588,201 active members*
4,511 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > 6A/80V unipolar microstep driver, price you want
View Poll Results: Price you want?
Voters
29. You may not vote on this poll
  • 39USD with 3 month waranty
    16 55.17%
  • 45USD with 6 mont waranty
    6 20.69%
  • 49USD with 9 mont waranty
    1 3.45%
  • 55USD with 12 mont waranty
    6 20.69%
Page 1 of 2 12
Results 1 to 20 of 26
    Nov 2009
    49
    Spec
    -Maximum motor voltage: 80VDC
    -Peak current: 6A per phase (4.2A RMS)
    -Micro step models: Full step, haf step, micro-step 4, 8, 16, 5, 10
    -Opto-isolated step/direction
    -Auto reduce current while motor is stopped
    -80khz maximum step pulse -frequency
    -Internal socketed fuse
    -Single supplier
    -Microstep to full step morphing at higher speeds
    Place: Houston USA
    PRICE YOUR WANT? pleas vote.
    thanks and regards
    protype board
    Compare size , Driver and 23 size stepper motor
    test clip
    6A 65V, 10 microstep, 1900RPM max, mach3 control, acc 1000mm per ss
    Nov 2009
    49
    upgrade
    -Peak current: 7A per phase (5A RMS)
    -Single supplier
    35538
    When will these be available??
    Nov 2009
    49
    thank you for ur interest in our Belief driver
    We are going to launch our first product in Febuary 2010
    thanks and regards
    Oct 2005
    1237
    I vote $30-$45 or less. Why?
    1. No mid band resonance damping.
    2. Peak amps are not real world amps. Saying peak 7A then a less RMS value says these will not run a 7A motor.
    3. No micro step morphing.
    The only positive item for this drive versus a Gecko 250 or 251 is the higher voltage. This is assuming the 70v stated isn't a fail at voltage. If this voltage is in the same light as the 7A, then it is only worth $30 each drive (or less). The biggest draw back is that this is a new drive from a new company. No idea if you will still be around in a year, and no idea how hard it will be to get a replacement drive if one fails, or how well warranty service will be met.
    These will have to be priced fairly cheap as many people will look at the track record of Gecko drives and shy away if you price too much money.
    Nov 2009
    49
    Thanks MrWild,
    1. YES, no mid band resonance damping
    2. RMS is 5A
    3. Have microstep morphing
    thanks and regards
    Jan 2009
    57
    Where are they?
    Quote Originally Posted by beliefdrive View Post
    thanks and regards
    Here we are April 1st. Where are these products and prices?
    Nov 2009
    49
    We producing heatsink for driver, i hope finish soon
    the price will 39 to 42usd
    thanks and regards
    Oct 2005
    1237
    That seems to be a fair price for a lot of components. The max motor voltage, is that power supply voltage? If the drive can handle up to 80v power supply, that is indeed a robust drive. At 5A, you also meet a niche market between the 3.5 and 8A of the Gecko line.
    Where are these made? You list Houston, Texas, but write like English is a second language. I think it would be a huge mistake to say made in U.S.A. and be found out as made in another country. Integrity is important. Integrity is more important than where these are made.
    Nov 2009
    49
    Thanks Mrwild, sory about my english
    Max motor voltage is power supply voltage. But it is unipolar stepper drive, Gecko is bipolar drive.
    Products assembled in vietnam. Driver will ship from houston
    Feb 2007
    969
    Looks like a good repairable drive. These cost more to make.
    $39 is ok with a high quantity, but charge $60 for 1-10. No other 80 volt drive is any where near that cheap.
    Maybe sell the PCB and instructions for $29.
    BTW, why not make a bipolar ?
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Nov 2009
    49
    thanks Larken
    Official price will be after I finish working with the aluminum cover producer.
    bipolar controller cost will be high, because using MOSFET drive, and a lot more power FET
    with unipolar drive, I can reduce costs because only 4 MOSFET, I use transistors to drive mosfet
    power and control stage
    power stage top
    power stage bottom
    Nov 2009
    49
    10A peak (7A RMS) 120V bipolar microsteping drive
    Full
    Power board top
    power board botom
    Nov 2009
    49
    7A peak (5A RMS) 80V microsteping drive
    Full
    Power top
    Power botom
    Feb 2007
    969
    What ? you made a bipolar drive since your last post ? Your fast !
    I have a new Stepper drive myself, and looks very similar to yours. Its also 12 amps 100 volts.
    Nov 2009
    49
    to Larken.
    I was build bipolar drive 7A 80V two year ago.
    10A 120V just finished last week
    Oct 2006
    975
    Hello,
    How much does the bipolar drive cost?
    Regards,
    Regards,
    Wes
    Nov 2009
    49
    will be 79USD for 7Apeak ( 5A RMS) /80V bipolar drive
    b.r
    Oct 2006
    975
    What are the microstepping settings for this bipolar drive?
    Regards,
    Wes
    Nov 2009
    49
    Microstep mode setting by dip switch. you can setting full, haf, 4 , 8, 16, 5, 10, 20 microstep mode
    thanks and regards
Page 1 of 2 12
  1. Using Picstep's PIC to microstep other driver chips.
    By lucas in forum CNC Machine Related Electronics
    Last Post: 08-10-2013, 08:28 PM
  2. Lowcost unipolar microstep driver - beliefdrive
    By beliefdrive in forum News Announcements
    Last Post: 03-19-2010, 03:39 AM
  3. Building a microstep driver
    By izua in forum CNC Machine Related Electronics
    Last Post: 05-02-2008, 07:41 PM
  4. full->microstep driver
    By visky in forum CNC Machine Related Electronics
    Last Post: 10-28-2007, 04:26 PM
  5. My 3d microstep motor driver
    By smartgsm in forum Open Source Controller Boards
    Last Post: 06-01-2006, 04:30 PM
