588,112 active members*
5,574 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > What stepper driver do I need
Results 1 to 7 of 7
    Oct 2007
    24
    Hi All
    I am looking for a stepper motor driver that does not use step direction commands from a PC. It uses a pulsed input one pulse one step
    Three input terminals +CCW negative +CW Can anyone steer in the right direction where to look.
    Doug
    Jun 2008
    128
    There is no need for a 3 input system. Standard is a pulse for step and a +/- for direction. Some like the gecko G203v cw/ccw use a pulse cw and a pulse ccw pin.
    What are use using to drive the stepper that needs 3 pins?
    George
    Oct 2007
    24
    stepper board
    Hi Thanks for the reply
    It is used on a chassis dynamometer for the load valve. the dyno controller does not use a step direction command but a +cw +ccw with a common negative. one input pulse = step on the load valve motor. any suggestions?
    Doug S
    Aug 2009
    65
    Quote Originally Posted by Doug Schwochert View Post
    How about discrete logics to convert the old +cw/+ccw to step/dir. It seems to be not about speed.
    Any idea of the signal timing ?
    Step seems to be simply a XOR of CW and CCW.
    For Dir I would suggest a flip-flop driven by CW and CCW.
    This would store the direction until the next oposite CW/CCW flips the logic.
    Jan 2006
    481
    Is the chassis dynamometer water brake unit? or telma retarder?
    Would be nice if some of the electronics wizards help build a all purpose cnc dynamometer controller !!!!
    Oct 2007
    24
    Dyno controll
    It is for a Dynomite dynamometer, water brake.. I have the entire set up for engine and chassis dynoing. I am always swapping the load controll valve from one to the other. The company wants close to a grand for the automated load valve. I am pretty good with metalworking and electronics I think I can make one cheaper. I reverse engineered the valve and I am up to the stepper electronics. The Gecko G203 is available with a CCW/CW input signal.
    Thanks to all for the help
    Doug
    Jan 2006
    481
    Hi
    Don't be shy , a few pictures and more information would be nice to share. I have a engine dyno i would like to be able to control automatically also.
    Open and closing water tap valves via a few stepper motors would be interesting method. As many dyno use this style of load control.
    What electronics are you going to use to PWM the Gecko G203 ?
    Cheers
  1. Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver?
    By joprinz in forum CNC Machine Related Electronics
    Last Post: 04-28-2011, 09:57 AM
  2. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  3. Need 80V, 9 amp stepper driver
    By leop in forum Want To Buy...Need help!
    Last Post: 06-15-2009, 11:45 PM
  4. Wanted DIY stepper driver circuit for 6 wire stepper motors
    By Colin300 in forum Australia, New Zealand Club House
    Last Post: 09-21-2007, 03:20 AM
  5. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
