588,202 active members*
4,428 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge Collet, Tap Adapter and Drill Bushing Tray
Results 1 to 3 of 3
    I tried for some time to find a used collet tray for my Hardinge HC Chucker.
    It apprears that the usual configuration when shipped is only one tray while the cabinet was fitted with 2 brackets for trays.
    I decided to make my own. I programmed the parts utilizing ONECNC XR3. While I was in the design process I decided to make some holes for holding my Hardinge Tap Adapters and Hardinge Drill Bushings.
    Here is a few pictures for your amusement.
    Attached Thumbnails Attached Thumbnails IMG_0557a.jpg   IMG_0558a.jpg   IMG_0559a.jpg   IMG_0562a.jpg
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
    Aug 2009
    71
    Very cool.
    Thanks for the positive comment. It is just one of the many projects I had laying around waiting to be done. It finally made it to the top of the list.
    :banana:
  1. 1/4 to 1/8 collet adapter?
    By CRFultz in forum DIY CNC Router Table Machines
    Last Post: 04-17-2010, 07:54 AM
  2. 5C Collet Adapter For TL
    By Geof in forum Haas Lathes
    Last Post: 12-03-2009, 09:40 PM
  3. Another Source for Collet Bushing Adapters
    By HayTay in forum DIY CNC Router Table Machines
    Last Post: 03-31-2006, 10:53 PM
  4. collet adapter
    By truman in forum MetalWork Discussion
    Last Post: 03-25-2006, 03:43 AM
