588,648 active members*
5,258 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How do I machine a rod to a precise length?
Results 1 to 7 of 7
    Apr 2005
    101
    Dear Machinists:
    This is probably a stupid question, but I don't know the answer:
    I own a lathe and think I know the basic operations, but I really
    can't figure a simple way to finish a piece of rod (say 400mm long)
    to its precise length: I can feed it through the spindle hole and
    face the first end, then reverse and face the 2nd end, but I cannot
    measure the precise length (I own a 600mm caliper) while it is chucked...
    If I remove it to measure, then I'll have to locate the end precisely
    to cut just a little more... Nothing like when turning to a precise
    diameter where, after a cut, I can stop the lathe and measure with a
    micrometer without disturbing the position of the work and the bit,
    so my next cut can be very accurate...
    If I mount the rod "between centers", then I can measure without removing,
    but it's difficult to face, and I would need a special dead center on
    the tailstock...
    I could mount it on the mill, using 2 V-blocks, and mill the ends using
    the sides of an end-mill, but I never heard of doing it this way, and I
    fear the finish will be much worse than what facing on the lathe will
    achieve...
    Am I missing something?
    Nelson
    Jul 2005
    12177
    Face one end.
    Grip this end in the chuck holding only a very short bit and support the far end in a steady rest.
    Face other end and measure with the calipers; you should be able to get the caliper between the chucks jaws for the measuring.
    Apr 2005
    101
    Thanks a lot, Geof.
    Very simple, as I suspected, but I couldn't figure it out by myself...
    Nelson
    Mar 2008
    443
    Alternately, you could make some kind of a plug for the back ond of your spindle with a centerspot facing the chuck, to act as a dead stop. Clean one end, flip it around and push it up against the hard stop you just made. Now you can clean off the opposite end, take it out for a measurement, and put it back in for the final cut without worry.
    Aug 2005
    385
    If you take the time to make a plug, then take a few more minutes to drill and tap it clear through. Then get a piece of threaded rod and make a second plug a few thousandths smaller than the bore of the through hole. On this second 'plug' you'll need a blind hole in the back of it for the threaded rod to bottom out in and then you have an adjustable solid stop that you can run all the way out to your jaws if needed. (Word of caution, careful about this hanging out the back of your lathe, it's a death trap if you accidentally start it up in high RPM's with the threaded rod hanging out unsupported!)
    Oh yeah, double nut the rod hanging out the back or else it will loosen up and you're screwed accuracy wise~ We run ours like this for production parts ALL THE TIME...
    EXIT 85 Manufacturing "The best custom wheels, period" (www.exit85.com)
    Experts in low volume, highly complicated, one-off forged aluminum wheels
    Aug 2005
    385
    PS
    I always get metric screwed up, so I'm not sure if 400mm us 3" or 3'! JK but if your part is really long and you use a stop like we mentioned, take a few minutes to whip up a collar to slip over your stock so it doesn't droop in the spindle while you're trying to load the part against your solid stop. We had to use collars in our CNC Mori all the time on really long bars and occasionally on the manual stuff too~
    Apr 2005
    101
    Dear PixMan & AMCjeepCJ:
    Thanks a lot for your suggestions - I like them a lot, specially because, more than a
    single rod with a precise length, I'm interested in machining a few rods, all exactly the
    same length.
    Let me start working on the plug for the back of my spindle...
    Nelson
  1. Precise Hold Down Fixture? Help?
    By acecnc in forum Moldmaking
    Last Post: 10-15-2009, 07:25 PM
  2. Precise jig grinder
    By ck cues in forum Community Club House
    Last Post: 01-26-2009, 08:01 PM
  3. precise movements in mach....how do I...
    By cephjedi in forum Mach Software (ArtSoft software)
    Last Post: 04-05-2007, 12:52 AM
  4. Precise Radius Grinding?
    By Otokoyama in forum MetalWork Discussion
    Last Post: 03-06-2006, 12:45 AM
