587,278 active members*
3,254 visitors online*
Results 1 to 3 of 3
    Dec 2008
    14
    Question Communications from PC to CNC
    I have a Mazak AJV 60/120 with an M-Plus controller. For the past (3) years it has been giving a tape error when drip feeding from the PC, but only if the program is longer than about 10-15 blocks. It will load the entire program into the memory but will not make it through the program when drip feeding.
    I have checked all parameters that were set when I had it working and they are all still set the same. I called Mazak and they said it sounded like the QX something, something, something, board. I had a repairman check it out and he replaced the board and $3500.00 later (not counting the board), still no luck. the board was returned to Mitsubishi since it did not seem to be the problem.
    Can anyone tell me how to fix this or what to check?
    Mar 2005
    988
    That card would've been my guess (if all other settings are correct)....
    But question: You're drip feeding a program that might be as short as 10-15 blocks???
    It's just a part..... cutter still goes round and round....
    Dec 2008
    14
    Correct. For example, if I send just a drilling program with 4-8 locations, it will work fine. Any more locations than that it will only make it so far and stops. It seems like a buffer error????
  1. Replies: 3
    Last Post: 05-15-2011, 05:04 AM
  2. PC to CNC Communications
    By ignisuti in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-06-2009, 11:50 PM
  3. I need help with communications
    By peterpan3 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-24-2009, 12:44 PM
  4. 98 HAAS VF-3 communications
    By jeff@rans in forum Controller & Computer Solutions
    Last Post: 10-08-2008, 07:11 PM
  5. PDA Communications
    By rfmerrill in forum MetalWork Discussion
    Last Post: 02-10-2005, 02:03 AM
