Hello again,
I had been struggling to save a few dollars for the electronics that I needed for this build and finally I was able to get enough together from a side job to get the things I needed. I had bought the used stepper motors on eBay about the same time I got the motion components but did not have the needed drivers, power supplies, break-out-board etc. to finish the build. I was very fortunate that another Vectric forum member offered me a C10 BOB that he could not use with his machine so that helped me tremendously. I got the electronics for the CNC router build and a DIY rotary indexer I am almost done with also.
I decided to make the driver control box from .063" aluminum along with a cover and designed it to fit my components including PEM hardware inserts for the threaded fasteners. I all fit together very well and is a very functional part of my build. I did redesign the orientation of the drivers so that the airflow through the box will be much better if I make more of the control boxes. I also added 2 outlets to the box to enable plugging the 5V BOB power supply and the Rotozip motor into. It is all fused an so far it is working well. Here are some pictures of the electronics, box drawing and the final assembled driver box.
Regards,
