587,999 active members*
2,540 visitors online*
Results 1 to 3 of 3
    Aug 2004
    244
    Ez Trak backlash adjustment
    Does anyone know how to adjust the backlash on a ez-trak mill? I would guess that the ballnut can be adjusted. If this true, any specs for torque or preload and how to measure. Thanks.
    Nov 2004
    3028
    I have never fooled around with the ball nut. Anytime it is too loose, the ballscrew gets regound and bigger balls are loaded. I installed a few machines at a place called National Precision in Franklin, TN. That is his business. He rebuilds ball screws.
    To adjust backlash, I increase the value in the machine by .002 inches. I then machine a circle in aluminum with a spring cut. Now sweep the circle with a dial indicator. The steps you measure are how much it is overcomped. Subtract this value from what is in the machine. If it varies at 3 and 9 oclock, then your X ball screw is worn unevenly. You may want to average the compensation. Ditto for the Y.
    To get to the backlash value, at the main screen, press the * key, the key word is 11235 followed by enter twice. Do not forget to save. If a ball screw is replaced or reground, the existing pitch error comp values are worthless.
    George
    Dec 2005
    3319
    Don't forget to check for looseness and/or wear in the ball screw support bearings.
    An overly tightened or improperly adjusted gib (did it myself) can also cause "backlash" problems
    Our of tune servo amps will further contribute to non linear servo performance.
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 04-05-2024, 08:10 AM
  2. Backlash with worm drives ?
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-02-2005, 11:40 AM
  3. Leadscrew backlash nut issue.
    By jaydee116 in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2004, 01:57 AM
  4. Backlash comp: does other axis pause during?
    By lesd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-30-2004, 08:05 PM
  5. Z axis backlash adjustment help sieg x3
    By replicapro in forum Benchtop Machines
    Last Post: 11-07-2004, 07:13 PM
