587,468 active members*
3,169 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Low cost 6 axis USB motion controller
Page 2 of 4 1234
Results 21 to 40 of 71
  1. #21
    Feb 2008
    644
    Quote Originally Posted by Xerxes View Post
    hunserv, I'm also EMC2 user and would very much like to see SPI drive support in it one day. However, EMC developer mailing lists discussions don't give much hope for USB device support. Would need lot of changes in EMC. However, some FPGA card could do the job instead. SPI gets finally documented so anyone can implement the support.
    Jerry, loop is closed in drives. USB card is quite dumb itself and just sends commands to drives. There is 6 I/O's on board (can be used as analog inputs too)
    The HostMot2 configuration firmware for our FPGA cards supports SPI, Its probably not more than a day job to add a component that drives the VSD SPI interface. This would allow a 5I20 to drive up to 18 axis, and a 3X20 to drive 36!
  2. #22
    Sep 2005
    1660
    Quote Originally Posted by PCW_MESA View Post
    Interesting! I'm interested anyway.. I've finally faced the fact that I'm going to have to move to EMC so simplified interfacing of my existing hardware is of great interest to me.
    JerryFlyGuy
    The more I know... the more I realize I don't
  3. #23
    Sep 2009
    5
    EtherCAT?!!!!!!
    I'm also researching possibilities to make the device EtherCAT compatible in addition to USB.
    The EtherCAT slave would expand significantly the area of use of the VSD-(X)E.:idea:
  4. #24
    Sep 2004
    1207
    Granite Devices is already a member of Ethercat Technology Group.
    I'm making progress with USB6AX. It seems that even the fastest ATmega AVR controller isn't fast enough to handle the data rate of 6x2500 Hz even when the most critical algorithms are optimized with assembly code. However, drives run perfectly smooth even with lower update rate.
    One interesting aspect of USB6AX design is that it allows inserting miscellaneous commands in the drive data stream without disturbing the steady timing of position commands. For example this allows modifying drive parameters on the fly while drives are running interpolated 6 axis motion.
  5. #25
    Sep 2004
    1207
    There will be a major design changes compared to the prototype. Planned new specs are:
    -7 servo axis
    -8 digital I/O (settable direction)
    -3 PWM outputs
    -3 Analog inputs
    -Up to 8x1000Hz update rate (8th channel controls I/O's)
  6. #26
    Feb 2006
    71
    Any idea when these will be for sale?
  7. #27
    Sep 2004
    1207
    Quote Originally Posted by integerspin View Post
    When it's ready. There are many other things to carry out at the same time but I hope to finish it in about 6 months.
    BTW,
    I think I found a neat way to operate drives thru fieldbuses like EtherCAT, CANopen, SERCOS, Profibus etc by using readily available automation parts. I will buy some of those parts to test and describe my idea. If one is interested about them now, just email me.
  8. #28
    Sep 2005
    1195
    Hello Xerxes,
    When these all done, what it is look alike that component? What kind of application the best for this 7 axis USB? or its just to simplify PCB. Thanks. Asuratman.
  9. #29
    Oct 2005
    255
    I think I need one ... Na , I know I need one.
    Any updates?
    /Paul
  10. #30
    Sep 2004
    1207
    Paul, normal development progress. I want it to work perfectly and not "almost correctly", thats why I don't like release schedules.
  11. #31
    May 2007
    8
    Bump?
  12. #32
    Sep 2004
    1207
    Quote Originally Posted by winner View Post
    Bump?
    Recent development has been in SimpleMotion library. It allows controlling drives with included USB adapter. Only syncronous contouring is not supported thru that (it needs USB7AX).
    SimpleMotion is considered to be the programming interface for USB7AX too.
  13. #33
    May 2007
    8
    If I understand correctly this project is on hold? I just cant get it.
  14. #34
    Sep 2004
    1207
    Quite much so in last months, but the project is still alive. It's just "too much work, not enough time" thing.
    BTW, we are evaluating EtherCAT interface. If it seems reasonable in work amount, then we probably replace USB with EtherCAT as it's much more supported in industry (i.e. EtherCAT CNC software already available). It takes more research on topic to say any decision. The solution could be either a) direct EtherCAT support on each drive or b) USB7AX like device but EtherCAT instead of USB.
  15. #35
    Oct 2005
    255
    Thanx
    Thanx for the update.
    /Paul
  16. #36
    May 2007
    8
    Thanks for clarification. About EtherCAT, I think you are talking about this:
    http://www.ethercat.org/en/ethercat.html
    And, if I understand correctly, with this EtherCAT, I can build a 6 axis CNC machine and control them from PC using an ethernet port instead of USB?
  17. #37
    May 2007
    8
    One more question. What software can control this EtherCAT thing? Mach3, Emc2, etc?
  18. #38
    Sep 2004
    1207
    Yes, correct link. Much more than 6 axis is possible in that bus.
    There is at least TwinCAT software that can run G-code with EtherCAT drives. It works on PC and communicates thru ethernet connector.
  19. #39
    Apr 2007
    90
    What would be the price range of the controller. Development of a new controller on the Ethercat platform can upgrade the current machine builders to a new level of field advancement, but prices, flexibility of usage should be within the reach, affordability & support with a nominal cost will scale the product to new heights (eg. Like Mach). Keep us updated & i would love to do Beta testing if you are interested.
  20. #40
    Sep 2005
    1195
    Just curious, is this controller card work in companion with your 6 each VSDE or it will be 1 card with 6 ea driver on board. Thanks.
Page 2 of 4 1234
  1. low cost linear motion with feedback
    By eganders in forum Linear and Rotary Motion
    Last Post: 11-16-2007, 07:04 PM
  2. Need advice for affordable 3-4 axis motion controller
    By mugabe in forum Controller Cards
    Last Post: 09-29-2007, 11:27 PM
  3. 3-4 axis motion controller
    By grebator in forum Stepper Motors / Drives
    Last Post: 04-19-2007, 09:15 PM
  4. PARKER 6K2 or 6K4 Motion controller
    By TUCSONCNC in forum Post Processors for MC
    Last Post: 02-02-2007, 07:07 AM
  5. The cost of motion
    By Jcadwell in forum DIY CNC Router Table Machines
    Last Post: 04-22-2004, 02:18 PM
