588,528 active members*
6,593 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How is this manufactured???
Results 1 to 20 of 20
    Jan 2009
    15
    Question How is this manufactured???
    This is a spindle OD = 7/8" with 48 splines. Is this a partial extrusion...? EDM...? Forged...? Casted...? I am lost, any help would be MUCH appreciated.
    Dec 2009
    14
    can u send me the
    drawing
    i can try to help u out
    Jan 2009
    15
    oops! Forgot to attach the pic.
    Jan 2009
    15
    Feb 2006
    992
    it's look like they are mill with a saw.
    The best way to learn is trial error.
    Dec 2009
    14
    this can be easily done using edm machine.
    if ur left with no option other than cnc milling milling machine, the component can be done using 4th axis arrangement. but the cutter leaves its traces at the ends. length of the spline should be more than the working length.
    Mar 2006
    58
    It would be super easy to do with a rotary table and a shaper. However, they probably use a broach, knurl, or EDM.
    Jan 2007
    1389
    Splines while you can make them on a edm or 4th axis they will never be 100% right
    I forget the proper name of the machine a gear shop uses, I wanna say a hob.
    a broach is pretty much for intenal splines. they do have them for od work as well
    We used to do thousands of parts (lathe work) splines for aircraft shafts. I can still picture the machine my vendor had but cant remember the proper name.
    15362
    Hi wilson248
    You have a lot of answers, You could do this your self with a manual mill a fly cutter ground to the shape of the spline, a 4 axes/ indexer or rotary table to hold the work
    The hole is nothing special you could drill this part on a lathe thread Etc
    The method for production would be to use a gear Hobbing machine, this process is very fast for such a spline, they can of cause be roll formed as automotive axles use this process
    If you look close at the part you will see how it was done, you can even measure what the diameter of the cutter they used by the radius at the end of the spline
    Mactec54
    Mar 2006
    2712
    Delw is right. Splines are commercially cut with a spline hobber. Splines CAN be cut with the proper form tool on a mill with an indexer. The form is usually an involute spline. Sometimes a straight sided spline.
    Accurate splines have about the same degree of difficulty as accurate gears.
    Dick Z
    DZASTR
    Jan 2006
    4396
    Quote Originally Posted by Delw View Post
    If you look at where the Spline Ends on the shaft it decreases. So it would have to be a Hob (like a Barbra Coleman) or a Slot Saw.
    The fastest and most accurate way to make this would be a Hob.
    I would say Hob as well.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Feb 2008
    586
    Could be done with an external rotary broach. Slater.
    Jan 2009
    27
    Check this out at Youtube.
    [ame="http://www.youtube.com/watch?v=fR2duvm3lPo"]YouTube- GEAR HOBBING M20/32 CITIZEN CINCOM[/ame]
    Jan 2006
    4396
    Quote Originally Posted by citizencnc View Post
    I have been dying to use one of these. Ever since seeing the Tsugami and the Star's this is one of the Must Does this year hopefully.
    Toby D.
    Schwarzwald
    Sep 2006
    36
    METHODS
    Quote Originally Posted by wilson248 View Post
    You have an SAE J500 SERRATION. As others have posted, may be hobbed, gear shaped, rotabroached, rolled, and so forth, here is the old data for example, current data will be close.
    Cheers, Les
    Sep 2006
    36
    Post SAE J500 SPLINE
    You have SAE J500 spline, here is some data.
    Your part as has been stated, may be hobbed shaped, rolled, in production quantaties, do it yourself; some kind of INDEXER for 48 Teeth. fly cutter ground to angles listed in data for 7/8-48t straight sided spline.
    Cheers,
    Jan 2009
    15
    Thanks for the info!
    Very helpful everyone!
    Oct 2007
    37
    Cool video. I used to work at a gear making company i even worked on manual hobbers. Dirty dirty work lol the hobbers ran oil coolant and even though they were "manual" it was just push a button and let them run after it was setup. They didnt have anything as fancy as the bar feed hobber in the last part of the video though. They did have the biggest gear hobber in the state and one gear they worked on was 20000 lbs . Neat to watch, but truly boring work.
    Oct 2005
    251
    For high production quantities (automotive) the process is done by rolling the splines on the shaft.
    Oct 2007
    37
    Quote Originally Posted by ctate2000 View Post
    It all really depends on how much taper they want in the back of the spline since hobbing leaves quite a bit.
  1. Need advice about wood product, manufactured in Canada
    By Litografa in forum Canadian Club House
    Last Post: 01-10-2010, 04:26 PM
  2. How to get your PCB design manufactured ?
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 07-30-2006, 03:08 AM
  3. Pricing A Cnc Manufactured Picture Frame
    By TheNigerian in forum Community Club House
    Last Post: 06-23-2006, 04:59 PM
