Does anyone have a length ways cross section of the neck pocket area (need to know the profile on the bottom of the neck joint)?
Hi do you mean the depth of cut of the neck pocket? if so this is normally about 5/8ths of an inch deep but you can make this as low as you want. I normally like my neck sat in where just the fretboard is proud so I make my neck pocket depths about 19-20mm deep,hope this helps.
What I mean is the crossection of the heel across the length of the body (the all access neck joint as they call it)
However details of the neck pocket depth are useful. Is it angled- I read somewhere there is a neck angle to allow full use of the floyd rose?
U might have guessed I am now trying to make a jem model. Its a good excercise for learning how to do bevels ect
Anyway I decided this forum needs some colour blown into it so here goes:
(work in progress):rainfro:
Love that render!
