587,801 active members*
3,507 visitors online*
Page 1 of 2 12
Results 1 to 20 of 38
    Jul 2008
    83
    Question Plasma cut quality questions *PICS*
    Made my first cuts today. Cut a 4" square with a 3" circle in the middle out of 16ga steel. I didn't clean it up and it was 98% dross free (pics below).
    Here's the problems I can see:
    1. There's a bit of taper.
    2. The cut is jagged around the radius of the circle.
    3. The corners of the square are rounded quite a bit.
    Is there a common problem for any of these that I should try to fix first? I'm using Mach3, SheetCam, and I drew the file with AutoCad.
    Photobucket
    Photobucket
    Photobucket
    Sep 2006
    5
    A mild vibration made by both axis moving at the same time can cause those jagged cuts. Decreased your feedrate or check the gantry system if it needs some lubrication.
    Mar 2009
    924
    tof1,
    for problem #3 you can loop the corners in sheetcam. What it does is go past the corner and come back in a loop or triangle to hit the next edge. I was watching a video in a post on CNCzone last night that showed a custom machine cut a spiral really fast and accurate! I think it was dnelso who posted it?
    Jul 2008
    83
    Is something mechanical the only thing that can cause the jagged cuts or can it be something with the programming?
    I actually checked the loop corners box but didn't see a change on the cutting path. Do you know if there's a setting in sheetcam that I can modify? I was also wondering if you do this, is it bad to cut over the gap of the cut you just made?
    Mar 2009
    924
    tof1,
    I am going to tag along here, I am hoping to make my first cuts early next week. I don't have a clue what to expect. I have to say those are some nice pictures. Someone should be able to give you some advice from them.
    Good luck!
    WSS
    Jan 2008
    2247
    The jagged edges most likely are caused by some roughness in the motion...if you put your hand on the torch while it is contouring...and you notice any vibration or roughness..it will show up in the cut. You don't mention what plasma, what consumables and what power level. Are you using arc voltage height control? If the z axis is too tight it can cause oscillation that will produce edge roughness as wel...but usually not as severe as the pics indicate.
    To minimize the taper...use the lowest power and the smallest consumable and the lowest speed for the material and thickness you are cutting. If it is a Hypertherm Powermax plasma..the FineCut consumables will dramatically iprove taper.
    The rounding of the corners is likely due to drive tuning....it looks like your gains are pretty sluggish (you can see some heat affected shadows where the motion essentially stops)....I'm not sure of the drive tuning methods for your equipment...but you should look into this. For plasma cutting you want maximum acceleration and de-acceleration....tune the gains so to the point where the machine starts to oscilate when exiting a sharp corner (verify with a pen in the torch holder) then back off slightly until the oscilation stops.
    Not bad for the first cuts!
    Jim Colt
    May 2007
    250
    Smile Brainstorm to help you
    Tof1,
    Could you share the design of your machine on CNCZONE? I think the experter at here can brainstorm to help you.
    Mongkol
    Nov 2007
    343
    I had the "jaggies" on my first cuts also. After watching the tip of the plasma closely I could see some vibration on movement especially on radial cutting. I added a brace to the top of my Z and that helped tremendously. Another way I have encountered jaggies is in the cut file itself. If a curve is made of a bunch of little lines the cut is going to appear jagged. Having a cut file wherein curves are really curves smooth's these out and cuts very cleanly.
    Jul 2008
    83
    I'm using a Hypertherm Powermax 1000, fine cut consumables, 40A, 150IPM, CandCNC DTHC. I upped my acceleration and "looped" the corners in Sheetcam. I only had time today for one cut and this one has sharp corners but still the jagged edges. The drawing is perfect, only 4 nodes in the circle and 4 in the square. I ran it with my had on the torch and I could feel a little vibrations. I'm surprised it's shows as much as it does in the cut. I'll try slowing the cut speed down to 130IPM and see if it helps with the taper. Still not bad for a second cut in my opinion! Guess I'll have to figure out a way to brace my gantry... Thanks for everyone's help!!
    Jul 2008
    83
    Something I was also wondering is my Z axis tops out at 80IPM how it's set up right now. Would the Z axis not being able to move quickly enough or something to do with a setting on the DTHC have anything to do with the rough edge??
    Jul 2005
    2415
    Quote Originally Posted by tof1 View Post
    As long as you not getting head "bounce" (visible up and down) then the jaggies are not coming from the Z motion. There are settings in the DTHC that allow you to fine tune the gap voltage (defaulted to 1 volt "span") and the "Tip Saver" (anti-dive) Percentage in the cut profiles. The max response of the DTHC is set by the total loop speed which includes the Z axis speed. You have to normally run the Z at reduced velocity during DTHC operation because there are no accleration curves applied. So if you start with 80 IPM you may be limited to 24 IPM in THC mode. The faster you can move the Z (and still keep resolution reasonable) the better your DTHC will perform. That being said, on flat cuts the 80 IPM is probably not the cause of the ragged edges. The rounded edges are from poor acceleration in the mechanics. The control software will compensate for the inability to accelerate by rounding the corners. While you can loop the corners that won't help you when you are trying to cut detailed cuts with sharp angles you don't have scrap areas to cut on.
    I have to agree that the problem looks a look like uneven motion. With MACH , which has constant velocity, and with 4 node circles motion should be smooth as butter. What is your final drive mechanics like? If it's stepper do you have belt reduction? Direct drives to pinon will run with poor acceleration and reduced resolution. Check everything for backlash.
    Get the workclamp onto the workpiece and grind off a spot for the clamp to get through the rust. Make sure you air supply is dry.
    Heed what Jim says. That 1000 will cut nicely if you pair up the right nozzle with the right current setting and the proper feedrate. I really like the cut quality I get with a 40A tip on material up to about 1/4 ".
    Contact me on the CandCNCSupport Forum and I can give you some settings for the Cut Profile for the DTHC to check.
    TOM Caudle
    www.CandCNC.com
    Mar 2009
    924
    If you are running with belts, can you see if there is a tighter spot at one degree or another in regards to your drive gear? It almost seems like it is rhythmic, maybe the bore is off center causing the belt to get tighter and looser at (almost) consistent intervals. Maybe check to see if anything is stuck in a timing groove (like a drill curly Q or a set screw not set deep enough if it is hubless). Other than that the cuts look good and nice tolerance! The jaggies are bothersome I see. with pitched rails you have to watch for tap holes exiting through the spur side, they can leave a nice bump to wear down if you don't file it or de-burr it somehow. Those are less rhythmic but will appear at the same spot on the table where a drive or pinion will show up anywhere on the table with a regular beat. Try cutting straight cuts about a foot apart with both X and Y and see if it is more pronounced in a certain spot. At least you can narrow down a mechanical issue somewhat.
    Good luck!
    WSS
    Mar 2009
    924
    Another thought, can you raise and lower the torch from were it is clamped and see if it has more jaggies extended and less jaggies retracted? It may be opposite if it is a single clamp, ie, more jaggies retracted because the weight is now over the top of the clamp point. You get the idea, it could go either way, but the key is if you see a difference.
    Jul 2008
    83
    I've pretty much narrowed the vibration down to my torch holder. I was able to get a much improved edge quality and I will still work on making it better. Now I threw a new sheet of cold rolled steel on the table and I cant get rid of the dross! I'm pretty sure the old rusty steel I was using before was also cold rolled and it cuts virtually dross free. What's the deal??
    Smoother edge.
    Dross free rusty old material and unavoidable dross on the new. I cut these right after each other.
    Jan 2008
    2247
    rusty steel always cuts with less dross than clean steel....there's noting for the molten steel to adhere to when there is rust...especially if it is on the bottom surface.
    To get rid of dross on clean steel: 1. Make sure your torch to work distance is at the torch manufacturers specification for the material you are cutting...and the consumable you are using. 2. Make sure you pierce at the pierce height and cut at the cut height....if you pierce at cut height you can damage a nozzle on the first pierce. 3. Keep increasing the speed...maybe 5 to 10 ipm at a time and check for dross. Usually.....for beginners with plasma...the problem is with using too much power, too big of a nozzle and cutting too slow. Use the smallest nozzle (I would use the Hypertherm FineCut nozzle) at maybe 35 Amps......and get your speed up in the 120 to 150 ipm range....faster if the dross is still there.....eventually you will find the DFZ (dross free zone......a speed range for the particular process and material that eliminates dross)
    Jim
    Jul 2005
    2415
    And once you find the magic DFZ you can build a profile in the MP3000 Cut Profiles screen. The upper parameters are for information (Notes) about the feedrates and amp settings and selected nozzle and you can use them to remind you what settings to use for a particular type of material. The lower section is actual settings for the DTHC to use (Preset Volts, etc). Be prepared to do a LOT of entries and testing because even slight variations will bring back the dross. If you start cutting smaller features the feedrates change and guess what......the dross shows up on those cuts. After hundreds of hours of cutting for our decorative cutting business, I found out two things:
    1. I could always get a dross free cut if I worked long and hard enough and made detailed notes and never cut anything but larger lines and arcs.
    2. I don't have enough patience to do #1
    I found that low speed dross is easier to remove with a simple tap with the angled edge of a cheap wood chisel. The time spent cleaning up cuts was less than trying to get perfect clean cuts. As you found, plasma cuts differently on different surface finishes, different thicknesses and different feedrates. Another dirty little secret was I found that having a tank of dilute HCL (Muratic Acid from the Home Center or pool supply) and hanging the cut pieces in the tank for a few hours did miracles and cut finish time by a lot. The acid etches off the rust, black mill scale and loosens the dross to a point a flat drop on concrete leaves you with just running a flap sander quickly over the cut edges before they go to paint or plating. WARNING the acid once it's diluted about 20 or 30 :1 from the muratic state is not too dangerous BUT it will oxidize (instant rust) anything metal in your shop that is exposed to the fumes. I keep my tank outside covered and a large box of Baking Soda handy. The pieces HAVE to be rinsed VERY well right after they come out of the tank and dried IMMEDIATELY.
    Lots of other secrets too but Dinner is calling to me!
    TOM Caudle
    www.CandCNC.com
    Jul 2008
    83
    Interesting. I'm using fine cut consumables with the settings straight out of the manual. Maybe I'll try spraying the back of the material with Pam or the anti spatter spray used for mig welding...
    Jul 2008
    83
    Thanks Tom, would love to hear your other secrets when your back!
    Jul 2008
    83
    Is it a no no to lower the amps below 40 with the fine cut consumables?
    Jun 2007
    268
    On 1/16 hot rolled with fine details i have cut my amps back to 25 with fine cut consumables, other wise its to hot and melts out the narrow strip of metal im trying to leave in the drawing... whether or not you are supposed to im not sure...but it doesnt seemed to have hurt anything yet...
    The acid works great, i got the idea from Tom also... but i have no place to keep the tanks outside so i gave the practise up... also dont spill it on any cement surface that you are fond of....
    I tried the anti spatter spray but gave that up also, in time you will find the sweet spot and the dross will be minimal... if you have a flat steel surface, like a welding table... try hitting the peice flat against it with the dross facing up...wear glasses as the dross comes off like bullets..
    EDD
Page 1 of 2 12
  1. Plasma cut quality
    By ajclay in forum Waterjet General Topics
    Last Post: 07-29-2009, 04:27 AM
  2. quality of plasma cuts and amp settings
    By justlarry in forum Waterjet General Topics
    Last Post: 07-23-2008, 09:15 AM
  3. Plasma cut quality
    By Apples in forum Waterjet General Topics
    Last Post: 04-13-2004, 03:18 PM
