588,277 active members*
6,274 visitors online*
    Jan 2008
    5
    vacuum table question
    I have a new job i just started and i'm a little lost. I am use to Hass mills cutting metal and now i am using a gantry style router with a vacuum table with mach3 software.
    My question is:
    #1.the vacuum pump has a water tank what's with that
    #2 the water starts to get worm (too hot to touch the tank but does not burn)
    #3 the vent stack (direct off the tank) seems to have a high volume of steam. Is this normal.
    #4 the pump does not sound good ( cavitation ) when i do a good job sealing the table should their be some flow/leakage to help the pump?
    this pump i believe came from china and their is not one marking in it. No brand name, no electrical spec, nothing
    any help would be appreciated
    Mike
    35538
    There's some talk about a pump like that here, between maybe post #15 and #33.
    http://www.cnczone.com/forums/showthread.php?t=91514
    Jan 2008
    5
    thanks so much
    Thank you very much. You saved me a lot of time.
    Jan 2008
    5
    liquid ring vacuum pump help
    now on to learn proper operation.
  1. DIY Vacuum Table
    By Baudros in forum DIY CNC Router Table Machines
    Last Post: 11-02-2013, 06:42 PM
  2. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  3. yet another vacuum table question....
    By boomerize in forum DIY CNC Router Table Machines
    Last Post: 08-18-2009, 06:16 PM
  4. vacuum table
    By Todd W in forum DIY CNC Router Table Machines
    Last Post: 07-11-2008, 05:42 PM
  5. Vacuum table
    By balsaman in forum DIY CNC Router Table Machines
    Last Post: 01-05-2004, 03:18 PM
