587,143 active members*
4,628 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > warning light on one drive
    Nov 2005
    93
    I'm getting acclimated with hyper-terminal and the campbell board/Mach3 settings and have the low voltage side of the drives running temporarily from my laptop to test the limit switches etc. Anyhow, starting Mach3 and jogging (with no HV to the drives), On the Z drive only, after jog the axes up, or hit the estop the red warning light starts blinking about twice a second . Onlt the Z axes does it though and switching it to one of the other axes doesn't change anything. Jogging it down seems OK. Programming is the same for all three drives and the setting is the same from what I can tell in Mach3. Makes me think it is something with the drive? Any suggestions? How does one tell wether this is a slow-medium- or fast blink? Thanks much all. Wayne
    YCM-40 converted from anilam to Mach3 and lovin it.
    Feb 2007
    966
    Sounds like the Range setting is doing its job. As you are hitting the end of travel, the encoder error is increasing. Once it exceeds the r setting, it will flash an error. It also could be the current warning setting (yellow Led with trimpot adjustment).
    You have to get use to knowing the flashing speed by experimenting. I am adding a read command that displays the error in my next s/w version.
    Are you able to jog it both directions ok when not near a limit ?
    Aug 2007
    58
    [QUOTE=Larken;664544]. I am adding a read command that displays the error in my next s/w version.
    QUOTE]
    Hi Larken,
    Is it possible for the "used to upload" / or is it factory only update.
    Atb
    Derek
    Feb 2007
    966
    I should have field upgradeable firmware in a few months, but for now they have to be flashed on my bench.
    Larry
  1. cause for warning light trip
    By gtool in forum Viper Servo drives
    Last Post: 08-26-2009, 11:29 AM
  2. Replies: 3
    Last Post: 06-18-2009, 09:13 PM
  3. Replies: 6
    Last Post: 10-26-2008, 12:16 AM
  4. Maztrol M32 - No monitor display No drive light
    By nbodie in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-17-2008, 08:26 PM
  5. Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal
    By SCG11762 in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2007, 02:08 PM
