587,481 active members*
3,179 visitors online*
IndustryArena Forum > CAM Software > UG NX > NX Toolpath Visualization Time Study
Results 1 to 5 of 5
    Feb 2008
    86
    Yo....
    Is there anything inside NX5 tool path visualization that will allow me to semi accurately time study the simulated toolpaths? If so can I run the animation at the fastest setting when doing so?
    Mongo
    Feb 2006
    146
    Machine time
    On the operation navigator you can get the machine time for milling operations. If you open a file from a previous version you may need to add the column.
    I don't know of any way to see the time from the verification dialog
    John Joyce -NC Programming Supervisor
    Barnes Aerospace, Windsor CT
    Feb 2008
    86
    Smile Awesome!
    Most excellent Camster, I never expanded my operation navigator out that far because it would obscure the rest of the screen. This is where the 2 monitor setup comes in handy.
    At first the column was blank but the times filled in as I regenerated the operations.
    Thanks!
    mongo
    Feb 2006
    146
    NX Time
    Quote Originally Posted by mongo46538 View Post
    Thanks!
    mongo
    Mongo,
    In NX manufacturing you can display the Time and Length of milling tool paths on the operation navigator. On the Operation Navigator you can right click in the empty area and select Properties. Click on the Columns tab and you can change the order of the columns by selecting the time and Length columns and move them up on the list. You can make them #2 and #3 so you don't need to expand the navigator to see the time.
    Camster
    Feb 2008
    86
    Very handy Camster.
    You know all the tricks ..hehe.
    mongo
  1. Torque Cut tech study/info
    By NC Cams in forum Bridgeport / Hardinge Mills
    Last Post: 01-06-2009, 10:38 PM
  2. mechanical engineering self study.....help
    By yousif_1985 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-04-2008, 08:06 AM
  3. as a study HYperMill
    By spoiled in forum Hypermill
    Last Post: 05-26-2008, 05:17 AM
  4. Visualization of 5-axis machining in EMC2
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 12-21-2007, 02:41 PM
  5. g-code path visualization ...
    By deadalvs in forum European Club House
    Last Post: 05-10-2007, 10:43 PM
