588,487 active members*
5,510 visitors online*
Results 1 to 10 of 10
    Feb 2010
    LSK problem with my fanuc
    Hi all,
    I have Fanuc 6T-A controller when I try to load a program into my fanuc memory I do the following :
    1-set the lock key to write(unprotected memory)
    2-set the mode selector key to EDIT
    3-Press the READ key
    4-set the lock key to LOCK.
    This is what I do to cnc, but this does nothing, I read before that when the CNC is ready to receive the information of the program, the initial LSK cominezan to flicker but this kind are not to be done.
    I do all the setting required like:
    Parameter
    000 bit 5 = 1
    026 bit 7 = 0 (the bit on the far left) should be a "0" so the control will send Xon/Xoff signals
    002 bit 5 = 1
    024 bit 0 = 1 (for 2 stop bits)
    025 :1 1 1 0 1 1 1 1 (4800 )
    under SETTING : Punch code = ISO, INPUT DEVICE 2 = 1
    Feb 2008
    15
    After you hit the read key what happens? Are you "setting the lock key" right after hitting read?
    2932
    After step 3 does LSK flash?
    You should then go to the PC and send the program.
    Don't do step 4 until the program has finished loading.
    Do you get any alarms?
    Where did you get those parameter numbers? I'm looking at a 6T-B manual. I wouldn't think they would be that different from a 6T-A... do you have a 6T-A manual?
    Parameters for 6T-B:
    #340 (IDVICE) = 2 (RS232C; set parameters for baud rate, etc. in PRM #311)
    #340 (IDVICE) = 3 (RS232C; set parameters for baud rate, etc. in PRM #312)
    #341 (ODVICE) = 2 or 3 (as above)
    #007 bit 7 (ICR) = 1 (LF is punched for EOB) = 0 (LFCRCR is punched for EOB)
    #009 bit 1 (REDT) = 1 (Storage of proram to memory is started by pressing CYCLE START in EDIT mode.
    #311 bit 0-3 = 1001 (Baud Rate 4800)
    #311 bit 4 (STP2) = 1 (2 Stop Bits)
    #311 bit 5 (RZSBC2) = 0 (Control Codes DC1 ~ DC4 are used)
    #311 bit 7 (NFED2) = 0 (Feed is not punched)
    Feb 2010
    LSK didn't falsh any time !!
    some times I got alarm no 085
    I don't have fanuc 6t-A parameter manual and I got these parameter from net
    note that also fanuc 6t-A have only 160 parameter
    Yes fanuc 6t-B parameret is different from 6t-A
    LTS,
    not thing change after I hit Read key!!
    thanks all
    Feb 2008
    15
    Are you using a pc and cable that work elsewere? Do you have any more 6TA controls that work?
    Feb 2010
    hi LTS,
    I use my computer on other fanuc machine and it is work,i don't have other 6ta controller
    I think my problem is why LSK not flashing?
    Feb 2010
    HI ALL,
    I try again to load a program into memory following these steps:
    when I hit the read key An edit label is appear beside LSK label on CRT tube!!
    Any one can help?
    thanks
    Aug 2007
    796
    Quote Originally Posted by samiahmed View Post
    HI ALL,
    Any one can help?
    thanks
    Is your RS232 card adjusted properly?
    See attached files
    Attached Files Attached Files
    Feb 2010
    I found jummber setting on my puncher car was set on "10-7" and "13-4" and the other socket is like picture you send me
    what this setting means?
    thanks
    Aug 2007
    796
    Look here http://www.cnczone.com/forums/showthread.php?t=66857
    there is photo of proper setting of jampers in the first post
  1. Fanuc PML-L&M Problem
    By taspunsaen in forum Fanuc
    Last Post: 07-01-2022, 05:24 PM
  2. fanuc 10m problem
    By wayneman in forum Fanuc
    Last Post: 04-11-2012, 07:15 PM
  3. Fanuc X-OC EDM problem
    By JoBwan in forum EDM Discussion General Topics
    Last Post: 06-17-2009, 12:46 PM
  4. Fanuc 18M oil problem
    By mustafaguler in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2008, 08:35 AM
  5. FANUC-OM ATC Problem
    By Stebedeff in forum Fanuc
    Last Post: 07-27-2007, 04:18 PM
