587,236 active members*
3,588 visitors online*
IndustryArena Forum > CAM Software > Mastercam > error message during rough flowline or contour
Results 1 to 2 of 2
    Apr 2008
    42
    During the process of choosing geometry to run a rough contour or flowline tool path I get the following message:
    "check and drive stock to leave are identical, you may wish to adjust check stock by plus or minus cut tolerance for crisper tool motion near external sharp corners formed by check and drive geometry"
    How do you adjust the check stock tolerances at this point in the process?
    Dec 2008
    3122
    Consider this more of a "Warning" insted of an "Error"
    This is letting you know that when machining the "Drive Surfaces", you may actually touch the "Check Surfaces"
    Values for each of these selections is input on the Surface Parameter page after you have selected the desired surfaces
    The Warning appears each time you go the regen the operation unless you select to not display future warnings for this session
  1. Error message CR1 etc.
    By NPI in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2010, 03:34 AM
  2. Replies: 3
    Last Post: 04-28-2010, 09:32 PM
  3. Bad contour error
    By apylus444 in forum BobCad-Cam
    Last Post: 10-03-2008, 08:25 PM
  4. G83 error message
    By HBFixedGear in forum Fadal
    Last Post: 01-30-2007, 04:42 PM
  5. Bad Contour Error while Pocketing
    By sundara in forum BobCad-Cam
    Last Post: 05-29-2005, 12:10 PM
