588,550 active members*
5,092 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Power Supply for Driver / Stepper
Results 1 to 5 of 5
    Oct 2009
    3
    I have been reading through some threads and would like to verify that this is correct. My driver needs 12 to 24V DC to operate 2A per axis with 2.5A max. My steppers only need 3.6V to operate. I am planning on rewiring an ATX PSU from a computer with the 12V to supply the appropriate power. Will this damage my steppers since it has to be 12V??
    Components links :
    http://www.lightobject.com/3-Axis-CN...KCam-P274.aspx
    http://www.mpja.com/prodinfo.asp?number=17748+MS
    Thanks a ton for any help.
    Sep 2007
    200
    a pc power supply won't cut it
    a stepper motor run with such minimal voltage will be slow and painful
    i noticed it is rated at 35volt max. use a 35volt supply. no joke.
    and your motors are 2a each make sure its a good 200-250watt power supply
    you don't need a switch mode or regulated supply
    just go for a torriodial type with a simple full bridge rectification
    Oct 2009
    3
    That is actually easier then. I just wanted to reassure that I was not going to have an issue with the steppers being rated at 3.6V and the driver at 12 to 24 V. I will hash up a 24V supply then.
    Thanks a ton.
    Sep 2007
    200
    cool,
    Mar 2008
    3655
    Hi evo. Welcome to the Zone!
    Some of this may help you:
    http://www.cnczone.com/forums/showthread.php?t=78713.#3
    CR.
  1. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  2. Very Low-Cost Stepper Driver And Power Supply?
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 03-21-2009, 05:58 AM
  3. power supply/ motor/ driver combo?
    By freddean2006 in forum DIY CNC Router Table Machines
    Last Post: 07-22-2007, 05:21 PM
  4. Some power supply and driver Questions
    By gone4pepsi in forum Benchtop Machines
    Last Post: 03-22-2007, 04:48 AM
  5. Driver, PC LPT and power supply schematicas
    By msnarouz in forum Stepper Motors / Drives
    Last Post: 07-30-2006, 03:11 AM
