588,342 active members*
5,090 visitors online*
Results 1 to 17 of 17
    Stuey Guest
    Why Belt-Driven Lead Screw?
    I've seen a few designs where stepper motors are indirectly coupled to acme or ball screws with a belt. Why is this done?
    A half hour of searching didn't turn up anything helpful.
    One rotation of a directly coupled stepper results in one rotation of the dreive screw. With a belt, one stepper rotation results in say, 1/4" rotation of the drive screw. So is the belt intended to increase the precision of the machine? Or is it done for greater simplicity and efficiency?
    Apr 2007
    8082
    Quote Originally Posted by Stuey View Post
    The timing belt drive system allows use of different size timing belt pulleys to give more speed, or more power. If the same pulley size is used on the motor and lead screw it is a 1:1 ratio just like directly driving the motor to the lead screw. As with with any other drive system there are advantages and disadvantages to deal with when using belts.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Stuey Guest
    I suppose that makes sense. I mostly see these on smaller machines.
    Sep 2006
    218
    it may be also a cheaper way to connect motor to the acme thread (flexible couplings are avoided)
    Apr 2007
    8082
    That's because the longer the belt is, the more sag it has unless you add idler pulleys to help support the belt without having to tighten the belt really tight make the belt support itself. Then the belt can stretch over time and it will sag again. It also puts a heavy load on the bearings. When the belt has sag, it has backlash because it has to take up the slack in each direction it runs. Some types of belt construction has less sag per unit of distance. Those tend to be more expensive. Sagging belts also tend to jump up and down in mid span as the direction is reversed.
    Belt drives can work very well when the right type and width of belt are used.
    CarveOne
    CarveOne
    May 2007
    781
    Power is constant, limited to what the motor can put out (RPM * torque) but for what is lost to efficiency.
    What a belt allows is to trade RPM for more torque or torque for more RPM. It can also be used to trade speed for steps per inch but the designer needs to remember it also effects the torque available which the screw converts to linear force.
    The fancy word is impedance matching, the mechanical equivalent to using a transformer to trade voltage for current.
    Dec 2003
    24220
    And as torque increases at the ratio rate of reduction, the motor to load inertia ratio decreases by the Square of the reduction.
    Al.
    Albert E.
    Apr 2009
    5516
    Also in the case of dual leadscrew design to move the gantry, so moving the leadscrew out from under the work table...
    Mar 2004
    439
    Say you have one machine with direct drive (motor on the screw) and the screw lead is 0.200".
    On another machine you have a 2.5:1 belt reduction and the screw lead is 0.500".
    You have the same resolution (motor rotation vs. distance) with both set-ups, but you can have a higher speed with the belt driven axis due to lower screw RPM, which is a big advantage for small diameter screws spanning a long distance, as it minimizes the potential for whip (the screw turning into a "jump-rope"). Also, if these are acme screws, it lowers the Surface Feet per Minuite within the nut, which can cause "squeal" or excess wear.
    Keith
    Stuey Guest
    Ah, I think I understand the gist of it a bit better now, thank you all for the clarification!
    Mar 2005
    181
    Belt drive also has the benefit of folding an axis drive under the end of the screw. In some designs this is a handy way to reduce total drive length by tucking the motor length under the ballscrew. A belt also acts as a high torque capacity misalignment coupling. Misalignment couplings are a necessary feature to prevent a "three bearing in a row" design problem when driving a screw with a motor. Basically a motor has at least two radial bearings. A ballscrew would be supported by two or more radial bearings at the ends.
    Joining a motor in line with a ballscrew would require that all four bearings (in motor and screw subassembly) be dead coaxial or you'd see some high radial loads due to misalignment as the bearings arm wrestled each other.
    Dropping the motor out of plane and using a belt is a clean way to provide this secondary feature. Belts also can be quite economically strong. Misalignment couplings that have high torque capacity are comparatively quite expensive.
    Apr 2010
    486
    The very first Bridgeport CNC mill has the x & Y stepper motors tucked up underneath the table, with a belt drive for each.
    Hate to thing how much access to the table would be impaired with the Y motor sticking out in the front and the x motor sticking out to the side.
    Tom
    35538
    I'll be using belts to keep the Z axis steppers from sticking an additional 8" above the machine, tucking them neatly out of the way instead.
    http://www.cnczone.com/forums/attach...7&d=1246200076
    Belts also act to damp-out motor vibrations.
    Mariss
    Stuey Guest
    I did consider the easier misalignment compensation that a belt drive offers, and thought more DIY designs would utilize it for this reason. Then again, for its full effect, I suppose the acme or ball screw must be turned down to accept the timing pulley without having to use couplers.
    Jul 2006
    1062
    Unless you use a taper-lock bush :idea:
    Keith
    Apr 2010
    363
    Mine uses a belt, probably because it's a dual leadscrew. One stepper can drive two screws.
  1. belt driven CNC
    By jwest in forum DIY CNC Router Table Machines
    Last Post: 11-29-2008, 11:10 PM
  2. Solsylva Dual Lead Screw Table - Suddent Belt Drift Causing Issues
    By mlammert in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 11:08 PM
  3. Belt driven screw ?
    By tomcat47 in forum Linear and Rotary Motion
    Last Post: 01-29-2007, 05:20 PM
  4. Lead screw lube amount. servo belt replacement
    By bob1112 in forum Linear and Rotary Motion
    Last Post: 11-25-2006, 01:59 AM
  5. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
