588,653 active members*
6,502 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Share Your Files Part or Art
Page 231 of 587 131181221229230231232233241281331
Results 4,601 to 4,620 of 11734
  1. #4601
    Oct 2009
    3
    That should work.
  2. #4602
    Mar 2005
    6
    inkscape/python/vista-64/R12_Dxf
    Switcher/Anyone, I have a vista64 and followed your video and tutorial, all installed fine(ensured the 4 files were infact in the correct directory, not a sub dir), but when I try to SaveAs, the python black cmd box comes up and stays as if it fails or never starts. So I never get the .dxf file. I have reinstalled inkscape 0.46 three times as well as your Inkscape_R12_Dxf.zip file. Any suggestions? Can my converted .bmp file be too complex, ie too many nodes? If I use explorer to drill down to the python.exe and double click it, I will get an error that says it can't find python25.dll, so maybe I can't execute it this way, or vista64 doesn't like this dll?
    I found this dll, copied it to several locations, including right next to python.exe, I can now run python.exe from the command line, but still can not create a .dxf yet
    I found that in inkscape I can export as an .emf file, import it into hycad then export a dxf from there.
  3. #4603
    Apr 2005
    3634
    pdarling,
    An easy way to find out If your Inkscape files are all setup correct, is to draw a simple square (4 - Nodes), then try & export that as a dxf from Inkscape.
    That will at the very least tell you If everything is setup correct.
    I run XP, but others have posted that they ran Vista with no problems, so it should work for you.
    The issue with to many Nodes is a drawback for Inkscape, the problem is when python trys to parse the bezier curves in the drawing path, it hangs Inkscape.
    One suggestion is Save your file, & Save often, as a Inkscape-SVG file, that way If the program does crash, you won't have to start all over.
    The Inkscape Nodes have always worked good for me, with less than 1,500 Nodes, I think it will max out at around 2,000 Nodes as far as the dxf export goes. Again the dxf/Node problem revolves around files with a large amount of bezier curves.
    Free DXF - vectorink.com
  4. #4604
    Mar 2005
    6
    Thanx again Switcher for all you have done in this field to help us. Yep, you were correct with your recommendation, I had too many nodes. I created some simpler designs and everything worked as promised with my vista64. The only issue I had was a missing python dll that I dropped in next to the executable. Everything worked after that, as long as I didn't use too complex of a starting image. Thank you once again.
  5. #4605
    Apr 2005
    3634
    Your welcome.
    If you have a cad/cam program that will work with .eps files that might be another option, since Inkscape will export an .eps?
  6. #4606
    Running Horses Custom Oval Gate Insert!
    visit http://www.plasmaspider.com/viewtopic.php?f=6&t=752 to receive 19 more of these custom designed oval gate inserts for only a small donation! It's for a good cause. Enjoy the file.
    Sincerely,
    Jason Henry
    Cascade Metal Designs
    www.customdxffiles.com
    Attached Files Attached Files
  7. #4607
    Jan 2006
    758
    InkScape .DXF Plugin issues
    Quote Originally Posted by pdarling View Post
    Switcher/Anyone, .......when I try to SaveAs, the python black cmd box comes up and stays as if it fails or never starts. ......I can now run python.exe from the command line, but still can not create a .dxf yet
    Hi there,
    Sounds like you are having exactly the kind of problems I mentioned in the post linked below...
    http://www.cnczone.com/forums/showpo...postcount=4601
    This is one of the main reasons I don't use InkScape for vectorization that much. It has great tools.. but is restricted to relatively un-challenging content due to the 'too many nodes' problem.
    If you have HyCAD then you really should try the vectorization tools it provides. File, Vectorize will open the interface.
    Hope this helps
    Danny
    What one man can do another man can do..
    BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
  8. #4608
    Jan 2009
    114
    Quote Originally Posted by Fatboy View Post
    Snip...Somewhere in this is IIRC, mention of a paint mask paper available in roll form. I went to the website and decided I would buy some as my current project progressed. Unfortunately I didn't bookmark the site and a search here is a daunting task considering that this thread alone is over 384 pages with 4600+ posts.
    Does anyone have the link for this site?
    Never mind, I found it in this thread:
    http://www.cnczone.com/forums/showth...t=39271&page=2
    It's from Beacon Graphics and it cost me $38.80 with shipping/handling.
    Now if I can get the impeller that I ordered last week for my dust collector on a brown truck I'd be happy.
    Thanks,
    Fatboy
  9. #4609
    Feb 2007
    6
    Steel eagle pics
    Quote Originally Posted by jimini View Post
    I didn't send a picture of the Eagle, sorry about that.
    Here's one incase you build it.
    Here are some pics of this same eagle made of steel
  10. #4610
    Apr 2005
    80
    Quote Originally Posted by jerlas View Post
    What gauge steel did you use? I had built the trex some time ago and used 10 gauge for him.
    Looks nice!
    steelandcopper.blogspot.com
    wakingbearstudio.etsy.com
  11. #4611
    Feb 2007
    6
    Quote Originally Posted by rpage View Post
    Looks nice!
    I made it out of 16 gauge steel The dxf I have needs some work as I had to force some of the parts together but it turned out all right in the end. If your interested I could upload the DXF for someone but I have to warn you it might have to have some modification made to it.
  12. #4612
    Aug 2009
    102
    Models
    Does anyone have any solidmodels that they can share . I
    have been looking and can't find much anyware .I would like
    to practice up on some 3D maching .
  13. #4613
    Jan 2006
    758
    25+ models online every month at cnc4free.org
    Quote Originally Posted by Kevin44 View Post
    Hi there,
    try http://cnc4free.org... 25 new 3D meshes every month.. via the download button. Also.. there are some meshes from other sources linked in the Share your 3D files parts or art thread at the link below..
    http://www.cnczone.com/forums/showthread.php?t=83378
    hope this helps
    Danny
  14. #4614
    Jan 2004
    24
    COAST GUARD INSIGNIA
    Hello the group. I have not posted in about a year. I need some help. Can someone please convert this Coast Guard insignia to DXF for me. I have been beating my head against the wall with PaintShop Pro. I can't get Autocad to recognize the .wmf file that I make.
  15. #4615
    Apr 2005
    3634
    I found a similar image, will this work?
    (dxf attached)
  16. #4616
    Jan 2004
    24
    Coast Guard Insignia
    Switcher you are the man!! Thank you so much. I have a grand-daughter that has her husband in the Coast Guard...career man. Well she wants a shelf thing with the Coast Guard Insignia on each end and their last name between them. They will be cut out and stood up and fastened to a pretty red oak board. The challenge will be how to fasten them on so it won't be so fragile. The letters of the name will also be a challenge to mount.
    Thanks again,
    Jerry
  17. #4617
    Feb 2008
    219
    Smile a new dxf
    hi all,
    have been working on a new dxf file. i found a old plate done by my aunt back in 94 and it had this angel on it. the original pattern was created by donna farley back in 1993. so i took the plate for inspiration and ink scape and i created this.
    ps. thanks switcher your help and support it is helping me to impove!
    would some one care to cut this angle out and post some pictures of how it turned out
    thanks
    ghostlx
    http://www.pure-teck.com/home.html
  18. #4618
    Apr 2005
    3634
    Jerry Dots,
    Happy to help.
  19. #4619
    Apr 2005
    3634
    ghostlx,
    Very clean looking project!
  20. #4620
    Apr 2005
    3634
    Christmas
    New DXF File ---> Design 350
  1. Share your 3D Carving files, Parts or Art
    By yohudi in forum WoodWorking Topics
    Last Post: 11-17-2016, 08:42 PM
  2. Lada
    By multiple in forum MetalWork Discussion
    Last Post: 01-18-2014, 11:00 AM
  3. Lets Share!!!!! (cut files)
    By Dustin407 in forum Waterjet General Topics
    Last Post: 08-24-2011, 11:46 PM
