587,998 active members*
1,747 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > need help rapids going very slow
Results 1 to 18 of 18
    Mar 2008
    107
    I have a 1992 conquest 42 it seems to go to the slowest rapid speed when you go to edit you program then go to run it.
    If you turn machine off then back on it runs fine at 100 percent on the rapids
    but then if you edit the program and go to run it it goes slow only on the rapids.
    Any help would be great I just got this runnung last week.
    thanks mike
    Feb 2009
    6028
    Did you zero return it?
    Mar 2008
    107
    do you have to do this after any edit in the program it was running at 100%
    then goes in slow mode after edit I will try this
    thanks
    Feb 2009
    6028
    Should only be on power up, as long as you did that should be ok. Sounds like your missing a prep code after doing your edit. Are you starting at the beginning of the program after? Is the control seeing the G0 command? Check your Modal screen and see whats been left on. If it works after power cycling, leeds me to believe the program is turning something on and not turning it off.
    Mar 2008
    107
    good thinking I will right down the codes and then check when I edit.
    but I am starting at the beginning of the program and it is still doing this.
    thanks
    Mar 2008
    107
    when you are in run mode and hit the check and see what codes active they all seem to be the same but when I hit edit and dont even change anything
    then go to run it rapids slow and I ran 5 pcs first and they all worked fine then edit and now it goes slow
    Mar 2008
    107
    I just hit my spindle free button ( it has the live tool option which I am not using ) and now it will rapid at 100% after edit does that make any sence
    Mar 2008
    107
    must of been a luck because it is doing it again any suggestions
    Jul 2007
    34
    Check diagnostics page # 305.0 (that is the farthest bit to the right)
    Without this set to 1, you will lose rapid traverse after EDIT
    regards,
    newc
    Mar 2008
    107
    I was a little scared to change the parameters I called hardinge they said on that year machine after edit turn the edit key to protect mode and then hold the edit key in and push spindle stop button and I can do this when it is running and this works.
    or if I mdi m30 that works to
    Thanks for the help Mike
    Jul 2007
    34
    I'm willing to bet that procedure sets a 1 at diagnostics #305.0 --
    Mar 2008
    107
    I am not sure I am looking at the same thing you are talking about I cant find a #350.0
    can you give me a little more info
    Jul 2007
    34
    I don't know how much you know about how the bits are numbered, so why not start from the beginning.
    The bits are named 0 through 7 for a total of eight bits.
    0 is the name of the farthest bit to the right.
    The next bit to the left (second bit) is bit 1.
    The one to the left of that (third bit) is bit 2.
    So on.
    So the bits are numbered thus: 76543210.
    This makes up a diagnostic "word".
    In your diagnostics pages, go to the location # 305
    You will see eight characters, either ones or zeros.
    The character that corresponds to bit 0 should be set to 1.
    This will enable rapid traverse after edit.
    I don't know what you have in the other bits, but don't change those.
    Only change bit 0.
    It should look like this: XXXXXXX1
    The X's represent the other bits, that you should not change.
    So if for example your location 305 now says 10010000 you should change it to read 10010001. If, say, it reads 10100100 you should change it to 10100101, etc. Only change the farthest right bit.
    regards,
    newc
    Mar 2008
    107
    I just tried it and it did not work mine is d0350 I dont know if I am doing it write
    Jul 2007
    34
    305 not 350
    regards,
    newc
    Mar 2008
    107
    wow it worked thanks a bunch
    I guess its time to quit it 10pm here and I have been at it since 5am
    thanks again what a difference number make
    Mike
    May 2007
    1003
    Quote Originally Posted by mls View Post
    thanks mike
    This is a Hardinge thing on the older machines. Whenever you use the Edit function the machine automatically rapids at the slowest until it reads an M30. Easy to get around. When done editing, go to the M30 before leaving EDIT mode. Hit Cycle Start. Run program from beginning or anywhere else, and it will now rapid at 100%.
    Sep 2005
    I know this is a little late, but if you go into edit with the program protect key off on this machine you will see a light next to the slow release button down by the x and z traverse buttons towards the bottom right of the control panel. when you go into auto or any other mode just press that slow release button and it will unlock it without having to read a M30 or powering the machine etc. If you keep the program protect key on you can go to edit without it triggering that slow release mode, but you can only view and skip thru the program that way.
    Sorry I didn't see this before
    btw if your buttons on the controls are numbers I believe that slow release button is #68
  1. NM 135 rapids in Mach3
    By zaebis in forum Novakon
    Last Post: 12-05-2009, 05:00 PM
  2. rapids
    By millman52 in forum Mach Software (ArtSoft software)
    Last Post: 11-01-2008, 01:41 AM
  3. All the sudden, big problems with Rapids
    By CROSSHATCH in forum LinuxCNC (formerly EMC2)
    Last Post: 04-24-2008, 03:44 PM
  4. feed and rapids
    By ccmind in forum Syil Products
    Last Post: 11-21-2006, 04:31 AM
  5. Fadal rapids
    By Garypl in forum Fadal
    Last Post: 11-03-2005, 09:36 PM
