Hello.
Does someone know how i fix the problem at the post #38?
Robert.
Hello.
Robert.
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
The best way is to deal with the Artcam reseller in your locality.. Also watch the Videos and post the same in artcam forum..I hope you will get speed up your learning curve..
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Ok, what version is your ArtCAM, maybe they are showing a newer version in the videos. I use what I see in the videos to do somethings in Cut2D.
I use Artcam 2008
Robert.
Can i see how much time i have to run the g-code?
Robert.
Once you have created your toolpaths, click: Toolpath Operations > Toolpath Summary. It will show the estimated time needed to finish the toolpaths. Hope this helps.
Yeah it helps! Thank you.
Robert.
Found more videos: here
Hello, can i program a A-axis in artcam?
Robert.
does so out there have artcam that can anwser a question for me. i downloaded a file STL from cnc4free when i open it in artcam i can't do nothing with it like move it and i can't see it as a vector to move it. can some one help he please
First, correct sentence formation will help others understand what you are asking:
Does someone out there....
On to your question, an STL file is NOT a vector, so you will not see it as one, you will not see it in the 2D view at all. You will see it in the 3D view however. When you import the STL, you can rotate it and translate it wherever you want, then when you click "paste" (I think thats what its called) it will actually paste the model into your workspace. Then you can only machine it using 3D toolpaths (machine relief, etc.) I have found artcam to be somewhat limited in its ability to work with 3D models, depending on what you are trying to do, it may or may not be adequate.
Good Luck
Matt
Hello, can i set a colour on the "milled" area?
Also, i see i can do many changes on my material, (wood, brushed silver.....) But can i set a black color, there i have milled vit a v-bit for example? so i get the text more out
Hope you understand..
Robert.
Hello, thanx for answer.
I mean that i get it dark "shadowed" or painted like the example under.
Robert.
Hi. I am fairly new to artcam 2008 and i have a recessed feature problem.
I followed the steps in the tutorial but i am having a hard time in the recessed feature tutorial b/c i can't find the 'Create' button w/c should be nearby.
Hoping for your kind consideration in detailing my mistake/s.
Thank You.
What does w/c mean?
