588,522 active members*
7,858 visitors online*
Page 3 of 10 12345
Results 41 to 60 of 191
  1. #41
    Feb 2010
    202
    backlash are small gear, about 0.1 mm's, at the same weight of only periodic lubrication and replacement gear,
    Tribology of engagement can not I write,
    but minimize the noise through the transmission and the number of steps per unit, here is the division step 1:30, will be very soft work without surges
  2. #42
    Feb 2010
    202
  3. #43
    Feb 2005
    130
    Quote Originally Posted by Bartuss1
    do you use mobile as camera?
  4. #44
    Feb 2010
    202
    Smile
    Implementation of this part of the project was successful
    Now time to drive the longitudinal (X axis)
  5. #45
    Sep 2005
    1195
    Hello markcomp77,
    I am just curious that such big stepper motor zcb 50 Nm, you just limit power to 1.5 kw, is that right.
  6. #46
    Feb 2005
    130
    Hi asuratman,
    Thanks for your notice - this is important.
    our stepper motors will work with small speed (rotate)
    because, It is difficult to make high transmission ratio, we use 1/3
    so, It is needed to use stepper with BIG torque
    let's do some calculations...
    Power[kW]=Torque[Nm] * Speed [rpm] / 9550
    so...
    Speed = Power * 9550 / Torque
    if we connect only one stepper 50Nm to supply transformer 2kW
    Speed = 2kW * 9550 / 50Nm = 382rpm = 6.3 rot/sec
    not really high speed
    but, I can power drivers directly from mains....
    I will make same test... and decide way
    same of my really working control unit include - 1kW trafo (230/180), 3 drivers(the same) and 3 stepper 28Nm - and have nice performance (20..40rot/sek)
    transformers can be significantly overloaded
    let's do other calculations...
    3 x driver m542, supply with transformer 300W
    3 x stepper motor - 3.1Nm
    Speed = Power * 9550 / Torque = 0.3kW*9550 / 3.1Nm = 924rm=15rot/sec
    typical real result is similar but for 3 axis connected to one transformer 300W
    and average load power of transformer is small
    small because transformer is not hot after 4..5 hours of extensive tests
  7. #47
    Feb 2005
    130
    control cabinet on wheels
    one wheel for my DeLorien
    beginnings of layout... routing
  8. #48
    Feb 2010
    202
    Smile
    corps gear for the X-axis during the milling
  9. #49
    Feb 2005
    130
    new optobob (bob with optical isolation) - additional leds + resistor match to the voltage 24V (logic will work on 24V level)
  10. #50
    Feb 2010
    202
    Smile
    one finite gear X-axis, the second during the work
  11. #51
    Oct 2005
    2392
    Bartuss1- what is your system for getting the belt tension correct?
    Do you mount the large pulley first, then pull the belt tight, then drill the 4 motor holes like that?
  12. #52
    Feb 2010
    202
    Smile
    in reverse order
  13. #53
    Feb 2005
    130
    Bartuss, did you end gears for X?
  14. #54
    Feb 2005
    130
    how do you make tension of timing belt?
  15. #55
    Feb 2010
    202
    Smile
    a little complicated, but the best way to loosen stiff with periodic
  16. #56
    Feb 2005
    130
    oversized good quality timing belt solves the problem of making periodic tension
    am I right?
  17. #57
    May 2005
    1810
    Very impressive work - and all the machining has been done on a CNC DRILL PRESS? Wow!!
    Hats off to you guys.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
  18. #58
    Feb 2010
    202
    Smile
    this is my cnc mill maschine for work
    oryginal made in china from auction's picture
  19. #59
    Feb 2010
    202
    Smile
    parts of this machine also has implemented my cnc baby
    http://soltysdesign.xip.pl/forum/vie...3&t=39&start=0
    I confess that this is a 5 axis machine, my 39 construction
  20. #60
    Feb 2005
    130
    Bartuss, do you have new photos?
    my ctlr electronics growing...
    I designed new ac-protection filter/varistor/fuse for mains supplying...
Page 3 of 10 12345
  1. 5aXis-USB-iso-BOB
    By Yachaan in forum Open Source Controller Boards
    Last Post: 09-20-2015, 05:48 PM
  2. Semi - DIY CNC Router / Mill Project Build (With photos)
    By rescueweasel in forum CNC Wood Router Project Log
    Last Post: 08-30-2014, 06:21 PM
  3. 5axis help
    By BOATDUDEGUY in forum Mach Software (ArtSoft software)
    Last Post: 02-24-2014, 08:08 PM
  4. My CNC build-up with video and photos + everything a beginner should know
    By dmoore in forum DIY CNC Router Table Machines
    Last Post: 02-07-2008, 02:53 AM
  5. 5axis Help
    By jybute in forum Haas Mills
    Last Post: 11-22-2006, 03:10 PM
