Hi I'm new here and looking at building my own CNC... my problem is I'm on a Mac and there is no software out there it seems.... SO.. in my search for a solution I have come across a USB controller that will handle 4 stepper motors.. I think it was just recently developed and sells for about $75 it accpets code from alot.. and I mean alot of programming options including action script from flash.... which BTW lets you create graphics in 3D I will post a lonk to have alook at...but here are some of the specs... can someone tell me if I've stumbled upon something good here,,,,or if I'm just chasing rainbows...keep in mind I know just the newbie basics about DIY CNC's I'll keep my fingers crossed...lol
http://blog.trossenrobotics.com/2008...or-controller/
roduct Specifications
Position Resolution: ½ step (40-bit signed)
Upper Position Limit: 239 – 1 ½ steps
Lower Position Limit: -(239 – 1) ½ steps
Velocity Resolution: 0.75 ½ steps/second (9-bit)
Velocity Limit: 383.25 ½ steps/second
Acceleration Resolution: 140.625 ½ steps/second2 (6-bit)
Acceleration Limit: 8859.375 ½ steps/second2
Minimum Power Supply Voltage: 5V
Maximum Power Supply Voltage: 12V
Max Current Per Coil: 1A
USB-Power Current Specification: 100mA max
Device Quiescent Current Consumption: 23mA
Device Active Current Consumption: 23mA max
Software Environment
Imacman
