587,086 active members*
2,878 visitors online*
Results 1 to 14 of 14
    Feb 2008
    4
    securing a spoilboard
    I apologize if this has been covered on here before or if it seems like a stupid question but: We have a Precix 9100 router with a t-slot table that has a hard black plastic top on it, with holes that allow the vacuum to draw thru a spoilboard. There is no grid to distribute the vacuum, precix instead relies on using many small holes to do the job. I've been using this router for over two years now and consider myself pretty well versed, however there's on thing we've never really gotten to work properly: the vacuum table. I understand the concept of skinning a piece of MDF or LDF to allow a vacuum to be drawn to hold parts down. We have tried doing this but met with an issue; how to properly secure the spoilboard to the table. On a shopbot, you can simply glue or screw it to the plenum piece, but with the t-slot table, we don't have that option. My question is simple: how does one properly secure the spoilboard to a table with a permanent plenum surface? Any helpful ideas would be HUGELY appreciated, since we are starting a giant job cutting some furniture grade mahogany plywood this weekend. Thanks in advance.
    Jul 2006
    1256
    My friends Thermwood router has nothing holding the spoil board down outher than the vacuum.Skinning the MDF is to make the surface parallel to the gantry.One trick is to use a 1/8" spoil board on top of the 3/4" MDF.Again the vacuum holds it down.Sorry I do not understand why the spoil board has to be fastened?
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Jul 2006
    1256
    Podzilla I re read your thread.Are you saying the vacuum will not pull the spoil board down?If so even if fastened down it will surley not hold down parts.With small holes your hold down pressure will be minimal.To hold down a 4X8 through an MDF spoil board you need a 20HP vacuum pump.Larry
    Feb 2008
    4
    thanks for the quick response. We have a 3phase FPZ regenerative vacuum blower that came with the table. I don't know the specific model number but it looks similar to this one. http://www.fpz.com/modules_cms/prcat...hp?cc=11&pc=18 It makes one hell of a noise when turned on and does have enough power to hold a single 4x8 sheet to the table well enough that I have no chance of moving it while the vacuum is on. The problem comes when we try to use it with a surfaced spoil board and piece of stock on top- it does not seem like there is enough pressure to hold both the spoilboard to the table as well as the stock piece on top, and as soon as the machine starts profile cutting, stuff starts moving around. I made a quick diagram to explain what i mean:
    I'm saying that there has to be something between the spoilboard and the table to keep the spoilboard from sliding around during cutting. I've searched high and low for this information and can't seem to find it anywhere. I figured it was typical to use double stick tape or glue of some sort but before i go marking up my table I just wanted some feedback from other people.
    Jul 2006
    1256
    We had the same problem,but the the outher way around.Our vacuum would not hold when cutting plastic.Sorry got to run.I will have a look at our set-up and post this evening.
    Try http://www.allstaradhesives.com/
    Larry
    35538
    All Star makes some double faced tape for this application. What you might want to do is get some low density or lightweight MDF, which will allow much more air to pass through it.
    Feb 2008
    4
    THANK YOU! Exactly what I was looking for. I just ordered a roll of their tape. In the meantime while I wait for it to be delivered, do you think that 3M mounting tape would also do the job?
    Jul 2006
    1256
    Hope your problem is solved.Just currious.The vacuum table never worked for 2 years?
    Did Precix not help you with the problem?
    larry
    Feb 2008
    4
    Its not that the table didn't work, its just that we never set it up properly. Precix was little help, it seemed like even they didn't know how to use their own system. They (or at least our tech support guy) had never heard of the idea of pulling a vacuum thru MDF. It just felt like they included the vacuum table because everyone else was doing it. I've been cutting with the vac table all weekend and all I have to say is "where have you been all my life?"
    Jul 2006
    1256
    Hay Pod,
    Thank you for the up date.Some times you try to help out and never hear from the guy again.We like to see that our help was use full.Really appreciate your responce.
    Many CNC buyers get zero support after signing the check and the customer thinks they are the blame.A favorite after sale responce is"you did not purchase our software so we can not help you"
    Keep us posted on your success.
    Try the 1/8"spoil board on top.I don't know why it works so well.
    MDF manfacturing is a thick paste put in a press and squeezed down.This results in two dense skins and a low density core.It helps if you seal the edges with tape.Give it a try.
    Let me know if it makes a difference.
    Larry
    May 2008
    79
    Re: securing a spoilboard
    I just stumbled on this very old thread. I can explain what is going on with the Precix if anyone is still interested. It is a design issue.
    BH Davis
    Apr 2018
    37
    Larger FT machines have the option of bolting it down. The machine comes preprogrammed to drill the holes in the correct spot on the board. It's then a case of bolting it down. Done.
    Dec 2018
    I just joined the forum. Yes, I would love to hear what you know about Precix. I just purchased a used Precix 9100. First CNC machine. I honestly don't know what I don't know at this point. Any assistance would be great..!!!
    Thank You..!!!
    May 2008
    79
    The problem is that those 1/16" holes do not allow enough air flow to work with a spoilboard. They'll sort of hold a piece right down to the plastic strips (if they are still there) but then you can't cut through without cutting into the plastic strips. The former head engineer of Precix has claimed in the past that this is how it should work and you just need to replace the plastic strips when they have been flycut too many times. It is no picnic to get those strips off........I know first hand. This was a terrible design right out of the gate.
    The solution is to mill off the plastic strips and then cover all those 1/16" holes with 4" wide aluminum tape strips. Just make sure the surface is good and clean from all minute pieces of debris.
    Then you can design and build a proper through vac hold down system that sits on top of the T-slot extrusions. Once the grid board is made and in place you just have to mill down into the air flow cores of the T-slot extrusions to transfer the air flow up to the spoilboard.
    I worked this all out on the used 9100 I purchased in the summer of 2018. My new spoilboard system works beautifully and is removable in 2' x 4' sections so the T-slots can still be used if desired.
    Feel free to contact me directly if you want to discuss this in more detail.
    BH Davis
  1. set to always cut 1/8 in to spoilboard
    By litleboy in forum SheetCam
    Last Post: 04-21-2014, 09:43 PM
  2. Need ideas for securing LED EDGE LIT ACRYLIC BASE.
    By Jimi Nep in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-31-2013, 03:59 PM
  3. Ballscrew securing
    By fragger6662000 in forum Benchtop Machines
    Last Post: 02-13-2011, 09:27 AM
  4. Securing the material
    By darkling27 in forum WoodWorking Topics
    Last Post: 04-27-2010, 05:12 PM
  5. securing ballscrew bearing / pictures of my homebuilt cnc
    By guru_florida in forum Uncategorised MetalWorking Machines
    Last Post: 02-04-2008, 09:43 PM
