588,231 active members*
4,468 visitors online*
Results 1 to 8 of 8
    Aug 2008
    3
    Haas TM-1 Post processor needed
    Does anybody have a good Haas post processor that they can send me? I have a TM-1 and am just getting started. Thanks.
    Nov 2008
    19
    hi , i just bought a new tm1 mill from haas. the belt that drives the spindle rides up and down the 2 cogs in clockwise - counterclockwise . it then rubs . haas are to put 2 belts on to cure it . the engineer tried to set the motor screws front and back and this helped but it still moves ad rubs . has anybody seen this before, does anyone know if their mills belt runs in the middle or does it ride up and down the spindle cog , thanks
    I SPOKE TO HAAS 2 DAYS AGO , STILL WAITING FOR A FORMAL SOLUTION AND RETURN OF 2 EMAILS
    Feb 2007
    498
    yes,i have the same problem for 4 years,makes alot of noise too,its an alignment issue
    i never did try to fix it,soon i have to replace the belt and will try to align it better than
    Feb 2007
    498
    as far as a post processor.for what software?i have one for master cam
    Nov 2008
    19
    has anyone got any pics or lins to pics of a haas tl1 or tl2 steady rest , thanks
    Aug 2010
    Well, I need a post for the TM-1P for Featurecam. If anyone has one that would be awesome. The post for the vf is not at all the same I hate having to adjust my speeds, feeds and depth of cuts all the time. Lack of power on this lil guy. Thanks again.
    May 2007
    312
    Just call your rep and they will email it to you. Their stock Haas mill post will work fine. They did create a custom post for my machine because we use 20 fixture offsets and it was based on the their stock haas post. Its been flawless.
    May 2023
    Re: Haas TM-1 Post processor needed
    Quote Originally Posted by SORCHEROR View Post
    Hi can you please send to me postprocessor for this machine with mastercam . thanks and regards
  1. Gibbscam Post processor needed for a haas
    By LEE-APEX in forum Post Processors for MC
    Last Post: 11-22-2013, 07:09 AM
  2. haas sl post processor
    By busted bit in forum BobCad-Cam
    Last Post: 09-21-2012, 03:54 PM
  3. Help Needed! Haas Mill Mill 2 Post Processor for Camworks
    By brettwemyss in forum Post Processor Files
    Last Post: 07-12-2012, 02:55 AM
