We have been running for 4 months or so on our custom 4x8 water table. On average we run though about 1.5 sheets of 7ga, 11ga, and .250 sheet weekly with little issues. Average consumable life is around one to two sheets depending on complexity.
It seems every once in a while the 1000 will pierce fine, but as soon as it moves it will only sever; or it will be cutting fine in one direction, then on direction change it will sever and make a mess. Most time it's just spend consumables, or a poor ground connection.
Every once in a while it's a PITA to figure out and Today it's been impossible to get a consistent clean cut on any thickness of metal.
What we have done:
Checked water separators (both dry)
Checked filters (clean and dry)
New consumables
Flipped grates (needed it anyway)
Ground clamp directly on sheet
Raised piece delay from .25 to .40 sec.
Slowed travel speed from 80 to 40 (.250 plate)
I have previously checked the grounding and torch connections in the 1000.
Still cutting poorly, randomly severing and piercing in the same cut path.
Observations:
Running Mach with C&CNC hardware. DTHC working fine, distance to material is staying consistently under .100
TIP voltage in MACH is set and staying right around 140 for .250.
Piece set at .125, cut at .0625.
Air pressure at ~75 PSI.
Table is grounded to the plaz body, and outside to a ground rod.
Could it be a power issue at the unit? A ground issue from the table to unit? Sometimes we randomly get an red fault light on the front panel. Usually a power reset (or two) will clear it up.
I don't know how old the swirl ring is, could that be a major contributer?
Sorry for the long post, just wanted to be as thorough as possible.![]()
