587,215 active members*
3,175 visitors online*
Results 1 to 7 of 7
    Aug 2006
    21
    tapping metric thread on fanuc
    Im tapping 3 holes M3x.5 in 304 ss on a fanuc robodrill
    to get my feedrate do I do .5 x .03937 x 150 rpms??? to get my feedrate??
    I never do anything in metric so not sure if my calculations are correct.
    Also a g82 spot drilling cycle axample would be helpful.
    Thanks!
    Jun 2008
    1511
    Because you are in metric mode you do not need to multiply by .03937. You just take your .5*150=75.
    I assume this thread is in reference to the “robodrill” one you posted in the fanuc forum??
    Stevo
    Aug 2006
    21
    Quote Originally Posted by stevo1 View Post
    Stevo
    Thanks again for the replie Stevo!
    Dec 2008
    3122
    Simple formula
    Feed per minute = Pitch x RPM
    If you alter the RPM at any time, the feed would also need re-calculating.
    Another common solution when tapping, is to use feed per rev ( G95 ), so the feedrate you dial in is the pitch of the tap, you can alter the RPM but the feed is still locked to the tap pitch and will not require adjusting.
    The only problem is that you must change back to G94 immediately after using the tap, to avoid the next tool having 10" per rev feeds, for example
    ie.(tapping)(imperial)
    G95
    G99 G84 Z-.75 R.12 F.0394 (M6x1.0mm tap)
    Xx.x Yy.y
    G80
    G94
    ie.(tapping)(metric)
    G95
    G99 G84 Z-19.05 R3. F1. (M6x1.0mm tap)
    Xx.x Yy.y
    G80
    G94
    ie.(spotting)(G81 and G82 do the same thing-one CAM software outputs G82 if you put a dwell in the cycle)
    G99 G81 Z-.1 R.2 F.01 (90° spotdrill)
    Xx.x Yy.y
    G80
    G94
    May 2006
    10
    You can also add a Q to the G84 line. This would define a peck tap, which is handy in deep holes.
    G99 G84 Z-19.05 R3. Q.05 F1.
    Brian
    Apr 2010
    3
    Hi There , I am new to The CNC Zone , and if any one could help, I want to do Metric Tapping on Fanuc 21M Control, its a Blind hole and need to Tap 5mm Tap , what could be the Feed Rate (.8pitch x300rpm=240 F ) is it correct or i should use any other M code Prior to this g84 line ?
    Please guide me
    Aug 2009
    684
    On our Fanuc 31i we need to put an additional M29 before G84 to put the machine into Rigid Tapping Mode.
    DP
  1. Metric rigid tapping, TM 1
    By Shop junkie in forum Haas Mills
    Last Post: 03-12-2013, 11:25 PM
  2. Standard tapping and Metric Programming.
    By Dull Tool in forum MetalWork Discussion
    Last Post: 03-12-2013, 11:23 PM
  3. Rigid Metric tapping... Need a bit of help
    By saabwagon in forum Haas Mills
    Last Post: 01-23-2013, 06:26 PM
  4. metric tapping
    By kurt_laughton in forum G-Code Programing
    Last Post: 10-02-2008, 03:54 PM
  5. metric tapping
    By fourperf in forum Fadal
    Last Post: 12-14-2007, 03:18 PM
