well thanks guys, i tryed a lot of times to cut wood using the jig-saw and i sux, i cant made an nice cut!.
btw, i think that its just practice, and do that slowly
thanks for the tips.
I have manually fabricated MDF for years with the straight edge trick, and it works well. The trick is to fabricate 1 piece as a pattern, and copy it with a router equipped with a flush trim bit.
I also use the router with the straight edge for nice straight lines on the patterns, which is much cleaner than the saw.
Hopefully I will soon just draw the shape, and let the cnc worry about the rest.
