587,166 active members*
3,988 visitors online*
Results 1 to 6 of 6
    CNC Lathe Work
    Need 200 pieces of the attached drawing. Will require a sample prior to the production run.
    Thanks,
    Walt
    Attached Files Attached Files
    Additional Information
    I don't specify it on the drawing, but a small (.005/.010) 45 would be acceptable in the inside corner. Then the same tool could be used to do everything but the parting operation. I could do the chamfer left after the cutoff.
    Thanks,
    Walt
    More Info
    Judging by the questions I've been getting, my post isn't nearly as clear as I thought it was. I re-did the drawing and added a dxf.
    Hopefully, this will clear the muddy waters.
    Cheers,
    Walt
    Feb 2009
    6028
    Would probably be cheaper if you accepted a small radius in that inside corner. All turning tools are ground with some radius on the tips. Say a .007 radius tool. Dead sharp tools leave a real crappy finish, even .007 is on the sharp side. A .015 or so would be even better.
    May 2007
    1003
    A .007R will give a good finish. I agree that a fillet radius will be easier than a 45 degree chamfer of that size. However, it can be made without making a special tool. Use Kennametal CCGT-21.5X.0LF KC5025 insert. This insert has a .0015R corner. It will do the small 45 degree you requested, and provide an acceptable finish. Just keep the feedrate down to around F.001 (or less) and you should be fine.
    A sharp corner (no radius) gives a crappy finish. Even a radius as small as this one will give a decent finish.
    And, no, my company's owner wouldn't be interested in quoting this job.
    A vendor has been found.
    Thanks to everyone that took the time to give me a quote.
  1. Who will work on a D&M 9 CNC lathe?
    By ken seale in forum Employment Opportunity
    Last Post: 03-30-2010, 12:12 AM
  2. RFQ CNC Lathe Work
    By Exoray in forum Employment Opportunity
    Last Post: 04-16-2009, 10:55 PM
  3. Need RFQ - Lathe work
    By ozturbo in forum Employment Opportunity
    Last Post: 07-11-2008, 07:00 PM
  4. Need CNC Lathe work?
    By mc-motorsports in forum Employment Opportunity
    Last Post: 12-18-2007, 10:17 PM
  5. CNC lathe work
    By Crazy Phantom in forum Employment Opportunity
    Last Post: 02-06-2006, 05:42 AM
