587,633 active members*
3,057 visitors online*
Results 1 to 5 of 5
    Sep 2006
    1738
    Exclamation White particle board?...
    I really like working with white particle board when it comes to my shop. I have done some research on melamine. It does appear to be waterproof because it is a type of resin/plastic product.
    I'm just asking for a second opinion because I need to use some inside my milling machine enclosure that runs full flood. And other than keeping the actual wood dry, i'm not concerned with it being submersed, cause it wont be. It will simply be getting splattered on.
    Just thought I'd ask.
    -Jason
    Feb 2006
    7063
    The melamine surface itself is nearly indestructible, and impervious to most fluids you'd find in a shop, but you need to do something to seal all the seams, and make sure the melamine surface does not get damaged in any way - If coolant, or pretty much any liquid, gets into the particle board itself, it will disintegrate rapidly.
    Regards,
    Ray L.
    Dec 2007
    362
    Also make sure your particle board is high moisture resistant (HMR).
    This is a waterproof particle board intended for use in kitchens.
    Regards
    Geoff
    Dec 2008
    42
    At the big hardware stores like Home Depot and Loews, you will find an iron-on edge banding that is made of pvc. Very inexpensive. I think this and silicone at any joints would make for a fairly water resistant rig.
    Sep 2006
    1738
    Thanks guys, I don' think i'll be needing it really, I had plenty of stainless steel in the shop.
    Thanks though,
    -I'll use it somewhere though.
    -Jason
  1. Is white particle board waterproof?
    By CROSSHATCH in forum WoodWorking Topics
    Last Post: 12-15-2009, 04:46 AM
  2. MIL-C-13924 white powder?
    By ghyman in forum Material Machining Solutions
    Last Post: 02-19-2008, 10:28 PM
  3. Copper is white?
    By lloyd778 in forum Casting Metals
    Last Post: 02-08-2008, 10:38 PM
  4. Tool Gray or White?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 02-21-2006, 06:01 AM
  5. mdf and particle board
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 07-21-2004, 09:14 PM
