588,221 active members*
4,412 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 6 M Alarm 401 and 420 Y Axis
Results 1 to 7 of 7
    Aug 2005
    82
    Hello
    I have Kitamura my center 2 with fanuc 6 m
    when strat up. it alarm 401 and 420 Y axis
    ( Sometime can start up for few miniute ) then go alarm as I said.
    I have clean Brush, Check Drive By Swap X and Y.
    Bolt drive is seem OK
    Where to Check other?
    Someone can help will be appreciated.
    CB
    Sep 2007
    371
    Alarm 401 can be caused by alarm 420, alarm 420 is a position deviation exsessive alarm in the Y axis. If all connections are OK and you already swap the dives and checked the motor, swap the motors with encoder if possible and test.
    Good luck.
    GP.
    Aug 2005
    82
    Hi
    Yes I aslo swap the motor + Endcoder between X and Y axis
    The Error come to X axis.
    I have not check all cable yet. But I have open the plug case. Look OK.
    ( Not measure Ohm yet , for case wire is broken in side )
    I think cable may be OK.( becuase sometime can start up for few minute. )
    Any other Suggestion?
    Thank you in advance
    CB
    Sep 2007
    371
    If you swapped the motors and encoders and the problem goes with the motor, then the problem in in the motor or encoder.
    I suggest that you swap only the encoders now, if the problem goes with the encoder then the encoder is bad, if the probem stays in the motor then the motor is bad.
    Good luck.
    GP.
    Aug 2005
    82
    It take long time for me to test that
    But I found too many wire to remove to test .
    I found new symptom.
    When turn on the machine normally. It quite offen alarm 420
    Or if it can get ready. May only few minute then Alarm 420.
    Today I Turn on by Press " P' and " CAN ' botton.
    It seem machine always get ready like normal
    and can Run Whole day.
    I belived tomorow If I turn on machine normally.
    It will Alarm 420.
    So For this sympton.
    May someone can help me to solve real problem.
    CBmach
    Oct 2007
    179
    If you have not checked already make sure the velocity command from the CAV cable on the mother board is wired the same on each axis.
    Also if you have an intermitent fault in another area of the machine ie. spindle drive it can sometimes cause the servos to jump on switch on causing your alarms 401 and 420 but actually the fault may not be sevo related at all.
    John.
    Jan 2009
    117
    Try to fit a round "spacer" (made from thin gasket material) between the encoder and motor flange. This will reduce the pressure on the encoder shaft and disk. Do this for the "faulty" motor Y-axis.
    You might have a problem with the master PCB as well. Swop the master PCB with a similar machine but take proper note of the short-pin settings.
  1. Fanuc Om-417 X Axis Servo Alarm
    By intermax in forum Fanuc
    Last Post: 05-11-2022, 11:55 AM
  2. Fanuc OM w/ no. 2000 axis interlock alarm
    By bikebasher in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-10-2022, 05:38 PM
  3. Z Servo Axis 434 Alarm on Fanuc 6M
    By barchdesigns in forum Fanuc
    Last Post: 09-16-2009, 06:56 PM
  4. Fanuc 18I Z axis servo Alarm 410
    By Ninus in forum Fanuc
    Last Post: 09-22-2006, 05:16 AM
  5. Fanuc 21-GA_416 Alarm-Axis Disconnect
    By lasermike in forum DNC Problems and Solutions
    Last Post: 03-10-2005, 07:49 AM
