My machine will go to 5140 rpms and wish it would go faster for the little cutters I have to use. I was thinking what if someone was to make a bigger pulley for faster speeds or even add a larger motor, say 3hp ...... Thoughts ???
As for cutting, you're saying to throw my rpms to 5140 for a 1/4" cutter ? Even with a DOC of 0.090" ?
Last should I jack up the feed rate to ?
If so,.... Wow my iphone machine feed & speed, IPM app is way off then.
Please let me know if I'm doing this right. To measure my chip load, pick up a chip and measure it with a caliper is the correct way to do it right ?
