle will not start:HELP
    By raps in forum Fadal
    Last Post: 02-28-2007, 09:32 PM
  5. Spindle Start Time out
    By JonLed in forum Fanuc
    Last Post: 03-17-2006, 07:00 AM
