This may be a SprutCAm question, but I wanted to ask current SC/Tormach owners first.
I have a figurine to machine and setting up files so when I actually get my machine it may be one of the first pieces machined (I know, simple blocks will be first).
My problem is I am not finding the info I need to rotate the 4th axis during roughing. I will either have a cylinder or block (thinking cylinder is easier) for material. I rough down the top part and then I simply want the 4th axis to rotate 180DEG and machine down the backside.
During the final passes, I believe I have that setup where it will turn around as it goes around the part. Just setting up the movement during roughing is the problem.
Is there a setting for the Tormach machine that I am missing?
