588,166 active members*
4,878 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Sep 2005
    41
    Trials and Tribulations of a Noob
    I am definitely a noob at machine building and will be chronicling my machine build with many questions for the masters thrown in from time to time. I have been lurking the boards for a long time and am now at a point where I am no longer capable of making excuses as to why I have not built my own CNC Router already.
    My Router will be based on a number of excellent designs from this very board. I started out on Buildyourcnc.com and found a lot of useful information. I ordered plans but when I got the plans I was expecting plans for the machine he sells on his site but it was a far lesser machine. With the plans though, I was able to sketch out a few ideas for a machine of my own. I found two other machines that really lit the fire under my behind and got me off the board and into the garage once and for all. The first machine I found was the LionClaw LC50 which I do not believe is being offered anymore as I have not been able to get a hold of the gentleman who designed and built it. The other machine was the boards very own Grunblau's CNC Router design. I liked the integrated table design and the absolute beauty of his machine. I will definitely be using the table design from his build and might take a few other ideas from it as well.
    I just got my Gecko G540 and am waiting on my steppers and power supply from Keling to arrive in the mail. I picked up the lead screws (1/2-8 2 start) from McMaster Carr and DumpsterCNC's AB lead nuts. I have a 1 3/4 HP Porter Cable motor that I will be using for the spindle. I have so many more parts to acquire like bearings, collars, motor/leadscrew connectors and the like. I also have to pick up some wire and switches for the limits and home switches. This leads into my first of many questions I will have on here. The motors are Keling's KL23H284-35-4BT and the KL-320-36 36V/9.6A Power Supply. The wire from teh G540 to the Steppers should be what? I would like opinions on the best wire to use for connecting the motors to the G540. I am reading a lot about shielded/unshielded and not coming from an electrical background I am kind of in the dark in this area. I also would like suggestions and ideas on how to mount up the limit switches and if I will really need them at all since I can set limits in Mach3 as well as soft limits.
    I should have the table structure finished this weekend and start work on the gantry next week. I am taking my time and making sure everything is as perfect as my rudimentary tools will allow. It took me more than a week to get where I am now only because the battery packs die in my little saw way too fast. I finally broke down and went and bought a corded circular saw so all should be good now.
    An overview of my machine
    table size: 4x3
    Z clearance: Shooting for six inches
    Controller: Gecko G540
    Stepper Motors: KL23H284-35-4BT
    Power Supply: KL-320-36 36V/9.6A
    Controller Software: Mach3
    Lead Screws: 1/2-8 2 Start
    Spindle: Porter Cable 691
    DumpsterCNC AB Nuts
    I invite any opinions anyone has on my system so far and any ideas anyone has that might make my life a lot easier during this build.
    Jeffrey
    Attached Thumbnails Attached Thumbnails IMG_3888.JPG   IMG_3889.JPG   IMG_3893.JPG   IMG_3894.JPG
    35538
    Quote Originally Posted by Turbo1zz View Post
    Jeffrey
    Close the clothes dryer before it gets full of MDF dust.
    For stepper motors, use a stranded 20 or 22 gauge wire. If using home/limit switches, shielded wire is probably a good idea. I don't use switches on ine, I home it up to the hard stops. If you do this, make sure the machine is built tough enough to not tear itself apart. To use softlimits in Mach3, you will need to reference the machine position to a very repeatable place, or the softlimits won't be of much use.
    Sep 2005
    41
    Ahhh yes! The dryer. I've been working on that for a year now. I close it up and the next day it's right back open. Must be that five foot five gremlin I have running around the house.
    I'm sure my machine will be plenty strong to stop an axis should it get out of bounds but I want to limit the self induced stress to a minimum. I think I am going to hit up the Local Fry's and see if they have any four wire 20 gauge wire. What is the benefit of using shielded and non shielded wiring? why use it on the switches and not the steppers? I would think the steppers would need to be shielded or is it the other way around. wire shields from outside signals or holds signal within?
    Like I stated in my original post, I am new to all this electrical hoopla but I learn quick and all the information I receive here will greatly reduce my chances of catastrophic destruction.
    Apr 2007
    8082
    Shielding braid, or foil, will attenuate signals from getting in or getting out of the wires inside the shield. It doesn't completely stop the signals, just reduce the levels enough that they don't have enough interaction with other wires to affect operation. Homing switches operate on lower voltage and currents than the steppers, and the logic circuits they connect to are easily given false triggers by interfering signals.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Sep 2005
    41
    Ok, So I am back from my vacation in San Francisco and the motors and power supply were waiting for my return. I unpacked the contents only to find that one of the motors was damaged in shipping. The sides of the box were collapsed in so the loose motor floating around the box had no chance. I have to contact Keling about a replacement and hopefully it won't be a long process. I got a three prong plug and wire for the power supply and about 50 feet of four wire cord for the motors. I was able to find only 3.3K 1/4 Watt resistors and will try the local electronics supplier after work tomorrow to see if they have 3.5K resistors, but for now the 3.3 will work.
    I am a tad bit confused about the wiring of the steppers. The motors came with no instructions or wiring diagram so I do not know what wires are what. I've searched around but it seems everything I find is for 8 wire steppers. The steppers have red/green/blue/black wires and I know that they represent Phase A, /A, B, /B, but which wire is which? I would like to get all the electronics wired up and tested before I install them on the machine. I would hate to have everything installed and find out I have a problem later.
    Now back to the garage to fill my lungs with more MDF. :-D
    Attached Thumbnails Attached Thumbnails IMG_3907.JPG   IMG_3909.JPG   IMG_4839.JPG   IMG_4840.JPG
    Sep 2005
    41
    I found a wire diagram for the G540 and the Keling steppers on.. of all places... Keling's web site. DOH!!! haha. Well, I am going to include a link here for future searchers looking for a diagram.
    http://www.kelinginc.net/G540WD.pdf
    I was not able to find the resistors anywhere local so I will be ordering some from digikey and using the 3.3's till they come in.
    Now that I have the neccessary diagram I can go solder away. My lead screw support bearings came in as well so I am off to fine a forstner bit the same diameter. Rockler here I come. I hope to have more progress photos up later this evening.
    Mar 2008
    3655
    Hi Turbo. Everything looks good except the 36V PSU. This will seriously limit your rapid speeds with the 64V 387 motors.
    If you can exchange the 36V for a KL-350-48/7.3A, it would do much better with the G540.
    Also, the Newest and best motor for G540 is the 54V KL23H2100-35-4B, which will give improved performance over the 387. Maybe you could swap the defective 387 for one of these and use it on the longest axis.
    CR.
    Sep 2005
    41
    Quote Originally Posted by Crevice Reamer View Post
    CR.
    Thanks for the input CR, I am going to consider the power supply swap but for now the motors should be sufficient. I think the 48V PS will be the ticket in the long run. I'm kind of wishing I had seen the CNCRouterParts web site before I ordered everything because I would have saved money and gotten the right stuff to begin with. Like the thread title reads.. Trials and Tribulations of a NOOB!!! )
    Well, I got quite a bit done this evening. I got the Z axis all together and started on the Y axis gantry. I soldered up the three wires and got them ready to connect up to the servo motors. I'm really getting excited seeing all the pieces come together like they are. I'm definitely going to be happy when this thing is built and I can start letting it do all the drilling. I haven't drilled this many holes in I don't know how long.
    I am already thinking a larger table will be a must for my second machine. I am going to lose about 4 inches around the perimeter of the table making my final work area 20" in Y and 44" in Z. This will be fine for all my clock gears but some of the kinetic sculpture ideas I have will exceed the limits of the table. I am think maybe a 4x6 table next time around will work out better.
    Now I have to work out how I am going to mount the lead screws, AB nuts, bearings and collars. The X axis is going to be a piece of cake but the Y and Z axis are quite tight.
    Tomorrow I hope to get the X axis bearing mounts built and get the gantry mounted. I have to pick up another sheet of MDF for the legs and cross brase and unfortunately the roommates truck is in the shop.
    Thanks again for all the input. )
    Jeffrey
    Attached Thumbnails Attached Thumbnails IMG_4843.JPG   IMG_4845.JPG   IMG_4846.JPG   IMG_4847.JPG
    Feb 2009
    27
    This looks like a great build, thanks for sharing all the pictures.
    William Riley
    http://workbench.freetcp.com/
    Sep 2005
    41
    Quote Originally Posted by wriley View Post
    Thank you, I have always been one to let photos fill in where my words fall short. The saying "A picture is worth a thousand words" has always rang true for me. )
    After looking around for the best connection to use between the lead screws and steppers, I decided to hit up the local Grainger and picked up some Lovejoy Shaft couplers and spiders. I also picked up two sets of Abec7 bearings for the X axis. I didn't get nearly as much done this evening.. actually, I got nothing done this evening but I am plugging away at figuring out my alternatives to VCarve since dropping 600 on a software program is not in the budget any time soon. I have Mastercam X2 and Surfcam Velocity but getting them to do what VCarve does is not a task for the faint at heart. Any ideas on what is out there that can do what VCarve does for maybe not so many clams? I need to pick up some more dowel nuts and another section of angle stock and I should be able to get the machine all together. I'm getting super excited seeing everything come together. Can't wait to flip that router on and watch it carve away.
    Sep 2005
    41
    One step forward.. Two steps back. I am having to rethink my router mount. I have no idea how Grunblau was able to use the draw latches but I made attempt to use them on my router but the wood split no matter what screws I use. I am thinking of using HDPE for the mounts instead. This will give me a super strong mount that will definitely last a lot longer than the MDF would have. I may just give in and get a motor mount from K2CNC isntead. That way I will have a mount that will move on to the next machine and be done with it.
    I made the mistake of going to Rockler for a forstner bit with too much free time to walk around. I ended up with a couple T tracks with hold downs that I plan to put on the CNC. I will have to beef up the table now seeing as I will be cutting out slots to fit the tracks. I might just lay another sheet on over the table but then I lose three quarters of an inch of my clearance. I am just over four inches of clearance between the table and gantry and want to lose as little space as possible.
    I got all the drive parts together and now just need to figure out how I am going to attach the AB nuts to the moving bits. I have the X Axis figured out but the Z and Y axis are going to be interesting. I have a sneaky suspicion that I am going to have to rebuild the the whole Y,Z assembly again but we'll see. Grr.
    Attached Thumbnails Attached Thumbnails IMG_4853.JPG   IMG_4854.JPG   IMG_4855.JPG   IMG_4857.JPG
    35538
    When screwing into the edge of MDF, pre drilling to the correct size is mandatory, and you can NOT overtighten the screws. Another option is to use machine screws into the mdf. Drill and tap the mdf, then coat the threads with thin cyanoacrylate glue.
    Aug 2008
    33
    Two of the best things I have found:
    Best Option: Cross Dowels
    http://www.woodpeck.com/crossdowels.html
    2nd Option: Wood Nuts
    http://www.profhdwr.com/55008.htm
    Throw in some wood glue with the wood nuts and it works well. but no where as close to as well than the cross dowels.
    Sep 2005
    41
    Quote Originally Posted by The J View Post
    I'm actually using Cross Dowel Nuts for the majority of my build but they are a b it large to be using side by side like I need them for the latches. The Wood nuts would have the same problem screws would and would weaken the area more than I want do to the larger hole needed to insert them. I have decided on going with the HDPE plastic for the mounts since this will give me far greater clamping strength and won't give me the same issues the MDF does since I can drill and tap the HDPE more easily and have far greater clamping force.
    Sep 2005
    41
    Finally got a chance to sneak off to the garage for some major construction time. I got the gantry finished and test fit along with the Z axis assembly. The gantry sides came out exactly ninety degrees to the table and slide easily with zero slop. The gantry still needs to have the rails screwed down but other than the screws, lead nuts and motors, the main structure is complete.
    I was having a difficult time figuring out how I was going to attach the lead nuts to each of the axis. I followed Grunblau's design fairly closely and unfortunately he has not been on the Zone for over a month now so I was unable to get a hold of him to see how he installed his so I went ahead and figured something out for the mean time. I decided to run a groove down the length of the backer and attack a piece to the opposite side with groove to fit the lead nut and have more material to screw into. I will eventually be redoing the whole Z axis assembly in HDPE plastic so for now, this will work. I now just have to do the same thing for the Y axis and then drill out for the leadscrew bearings for all three. I am hoping to have all the electronics wired up and test by Sunday and then possibly install by the following weekend. I want to get her up and running soon so I can start making better parts for a more accurate machine.
    Attached Thumbnails Attached Thumbnails IMG_4867.JPG   IMG_4869.JPG   IMG_4870.JPG   IMG_4872.JPG
    Sep 2005
    41
    IT'S ALIVE!!!
    So, I haven't been on here too much because I've been focusing on getting the router up and running. I have so many projects for it that I wanted to get it up and running as soon as possible.
    So I ran into a couple problems but nothing major as of yet. I got all the cables and wires setup to run the motors and when I applied power to the G540 I got nothing. No light, no fault, nothing. I took it apart and checked everything and the fast blo fuse inside had blown for some apparent reason. I wired everything up properly and double/triple/quadruple check everything before plugging anything into a power source so I can only assume it was blown before receiving it. I went and picked up a pack of fuses, replaced the fuse, wired everything back up the same way and the little G540 came to life. Thankfully it was nothing serious. My other issue was with the set resister on the Y axis motor but that was figured out and fixed with no real big hassle.
    After a lot of searching on here and the web, I figured out the steps per rev for my setup. I found that I have to take 200 steps for the motors and multiply them by the number of micro steps from the controller then multiply that number by the number of turns to move one inch. This last part kind of messed me up because I was multiplying the number by 8 because I am using 1/2 - 8 lead screws but they are two start so really it is only 4 giving me a steps per of 8000. Once I set that up, the router moves 1 inch when I tell it to move 1 inch. amazing how that works, huh?
    Now I have to wire up the home switches and finish the router motor mounts and I should be making gears in no time at all. I do not believe I will be wiring up limit switches, I will just have to watch my limits when drawing stuff up.
    I am excited to no end that this thing is actually becoming a reality. I have been wanting to build my own CNC for a very long time and to have it together and running is just amazing. I seriously could not have done all this without all the amazing and talented people on this board. I especially would not have done it without the inspiration I gained from Grunblau's Router Build. Coming across his router build thread kicked my drive into high gear and got me to where I am today.
    I will be making a few parts to replace parts of the machine I feel could use a little help but for the most part, I am really happy with the way she turned out.
    Jeffrey
    Attached Thumbnails Attached Thumbnails IMG_4881.JPG   IMG_4894.JPG   IMG_4895.JPG   IMG_4896.JPG
    Aug 2003
    454
    Hi Jeffrey,
    Nice build - ahh, the ubiquitous road runner strikes again
    Just a point - I assume you will be stripping the whole machine down shortly to seal the MDF? This really is a must, and do it soon, before it has time to start absorbing moisture. If left too long, you will find it will start moving and the normal way it moves is in thickness. I don't know if you have ever had experience with damp MDF but it can easily double in thickness if it gets wet. Make sure you seal it well, particularly the edges. MDF is like a sponge and the first coat will disappear almost totally - depending on what you use as a sealer.
    Don't get carried away and start cutting too many gears before you seal your MDF or it may never get done and then, one rainy day, you will wonder why everything has tightened up.
    Good luck and enjoy this great hobby/pastime/affliction/obsession.
    Mike
    Mar 2008
    3655
    I do not believe I will be wiring up limit switches, I will just have to watch my limits when drawing stuff up.Jeffrey
    You can easily set up soft limits in Mach3:
    http://syilamerica.com/docs/Homing_V...%20Limits.html
    CR.
    Sep 2005
    41
    Quote Originally Posted by Mike F View Post
    Hi Jeffrey,
    Thanks, Mike. The road runner was the easiest and best program to test the setup since it was already loaded and ready to go. I had actually thought about drawing the skull and cross bones on the center of the table, a sort of warning to those wanting to touch the machine. :-D
    I will be stripping the majority of the machine down and coating it with Satin Polyurethane before I get too wrapped up in cutting gears. Here in mostly sunny california, I am a lot less likely to have major wood expansion but it's never a bad idea to give everything a coat to protect against spills. I also want to keep the grime factor down as well.
    Sep 2005
    41
    CR.
    Thank you CR. that is exactly what I have done in Mach. I am still poking around the software and am constantly having those "Aha" moments. I come from a background using Fanuc and Haas controls so Mach3 is more about learning where they hid everything. Now the only thing I need to start flinging wood dust everywhere is a post processor for Surfcam.
    Speaking of Software, is there a program out there that will do what VCarve does as far as tool paths? I am sure I could get the same results in Surfcam but would be cut completely different then what vcarve would do. My budget does not include another six hundred dollar program so an alternative would be nice.
    Thanks, Jeffrey
Page 1 of 2 12
  1. noob help...
    By jmodguy in forum Benchtop Machines
    Last Post: 08-15-2009, 11:10 PM
  2. noob trying to get some of the CNC pie
    By jestah in forum DIY CNC Router Table Machines
    Last Post: 04-25-2009, 01:54 AM
  3. Another noob looking for help
    By cuetipper in forum Want To Buy...Need help!
    Last Post: 01-15-2009, 03:41 AM
  4. Noob
    By Nuff_Said in forum Waterjet General Topics
    Last Post: 01-07-2008, 11:56 AM
  5. NooB Needs a little Help
    By js11110 in forum DIY CNC Router Table Machines
    Last Post: 03-21-2006, 12:41 AM
