The appearance and performance of my Tormach's plexiglass and Loc Line needed to be replaced !!!
- Plexiglass had some weird fungus growing inside the plastic (clouding my visibility) and also started to turn yellow (not that this is a major issue). My main concern was I wanted something a little taller to protect my face. So standing behind 1/4" lexan has me feeling a little more safe.![]()
- For some reason the loc line that came with my setup would not move without force, and the line always popped off the value fitting. Not to mention almost hitting my 6k camera setup and soaking me in coolant, I had enough....
Parts purchased at Enco, Lowes & Homedepot and spent less than $40
I had 2 Snap Flow 1/4" hose kits laying around from my pervious CNC DIY Mill, so I'm not sure if this kit is still sold at Enco or not, but think I paid a little under $16 for both.
As for the brass fittings, here's a picture that shows the exact model number and company.
Note I purchased two different step down pipe sizes due to what came with my kit. You might be able to skip these products if you find a kit that offers two of the same size Snap Flow threaded fittings.
