587,675 active members*
3,647 visitors online*
Results 1 to 3 of 3
    Mar 2010
    lathe worm gear cutting
    have any of you guys ever put together a macro that would allow you to cut a worm gear on the od of a shaft. i want to feed in with a Y/Z move and go to a Z/C move for the length of the shaft and then feed off in another Y/Z move. i would like to put variables in for lead, number of starts, depth of cut, number of cuts, and start diameter.
    if you have any ideas, or know of a source for this type of program drop me a line.
    Mar 2006
    2712
    Can you tilt the axis of the milling cutter spindle? You will have to compensate for the lead angle of the worm helix somehow. You can see I ASSumed this is a live tooling application.
    Dick Z
    DZASTR
    Feb 2009
    6028
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    Me to, since he wants to move Y axis.
  1. Need some help finding worm gear oil
    By Dustin L in forum Linear and Rotary Motion
    Last Post: 11-04-2008, 09:32 PM
  2. Worm gear and worm drive
    By LEWENZ in forum Employment Opportunity
    Last Post: 04-27-2008, 10:28 PM
  3. Worm Gear
    By jackson in forum MetalWork Discussion
    Last Post: 02-07-2008, 10:25 PM
  4. worm gear drive
    By csrc in forum DIY CNC Router Table Machines
    Last Post: 07-03-2007, 08:53 PM
  5. Ha5c Worm Gear
    By engine tech art in forum Haas Mills
    Last Post: 05-10-2007, 02:08 AM
