587,996 active members*
5,350 visitors online*
Page 2 of 29 123412
Results 21 to 40 of 569
  1. #21
    Aug 2009
    899
    Awesome, I will pick up the C11G soon and will also add a sensor to input the spindle speed into Mach 3. I think I have narrowed it down to The Bolton ZX45 due to it having a larger travel than most of the other cloans and a 2HP motor.
    As for ball screws what do you think about this set?
    http://cgi.ebay.com/3-RM1605-300-500...item3a557b57db
    I would request a longer screw for the Z of course, and I'm not totally sure on how long I would need them but it would be to easy to cut and re machine the free end of the screw.
  2. #22
    May 2005
    2502
    Another RF-45 build--excellent!
    BTW, I read that the G320X is no longer as sensitive to the encoders. Nevertheless, the AMT encoders are nicer units.
    I'll second the notion of the one shot oiler. I wouldn't want to be without mine.
    I am curious to hear what backlash the linearmotionbearings ballscrews have since they are not double nut ballscrews.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  3. #23
    Apr 2008
    46
    Is there any benefit of buying a RF45 clone with power head lift?
    Looks like this power lift model has a motor on top of the column
    http://www.lovangersmaskin.se/produc...roducts_id/516
  4. #24
    May 2005
    2502
    Quote Originally Posted by daman View Post
    Daman, if you plan to CNC you will be discarding that lift, so I wouldn't pay the extra for it. It's a free workout for your biceps without it!
    Cheers,
    BW
  5. #25
    Dec 2009
    303
    Quote Originally Posted by BobWarfield View Post
    Cheers,
    BW
    i heard a rumour that the circuits are spread out in the ballnuts to give it the anti-backlash, with no adjustables... we'll see how well works,
    matt
  6. #26
    Oct 2007
    398
    Quote Originally Posted by mattmark View Post
    matt
    I have an RM1204 and an RM1605 on my lathe. They both have separate circuits on each side of the nut, so there is some preload giving it effectively zero backlash. The preload appears to be pretty low, though, and I don't know how or if it can be adjusted, or if there is really backlash when that preload is exceeded.
    I'm planning on using double nuts with additional preload if there's room. Some rough measurements on the Y-axis makes me think I was hasty in buying 2 nuts for that axis, though. At $26 each, I'm not too concerned
    Jeff
  7. #27
    Dec 2009
    303
    ballnuts
    Quote Originally Posted by Flenser View Post
    Jeff
    hey jeff,
    agreed - the y-axis is pretty tight.. i have very little additional height clearance on the flange of the ballnut (from lmb), because of the table... and that's after changing the direction of the way the flange is facing (taking out and repacking the ball bearings was educational).. if you can get 2 ballnuts in there, i'd like to see it!
    matt
  8. #28
    Oct 2007
    398
    hey jeff,
    matt
    I haven't given up hope completely on using a double nut, but it sure doesn't look good. The other mill showed up at the office today, so as soon as I get it home and setup I'll be able to tear the 45 down and get a better look.
    Jeff
  9. #29
    Aug 2009
    899
    The ball screws are not double nut but my guess is because they are advertising anti-backlash nuts that they are using over-sized balls in the nuts. This will be my first use of ball screws so we will see how it goes.
  10. #30
    Aug 2009
    899
    Spoke with Arturo from CNC4PC and they suggested I use the C11T due to added features for the G320 drivers. The C11T will also send a 0-10VDC signal to a commercial VFD but I will be needing a C3 card to feed the spindle speed into Mach 3. No just what VFD to use...
  11. #31
    Sep 2006
    509
    I got my VFD from dealers electric, a GE D5815. Its been great and was exactly what it was advertised as (new surplus in factory carton) for a good price. http://dealerselectric.com/item.asp?cID=&PID=1028
    I oversized it a bit oversized (3hp) as I bought it before I bought my motor (was aiming for 3hp but ended up with 2hp)
    I'll probably buy another from them when the time comes to do something on my lathe. Actually I should buy it now before it disappears (I had book marked a 2hp version for my lathe but its gone....)
    Mike
  12. #32
    Aug 2009
    899
    If I am correct I can take a 3PH driver and run 1PH motor with just using 1 pole from the VFD right? Or would I need to change to a 3Ph motor?
  13. #33
    Dec 2009
    303
    vfds
    Quote Originally Posted by eartaker View Post
    I've heard lots of good things about the Teco FM50:
    http://www.factorymation.com/s.nl/sc.2/category.13/.f
    upon further recommendations, I ended up picking up the Teco 7300CV sensorless: http://www.factorymation.com/s.nl/sc...egory.15366/.f
    matt
    ps not sure about the 1 pole question. haven't gotten to the VFD part yet
  14. #34
    Oct 2007
    398
    Don't know for sure, but I would expect a VFD to fault with just one circuit wired like that. Also, I don't know how well you will be able to control the RPM on a SP motor which has a 180 deg phase angle. The 60 deg phase angle of 3P motor will make RPMs a lot easier to control under a load. This is the motor I've been planning to pick up.
  15. #35
    Apr 2007
    2580
    Teco.....
    Definitely get the Teco.... I got the sensorless vector drive too and it is excellent. My pal Art also has a teco and recommended it to me as well....
    Why the hell would you want to power a single phase motor with a three phase vfd? Not sure what it is you are after, am I correct in assuming you have three phase wall power in your shop? Most here have single phase power and require the vfd for three phase conversion to run three phase motors? Peace
  16. #36
    Aug 2009
    899
    I was looking at running a single PH motor so I could keep from having to change it out but it looks like I will be picking up a 3Ph motor eventually. I do not have 3Ph power in my shop only 1Ph.
  17. #37
    Apr 2007
    2580
    I would say to get the......
    I would say to get the Three phase motor in either two or three HP and get a vfd or sensorless vector of your choice. If you can it may be possible to order your machine with the three phase motor so all you have to buy is the vfd at around $150.00 or so.... That would be the best way I would think..... peace
    Pete
  18. #38
    Aug 2009
    899
    Made it home and placed an order for over $600 in random tooling, about to place the order for the RF-45.
  19. #39
    May 2010
    26
    I am glad you made it hope safely, Thanks for serving, Bro.
  20. #40
    Aug 2009
    899
    Well I did it, the wife is going to kill me but I ordered the Bolton hardware ZX45, should be here by Friday. Already have the Servo motors, the encoders, and the Gecko 320X's (smaller than I thought they would be). Waiting on the mill, About to order the C11T breakout board along with some timing pulleys, belts and, ball screws....
Page 2 of 29 123412
  1. advice needed
    By teamjnz in forum Haas Lathes
    Last Post: 05-20-2009, 11:19 PM
  2. Advice needed.
    By Terence E in forum Community Club House
    Last Post: 05-14-2009, 03:56 PM
  3. advice needed / to buy or not???
    By teamjnz in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2008, 02:48 PM
  4. advice needed
    By trubleshtr in forum CNC Machine Related Electronics
    Last Post: 04-22-2005, 02:48 AM
  5. Little advice needed
    By STUG in forum DIY CNC Router Table Machines
    Last Post: 01-26-2005, 02:11 AM
