587,195 active members*
2,959 visitors online*
Results 1 to 2 of 2
Threaded View
    Feb 2006
    52
    Y Axis Design Feedback Needed
    getting around to starting to fabricate approx 60"x60" router and could use some feedback on my thoughts for the Y axis. my plan is to use 1" black pipe with connecting support between 2 pipes spread apart approx 6-7" and use skate bearings top and bottom in a 120 degree layout on the four corners of my Y/Z slide. my concern is how well this layout will function with working torque from X/Z axis. I attached a rough pic of layout. my fear is that the whole unit will be to easy to rotate with the round pipe and almost circular bearing layout. the spread of the pipes I'm going to try to maximize and make bearing carriers adjustable.
  1. New Spindle Design, feedback plz!
    By h3ndrix in forum Uncategorised MetalWorking Machines
    Last Post: 09-22-2014, 09:37 AM
  2. Need feedback on design
    By joeinbend in forum Stepper Motors / Drives
    Last Post: 03-01-2010, 08:17 PM
  3. Looking for Milling spindle design feedback
    By pstockley in forum Mechanical Calculations/Engineering Design
    Last Post: 12-30-2008, 12:54 AM
  4. Homemade Linear Design, Feedback.
    By MrBean in forum Linear and Rotary Motion
    Last Post: 05-20-2005, 08:50 AM
  5. Need feedback on design.
    By Mike F in forum DIY CNC Router Table Machines
    Last Post: 02-13-2004, 02:18 PM
