588,457 active members*
5,163 visitors online*
Results 1 to 16 of 16
    Nov 2008
    37
    Vacuum Pump Question
    I have a 4' x 4' router. I was wanting to know if anyone has any suggestions on a vacuum pump. What size have they used and any certain models. Thanks
    May 2009
    23
    I also have a 4 x 4 table router. My current setup uses two shopvac heads. This seems to work OK, although more vacuum is always better. If I plate off the open portions of the spoilboard it will hold a 6 x 18" piece of flat material as long as I don't push it too hard. Basically it comes down to making sure you block the small pieces in to help keep them from sliding. A vane pump would be nice, but I need to stay. within the hobby budget.
    Jul 2006
    1256
    Hay GrassGrower.
    Good question of vacuum.
    First I would ask new life for more details on his shopvac system.I admire the guys who get by cheap.
    If you cut at 600IPM you probably need at least 10HP of vacuum.If cutting small parts and using perimeter gaskets and zoning a shop vac may be enoughAnother methog would be to cut in 2 or more passes.After the first pass,brad or nail the parts to the spoil board.It works as well as a 20HP vacuum pump.but now you have 2 nails or holes which may not be acceptable.
    Check ...www.staradhesives.com for some useful ideas on hold down.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    May 2009
    23
    Further details, vacuum system
    My vac table is split into 4 quadrants with 1 shop vac head mounted with 2" PVC pipe to supply vacuum to 1/2 of the table which has 1.5" square grids x 1/2"slots. There are ball valves to shut off unused quadrants. I use soft foam rubber strip to seal out the perimeter of the spoilboard. I have trouble pulling down warped ply although flat material holds pretty good as long as it is smooth and clean. This works because I have a limit of about 150 ipm in my control. Not a speed demon but I am a hobbiest and haven't tried to make the system pay for itself yet.
    Someone trying to make the mortgage payment would probably want a system that would allow faster feeds. Seems to me it all depends on what you intend to do with your machine.
    Newlife
    Jul 2006
    1256
    THANKS for the reply.You are correct.150ipm and a shop vac is OK IF NOT NEEDED for income.Personally I would prefer to watch a 50ipm router than watch the seasion final of LOST for the millionth time.Got to go,the final episode of Boston Legal and desprite house wife's is on,AGAIN!!!!
    Nov 2008
    37
    I have a regenerative blower that I use now. It works pretty good. I planed my spoilboard @ 200" a minute and it held good. I need to modify my grid table, my seal needs to be closer to the edge. What does everyone else use for spoilboard?
    Jul 2006
    1256
    Sorry got the address wrong
    http://www.allstaradhesives.com/
    Apr 2005
    1268
    Newlife;
    How about some more info on the soft rubber seal for the edges of the spoilboard. I have a similar setup with 4 quadrants and valving using a 6.5 Horse Shop Vac. I've also added a 1/4 inch air inbleed to the vacuum header which I hope sill help prevent the shop vac from overheating on long cuts. I don't know if it was needed but it didn't hurt anything and the $100 for the vacuum is a lot to me so I want to protect it.
    I also added a vacuum gauge and was surprised that the vacuum was less than 5 inches of vacuum. Thought it would be more. Seems to work OK on MDF cuts at 100 IPM. Thanks for the information.
    bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    May 2009
    23
    More details
    I currently use 3/8 X 1/2 foam w/ adheasive backing from MCMASTER Carr #8694K13. This is slightly too tall for my grid and holds the spoilboard up off the grid table resulting in a slightly changing spoilboard top surface between clampings. It appears if I had 1/4" high foam, the vacuum wouldn't have to compress the foam as much to get the spoilboard and the grid top to mate and stay stable. As it is if there isn't a good vacuum seal on top of the spoilboard eg too much open space, the spoilboard doesn't get pulled down flat to the grid top, resulting in a uneven work surface. -sigh- lessons learned.
    I am considering upgrading to a replacement vacuum head from Grainger to replace both of my existing shop vacs. Grainger Item # 4M944 price (ea.) $178.25 Brand AMETEK LAMB Mfr. Model # 116859-00. This is a 3 stage 240vac unit pulling 115" H2O. I think this should be much higher vacuum than I am currently using but I will need to check with a vacuum gauge before springing for this system.
    Any idea on whether this is more than I would get with a regenerative blower?
    Jul 2005
    12177
    Rather than spending money on something that only gives you one third of an atmosphere of vacuum look into get a secondhand vacuum pump, or find a junk compressor and convert it into a vacuum pump:
    http://www.cnczone.com/forums/showthread.php?p=691162
    Shop vacs simply do not have enough suck to hold things down effectively. That one rated at 115 inches of water is quite good for a dust sucking vac but a full vacuum is equivalent to 384 inches of water. To hold things down you really need at least a vacuum equivalent somewhere between 260 and 333 inches of water.
    And to put things in the proper terminology you need a vacuum pump that can create a vacuum of between 20 and 26 inches of mercury.
    May 2009
    23
    Thanks for the input Geof. Question, can a old air compressor move enough CFM to get a good holddown?
    Newlife
    Jul 2005
    12177
    Quote Originally Posted by newlife View Post
    .... can a old air compressor move enough CFM to get a good holddown?
    Newlife
    The answer to this is three more questions:
    1, How big is the compressor?
    2, What surface area are you holding down?
    3, How much leakage do you have?
    Answering 1, and 2, is easy, but 3, is almost impossible to answer.
    If you have a nice flat surface, good rubber seals, non-porous material and no leaks in the vacuum lines you will probably be able to pull a vacuum of 24 tp 26 inches of mercury with a very small pump capable of only pumping 1 or 2 cubic feet a minute.
    Nearly always your leakage is going to be more when the vaccum is low, i.e. when you have just turned the system on, but as the parts snug down against the seals the leakage diminishes. To overcome this initial leakage you may need an enormous pump that can get enough vacuum despite the leakage to start pulling the part down against the seals. This is partly why you see commercial machines with vacuum pumps capable of moving 40 or more cubic feet a minute driven by a 50 hp motor.
    I don't think you are in that league so you more or less have to work with what you can get and one advantage of going the old compressor route is that you will probably have a tank that can be used as a vacuum tank. I know some people suggest that compressor tanks are not suitable for vacuum but so far my conversion has worked okay.
    The advantage of a tank is that you can pump this down as faras possible with your vacuum pump and then open the valve, a big valve and big lines, to the vacuum table. This gives a strong surge which can overcome the initial leakage and snap the part down on the seals so the pump can continue to handle the leakage from there.
    Nov 2008
    37
    I purchased my blower off of Ebay. I would recommend spending the money for a blower. I've been around routers with regenerative blowers and positive hold down systems. If money was no object I would say buy a positive hold down system. I've seen them pull a sheet of 1" UHMW flat. But like everyone else I have to choose where to spend my money. Mine seems to work with a regenerative blower. I just got my router finished, so I'm no expert. I'm going to try and use mdf for my waste board. I thought I would give my 2 cents worth.
    Nov 2007
    368
    so what is a good Vacuum?
    Regenerative
    Rotary Vein
    displacement or screw? also what brands?
    35538
    Depends on the system your using.
    My last job, the machine used a Becker rotary vane, I think 7 or 10 HP, connected to 18 pods.
    I started a new job today. The machine there has two 40HP pumps, for a 5x10 table.
    Jul 2006
    1256
    Gerry good luck on the new job.We only have 25Hp on the 5X10 table,a busch.the owner says it cost over 20grand and we still have problems holding slick plastic sheets.Carpet tape anyone?Works too good,it is almost impossible to remove the parts.
    On air or non-air tanks.An air compressor tank is rated for positive pressure,usually under 200PSI.An air tank withought internal support will fail with over 14PSIG of negative pressure.I have a small BUSCH 1HP rotary vane pump and if you want to send me your air tank,I will gladley make it into a pancake with 29.5"Hg.With the small pump,I would pull a vacuum on wet fiberglass on 4X8 sheets of wood.The negative pressure was 48x96x14psi=64512 lbs on a 4x8sheet.I could suck the resin through 3/4"ply.
    So what does this have to do with hold down?Nothing.A closed system can be very powerful but a live system relies on CFM or airflow for holdown.DO NOT use an air compressor tank for negative storage.I think I will bring out the double sided tape
    Larry
  1. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  2. Vacuum Pump for Rubber degassing question
    By CNC-Dude in forum Glass, Plastic and Stone
    Last Post: 01-18-2010, 04:31 AM
  3. OK, I've got my vacuum pump. Now what do I do with it?
    By DougO in forum Work Fixtures / Hold-Down Solutions
    Last Post: 07-09-2008, 08:35 AM
  4. Vacuum Pump
    By jfcamilo in forum DIY CNC Router Table Machines
    Last Post: 04-29-2008, 09:45 PM
  5. Where to get a vacuum pump
    By whiteriver in forum DIY CNC Router Table Machines
    Last Post: 05-11-2004, 04:47 PM
