587,157 active members*
2,992 visitors online*
Results 1 to 16 of 16
    Nov 2005
    57
    Smile G21 and G17 Mazatrol M2
    My Mazak mazatrol M2 seams bee allergic for G21 and G17
    Why and whot can I do.
    The machine is metric as is now.
    Sven
    Thankyou.
    Mar 2005
    988
    Are you getting alarms? What is the machine doing when you command G21 or G17?
    It's just a part..... cutter still goes round and round....
    Nov 2005
    57
    Machine stops and show alarm (illegal data)
    So i take away G21 and start again.
    Same thing and i take away G17.
    After that it works.
    Sven
    Mar 2005
    988
    What's the alarm number?
    Illegal Data also usually means that you are using some codes that cannot be used with each other or on the same line. A conflict of code...
    Can you post a portion of the program where you're having problems?
    Nov 2005
    57
    G17 and G21
    O0100
    N1 G54 G90 G80 G21 G17 G00 Its little but problem
    starts here.
    Machine stops and show alarm (551 illegal data input)
    Still same thing so i also take away G17.
    After that it works for more then 8000 lines.
    Machine is in Europe and all the time in metric mode.
    Sven
    Feb 2007
    198
    related comments that may not solve the problem;
    I am in the habit of putting G54 in a line all by itself at the first line of the program. In my 30 year history dealing with CNC's (not all accross the board - fanuc, mits, mazatrol, vickers, dyna mechatronics) sometimes problems can be caused by burying G54 with a string of other modals.
    Secondly. NOT ALL CNC's can digest more than 3 G codes in one line. Some only act on the first three and ignore the subsequent ones. Mazatrol EIA can digest up to a string of 6, I think?
    PROGRAM EXPERIMENT
    N1G54
    N2 G01
    N3 G17
    N4 G90
    N5 G21
    N6 G80
    You can put in any G codes you want, in any order you want. The purpose of this is trouble shooting. Using the N word (aka sequence number) will help decode where your program error is taking place. (12, 34, 56) type of info will appear along with the alarm code (Always include the alarm number when asking questions) 12 is program number, 34 is sequence number, 56 is the line after the sequence number 34 is read. I have never quite understood whether the alarm is pointing to "the last good line" or "the line where the problem is", so I use this just to get in the vicinity of the problem.
    Use the scientific method. run the experiment and change one thing at a time and record the results.
    jim
    Mar 2005
    988
    Not sure if Jim's test is going to work... I suspect no alarms with that. Reason being is that all the codes are valid particularly if you have them all seperated on each line (for this case of the codes being used). But Jim's reasoning is not far off I think and right alongside of what I'm thinking. The problem is the combination of codes in the same line I believe.
    In this case (on that ancient control), your plane select is likely the culprit being used on the same line with G54 (and possibly along with G0).
    But as Jim suggested, test the difference. Try the same line but only remove G17 (for example)
    Nov 2005
    57
    G21 G17 and Mazatrol m-2
    Hello again Psycomill.
    I notice today that it wasent any G40 in begining
    but it is a G43 later in prog,coud it be sourse to the problems.
    And about compensation some on net or on these site was say
    it is nessesary set tools to zero,do that means in tool data and
    tool comp.
    Thank you one more time.
    Sven.
    Mar 2005
    988
    I don't think that would be it. G40 cancels Cutter Compensation and G43 is to activate Tool Length.
    tool comp.
    This is going to depend on how your machine is set up on the parameters and how you program. If you're only talking about diameter compensation, you're pretty safe to set both sides (Data and Comp) to zero. If you program by centerline of tool, you'll know right away as well since the part size won't be right (1/2 the cutter diameter off).
    If you're talking about Tool Length settings, ... You need the tool length active and correct for at least one side. Again, this will depend on parameters.
    Sounds like you may need to run a couple tests with tool length and diameter compensation to see how your machine is set up..... be careful doing this....
    Nov 2005
    57
    I dont think its that G40 G43 Mazatrol M2
    How do i in tool data set tool lengd without diameter
    I belive it will come up something like tol data not complite
    And how to understand one side.
    Thanks meny times more
    Sven
    Nov 2005
    57
    Here is a program that works untill line 11 or 12.
    O100 (POCKET IDAG..NC)
    N1 (TUE. 06/15/2010 10:38AM)
    N2 ( MAZATROL CAM M-2 - METRIC)
    N3 ( T10 ENDMILL ROUGH , DIAMETER = 16. , LENGTH = 127.)
    N4 ( T1 ENDMILL FINISH , DIAMETER = 12.7 , LENGTH = 127.)
    N5 G90 G80 G17 G00
    N6 G91 G28 Z0.
    N7 G91 G28 X0. Y0.
    N8 (JOB 1 POCKET)
    N9 (FEATURE POCKET)
    N10 M06 T10
    N11 M03 S994
    N12 G54 G90 X.73 Y.73
    N13 G43 Z2.54 H10
    N14 M08
    N15 G01 Z-12.7 F101.0375
    N16 X-.73 F197.0232
    N17 Y-.73
    N18 X.73
    N19 Y.73
    N20 X8.73
    N21 Y8.73
    N22 X-8.73
    N23 Y-8.73
    N24 X8.73
    N25 Y.73
    N26 X16.73
    N27 Y16.73
    N28 X-16.73
    N29 Y-16.73
    N30 X16.73
    N31 Y.73
    N32 X24.73
    N33 Y24.73
    N34 X-24.73
    N35 Y-24.73
    N36 X24.73
    N37 Y.73
    N38 X32.73
    N39 Y32.73
    N40 X-32.73
    N41 Y-32.73
    N42 X32.73
    N43 Y.73
    N44 Y32.73
    N45 X40.73
    N46 Y40.73
    N47 X-40.73
    N48 Y-40.73
    N49 X40.73
    N50 Y32.73
    N51 G00 Z2.54
    N52 M09
    N53 M05
    N54 G91 G30 Z0. H0
    N55 (JOB 1 POCKET)
    N56 (FEATURE POCKET)
    N57 M06 T1
    N58 M03 S1879
    N59 G54 G90 X43.65 Y43.65
    N60 G43 Z2.54 H1
    N61 M08
    N62 G01 Z-12.7 F190.937
    N63 X-43.65
    N64 Y-43.65
    N65 X43.65
    N66 Y43.65
    N67 G00 Z2.54
    N68 M09
    N69 M05
    N70 G91 G28 Z0.
    N71 G91 G28 X0. Y0.
    N72 M02
    N73 M30
    Nov 2005
    57
    If i set not complet inputs in tool file in the mazak
    I will get alarm inadequate data in the tool data
    then i try to set the info for the same tool nr.
    Do that means that i should set these data on Pc side
    in progr cad/cam under tools.
    Nov 2005
    57
    Psychomill was right Mazatrol M-2 Four digits
    Thanks to Psychomill for pointing
    out four digits after point can give trouble.It did.
    I changed to 3 digits after point and it works.
    However I made a new prog,working good untill line
    9994,there it stops giving alarm 551 saying as follow.
    (Numerical falling out off the specified range has
    been entered).
    Now I dont know to do,becuse I just dont see any Wrong,
    Maybee other eyes see better?
    O100 (KROSS.NC made off 10"lenghd 2"Dia, alu stock 12"times 12")
    N1 (WED. 06/23/2010 11:15AM)
    N4 G90 G80 G17 G00
    N5 G91 G28 Z0.
    N6 G91 G28 X0. Y0.
    N7 (JOB 1 SLICE CUT PLANAR)
    N8 (FEATURE SLICE PLANAR)
    N9 M06 T10
    N10 M03 S994
    N11 G54 G90 X-50.74 Y130.174
    N12 G43 Z2.6 H10
    N13 M08
    N14 G01 Z0. F3031.12
    N15 X50.74 F5910.69
    N16 X53.407 Y128.975
    N17 X51.331 Z-.062
    N18 X-51.626 Z-.056
    N19 X-53.407 Z0.
    N20 X-53.826 Y127.775
    N21 X-53.014 Z-.03
    N22 X-52.202 Z-.121
    N23 X-51.39 Z-.254
    N24 X51.39
    N25 X52.202 Z-.121
    N26 X53.014 Z-.03
    N27 X53.826 Z0.
    N28 X53.882 Y126.575
    N29 X52.984 Z-.036
    N30 X52.085 Z-.146
    N31 X51.187 Z-.331
    N32 X50.289 Z-.596
    N33 X-50.289
    N34 X-51.187 Z-.331
    N35 X-52.085 Z-.146
    N36 X-52.984 Z-.036
    N37 X-53.882 Z0.
    N38 Y125.375
    N39 X-52.984 Z-.036
    N40 X-52.085 Z-.146
    N41 X-51.187 Z-.331
    N42 X-50.289 Z-.596
    N43 X-49.025 Z-1.084
    N44 X48.985
    N45 X50.289 Z-.596
    N46 X51.187 Z-.331
    N47 X52.085 Z-.146
    N48 X52.984 Z-.036
    N49 X53.882 Z0.
    N50 Y124.175
    N51 X52.984 Z-.036
    N52 X52.085 Z-.146
    N53 X51.187 Z-.331
    N54 X50.289 Z-.596
    N55 X49.84 Z-.756
    N56 X48.942 Z-1.151
    N57 X47.888 Z-1.744
    N58 X-47.876 Z-1.748
    N59 X-48.942 Z-1.151
    N60 X-49.84 Z-.756
    N61 X-50.289 Z-.596
    N62 X-51.187 Z-.331
    N63 X-52.085 Z-.146
    N64 X-52.984 Z-.036
    N65 X-53.882 Z0.
    N66 Y122.975
    N67 X-52.984 Z-.036
    N68 X-52.085 Z-.146
    N69 X-51.187 Z-.331
    N70 X-50.289 Z-.596
    N71 X-49.84 Z-.757
    N72 X-48.942 Z-1.151
    N73 X-48.044 Z-1.646
    N74 X-47.146 Z-2.258
    N75 X-46.697 Z-2.62
    N76 X-39.513 Z-2.634
    N77 X46.697 Z-2.62
    N78 X47.146 Z-2.258
    N79 X48.044 Z-1.646
    N80 X48.942 Z-1.151
    N81 X49.84 Z-.756
    N82 X50.289 Z-.596
    N83 X51.187 Z-.331
    N84 X52.085 Z-.146
    N85 X52.984 Z-.036
    N86 X53.882 Z0.
    N87 Y121.775
    N88 X52.984 Z-.036
    N89 X52.085 Z-.146
    N90 X51.187 Z-.331
    N91 X50.289 Z-.596
    N92 X49.84 Z-.757
    N93 X48.942 Z-1.151
    N94 X48.044 Z-1.646
    N95 X47.146 Z-2.258
    N96 X46.343 Z-2.927
    N97 X45.5 Z-3.784
    N98 X45.456 Z-3.805
    N99 X-45.439
    N100 X-45.499 Z-3.785
    N101 X-46.248 Z-3.013
    N102 X-47.146 Z-2.258
    N103 X-48.044 Z-1.646
    N104 X-48.942 Z-1.151
    N105 X-49.84 Z-.757
    N106 X-50.289 Z-.596
    N107 X-51.187 Z-.331
    N108 X-52.085 Z-.146
    N109 X-52.984 Z-.036
    N110 X-53.882 Z0.
    N111 Y120.575
    N112 X-52.984 Z-.036
    N113 X-52.085 Z-.146
    N114 X-51.187 Z-.331
    N115 X-50.289 Z-.596
    N116 X-49.84 Z-.757
    N117 X-48.942 Z-1.151
    N118 X-48.044 Z-1.646
    N119 X-47.146 Z-2.258
    N120 X-46.248 Z-3.013
    N121 X-45.799 Z-3.463
    N122 X-45.35 Z-3.958
    N123 X-44.677 Z-4.839
    N124 X-44.284 Z-5.453
    N125 X44.237 Z-5.456
    N126 X44.288 Z-5.446
    N127 X44.647 Z-4.883
    N128 X45.057 Z-4.325
    N129 X45.467 Z-3.821
    N130 X46.287 Z-2.977
    N131 X47.146 Z-2.258
    N132 X48.044 Z-1.646
    N133 X48.942 Z-1.151
    N134 X49.84 Z-.757
    N135 X50.289 Z-.596
    N136 X51.187 Z-.331
    N137 X52.085 Z-.146
    N138 X52.984 Z-.036
    N139 X53.882 Z0.
    N140 Y119.375
    N141 X52.984 Z-.036
    N142 X52.085 Z-.146
    N143 X51.187 Z-.331
    N144 X50.289 Z-.596
    N145 X49.84 Z-.757
    N146 X48.942 Z-1.151
    N147 X48.044 Z-1.646
    N148 X47.146 Z-2.258
    N149 X46.248 Z-3.013
    N150 X45.799 Z-3.463
    N151 X45.35 Z-3.958
    N152 X44.677 Z-4.839
    N153 X44.228 Z-5.547
    N154 X43.779 Z-6.401
    N155 X43.554 Z-6.911
    N156 X43.217 Z-7.839
    N157 X43.077 Z-8.308
    N158 X-43.077
    N159 X-43.33 Z-7.496
    N160 X-43.554 Z-6.911
    N161 X-43.779 Z-6.401
    N162 X-44.228 Z-5.547
    N163 X-44.677 Z-4.839
    N164 X-45.35 Z-3.958
    N165 X-45.799 Z-3.463
    N166 X-46.248 Z-3.013
    N167 X-47.146 Z-2.258
    N168 X-48.044 Z-1.646
    N169 X-48.942 Z-1.151
    N170 X-49.84 Z-.757
    N171 X-50.289 Z-.596
    N172 X-51.187 Z-.331
    N173 X-52.085 Z-.146
    N174 X-52.984 Z-.036
    N175 X-53.882 Z0.
    N176 Y118.175
    N177 X-52.984 Z-.036
    N178 X-52.085 Z-.146
    N179 X-51.187 Z-.331
    N180 X-50.289 Z-.596
    N181 X-49.84 Z-.757
    N182 X-48.942 Z-1.151
    N183 X-48.044 Z-1.646
    N184 X-47.146 Z-2.258
    N185 X-46.248 Z-3.013
    N186 X-45.799 Z-3.463
    N187 X-45.35 Z-3.958
    N188 X-44.677 Z-4.839
    N189 X-44.228 Z-5.547
    N190 X-43.779 Z-6.401
    N191 X-43.554 Z-6.911
    N192 X-43.33 Z-7.496
    N193 X-43.003 Z-8.619
    N194 X-42.798 Z-9.751
    N195 X-42.491 Z-13.112
    N196 X-42.082 Z-15.789
    N197 X-41.346 Z-19.058
    N198 X-40.491 Z-21.866
    N199 X-39.757 Z-23.846
    N200 X-39.033 Z-25.551
    N201 X-38.554 Z-26.583
    N202 X-38.074 Z-27.548
    N203 X-37.595 Z-28.455
    N204 X-36.635 Z-30.125
    N205 X-35.676 Z-31.638
    N206 X-34.839 Z-32.859
    N207 X-34.002 Z-33.989
    N208 X-33.166 Z-35.047
    N209 X-32.329 Z-36.043
    N210 X-31.408 Z-37.073
    N211 X-30.487 Z-38.035
    N212 X-29.566 Z-38.941
    N213 X-28.645 Z-39.796
    N214 X-27.77 Z-40.565
    N215 X-26.895 Z-41.292
    N216 X-26.02 Z-41.981
    N217 X-25.145 Z-42.634
    N218 X-24.233 Z-43.278
    N219 X-23.321 Z-43.886
    N220 X-22.41 Z-44.462
    N221 X-21.498 Z-45.007
    N222 X-19.729 Z-45.98
    N223 X-17.961 Z-46.848
    N224 X-16.151 Z-47.634
    N225 X-14.342 Z-48.323
    N226 X-12.559 Z-48.913
    N227 X-10.776 Z-49.418
    N228 X-8.958 Z-49.849
    N229 X-7.169 Z-50.192
    N230 X-5.362 Z-50.46
    N231 X-3.592 Z-50.648
    N232 X-1.797 Z-50.761
    N233 X0. Z-50.8
    N234 X1.797 Z-50.761
    N235 X3.592 Z-50.648
    N236 X5.362 Z-50.46
    N237 X7.169 Z-50.192
    N238 X8.958 Z-49.849
    N239 X10.776 Z-49.418
    N240 X12.559 Z-48.913
    N241 X14.342 Z-48.323
    N242 X16.151 Z-47.634
    N243 X17.961 Z-46.848
    N244 X18.845 Z-46.427
    N245 X20.614 Z-45.507
    N246 X22.41 Z-44.462
    N247 X23.321 Z-43.886
    N248 X24.233 Z-43.278
    N249 X25.145 Z-42.634
    N250 X26.02 Z-41.981
    N251 X26.895 Z-41.292
    N252 X27.77 Z-40.565
    N253 X28.645 Z-39.796
    N254 X29.566 Z-38.941
    N255 X30.487 Z-38.035
    N256 X31.408 Z-37.073
    N257 X32.329 Z-36.043
    N258 X33.166 Z-35.047
    N259 X34.002 Z-33.989
    N260 X34.839 Z-32.859
    N261 X35.676 Z-31.638
    N262 X36.156 Z-30.898
    N263 X37.115 Z-29.312
    N264 X38.074 Z-27.548
    N265 X38.554 Z-26.583
    N266 X39.033 Z-25.551
    N267 X39.757 Z-23.846
    N268 X40.491 Z-21.866
    N269 X40.979 Z-20.339
    N270 X41.57 Z-18.179
    N271 X42.184 Z-15.23
    N272 X42.44 Z-13.521
    N273 X42.798 Z-9.751
    N274 X42.952 Z-8.854
    N275 X43.217 Z-7.839
    N276 X43.554 Z-6.911
    N277 X43.779 Z-6.401
    N278 X44.228 Z-5.547
    N279 X44.677 Z-4.839
    N280 X45.35 Z-3.958
    N281 X45.799 Z-3.463
    N282 X46.248 Z-3.013
    N283 X47.146 Z-2.258
    N284 X48.044 Z-1.646
    N285 X48.942 Z-1.151
    N286 X49.84 Z-.757
    N287 X50.289 Z-.596
    N288 X51.187 Z-.331
    N289 X52.085 Z-.146
    N290 X52.984 Z-.036
    N291 X53.882 Z0.
    N292 Y116.975
    N293 X52.984 Z-.036
    N294 X52.085 Z-.146
    N295 X51.187 Z-.331
    N296 X50.289 Z-.596
    N297 X49.84 Z-.757
    N298 X48.942 Z-1.151
    N299 X48.044 Z-1.646
    N300 X47.146 Z-2.258
    N301 X46.248 Z-3.013
    N302 X45.799 Z-3.463
    N303 X45.35 Z-3.958
    N304 X44.677 Z-4.839
    N305 X44.228 Z-5.547
    N306 X43.779 Z-6.401
    N307 X43.554 Z-6.91
    N308 X43.217 Z-7.838
    N309 X42.952 Z-8.854
    N310 X42.798 Z-9.751
    N311 X42.44 Z-13.521
    N312 X42.184 Z-15.229
    N313 X41.57 Z-18.179
    N314 X40.979 Z-20.339
    N315 X40.491 Z-21.866
    N316 X39.758 Z-23.846
    N317 X39.033 Z-25.551
    N318 X38.554 Z-26.583
    N319 X38.074 Z-27.548
    N320 X37.115 Z-29.312
    N321 X36.156 Z-30.898
    N322 X35.676 Z-31.638
    N323 X34.839 Z-32.859
    N324 X34.002 Z-33.989
    N325 X33.166 Z-35.047
    N326 X32.329 Z-36.043
    N327 X31.408 Z-37.073
    N328 X30.487 Z-38.035
    N329 X29.566 Z-38.941
    N330 X28.645 Z-39.796
    N331 X27.77 Z-40.565
    N332 X26.895 Z-41.292
    N333 X26.02 Z-41.981
    N334 X25.145 Z-42.634
    N335 X24.233 Z-43.278
    N336 X23.321 Z-43.886
    N337 X22.41 Z-44.462
    N338 X20.614 Z-45.507
    N339 X18.845 Z-46.427
    N340 X17.961 Z-46.848
    N341 X16.151 Z-47.634
    N342 X14.342 Z-48.323
    N343 X12.559 Z-48.913
    N344 X10.776 Z-49.418
    N345 X8.958 Z-49.849
    N346 X7.169 Z-50.192
    N347 X5.362 Z-50.46
    N348 X3.592 Z-50.648
    N349 X1.797 Z-50.761
    N350 X0. Z-50.8
    N351 X-1.797 Z-50.761
    N352 X-3.592 Z-50.648
    N353 X-5.362 Z-50.46
    N354 X-7.169 Z-50.192
    N355 X-8.958 Z-49.849
    N356 X-10.776 Z-49.418
    N357 X-12.559 Z-48.913
    N358 X-14.342 Z-48.323
    N359 X-16.151 Z-47.634
    N360 X-17.961 Z-46.848
    N361 X-19.729 Z-45.98
    N362 X-21.498 Z-45.007
    N363 X-22.41 Z-44.462
    N364 X-23.321 Z-43.886
    N365 X-24.233 Z-43.278
    N366 X-25.145 Z-42.634
    N367 X-26.02 Z-41.981
    N368 X-26.895 Z-41.292
    N369 X-27.77 Z-40.565
    N370 X-28.645 Z-39.796
    N371 X-29.566 Z-38.941
    N372 X-30.487 Z-38.035
    N373 X-31.408 Z-37.073
    N374 X-32.329 Z-36.043
    N375 X-33.166 Z-35.047
    N376 X-34.002 Z-33.989
    N377 X-34.839 Z-32.859
    N378 X-35.676 Z-31.638
    N379 X-36.635 Z-30.125
    N380 X-37.595 Z-28.455
    N381 X-38.074 Z-27.548
    N382 X-38.554 Z-26.583
    N383 X-39.033 Z-25.551
    N384 X-39.758 Z-23.846
    N385 X-40.491 Z-21.866
    N386 X-41.346 Z-19.058
    N387 X-42.082 Z-15.789
    N388 X-42.491 Z-13.112
    N389 X-42.798 Z-9.751
    N390 X-43.003 Z-8.619
    N391 X-43.33 Z-7.496
    N392 X-43.554 Z-6.91
    N393 X-43.779 Z-6.401
    N394 X-44.228 Z-5.547
    N395 X-44.677 Z-4.839
    N396 X-45.35 Z-3.958
    N397 X-45.799 Z-3.463
    N398 X-46.248 Z-3.013
    N399 X-47.146 Z-2.258
    N400 X-48.044 Z-1.646
    N401 X-48.942 Z-1.151
    N402 X-49.84 Z-.757
    N403 X-50.289 Z-.596
    N404 X-51.187 Z-.331
    N405 X-52.085 Z-.146
    N406 X-52.984 Z-.036
    N407 X-53.882 Z0.
    N408 Y115.775
    N409 X-52.984 Z-.036
    N410 X-52.085 Z-.146
    N411 X-51.187 Z-.331
    N412 X-50.289 Z-.596
    N413 X-49.84 Z-.757
    N414 X-48.942 Z-1.151
    N415 X-48.044 Z-1.646
    N416 X-47.146 Z-2.258
    N417 X-46.248 Z-3.013
    N418 X-45.799 Z-3.463
    N419 X-45.35 Z-3.958
    N420 X-44.677 Z-4.839
    N421 X-44.228 Z-5.547
    N422 X-43.779 Z-6.401
    N423 X-43.554 Z-6.91
    N424 X-43.33 Z-7.496
    N425 X-43.003 Z-8.619
    N426 X-42.798 Z-9.751
    N427 X-42.491 Z-13.112
    N428 X-42.082 Z-15.789
    N429 X-41.346 Z-19.058
    N430 X-40.491 Z-21.866
    N431 X-39.758 Z-23.846
    N432 X-39.033 Z-25.551
    N433 X-38.554 Z-26.583
    N434 X-38.074 Z-27.548
    N435 X-37.595 Z-28.455
    N436 X-36.635 Z-30.125
    N437 X-35.676 Z-31.638
    N438 X-34.839 Z-32.859
    N439 X-34.002 Z-33.989
    N440 X-33.166 Z-35.047
    N441 X-32.329 Z-36.043
    N442 X-31.408 Z-37.073
    N443 X-30.487 Z-38.035
    N444 X-29.566 Z-38.941
    N445 X-28.645 Z-39.796
    N446 X-27.77 Z-40.565
    N447 X-26.895 Z-41.292
    N448 X-26.02 Z-41.981
    N449 X-25.145 Z-42.634
    N450 X-24.233 Z-43.278
    N451 X-23.321 Z-43.886
    N452 X-22.41 Z-44.462
    N453 X-21.498 Z-45.007
    N454 X-19.729 Z-45.98
    N455 X-17.961 Z-46.848
    N456 X-16.151 Z-47.634
    N457 X-14.342 Z-48.323
    N458 X-12.559 Z-48.913
    N459 X-10.776 Z-49.418
    N460 X-8.958 Z-49.849
    N461 X-7.169 Z-50.192
    N462 X-5.362 Z-50.46
    N463 X-3.592 Z-50.648
    N464 X-1.797 Z-50.761
    N465 X0. Z-50.8
    N466 X1.797 Z-50.761
    N467 X3.592 Z-50.648
    N468 X5.362 Z-50.46
    N469 X7.169 Z-50.192
    N470 X8.958 Z-49.849
    N471 X10.776 Z-49.418
    N472 X12.559 Z-48.913
    N473 X14.342 Z-48.323
    N474 X16.151 Z-47.634
    N475 X17.961 Z-46.848
    N476 X18.845 Z-46.427
    N477 X20.614 Z-45.507
    N478 X22.41 Z-44.462
    N479 X23.321 Z-43.886
    N480 X24.233 Z-43.278
    N481 X25.145 Z-42.634
    N482 X26.02 Z-41.981
    N483 X26.895 Z-41.292
    N484 X27.77 Z-40.565
    N485 X28.645 Z-39.796
    N486 X29.566 Z-38.941
    N487 X30.487 Z-38.035
    N488 X31.408 Z-37.073
    N489 X32.329 Z-36.043
    N490 X33.166 Z-35.047
    N491 X34.002 Z-33.989
    N492 X34.839 Z-32.859
    N493 X35.676 Z-31.638
    N494 X36.156 Z-30.898
    N495 X37.115 Z-29.312
    N496 X38.074 Z-27.548
    N497 X38.554 Z-26.583
    N498 X39.033 Z-25.551
    N499 X39.758 Z-23.846
    N500 X40.491 Z-21.866
    N501 X40.979 Z-20.339
    N502 X41.57 Z-18.179
    N503 X42.184 Z-15.229
    N504 X42.44 Z-13.521
    N505 X42.798 Z-9.751
    N506 X42.952 Z-8.854
    N507 X43.217 Z-7.838
    N508 X43.554 Z-6.91
    N509 X43.779 Z-6.401
    N510 X44.228 Z-5.547
    N511 X44.677 Z-4.839
    N512 X45.35 Z-3.958
    N513 X45.799 Z-3.463
    N514 X46.248 Z-3.013
    N515 X47.146 Z-2.258
    N516 X48.044 Z-1.646
    N517 X48.942 Z-1.151
    N518 X49.391 Z-.945
    N519 X50.289 Z-.596
    N520 X51.187 Z-.331
    N521 X52.085 Z-.146
    N522 X52.984 Z-.036
    N523 X53.882 Z0.
    N524 Y114.575
    N525 X52.984 Z-.036
    N526 X52.085 Z-.146
    N527 X51.187 Z-.331
    N528 X50.289 Z-.596
    N529 X49.391 Z-.945
    N530 X48.942 Z-1.151
    N531 X48.044 Z-1.646
    N532 X47.146 Z-2.258
    N533 X46.248 Z-3.013
    N534 X45.799 Z-3.463
    N535 X45.35 Z-3.958
    N536 X44.677 Z-4.839
    N537 X44.228 Z-5.547
    N538 X43.779 Z-6.402
    N539 X43.554 Z-6.91
    N540 X43.217 Z-7.838
    N541 X42.952 Z-8.854
    N542 X42.798 Z-9.751
    N543 X42.44 Z-13.521
    N544 X42.184 Z-15.229
    N545 X41.57 Z-18.179
    N546 X40.979 Z-20.339
    N547 X40.491 Z-21.866
    N548 X39.758 Z-23.846
    N549 X39.033 Z-25.551
    N550 X38.554 Z-26.583
    N551 X38.074 Z-27.548
    N552 X37.115 Z-29.312
    N553 X36.156 Z-30.898
    N554 X35.676 Z-31.638
    N555 X34.839 Z-32.859
    N556 X34.002 Z-33.989
    N557 X33.166 Z-35.047
    N558 X32.329 Z-36.043
    N559 X31.408 Z-37.073
    N560 X30.487 Z-38.035
    N561 X29.566 Z-38.941
    N562 X28.645 Z-39.796
    N563 X27.77 Z-40.565
    N564 X26.895 Z-41.292
    N565 X26.02 Z-41.981
    N566 X25.145 Z-42.634
    N567 X24.233 Z-43.278
    N568 X23.321 Z-43.886
    N569 X22.41 Z-44.462
    N570 X20.614 Z-45.507
    N571 X18.845 Z-46.427
    N572 X17.961 Z-46.848
    N573 X16.151 Z-47.634
    N574 X14.342 Z-48.323
    N575 X12.559 Z-48.913
    N576 X10.776 Z-49.418
    N577 X8.958 Z-49.849
    N578 X7.169 Z-50.192
    N579 X5.362 Z-50.46
    N580 X3.592 Z-50.648
    N581 X1.797 Z-50.761
    N582 X0. Z-50.8
    N583 X-1.797 Z-50.761
    N584 X-3.592 Z-50.648
    N585 X-5.362 Z-50.46
    N586 X-7.169 Z-50.192
    N587 X-8.958 Z-49.849
    N588 X-10.776 Z-49.418
    N589 X-12.559 Z-48.913
    N590 X-14.342 Z-48.323
    N591 X-16.151 Z-47.634
    N592 X-17.961 Z-46.848
    N593 X-19.729 Z-45.98
    N594 X-21.498 Z-45.007
    N595 X-22.41 Z-44.462
    N596 X-23.321 Z-43.886
    N597 X-24.233 Z-43.278
    N598 X-25.145 Z-42.634
    N599 X-26.02 Z-41.981
    N600 X-26.895 Z-41.292
    N601 X-27.77 Z-40.565
    N602 X-28.645 Z-39.796
    N603 X-29.566 Z-38.941
    N604 X-30.487 Z-38.035
    N605 X-31.408 Z-37.073
    N606 X-32.329 Z-36.043
    N607 X-33.166 Z-35.047
    N608 X-34.002 Z-33.989
    N609 X-34.839 Z-32.859
    N610 X-35.676 Z-31.638
    N611 X-36.635 Z-30.125
    N612 X-37.595 Z-28.455
    N613 X-38.074 Z-27.548
    N614 X-38.554 Z-26.583
    N615 X-39.033 Z-25.551
    N616 X-39.758 Z-23.846
    N617 X-40.491 Z-21.866
    N618 X-41.346 Z-19.058
    N619 X-42.082 Z-15.789
    N620 X-42.491 Z-13.112
    N621 X-42.798 Z-9.751
    N622 X-43.003 Z-8.619
    N623 X-43.33 Z-7.496
    N624 X-43.554 Z-6.91
    N625 X-43.779 Z-6.402
    N626 X-44.228 Z-5.547
    N627 X-44.677 Z-4.839
    N628 X-45.35 Z-3.958
    N629 X-45.799 Z-3.463
    N630 X-46.248 Z-3.013
    N631 X-47.146 Z-2.258
    N632 X-48.044 Z-1.646
    N633 X-48.942 Z-1.151
    N634 X-49.84 Z-.757
    N635 X-50.289 Z-.596
    N636 X-51.187 Z-.331
    N637 X-52.085 Z-.146
    N638 X-52.984 Z-.036
    N639 X-53.882 Z0.
    N640 Y113.375
    N641 X-52.984 Z-.036
    N642 X-52.085 Z-.146
    N643 X-51.187 Z-.331
    N644 X-50.289 Z-.595
    N645 X-49.84 Z-.757
    N646 X-48.942 Z-1.151
    N647 X-48.044 Z-1.646
    N648 X-47.146 Z-2.258
    N649 X-46.248 Z-3.013
    N650 X-45.799 Z-3.463
    N651 X-45.35 Z-3.958
    N652 X-44.677 Z-4.839
    N653 X-44.228 Z-5.547
    N654 X-43.779 Z-6.402
    N655 X-43.554 Z-6.91
    N656 X-43.33 Z-7.496
    N657 X-43.003 Z-8.619
    N658 X-42.798 Z-9.751
    N659 X-42.491 Z-13.112
    N660 X-42.082 Z-15.789
    N661 X-41.346 Z-19.058
    N662 X-40.491 Z-21.866
    N663 X-39.758 Z-23.846
    N664 X-39.033 Z-25.551
    N665 X-38.554 Z-26.583
    N666 X-38.074 Z-27.548
    N667 X-37.595 Z-28.455
    N668 X-36.635 Z-30.125
    N669 X-35.676 Z-31.638
    N670 X-34.839 Z-32.859
    N671 X-34.002 Z-33.989
    N672 X-33.166 Z-35.047
    N673 X-32.329 Z-36.043
    N674 X-31.408 Z-37.073
    N675 X-30.487 Z-38.035
    N676 X-29.566 Z-38.941
    N677 X-28.645 Z-39.796
    N678 X-27.77 Z-40.565
    N679 X-26.895 Z-41.292
    N680 X-26.02 Z-41.981
    N681 X-25.145 Z-42.634
    N682 X-24.233 Z-43.278
    N683 X-23.321 Z-43.886
    N684 X-22.41 Z-44.462
    N685 X-21.498 Z-45.007
    N686 X-19.729 Z-45.98
    N687 X-17.961 Z-46.848
    N688 X-16.151 Z-47.634
    N689 X-14.342 Z-48.323
    N690 X-12.559 Z-48.913
    N691 X-10.776 Z-49.418
    N692 X-8.958 Z-49.849
    N693 X-7.169 Z-50.192
    N694 X-5.362 Z-50.46
    N695 X-3.592 Z-50.648
    N696 X-1.797 Z-50.761
    N697 X0. Z-50.8
    N698 X1.797 Z-50.761
    N699 X3.592 Z-50.648
    N700 X5.362 Z-50.46
    N701 X7.169 Z-50.192
    N702 X8.958 Z-49.849
    N703 X10.776 Z-49.418
    N704 X12.559 Z-48.913
    N705 X14.342 Z-48.323
    N706 X16.151 Z-47.634
    N707 X17.961 Z-46.848
    N708 X18.845 Z-46.427
    N709 X20.614 Z-45.507
    N710 X22.41 Z-44.462
    N711 X23.321 Z-43.886
    N712 X24.233 Z-43.278
    N713 X25.145 Z-42.634
    N714 X26.02 Z-41.981
    N715 X26.895 Z-41.292
    N716 X27.77 Z-40.565
    N717 X28.645 Z-39.796
    N718 X29.566 Z-38.941
    N719 X30.487 Z-38.035
    N720 X31.408 Z-37.073
    N721 X32.329 Z-36.043
    N722 X33.166 Z-35.047
    N723 X34.002 Z-33.989
    N724 X34.839 Z-32.859
    N725 X35.676 Z-31.638
    N726 X36.156 Z-30.898
    N727 X37.115 Z-29.312
    N728 X38.074 Z-27.548
    N729 X38.554 Z-26.583
    N730 X39.033 Z-25.551
    N731 X39.758 Z-23.846
    N732 X40.491 Z-21.866
    N733 X40.979 Z-20.339
    N734 X41.57 Z-18.179
    N735 X42.184 Z-15.229
    N736 X42.44 Z-13.521
    N737 X42.798 Z-9.751
    N738 X42.952 Z-8.854
    N739 X43.217 Z-7.838
    N740 X43.554 Z-6.91
    N741 X43.779 Z-6.402
    N742 X44.228 Z-5.547
    N743 X44.677 Z-4.839
    N744 X45.35 Z-3.958
    N745 X45.799 Z-3.463
    N746 X46.248 Z-3.013
    N747 X47.146 Z-2.258
    N748 X48.044 Z-1.646
    N749 X48.942 Z-1.151
    N750 X49.391 Z-.945
    N751 X50.289 Z-.595
    N752 X51.187 Z-.331
    N753 X52.085 Z-.146
    N754 X52.984 Z-.036
    N755 X53.882 Z0.
    N756 Y112.175
    N757 X52.984 Z-.036
    N758 X52.085 Z-.146
    N759 X51.187 Z-.331
    N760 X50.289 Z-.595
    N761 X49.391 Z-.945
    N762 X48.942 Z-1.151
    N763 X48.044 Z-1.646
    N764 X47.146 Z-2.258
    N765 X46.248 Z-3.013
    N766 X45.799 Z-3.463
    N767 X45.35 Z-3.958
    N768 X44.677 Z-4.839
    N769 X44.228 Z-5.547
    N770 X43.779 Z-6.402
    N771 X43.554 Z-6.91
    N772 X43.217 Z-7.838
    N773 X42.952 Z-8.854
    N774 X42.798 Z-9.75
    N775 X42.44 Z-13.521
    N776 X42.184 Z-15.229
    N777 X41.57 Z-18.178
    N778 X40.979 Z-20.339
    N779 X40.491 Z-21.866
    N780 X39.758 Z-23.846
    N781 X39.033 Z-25.551
    N782 X38.554 Z-26.583
    N783 X38.074 Z-27.548
    N784 X37.115 Z-29.312
    N785 X36.156 Z-30.898
    N786 X35.676 Z-31.638
    N787 X34.839 Z-32.859
    N788 X34.002 Z-33.989
    N789 X33.166 Z-35.047
    N790 X32.329 Z-36.043
    N791 X31.408 Z-37.073
    N792 X30.487 Z-38.035
    N793 X29.566 Z-38.941
    N794 X28.645 Z-39.796
    N795 X27.77 Z-40.565
    N796 X26.895 Z-41.292
    N797 X26.02 Z-41.981
    N798 X25.145 Z-42.634
    N799 X24.233 Z-43.278
    N800 X23.321 Z-43.886
    N801 X22.41 Z-44.462
    N802 X20.614 Z-45.507
    N803 X18.845 Z-46.427
    N804 X17.961 Z-46.848
    N805 X16.151 Z-47.634
    N806 X14.342 Z-48.323
    N807 X12.559 Z-48.913
    N808 X10.776 Z-49.418
    N809 X8.958 Z-49.849
    N810 X7.169 Z-50.192
    N811 X5.362 Z-50.46
    N812 X3.592 Z-50.648
    N813 X1.797 Z-50.761
    N814 X0. Z-50.8
    N815 X-1.797 Z-50.761
    N816 X-3.592 Z-50.648
    N817 X-5.362 Z-50.46
    N818 X-7.169 Z-50.192
    N819 X-8.958 Z-49.849
    N820 X-10.776 Z-49.418
    N821 X-12.559 Z-48.913
    N822 X-14.342 Z-48.323
    N823 X-16.151 Z-47.634
    N824 X-17.961 Z-46.848
    N825 X-19.729 Z-45.98
    N826 X-21.498 Z-45.007
    N827 X-22.41 Z-44.462
    N828 X-23.321 Z-43.886
    N829 X-24.233 Z-43.278
    N830 X-25.145 Z-42.634
    N831 X-26.02 Z-41.981
    N832 X-26.895 Z-41.292
    N833 X-27.77 Z-40.565
    N834 X-28.645 Z-39.796
    N835 X-29.566 Z-38.941
    N836 X-30.487 Z-38.035
    N837 X-31.408 Z-37.073
    N838 X-32.329 Z-36.043
    N839 X-33.166 Z-35.047
    N840 X-34.002 Z-33.989
    N841 X-34.839 Z-32.859
    N842 X-35.676 Z-31.638
    N843 X-36.635 Z-30.125
    N844 X-37.595 Z-28.455
    N845 X-38.074 Z-27.548
    N846 X-38.554 Z-26.583
    N847 X-39.033 Z-25.551
    N848 X-39.758 Z-23.846
    N849 X-40.491 Z-21.866
    N850 X-41.346 Z-19.058
    N851 X-42.082 Z-15.789
    N852 X-42.491 Z-13.112
    N853 X-42.798 Z-9.75
    N854 X-43.003 Z-8.619
    N855 X-43.33 Z-7.496
    N856 X-43.554 Z-6.91
    N857 X-43.779 Z-6.402
    N858 X-44.228 Z-5.547
    N859 X-44.677 Z-4.839
    N860 X-45.35 Z-3.958
    N861 X-45.799 Z-3.463
    N862 X-46.248 Z-3.013
    N863 X-47.146 Z-2.258
    N864 X-48.044 Z-1.646
    N865 X-48.942 Z-1.151
    N866 X-49.84 Z-.757
    N867 X-50.289 Z-.595
    N868 X-51.187 Z-.331
    N869 X-52.085 Z-.146
    N870 X-52.984 Z-.036
    N871 X-53.882 Z0.
    N872 Y110.975
    N873 X-52.984 Z-.036
    N874 X-52.085 Z-.146
    N875 X-51.187 Z-.331
    N876 X-50.289 Z-.595
    N877 X-49.84 Z-.757
    N878 X-48.942 Z-1.151
    N879 X-48.044 Z-1.646
    N880 X-47.146 Z-2.258
    N881 X-46.697 Z-2.619
    N882 X-46.248 Z-3.013
    N883 X-45.799 Z-3.463
    N884 X-45.35 Z-3.958
    N885 X-44.677 Z-4.839
    N886 X-44.228 Z-5.547
    N887 X-43.779 Z-6.402
    N888 X-43.554 Z-6.91
    N889 X-43.33 Z-7.496
    N890 X-43.003 Z-8.619
    N891 X-42.798 Z-9.75
    N892 X-42.491 Z-13.112
    N893 X-42.082 Z-15.789
    N894 X-41.346 Z-19.058
    N895 X-40.491 Z-21.866
    N896 X-39.758 Z-23.846
    N897 X-39.033 Z-25.551
    N898 X-38.554 Z-26.583
    N899 X-38.074 Z-27.548
    N900 X-37.595 Z-28.455
    N901 X-36.635 Z-30.125
    N902 X-35.676 Z-31.638
    N903 X-34.839 Z-32.859
    N904 X-34.002 Z-33.989
    N905 X-33.166 Z-35.047
    N906 X-32.329 Z-36.043
    N907 X-31.408 Z-37.073
    N908 X-30.487 Z-38.035
    N909 X-29.566 Z-38.941
    N910 X-28.645 Z-39.796
    N911 X-27.77 Z-40.565
    N912 X-26.895 Z-41.292
    N913 X-26.02 Z-41.981
    N914 X-25.145 Z-42.634
    N915 X-24.233 Z-43.278
    N916 X-23.321 Z-43.886
    N917 X-22.41 Z-44.462
    N918 X-21.498 Z-45.007
    N919 X-19.729 Z-45.98
    N920 X-17.961 Z-46.848
    N921 X-16.151 Z-47.634
    N922 X-14.342 Z-48.323
    N923 X-12.559 Z-48.913
    N924 X-10.776 Z-49.418
    N925 X-8.958 Z-49.849
    N926 X-7.169 Z-50.192
    N927 X-5.362 Z-50.46
    N928 X-3.592 Z-50.648
    N929 X-1.797 Z-50.761
    N930 X0. Z-50.8
    N931 X1.797 Z-50.761
    N932 X3.592 Z-50.648
    N933 X5.362 Z-50.46
    N934 X7.169 Z-50.192
    N935 X8.958 Z-49.849
    N936 X10.776 Z-49.418
    N937 X12.559 Z-48.913
    N938 X14.342 Z-48.323
    N939 X16.151 Z-47.634
    N940 X17.961 Z-46.848
    N941 X18.845 Z-46.427
    N942 X20.614 Z-45.507
    N943 X22.41 Z-44.462
    N944 X23.321 Z-43.886
    N945 X24.233 Z-43.278
    N946 X25.145 Z-42.634
    N947 X26.02 Z-41.981
    N948 X26.895 Z-41.292
    N949 X27.77 Z-40.565
    N950 X28.645 Z-39.796
    N951 X29.566 Z-38.941
    N952 X30.487 Z-38.035
    N953 X31.408 Z-37.073
    N954 X32.329 Z-36.043
    N955 X33.166 Z-35.047
    N956 X34.002 Z-33.989
    N957 X34.839 Z-32.859
    N958 X35.676 Z-31.638
    N959 X36.156 Z-30.898
    N960 X37.115 Z-29.312
    N961 X38.074 Z-27.548
    N962 X38.554 Z-26.583
    N963 X39.033 Z-25.551
    N964 X39.758 Z-23.846
    N965 X40.491 Z-21.866
    N966 X40.979 Z-20.339
    N967 X41.57 Z-18.178
    N968 X42.184 Z-15.229
    N969 X42.44 Z-13.521
    N970 X42.798 Z-9.75
    N971 X42.952 Z-8.854
    N972 X43.217 Z-7.838
    N973 X43.554 Z-6.91
    N974 X43.779 Z-6.402
    N975 X44.228 Z-5.547
    N976 X44.677 Z-4.839
    N977 X45.35 Z-3.958
    N978 X45.799 Z-3.463
    N979 X46.248 Z-3.013
    N980 X47.146 Z-2.258
    N981 X48.044 Z-1.646
    N982 X48.942 Z-1.151
    N983 X49.391 Z-.945
    N984 X50.289 Z-.595
    N985 X51.187 Z-.331
    N986 X52.085 Z-.146
    N987 X52.984 Z-.036
    N988 X53.882 Z0.
    N989 Y109.775
    N990 X52.984 Z-.036
    N991 X52.085 Z-.146
    N992 X51.187 Z-.331
    N993 X50.289 Z-.595
    N994 X49.391 Z-.945
    N995 X48.942 Z-1.151
    N996 X48.044 Z-1.646
    N997 X47.146 Z-2.258
    N998 X46.697 Z-2.619
    N999 X46.248 Z-3.013
    N1000 X45.799 Z-3.463
    N1001 X45.35 Z-3.958
    N1002 X44.677 Z-4.839
    N1003 X44.228 Z-5.547
    N1004 X43.779 Z-6.402
    N1005 X43.554 Z-6.91
    N1006 X43.217 Z-7.838
    N1007 X42.952 Z-8.854
    N1008 X42.798 Z-9.75
    N1009 X42.44 Z-13.521
    N1010 X42.184 Z-15.229
    N1011 X41.57 Z-18.178
    N1012 X40.979 Z-20.339
    N1013 X40.491 Z-21.866
    N1014 X39.758 Z-23.846
    N1015 X39.033 Z-25.551
    N1016 X38.554 Z-26.583
    N1017 X38.074 Z-27.548
    N1018 X37.115 Z-29.312
    N1019 X36.156 Z-30.898
    N1020 X35.676 Z-31.638
    N1021 X34.839 Z-32.859
    N1022 X34.002 Z-33.989
    N1023 X33.166 Z-35.047
    N1024 X32.329 Z-36.043
    N1025 X31.408 Z-37.073
    N1026 X30.487 Z-38.035
    N1027 X29.566 Z-38.941
    N1028 X28.645 Z-39.796
    N1029 X27.77 Z-40.565
    N1030 X26.895 Z-41.292
    N1031 X26.02 Z-41.981
    N1032 X25.145 Z-42.634
    N1033 X24.233 Z-43.278
    N1034 X23.321 Z-43.886
    N1035 X22.41 Z-44.462
    N1036 X20.614 Z-45.507
    N1037 X18.845 Z-46.427
    N1038 X17.961 Z-46.848
    N1039 X16.151 Z-47.634
    N1040 X14.342 Z-48.323
    N1041 X12.559 Z-48.913
    N1042 X10.776 Z-49.418
    N1043 X8.958 Z-49.849
    N1044 X7.169 Z-50.192
    N1045 X5.362 Z-50.46
    N1046 X3.592 Z-50.648
    N1047 X1.797 Z-50.761
    N1048 X0. Z-50.8
    N1049 X-1.797 Z-50.761
    N1050 X-3.592 Z-50.648
    N1051 X-5.362 Z-50.46
    N1052 X-7.169 Z-50.192
    N1053 X-8.958 Z-49.849
    N1054 X-10.776 Z-49.418
    N1055 X-12.559 Z-48.913
    N1056 X-14.342 Z-48.323
    N1057 X-16.151 Z-47.634
    N1058 X-17.961 Z-46.848
    N1059 X-19.729 Z-45.98
    N1060 X-21.498 Z-45.007
    N1061 X-22.41 Z-44.462
    N1062 X-23.321 Z-43.886
    N1063 X-24.233 Z-43.278
    N1064 X-25.145 Z-42.634
    N1065 X-26.02 Z-41.981
    N1066 X-26.895 Z-41.292
    N1067 X-27.77 Z-40.565
    N1068 X-28.645 Z-39.796
    N1069 X-29.566 Z-38.941
    N1070 X-30.487 Z-38.035
    N1071 X-31.408 Z-37.073
    N1072 X-32.329 Z-36.043
    N1073 X-33.166 Z-35.047
    N1074 X-34.002 Z-33.989
    N1075 X-34.839 Z-32.859
    N1076 X-35.676 Z-31.638
    N1077 X-36.635 Z-30.125
    N1078 X-37.595 Z-28.455
    N1079 X-38.074 Z-27.548
    N1080 X-38.554 Z-26.583
    N1081 X-39.033 Z-25.551
    N1082 X-39.758 Z-23.846
    N1083 X-40.491 Z-21.866
    N1084 X-41.346 Z-19.058
    N1085 X-42.082 Z-15.789
    N1086 X-42.491 Z-13.112
    N1087 X-42.798 Z-9.75
    N1088 X-43.003 Z-8.619
    N1089 X-43.33 Z-7.496
    N1090 X-43.554 Z-6.91
    N1091 X-43.779 Z-6.402
    N1092 X-44.228 Z-5.547
    N1093 X-44.677 Z-4.839
    N1094 X-45.35 Z-3.958
    N1095 X-45.799 Z-3.463
    N1096 X-46.248 Z-3.013
    N1097 X-46.697 Z-2.619
    N1098 X-47.146 Z-2.258
    N1099 X-48.044 Z-1.647
    N1100 X-48.942 Z-1.152
    N1101 X-49.84 Z-.757
    N1102 X-50.289 Z-.595
    N1103 X-51.187 Z-.331
    N1104 X-52.085 Z-.146
    N1105 X-52.984 Z-.036
    N1106 X-53.882 Z0.
    N1107 Y108.575
    N1108 X-52.984 Z-.036
    N1109 X-52.085 Z-.146
    N1110 X-51.187 Z-.331
    N1111 X-50.289 Z-.595
    N1112 X-49.84 Z-.757
    N1113 X-48.942 Z-1.152
    N1114 X-48.044 Z-1.647
    N1115 X-47.146 Z-2.258
    N1116 X-46.697 Z-2.619
    N1117 X-46.248 Z-3.013
    N1118 X-45.799 Z-3.463
    N1119 X-45.35 Z-3.958
    N1120 X-44.677 Z-4.839
    N1121 X-44.228 Z-5.547
    N1122 X-43.779 Z-6.402
    N1123 X-43.554 Z-6.91
    N1124 X-43.33 Z-7.496
    N1125 X-43.003 Z-8.619
    N1126 X-42.798 Z-9.75
    N1127 X-42.491 Z-13.112
    N1128 X-42.082 Z-15.789
    N1129 X-41.346 Z-19.058
    N1130 X-40.491 Z-21.866
    N1131 X-39.758 Z-23.846
    N1132 X-39.033 Z-25.551
    N1133 X-38.554 Z-26.583
    N1134 X-38.074 Z-27.548
    N1135 X-37.595 Z-28.455
    N1136 X-36.635 Z-30.125
    N1137 X-35.676 Z-31.638
    N1138 X-34.839 Z-32.859
    N1139 X-34.002 Z-33.989
    N1140 X-33.166 Z-35.047
    N1141 X-32.329 Z-36.043
    N1142 X-31.408 Z-37.073
    N1143 X-30.487 Z-38.035
    N1144 X-29.566 Z-38.941
    N1145 X-28.645 Z-39.796
    N1146 X-27.77 Z-40.565
    N1147 X-26.895 Z-41.292
    N1148 X-26.02 Z-41.981
    N1149 X-25.145 Z-42.634
    N1150 X-24.233 Z-43.278
    N1151 X-23.321 Z-43.886
    N1152 X-22.41 Z-44.462
    N1153 X-21.498 Z-45.007
    N1154 X-19.729 Z-45.98
    N1155 X-17.961 Z-46.848
    N1156 X-16.151 Z-47.634
    N1157 X-14.342 Z-48.323
    N1158 X-12.559 Z-48.913
    N1159 X-10.776 Z-49.418
    N1160 X-8.958 Z-49.849
    N1161 X-7.169 Z-50.192
    N1162 X-5.362 Z-50.46
    N1163 X-3.592 Z-50.648
    N1164 X-1.797 Z-50.761
    N1165 X0. Z-50.8
    N1166 X1.797 Z-50.761
    N1167 X3.592 Z-50.648
    N1168 X5.362 Z-50.46
    N1169 X7.169 Z-50.192
    N1170 X8.958 Z-49.849
    N1171 X10.776 Z-49.418
    N1172 X12.559 Z-48.913
    N1173 X14.342 Z-48.323
    N1174 X16.151 Z-47.634
    N1175 X17.961 Z-46.848
    N1176 X18.845 Z-46.427
    N1177 X20.614 Z-45.507
    N1178 X22.41 Z-44.462
    N1179 X23.321 Z-43.886
    N1180 X24.233 Z-43.278
    N1181 X25.145 Z-42.634
    N1182 X26.02 Z-41.981
    N1183 X26.895 Z-41.292
    N1184 X27.77 Z-40.565
    N1185 X28.645 Z-39.796
    N1186 X29.566 Z-38.941
    N1187 X30.487 Z-38.035
    N1188 X31.408 Z-37.073
    N1189 X32.329 Z-36.043
    N1190 X33.166 Z-35.047
    N1191 X34.002 Z-33.989
    N1192 X34.839 Z-32.859
    N1193 X35.676 Z-31.638
    N1194 X36.156 Z-30.898
    N1195 X37.115 Z-29.312
    N1196 X38.074 Z-27.548
    N1197 X38.554 Z-26.583
    N1198 X39.033 Z-25.551
    N1199 X39.758 Z-23.846
    N1200 X40.491 Z-21.866
    N1201 X40.979 Z-20.339
    N1202 X41.57 Z-18.178
    N1203 X42.184 Z-15.229
    N1204 X42.44 Z-13.521
    N1205 X42.798 Z-9.75
    N1206 X42.952 Z-8.854
    N1207 X43.217 Z-7.838
    N1208 X43.554 Z-6.91
    N1209 X43.779 Z-6.402
    N1210 X44.228 Z-5.547
    N1211 X44.677 Z-4.839
    N1212 X45.35 Z-3.958
    N1213 X45.799 Z-3.463
    N1214 X46.248 Z-3.013
    N1215 X46.697 Z-2.619
    N1216 X47.146 Z-2.258
    N1217 X48.044 Z-1.647
    N1218 X48.942 Z-1.152
    N1219 X49.391 Z-.945
    N1220 X50.289 Z-.595
    N1221 X51.187 Z-.331
    N1222 X52.085 Z-.146
    N1223 X52.984 Z-.036
    N1224 X53.882 Z0.
    N1225 Y107.375
    N1226 X52.984 Z-.036
    N1227 X52.085 Z-.146
    N1228 X51.187 Z-.331
    N1229 X50.289 Z-.595
    N1230 X49.391 Z-.945
    N1231 X48.942 Z-1.152
    N1232 X48.044 Z-1.647
    N1233 X47.146 Z-2.258
    N1234 X46.697 Z-2.619
    N1235 X46.248 Z-3.013
    N1236 X45.799 Z-3.463
    N1237 X45.35 Z-3.958
    N1238 X44.677 Z-4.839
    N1239 X44.228 Z-5.547
    N1240 X43.779 Z-6.402
    N1241 X43.554 Z-6.91
    N1242 X43.217 Z-7.838
    N1243 X42.952 Z-8.853
    N1244 X42.773 Z-9.981
    N1245 X42.44 Z-13.521
    N1246 X42.184 Z-15.229
    N1247 X41.571 Z-18.178
    N1248 X40.979 Z-20.339
    N1249 X40.491 Z-21.866
    N1250 X39.758 Z-23.846
    N1251 X39.033 Z-25.551
    N1252 X38.554 Z-26.583
    N1253 X38.074 Z-27.548
    N1254 X37.115 Z-29.312
    N1255 X36.156 Z-30.898
    N1256 X35.676 Z-31.638
    N1257 X34.839 Z-32.859
    N1258 X34.002 Z-33.989
    N1259 X33.166 Z-35.047
    N1260 X32.329 Z-36.043
    N1261 X31.408 Z-37.073
    N1262 X30.487 Z-38.035
    N1263 X29.566 Z-38.941
    N1264 X28.645 Z-39.796
    N1265 X27.77 Z-40.565
    N1266 X26.895 Z-41.292
    N1267 X26.02 Z-41.981
    N1268 X25.145 Z-42.634
    N1269 X24.233 Z-43.278
    N1270 X23.321 Z-43.886
    N1271 X22.41 Z-44.462
    N1272 X20.614 Z-45.507
    N1273 X18.845 Z-46.427
    N1274 X17.961 Z-46.848
    N1275 X16.151 Z-47.634
    N1276 X14.342 Z-48.323
    N1277 X12.559 Z-48.913
    N1278 X10.776 Z-49.418
    N1279 X8.958 Z-49.849
    N1280 X7.169 Z-50.192
    N1281 X5.362 Z-50.46
    N1282 X3.592 Z-50.648
    N1283 X1.797 Z-50.761
    N1284 X0. Z-50.8
    N1285 X-1.797 Z-50.761
    N1286 X-3.592 Z-50.648
    N1287 X-5.362 Z-50.46
    N1288 X-7.169 Z-50.192
    N1289 X-8.958 Z-49.849
    N1290 X-10.776 Z-49.418
    N1291 X-12.559 Z-48.913
    N1292 X-14.342 Z-48.323
    N1293 X-16.151 Z-47.634
    N1294 X-17.961 Z-46.848
    N1295 X-19.729 Z-45.98
    N1296 X-21.498 Z-45.007
    N1297 X-22.41 Z-44.462
    N1298 X-23.321 Z-43.886
    N1299 X-24.233 Z-43.278
    N1300 X-25.145 Z-42.634
    N1301 X-26.02 Z-41.981
    N1302 X-26.895 Z-41.292
    N1303 X-27.77 Z-40.565
    N1304 X-28.645 Z-39.796
    N1305 X-29.566 Z-38.941
    N1306 X-30.487 Z-38.035
    N1307 X-31.408 Z-37.073
    N1308 X-32.329 Z-36.043
    N1309 X-33.166 Z-35.047
    N1310 X-34.002 Z-33.989
    N1311 X-34.839 Z-32.859
    N1312 X-35.676 Z-31.638
    N1313 X-36.635 Z-30.125
    N1314 X-37.595 Z-28.455
    N1315 X-38.074 Z-27.548
    N1316 X-38.554 Z-26.583
    N1317 X-39.513 Z-24.44
    N1318 X-40.246 Z-22.554
    N1319 X-40.735 Z-21.126
    N1320 X-41.346 Z-19.058
    N1321 X-41.98 Z-16.329
    N1322 X-42.491 Z-13.111
    N1323 X-42.798 Z-9.75
    N1324 X-43.003 Z-8.619
    N1325 X-43.33 Z-7.496
    N1326 X-43.554 Z-6.91
    N1327 X-44.003 Z-5.954
    N1328 X-44.452 Z-5.184
    N1329 X-44.901 Z-4.526
    N1330 X-45.35 Z-3.958
    N1331 X-45.799 Z-3.462
    N1332 X-46.248 Z-3.013
    N1333 X-46.697 Z-2.619
    N1334 X-47.146 Z-2.259
    N1335 X-48.044 Z-1.647
    N1336 X-48.942 Z-1.152
    N1337 X-49.84 Z-.757
    N1338 X-50.289 Z-.595
    N1339 X-51.187 Z-.331
    N1340 X-52.085 Z-.146
    N1341 X-52.984 Z-.036
    N1342 X-53.882 Z0.
    N1343 Y106.175
    N1344 X-52.984 Z-.036
    N1345 X-52.085 Z-.146
    N1346 X-51.187 Z-.331
    N1347 X-50.289 Z-.595
    N1348 X-49.84 Z-.757
    N1349 X-48.942 Z-1.152
    N1350 X-48.044 Z-1.647
    N1351 X-47.146 Z-2.259
    N1352 X-46.697 Z-2.619
    N1353 X-46.248 Z-3.013
    N1354 X-45.799 Z-3.462
    N1355 X-45.35 Z-3.958
    N1356 X-44.901 Z-4.526
    N1357 X-44.452 Z-5.184
    N1358 X-44.003 Z-5.954
    N1359 X-43.554 Z-6.91
    N1360 X-43.33 Z-7.496
    N1361 X-43.003 Z-8.619
    N1362 X-42.798 Z-9.75
    N1363 X-42.491 Z-13.111
    N1364 X-42.082 Z-15.789
    N1365 X-41.346 Z-19.058
    N1366 X-40.491 Z-21.866
    N1367 X-39.758 Z-23.846
    N1368 X-39.033 Z-25.551
    N1369 X-38.554 Z-26.583
    N1370 X-38.074 Z-27.548
    N1371 X-37.595 Z-28.455
    N1372 X-36.635 Z-30.125
    N1373 X-35.676 Z-31.638
    N1374 X-34.839 Z-32.859
    N1375 X-34.002 Z-33.989
    N1376 X-33.166 Z-35.047
    N1377 X-32.329 Z-36.043
    N1378 X-31.408 Z-37.073
    N1379 X-30.487 Z-38.035
    N1380 X-29.566 Z-38.941
    N1381 X-28.645 Z-39.796
    N1382 X-27.77 Z-40.565
    N1383 X-26.895 Z-41.292
    N1384 X-26.02 Z-41.981
    N1385 X-25.145 Z-42.634
    N1386 X-24.233 Z-43.278
    N1387 X-23.321 Z-43.886
    N1388 X-22.41 Z-44.462
    N1389 X-21.498 Z-45.007
    N1390 X-19.729 Z-45.98
    N1391 X-17.961 Z-46.848
    N1392 X-16.151 Z-47.634
    N1393 X-14.342 Z-48.323
    N1394 X-12.559 Z-48.913
    N1395 X-10.776 Z-49.418
    N1396 X-8.958 Z-49.849
    N1397 X-7.169 Z-50.192
    N1398 X-5.362 Z-50.46
    N1399 X-3.592 Z-50.648
    N1400 X-1.797 Z-50.761
    N1401 X0. Z-50.8
    N1402 X1.797 Z-50.761
    N1403 X3.592 Z-50.648
    N1404 X5.362 Z-50.46
    N1405 X7.169 Z-50.192
    N1406 X8.958 Z-49.849
    N1407 X10.776 Z-49.418
    N1408 X12.559 Z-48.913
    N1409 X14.342 Z-48.323
    N1410 X16.151 Z-47.634
    N1411 X17.961 Z-46.848
    N1412 X18.845 Z-46.427
    N1413 X20.614 Z-45.507
    N1414 X22.41 Z-44.462
    N1415 X23.321 Z-43.886
    N1416 X24.233 Z-43.278
    N1417 X25.145 Z-42.634
    N1418 X26.02 Z-41.981
    N1419 X26.895 Z-41.292
    N1420 X27.77 Z-40.565
    N1421 X28.645 Z-39.796
    N1422 X29.566 Z-38.941
    N1423 X30.487 Z-38.035
    N1424 X31.408 Z-37.073
    N1425 X32.329 Z-36.043
    N1426 X33.166 Z-35.047
    N1427 X34.002 Z-33.989
    N1428 X34.839 Z-32.859
    N1429 X35.676 Z-31.638
    N1430 X36.156 Z-30.898
    N1431 X37.115 Z-29.312
    N1432 X38.074 Z-27.548
    N1433 X38.554 Z-26.583
    N1434 X39.033 Z-25.551
    N1435 X39.758 Z-23.846
    N1436 X40.491 Z-21.866
    N1437 X40.979 Z-20.339
    N1438 X41.571 Z-18.178
    N1439 X42.184 Z-15.229
    N1440 X42.44 Z-13.521
    N1441 X42.773 Z-9.981
    N1442 X42.952 Z-8.853
    N1443 X43.217 Z-7.838
    N1444 X43.554 Z-6.91
    N1445 X43.779 Z-6.402
    N1446 X44.228 Z-5.547
    N1447 X44.677 Z-4.839
    N1448 X45.35 Z-3.958
    N1449 X45.799 Z-3.462
    N1450 X46.248 Z-3.013
    N1451 X46.697 Z-2.619
    N1452 X47.146 Z-2.258
    N1453 X48.044 Z-1.647
    N1454 X48.942 Z-1.152
    N1455 X49.391 Z-.945
    N1456 X50.289 Z-.595
    N1457 X51.187 Z-.331
    N1458 X52.085 Z-.146
    N1459 X52.984 Z-.036
    N1460 X53.882 Z0.
    N1461 Y104.975
    N1462 X52.984 Z-.036
    N1463 X52.085 Z-.146
    N1464 X51.187 Z-.331
    N1465 X50.289 Z-.595
    N1466 X49.391 Z-.945
    N1467 X48.942 Z-1.152
    N1468 X48.044 Z-1.647
    N1469 X47.146 Z-2.259
    N1470 X46.697 Z-2.619
    N1471 X46.248 Z-3.013
    N1472 X45.799 Z-3.462
    N1473 X45.35 Z-3.958
    N1474 X44.677 Z-4.839
    N1475 X44.228 Z-5.547
    N1476 X43.779 Z-6.402
    N1477 X43.554 Z-6.909
    N1478 X43.217 Z-7.838
    N1479 X43.003 Z-8.619
    N1480 X42.798 Z-9.75
    N1481 X42.44 Z-13.521
    N1482 X42.184 Z-15.229
    N1483 X41.571 Z-18.178
    N1484 X40.979 Z-20.339
    N1485 X40.491 Z-21.866
    N1486 X39.758 Z-23.846
    N1487 X39.033 Z-25.551
    N1488 X38.554 Z-26.583
    N1489 X38.074 Z-27.548
    N1490 X37.115 Z-29.312
    N1491 X36.156 Z-30.898
    N1492 X35.676 Z-31.638
    N1493 X34.839 Z-32.859
    N1494 X34.002 Z-33.989
    N1495 X33.166 Z-35.047
    N1496 X32.329 Z-36.043
    N1497 X31.408 Z-37.073
    N1498 X30.487 Z-38.035
    N1499 X29.566 Z-38.941
    N1500 X28.645 Z-39.796
    N1501 X27.77 Z-40.565
    N1502 X26.895 Z-41.292
    N1503 X26.02 Z-41.981
    N1504 X25.145 Z-42.634
    N1505 X24.233 Z-43.278
    N1506 X23.321 Z-43.886
    N1507 X22.41 Z-44.462
    N1508 X20.614 Z-45.507
    N1509 X18.845 Z-46.427
    N1510 X17.961 Z-46.848
    N1511 X16.151 Z-47.634
    N1512 X14.342 Z-48.323
    N1513 X12.559 Z-48.913
    N1514 X10.776 Z-49.418
    N1515 X8.958 Z-49.849
    N1516 X7.169 Z-50.192
    N1517 X5.362 Z-50.46
    N1518 X3.592 Z-50.648
    N1519 X1.797 Z-50.761
    N1520 X0. Z-50.8
    N1521 X-1.797 Z-50.761
    N1522 X-3.592 Z-50.648
    N1523 X-5.362 Z-50.46
    N1524 X-7.169 Z-50.192
    N1525 X-8.958 Z-49.849
    N1526 X-10.776 Z-49.418
    N1527 X-12.559 Z-48.913
    N1528 X-14.342 Z-48.323
    N1529 X-16.151 Z-47.634
    N1530 X-17.961 Z-46.848
    N1531 X-19.729 Z-45.98
    N1532 X-21.498 Z-45.007
    N1533 X-22.41 Z-44.462
    N1534 X-23.321 Z-43.886
    N1535 X-24.233 Z-43.278
    N1536 X-25.145 Z-42.634
    N1537 X-26.02 Z-41.981
    N1538 X-26.895 Z-41.292
    N1539 X-27.77 Z-40.565
    N1540 X-28.645 Z-39.796
    N1541 X-29.566 Z-38.941
    N1542 X-30.487 Z-38.035
    N1543 X-31.408 Z-37.073
    N1544 X-32.329 Z-36.043
    N1545 X-33.166 Z-35.047
    N1546 X-34.002 Z-33.989
    N1547 X-34.839 Z-32.859
    N1548 X-35.676 Z-31.638
    N1549 X-36.635 Z-30.125
    N1550 X-37.595 Z-28.455
    N1551 X-38.074 Z-27.548
    N1552 X-38.554 Z-26.583
    N1553 X-39.033 Z-25.551
    N1554 X-39.758 Z-23.846
    N1555 X-40.491 Z-21.866
    N1556 X-41.346 Z-19.058
    N1557 X-41.98 Z-16.328
    N1558 X-42.491 Z-13.111
    N1559 X-42.798 Z-9.75
    N1560 X-43.003 Z-8.619
    N1561 X-43.33 Z-7.496
    N1562 X-43.554 Z-6.909
    N1563 X-44.003 Z-5.954
    N1564 X-44.452 Z-5.184
    N1565 X-44.901 Z-4.526
    N1566 X-45.35 Z-3.958
    N1567 X-45.799 Z-3.462
    N1568 X-46.248 Z-3.013
    N1569 X-46.697 Z-2.619
    N1570 X-47.146 Z-2.259
    N1571 X-48.044 Z-1.647
    N1572 X-48.942 Z-1.152
    N1573 X-49.391 Z-.945
    N1574 X-50.289 Z-.595
    N1575 X-51.187 Z-.331
    N1576 X-52.085 Z-.146
    N1577 X-52.984 Z-.036
    N1578 X-53.882 Z0.
    N1579 Y103.775
    N1580 X-52.984 Z-.036
    N1581 X-52.085 Z-.146
    N1582 X-51.187 Z-.331
    N1583 X-50.289 Z-.595
    N1584 X-49.391 Z-.945
    N1585 X-48.942 Z-1.152
    N1586 X-48.044 Z-1.647
    N1587 X-47.146 Z-2.259
    N1588 X-46.697 Z-2.619
    N1589 X-46.248 Z-3.013
    N1590 X-45.799 Z-3.462
    N1591 X-45.35 Z-3.957
    N1592 X-44.901 Z-4.526
    N1593 X-44.452 Z-5.184
    N1594 X-44.003 Z-5.954
    N1595 X-43.554 Z-6.909
    N1596 X-43.33 Z-7.496
    N1597 X-43.003 Z-8.619
    N1598 X-42.798 Z-9.75
    N1599 X-42.491 Z-13.111
    N1600 X-41.98 Z-16.328
    N1601 X-41.346 Z-19.058
    N1602 X-40.491 Z-21.866
    N1603 X-39.758 Z-23.846
    N1604 X-39.033 Z-25.551
    N1605 X-38.554 Z-26.583
    N1606 X-38.074 Z-27.548
    N1607 X-37.595 Z-28.455
    N1608 X-36.635 Z-30.125
    N1609 X-35.676 Z-31.638
    N1610 X-34.839 Z-32.859
    N1611 X-34.002 Z-33.989
    N1612 X-33.166 Z-35.047
    N1613 X-32.329 Z-36.043
    N1614 X-31.408 Z-37.073
    N1615 X-30.487 Z-38.035
    N1616 X-29.566 Z-38.941
    N1617 X-28.645 Z-39.796
    N1618 X-27.77 Z-40.565
    N1619 X-26.895 Z-41.292
    N1620 X-26.02 Z-41.981
    N1621 X-25.145 Z-42.634
    N1622 X-24.233 Z-43.278
    N1623 X-23.321 Z-43.886
    N1624 X-22.41 Z-44.462
    N1625 X-21.498 Z-45.007
    N1626 X-19.729 Z-45.98
    N1627 X-17.961 Z-46.848
    N1628 X-16.151 Z-47.634
    N1629 X-14.342 Z-48.323
    N1630 X-12.559 Z-48.913
    N1631 X-10.776 Z-49.418
    N1632 X-8.958 Z-49.849
    N1633 X-7.169 Z-50.192
    N1634 X-5.362 Z-50.46
    N1635 X-3.592 Z-50.648
    N1636 X-1.797 Z-50.761
    N1637 X0. Z-50.8
    N1638 X1.797 Z-50.761
    N1639 X3.592 Z-50.648
    N1640 X5.362 Z-50.46
    N1641 X7.169 Z-50.192
    N1642 X8.958 Z-49.849
    N1643 X10.776 Z-49.418
    N1644 X12.559 Z-48.913
    N1645 X14.342 Z-48.323
    N1646 X16.151 Z-47.634
    N1647 X17.961 Z-46.848
    N1648 X18.845 Z-46.427
    N1649 X20.614 Z-45.507
    N1650 X22.41 Z-44.462
    N1651 X23.321 Z-43.886
    N1652 X24.233 Z-43.278
    N1653 X25.145 Z-42.634
    N1654 X26.02 Z-41.981
    N1655 X26.895 Z-41.292
    N1656 X27.77 Z-40.565
    N1657 X28.645 Z-39.796
    N1658 X29.566 Z-38.941
    N1659 X30.487 Z-38.035
    N1660 X31.408 Z-37.073
    N1661 X32.329 Z-36.043
    N1662 X33.166 Z-35.047
    N1663 X34.002 Z-33.989
    N1664 X34.839 Z-32.859
    N1665 X35.676 Z-31.638
    N1666 X36.156 Z-30.898
    N1667 X37.115 Z-29.312
    N1668 X38.074 Z-27.548
    N1669 X38.554 Z-26.583
    N1670 X39.033 Z-25.551
    N1671 X39.758 Z-23.846
    N1672 X40.491 Z-21.866
    N1673 X40.979 Z-20.339
    N1674 X41.571 Z-18.178
    N1675 X42.184 Z-15.229
    N1676 X42.44 Z-13.521
    N1677 X42.798 Z-9.75
    N1678 X43.003 Z-8.619
    N1679 X43.217 Z-7.838
    N1680 X43.554 Z-6.909
    N1681 X43.779 Z-6.403
    N1682 X44.228 Z-5.547
    N1683 X44.677 Z-4.839
    N1684 X45.35 Z-3.958
    N1685 X45.799 Z-3.462
    N1686 X46.248 Z-3.013
    N1687 X46.697 Z-2.619
    N1688 X47.146 Z-2.259
    N1689 X48.044 Z-1.647
    N1690 X48.942 Z-1.152
    N1691 X49.391 Z-.945
    N1692 X50.289 Z-.595
    N1693 X51.187 Z-.331
    N1694 X52.085 Z-.146
    N1695 X52.984 Z-.036
    N1696 X53.882 Z0.
    N1697 Y102.575
    N1698 X52.984 Z-.036
    N1699 X52.085 Z-.146
    N1700 X51.187 Z-.331
    N1701 X50.289 Z-.595
    N1702 X49.391 Z-.944
    N1703 X48.942 Z-1.152
    N1704 X48.044 Z-1.647
    N1705 X47.146 Z-2.259
    N1706 X46.697 Z-2.619
    N1707 X46.248 Z-3.013
    N1708 X45.799 Z-3.462
    N1709 X45.35 Z-3.957
    N1710 X44.677 Z-4.839
    N1711 X44.228 Z-5.547
    N1712 X43.779 Z-6.403
    N1713 X43.554 Z-6.909
    N1714 X43.217 Z-7.838
    N1715 X43.003 Z-8.619
    N1716 X42.798 Z-9.75
    N1717 X42.44 Z-13.521
    N1718 X42.184 Z-15.229
    N1719 X41.571 Z-18.178
    N1720 X40.979 Z-20.339
    N1721 X40.491 Z-21.866
    N1722 X39.758 Z-23.846
    N1723 X39.033 Z-25.551
    N1724 X38.554 Z-26.583
    N1725 X38.074 Z-27.548
    N1726 X37.115 Z-29.312
    N1727 X36.156 Z-30.898
    N1728 X35.676 Z-31.638
    N1729 X34.839 Z-32.859
    N1730 X34.002 Z-33.989
    N1731 X33.166 Z-35.047
    N1732 X32.329 Z-36.043
    N1733 X31.408 Z-37.073
    N1734 X30.487 Z-38.035
    N1735 X29.566 Z-38.941
    N1736 X28.645 Z-39.796
    N1737 X27.77 Z-40.565
    N1738 X26.895 Z-41.292
    N1739 X26.02 Z-41.981
    N1740 X25.145 Z-42.634
    N1741 X24.233 Z-43.278
    N1742 X23.321 Z-43.886
    N1743 X22.41 Z-44.462
    N1744 X20.614 Z-45.507
    N1745 X18.845 Z-46.427
    N1746 X17.961 Z-46.848
    N1747 X16.151 Z-47.634
    N1748 X14.342 Z-48.323
    N1749 X12.559 Z-48.913
    N1750 X10.776 Z-49.418
    N1751 X8.958 Z-49.849
    N1752 X7.169 Z-50.192
    N1753 X5.362 Z-50.46
    N1754 X3.592 Z-50.648
    N1755 X1.797 Z-50.761
    N1756 X0. Z-50.8
    N1757 X-1.797 Z-50.761
    N1758 X-3.592 Z-50.648
    N1759 X-5.362 Z-50.46
    N1760 X-7.169 Z-50.192
    N1761 X-8.958 Z-49.849
    N1762 X-10.776 Z-49.418
    N1763 X-12.559 Z-48.913
    N1764 X-14.342 Z-48.323
    N1765 X-16.151 Z-47.634
    N1766 X-17.961 Z-46.848
    N1767 X-19.729 Z-45.98
    N1768 X-21.498 Z-45.007
    N1769 X-22.41 Z-44.462
    N1770 X-23.321 Z-43.886
    N1771 X-24.233 Z-43.278
    N1772 X-25.145 Z-42.634
    N1773 X-26.02 Z-41.981
    N1774 X-26.895 Z-41.292
    N1775 X-27.77 Z-40.565
    N1776 X-28.645 Z-39.796
    N1777 X-29.566 Z-38.941
    N1778 X-30.487 Z-38.035
    N1779 X-31.408 Z-37.073
    N1780 X-32.329 Z-36.043
    N1781 X-33.166 Z-35.047
    N1782 X-34.002 Z-33.989
    N1783 X-34.839 Z-32.859
    N1784 X-35.676 Z-31.638
    N1785 X-36.635 Z-30.125
    N1786 X-37.595 Z-28.455
    N1787 X-38.074 Z-27.548
    N1788 X-38.554 Z-26.583
    N1789 X-39.033 Z-25.551
    N1790 X-39.758 Z-23.846
    N1791 X-40.491 Z-21.866
    N1792 X-41.346 Z-19.058
    N1793 X-41.98 Z-16.328
    N1794 X-42.491 Z-13.111
    N1795 X-42.798 Z-9.75
    N1796 X-43.003 Z-8.619
    N1797 X-43.33 Z-7.496
    N1798 X-43.554 Z-6.909
    N1799 X-44.003 Z-5.954
    N1800 X-44.452 Z-5.184
    N1801 X-44.901 Z-4.526
    N1802 X-45.35 Z-3.957
    N1803 X-45.799 Z-3.462
    N1804 X-46.248 Z-3.014
    N1805 X-46.697 Z-2.619
    N1806 X-47.146 Z-2.259
    N1807 X-48.044 Z-1.647
    N1808 X-48.942 Z-1.152
    N1809 X-49.391 Z-.944
    N1810 X-50.289 Z-.595
    N1811 X-51.187 Z-.331
    N1812 X-52.085 Z-.146
    N1813 X-52.984 Z-.036
    N1814 X-53.882 Z0.
    N1815 Y101.375
    N1816 X-52.984 Z-.036
    N1817 X-52.085 Z-.146
    N1818 X-51.187 Z-.331
    N1819 X-50.289 Z-.595
    N1820 X-49.391 Z-.944
    N1821 X-48.942 Z-1.152
    N1822 X-48.044 Z-1.647
    N1823 X-47.146 Z-2.259
    N1824 X-46.697 Z-2.619
    N1825 X-46.248 Z-3.014
    N1826 X-45.799 Z-3.462
    N1827 X-45.35 Z-3.957
    N1828 X-44.901 Z-4.526
    N1829 X-44.452 Z-5.184
    N1830 X-44.003 Z-5.954
    N1831 X-43.554 Z-6.909
    N1832 X-43.33 Z-7.496
    N1833 X-43.003 Z-8.619
    N1834 X-42.798 Z-9.75
    N1835 X-42.491 Z-13.111
    N1836 X-41.98 Z-16.328
    N1837 X-41.346 Z-19.058
    N1838 X-40.491 Z-21.866
    N1839 X-39.758 Z-23.846
    N1840 X-39.033 Z-25.551
    N1841 X-38.554 Z-26.583
    N1842 X-38.074 Z-27.548
    N1843 X-37.595 Z-28.455
    N1844 X-36.635 Z-30.125
    N1845 X-35.676 Z-31.638
    N1846 X-34.839 Z-32.859
    N1847 X-34.002 Z-33.989
    N1848 X-33.166 Z-35.047
    N1849 X-32.329 Z-36.043
    N1850 X-31.408 Z-37.073
    N1851 X-30.487 Z-38.035
    N1852 X-29.566 Z-38.941
    N1853 X-28.645 Z-39.796
    N1854 X-27.77 Z-40.565
    N1855 X-26.895 Z-41.292
    N1856 X-26.02 Z-41.981
    N1857 X-25.145 Z-42.634
    N1858 X-24.233 Z-43.278
    N1859 X-23.321 Z-43.886
    N1860 X-22.41 Z-44.462
    N1861 X-21.498 Z-45.007
    N1862 X-19.729 Z-45.98
    N1863 X-17.961 Z-46.848
    N1864 X-16.151 Z-47.634
    N1865 X-14.342 Z-48.323
    N1866 X-12.559 Z-48.913
    N1867 X-10.776 Z-49.418
    N1868 X-8.958 Z-49.849
    N1869 X-7.169 Z-50.192
    N1870 X-5.362 Z-50.46
    N1871 X-3.592 Z-50.648
    N1872 X-1.797 Z-50.761
    N1873 X0. Z-50.8
    N1874 X1.797 Z-50.761
    N1875 X3.592 Z-50.648
    N1876 X5.362 Z-50.46
    N1877 X7.169 Z-50.192
    N1878 X8.958 Z-49.849
    N1879 X10.776 Z-49.418
    N1880 X12.559 Z-48.913
    N1881 X14.342 Z-48.323
    N1882 X16.151 Z-47.634
    N1883 X17.961 Z-46.848
    N1884 X18.845 Z-46.427
    N1885 X20.614 Z-45.507
    N1886 X22.41 Z-44.462
    N1887 X23.321 Z-43.886
    N1888 X24.233 Z-43.278
    N1889 X25.145 Z-42.634
    N1890 X26.02 Z-41.981
    N1891 X26.895 Z-41.292
    N1892 X27.77 Z-40.565
    N1893 X28.645 Z-39.796
    N1894 X29.566 Z-38.941
    N1895 X30.487 Z-38.035
    N1896 X31.408 Z-37.073
    N1897 X32.329 Z-36.043
    N1898 X33.166 Z-35.047
    N1899 X34.002 Z-33.989
    N1900 X34.839 Z-32.859
    N1901 X35.676 Z-31.638
    N1902 X36.156 Z-30.898
    N1903 X37.115 Z-29.312
    N1904 X38.074 Z-27.548
    N1905 X38.554 Z-26.583
    N1906 X39.033 Z-25.551
    N1907 X39.758 Z-23.846
    N1908 X40.491 Z-21.866
    N1909 X40.979 Z-20.339
    N1910 X41.571 Z-18.178
    N1911 X42.184 Z-15.229
    N1912 X42.44 Z-13.521
    N1913 X42.798 Z-9.75
    N1914 X43.003 Z-8.619
    N1915 X43.217 Z-7.837
    N1916 X43.554 Z-6.909
    N1917 X43.779 Z-6.403
    N1918 X44.228 Z-5.547
    N1919 X44.677 Z-4.839
    N1920 X45.35 Z-3.957
    N1921 X45.799 Z-3.462
    N1922 X46.248 Z-3.013
    N1923 X46.697 Z-2.619
    N1924 X47.146 Z-2.259
    N1925 X48.044 Z-1.647
    N1926 X48.493 Z-1.387
    N1927 X49.391 Z-.944
    N1928 X50.289 Z-.595
    N1929 X51.187 Z-.331
    N1930 X52.085 Z-.146
    N1931 X52.984 Z-.036
    N1932 X53.882 Z0.
    N1933 Y100.175
    N1934 X52.984 Z-.036
    N1935 X52.085 Z-.146
    N1936 X51.187 Z-.33
    N1937 X50.289 Z-.595
    N1938 X49.391 Z-.944
    N1939 X48.493 Z-1.387
    N1940 X48.044 Z-1.647
    N1941 X47.146 Z-2.259
    N1942 X46.697 Z-2.619
    N1943 X46.248 Z-3.014
    N1944 X45.799 Z-3.462
    N1945 X45.35 Z-3.957
    N1946 X44.677 Z-4.839
    N1947 X44.228 Z-5.547
    N1948 X43.779 Z-6.403
    N1949 X43.554 Z-6.909
    N1950 X43.217 Z-7.837
    N1951 X43.003 Z-8.619
    N1952 X42.798 Z-9.749
    N1953 X42.44 Z-13.521
    N1954 X42.184 Z-15.229
    N1955 X41.571 Z-18.178
    N1956 X40.979 Z-20.339
    N1957 X40.491 Z-21.866
    N1958 X39.758 Z-23.846
    N1959 X39.033 Z-25.551
    N1960 X38.554 Z-26.583
    N1961 X38.074 Z-27.548
    N1962 X37.115 Z-29.312
    N1963 X36.156 Z-30.898
    N1964 X35.676 Z-31.638
    N1965 X34.839 Z-32.859
    N1966 X34.002 Z-33.989
    N1967 X33.166 Z-35.047
    N1968 X32.329 Z-36.043
    N1969 X31.408 Z-37.073
    N1970 X30.487 Z-38.035
    N1971 X29.566 Z-38.941
    N1972 X28.645 Z-39.796
    N1973 X27.77 Z-40.565
    N1974 X26.895 Z-41.292
    N1975 X26.02 Z-41.981
    N1976 X25.145 Z-42.634
    N1977 X24.233 Z-43.278
    N1978 X23.321 Z-43.886
    N1979 X22.41 Z-44.462
    N1980 X20.614 Z-45.507
    N1981 X18.845 Z-46.427
    N1982 X17.961 Z-46.848
    N1983 X16.151 Z-47.634
    N1984 X14.342 Z-48.323
    N1985 X12.559 Z-48.913
    N1986 X10.776 Z-49.418
    N1987 X8.958 Z-49.849
    N1988 X7.169 Z-50.192
    N1989 X5.362 Z-50.46
    N1990 X3.592 Z-50.648
    N1991 X1.797 Z-50.761
    N1992 X0. Z-50.8
    N1993 X-1.797 Z-50.761
    N1994 X-3.592 Z-50.648
    N1995 X-5.362 Z-50.46
    N1996 X-7.169 Z-50.192
    N1997 X-8.958 Z-49.849
    N1998 X-10.776 Z-49.418
    N1999 X-12.559 Z-48.913
    N2000 X-14.342 Z-48.323
    N2001 X-16.151 Z-47.634
    N2002 X-17.961 Z-46.848
    N2003 X-19.729 Z-45.98
    N2004 X-21.498 Z-45.007
    N2005 X-22.41 Z-44.462
    N2006 X-23.321 Z-43.886
    N2007 X-24.233 Z-43.278
    N2008 X-25.145 Z-42.634
    N2009 X-26.02 Z-41.981
    N2010 X-26.895 Z-41.292
    N2011 X-27.77 Z-40.565
    N2012 X-28.645 Z-39.796
    N2013 X-29.566 Z-38.941
    N2014 X-30.487 Z-38.035
    N2015 X-31.408 Z-37.073
    N2016 X-32.329 Z-36.043
    N2017 X-33.166 Z-35.047
    N2018 X-34.002 Z-33.989
    N2019 X-34.839 Z-32.859
    N2020 X-35.676 Z-31.638
    N2021 X-36.635 Z-30.125
    N2022 X-37.595 Z-28.455
    N2023 X-38.074 Z-27.548
    N2024 X-38.554 Z-26.583
    N2025 X-39.033 Z-25.551
    N2026 X-39.758 Z-23.846
    N2027 X-40.491 Z-21.866
    N2028 X-41.346 Z-19.058
    N2029 X-41.98 Z-16.328
    N2030 X-42.491 Z-13.111
    N2031 X-42.798 Z-9.749
    N2032 X-42.901 Z-9.113
    N2033 X-43.105 Z-8.222
    N2034 X-43.33 Z-7.496
    N2035 X-43.554 Z-6.909
    N2036 X-44.003 Z-5.954
    N2037 X-44.452 Z-5.184
    N2038 X-44.901 Z-4.526
    N2039 X-45.35 Z-3.957
    N2040 X-45.799 Z-3.462
    N2041 X-46.248 Z-3.014
    N2042 X-46.697 Z-2.619
    N2043 X-47.146 Z-2.259
    N2044 X-48.044 Z-1.647
    N2045 X-48.942 Z-1.152
    N2046 X-49.391 Z-.944
    N2047 X-50.289 Z-.595
    N2048 X-51.187 Z-.331
    N2049 X-52.085 Z-.146
    N2050 X-52.984 Z-.036
    N2051 X-53.882 Z0.
    N2052 Y98.975
    N2053 X-52.984 Z-.036
    N2054 X-52.085 Z-.146
    N2055 X-51.187 Z-.33
    N2056 X-50.289 Z-.595
    N2057 X-49.391 Z-.944
    N2058 X-48.942 Z-1.152
    N2059 X-48.044 Z-1.647
    N2060 X-47.146 Z-2.259
    N2061 X-46.697 Z-2.619
    N2062 X-46.248 Z-3.014
    N2063 X-45.799 Z-3.462
    N2064 X-45.35 Z-3.957
    N2065 X-44.901 Z-4.526
    N2066 X-44.452 Z-5.184
    N2067 X-44.003 Z-5.954
    N2068 X-43.554 Z-6.909
    N2069 X-43.33 Z-7.496
    N2070 X-43.105 Z-8.222
    N2071 X-42.901 Z-9.112
    N2072 X-42.798 Z-9.749
    N2073 X-42.491 Z-13.111
    N2074 X-41.98 Z-16.328
    N2075 X-41.346 Z-19.058
    N2076 X-40.491 Z-21.866
    N2077 X-39.758 Z-23.846
    N2078 X-39.033 Z-25.551
    N2079 X-38.554 Z-26.583
    N2080 X-38.074 Z-27.548
    N2081 X-37.595 Z-28.455
    N2082 X-36.635 Z-30.125
    N2083 X-35.676 Z-31.638
    N2084 X-34.839 Z-32.859
    N2085 X-34.002 Z-33.989
    N2086 X-33.166 Z-35.047
    N2087 X-32.329 Z-36.043
    N2088 X-31.408 Z-37.073
    N2089 X-30.487 Z-38.035
    N2090 X-29.566 Z-38.941
    N2091 X-28.645 Z-39.796
    N2092 X-27.77 Z-40.565
    N2093 X-26.895 Z-41.292
    N2094 X-26.02 Z-41.981
    N2095 X-25.145 Z-42.634
    N2096 X-24.233 Z-43.278
    N2097 X-23.321 Z-43.886
    N2098 X-22.41 Z-44.462
    N2099 X-21.498 Z-45.007
    N2100 X-19.729 Z-45.98
    N2101 X-17.961 Z-46.848
    N2102 X-16.151 Z-47.634
    N2103 X-14.342 Z-48.323
    N2104 X-12.559 Z-48.913
    N2105 X-10.776 Z-49.418
    N2106 X-8.958 Z-49.849
    N2107 X-7.169 Z-50.192
    N2108 X-5.362 Z-50.46
    N2109 X-3.592 Z-50.648
    N2110 X-1.797 Z-50.761
    N2111 X0. Z-50.8
    N2112 X1.797 Z-50.761
    N2113 X3.592 Z-50.648
    N2114 X5.362 Z-50.46
    N2115 X7.169 Z-50.192
    N2116 X8.958 Z-49.849
    N2117 X10.776 Z-49.418
    N2118 X12.559 Z-48.913
    N2119 X14.342 Z-48.323
    N2120 X16.151 Z-47.634
    N2121 X17.961 Z-46.848
    N2122 X18.845 Z-46.427
    N2123 X20.614 Z-45.507
    N2124 X22.41 Z-44.462
    N2125 X23.321 Z-43.886
    N2126 X24.233 Z-43.278
    N2127 X25.145 Z-42.634
    N2128 X26.02 Z-41.981
    N2129 X26.895 Z-41.292
    N2130 X27.77 Z-40.565
    N2131 X28.645 Z-39.796
    N2132 X29.566 Z-38.941
    N2133 X30.487 Z-38.035
    N2134 X31.408 Z-37.073
    N2135 X32.329 Z-36.043
    N2136 X33.166 Z-35.047
    N2137 X34.002 Z-33.989
    N2138 X34.839 Z-32.859
    N2139 X35.676 Z-31.638
    N2140 X36.156 Z-30.898
    N2141 X37.115 Z-29.312
    N2142 X38.074 Z-27.548
    N2143 X38.554 Z-26.583
    N2144 X39.033 Z-25.551
    N2145 X39.758 Z-23.846
    N2146 X40.491 Z-21.866
    N2147 X40.979 Z-20.339
    N2148 X41.571 Z-18.178
    N2149 X42.184 Z-15.229
    N2150 X42.44 Z-13.521
    N2151 X42.798 Z-9.749
    N2152 X43.003 Z-8.619
    N2153 X43.217 Z-7.837
    N2154 X43.554 Z-6.909
    N2155 X43.779 Z-6.403
    N2156 X44.228 Z-5.547
    N2157 X44.677 Z-4.839
    N2158 X45.35 Z-3.957
    N2159 X45.799 Z-3.462
    N2160 X46.248 Z-3.014
    N2161 X46.697 Z-2.619
    N2162 X47.146 Z-2.259
    N2163 X48.044 Z-1.647
    N2164 X48.493 Z-1.387
    N2165 X49.391 Z-.944
    N2166 X50.289 Z-.595
    N2167 X51.187 Z-.33
    N2168 X52.085 Z-.146
    N2169 X52.984 Z-.036
    N2170 X53.882 Z0.
    N2171 Y97.775
    N2172 X52.984 Z-.036
    N2173 X52.085 Z-.146
    N2174 X51.187 Z-.33
    N2175 X50.289 Z-.595
    N2176 X49.391 Z-.944
    N2177 X48.493 Z-1.387
    N2178 X48.044 Z-1.647
    N2179 X47.146 Z-2.259
    N2180 X46.697 Z-2.619
    N2181 X46.248 Z-3.014
    N2182 X45.799 Z-3.462
    N2183 X45.35 Z-3.957
    N2184 X44.677 Z-4.839
    N2185 X44.228 Z-5.547
    N2186 X43.779 Z-6.403
    N2187 X43.554 Z-6.909
    N2188 X43.217 Z-7.837
    N2189 X43.003 Z-8.619
    N2190 X42.798 Z-9.749
    N2191 X42.44 Z-13.521
    N2192 X42.184 Z-15.229
    N2193 X41.571 Z-18.178
    N2194 X40.979 Z-20.339
    N2195 X40.491 Z-21.866
    N2196 X39.758 Z-23.846
    N2197 X39.033 Z-25.551
    N2198 X38.554 Z-26.583
    N2199 X38.074 Z-27.548
    N2200 X37.115 Z-29.312
    N2201 X36.156 Z-30.898
    N2202 X35.676 Z-31.638
    N2203 X34.839 Z-32.859
    N2204 X34.002 Z-33.989
    N2205 X33.166 Z-35.047
    N2206 X32.329 Z-36.043
    N2207 X31.408 Z-37.073
    N2208 X30.487 Z-38.035
    N2209 X29.566 Z-38.941
    N2210 X28.645 Z-39.796
    N2211 X27.77 Z-40.565
    N2212 X26.895 Z-41.292
    N2213 X26.02 Z-41.981
    N2214 X25.145 Z-42.634
    N2215 X24.233 Z-43.278
    N2216 X23.321 Z-43.886
    N2217 X22.41 Z-44.462
    N2218 X20.614 Z-45.507
    N2219 X18.845 Z-46.427
    N2220 X17.961 Z-46.848
    N2221 X16.151 Z-47.634
    N2222 X14.342 Z-48.323
    N2223 X12.559 Z-48.913
    N2224 X10.776 Z-49.418
    N2225 X8.958 Z-49.849
    N2226 X7.169 Z-50.192
    N2227 X5.362 Z-50.46
    N2228 X3.592 Z-50.648
    N2229 X1.797 Z-50.761
    N2230 X0. Z-50.8
    N2231 X-1.797 Z-50.761
    N2232 X-3.592 Z-50.648
    N2233 X-5.362 Z-50.46
    N2234 X-7.169 Z-50.192
    N2235 X-8.958 Z-49.849
    N2236 X-10.776 Z-49.418
    N2237 X-12.559 Z-48.913
    N2238 X-14.342 Z-48.323
    N2239 X-16.151 Z-47.634
    N2240 X-17.961 Z-46.848
    N2241 X-19.729 Z-45.98
    N2242 X-21.498 Z-45.007
    N2243 X-22.41 Z-44.462
    N2244 X-23.321 Z-43.886
    N2245 X-24.233 Z-43.278
    N2246 X-25.145 Z-42.634
    N2247 X-26.02 Z-41.981
    N2248 X-26.895 Z-41.292
    N2249 X-27.77 Z-40.565
    N2250 X-28.645 Z-39.796
    N2251 X-29.566 Z-38.941
    N2252 X-30.487 Z-38.035
    N2253 X-31.408 Z-37.073
    N2254 X-32.329 Z-36.043
    N2255 X-33.166 Z-35.047
    N2256 X-34.002 Z-33.989
    N2257 X-34.839 Z-32.859
    N2258 X-35.676 Z-31.638
    N2259 X-36.635 Z-30.125
    N2260 X-37.595 Z-28.455
    N2261 X-38.074 Z-27.548
    N2262 X-38.554 Z-26.583
    N2263 X-39.033 Z-25.551
    N2264 X-39.758 Z-23.846
    N2265 X-40.491 Z-21.866
    N2266 X-41.346 Z-19.058
    N2267 X-41.98 Z-16.328
    N2268 X-42.491 Z-13.111
    N2269 X-42.798 Z-9.749
    N2270 X-42.901 Z-9.112
    N2271 X-43.105 Z-8.222
    N2272 X-43.33 Z-7.496
    N2273 X-43.554 Z-6.909
    N2274 X-44.003 Z-5.954
    N2275 X-44.452 Z-5.184
    N2276 X-44.901 Z-4.526
    N2277 X-45.35 Z-3.957
    N2278 X-45.799 Z-3.462
    N2279 X-46.248 Z-3.014
    N2280 X-46.697 Z-2.619
    N2281 X-47.146 Z-2.259
    N2282 X-48.044 Z-1.647
    N2283 X-48.942 Z-1.152
    N2284 X-49.391 Z-.944
    N2285 X-50.289 Z-.595
    N2286 X-51.187 Z-.33
    N2287 X-52.085 Z-.146
    N2288 X-52.984 Z-.036
    N2289 X-53.882 Z0.
    N2290 Y96.575
    N2291 X-52.984 Z-.036
    N2292 X-52.085 Z-.146
    N2293 X-51.187 Z-.33
    N2294 X-50.289 Z-.595
    N2295 X-49.391 Z-.944
    N2296 X-48.942 Z-1.152
    N2297 X-48.044 Z-1.647
    N2298 X-47.146 Z-2.259
    N2299 X-46.697 Z-2.619
    N2300 X-46.248 Z-3.014
    N2301 X-45.799 Z-3.462
    N2302 X-45.35 Z-3.957
    N2303 X-44.901 Z-4.526
    N2304 X-44.452 Z-5.184
    N2305 X-44.003 Z-5.954
    N2306 X-43.554 Z-6.909
    N2307 X-43.33 Z-7.496
    N2308 X-43.105 Z-8.222
    N2309 X-42.901 Z-9.112
    N2310 X-42.798 Z-9.749
    N2311 X-42.491 Z-13.111
    N2312 X-41.98 Z-16.328
    N2313 X-41.346 Z-19.058
    N2314 X-40.491 Z-21.866
    N2315 X-39.758 Z-23.846
    N2316 X-39.033 Z-25.551
    N2317 X-38.554 Z-26.583
    N2318 X-38.074 Z-27.548
    N2319 X-37.595 Z-28.455
    N2320 X-36.635 Z-30.125
    N2321 X-35.676 Z-31.638
    N2322 X-34.839 Z-32.859
    N2323 X-34.002 Z-33.989
    N2324 X-33.166 Z-35.047
    N2325 X-32.329 Z-36.043
    N2326 X-31.408 Z-37.073
    N2327 X-30.487 Z-38.035
    N2328 X-29.566 Z-38.941
    N2329 X-28.645 Z-39.796
    N2330 X-27.77 Z-40.565
    N2331 X-26.895 Z-41.292
    N2332 X-26.02 Z-41.981
    N2333 X-25.145 Z-42.634
    N2334 X-24.233 Z-43.278
    N2335 X-23.321 Z-43.886
    N2336 X-22.41 Z-44.462
    N2337 X-21.498 Z-45.007
    N2338 X-19.729 Z-45.98
    N2339 X-17.961 Z-46.848
    N2340 X-16.151 Z-47.634
    N2341 X-14.342 Z-48.323
    N2342 X-12.559 Z-48.913
    N2343 X-10.776 Z-49.418
    N2344 X-8.958 Z-49.849
    N2345 X-7.169 Z-50.192
    N2346 X-5.362 Z-50.46
    N2347 X-3.592 Z-50.648
    N2348 X-1.797 Z-50.761
    N2349 X0. Z-50.8
    N2350 X1.797 Z-50.761
    N2351 X3.592 Z-50.648
    N2352 X5.362 Z-50.46
    N2353 X7.169 Z-50.192
    N2354 X8.958 Z-49.849
    N2355 X10.776 Z-49.418
    N2356 X12.559 Z-48.913
    N2357 X14.342 Z-48.323
    N2358 X16.151 Z-47.634
    N2359 X17.961 Z-46.848
    N2360 X18.845 Z-46.427
    N2361 X20.614 Z-45.507
    N2362 X22.41 Z-44.462
    N2363 X23.321 Z-43.886
    N2364 X24.233 Z-43.278
    N2365 X25.145 Z-42.634
    N2366 X26.02 Z-41.981
    N2367 X26.895 Z-41.292
    N2368 X27.77 Z-40.565
    N2369 X28.645 Z-39.796
    N2370 X29.566 Z-38.941
    N2371 X30.487 Z-38.035
    N2372 X31.408 Z-37.073
    N2373 X32.329 Z-36.043
    N2374 X33.166 Z-35.047
    N2375 X34.002 Z-33.989
    N2376 X34.839 Z-32.859
    N2377 X35.676 Z-31.638
    N2378 X36.156 Z-30.898
    N2379 X37.115 Z-29.312
    N2380 X38.074 Z-27.548
    N2381 X38.554 Z-26.583
    N2382 X39.033 Z-25.551
    N2383 X39.758 Z-23.846
    N2384 X40.491 Z-21.866
    N2385 X40.979 Z-20.339
    N2386 X41.571 Z-18.178
    N2387 X42.184 Z-15.229
    N2388 X42.44 Z-13.521
    N2389 X42.798 Z-9.749
    N2390 X43.003 Z-8.619
    N2391 X43.217 Z-7.837
    N2392 X43.554 Z-6.909
    N2393 X43.779 Z-6.403
    N2394 X44.228 Z-5.547
    N2395 X44.677 Z-4.839
    N2396 X45.35 Z-3.957
    N2397 X45.799 Z-3.462
    N2398 X46.248 Z-3.014
    N2399 X46.697 Z-2.619
    N2400 X47.146 Z-2.259
    N2401 X48.044 Z-1.647
    N2402 X48.493 Z-1.387
    N2403 X49.391 Z-.944
    N2404 X50.289 Z-.595
    N2405 X51.187 Z-.33
    N2406 X52.085 Z-.146
    N2407 X52.984 Z-.036
    N2408 X53.882 Z0.
    N2409 Y95.375
    N2410 X52.984 Z-.036
    N2411 X52.085 Z-.146
    N2412 X51.187 Z-.33
    N2413 X50.289 Z-.595
    N2414 X49.391 Z-.944
    N2415 X48.493 Z-1.387
    N2416 X48.044 Z-1.647
    N2417 X47.146 Z-2.259
    N2418 X46.697 Z-2.619
    N2419 X46.248 Z-3.014
    N2420 X45.799 Z-3.462
    N2421 X45.35 Z-3.957
    N2422 X44.677 Z-4.839
    N2423 X44.228 Z-5.547
    N2424 X43.779 Z-6.403
    N2425 X43.554 Z-6.909
    N2426 X43.217 Z-7.837
    N2427 X43.003 Z-8.619
    N2428 X42.798 Z-9.749
    N2429 X42.44 Z-13.521
    N2430 X42.184 Z-15.229
    N2431 X41.571 Z-18.178
    N2432 X40.979 Z-20.339
    N2433 X40.491 Z-21.866
    N2434 X39.758 Z-23.846
    N2435 X39.033 Z-25.551
    N2436 X38.554 Z-26.583
    N2437 X38.074 Z-27.548
    N2438 X37.115 Z-29.312
    N2439 X36.156 Z-30.898
    N2440 X35.676 Z-31.638
    N2441 X34.839 Z-32.859
    N2442 X34.002 Z-33.989
    N2443 X33.166 Z-35.047
    N2444 X32.329 Z-36.043
    N2445 X31.408 Z-37.073
    N2446 X30.487 Z-38.035
    N2447 X29.566 Z-38.941
    N2448 X28.645 Z-39.796
    N2449 X27.77 Z-40.565
    N2450 X26.895 Z-41.292
    N2451 X26.02 Z-41.981
    N2452 X25.145 Z-42.634
    N2453 X24.233 Z-43.278
    N2454 X23.321 Z-43.886
    N2455 X22.41 Z-44.462
    N2456 X20.614 Z-45.507
    N2457 X18.845 Z-46.427
    N2458 X17.961 Z-46.848
    N2459 X16.151 Z-47.634
    N2460 X14.342 Z-48.323
    N2461 X12.559 Z-48.913
    N2462 X10.776 Z-49.418
    N2463 X8.958 Z-49.849
    N2464 X7.169 Z-50.192
    N2465 X5.362 Z-50.46
    N2466 X3.592 Z-50.648
    N2467 X1.797 Z-50.761
    N2468 X0. Z-50.8
    N2469 X-1.797 Z-50.761
    N2470 X-3.592 Z-50.648
    N2471 X-5.362 Z-50.46
    N2472 X-7.169 Z-50.192
    N2473 X-8.958 Z-49.849
    N2474 X-10.776 Z-49.418
    N2475 X-12.559 Z-48.913
    N2476 X-14.342 Z-48.323
    N2477 X-16.151 Z-47.634
    N2478 X-17.961 Z-46.848
    N2479 X-19.729 Z-45.98
    N2480 X-21.498 Z-45.007
    N2481 X-22.41 Z-44.462
    N2482 X-23.321 Z-43.886
    N2483 X-24.233 Z-43.278
    N2484 X-25.145 Z-42.634
    N2485 X-26.02 Z-41.981
    N2486 X-26.895 Z-41.292
    N2487 X-27.77 Z-40.565
    N2488 X-28.645 Z-39.796
    N2489 X-29.566 Z-38.941
    N2490 X-30.487 Z-38.035
    N2491 X-31.408 Z-37.073
    N2492 X-32.329 Z-36.043
    N2493 X-33.166 Z-35.047
    N2494 X-34.002 Z-33.989
    N2495 X-34.839 Z-32.859
    N2496 X-35.676 Z-31.638
    N2497 X-36.635 Z-30.125
    N2498 X-37.595 Z-28.455
    N2499 X-38.074 Z-27.548
    N2500 X-38.554 Z-26.583
    N2501 X-39.033 Z-25.551
    N2502 X-39.758 Z-23.846
    N2503 X-40.491 Z-21.866
    N2504 X-41.346 Z-19.058
    N2505 X-41.98 Z-16.328
    N2506 X-42.491 Z-13.111
    N2507 X-42.798 Z-9.749
    N2508 X-42.901 Z-9.112
    N2509 X-43.105 Z-8.221
    N2510 X-43.33 Z-7.496
    N2511 X-43.554 Z-6.909
    N2512 X-44.003 Z-5.954
    N2513 X-44.452 Z-5.183
    N2514 X-44.901 Z-4.526
    N2515 X-45.35 Z-3.957
    N2516 X-45.799 Z-3.462
    N2517 X-46.248 Z-3.014
    N2518 X-46.697 Z-2.619
    N2519 X-47.146 Z-2.259
    N2520 X-48.044 Z-1.647
    N2521 X-48.942 Z-1.152
    N2522 X-49.391 Z-.944
    N2523 X-50.289 Z-.595
    N2524 X-51.187 Z-.33
    N2525 X-52.085 Z-.146
    N2526 X-52.984 Z-.036
    N2527 X-53.882 Z0.
    N2528 Y94.175
    N2529 X-52.984 Z-.036
    N2530 X-52.085 Z-.146
    N2531 X-51.187 Z-.33
    N2532 X-50.289 Z-.595
    N2533 X-49.391 Z-.944
    N2534 X-48.942 Z-1.152
    N2535 X-48.044 Z-1.647
    N2536 X-47.146 Z-2.259
    N2537 X-46.697 Z-2.619
    N2538 X-46.248 Z-3.014
    N2539 X-45.799 Z-3.462
    N2540 X-45.35 Z-3.957
    N2541 X-44.901 Z-4.526
    N2542 X-44.452 Z-5.183
    N2543 X-44.003 Z-5.954
    N2544 X-43.554 Z-6.909
    N2545 X-43.33 Z-7.496
    N2546 X-43.105 Z-8.221
    N2547 X-42.901 Z-9.111
    N2548 X-42.798 Z-9.749
    N2549 X-42.491 Z-13.111
    N2550 X-41.98 Z-16.328
    N2551 X-41.346 Z-19.058
    N2552 X-40.491 Z-21.866
    N2553 X-39.758 Z-23.846
    N2554 X-39.033 Z-25.551
    N2555 X-38.554 Z-26.583
    N2556 X-38.074 Z-27.548
    N2557 X-37.595 Z-28.455
    N2558 X-36.635 Z-30.125
    N2559 X-35.676 Z-31.638
    N2560 X-34.839 Z-32.859
    N2561 X-34.002 Z-33.989
    N2562 X-33.166 Z-35.047
    N2563 X-32.329 Z-36.043
    N2564 X-31.408 Z-37.073
    N2565 X-30.487 Z-38.035
    N2566 X-29.566 Z-38.941
    N2567 X-28.645 Z-39.796
    N2568 X-27.77 Z-40.565
    N2569 X-26.895 Z-41.292
    N2570 X-26.02 Z-41.981
    N2571 X-25.145 Z-42.634
    N2572 X-24.233 Z-43.278
    N2573 X-23.321 Z-43.886
    N2574 X-22.41 Z-44.462
    N2575 X-21.498 Z-45.007
    N2576 X-19.729 Z-45.98
    N2577 X-17.961 Z-46.848
    N2578 X-16.151 Z-47.634
    N2579 X-14.342 Z-48.323
    N2580 X-12.559 Z-48.913
    N2581 X-10.776 Z-49.418
    N2582 X-8.958 Z-49.849
    N2583 X-7.169 Z-50.192
    N2584 X-5.362 Z-50.46
    N2585 X-3.592 Z-50.648
    N2586 X-1.797 Z-50.761
    N2587 X0. Z-50.8
    N2588 X1.797 Z-50.761
    N2589 X3.592 Z-50.648
    N2590 X5.362 Z-50.46
    N2591 X7.169 Z-50.192
    N2592 X8.958 Z-49.849
    N2593 X10.776 Z-49.418
    N2594 X12.559 Z-48.913
    N2595 X14.342 Z-48.323
    N2596 X16.151 Z-47.634
    N2597 X17.961 Z-46.848
    N2598 X18.845 Z-46.427
    N2599 X20.614 Z-45.507
    N2600 X22.41 Z-44.462
    N2601 X23.321 Z-43.886
    N2602 X24.233 Z-43.278
    N2603 X25.145 Z-42.634
    N2604 X26.02 Z-41.981
    N2605 X26.895 Z-41.292
    N2606 X27.77 Z-40.565
    N2607 X28.645 Z-39.796
    N2608 X29.566 Z-38.941
    N2609 X30.487 Z-38.035
    N2610 X31.408 Z-37.073
    N2611 X32.329 Z-36.043
    N2612 X33.166 Z-35.047
    N2613 X34.002 Z-33.989
    N2614 X34.839 Z-32.859
    N2615 X35.676 Z-31.638
    N2616 X36.156 Z-30.898
    N2617 X37.115 Z-29.312
    N2618 X38.074 Z-27.548
    N2619 X38.554 Z-26.583
    N2620 X39.033 Z-25.551
    N2621 X39.758 Z-23.846
    N2622 X40.491 Z-21.866
    N2623 X40.979 Z-20.339
    N2624 X41.571 Z-18.178
    N2625 X42.184 Z-15.229
    N2626 X42.44 Z-13.521
    N2627 X42.798 Z-9.749
    N2628 X43.003 Z-8.619
    N2629 X43.217 Z-7.837
    N2630 X43.554 Z-6.909
    N2631 X43.779 Z-6.403
    N2632 X44.228 Z-5.547
    N2633 X44.677 Z-4.839
    N2634 X45.35 Z-3.957
    N2635 X45.799 Z-3.462
    N2636 X46.248 Z-3.014
    N2637 X46.697 Z-2.619
    N2638 X47.146 Z-2.259
    N2639 X48.044 Z-1.647
    N2640 X48.493 Z-1.387
    N2641 X49.391 Z-.944
    N2642 X50.289 Z-.595
    N2643 X51.187 Z-.33
    N2644 X52.085 Z-.146
    N2645 X52.984 Z-.036
    N2646 X53.882 Z0.
    N2647 Y92.975
    N2648 X52.984 Z-.036
    N2649 X52.085 Z-.146
    N2650 X51.187 Z-.33
    N2651 X50.289 Z-.595
    N2652 X49.391 Z-.944
    N2653 X48.493 Z-1.387
    N2654 X48.044 Z-1.647
    N2655 X47.146 Z-2.259
    N2656 X46.697 Z-2.619
    N2657 X46.248 Z-3.014
    N2658 X45.799 Z-3.462
    N2659 X45.35 Z-3.957
    N2660 X44.677 Z-4.839
    N2661 X44.228 Z-5.547
    N2662 X43.779 Z-6.404
    N2663 X43.554 Z-6.909
    N2664 X43.217 Z-7.837
    N2665 X43.003 Z-8.619
    N2666 X42.798 Z-9.749
    N2667 X42.44 Z-13.521
    N2668 X42.184 Z-15.229
    N2669 X41.571 Z-18.178
    N2670 X40.979 Z-20.339
    N2671 X40.491 Z-21.866
    N2672 X39.758 Z-23.846
    N2673 X39.033 Z-25.551
    N2674 X38.554 Z-26.583
    N2675 X38.074 Z-27.548
    N2676 X37.115 Z-29.312
    N2677 X36.156 Z-30.898
    N2678 X35.676 Z-31.638
    N2679 X34.839 Z-32.859
    N2680 X34.002 Z-33.989
    N2681 X33.166 Z-35.047
    N2682 X32.329 Z-36.043
    N2683 X31.408 Z-37.073
    N2684 X30.487 Z-38.035
    N2685 X29.566 Z-38.941
    N2686 X28.645 Z-39.796
    N2687 X27.77 Z-40.565
    N2688 X26.895 Z-41.292
    N2689 X26.02 Z-41.981
    N2690 X25.145 Z-42.634
    N2691 X24.233 Z-43.278
    N2692 X23.321 Z-43.886
    N2693 X22.41 Z-44.462
    N2694 X20.614 Z-45.507
    N2695 X18.845 Z-46.427
    N2696 X17.961 Z-46.848
    N2697 X16.151 Z-47.634
    N2698 X14.342 Z-48.323
    N2699 X12.559 Z-48.913
    N2700 X10.776 Z-49.418
    N2701 X8.958 Z-49.849
    N2702 X7.169 Z-50.192
    N2703 X5.362 Z-50.46
    N2704 X3.592 Z-50.648
    N2705 X1.797 Z-50.761
    N2706 X0. Z-50.8
    N2707 X-1.797 Z-50.761
    N2708 X-3.592 Z-50.648
    N2709 X-5.362 Z-50.46
    N2710 X-7.169 Z-50.192
    N2711 X-8.958 Z-49.849
    N2712 X-10.776 Z-49.418
    N2713 X-12.559 Z-48.913
    N2714 X-14.342 Z-48.323
    N2715 X-16.151 Z-47.634
    N2716 X-17.961 Z-46.848
    N2717 X-19.729 Z-45.98
    N2718 X-21.498 Z-45.007
    N2719 X-22.41 Z-44.462
    N2720 X-23.321 Z-43.886
    N2721 X-24.233 Z-43.278
    N2722 X-25.145 Z-42.634
    N2723 X-26.02 Z-41.981
    N2724 X-26.895 Z-41.292
    N2725 X-27.77 Z-40.565
    N2726 X-28.645 Z-39.796
    N2727 X-29.566 Z-38.941
    N2728 X-30.487 Z-38.035
    N2729 X-31.408 Z-37.073
    N2730 X-32.329 Z-36.043
    N2731 X-33.166 Z-35.047
    N2732 X-34.002 Z-33.989
    N2733 X-34.839 Z-32.859
    N2734 X-35.676 Z-31.638
    N2735 X-36.635 Z-30.125
    N2736 X-37.595 Z-28.455
    N2737 X-38.074 Z-27.548
    N2738 X-38.554 Z-26.583
    N2739 X-39.033 Z-25.551
    N2740 X-39.758 Z-23.846
    N2741 X-40.491 Z-21.866
    N2742 X-41.346 Z-19.058
    N2743 X-41.98 Z-16.328
    N2744 X-42.491 Z-13.111
    N2745 X-42.798 Z-9.749
    N2746 X-42.901 Z-9.111
    N2747 X-43.105 Z-8.221
    N2748 X-43.33 Z-7.496
    N2749 X-43.554 Z-6.909
    N2750 X-44.003 Z-5.954
    N2751 X-44.452 Z-5.183
    N2752 X-44.901 Z-4.526
    N2753 X-45.35 Z-3.957
    N2754 X-45.799 Z-3.462
    N2755 X-46.248 Z-3.014
    N2756 X-46.697 Z-2.619
    N2757 X-47.146 Z-2.259
    N2758 X-48.044 Z-1.647
    N2759 X-48.942 Z-1.152
    N2760 X-49.391 Z-.944
    N2761 X-50.289 Z-.595
    N2762 X-51.187 Z-.33
    N2763 X-52.085 Z-.146
    N2764 X-52.984 Z-.036
    N2765 X-53.882 Z0.
    N2766 Y91.775
    N2767 X-52.984 Z-.036
    N2768 X-52.085 Z-.146
    N2769 X-51.187 Z-.33
    N2770 X-50.289 Z-.595
    N2771 X-49.391 Z-.944
    N2772 X-48.942 Z-1.152
    N2773 X-48.044 Z-1.647
    N2774 X-47.146 Z-2.259
    N2775 X-46.697 Z-2.618
    N2776 X-46.248 Z-3.014
    N2777 X-45.799 Z-3.462
    N2778 X-45.35 Z-3.957
    N2779 X-44.901 Z-4.526
    N2780 X-44.452 Z-5.183
    N2781 X-44.003 Z-5.953
    N2782 X-43.554 Z-6.908
    N2783 X-43.33 Z-7.496
    N2784 X-43.105 Z-8.221
    N2785 X-42.901 Z-9.111
    N2786 X-42.798 Z-9.749
    N2787 X-42.491 Z-13.111
    N2788 X-41.98 Z-16.328
    N2789 X-41.346 Z-19.058
    N2790 X-40.491 Z-21.866
    N2791 X-39.758 Z-23.846
    N2792 X-39.033 Z-25.551
    N2793 X-38.554 Z-26.583
    N2794 X-38.074 Z-27.548
    N2795 X-37.595 Z-28.455
    N2796 X-36.635 Z-30.125
    N2797 X-35.676 Z-31.638
    N2798 X-34.839 Z-32.859
    N2799 X-34.002 Z-33.989
    N2800 X-33.166 Z-35.047
    N2801 X-32.329 Z-36.043
    N2802 X-31.408 Z-37.073
    N2803 X-30.487 Z-38.035
    N2804 X-29.566 Z-38.941
    N2805 X-28.645 Z-39.796
    N2806 X-27.77 Z-40.565
    N2807 X-26.895 Z-41.292
    N2808 X-26.02 Z-41.981
    N2809 X-25.145 Z-42.634
    N2810 X-24.233 Z-43.278
    N2811 X-23.321 Z-43.886
    N2812 X-22.41 Z-44.462
    N2813 X-21.498 Z-45.007
    N2814 X-19.729 Z-45.98
    N2815 X-17.961 Z-46.848
    N2816 X-16.151 Z-47.634
    N2817 X-14.342 Z-48.323
    N2818 X-12.559 Z-48.913
    N2819 X-10.776 Z-49.418
    N2820 X-8.958 Z-49.849
    N2821 X-7.169 Z-50.192
    N2822 X-5.362 Z-50.46
    N2823 X-3.592 Z-50.648
    N2824 X-1.797 Z-50.761
    N2825 X0. Z-50.8
    N2826 X1.797 Z-50.761
    N2827 X3.592 Z-50.648
    N2828 X5.362 Z-50.46
    N2829 X7.169 Z-50.192
    N2830 X8.958 Z-49.849
    N2831 X10.776 Z-49.418
    N2832 X12.559 Z-48.913
    N2833 X14.342 Z-48.323
    N2834 X16.151 Z-47.634
    N2835 X17.961 Z-46.848
    N2836 X18.845 Z-46.427
    N2837 X20.614 Z-45.507
    N2838 X22.41 Z-44.462
    N2839 X23.321 Z-43.886
    N2840 X24.233 Z-43.278
    N2841 X25.145 Z-42.634
    N2842 X26.02 Z-41.981
    N2843 X26.895 Z-41.292
    N2844 X27.77 Z-40.565
    N2845 X28.645 Z-39.796
    N2846 X29.566 Z-38.941
    N2847 X30.487 Z-38.035
    N2848 X31.408 Z-37.073
    N2849 X32.329 Z-36.043
    N2850 X33.166 Z-35.047
    N2851 X34.002 Z-33.989
    N2852 X34.839 Z-32.859
    N2853 X35.676 Z-31.638
    N2854 X36.156 Z-30.898
    N2855 X37.115 Z-29.312
    N2856 X38.074 Z-27.548
    N2857 X38.554 Z-26.583
    N2858 X39.033 Z-25.551
    N2859 X39.758 Z-23.846
    N2860 X40.491 Z-21.866
    N2861 X40.979 Z-20.339
    N2862 X41.571 Z-18.178
    N2863 X42.184 Z-15.229
    N2864 X42.44 Z-13.521
    N2865 X42.798 Z-9.749
    N2866 X43.003 Z-8.619
    N2867 X43.217 Z-7.837
    N2868 X43.554 Z-6.908
    N2869 X43.779 Z-6.404
    N2870 X44.228 Z-5.547
    N2871 X44.677 Z-4.839
    N2872 X45.35 Z-3.957
    N2873 X45.799 Z-3.462
    N2874 X46.248 Z-3.014
    N2875 X46.697 Z-2.619
    N2876 X47.146 Z-2.259
    N2877 X48.044 Z-1.647
    N2878 X48.493 Z-1.387
    N2879 X49.391 Z-.944
    N2880 X50.289 Z-.594
    N2881 X51.187 Z-.33
    N2882 X52.085 Z-.146
    N2883 X52.984 Z-.036
    N2884 X53.882 Z0.
    N2885 Y90.575
    N2886 X52.984 Z-.036
    N2887 X52.085 Z-.146
    N2888 X51.187 Z-.33
    N2889 X50.289 Z-.594
    N2890 X49.391 Z-.944
    N2891 X48.493 Z-1.387
    N2892 X48.044 Z-1.647
    N2893 X47.146 Z-2.259
    N2894 X46.697 Z-2.618
    N2895 X46.248 Z-3.014
    N2896 X45.799 Z-3.462
    N2897 X45.35 Z-3.957
    N2898 X44.677 Z-4.839
    N2899 X44.228 Z-5.547
    N2900 X43.779 Z-6.404
    N2901 X43.554 Z-6.908
    N2902 X43.217 Z-7.837
    N2903 X43.003 Z-8.619
    N2904 X42.798 Z-9.749
    N2905 X42.44 Z-13.521
    N2906 X42.184 Z-15.229
    N2907 X41.571 Z-18.178
    N2908 X40.979 Z-20.339
    N2909 X40.491 Z-21.866
    N2910 X39.758 Z-23.846
    N2911 X39.033 Z-25.551
    N2912 X38.554 Z-26.583
    N2913 X38.074 Z-27.548
    N2914 X37.115 Z-29.312
    N2915 X36.156 Z-30.898
    N2916 X35.676 Z-31.638
    N2917 X34.839 Z-32.859
    N2918 X34.002 Z-33.989
    N2919 X33.166 Z-35.047
    N2920 X32.329 Z-36.043
    N2921 X31.408 Z-37.073
    N2922 X30.487 Z-38.035
    N2923 X29.566 Z-38.941
    N2924 X28.645 Z-39.796
    N2925 X27.77 Z-40.565
    N2926 X26.895 Z-41.292
    N2927 X26.02 Z-41.981
    N2928 X25.145 Z-42.634
    N2929 X24.233 Z-43.278
    N2930 X23.321 Z-43.886
    N2931 X22.41 Z-44.462
    N2932 X20.614 Z-45.507
    N2933 X18.845 Z-46.427
    N2934 X17.961 Z-46.848
    N2935 X16.151 Z-47.634
    N2936 X14.342 Z-48.323
    N2937 X12.559 Z-48.913
    N2938 X10.776 Z-49.418
    N2939 X8.958 Z-49.849
    N2940 X7.169 Z-50.192
    N2941 X5.362 Z-50.46
    N2942 X3.592 Z-50.648
    N2943 X1.797 Z-50.761
    N2944 X0. Z-50.8
    N2945 X-1.797 Z-50.761
    N2946 X-3.592 Z-50.648
    N2947 X-5.362 Z-50.46
    N2948 X-7.169 Z-50.192
    N2949 X-8.958 Z-49.849
    N2950 X-10.776 Z-49.418
    N2951 X-12.559 Z-48.913
    N2952 X-14.342 Z-48.323
    N2953 X-16.151 Z-47.634
    N2954 X-17.961 Z-46.848
    N2955 X-19.729 Z-45.98
    N2956 X-21.498 Z-45.007
    N2957 X-22.41 Z-44.462
    N2958 X-23.321 Z-43.886
    N2959 X-24.233 Z-43.278
    N2960 X-25.145 Z-42.634
    N2961 X-26.02 Z-41.981
    N2962 X-26.895 Z-41.292
    N2963 X-27.77 Z-40.565
    N2964 X-28.645 Z-39.796
    N2965 X-29.566 Z-38.941
    N2966 X-30.487 Z-38.035
    N2967 X-31.408 Z-37.073
    N2968 X-32.329 Z-36.043
    N2969 X-33.166 Z-35.047
    N2970 X-34.002 Z-33.989
    N2971 X-34.839 Z-32.859
    N2972 X-35.676 Z-31.638
    N2973 X-36.635 Z-30.125
    N2974 X-37.595 Z-28.455
    N2975 X-38.074 Z-27.548
    N2976 X-38.554 Z-26.583
    N2977 X-39.033 Z-25.551
    N2978 X-39.758 Z-23.846
    N2979 X-40.491 Z-21.866
    N2980 X-41.346 Z-19.058
    N2981 X-41.98 Z-16.328
    N2982 X-42.491 Z-13.111
    N2983 X-42.798 Z-9.749
    N2984 X-42.901 Z-9.111
    N2985 X-43.105 Z-8.221
    N2986 X-43.33 Z-7.496
    N2987 X-43.554 Z-6.908
    N2988 X-44.003 Z-5.953
    N2989 X-44.452 Z-5.183
    N2990 X-44.901 Z-4.526
    N2991 X-45.35 Z-3.957
    N2992 X-45.799 Z-3.462
    N2993 X-46.248 Z-3.014
    N2994 X-46.697 Z-2.618
    N2995 X-47.146 Z-2.259
    N2996 X-48.044 Z-1.647
    N2997 X-48.942 Z-1.152
    N2998 X-49.391 Z-.944
    N2999 X-50.289 Z-.594
    N3000 X-51.187 Z-.33
    N3001 X-52.085 Z-.146
    N3002 X-52.984 Z-.036
    N3003 X-53.882 Z0.
    N3004 Y89.375
    N3005 X-52.984 Z-.036
    N3006 X-52.085 Z-.146
    N3007 X-51.187 Z-.33
    N3008 X-50.289 Z-.594
    N3009 X-49.391 Z-.944
    N3010 X-48.942 Z-1.152
    N3011 X-48.044 Z-1.647
    N3012 X-47.595 Z-1.938
    N3013 X-47.146 Z-2.259
    N3014 X-46.697 Z-2.618
    N3015 X-46.248 Z-3.014
    N3016 X-45.799 Z-3.462
    N3017 X-45.35 Z-3.957
    N3018 X-44.901 Z-4.526
    N3019 X-44.452 Z-5.183
    N3020 X-44.003 Z-5.953
    N3021 X-43.554 Z-6.908
    N3022 X-43.33 Z-7.496
    N3023 X-43.105 Z-8.221
    N3024 X-42.901 Z-9.111
    N3025 X-42.798 Z-9.749
    N3026 X-42.491 Z-13.111
    N3027 X-41.98 Z-16.328
    N3028 X-41.346 Z-19.058
    N3029 X-40.491 Z-21.866
    N3030 X-39.758 Z-23.846
    N3031 X-39.033 Z-25.551
    N3032 X-38.554 Z-26.583
    N3033 X-38.074 Z-27.548
    N3034 X-37.595 Z-28.455
    N3035 X-36.635 Z-30.125
    N3036 X-35.676 Z-31.638
    N3037 X-34.839 Z-32.859
    N3038 X-34.002 Z-33.989
    N3039 X-33.166 Z-35.047
    N3040 X-32.329 Z-36.043
    N3041 X-31.408 Z-37.073
    N3042 X-30.487 Z-38.035
    N3043 X-29.566 Z-38.941
    N3044 X-28.645 Z-39.796
    N3045 X-27.77 Z-40.565
    N3046 X-26.895 Z-41.292
    N3047 X-26.02 Z-41.981
    N3048 X-25.145 Z-42.634
    N3049 X-24.233 Z-43.278
    N3050 X-23.321 Z-43.886
    N3051 X-22.41 Z-44.462
    N3052 X-21.498 Z-45.007
    N3053 X-19.729 Z-45.98
    N3054 X-17.961 Z-46.848
    N3055 X-16.151 Z-47.634
    N3056 X-14.342 Z-48.323
    N3057 X-12.559 Z-48.913
    N3058 X-10.776 Z-49.418
    N3059 X-8.958 Z-49.849
    N3060 X-7.169 Z-50.192
    N3061 X-5.362 Z-50.46
    N3062 X-3.592 Z-50.648
    N3063 X-1.797 Z-50.761
    N3064 X0. Z-50.8
    N3065 X1.797 Z-50.761
    N3066 X3.592 Z-50.648
    N3067 X5.362 Z-50.46
    N3068 X7.169 Z-50.192
    N3069 X8.958 Z-49.849
    N3070 X10.776 Z-49.418
    N3071 X12.559 Z-48.913
    N3072 X14.342 Z-48.323
    N3073 X16.151 Z-47.634
    N3074 X17.961 Z-46.848
    N3075 X18.845 Z-46.427
    N3076 X20.614 Z-45.507
    N3077 X22.41 Z-44.462
    N3078 X23.321 Z-43.886
    N3079 X24.233 Z-43.278
    N3080 X25.145 Z-42.634
    N3081 X26.02 Z-41.981
    N3082 X26.895 Z-41.292
    N3083 X27.77 Z-40.565
    N3084 X28.645 Z-39.796
    N3085 X29.566 Z-38.941
    N3086 X30.487 Z-38.035
    N3087 X31.408 Z-37.073
    N3088 X32.329 Z-36.043
    N3089 X33.166 Z-35.047
    N3090 X34.002 Z-33.989
    N3091 X34.839 Z-32.859
    N3092 X35.676 Z-31.638
    N3093 X36.156 Z-30.898
    N3094 X37.115 Z-29.312
    N3095 X38.074 Z-27.548
    N3096 X38.554 Z-26.583
    N3097 X39.033 Z-25.551
    N3098 X39.758 Z-23.846
    N3099 X40.491 Z-21.866
    N3100 X40.979 Z-20.339
    N3101 X41.571 Z-18.178
    N3102 X42.184 Z-15.229
    N3103 X42.44 Z-13.521
    N3104 X42.798 Z-9.749
    N3105 X43.003 Z-8.619
    N3106 X43.217 Z-7.837
    N3107 X43.554 Z-6.908
    N3108 X43.779 Z-6.404
    N3109 X44.228 Z-5.547
    N3110 X44.677 Z-4.839
    N3111 X45.35 Z-3.957
    N3112 X45.799 Z-3.462
    N3113 X46.248 Z-3.014
    N3114 X46.697 Z-2.618
    N3115 X47.146 Z-2.259
    N3116 X48.044 Z-1.647
    N3117 X48.493 Z-1.387
    N3118 X49.391 Z-.944
    N3119 X50.289 Z-.594
    N3120 X51.187 Z-.33
    N3121 X52.085 Z-.146
    N3122 X52.984 Z-.036
    N3123 X53.882 Z0.
    N3124 Y88.175
    N3125 X52.984 Z-.036
    N3126 X52.085 Z-.146
    N3127 X51.187 Z-.33
    N3128 X50.289 Z-.594
    N3129 X49.391 Z-.944
    N3130 X48.493 Z-1.387
    N3131 X48.044 Z-1.647
    N3132 X47.595 Z-1.938
    N3133 X47.146 Z-2.259
    N3134 X46.697 Z-2.618
    N3135 X46.248 Z-3.014
    N3136 X45.799 Z-3.462
    N3137 X45.35 Z-3.957
    N3138 X44.677 Z-4.839
    N3139 X44.228 Z-5.547
    N3140 X43.779 Z-6.404
    N3141 X43.554 Z-6.908
    N3142 X43.217 Z-7.837
    N3143 X43.003 Z-8.619
    N3144 X42.798 Z-9.749
    N3145 X42.44 Z-13.52
    N3146 X42.184 Z-15.229
    N3147 X41.571 Z-18.178
    N3148 X40.979 Z-20.339
    N3149 X40.491 Z-21.866
    N3150 X39.758 Z-23.846
    N3151 X39.033 Z-25.551
    N3152 X38.554 Z-26.583
    N3153 X38.074 Z-27.548
    N3154 X37.115 Z-29.312
    N3155 X36.156 Z-30.898
    N3156 X35.676 Z-31.638
    N3157 X34.839 Z-32.859
    N3158 X34.002 Z-33.989
    N3159 X33.166 Z-35.047
    N3160 X32.329 Z-36.043
    N3161 X31.408 Z-37.073
    N3162 X30.487 Z-38.035
    N3163 X29.566 Z-38.941
    N3164 X28.645 Z-39.796
    N3165 X27.77 Z-40.565
    N3166 X26.895 Z-41.292
    N3167 X26.02 Z-41.981
    N3168 X25.145 Z-42.634
    N3169 X24.233 Z-43.278
    N3170 X23.321 Z-43.886
    N3171 X22.41 Z-44.462
    N3172 X20.614 Z-45.507
    N3173 X18.845 Z-46.427
    N3174 X17.961 Z-46.848
    N3175 X16.151 Z-47.634
    N3176 X14.342 Z-48.323
    N3177 X12.559 Z-48.913
    N3178 X10.776 Z-49.418
    N3179 X8.958 Z-49.849
    N3180 X7.169 Z-50.192
    N3181 X5.362 Z-50.46
    N3182 X3.592 Z-50.648
    N3183 X1.797 Z-50.761
    N3184 X0. Z-50.8
    N3185 X-1.797 Z-50.761
    N3186 X-3.592 Z-50.648
    N3187 X-5.362 Z-50.46
    N3188 X-7.169 Z-50.192
    N3189 X-8.958 Z-49.849
    N3190 X-10.776 Z-49.418
    N3191 X-12.559 Z-48.913
    N3192 X-14.342 Z-48.323
    N3193 X-16.151 Z-47.634
    N3194 X-17.961 Z-46.848
    N3195 X-19.729 Z-45.98
    N3196 X-21.498 Z-45.007
    N3197 X-22.41 Z-44.462
    N3198 X-23.321 Z-43.886
    N3199 X-24.233 Z-43.278
    N3200 X-25.145 Z-42.634
    N3201 X-26.02 Z-41.981
    N3202 X-26.895 Z-41.292
    N3203 X-27.77 Z-40.565
    N3204 X-28.645 Z-39.796
    N3205 X-29.566 Z-38.941
    N3206 X-30.487 Z-38.035
    N3207 X-31.408 Z-37.073
    N3208 X-32.329 Z-36.043
    N3209 X-33.166 Z-35.047
    N3210 X-34.002 Z-33.989
    N3211 X-34.839 Z-32.859
    N3212 X-35.676 Z-31.638
    N3213 X-36.635 Z-30.125
    N3214 X-37.595 Z-28.455
    N3215 X-38.074 Z-27.548
    N3216 X-38.554 Z-26.583
    N3217 X-39.033 Z-25.551
    N3218 X-39.758 Z-23.846
    N3219 X-40.491 Z-21.866
    N3220 X-41.346 Z-19.058
    N3221 X-41.98 Z-16.328
    N3222 X-42.491 Z-13.111
    N3223 X-42.798 Z-9.749
    N3224 X-42.901 Z-9.11
    N3225 X-43.105 Z-8.221
    N3226 X-43.33 Z-7.496
    N3227 X-43.554 Z-6.908
    N3228 X-44.003 Z-5.953
    N3229 X-44.452 Z-5.183
    N3230 X-44.901 Z-4.526
    N3231 X-45.35 Z-3.957
    N3232 X-45.799 Z-3.462
    N3233 X-46.248 Z-3.014
    N3234 X-46.697 Z-2.618
    N3235 X-47.146 Z-2.259
    N3236 X-47.595 Z-1.938
    N3237 X-48.493 Z-1.387
    N3238 X-49.391 Z-.944
    N3239 X-50.289 Z-.594
    N3240 X-51.187 Z-.33
    N3241 X-52.085 Z-.146
    N3242 X-52.984 Z-.036
    N3243 X-53.882 Z0.
    N3244 Y86.975
    N3245 X-52.984 Z-.036
    N3246 X-52.085 Z-.146
    N3247 X-51.187 Z-.33
    N3248 X-50.289 Z-.594
    N3249 X-49.391 Z-.944
    N3250 X-48.493 Z-1.387
    N3251 X-47.595 Z-1.938
    N3252 X-47.146 Z-2.259
    N3253 X-46.697 Z-2.618
    N3254 X-46.248 Z-3.014
    N3255 X-45.799 Z-3.462
    N3256 X-45.35 Z-3.957
    N3257 X-44.901 Z-4.527
    N3258 X-44.452 Z-5.183
    N3259 X-44.003 Z-5.953
    N3260 X-43.554 Z-6.908
    N3261 X-43.33 Z-7.496
    N3262 X-43.105 Z-8.221
    N3263 X-42.901 Z-9.11
    N3264 X-42.798 Z-9.749
    N3265 X-42.491 Z-13.111
    N3266 X-41.98 Z-16.328
    N3267 X-41.346 Z-19.058
    N3268 X-40.491 Z-21.866
    N3269 X-39.758 Z-23.846
    N3270 X-39.033 Z-25.551
    N3271 X-38.554 Z-26.583
    N3272 X-38.074 Z-27.548
    N3273 X-37.595 Z-28.455
    N3274 X-36.635 Z-30.125
    N3275 X-35.676 Z-31.638
    N3276 X-34.839 Z-32.859
    N3277 X-34.002 Z-33.989
    N3278 X-33.166 Z-35.047
    N3279 X-32.329 Z-36.043
    N3280 X-31.408 Z-37.073
    N3281 X-30.487 Z-38.035
    N3282 X-29.566 Z-38.941
    N3283 X-28.645 Z-39.796
    N3284 X-27.77 Z-40.565
    N3285 X-26.895 Z-41.292
    N3286 X-26.02 Z-41.981
    N3287 X-25.145 Z-42.634
    N3288 X-24.233 Z-43.278
    N3289 X-23.321 Z-43.886
    N3290 X-22.41 Z-44.462
    N3291 X-21.498 Z-45.007
    N3292 X-19.729 Z-45.98
    N3293 X-17.961 Z-46.848
    N3294 X-16.151 Z-47.634
    N3295 X-14.342 Z-48.323
    N3296 X-12.559 Z-48.913
    N3297 X-10.776 Z-49.418
    N3298 X-8.958 Z-49.849
    N3299 X-7.169 Z-50.192
    N3300 X-5.362 Z-50.46
    N3301 X-3.592 Z-50.648
    N3302 X-1.797 Z-50.761
    N3303 X0. Z-50.8
    N3304 X1.797 Z-50.761
    N3305 X3.592 Z-50.648
    N3306 X5.362 Z-50.46
    N3307 X7.169 Z-50.192
    N3308 X8.958 Z-49.849
    N3309 X10.776 Z-49.418
    N3310 X12.559 Z-48.913
    N3311 X14.342 Z-48.323
    N3312 X16.151 Z-47.634
    N3313 X17.961 Z-46.848
    N3314 X18.845 Z-46.427
    N3315 X20.614 Z-45.507
    N3316 X22.41 Z-44.462
    N3317 X23.321 Z-43.886
    N3318 X24.233 Z-43.278
    N3319 X25.145 Z-42.634
    N3320 X26.02 Z-41.981
    N3321 X26.895 Z-41.292
    N3322 X27.77 Z-40.565
    N3323 X28.645 Z-39.796
    N3324 X29.566 Z-38.941
    N3325 X30.487 Z-38.035
    N3326 X31.408 Z-37.073
    N3327 X32.329 Z-36.043
    N3328 X33.166 Z-35.047
    N3329 X34.002 Z-33.989
    N3330 X34.839 Z-32.859
    N3331 X35.676 Z-31.638
    N3332 X36.156 Z-30.898
    N3333 X37.115 Z-29.312
    N3334 X38.074 Z-27.548
    N3335 X38.554 Z-26.583
    N3336 X39.033 Z-25.551
    N3337 X39.758 Z-23.846
    N3338 X40.491 Z-21.866
    N3339 X40.979 Z-20.339
    N3340 X41.571 Z-18.178
    N3341 X42.184 Z-15.229
    N3342 X42.44 Z-13.52
    N3343 X42.798 Z-9.749
    N3344 X43.003 Z-8.618
    N3345 X43.217 Z-7.837
    N3346 X43.554 Z-6.908
    N3347 X43.779 Z-6.404
    N3348 X44.228 Z-5.547
    N3349 X44.677 Z-4.839
    N3350 X45.35 Z-3.957
    N3351 X45.799 Z-3.462
    N3352 X46.248 Z-3.014
    N3353 X46.697 Z-2.618
    N3354 X47.146 Z-2.259
    N3355 X47.595 Z-1.938
    N3356 X48.493 Z-1.387
    N3357 X49.391 Z-.944
    N3358 X50.289 Z-.594
    N3359 X51.187 Z-.33
    N3360 X52.085 Z-.145
    N3361 X52.984 Z-.036
    N3362 X53.882 Z0.
    N3363 Y85.775
    N3364 X52.984 Z-.036
    N3365 X52.085 Z-.145
    N3366 X51.187 Z-.33
    N3367 X50.289 Z-.594
    N3368 X49.391 Z-.944
    N3369 X48.493 Z-1.387
    N3370 X47.595 Z-1.938
    N3371 X47.146 Z-2.259
    N3372 X46.697 Z-2.618
    N3373 X46.248 Z-3.014
    N3374 X45.799 Z-3.462
    N3375 X45.35 Z-3.957
    N3376 X44.677 Z-4.839
    N3377 X44.228 Z-5.547
    N3378 X43.779 Z-6.404
    N3379 X43.554 Z-6.908
    N3380 X43.217 Z-7.837
    N3381 X43.003 Z-8.618
    N3382 X42.798 Z-9.749
    N3383 X42.44 Z-13.52
    N3384 X42.184 Z-15.229
    N3385 X41.571 Z-18.178
    N3386 X40.979 Z-20.339
    N3387 X40.491 Z-21.866
    N3388 X39.758 Z-23.846
    N3389 X39.033 Z-25.551
    N3390 X38.554 Z-26.583
    N3391 X38.074 Z-27.548
    N3392 X37.115 Z-29.312
    N3393 X36.156 Z-30.898
    N3394 X35.676 Z-31.638
    N3395 X34.839 Z-32.859
    N3396 X34.002 Z-33.989
    N3397 X33.166 Z-35.047
    N3398 X32.329 Z-36.043
    N3399 X31.408 Z-37.073
    N3400 X30.487 Z-38.035
    N3401 X29.566 Z-38.941
    N3402 X28.645 Z-39.796
    N3403 X27.77 Z-40.565
    N3404 X26.895 Z-41.292
    N3405 X26.02 Z-41.981
    N3406 X25.145 Z-42.634
    N3407 X24.233 Z-43.278
    N3408 X23.321 Z-43.886
    N3409 X22.41 Z-44.462
    N3410 X20.614 Z-45.507
    N3411 X18.845 Z-46.427
    N3412 X17.961 Z-46.848
    N3413 X16.151 Z-47.634
    N3414 X14.342 Z-48.323
    N3415 X12.559 Z-48.913
    N3416 X10.776 Z-49.418
    N3417 X8.958 Z-49.849
    N3418 X7.169 Z-50.192
    N3419 X5.362 Z-50.46
    N3420 X3.592 Z-50.648
    N3421 X1.797 Z-50.761
    N3422 X0. Z-50.8
    N3423 X-1.797 Z-50.761
    N3424 X-3.592 Z-50.648
    N3425 X-5.362 Z-50.46
    N3426 X-7.169 Z-50.192
    N3427 X-8.958 Z-49.849
    N3428 X-10.776 Z-49.418
    N3429 X-12.559 Z-48.913
    N3430 X-14.342 Z-48.323
    N3431 X-16.151 Z-47.634
    N3432 X-17.961 Z-46.848
    N3433 X-19.729 Z-45.98
    N3434 X-21.498 Z-45.007
    N3435 X-22.41 Z-44.462
    N3436 X-23.321 Z-43.886
    N3437 X-24.233 Z-43.278
    N3438 X-25.145 Z-42.634
    N3439 X-26.02 Z-41.981
    N3440 X-26.895 Z-41.292
    N3441 X-27.77 Z-40.565
    N3442 X-28.645 Z-39.796
    N3443 X-29.566 Z-38.941
    N3444 X-30.487 Z-38.035
    N3445 X-31.408 Z-37.073
    N3446 X-32.329 Z-36.043
    N3447 X-33.166 Z-35.047
    N3448 X-34.002 Z-33.989
    N3449 X-34.839 Z-32.859
    N3450 X-35.676 Z-31.638
    N3451 X-36.635 Z-30.125
    N3452 X-37.595 Z-28.455
    N3453 X-38.074 Z-27.548
    N3454 X-38.554 Z-26.583
    N3455 X-39.033 Z-25.551
    N3456 X-39.758 Z-23.846
    N3457 X-40.491 Z-21.866
    N3458 X-41.346 Z-19.058
    N3459 X-41.98 Z-16.328
    N3460 X-42.491 Z-13.111
    N3461 X-42.798 Z-9.749
    N3462 X-42.901 Z-9.11
    N3463 X-43.105 Z-8.221
    N3464 X-43.33 Z-7.496
    N3465 X-43.554 Z-6.908
    N3466 X-44.003 Z-5.953
    N3467 X-44.452 Z-5.183
    N3468 X-44.901 Z-4.527
    N3469 X-45.35 Z-3.957
    N3470 X-45.799 Z-3.462
    N3471 X-46.248 Z-3.014
    N3472 X-46.697 Z-2.618
    N3473 X-47.146 Z-2.259
    N3474 X-47.595 Z-1.938
    N3475 X-48.493 Z-1.387
    N3476 X-49.391 Z-.944
    N3477 X-50.289 Z-.594
    N3478 X-51.187 Z-.33
    N3479 X-52.085 Z-.145
    N3480 X-52.984 Z-.036
    N3481 X-53.882 Z0.
    N3482 Y84.575
    N3483 X-52.984 Z-.036
    N3484 X-52.085 Z-.145
    N3485 X-51.187 Z-.33
    N3486 X-50.289 Z-.594
    N3487 X-49.391 Z-.943
    N3488 X-48.493 Z-1.387
    N3489 X-47.595 Z-1.938
    N3490 X-47.146 Z-2.259
    N3491 X-46.697 Z-2.618
    N3492 X-46.248 Z-3.014
    N3493 X-45.799 Z-3.462
    N3494 X-45.35 Z-3.957
    N3495 X-44.901 Z-4.527
    N3496 X-44.452 Z-5.183
    N3497 X-44.003 Z-5.953
    N3498 X-43.554 Z-6.908
    N3499 X-43.33 Z-7.496
    N3500 X-43.105 Z-8.221
    N3501 X-42.901 Z-9.11
    N3502 X-42.798 Z-9.749
    N3503 X-42.491 Z-13.111
    N3504 X-41.98 Z-16.328
    N3505 X-41.346 Z-19.058
    N3506 X-40.491 Z-21.866
    N3507 X-39.758 Z-23.846
    N3508 X-39.033 Z-25.551
    N3509 X-38.554 Z-26.583
    N3510 X-38.074 Z-27.548
    N3511 X-37.595 Z-28.455
    N3512 X-36.635 Z-30.125
    N3513 X-35.676 Z-31.638
    N3514 X-34.839 Z-32.859
    N3515 X-34.002 Z-33.989
    N3516 X-33.166 Z-35.047
    N3517 X-32.329 Z-36.043
    N3518 X-31.408 Z-37.073
    N3519 X-30.487 Z-38.035
    N3520 X-29.566 Z-38.941
    N3521 X-28.645 Z-39.796
    N3522 X-27.77 Z-40.565
    N3523 X-26.895 Z-41.292
    N3524 X-26.02 Z-41.981
    N3525 X-25.145 Z-42.634
    N3526 X-24.233 Z-43.278
    N3527 X-23.321 Z-43.886
    N3528 X-22.41 Z-44.462
    N3529 X-21.498 Z-45.007
    N3530 X-19.729 Z-45.98
    N3531 X-17.961 Z-46.848
    N3532 X-16.151 Z-47.634
    N3533 X-14.342 Z-48.323
    N3534 X-12.559 Z-48.913
    N3535 X-10.776 Z-49.418
    N3536 X-8.958 Z-49.849
    N3537 X-7.169 Z-50.192
    N3538 X-5.362 Z-50.46
    N3539 X-3.592 Z-50.648
    N3540 X-1.797 Z-50.761
    N3541 X0. Z-50.8
    N3542 X1.797 Z-50.761
    N3543 X3.592 Z-50.648
    N3544 X5.362 Z-50.46
    N3545 X7.169 Z-50.192
    N3546 X8.958 Z-49.849
    N3547 X10.776 Z-49.418
    N3548 X12.559 Z-48.913
    N3549 X14.342 Z-48.323
    N3550 X16.151 Z-47.634
    N3551 X17.961 Z-46.848
    N3552 X18.845 Z-46.427
    N3553 X20.614 Z-45.507
    N3554 X22.41 Z-44.462
    N3555 X23.321 Z-43.886
    N3556 X24.233 Z-43.278
    N3557 X25.145 Z-42.634
    N3558 X26.02 Z-41.981
    N3559 X26.895 Z-41.292
    N3560 X27.77 Z-40.565
    N3561 X28.645 Z-39.796
    N3562 X29.566 Z-38.941
    N3563 X30.487 Z-38.035
    N3564 X31.408 Z-37.073
    N3565 X32.329 Z-36.043
    N3566 X33.166 Z-35.047
    N3567 X34.002 Z-33.989
    N3568 X34.839 Z-32.859
    N3569 X35.676 Z-31.638
    N3570 X36.156 Z-30.898
    N3571 X37.115 Z-29.312
    N3572 X38.074 Z-27.548
    N3573 X38.554 Z-26.583
    N3574 X39.033 Z-25.551
    N3575 X39.758 Z-23.846
    N3576 X40.491 Z-21.866
    N3577 X40.979 Z-20.339
    N3578 X41.571 Z-18.178
    N3579 X42.184 Z-15.229
    N3580 X42.44 Z-13.52
    N3581 X42.798 Z-9.749
    N3582 X43.003 Z-8.618
    N3583 X43.217 Z-7.837
    N3584 X43.554 Z-6.908
    N3585 X43.779 Z-6.404
    N3586 X44.228 Z-5.547
    N3587 X44.677 Z-4.839
    N3588 X45.35 Z-3.957
    N3589 X45.799 Z-3.462
    N3590 X46.248 Z-3.014
    N3591 X46.697 Z-2.618
    N3592 X47.146 Z-2.259
    N3593 X47.595 Z-1.938
    N3594 X48.493 Z-1.387
    N3595 X49.391 Z-.943
    N3596 X50.289 Z-.594
    N3597 X51.187 Z-.33
    N3598 X52.085 Z-.145
    N3599 X52.984 Z-.036
    N3600 X53.882 Z0.
    N3601 Y83.375
    N3602 X52.984 Z-.036
    N3603 X52.085 Z-.145
    N3604 X51.187 Z-.33
    N3605 X50.289 Z-.594
    N3606 X49.391 Z-.943
    N3607 X48.493 Z-1.386
    N3608 X47.595 Z-1.938
    N3609 X47.146 Z-2.259
    N3610 X46.697 Z-2.618
    N3611 X46.248 Z-3.014
    N3612 X45.799 Z-3.462
    N3613 X45.35 Z-3.957
    N3614 X44.677 Z-4.839
    N3615 X44.228 Z-5.547
    N3616 X43.779 Z-6.405
    N3617 X43.554 Z-6.908
    N3618 X43.217 Z-7.837
    N3619 X43.003 Z-8.618
    N3620 X42.798 Z-9.749
    N3621 X42.44 Z-13.52
    N3622 X42.184 Z-15.229
    N3623 X41.571 Z-18.178
    N3624 X40.979 Z-20.339
    N3625 X40.491 Z-21.866
    N3626 X39.758 Z-23.846
    N3627 X39.033 Z-25.551
    N3628 X38.554 Z-26.583
    N3629 X38.074 Z-27.548
    N3630 X37.115 Z-29.312
    N3631 X36.156 Z-30.898
    N3632 X35.676 Z-31.638
    N3633 X34.839 Z-32.859
    N3634 X34.002 Z-33.989
    N3635 X33.166 Z-35.047
    N3636 X32.329 Z-36.043
    N3637 X31.408 Z-37.073
    N3638 X30.487 Z-38.035
    N3639 X29.566 Z-38.941
    N3640 X28.645 Z-39.796
    N3641 X27.77 Z-40.565
    N3642 X26.895 Z-41.292
    N3643 X26.02 Z-41.981
    N3644 X25.145 Z-42.634
    N3645 X24.233 Z-43.278
    N3646 X23.321 Z-43.886
    N3647 X22.41 Z-44.462
    N3648 X20.614 Z-45.507
    N3649 X18.845 Z-46.427
    N3650 X17.961 Z-46.848
    N3651 X16.151 Z-47.634
    N3652 X14.342 Z-48.323
    N3653 X12.559 Z-48.913
    N3654 X10.776 Z-49.418
    N3655 X8.958 Z-49.849
    N3656 X7.169 Z-50.192
    N3657 X5.362 Z-50.46
    N3658 X3.592 Z-50.648
    N3659 X1.797 Z-50.761
    N3660 X0. Z-50.8
    N3661 X-1.797 Z-50.761
    N3662 X-3.592 Z-50.648
    N3663 X-5.362 Z-50.46
    N3664 X-7.169 Z-50.192
    N3665 X-8.958 Z-49.849
    N3666 X-10.776 Z-49.418
    N3667 X-12.559 Z-48.913
    N3668 X-14.342 Z-48.323
    N3669 X-16.151 Z-47.634
    N3670 X-17.961 Z-46.848
    N3671 X-19.729 Z-45.98
    N3672 X-21.498 Z-45.007
    N3673 X-22.41 Z-44.462
    N3674 X-23.321 Z-43.886
    N3675 X-24.233 Z-43.278
    N3676 X-25.145 Z-42.634
    N3677 X-26.02 Z-41.981
    N3678 X-26.895 Z-41.292
    N3679 X-27.77 Z-40.565
    N3680 X-28.645 Z-39.796
    N3681 X-29.566 Z-38.941
    N3682 X-30.487 Z-38.035
    N3683 X-31.408 Z-37.073
    N3684 X-32.329 Z-36.043
    N3685 X-33.166 Z-35.047
    N3686 X-34.002 Z-33.989
    N3687 X-34.839 Z-32.859
    N3688 X-35.676 Z-31.638
    N3689 X-36.635 Z-30.125
    N3690 X-37.595 Z-28.455
    N3691 X-38.074 Z-27.548
    N3692 X-38.554 Z-26.583
    N3693 X-39.033 Z-25.551
    N3694 X-39.758 Z-23.846
    N3695 X-40.491 Z-21.866
    N3696 X-41.346 Z-19.058
    N3697 X-41.98 Z-16.328
    N3698 X-42.491 Z-13.111
    N3699 X-42.798 Z-9.749
    N3700 X-42.901 Z-9.109
    N3701 X-43.105 Z-8.221
    N3702 X-43.33 Z-7.496
    N3703 X-43.554 Z-6.908
    N3704 X-44.003 Z-5.953
    N3705 X-44.452 Z-5.183
    N3706 X-44.901 Z-4.527
    N3707 X-45.35 Z-3.957
    N3708 X-45.799 Z-3.462
    N3709 X-46.248 Z-3.014
    N3710 X-46.697 Z-2.618
    N3711 X-47.146 Z-2.259
    N3712 X-47.595 Z-1.937
    N3713 X-48.493 Z-1.386
    N3714 X-49.391 Z-.943
    N3715 X-50.289 Z-.594
    N3716 X-51.187 Z-.33
    N3717 X-52.085 Z-.145
    N3718 X-52.984 Z-.036
    N3719 X-53.882 Z0.
    N3720 Y82.175
    N3721 X-52.984 Z-.036
    N3722 X-52.085 Z-.145
    N3723 X-51.187 Z-.33
    N3724 X-50.289 Z-.594
    N3725 X-49.391 Z-.943
    N3726 X-48.493 Z-1.386
    N3727 X-47.595 Z-1.937
    N3728 X-47.146 Z-2.259
    N3729 X-46.697 Z-2.618
    N3730 X-46.248 Z-3.014
    N3731 X-45.799 Z-3.462
    N3732 X-45.35 Z-3.957
    N3733 X-44.901 Z-4.527
    N3734 X-44.452 Z-5.183
    N3735 X-44.003 Z-5.953
    N3736 X-43.554 Z-6.908
    N3737 X-43.33 Z-7.496
    N3738 X-43.105 Z-8.221
    N3739 X-42.901 Z-9.109
    N3740 X-42.798 Z-9.748
    N3741 X-42.491 Z-13.111
    N3742 X-41.98 Z-16.328
    N3743 X-41.346 Z-19.058
    N3744 X-40.491 Z-21.866
    N3745 X-39.758 Z-23.846
    N3746 X-39.033 Z-25.551
    N3747 X-38.554 Z-26.583
    N3748 X-38.074 Z-27.548
    N3749 X-37.595 Z-28.455
    N3750 X-36.635 Z-30.125
    N3751 X-35.676 Z-31.638
    N3752 X-34.839 Z-32.859
    N3753 X-34.002 Z-33.989
    N3754 X-33.166 Z-35.047
    N3755 X-32.329 Z-36.043
    N3756 X-31.408 Z-37.073
    N3757 X-30.487 Z-38.035
    N3758 X-29.566 Z-38.941
    N3759 X-28.645 Z-39.796
    N3760 X-27.77 Z-40.565
    N3761 X-26.895 Z-41.292
    N3762 X-26.02 Z-41.981
    N3763 X-25.145 Z-42.634
    N3764 X-24.233 Z-43.278
    N3765 X-23.321 Z-43.886
    N3766 X-22.41 Z-44.462
    N3767 X-21.498 Z-45.007
    N3768 X-19.729 Z-45.98
    N3769 X-17.961 Z-46.848
    N3770 X-16.151 Z-47.634
    N3771 X-14.342 Z-48.323
    N3772 X-12.559 Z-48.913
    N3773 X-10.776 Z-49.418
    N3774 X-8.958 Z-49.849
    N3775 X-7.169 Z-50.192
    N3776 X-5.362 Z-50.46
    N3777 X-3.592 Z-50.648
    N3778 X-1.797 Z-50.761
    N3779 X0. Z-50.8
    N3780 X1.797 Z-50.761
    N3781 X3.592 Z-50.648
    N3782 X5.362 Z-50.46
    N3783 X7.169 Z-50.192
    N3784 X8.958 Z-49.849
    N3785 X10.776 Z-49.418
    N3786 X12.559 Z-48.913
    N3787 X14.342 Z-48.323
    N3788 X16.151 Z-47.634
    N3789 X17.961 Z-46.848
    N3790 X18.845 Z-46.427
    N3791 X20.614 Z-45.507
    N3792 X22.41 Z-44.462
    N3793 X23.321 Z-43.886
    N3794 X24.233 Z-43.278
    N3795 X25.145 Z-42.634
    N3796 X26.02 Z-41.981
    N3797 X26.895 Z-41.292
    N3798 X27.77 Z-40.565
    N3799 X28.645 Z-39.796
    N3800 X29.566 Z-38.941
    N3801 X30.487 Z-38.035
    N3802 X31.408 Z-37.073
    N3803 X32.329 Z-36.043
    N3804 X33.166 Z-35.047
    N3805 X34.002 Z-33.989
    N3806 X34.839 Z-32.859
    N3807 X35.676 Z-31.638
    N3808 X36.156 Z-30.898
    N3809 X37.115 Z-29.312
    N3810 X38.074 Z-27.548
    N3811 X38.554 Z-26.583
    N3812 X39.033 Z-25.551
    N3813 X39.758 Z-23.846
    N3814 X40.491 Z-21.866
    N3815 X40.979 Z-20.339
    N3816 X41.571 Z-18.178
    N3817 X42.184 Z-15.229
    N3818 X42.44 Z-13.52
    N3819 X42.798 Z-9.748
    N3820 X43.003 Z-8.618
    N3821 X43.217 Z-7.837
    N3822 X43.554 Z-6.908
    N3823 X43.779 Z-6.405
    N3824 X44.228 Z-5.547
    N3825 X44.677 Z-4.839
    N3826 X45.35 Z-3.957
    N3827 X45.799 Z-3.462
    N3828 X46.248 Z-3.014
    N3829 X46.697 Z-2.618
    N3830 X47.146 Z-2.259
    N3831 X47.595 Z-1.937
    N3832 X48.493 Z-1.386
    N3833 X49.391 Z-.943
    N3834 X50.289 Z-.594
    N3835 X51.187 Z-.33
    N3836 X52.085 Z-.145
    N3837 X52.984 Z-.036
    N3838 X53.882 Z0.
    N3839 Y80.975
    N3840 X52.984 Z-.036
    N3841 X52.085 Z-.145
    N3842 X51.187 Z-.33
    N3843 X50.289 Z-.594
    N3844 X49.391 Z-.943
    N3845 X48.493 Z-1.386
    N3846 X47.595 Z-1.937
    N3847 X47.146 Z-2.259
    N3848 X46.697 Z-2.618
    N3849 X46.248 Z-3.014
    N3850 X45.799 Z-3.462
    N3851 X45.35 Z-3.957
    N3852 X44.677 Z-4.839
    N3853 X44.228 Z-5.548
    N3854 X43.779 Z-6.405
    N3855 X43.554 Z-6.908
    N3856 X43.217 Z-7.837
    N3857 X43.003 Z-8.618
    N3858 X42.798 Z-9.748
    N3859 X42.44 Z-13.52
    N3860 X42.184 Z-15.229
    N3861 X41.571 Z-18.178
    N3862 X40.979 Z-20.339
    N3863 X40.491 Z-21.866
    N3864 X39.758 Z-23.846
    N3865 X39.033 Z-25.551
    N3866 X38.554 Z-26.583
    N3867 X38.074 Z-27.548
    N3868 X37.115 Z-29.312
    N3869 X36.156 Z-30.898
    N3870 X35.676 Z-31.638
    N3871 X34.839 Z-32.859
    N3872 X34.002 Z-33.989
    N3873 X33.166 Z-35.047
    N3874 X32.329 Z-36.043
    N3875 X31.408 Z-37.073
    N3876 X30.487 Z-38.035
    N3877 X29.566 Z-38.941
    N3878 X28.645 Z-39.796
    N3879 X27.77 Z-40.565
    N3880 X26.895 Z-41.292
    N3881 X26.02 Z-41.981
    N3882 X25.145 Z-42.634
    N3883 X24.233 Z-43.278
    N3884 X23.321 Z-43.886
    N3885 X22.41 Z-44.462
    N3886 X20.614 Z-45.507
    N3887 X18.845 Z-46.427
    N3888 X17.961 Z-46.848
    N3889 X16.151 Z-47.634
    N3890 X14.342 Z-48.323
    N3891 X12.559 Z-48.913
    N3892 X10.776 Z-49.418
    N3893 X8.958 Z-49.849
    N3894 X7.169 Z-50.192
    N3895 X5.362 Z-50.46
    N3896 X3.592 Z-50.648
    N3897 X1.797 Z-50.761
    N3898 X0. Z-50.8
    N3899 X-1.797 Z-50.761
    N3900 X-3.592 Z-50.648
    N3901 X-5.362 Z-50.46
    N3902 X-7.169 Z-50.192
    N3903 X-8.958 Z-49.849
    N3904 X-10.776 Z-49.418
    N3905 X-12.559 Z-48.913
    N3906 X-14.342 Z-48.323
    N3907 X-16.151 Z-47.634
    N3908 X-17.961 Z-46.848
    N3909 X-19.729 Z-45.98
    N3910 X-21.498 Z-45.007
    N3911 X-22.41 Z-44.462
    N3912 X-23.321 Z-43.886
    N3913 X-24.233 Z-43.278
    N3914 X-25.145 Z-42.634
    N3915 X-26.02 Z-41.981
    N3916 X-26.895 Z-41.292
    N3917 X-27.77 Z-40.565
    N3918 X-28.645 Z-39.796
    N3919 X-29.566 Z-38.941
    N3920 X-30.487 Z-38.035
    N3921 X-31.408 Z-37.073
    N3922 X-32.329 Z-36.043
    N3923 X-33.166 Z-35.047
    N3924 X-34.002 Z-33.989
    N3925 X-34.839 Z-32.859
    N3926 X-35.676 Z-31.638
    N3927 X-36.635 Z-30.125
    N3928 X-37.595 Z-28.455
    N3929 X-38.074 Z-27.548
    N3930 X-38.554 Z-26.583
    N3931 X-39.033 Z-25.551
    N3932 X-39.758 Z-23.846
    N3933 X-40.491 Z-21.866
    N3934 X-41.346 Z-19.058
    N3935 X-41.98 Z-16.328
    N3936 X-42.491 Z-13.111
    N3937 X-42.798 Z-9.748
    N3938 X-42.901 Z-9.109
    N3939 X-43.105 Z-8.22
    N3940 X-43.33 Z-7.496
    N3941 X-43.554 Z-6.908
    N3942 X-44.003 Z-5.953
    N3943 X-44.452 Z-5.183
    N3944 X-44.901 Z-4.527
    N3945 X-45.35 Z-3.957
    N3946 X-45.799 Z-3.462
    N3947 X-46.248 Z-3.014
    N3948 X-46.697 Z-2.618
    N3949 X-47.146 Z-2.259
    N3950 X-47.595 Z-1.937
    N3951 X-48.493 Z-1.386
    N3952 X-49.391 Z-.943
    N3953 X-50.289 Z-.594
    N3954 X-51.187 Z-.33
    N3955 X-52.085 Z-.145
    N3956 X-52.984 Z-.036
    N3957 X-53.882 Z0.
    N3958 Y79.775
    N3959 X-52.984 Z-.036
    N3960 X-52.085 Z-.145
    N3961 X-51.187 Z-.33
    N3962 X-50.289 Z-.594
    N3963 X-49.391 Z-.943
    N3964 X-48.493 Z-1.386
    N3965 X-47.595 Z-1.937
    N3966 X-47.146 Z-2.259
    N3967 X-46.697 Z-2.618
    N3968 X-46.248 Z-3.014
    N3969 X-45.799 Z-3.462
    N3970 X-45.35 Z-3.957
    N3971 X-44.901 Z-4.527
    N3972 X-44.452 Z-5.183
    N3973 X-44.003 Z-5.953
    N3974 X-43.554 Z-6.908
    N3975 X-43.33 Z-7.496
    N3976 X-43.105 Z-8.22
    N3977 X-42.901 Z-9.109
    N3978 X-42.798 Z-9.748
    N3979 X-42.491 Z-13.111
    N3980 X-41.98 Z-16.328
    N3981 X-41.346 Z-19.058
    N3982 X-40.491 Z-21.866
    N3983 X-39.758 Z-23.846
    N3984 X-39.033 Z-25.551
    N3985 X-38.554 Z-26.583
    N3986 X-38.074 Z-27.548
    N3987 X-37.595 Z-28.455
    N3988 X-36.635 Z-30.125
    N3989 X-35.676 Z-31.638
    N3990 X-34.839 Z-32.859
    N3991 X-34.002 Z-33.989
    N3992 X-33.166 Z-35.047
    N3993 X-32.329 Z-36.043
    N3994 X-31.408 Z-37.073
    N3995 X-30.487 Z-38.035
    N3996 X-29.566 Z-38.941
    N3997 X-28.645 Z-39.796
    N3998 X-27.77 Z-40.565
    N3999 X-26.895 Z-41.292
    N4000 X-26.02 Z-41.981
    N4001 X-25.145 Z-42.634
    N4002 X-24.233 Z-43.278
    N4003 X-23.321 Z-43.886
    N4004 X-22.41 Z-44.462
    N4005 X-21.498 Z-45.007
    N4006 X-19.729 Z-45.98
    N4007 X-17.961 Z-46.848
    N4008 X-16.151 Z-47.634
    N4009 X-14.342 Z-48.323
    N4010 X-12.559 Z-48.913
    N4011 X-10.776 Z-49.418
    N4012 X-8.958 Z-49.849
    N4013 X-7.169 Z-50.192
    N4014 X-5.362 Z-50.46
    N4015 X-3.592 Z-50.648
    N4016 X-1.797 Z-50.761
    N4017 X0. Z-50.8
    N4018 X1.797 Z-50.761
    N4019 X3.592 Z-50.648
    N4020 X5.362 Z-50.46
    N4021 X7.169 Z-50.192
    N4022 X8.958 Z-49.849
    N4023 X10.776 Z-49.418
    N4024 X12.559 Z-48.913
    N4025 X14.342 Z-48.323
    N4026 X16.151 Z-47.634
    N4027 X17.961 Z-46.848
    N4028 X18.845 Z-46.427
    N4029 X20.614 Z-45.507
    N4030 X22.41 Z-44.462
    N4031 X23.321 Z-43.886
    N4032 X24.233 Z-43.278
    N4033 X25.145 Z-42.634
    N4034 X26.02 Z-41.981
    N4035 X26.895 Z-41.292
    N4036 X27.77 Z-40.565
    N4037 X28.645 Z-39.796
    N4038 X29.566 Z-38.941
    N4039 X30.487 Z-38.035
    N4040 X31.408 Z-37.073
    N4041 X32.329 Z-36.043
    N4042 X33.166 Z-35.047
    N4043 X34.002 Z-33.989
    N4044 X34.839 Z-32.859
    N4045 X35.676 Z-31.638
    N4046 X36.156 Z-30.898
    N4047 X37.115 Z-29.312
    N4048 X38.074 Z-27.548
    N4049 X38.554 Z-26.583
    N4050 X39.033 Z-25.551
    N4051 X39.758 Z-23.846
    N4052 X40.491 Z-21.866
    N4053 X40.979 Z-20.339
    N4054 X41.571 Z-18.178
    N4055 X42.184 Z-15.229
    N4056 X42.44 Z-13.52
    N4057 X42.798 Z-9.748
    N4058 X43.003 Z-8.618
    N4059 X43.217 Z-7.837
    N4060 X43.554 Z-6.908
    N4061 X43.779 Z-6.405
    N4062 X44.228 Z-5.548
    N4063 X44.677 Z-4.839
    N4064 X45.35 Z-3.957
    N4065 X45.799 Z-3.462
    N4066 X46.248 Z-3.014
    N4067 X46.697 Z-2.618
    N4068 X47.146 Z-2.259
    N4069 X47.595 Z-1.937
    N4070 X48.493 Z-1.386
    N4071 X49.391 Z-.943
    N4072 X50.289 Z-.594
    N4073 X51.187 Z-.33
    N4074 X52.085 Z-.145
    N4075 X52.984 Z-.036
    N4076 X53.882 Z0.
    N4077 Y78.575
    N4078 X52.984 Z-.036
    N4079 X52.085 Z-.145
    N4080 X51.187 Z-.33
    N4081 X50.289 Z-.594
    N4082 X49.391 Z-.943
    N4083 X48.493 Z-1.386
    N4084 X47.595 Z-1.937
    N4085 X47.146 Z-2.259
    N4086 X46.697 Z-2.618
    N4087 X46.248 Z-3.014
    N4088 X45.799 Z-3.462
    N4089 X45.35 Z-3.957
    N4090 X44.677 Z-4.839
    N4091 X44.228 Z-5.548
    N4092 X43.779 Z-6.405
    N4093 X43.554 Z-6.908
    N4094 X43.217 Z-7.837
    N4095 X43.003 Z-8.618
    N4096 X42.798 Z-9.748
    N4097 X42.44 Z-13.52
    N4098 X42.184 Z-15.229
    N4099 X41.571 Z-18.178
    N4100 X40.979 Z-20.339
    N4101 X40.491 Z-21.866
    N4102 X39.758 Z-23.846
    N4103 X39.033 Z-25.551
    N4104 X38.554 Z-26.583
    N4105 X38.074 Z-27.548
    N4106 X37.115 Z-29.312
    N4107 X36.156 Z-30.898
    N4108 X35.676 Z-31.638
    N4109 X34.839 Z-32.859
    N4110 X34.002 Z-33.989
    N4111 X33.166 Z-35.047
    N4112 X32.329 Z-36.043
    N4113 X31.408 Z-37.073
    N4114 X30.487 Z-38.035
    N4115 X29.566 Z-38.941
    N4116 X28.645 Z-39.796
    N4117 X27.77 Z-40.565
    N4118 X26.895 Z-41.292
    N4119 X26.02 Z-41.981
    N4120 X25.145 Z-42.634
    N4121 X24.233 Z-43.278
    N4122 X23.321 Z-43.886
    N4123 X22.41 Z-44.462
    N4124 X20.614 Z-45.507
    N4125 X18.845 Z-46.427
    N4126 X17.961 Z-46.848
    N4127 X16.151 Z-47.634
    N4128 X14.342 Z-48.323
    N4129 X12.559 Z-48.913
    N4130 X10.776 Z-49.418
    N4131 X8.958 Z-49.849
    N4132 X7.169 Z-50.192
    N4133 X5.362 Z-50.46
    N4134 X3.592 Z-50.648
    N4135 X1.797 Z-50.761
    N4136 X0. Z-50.8
    N4137 X-1.797 Z-50.761
    N4138 X-3.592 Z-50.648
    N4139 X-5.362 Z-50.46
    N4140 X-7.169 Z-50.192
    N4141 X-8.958 Z-49.849
    N4142 X-10.776 Z-49.418
    N4143 X-12.559 Z-48.913
    N4144 X-14.342 Z-48.323
    N4145 X-16.151 Z-47.634
    N4146 X-17.961 Z-46.848
    N4147 X-19.729 Z-45.98
    N4148 X-21.498 Z-45.007
    N4149 X-22.41 Z-44.462
    N4150 X-23.321 Z-43.886
    N4151 X-24.233 Z-43.278
    N4152 X-25.145 Z-42.634
    N4153 X-26.02 Z-41.981
    N4154 X-26.895 Z-41.292
    N4155 X-27.77 Z-40.565
    N4156 X-28.645 Z-39.796
    N4157 X-29.566 Z-38.941
    N4158 X-30.487 Z-38.035
    N4159 X-31.408 Z-37.073
    N4160 X-32.329 Z-36.043
    N4161 X-33.166 Z-35.047
    N4162 X-34.002 Z-33.989
    N4163 X-34.839 Z-32.859
    N4164 X-35.676 Z-31.638
    N4165 X-36.635 Z-30.125
    N4166 X-37.595 Z-28.455
    N4167 X-38.074 Z-27.548
    N4168 X-38.554 Z-26.583
    N4169 X-39.033 Z-25.551
    N4170 X-39.758 Z-23.846
    N4171 X-40.491 Z-21.866
    N4172 X-41.346 Z-19.058
    N4173 X-41.98 Z-16.328
    N4174 X-42.491 Z-13.111
    N4175 X-42.798 Z-9.748
    N4176 X-42.901 Z-9.108
    N4177 X-43.105 Z-8.22
    N4178 X-43.33 Z-7.496
    N4179 X-43.554 Z-6.908
    N4180 X-44.003 Z-5.953
    N4181 X-44.452 Z-5.183
    N4182 X-44.901 Z-4.527
    N4183 X-45.35 Z-3.957
    N4184 X-45.799 Z-3.462
    N4185 X-46.248 Z-3.014
    N4186 X-46.697 Z-2.618
    N4187 X-47.146 Z-2.259
    N4188 X-47.595 Z-1.937
    N4189 X-48.493 Z-1.386
    N4190 X-49.391 Z-.943
    N4191 X-50.289 Z-.594
    N4192 X-51.187 Z-.33
    N4193 X-52.085 Z-.145
    N4194 X-52.984 Z-.036
    N4195 X-53.882 Z0.
    N4196 Y77.375
    N4197 X-52.984 Z-.036
    N4198 X-52.085 Z-.145
    N4199 X-51.187 Z-.33
    N4200 X-50.289 Z-.594
    N4201 X-49.391 Z-.943
    N4202 X-48.493 Z-1.386
    N4203 X-47.595 Z-1.937
    N4204 X-47.146 Z-2.259
    N4205 X-46.697 Z-2.618
    N4206 X-46.248 Z-3.014
    N4207 X-45.799 Z-3.462
    N4208 X-45.35 Z-3.957
    N4209 X-44.901 Z-4.527
    N4210 X-44.452 Z-5.183
    N4211 X-44.003 Z-5.953
    N4212 X-43.554 Z-6.907
    N4213 X-43.33 Z-7.496
    N4214 X-43.105 Z-8.22
    N4215 X-42.901 Z-9.108
    N4216 X-42.798 Z-9.748
    N4217 X-42.491 Z-13.111
    N4218 X-41.98 Z-16.328
    N4219 X-41.346 Z-19.058
    N4220 X-40.491 Z-21.866
    N4221 X-39.758 Z-23.846
    N4222 X-39.033 Z-25.551
    N4223 X-38.554 Z-26.583
    N4224 X-38.074 Z-27.548
    N4225 X-37.595 Z-28.455
    N4226 X-36.635 Z-30.125
    N4227 X-35.676 Z-31.638
    N4228 X-34.839 Z-32.859
    N4229 X-34.002 Z-33.989
    N4230 X-33.166 Z-35.047
    N4231 X-32.329 Z-36.043
    N4232 X-31.408 Z-37.073
    N4233 X-30.487 Z-38.035
    N4234 X-29.566 Z-38.941
    N4235 X-28.645 Z-39.796
    N4236 X-27.77 Z-40.565
    N4237 X-26.895 Z-41.292
    N4238 X-26.02 Z-41.981
    N4239 X-25.145 Z-42.634
    N4240 X-24.233 Z-43.278
    N4241 X-23.321 Z-43.886
    N4242 X-22.41 Z-44.462
    N4243 X-21.498 Z-45.007
    N4244 X-19.729 Z-45.98
    N4245 X-17.961 Z-46.848
    N4246 X-16.151 Z-47.634
    N4247 X-14.342 Z-48.323
    N4248 X-12.559 Z-48.913
    N4249 X-10.776 Z-49.418
    N4250 X-8.958 Z-49.849
    N4251 X-7.169 Z-50.192
    N4252 X-5.362 Z-50.46
    N4253 X-3.592 Z-50.648
    N4254 X-1.797 Z-50.761
    N4255 X0. Z-50.8
    N4256 X1.797 Z-50.761
    N4257 X3.592 Z-50.648
    N4258 X5.362 Z-50.46
    N4259 X7.169 Z-50.192
    N4260 X8.958 Z-49.849
    N4261 X10.776 Z-49.418
    N4262 X12.559 Z-48.913
    N4263 X14.342 Z-48.323
    N4264 X16.151 Z-47.634
    N4265 X17.961 Z-46.848
    N4266 X18.845 Z-46.427
    N4267 X20.614 Z-45.507
    N4268 X22.41 Z-44.462
    N4269 X23.321 Z-43.886
    N4270 X24.233 Z-43.278
    N4271 X25.145 Z-42.634
    N4272 X26.02 Z-41.981
    N4273 X26.895 Z-41.292
    N4274 X27.77 Z-40.565
    N4275 X28.645 Z-39.796
    N4276 X29.566 Z-38.941
    N4277 X30.487 Z-38.035
    N4278 X31.408 Z-37.073
    N4279 X32.329 Z-36.043
    N4280 X33.166 Z-35.047
    N4281 X34.002 Z-33.989
    N4282 X34.839 Z-32.859
    N4283 X35.676 Z-31.638
    N4284 X36.156 Z-30.898
    N4285 X37.115 Z-29.312
    N4286 X38.074 Z-27.548
    N4287 X38.554 Z-26.583
    N4288 X39.033 Z-25.551
    N4289 X39.758 Z-23.846
    N4290 X40.491 Z-21.866
    N4291 X40.979 Z-20.339
    N4292 X41.571 Z-18.178
    N4293 X42.184 Z-15.229
    N4294 X42.44 Z-13.52
    N4295 X42.798 Z-9.748
    N4296 X43.003 Z-8.618
    N4297 X43.217 Z-7.837
    N4298 X43.554 Z-6.907
    N4299 X43.779 Z-6.405
    N4300 X44.228 Z-5.548
    N4301 X44.677 Z-4.839
    N4302 X45.35 Z-3.957
    N4303 X45.799 Z-3.462
    N4304 X46.248 Z-3.014
    N4305 X46.697 Z-2.618
    N4306 X47.146 Z-2.259
    N4307 X47.595 Z-1.937
    N4308 X48.493 Z-1.386
    N4309 X49.391 Z-.943
    N4310 X50.289 Z-.594
    N4311 X51.187 Z-.33
    N4312 X52.085 Z-.145
    N4313 X52.984 Z-.036
    N4314 X53.882 Z0.
    N4315 Y76.175
    N4316 X52.984 Z-.036
    N4317 X52.085 Z-.145
    N4318 X51.187 Z-.33
    N4319 X50.289 Z-.594
    N4320 X49.391 Z-.943
    N4321 X48.493 Z-1.386
    N4322 X47.595 Z-1.937
    N4323 X47.146 Z-2.259
    N4324 X46.697 Z-2.618
    N4325 X46.248 Z-3.014
    N4326 X45.799 Z-3.462
    N4327 X45.35 Z-3.957
    N4328 X44.677 Z-4.839
    N4329 X44.228 Z-5.548
    N4330 X43.779 Z-6.405
    N4331 X43.554 Z-6.907
    N4332 X43.217 Z-7.837
    N4333 X43.003 Z-8.618
    N4334 X42.798 Z-9.748
    N4335 X42.44 Z-13.52
    N4336 X42.184 Z-15.229
    N4337 X41.571 Z-18.178
    N4338 X40.979 Z-20.339
    N4339 X40.491 Z-21.866
    N4340 X39.758 Z-23.846
    N4341 X39.033 Z-25.551
    N4342 X38.554 Z-26.583
    N4343 X38.074 Z-27.548
    N4344 X37.115 Z-29.312
    N4345 X36.156 Z-30.898
    N4346 X35.676 Z-31.638
    N4347 X34.839 Z-32.859
    N4348 X34.002 Z-33.989
    N4349 X33.166 Z-35.047
    N4350 X32.329 Z-36.043
    N4351 X31.408 Z-37.073
    N4352 X30.487 Z-38.035
    N4353 X29.566 Z-38.941
    N4354 X28.645 Z-39.796
    N4355 X27.77 Z-40.565
    N4356 X26.895 Z-41.292
    N4357 X26.02 Z-41.981
    N4358 X25.145 Z-42.634
    N4359 X24.233 Z-43.278
    N4360 X23.321 Z-43.886
    N4361 X22.41 Z-44.462
    N4362 X20.614 Z-45.507
    N4363 X18.845 Z-46.427
    N4364 X17.961 Z-46.848
    N4365 X16.151 Z-47.634
    N4366 X14.342 Z-48.323
    N4367 X12.559 Z-48.913
    N4368 X10.776 Z-49.418
    N4369 X8.958 Z-49.849
    N4370 X7.169 Z-50.192
    N4371 X5.362 Z-50.46
    N4372 X3.592 Z-50.648
    N4373 X1.797 Z-50.761
    N4374 X0. Z-50.8
    N4375 X-1.797 Z-50.761
    N4376 X-3.592 Z-50.648
    N4377 X-5.362 Z-50.46
    N4378 X-7.169 Z-50.192
    N4379 X-8.958 Z-49.849
    N4380 X-10.776 Z-49.418
    N4381 X-12.559 Z-48.913
    N4382 X-14.342 Z-48.323
    N4383 X-16.151 Z-47.634
    N4384 X-17.961 Z-46.848
    N4385 X-19.729 Z-45.98
    N4386 X-21.498 Z-45.007
    N4387 X-22.41 Z-44.462
    N4388 X-23.321 Z-43.886
    N4389 X-24.233 Z-43.278
    N4390 X-25.145 Z-42.634
    N4391 X-26.02 Z-41.981
    N4392 X-26.895 Z-41.292
    N4393 X-27.77 Z-40.565
    N4394 X-28.645 Z-39.796
    N4395 X-29.566 Z-38.941
    N4396 X-30.487 Z-38.035
    N4397 X-31.408 Z-37.073
    N4398 X-32.329 Z-36.043
    N4399 X-33.166 Z-35.047
    N4400 X-34.002 Z-33.989
    N4401 X-34.839 Z-32.859
    N4402 X-35.676 Z-31.638
    N4403 X-36.635 Z-30.125
    N4404 X-37.595 Z-28.455
    N4405 X-38.074 Z-27.548
    N4406 X-38.554 Z-26.583
    N4407 X-39.033 Z-25.551
    N4408 X-39.758 Z-23.846
    N4409 X-40.491 Z-21.866
    N4410 X-41.346 Z-19.058
    N4411 X-41.98 Z-16.328
    N4412 X-42.491 Z-13.111
    N4413 X-42.798 Z-9.748
    N4414 X-42.901 Z-9.108
    N4415 X-43.105 Z-8.22
    N4416 X-43.33 Z-7.496
    N4417 X-43.554 Z-6.907
    N4418 X-44.003 Z-5.953
    N4419 X-44.452 Z-5.183
    N4420 X-44.901 Z-4.527
    N4421 X-45.35 Z-3.957
    N4422 X-45.799 Z-3.462
    N4423 X-46.248 Z-3.014
    N4424 X-46.697 Z-2.618
    N4425 X-47.146 Z-2.259
    N4426 X-47.595 Z-1.937
    N4427 X-48.493 Z-1.386
    N4428 X-49.391 Z-.943
    N4429 X-50.289 Z-.594
    N4430 X-51.187 Z-.33
    N4431 X-52.085 Z-.145
    N4432 X-52.984 Z-.036
    N4433 X-53.882 Z0.
    N4434 Y74.975
    N4435 X-52.984 Z-.036
    N4436 X-52.085 Z-.145
    N4437 X-51.187 Z-.33
    N4438 X-50.289 Z-.594
    N4439 X-49.391 Z-.943
    N4440 X-48.493 Z-1.386
    N4441 X-47.595 Z-1.937
    N4442 X-47.146 Z-2.259
    N4443 X-46.697 Z-2.618
    N4444 X-46.248 Z-3.014
    N4445 X-45.799 Z-3.462
    N4446 X-45.35 Z-3.957
    N4447 X-44.901 Z-4.527
    N4448 X-44.452 Z-5.183
    N4449 X-44.003 Z-5.953
    N4450 X-43.554 Z-6.907
    N4451 X-43.33 Z-7.496
    N4452 X-43.105 Z-8.22
    N4453 X-42.901 Z-9.108
    N4454 X-42.798 Z-9.748
    N4455 X-42.491 Z-13.111
    N4456 X-41.98 Z-16.328
    N4457 X-41.346 Z-19.058
    N4458 X-40.491 Z-21.866
    N4459 X-39.758 Z-23.846
    N4460 X-39.033 Z-25.551
    N4461 X-38.554 Z-26.583
    N4462 X-38.074 Z-27.548
    N4463 X-37.595 Z-28.455
    N4464 X-36.635 Z-30.125
    N4465 X-35.676 Z-31.638
    N4466 X-34.839 Z-32.859
    N4467 X-34.002 Z-33.989
    N4468 X-33.166 Z-35.047
    N4469 X-32.329 Z-36.043
    N4470 X-31.408 Z-37.073
    N4471 X-30.487 Z-38.035
    N4472 X-29.566 Z-38.941
    N4473 X-28.645 Z-39.796
    N4474 X-27.77 Z-40.565
    N4475 X-26.895 Z-41.292
    N4476 X-26.02 Z-41.981
    N4477 X-25.145 Z-42.634
    N4478 X-24.233 Z-43.278
    N4479 X-23.321 Z-43.886
    N4480 X-22.41 Z-44.462
    N4481 X-21.498 Z-45.007
    N4482 X-19.729 Z-45.98
    N4483 X-17.961 Z-46.848
    N4484 X-16.151 Z-47.634
    N4485 X-14.342 Z-48.323
    N4486 X-12.559 Z-48.913
    N4487 X-10.776 Z-49.418
    N4488 X-8.958 Z-49.849
    N4489 X-7.169 Z-50.192
    N4490 X-5.362 Z-50.46
    N4491 X-3.592 Z-50.648
    N4492 X-1.797 Z-50.761
    N4493 X0. Z-50.8
    N4494 X1.797 Z-50.761
    N4495 X3.592 Z-50.648
    N4496 X5.362 Z-50.46
    N4497 X7.169 Z-50.192
    N4498 X8.958 Z-49.849
    N4499 X10.776 Z-49.418
    N4500 X12.559 Z-48.913
    N4501 X14.342 Z-48.323
    N4502 X16.151 Z-47.634
    N4503 X17.961 Z-46.848
    N4504 X18.845 Z-46.427
    N4505 X20.614 Z-45.507
    N4506 X22.41 Z-44.462
    N4507 X23.321 Z-43.886
    N4508 X24.233 Z-43.278
    N4509 X25.145 Z-42.634
    N4510 X26.02 Z-41.981
    N4511 X26.895 Z-41.292
    N4512 X27.77 Z-40.565
    N4513 X28.645 Z-39.796
    N4514 X29.566 Z-38.941
    N4515 X30.487 Z-38.035
    N4516 X31.408 Z-37.073
    N4517 X32.329 Z-36.043
    N4518 X33.166 Z-35.047
    N4519 X34.002 Z-33.989
    N4520 X34.839 Z-32.859
    N4521 X35.676 Z-31.638
    N4522 X36.156 Z-30.898
    N4523 X37.115 Z-29.312
    N4524 X38.074 Z-27.548
    N4525 X38.554 Z-26.583
    N4526 X39.033 Z-25.551
    N4527 X39.758 Z-23.846
    N4528 X40.491 Z-21.866
    N4529 X40.979 Z-20.339
    N4530 X41.571 Z-18.178
    N4531 X42.184 Z-15.229
    N4532 X42.44 Z-13.52
    N4533 X42.798 Z-9.748
    N4534 X43.003 Z-8.618
    N4535 X43.217 Z-7.836
    N4536 X43.554 Z-6.907
    N4537 X43.779 Z-6.405
    N4538 X44.228 Z-5.548
    N4539 X44.677 Z-4.839
    N4540 X45.35 Z-3.957
    N4541 X45.799 Z-3.462
    N4542 X46.248 Z-3.014
    N4543 X46.697 Z-2.618
    N4544 X47.146 Z-2.259
    N4545 X47.595 Z-1.937
    N4546 X48.493 Z-1.386
    N4547 X49.391 Z-.943
    N4548 X50.289 Z-.594
    N4549 X51.187 Z-.33
    N4550 X52.085 Z-.145
    N4551 X52.984 Z-.036
    N4552 X53.882 Z0.
    N4553 Y73.775
    N4554 X52.984 Z-.036
    N4555 X52.085 Z-.145
    N4556 X51.187 Z-.33
    N4557 X50.289 Z-.594
    N4558 X49.391 Z-.943
    N4559 X48.493 Z-1.386
    N4560 X47.595 Z-1.937
    N4561 X47.146 Z-2.259
    N4562 X46.697 Z-2.618
    N4563 X46.248 Z-3.014
    N4564 X45.799 Z-3.462
    N4565 X45.35 Z-3.957
    N4566 X44.677 Z-4.839
    N4567 X44.228 Z-5.548
    N4568 X43.779 Z-6.405
    N4569 X43.554 Z-6.907
    N4570 X43.217 Z-7.836
    N4571 X43.003 Z-8.618
    N4572 X42.798 Z-9.748
    N4573 X42.44 Z-13.52
    N4574 X42.184 Z-15.229
    N4575 X41.571 Z-18.178
    N4576 X40.979 Z-20.339
    N4577 X40.491 Z-21.866
    N4578 X39.758 Z-23.846
    N4579 X39.033 Z-25.551
    N4580 X38.554 Z-26.583
    N4581 X38.074 Z-27.548
    N4582 X37.115 Z-29.312
    N4583 X36.156 Z-30.898
    N4584 X35.676 Z-31.638
    N4585 X34.839 Z-32.859
    N4586 X34.002 Z-33.989
    N4587 X33.166 Z-35.047
    N4588 X32.329 Z-36.043
    N4589 X31.408 Z-37.073
    N4590 X30.487 Z-38.035
    N4591 X29.566 Z-38.941
    N4592 X28.645 Z-39.796
    N4593 X27.77 Z-40.565
    N4594 X26.895 Z-41.292
    N4595 X26.02 Z-41.981
    N4596 X25.145 Z-42.634
    N4597 X24.233 Z-43.278
    N4598 X23.321 Z-43.886
    N4599 X22.41 Z-44.462
    N4600 X20.614 Z-45.507
    N4601 X18.845 Z-46.427
    N4602 X17.961 Z-46.848
    N4603 X16.151 Z-47.634
    N4604 X14.342 Z-48.323
    N4605 X12.559 Z-48.913
    N4606 X10.776 Z-49.418
    N4607 X8.958 Z-49.849
    N4608 X7.169 Z-50.192
    N4609 X5.362 Z-50.46
    N4610 X3.592 Z-50.648
    N4611 X1.797 Z-50.761
    N4612 X0. Z-50.8
    N4613 X-1.797 Z-50.761
    N4614 X-3.592 Z-50.648
    N4615 X-5.362 Z-50.46
    N4616 X-7.169 Z-50.192
    N4617 X-8.958 Z-49.849
    N4618 X-10.776 Z-49.418
    N4619 X-12.559 Z-48.913
    N4620 X-14.342 Z-48.323
    N4621 X-16.151 Z-47.634
    N4622 X-17.961 Z-46.848
    N4623 X-19.729 Z-45.98
    N4624 X-21.498 Z-45.007
    N4625 X-22.41 Z-44.462
    N4626 X-23.321 Z-43.886
    N4627 X-24.233 Z-43.278
    N4628 X-25.145 Z-42.634
    N4629 X-26.02 Z-41.981
    N4630 X-26.895 Z-41.292
    N4631 X-27.77 Z-40.565
    N4632 X-28.645 Z-39.796
    N4633 X-29.566 Z-38.941
    N4634 X-30.487 Z-38.035
    N4635 X-31.408 Z-37.073
    N4636 X-32.329 Z-36.043
    N4637 X-33.166 Z-35.047
    N4638 X-34.002 Z-33.989
    N4639 X-34.839 Z-32.859
    N4640 X-35.676 Z-31.638
    N4641 X-36.635 Z-30.125
    N4642 X-37.595 Z-28.455
    N4643 X-38.074 Z-27.548
    N4644 X-38.554 Z-26.583
    N4645 X-39.033 Z-25.551
    N4646 X-39.758 Z-23.846
    N4647 X-40.491 Z-21.866
    N4648 X-41.346 Z-19.058
    N4649 X-41.98 Z-16.328
    N4650 X-42.491 Z-13.111
    N4651 X-42.798 Z-9.748
    N4652 X-42.901 Z-9.108
    N4653 X-43.105 Z-8.22
    N4654 X-43.33 Z-7.496
    N4655 X-43.554 Z-6.907
    N4656 X-44.003 Z-5.953
    N4657 X-44.452 Z-5.183
    N4658 X-44.901 Z-4.527
    N4659 X-45.35 Z-3.957
    N4660 X-45.799 Z-3.462
    N4661 X-46.248 Z-3.014
    N4662 X-46.697 Z-2.618
    N4663 X-47.146 Z-2.259
    N4664 X-47.595 Z-1.937
    N4665 X-48.493 Z-1.386
    N4666 X-49.391 Z-.943
    N4667 X-50.289 Z-.594
    N4668 X-51.187 Z-.33
    N4669 X-52.085 Z-.145
    N4670 X-52.984 Z-.036
    N4671 X-53.882 Z0.
    N4672 Y72.575
    N4673 X-52.984 Z-.036
    N4674 X-52.085 Z-.145
    N4675 X-51.187 Z-.33
    N4676 X-50.289 Z-.594
    N4677 X-49.391 Z-.943
    N4678 X-48.493 Z-1.386
    N4679 X-47.595 Z-1.937
    N4680 X-47.146 Z-2.259
    N4681 X-46.697 Z-2.618
    N4682 X-46.248 Z-3.014
    N4683 X-45.799 Z-3.462
    N4684 X-45.35 Z-3.957
    N4685 X-44.901 Z-4.527
    N4686 X-44.452 Z-5.183
    N4687 X-44.003 Z-5.953
    N4688 X-43.554 Z-6.907
    N4689 X-43.33 Z-7.496
    N4690 X-43.105 Z-8.22
    N4691 X-42.901 Z-9.107
    N4692 X-42.798 Z-9.748
    N4693 X-42.491 Z-13.111
    N4694 X-41.98 Z-16.328
    N4695 X-41.346 Z-19.058
    N4696 X-40.491 Z-21.866
    N4697 X-39.758 Z-23.846
    N4698 X-39.033 Z-25.551
    N4699 X-38.554 Z-26.583
    N4700 X-38.074 Z-27.548
    N4701 X-37.595 Z-28.455
    N4702 X-36.635 Z-30.125
    N4703 X-35.676 Z-31.638
    N4704 X-34.839 Z-32.859
    N4705 X-34.002 Z-33.989
    N4706 X-33.166 Z-35.047
    N4707 X-32.329 Z-36.043
    N4708 X-31.408 Z-37.073
    N4709 X-30.487 Z-38.035
    N4710 X-29.566 Z-38.941
    N4711 X-28.645 Z-39.796
    N4712 X-27.77 Z-40.565
    N4713 X-26.895 Z-41.292
    N4714 X-26.02 Z-41.981
    N4715 X-25.145 Z-42.634
    N4716 X-24.233 Z-43.278
    N4717 X-23.321 Z-43.886
    N4718 X-22.41 Z-44.462
    N4719 X-21.498 Z-45.007
    N4720 X-19.729 Z-45.98
    N4721 X-17.961 Z-46.848
    N4722 X-16.151 Z-47.634
    N4723 X-14.342 Z-48.323
    N4724 X-12.559 Z-48.913
    N4725 X-10.776 Z-49.418
    N4726 X-8.958 Z-49.849
    N4727 X-7.169 Z-50.192
    N4728 X-5.362 Z-50.46
    N4729 X-3.592 Z-50.648
    N4730 X-1.797 Z-50.761
    N4731 X0. Z-50.8
    N4732 X1.797 Z-50.761
    N4733 X3.592 Z-50.648
    N4734 X5.362 Z-50.46
    N4735 X7.169 Z-50.192
    N4736 X8.958 Z-49.849
    N4737 X10.776 Z-49.418
    N4738 X12.559 Z-48.913
    N4739 X14.342 Z-48.323
    N4740 X16.151 Z-47.634
    N4741 X17.961 Z-46.848
    N4742 X18.845 Z-46.427
    N4743 X20.614 Z-45.507
    N4744 X22.41 Z-44.462
    N4745 X23.321 Z-43.886
    N4746 X24.233 Z-43.278
    N4747 X25.145 Z-42.634
    N4748 X26.02 Z-41.981
    N4749 X26.895 Z-41.292
    N4750 X27.77 Z-40.565
    N4751 X28.645 Z-39.796
    N4752 X29.566 Z-38.941
    N4753 X30.487 Z-38.035
    N4754 X31.408 Z-37.073
    N4755 X32.329 Z-36.043
    N4756 X33.166 Z-35.047
    N4757 X34.002 Z-33.989
    N4758 X34.839 Z-32.859
    N4759 X35.676 Z-31.638
    N4760 X36.156 Z-30.898
    N4761 X37.115 Z-29.312
    N4762 X38.074 Z-27.548
    N4763 X38.554 Z-26.583
    N4764 X39.033 Z-25.551
    N4765 X39.758 Z-23.846
    N4766 X40.491 Z-21.866
    N4767 X40.979 Z-20.339
    N4768 X41.571 Z-18.178
    N4769 X42.184 Z-15.229
    N4770 X42.44 Z-13.52
    N4771 X42.798 Z-9.748
    N4772 X43.003 Z-8.618
    N4773 X43.217 Z-7.836
    N4774 X43.554 Z-6.907
    N4775 X43.779 Z-6.406
    N4776 X44.228 Z-5.548
    N4777 X44.677 Z-4.839
    N4778 X45.35 Z-3.957
    N4779 X45.799 Z-3.462
    N4780 X46.248 Z-3.014
    N4781 X46.697 Z-2.618
    N4782 X47.146 Z-2.259
    N4783 X47.595 Z-1.937
    N4784 X48.493 Z-1.386
    N4785 X49.391 Z-.943
    N4786 X50.289 Z-.594
    N4787 X51.187 Z-.33
    N4788 X52.085 Z-.145
    N4789 X52.984 Z-.036
    N4790 X53.882 Z0.
    N4791 Y71.375
    N4792 X52.984 Z-.036
    N4793 X52.085 Z-.145
    N4794 X51.187 Z-.33
    N4795 X50.289 Z-.594
    N4796 X49.391 Z-.943
    N4797 X48.493 Z-1.386
    N4798 X47.595 Z-1.937
    N4799 X47.146 Z-2.259
    N4800 X46.697 Z-2.618
    N4801 X46.248 Z-3.014
    N4802 X45.799 Z-3.462
    N4803 X45.35 Z-3.957
    N4804 X44.677 Z-4.839
    N4805 X44.228 Z-5.548
    N4806 X43.779 Z-6.406
    N4807 X43.554 Z-6.907
    N4808 X43.217 Z-7.836
    N4809 X43.003 Z-8.618
    N4810 X42.798 Z-9.748
    N4811 X42.44 Z-13.52
    N4812 X42.184 Z-15.229
    N4813 X41.571 Z-18.178
    N4814 X40.979 Z-20.339
    N4815 X40.491 Z-21.866
    N4816 X39.758 Z-23.846
    N4817 X39.033 Z-25.551
    N4818 X38.554 Z-26.583
    N4819 X38.074 Z-27.548
    N4820 X37.115 Z-29.312
    N4821 X36.156 Z-30.898
    N4822 X35.676 Z-31.638
    N4823 X34.839 Z-32.859
    N4824 X34.002 Z-33.989
    N4825 X33.166 Z-35.047
    N4826 X32.329 Z-36.043
    N4827 X31.408 Z-37.073
    N4828 X30.487 Z-38.035
    N4829 X29.566 Z-38.941
    N4830 X28.645 Z-39.796
    N4831 X27.77 Z-40.565
    N4832 X26.895 Z-41.292
    N4833 X26.02 Z-41.981
    N4834 X25.145 Z-42.634
    N4835 X24.233 Z-43.278
    N4836 X23.321 Z-43.886
    N4837 X22.41 Z-44.462
    N4838 X20.614 Z-45.507
    N4839 X18.845 Z-46.427
    N4840 X17.961 Z-46.848
    N4841 X16.151 Z-47.634
    N4842 X14.342 Z-48.323
    N4843 X12.559 Z-48.913
    N4844 X10.776 Z-49.418
    N4845 X8.958 Z-49.849
    N4846 X7.169 Z-50.192
    N4847 X5.362 Z-50.46
    N4848 X3.592 Z-50.648
    N4849 X1.797 Z-50.761
    N4850 X0. Z-50.8
    N4851 X-1.797 Z-50.761
    N4852 X-3.592 Z-50.648
    N4853 X-5.362 Z-50.46
    N4854 X-7.169 Z-50.192
    N4855 X-8.958 Z-49.849
    N4856 X-10.776 Z-49.418
    N4857 X-12.559 Z-48.913
    N4858 X-14.342 Z-48.323
    N4859 X-16.151 Z-47.634
    N4860 X-17.961 Z-46.848
    N4861 X-19.729 Z-45.98
    N4862 X-21.498 Z-45.007
    N4863 X-22.41 Z-44.462
    N4864 X-23.321 Z-43.886
    N4865 X-24.233 Z-43.278
    N4866 X-25.145 Z-42.634
    N4867 X-26.02 Z-41.981
    N4868 X-26.895 Z-41.292
    N4869 X-27.77 Z-40.565
    N4870 X-28.645 Z-39.796
    N4871 X-29.566 Z-38.941
    N4872 X-30.487 Z-38.035
    N4873 X-31.408 Z-37.073
    N4874 X-32.329 Z-36.043
    N4875 X-33.166 Z-35.047
    N4876 X-34.002 Z-33.989
    N4877 X-34.839 Z-32.859
    N4878 X-35.676 Z-31.638
    N4879 X-36.635 Z-30.125
    N4880 X-37.595 Z-28.455
    N4881 X-38.074 Z-27.548
    N4882 X-38.554 Z-26.583
    N4883 X-39.033 Z-25.551
    N4884 X-39.758 Z-23.846
    N4885 X-40.491 Z-21.866
    N4886 X-41.346 Z-19.058
    N4887 X-41.98 Z-16.328
    N4888 X-42.491 Z-13.111
    N4889 X-42.798 Z-9.748
    N4890 X-42.901 Z-9.107
    N4891 X-43.105 Z-8.22
    N4892 X-43.33 Z-7.496
    N4893 X-43.554 Z-6.907
    N4894 X-44.003 Z-5.952
    N4895 X-44.452 Z-5.183
    N4896 X-44.901 Z-4.527
    N4897 X-45.35 Z-3.957
    N4898 X-45.799 Z-3.462
    N4899 X-46.248 Z-3.014
    N4900 X-46.697 Z-2.618
    N4901 X-47.146 Z-2.26
    N4902 X-47.595 Z-1.937
    N4903 X-48.493 Z-1.386
    N4904 X-49.391 Z-.943
    N4905 X-50.289 Z-.594
    N4906 X-51.187 Z-.33
    N4907 X-52.085 Z-.145
    N4908 X-52.984 Z-.036
    N4909 X-53.882 Z0.
    N4910 Y70.175
    N4911 X-52.984 Z-.036
    N4912 X-52.085 Z-.145
    N4913 X-51.187 Z-.33
    N4914 X-50.289 Z-.594
    N4915 X-49.391 Z-.943
    N4916 X-48.493 Z-1.386
    N4917 X-47.595 Z-1.937
    N4918 X-47.146 Z-2.26
    N4919 X-46.697 Z-2.618
    N4920 X-46.248 Z-3.014
    N4921 X-45.799 Z-3.462
    N4922 X-45.35 Z-3.957
    N4923 X-44.901 Z-4.527
    N4924 X-44.452 Z-5.183
    N4925 X-44.003 Z-5.952
    N4926 X-43.554 Z-6.907
    N4927 X-43.33 Z-7.496
    N4928 X-43.105 Z-8.22
    N4929 X-42.901 Z-9.107
    N4930 X-42.798 Z-9.748
    N4931 X-42.491 Z-13.111
    N4932 X-41.98 Z-16.328
    N4933 X-41.346 Z-19.058
    N4934 X-40.491 Z-21.866
    N4935 X-39.758 Z-23.846
    N4936 X-39.033 Z-25.551
    N4937 X-38.554 Z-26.583
    N4938 X-38.074 Z-27.548
    N4939 X-37.595 Z-28.455
    N4940 X-36.635 Z-30.125
    N4941 X-35.676 Z-31.638
    N4942 X-34.839 Z-32.859
    N4943 X-34.002 Z-33.989
    N4944 X-33.166 Z-35.047
    N4945 X-32.329 Z-36.043
    N4946 X-31.408 Z-37.073
    N4947 X-30.487 Z-38.035
    N4948 X-29.566 Z-38.941
    N4949 X-28.645 Z-39.796
    N4950 X-27.77 Z-40.565
    N4951 X-26.895 Z-41.292
    N4952 X-26.02 Z-41.981
    N4953 X-25.145 Z-42.634
    N4954 X-24.233 Z-43.278
    N4955 X-23.321 Z-43.886
    N4956 X-22.41 Z-44.462
    N4957 X-21.498 Z-45.007
    N4958 X-19.729 Z-45.98
    N4959 X-17.961 Z-46.848
    N4960 X-16.151 Z-47.634
    N4961 X-14.342 Z-48.323
    N4962 X-12.559 Z-48.913
    N4963 X-10.776 Z-49.418
    N4964 X-8.958 Z-49.849
    N4965 X-7.169 Z-50.192
    N4966 X-5.362 Z-50.46
    N4967 X-3.592 Z-50.648
    N4968 X-1.797 Z-50.761
    N4969 X0. Z-50.8
    N4970 X1.797 Z-50.761
    N4971 X3.592 Z-50.648
    N4972 X5.362 Z-50.46
    N4973 X7.169 Z-50.192
    N4974 X8.958 Z-49.849
    N4975 X10.776 Z-49.418
    N4976 X12.559 Z-48.913
    N4977 X14.342 Z-48.323
    N4978 X16.151 Z-47.634
    N4979 X17.961 Z-46.848
    N4980 X18.845 Z-46.427
    N4981 X20.614 Z-45.507
    N4982 X22.41 Z-44.462
    N4983 X23.321 Z-43.886
    N4984 X24.233 Z-43.278
    N4985 X25.145 Z-42.634
    N4986 X26.02 Z-41.981
    N4987 X26.895 Z-41.292
    N4988 X27.77 Z-40.565
    N4989 X28.645 Z-39.796
    N4990 X29.566 Z-38.941
    N4991 X30.487 Z-38.035
    N4992 X31.408 Z-37.073
    N4993 X32.329 Z-36.043
    N4994 X33.166 Z-35.047
    N4995 X34.002 Z-33.989
    N4996 X34.839 Z-32.859
    N4997 X35.676 Z-31.638
    N4998 X36.156 Z-30.898
    N4999 X37.115 Z-29.312
    N5000 X38.074 Z-27.548
    N5001 X38.554 Z-26.583
    N5002 X39.033 Z-25.551
    N5003 X39.758 Z-23.846
    N5004 X40.491 Z-21.866
    N5005 X40.979 Z-20.339
    N5006 X41.571 Z-18.178
    N5007 X42.184 Z-15.229
    N5008 X42.44 Z-13.52
    N5009 X42.798 Z-9.748
    N5010 X43.003 Z-8.618
    N5011 X43.217 Z-7.836
    N5012 X43.554 Z-6.907
    N5013 X43.779 Z-6.406
    N5014 X44.228 Z-5.548
    N5015 X44.677 Z-4.839
    N5016 X45.35 Z-3.957
    N5017 X45.799 Z-3.462
    N5018 X46.248 Z-3.014
    N5019 X46.697 Z-2.618
    N5020 X47.146 Z-2.259
    N5021 X47.595 Z-1.937
    N5022 X48.493 Z-1.386
    N5023 X49.391 Z-.943
    N5024 X50.289 Z-.594
    N5025 X51.187 Z-.33
    N5026 X52.085 Z-.145
    N5027 X52.984 Z-.036
    N5028 X53.882 Z0.
    N5029 Y68.975
    N5030 X52.984 Z-.036
    N5031 X52.085 Z-.145
    N5032 X51.187 Z-.33
    N5033 X50.289 Z-.594
    N5034 X49.391 Z-.943
    N5035 X48.493 Z-1.386
    N5036 X47.595 Z-1.937
    N5037 X47.146 Z-2.259
    N5038 X46.697 Z-2.618
    N5039 X46.248 Z-3.014
    N5040 X45.799 Z-3.462
    N5041 X45.35 Z-3.957
    N5042 X44.677 Z-4.839
    N5043 X44.228 Z-5.548
    N5044 X43.779 Z-6.406
    N5045 X43.554 Z-6.907
    N5046 X43.217 Z-7.836
    N5047 X43.003 Z-8.618
    N5048 X42.798 Z-9.748
    N5049 X42.44 Z-13.52
    N5050 X42.184 Z-15.229
    N5051 X41.571 Z-18.178
    N5052 X40.979 Z-20.339
    N5053 X40.491 Z-21.866
    N5054 X39.758 Z-23.846
    N5055 X39.033 Z-25.551
    N5056 X38.554 Z-26.583
    N5057 X38.074 Z-27.548
    N5058 X37.115 Z-29.312
    N5059 X36.156 Z-30.898
    N5060 X35.676 Z-31.638
    N5061 X34.839 Z-32.859
    N5062 X34.002 Z-33.989
    N5063 X33.166 Z-35.047
    N5064 X32.329 Z-36.043
    N5065 X31.408 Z-37.073
    N5066 X30.487 Z-38.035
    N5067 X29.566 Z-38.941
    N5068 X28.645 Z-39.796
    N5069 X27.77 Z-40.565
    N5070 X26.895 Z-41.292
    N5071 X26.02 Z-41.981
    N5072 X25.145 Z-42.634
    N5073 X24.233 Z-43.278
    N5074 X23.321 Z-43.886
    N5075 X22.41 Z-44.462
    N5076 X20.614 Z-45.507
    N5077 X18.845 Z-46.427
    N5078 X17.961 Z-46.848
    N5079 X16.151 Z-47.634
    N5080 X14.342 Z-48.323
    N5081 X12.559 Z-48.913
    N5082 X10.776 Z-49.418
    N5083 X8.958 Z-49.849
    N5084 X7.169 Z-50.192
    N5085 X5.362 Z-50.46
    N5086 X3.592 Z-50.648
    N5087 X1.797 Z-50.761
    N5088 X0. Z-50.8
    N5089 X-1.797 Z-50.761
    N5090 X-3.592 Z-50.648
    N5091 X-5.362 Z-50.46
    N5092 X-7.169 Z-50.192
    N5093 X-8.958 Z-49.849
    N5094 X-10.776 Z-49.418
    N5095 X-12.559 Z-48.913
    N5096 X-14.342 Z-48.323
    N5097 X-16.151 Z-47.634
    N5098 X-17.961 Z-46.848
    N5099 X-19.729 Z-45.98
    N5100 X-21.498 Z-45.007
    N5101 X-22.41 Z-44.462
    N5102 X-23.321 Z-43.886
    N5103 X-24.233 Z-43.278
    N5104 X-25.145 Z-42.634
    N5105 X-26.02 Z-41.981
    N5106 X-26.895 Z-41.292
    N5107 X-27.77 Z-40.565
    N5108 X-28.645 Z-39.796
    N5109 X-29.566 Z-38.941
    N5110 X-30.487 Z-38.035
    N5111 X-31.408 Z-37.073
    N5112 X-32.329 Z-36.043
    N5113 X-33.166 Z-35.047
    N5114 X-34.002 Z-33.989
    N5115 X-34.839 Z-32.859
    N5116 X-35.676 Z-31.638
    N5117 X-36.635 Z-30.125
    N5118 X-37.595 Z-28.455
    N5119 X-38.074 Z-27.548
    N5120 X-38.554 Z-26.583
    N5121 X-39.033 Z-25.551
    N5122 X-39.758 Z-23.846
    N5123 X-40.491 Z-21.866
    N5124 X-41.346 Z-19.058
    N5125 X-41.98 Z-16.328
    N5126 X-42.491 Z-13.111
    N5127 X-42.798 Z-9.748
    N5128 X-42.901 Z-9.107
    N5129 X-43.105 Z-8.22
    N5130 X-43.33 Z-7.496
    N5131 X-43.554 Z-6.907
    N5132 X-44.003 Z-5.952
    N5133 X-44.452 Z-5.183
    N5134 X-44.901 Z-4.527
    N5135 X-45.35 Z-3.957
    N5136 X-45.799 Z-3.462
    N5137 X-46.248 Z-3.014
    N5138 X-46.697 Z-2.617
    N5139 X-47.146 Z-2.26
    N5140 X-47.595 Z-1.937
    N5141 X-48.493 Z-1.386
    N5142 X-49.391 Z-.943
    N5143 X-50.289 Z-.594
    N5144 X-51.187 Z-.33
    N5145 X-52.085 Z-.145
    N5146 X-52.984 Z-.036
    N5147 X-53.882 Z0.
    N5148 Y67.775
    N5149 X-52.984 Z-.036
    N5150 X-52.085 Z-.145
    N5151 X-51.187 Z-.33
    N5152 X-50.289 Z-.594
    N5153 X-49.391 Z-.943
    N5154 X-48.493 Z-1.386
    N5155 X-47.595 Z-1.937
    N5156 X-47.146 Z-2.26
    N5157 X-46.697 Z-2.617
    N5158 X-46.248 Z-3.014
    N5159 X-45.799 Z-3.462
    N5160 X-45.35 Z-3.957
    N5161 X-44.901 Z-4.527
    N5162 X-44.452 Z-5.183
    N5163 X-44.003 Z-5.952
    N5164 X-43.554 Z-6.907
    N5165 X-43.33 Z-7.496
    N5166 X-43.105 Z-8.22
    N5167 X-42.901 Z-9.106
    N5168 X-42.798 Z-9.748
    N5169 X-42.491 Z-13.111
    N5170 X-41.98 Z-16.328
    N5171 X-41.346 Z-19.058
    N5172 X-40.491 Z-21.866
    N5173 X-39.758 Z-23.846
    N5174 X-39.033 Z-25.551
    N5175 X-38.554 Z-26.583
    N5176 X-38.074 Z-27.548
    N5177 X-37.595 Z-28.455
    N5178 X-36.635 Z-30.125
    N5179 X-35.676 Z-31.638
    N5180 X-34.839 Z-32.859
    N5181 X-34.002 Z-33.989
    N5182 X-33.166 Z-35.047
    N5183 X-32.329 Z-36.043
    N5184 X-31.408 Z-37.073
    N5185 X-30.487 Z-38.035
    N5186 X-29.566 Z-38.941
    N5187 X-28.645 Z-39.796
    N5188 X-27.77 Z-40.565
    N5189 X-26.895 Z-41.292
    N5190 X-26.02 Z-41.981
    N5191 X-25.145 Z-42.634
    N5192 X-24.233 Z-43.278
    N5193 X-23.321 Z-43.886
    N5194 X-22.41 Z-44.462
    N5195 X-21.498 Z-45.007
    N5196 X-19.729 Z-45.98
    N5197 X-17.961 Z-46.848
    N5198 X-16.151 Z-47.634
    N5199 X-14.342 Z-48.323
    N5200 X-12.559 Z-48.913
    N5201 X-10.776 Z-49.418
    N5202 X-8.958 Z-49.849
    N5203 X-7.169 Z-50.192
    N5204 X-5.362 Z-50.46
    N5205 X-3.592 Z-50.648
    N5206 X-1.797 Z-50.761
    N5207 X0. Z-50.8
    N5208 X1.797 Z-50.761
    N5209 X3.592 Z-50.648
    N5210 X5.362 Z-50.46
    N5211 X7.169 Z-50.192
    N5212 X8.958 Z-49.849
    N5213 X10.776 Z-49.418
    N5214 X12.559 Z-48.913
    N5215 X14.342 Z-48.323
    N5216 X16.151 Z-47.634
    N5217 X17.961 Z-46.848
    N5218 X18.845 Z-46.427
    N5219 X20.614 Z-45.507
    N5220 X22.41 Z-44.462
    N5221 X23.321 Z-43.886
    N5222 X24.233 Z-43.278
    N5223 X25.145 Z-42.634
    N5224 X26.02 Z-41.981
    N5225 X26.895 Z-41.292
    N5226 X27.77 Z-40.565
    N5227 X28.645 Z-39.796
    N5228 X29.566 Z-38.941
    N5229 X30.487 Z-38.035
    N5230 X31.408 Z-37.073
    N5231 X32.329 Z-36.043
    N5232 X33.166 Z-35.047
    N5233 X34.002 Z-33.989
    N5234 X34.839 Z-32.859
    N5235 X35.676 Z-31.638
    N5236 X36.156 Z-30.898
    N5237 X37.115 Z-29.312
    N5238 X38.074 Z-27.548
    N5239 X38.554 Z-26.583
    N5240 X39.033 Z-25.551
    N5241 X39.758 Z-23.846
    N5242 X40.491 Z-21.866
    N5243 X40.979 Z-20.339
    N5244 X41.571 Z-18.178
    N5245 X42.184 Z-15.229
    N5246 X42.44 Z-13.52
    N5247 X42.798 Z-9.748
    N5248 X43.003 Z-8.618
    N5249 X43.217 Z-7.836
    N5250 X43.554 Z-6.907
    N5251 X43.779 Z-6.406
    N5252 X44.228 Z-5.548
    N5253 X44.677 Z-4.839
    N5254 X45.35 Z-3.957
    N5255 X45.799 Z-3.462
    N5256 X46.248 Z-3.014
    N5257 X46.697 Z-2.617
    N5258 X47.146 Z-2.26
    N5259 X47.595 Z-1.937
    N5260 X48.493 Z-1.386
    N5261 X49.391 Z-.943
    N5262 X50.289 Z-.594
    N5263 X51.187 Z-.33
    N5264 X52.085 Z-.145
    N5265 X52.984 Z-.036
    N5266 X53.882 Z0.
    N5267 Y66.575
    N5268 X52.984 Z-.036
    N5269 X52.085 Z-.145
    N5270 X51.187 Z-.33
    N5271 X50.289 Z-.594
    N5272 X49.391 Z-.943
    N5273 X48.493 Z-1.386
    N5274 X47.595 Z-1.937
    N5275 X47.146 Z-2.26
    N5276 X46.697 Z-2.617
    N5277 X46.248 Z-3.014
    N5278 X45.799 Z-3.462
    N5279 X45.35 Z-3.957
    N5280 X44.677 Z-4.839
    N5281 X44.228 Z-5.548
    N5282 X43.779 Z-6.406
    N5283 X43.554 Z-6.907
    N5284 X43.217 Z-7.836
    N5285 X43.003 Z-8.618
    N5286 X42.798 Z-9.748
    N5287 X42.44 Z-13.52
    N5288 X42.184 Z-15.229
    N5289 X41.571 Z-18.178
    N5290 X40.979 Z-20.339
    N5291 X40.491 Z-21.866
    N5292 X39.758 Z-23.846
    N5293 X39.033 Z-25.551
    N5294 X38.554 Z-26.583
    N5295 X38.074 Z-27.548
    N5296 X37.115 Z-29.312
    N5297 X36.156 Z-30.898
    N5298 X35.676 Z-31.638
    N5299 X34.839 Z-32.859
    N5300 X34.002 Z-33.989
    N5301 X33.166 Z-35.047
    N5302 X32.329 Z-36.043
    N5303 X31.408 Z-37.073
    N5304 X30.487 Z-38.035
    N5305 X29.566 Z-38.941
    N5306 X28.645 Z-39.796
    N5307 X27.77 Z-40.565
    N5308 X26.895 Z-41.292
    N5309 X26.02 Z-41.981
    N5310 X25.145 Z-42.634
    N5311 X24.233 Z-43.278
    N5312 X23.321 Z-43.886
    N5313 X22.41 Z-44.462
    N5314 X20.614 Z-45.507
    N5315 X18.845 Z-46.427
    N5316 X17.961 Z-46.848
    N5317 X16.151 Z-47.634
    N5318 X14.342 Z-48.323
    N5319 X12.559 Z-48.913
    N5320 X10.776 Z-49.418
    N5321 X8.958 Z-49.849
    N5322 X7.169 Z-50.192
    N5323 X5.362 Z-50.46
    N5324 X3.592 Z-50.648
    N5325 X1.797 Z-50.761
    N5326 X0. Z-50.8
    N5327 X-1.797 Z-50.761
    N5328 X-3.592 Z-50.648
    N5329 X-5.362 Z-50.46
    N5330 X-7.169 Z-50.192
    N5331 X-8.958 Z-49.849
    N5332 X-10.776 Z-49.418
    N5333 X-12.559 Z-48.913
    N5334 X-14.342 Z-48.323
    N5335 X-16.151 Z-47.634
    N5336 X-17.961 Z-46.848
    N5337 X-19.729 Z-45.98
    N5338 X-21.498 Z-45.007
    N5339 X-22.41 Z-44.462
    N5340 X-23.321 Z-43.886
    N5341 X-24.233 Z-43.278
    N5342 X-25.145 Z-42.634
    N5343 X-26.02 Z-41.981
    N5344 X-26.895 Z-41.292
    N5345 X-27.77 Z-40.565
    N5346 X-28.645 Z-39.796
    N5347 X-29.566 Z-38.941
    N5348 X-30.487 Z-38.035
    N5349 X-31.408 Z-37.073
    N5350 X-32.329 Z-36.043
    N5351 X-33.166 Z-35.047
    N5352 X-34.002 Z-33.989
    N5353 X-34.839 Z-32.859
    N5354 X-35.676 Z-31.638
    N5355 X-36.635 Z-30.125
    N5356 X-37.595 Z-28.455
    N5357 X-38.074 Z-27.548
    N5358 X-38.554 Z-26.583
    N5359 X-39.033 Z-25.551
    N5360 X-39.758 Z-23.846
    N5361 X-40.491 Z-21.866
    N5362 X-41.346 Z-19.058
    N5363 X-41.98 Z-16.328
    N5364 X-42.491 Z-13.111
    N5365 X-42.798 Z-9.748
    N5366 X-42.901 Z-9.106
    N5367 X-43.105 Z-8.22
    N5368 X-43.33 Z-7.496
    N5369 X-43.554 Z-6.907
    N5370 X-44.003 Z-5.952
    N5371 X-44.452 Z-5.183
    N5372 X-44.901 Z-4.527
    N5373 X-45.35 Z-3.957
    N5374 X-45.799 Z-3.462
    N5375 X-46.248 Z-3.014
    N5376 X-46.697 Z-2.617
    N5377 X-47.146 Z-2.26
    N5378 X-47.595 Z-1.937
    N5379 X-48.493 Z-1.386
    N5380 X-49.391 Z-.943
    N5381 X-50.289 Z-.594
    N5382 X-51.187 Z-.33
    N5383 X-52.085 Z-.145
    N5384 X-52.984 Z-.036
    N5385 X-53.882 Z0.
    N5386 Y65.375
    N5387 X-52.984 Z-.036
    N5388 X-52.085 Z-.145
    N5389 X-51.187 Z-.33
    N5390 X-50.289 Z-.593
    N5391 X-49.391 Z-.942
    N5392 X-48.493 Z-1.385
    N5393 X-47.595 Z-1.937
    N5394 X-47.146 Z-2.26
    N5395 X-46.697 Z-2.617
    N5396 X-46.248 Z-3.014
    N5397 X-45.799 Z-3.462
    N5398 X-45.35 Z-3.957
    N5399 X-44.901 Z-4.527
    N5400 X-44.452 Z-5.184
    N5401 X-44.003 Z-5.952
    N5402 X-43.554 Z-6.907
    N5403 X-43.33 Z-7.496
    N5404 X-43.105 Z-8.22
    N5405 X-42.901 Z-9.106
    N5406 X-42.798 Z-9.748
    N5407 X-42.491 Z-13.111
    N5408 X-41.98 Z-16.328
    N5409 X-41.346 Z-19.058
    N5410 X-40.491 Z-21.866
    N5411 X-39.758 Z-23.846
    N5412 X-39.033 Z-25.551
    N5413 X-38.554 Z-26.583
    N5414 X-38.074 Z-27.548
    N5415 X-37.595 Z-28.455
    N5416 X-36.635 Z-30.125
    N5417 X-35.676 Z-31.638
    N5418 X-34.839 Z-32.859
    N5419 X-34.002 Z-33.989
    N5420 X-33.166 Z-35.047
    N5421 X-32.329 Z-36.043
    N5422 X-31.408 Z-37.073
    N5423 X-30.487 Z-38.035
    N5424 X-29.566 Z-38.941
    N5425 X-28.645 Z-39.796
    N5426 X-27.77 Z-40.565
    N5427 X-26.895 Z-41.292
    N5428 X-26.02 Z-41.981
    N5429 X-25.145 Z-42.634
    N5430 X-24.233 Z-43.278
    N5431 X-23.321 Z-43.886
    N5432 X-22.41 Z-44.462
    N5433 X-21.498 Z-45.007
    N5434 X-19.729 Z-45.98
    N5435 X-17.961 Z-46.848
    N5436 X-16.151 Z-47.634
    N5437 X-14.342 Z-48.323
    N5438 X-12.559 Z-48.913
    N5439 X-10.776 Z-49.418
    N5440 X-8.958 Z-49.849
    N5441 X-7.169 Z-50.192
    N5442 X-5.362 Z-50.46
    N5443 X-3.592 Z-50.648
    N5444 X-1.797 Z-50.761
    N5445 X0. Z-50.8
    N5446 X1.797 Z-50.761
    N5447 X3.592 Z-50.648
    N5448 X5.362 Z-50.46
    N5449 X7.169 Z-50.192
    N5450 X8.958 Z-49.849
    N5451 X10.776 Z-49.418
    N5452 X12.559 Z-48.913
    N5453 X14.342 Z-48.323
    N5454 X16.151 Z-47.634
    N5455 X17.961 Z-46.848
    N5456 X18.845 Z-46.427
    N5457 X20.614 Z-45.507
    N5458 X22.41 Z-44.462
    N5459 X23.321 Z-43.886
    N5460 X24.233 Z-43.278
    N5461 X25.145 Z-42.634
    N5462 X26.02 Z-41.981
    N5463 X26.895 Z-41.292
    N5464 X27.77 Z-40.565
    N5465 X28.645 Z-39.796
    N5466 X29.566 Z-38.941
    N5467 X30.487 Z-38.035
    N5468 X31.408 Z-37.073
    N5469 X32.329 Z-36.043
    N5470 X33.166 Z-35.047
    N5471 X34.002 Z-33.989
    N5472 X34.839 Z-32.859
    N5473 X35.676 Z-31.638
    N5474 X36.156 Z-30.898
    N5475 X37.115 Z-29.312
    N5476 X38.074 Z-27.548
    N5477 X38.554 Z-26.583
    N5478 X39.033 Z-25.551
    N5479 X39.758 Z-23.846
    N5480 X40.491 Z-21.866
    N5481 X40.979 Z-20.339
    N5482 X41.571 Z-18.178
    N5483 X42.184 Z-15.229
    N5484 X42.44 Z-13.521
    N5485 X42.798 Z-9.748
    N5486 X43.003 Z-8.618
    N5487 X43.217 Z-7.836
    N5488 X43.554 Z-6.907
    N5489 X43.779 Z-6.406
    N5490 X44.228 Z-5.548
    N5491 X44.677 Z-4.839
    N5492 X45.35 Z-3.957
    N5493 X45.799 Z-3.462
    N5494 X46.248 Z-3.014
    N5495 X46.697 Z-2.617
    N5496 X47.146 Z-2.26
    N5497 X47.595 Z-1.937
    N5498 X48.493 Z-1.386
    N5499 X49.391 Z-.942
    N5500 X50.289 Z-.593
    N5501 X51.187 Z-.33
    N5502 X52.085 Z-.145
    N5503 X52.984 Z-.036
    N5504 X53.882 Z0.
    N5505 Y64.175
    N5506 X52.984 Z-.036
    N5507 X52.085 Z-.145
    N5508 X51.187 Z-.33
    N5509 X50.289 Z-.593
    N5510 X49.391 Z-.942
    N5511 X48.493 Z-1.385
    N5512 X47.595 Z-1.937
    N5513 X47.146 Z-2.26
    N5514 X46.697 Z-2.617
    N5515 X46.248 Z-3.014
    N5516 X45.799 Z-3.462
    N5517 X45.35 Z-3.957
    N5518 X44.677 Z-4.839
    N5519 X44.228 Z-5.548
    N5520 X43.779 Z-6.406
    N5521 X43.554 Z-6.907
    N5522 X43.217 Z-7.836
    N5523 X43.003 Z-8.618
    N5524 X42.798 Z-9.748
    N5525 X42.44 Z-13.521
    N5526 X42.184 Z-15.229
    N5527 X41.571 Z-18.178
    N5528 X40.979 Z-20.339
    N5529 X40.491 Z-21.866
    N5530 X39.758 Z-23.846
    N5531 X39.033 Z-25.551
    N5532 X38.554 Z-26.583
    N5533 X38.074 Z-27.548
    N5534 X37.115 Z-29.312
    N5535 X36.156 Z-30.898
    N5536 X35.676 Z-31.638
    N5537 X34.839 Z-32.859
    N5538 X34.002 Z-33.989
    N5539 X33.166 Z-35.047
    N5540 X32.329 Z-36.043
    N5541 X31.408 Z-37.073
    N5542 X30.487 Z-38.035
    N5543 X29.566 Z-38.941
    N5544 X28.645 Z-39.796
    N5545 X27.77 Z-40.565
    N5546 X26.895 Z-41.292
    N5547 X26.02 Z-41.981
    N5548 X25.145 Z-42.634
    N5549 X24.233 Z-43.278
    N5550 X23.321 Z-43.886
    N5551 X22.41 Z-44.462
    N5552 X20.614 Z-45.507
    N5553 X18.845 Z-46.427
    N5554 X17.961 Z-46.848
    N5555 X16.151 Z-47.634
    N5556 X14.342 Z-48.323
    N5557 X12.559 Z-48.913
    N5558 X10.776 Z-49.418
    N5559 X8.958 Z-49.849
    N5560 X7.169 Z-50.192
    N5561 X5.362 Z-50.46
    N5562 X3.592 Z-50.648
    N5563 X1.797 Z-50.761
    N5564 X0. Z-50.8
    N5565 X-1.797 Z-50.761
    N5566 X-3.592 Z-50.648
    N5567 X-5.362 Z-50.46
    N5568 X-7.169 Z-50.192
    N5569 X-8.958 Z-49.849
    N5570 X-10.776 Z-49.418
    N5571 X-12.559 Z-48.913
    N5572 X-14.342 Z-48.323
    N5573 X-16.151 Z-47.634
    N5574 X-17.961 Z-46.848
    N5575 X-19.729 Z-45.98
    N5576 X-21.498 Z-45.007
    N5577 X-22.41 Z-44.462
    N5578 X-23.321 Z-43.886
    N5579 X-24.233 Z-43.278
    N5580 X-25.145 Z-42.634
    N5581 X-26.02 Z-41.981
    N5582 X-26.895 Z-41.292
    N5583 X-27.77 Z-40.565
    N5584 X-28.645 Z-39.796
    N5585 X-29.566 Z-38.941
    N5586 X-30.487 Z-38.035
    N5587 X-31.408 Z-37.073
    N5588 X-32.329 Z-36.043
    N5589 X-33.166 Z-35.047
    N5590 X-34.002 Z-33.989
    N5591 X-34.839 Z-32.859
    N5592 X-35.676 Z-31.638
    N5593 X-36.635 Z-30.125
    N5594 X-37.595 Z-28.455
    N5595 X-38.074 Z-27.548
    N5596 X-38.554 Z-26.583
    N5597 X-39.513 Z-24.44
    N5598 X-40.246 Z-22.553
    N5599 X-40.735 Z-21.126
    N5600 X-41.346 Z-19.058
    N5601 X-41.98 Z-16.328
    N5602 X-42.491 Z-13.111
    N5603 X-42.798 Z-9.748
    N5604 X-42.901 Z-9.106
    N5605 X-43.105 Z-8.22
    N5606 X-43.33 Z-7.496
    N5607 X-43.554 Z-6.907
    N5608 X-44.003 Z-5.952
    N5609 X-44.452 Z-5.184
    N5610 X-44.901 Z-4.527
    N5611 X-45.35 Z-3.957
    N5612 X-45.799 Z-3.462
    N5613 X-46.248 Z-3.014
    N5614 X-46.697 Z-2.617
    N5615 X-47.146 Z-2.26
    N5616 X-47.595 Z-1.937
    N5617 X-48.493 Z-1.385
    N5618 X-49.391 Z-.942
    N5619 X-50.289 Z-.593
    N5620 X-51.187 Z-.33
    N5621 X-52.085 Z-.145
    N5622 X-52.984 Z-.036
    N5623 X-53.882 Z0.
    N5624 Y62.975
    N5625 X-52.984 Z-.036
    N5626 X-52.085 Z-.145
    N5627 X-51.187 Z-.33
    N5628 X-50.289 Z-.593
    N5629 X-49.391 Z-.942
    N5630 X-48.493 Z-1.385
    N5631 X-47.595 Z-1.937
    N5632 X-47.146 Z-2.26
    N5633 X-46.697 Z-2.617
    N5634 X-46.248 Z-3.014
    N5635 X-45.799 Z-3.462
    N5636 X-45.35 Z-3.957
    N5637 X-44.901 Z-4.527
    N5638 X-44.452 Z-5.184
    N5639 X-44.003 Z-5.952
    N5640 X-43.554 Z-6.907
    N5641 X-43.33 Z-7.496
    N5642 X-43.105 Z-8.22
    N5643 X-42.901 Z-9.106
    N5644 X-42.798 Z-9.748
    N5645 X-42.491 Z-13.111
    N5646 X-41.98 Z-16.328
    N5647 X-41.346 Z-19.058
    N5648 X-40.735 Z-21.126
    N5649 X-40.246 Z-22.553
    N5650 X-39.513 Z-24.44
    N5651 X-38.554 Z-26.583
    N5652 X-38.074 Z-27.548
    N5653 X-37.595 Z-28.455
    N5654 X-36.635 Z-30.125
    N5655 X-35.676 Z-31.638
    N5656 X-34.839 Z-32.859
    N5657 X-34.002 Z-33.989
    N5658 X-33.166 Z-35.047
    N5659 X-32.329 Z-36.043
    N5660 X-31.408 Z-37.073
    N5661 X-30.487 Z-38.035
    N5662 X-29.566 Z-38.941
    N5663 X-28.645 Z-39.796
    N5664 X-27.77 Z-40.565
    N5665 X-26.895 Z-41.292
    N5666 X-26.02 Z-41.981
    N5667 X-25.145 Z-42.634
    N5668 X-24.233 Z-43.278
    N5669 X-23.321 Z-43.886
    N5670 X-22.41 Z-44.462
    N5671 X-21.498 Z-45.007
    N5672 X-19.729 Z-45.98
    N5673 X-17.961 Z-46.848
    N5674 X-16.151 Z-47.634
    N5675 X-14.342 Z-48.323
    N5676 X-12.559 Z-48.913
    N5677 X-10.776 Z-49.418
    N5678 X-8.958 Z-49.849
    N5679 X-7.169 Z-50.192
    N5680 X-5.362 Z-50.46
    N5681 X-3.592 Z-50.648
    N5682 X-1.797 Z-50.761
    N5683 X0. Z-50.8
    N5684 X1.797 Z-50.761
    N5685 X3.592 Z-50.648
    N5686 X5.362 Z-50.46
    N5687 X7.169 Z-50.192
    N5688 X8.958 Z-49.849
    N5689 X10.776 Z-49.418
    N5690 X12.559 Z-48.913
    N5691 X14.342 Z-48.323
    N5692 X16.151 Z-47.634
    N5693 X17.961 Z-46.848
    N5694 X18.845 Z-46.427
    N5695 X20.614 Z-45.507
    N5696 X22.41 Z-44.462
    N5697 X23.321 Z-43.886
    N5698 X24.233 Z-43.278
    N5699 X25.145 Z-42.634
    N5700 X26.02 Z-41.981
    N5701 X26.895 Z-41.292
    N5702 X27.77 Z-40.565
    N5703 X28.645 Z-39.796
    N5704 X29.566 Z-38.941
    N5705 X30.487 Z-38.035
    N5706 X31.408 Z-37.073
    N5707 X32.329 Z-36.043
    N5708 X33.166 Z-35.047
    N5709 X34.002 Z-33.989
    N5710 X34.839 Z-32.859
    N5711 X35.676 Z-31.638
    N5712 X36.156 Z-30.898
    N5713 X37.115 Z-29.312
    N5714 X38.074 Z-27.548
    N5715 X38.554 Z-26.583
    N5716 X39.033 Z-25.551
    N5717 X39.758 Z-23.846
    N5718 X40.491 Z-21.866
    N5719 X40.979 Z-20.339
    N5720 X41.571 Z-18.178
    N5721 X42.184 Z-15.229
    N5722 X42.44 Z-13.521
    N5723 X42.798 Z-9.748
    N5724 X43.003 Z-8.618
    N5725 X43.217 Z-7.836
    N5726 X43.554 Z-6.907
    N5727 X43.779 Z-6.407
    N5728 X44.228 Z-5.548
    N5729 X44.677 Z-4.839
    N5730 X45.35 Z-3.957
    N5731 X45.799 Z-3.462
    N5732 X46.248 Z-3.014
    N5733 X46.697 Z-2.617
    N5734 X47.146 Z-2.26
    N5735 X47.595 Z-1.937
    N5736 X48.493 Z-1.385
    N5737 X49.391 Z-.942
    N5738 X50.289 Z-.593
    N5739 X51.187 Z-.33
    N5740 X52.085 Z-.145
    N5741 X52.984 Z-.036
    N5742 X53.882 Z0.
    N5743 Y61.775
    N5744 X52.984 Z-.036
    N5745 X52.085 Z-.145
    N5746 X51.187 Z-.33
    N5747 X50.289 Z-.593
    N5748 X49.391 Z-.942
    N5749 X48.493 Z-1.385
    N5750 X47.595 Z-1.937
    N5751 X47.146 Z-2.26
    N5752 X46.697 Z-2.617
    N5753 X46.248 Z-3.014
    N5754 X45.799 Z-3.462
    N5755 X45.35 Z-3.957
    N5756 X44.677 Z-4.839
    N5757 X44.228 Z-5.548
    N5758 X43.779 Z-6.407
    N5759 X43.554 Z-6.906
    N5760 X43.217 Z-7.836
    N5761 X43.003 Z-8.618
    N5762 X42.798 Z-9.748
    N5763 X42.44 Z-13.521
    N5764 X42.184 Z-15.229
    N5765 X41.571 Z-18.178
    N5766 X40.979 Z-20.339
    N5767 X40.491 Z-21.866
    N5768 X39.758 Z-23.846
    N5769 X39.033 Z-25.551
    N5770 X38.554 Z-26.583
    N5771 X38.074 Z-27.548
    N5772 X37.115 Z-29.312
    N5773 X36.156 Z-30.898
    N5774 X35.676 Z-31.638
    N5775 X34.839 Z-32.859
    N5776 X34.002 Z-33.989
    N5777 X33.166 Z-35.047
    N5778 X32.329 Z-36.043
    N5779 X31.408 Z-37.073
    N5780 X30.487 Z-38.035
    N5781 X29.566 Z-38.941
    N5782 X28.645 Z-39.796
    N5783 X27.77 Z-40.565
    N5784 X26.895 Z-41.292
    N5785 X26.02 Z-41.981
    N5786 X25.145 Z-42.634
    N5787 X24.233 Z-43.278
    N5788 X23.321 Z-43.886
    N5789 X22.41 Z-44.462
    N5790 X20.614 Z-45.507
    N5791 X18.845 Z-46.427
    N5792 X17.961 Z-46.848
    N5793 X16.151 Z-47.634
    N5794 X14.342 Z-48.323
    N5795 X12.559 Z-48.913
    N5796 X10.776 Z-49.418
    N5797 X8.958 Z-49.849
    N5798 X7.169 Z-50.192
    N5799 X5.362 Z-50.46
    N5800 X3.592 Z-50.648
    N5801 X1.797 Z-50.761
    N5802 X0. Z-50.8
    N5803 X-1.797 Z-50.761
    N5804 X-3.592 Z-50.648
    N5805 X-5.362 Z-50.46
    N5806 X-7.169 Z-50.192
    N5807 X-8.958 Z-49.849
    N5808 X-10.776 Z-49.418
    N5809 X-12.559 Z-48.913
    N5810 X-14.342 Z-48.323
    N5811 X-16.151 Z-47.634
    N5812 X-17.961 Z-46.848
    N5813 X-19.729 Z-45.98
    N5814 X-21.498 Z-45.007
    N5815 X-22.41 Z-44.462
    N5816 X-23.321 Z-43.886
    N5817 X-24.233 Z-43.278
    N5818 X-25.145 Z-42.634
    N5819 X-26.02 Z-41.981
    N5820 X-26.895 Z-41.292
    N5821 X-27.77 Z-40.565
    N5822 X-28.645 Z-39.796
    N5823 X-29.566 Z-38.941
    N5824 X-30.487 Z-38.035
    N5825 X-31.408 Z-37.073
    N5826 X-32.329 Z-36.043
    N5827 X-33.166 Z-35.047
    N5828 X-34.002 Z-33.989
    N5829 X-34.839 Z-32.859
    N5830 X-35.676 Z-31.638
    N5831 X-36.635 Z-30.125
    N5832 X-37.595 Z-28.455
    N5833 X-38.074 Z-27.548
    N5834 X-38.554 Z-26.583
    N5835 X-39.513 Z-24.44
    N5836 X-40.246 Z-22.553
    N5837 X-40.735 Z-21.126
    N5838 X-41.346 Z-19.058
    N5839 X-41.98 Z-16.328
    N5840 X-42.491 Z-13.111
    N5841 X-42.798 Z-9.748
    N5842 X-42.901 Z-9.105
    N5843 X-43.105 Z-8.22
    N5844 X-43.33 Z-7.496
    N5845 X-43.554 Z-6.906
    N5846 X-44.003 Z-5.952
    N5847 X-44.452 Z-5.184
    N5848 X-44.901 Z-4.527
    N5849 X-45.35 Z-3.957
    N5850 X-45.799 Z-3.462
    N5851 X-46.248 Z-3.014
    N5852 X-46.697 Z-2.617
    N5853 X-47.146 Z-2.26
    N5854 X-47.595 Z-1.936
    N5855 X-48.493 Z-1.385
    N5856 X-49.391 Z-.942
    N5857 X-50.289 Z-.593
    N5858 X-51.187 Z-.33
    N5859 X-52.085 Z-.145
    N5860 X-52.984 Z-.036
    N5861 X-53.882 Z0.
    N5862 Y60.575
    N5863 X-52.984 Z-.036
    N5864 X-52.085 Z-.145
    N5865 X-51.187 Z-.33
    N5866 X-50.289 Z-.593
    N5867 X-49.391 Z-.942
    N5868 X-48.493 Z-1.385
    N5869 X-47.595 Z-1.936
    N5870 X-47.146 Z-2.26
    N5871 X-46.697 Z-2.617
    N5872 X-46.248 Z-3.014
    N5873 X-45.799 Z-3.462
    N5874 X-45.35 Z-3.957
    N5875 X-44.901 Z-4.527
    N5876 X-44.452 Z-5.184
    N5877 X-44.003 Z-5.952
    N5878 X-43.554 Z-6.906
    N5879 X-43.33 Z-7.496
    N5880 X-43.105 Z-8.22
    N5881 X-42.901 Z-9.105
    N5882 X-42.798 Z-9.748
    N5883 X-42.491 Z-13.111
    N5884 X-41.98 Z-16.328
    N5885 X-41.346 Z-19.058
    N5886 X-40.735 Z-21.126
    N5887 X-40.246 Z-22.553
    N5888 X-39.513 Z-24.44
    N5889 X-38.554 Z-26.583
    N5890 X-38.074 Z-27.548
    N5891 X-37.595 Z-28.455
    N5892 X-36.635 Z-30.125
    N5893 X-35.676 Z-31.638
    N5894 X-34.839 Z-32.859
    N5895 X-34.002 Z-33.989
    N5896 X-33.166 Z-35.047
    N5897 X-32.329 Z-36.043
    N5898 X-31.408 Z-37.073
    N5899 X-30.487 Z-38.035
    N5900 X-29.566 Z-38.941
    N5901 X-28.645 Z-39.796
    N5902 X-27.77 Z-40.565
    N5903 X-26.895 Z-41.292
    N5904 X-26.02 Z-41.981
    N5905 X-25.145 Z-42.634
    N5906 X-24.233 Z-43.278
    N5907 X-23.321 Z-43.886
    N5908 X-22.41 Z-44.462
    N5909 X-21.498 Z-45.007
    N5910 X-19.729 Z-45.98
    N5911 X-17.961 Z-46.848
    N5912 X-16.151 Z-47.634
    N5913 X-14.342 Z-48.323
    N5914 X-12.559 Z-48.913
    N5915 X-10.776 Z-49.418
    N5916 X-8.958 Z-49.849
    N5917 X-7.169 Z-50.192
    N5918 X-5.362 Z-50.46
    N5919 X-3.592 Z-50.648
    N5920 X-1.797 Z-50.761
    N5921 X0. Z-50.8
    N5922 X1.797 Z-50.761
    N5923 X3.592 Z-50.648
    N5924 X5.362 Z-50.46
    N5925 X7.169 Z-50.192
    N5926 X8.958 Z-49.849
    N5927 X10.776 Z-49.418
    N5928 X12.559 Z-48.913
    N5929 X14.342 Z-48.323
    N5930 X16.151 Z-47.634
    N5931 X17.961 Z-46.848
    N5932 X18.845 Z-46.427
    N5933 X20.614 Z-45.507
    N5934 X22.41 Z-44.462
    N5935 X23.321 Z-43.886
    N5936 X24.233 Z-43.278
    N5937 X25.145 Z-42.634
    N5938 X26.02 Z-41.981
    N5939 X26.895 Z-41.292
    N5940 X27.77 Z-40.565
    N5941 X28.645 Z-39.796
    N5942 X29.566 Z-38.941
    N5943 X30.487 Z-38.035
    N5944 X31.408 Z-37.073
    N5945 X32.329 Z-36.043
    N5946 X33.166 Z-35.047
    N5947 X34.002 Z-33.989
    N5948 X34.839 Z-32.859
    N5949 X35.676 Z-31.638
    N5950 X36.156 Z-30.898
    N5951 X37.115 Z-29.312
    N5952 X38.074 Z-27.548
    N5953 X38.554 Z-26.583
    N5954 X39.033 Z-25.551
    N5955 X39.758 Z-23.846
    N5956 X40.491 Z-21.866
    N5957 X40.979 Z-20.339
    N5958 X41.571 Z-18.178
    N5959 X42.184 Z-15.229
    N5960 X42.44 Z-13.521
    N5961 X42.798 Z-9.748
    N5962 X43.003 Z-8.618
    N5963 X43.217 Z-7.836
    N5964 X43.554 Z-6.906
    N5965 X43.779 Z-6.407
    N5966 X44.228 Z-5.548
    N5967 X44.677 Z-4.839
    N5968 X45.35 Z-3.957
    N5969 X45.799 Z-3.462
    N5970 X46.248 Z-3.014
    N5971 X46.697 Z-2.617
    N5972 X47.146 Z-2.26
    N5973 X47.595 Z-1.936
    N5974 X48.493 Z-1.385
    N5975 X49.391 Z-.942
    N5976 X50.289 Z-.593
    N5977 X51.187 Z-.33
    N5978 X52.085 Z-.145
    N5979 X52.984 Z-.036
    N5980 X53.882 Z0.
    N5981 Y59.375
    N5982 X52.984 Z-.036
    N5983 X52.085 Z-.145
    N5984 X51.187 Z-.33
    N5985 X50.289 Z-.593
    N5986 X49.391 Z-.942
    N5987 X48.493 Z-1.385
    N5988 X47.595 Z-1.936
    N5989 X47.146 Z-2.26
    N5990 X46.697 Z-2.617
    N5991 X46.248 Z-3.014
    N5992 X45.799 Z-3.462
    N5993 X45.35 Z-3.957
    N5994 X44.677 Z-4.839
    N5995 X44.228 Z-5.548
    N5996 X43.779 Z-6.407
    N5997 X43.554 Z-6.906
    N5998 X43.217 Z-7.836
    N5999 X43.003 Z-8.618
    N6000 X42.798 Z-9.748
    N6001 X42.44 Z-13.521
    N6002 X42.184 Z-15.229
    N6003 X41.571 Z-18.178
    N6004 X40.979 Z-20.339
    N6005 X40.491 Z-21.866
    N6006 X39.758 Z-23.846
    N6007 X39.033 Z-25.551
    N6008 X38.554 Z-26.583
    N6009 X38.074 Z-27.548
    N6010 X37.115 Z-29.312
    N6011 X36.156 Z-30.898
    N6012 X35.676 Z-31.638
    N6013 X34.839 Z-32.859
    N6014 X34.002 Z-33.989
    N6015 X33.166 Z-35.047
    N6016 X32.329 Z-36.043
    N6017 X31.408 Z-37.073
    N6018 X30.487 Z-38.035
    N6019 X29.566 Z-38.941
    N6020 X28.645 Z-39.796
    N6021 X27.77 Z-40.565
    N6022 X26.895 Z-41.292
    N6023 X26.02 Z-41.981
    N6024 X25.145 Z-42.634
    N6025 X24.233 Z-43.278
    N6026 X23.321 Z-43.886
    N6027 X22.41 Z-44.462
    N6028 X20.614 Z-45.507
    N6029 X18.845 Z-46.427
    N6030 X17.961 Z-46.848
    N6031 X16.151 Z-47.634
    N6032 X14.342 Z-48.323
    N6033 X12.559 Z-48.913
    N6034 X10.776 Z-49.418
    N6035 X8.958 Z-49.849
    N6036 X7.169 Z-50.192
    N6037 X5.362 Z-50.46
    N6038 X3.592 Z-50.648
    N6039 X1.797 Z-50.761
    N6040 X0. Z-50.8
    N6041 X-1.797 Z-50.761
    N6042 X-3.592 Z-50.648
    N6043 X-5.362 Z-50.46
    N6044 X-7.169 Z-50.192
    N6045 X-8.958 Z-49.849
    N6046 X-10.776 Z-49.418
    N6047 X-12.559 Z-48.913
    N6048 X-14.342 Z-48.323
    N6049 X-16.151 Z-47.634
    N6050 X-17.961 Z-46.848
    N6051 X-19.729 Z-45.98
    N6052 X-21.498 Z-45.007
    N6053 X-22.41 Z-44.462
    N6054 X-23.321 Z-43.886
    N6055 X-24.233 Z-43.278
    N6056 X-25.145 Z-42.634
    N6057 X-26.02 Z-41.981
    N6058 X-26.895 Z-41.292
    N6059 X-27.77 Z-40.565
    N6060 X-28.645 Z-39.796
    N6061 X-29.566 Z-38.941
    N6062 X-30.487 Z-38.035
    N6063 X-31.408 Z-37.073
    N6064 X-32.329 Z-36.043
    N6065 X-33.166 Z-35.047
    N6066 X-34.002 Z-33.989
    N6067 X-34.839 Z-32.859
    N6068 X-35.676 Z-31.638
    N6069 X-36.635 Z-30.125
    N6070 X-37.595 Z-28.455
    N6071 X-38.074 Z-27.548
    N6072 X-38.554 Z-26.583
    N6073 X-39.513 Z-24.44
    N6074 X-40.246 Z-22.553
    N6075 X-40.735 Z-21.126
    N6076 X-41.346 Z-19.058
    N6077 X-41.98 Z-16.328
    N6078 X-42.491 Z-13.111
    N6079 X-42.798 Z-9.748
    N6080 X-42.901 Z-9.105
    N6081 X-43.105 Z-8.22
    N6082 X-43.33 Z-7.496
    N6083 X-43.554 Z-6.906
    N6084 X-44.003 Z-5.952
    N6085 X-44.452 Z-5.184
    N6086 X-44.901 Z-4.527
    N6087 X-45.35 Z-3.957
    N6088 X-45.799 Z-3.462
    N6089 X-46.248 Z-3.014
    N6090 X-46.697 Z-2.617
    N6091 X-47.146 Z-2.26
    N6092 X-47.595 Z-1.936
    N6093 X-48.493 Z-1.385
    N6094 X-49.391 Z-.942
    N6095 X-50.289 Z-.593
    N6096 X-51.187 Z-.33
    N6097 X-52.085 Z-.145
    N6098 X-52.984 Z-.036
    N6099 X-53.882 Z0.
    N6100 Y58.175
    N6101 X-52.984 Z-.036
    N6102 X-52.085 Z-.145
    N6103 X-51.187 Z-.33
    N6104 X-50.289 Z-.593
    N6105 X-49.391 Z-.942
    N6106 X-48.493 Z-1.385
    N6107 X-47.595 Z-1.936
    N6108 X-47.146 Z-2.26
    N6109 X-46.697 Z-2.617
    N6110 X-46.248 Z-3.014
    N6111 X-45.799 Z-3.462
    N6112 X-45.35 Z-3.957
    N6113 X-44.901 Z-4.527
    N6114 X-44.452 Z-5.184
    N6115 X-44.003 Z-5.952
    N6116 X-43.554 Z-6.906
    N6117 X-43.33 Z-7.496
    N6118 X-43.105 Z-8.22
    N6119 X-42.901 Z-9.105
    N6120 X-42.798 Z-9.748
    N6121 X-42.491 Z-13.111
    N6122 X-41.98 Z-16.328
    N6123 X-41.346 Z-19.058
    N6124 X-40.735 Z-21.126
    N6125 X-40.246 Z-22.554
    N6126 X-39.513 Z-24.44
    N6127 X-38.554 Z-26.583
    N6128 X-38.074 Z-27.548
    N6129 X-37.595 Z-28.455
    N6130 X-36.635 Z-30.125
    N6131 X-35.676 Z-31.638
    N6132 X-34.839 Z-32.859
    N6133 X-34.002 Z-33.989
    N6134 X-33.166 Z-35.047
    N6135 X-32.329 Z-36.043
    N6136 X-31.408 Z-37.073
    N6137 X-30.487 Z-38.035
    N6138 X-29.566 Z-38.941
    N6139 X-28.645 Z-39.796
    N6140 X-27.77 Z-40.565
    N6141 X-26.895 Z-41.292
    N6142 X-26.02 Z-41.981
    N6143 X-25.145 Z-42.634
    N6144 X-24.233 Z-43.278
    N6145 X-23.321 Z-43.886
    N6146 X-22.41 Z-44.462
    N6147 X-21.498 Z-45.007
    N6148 X-19.729 Z-45.98
    N6149 X-17.961 Z-46.848
    N6150 X-16.151 Z-47.634
    N6151 X-14.342 Z-48.323
    N6152 X-12.559 Z-48.913
    N6153 X-10.776 Z-49.418
    N6154 X-8.958 Z-49.849
    N6155 X-7.169 Z-50.192
    N6156 X-5.362 Z-50.46
    N6157 X-3.592 Z-50.648
    N6158 X-1.797 Z-50.761
    N6159 X0. Z-50.8
    N6160 X1.797 Z-50.761
    N6161 X3.592 Z-50.648
    N6162 X5.362 Z-50.46
    N6163 X7.169 Z-50.192
    N6164 X8.958 Z-49.849
    N6165 X10.776 Z-49.418
    N6166 X12.559 Z-48.913
    N6167 X14.342 Z-48.323
    N6168 X16.151 Z-47.634
    N6169 X17.961 Z-46.848
    N6170 X18.845 Z-46.427
    N6171 X20.614 Z-45.507
    N6172 X22.41 Z-44.462
    N6173 X23.321 Z-43.886
    N6174 X24.233 Z-43.278
    N6175 X25.145 Z-42.634
    N6176 X26.02 Z-41.981
    N6177 X26.895 Z-41.292
    N6178 X27.77 Z-40.565
    N6179 X28.645 Z-39.796
    N6180 X29.566 Z-38.941
    N6181 X30.487 Z-38.035
    N6182 X31.408 Z-37.073
    N6183 X32.329 Z-36.043
    N6184 X33.166 Z-35.047
    N6185 X34.002 Z-33.989
    N6186 X34.839 Z-32.859
    N6187 X35.676 Z-31.638
    N6188 X36.156 Z-30.898
    N6189 X37.115 Z-29.312
    N6190 X38.074 Z-27.548
    N6191 X38.554 Z-26.583
    N6192 X39.033 Z-25.551
    N6193 X39.758 Z-23.846
    N6194 X40.491 Z-21.866
    N6195 X40.979 Z-20.339
    N6196 X41.571 Z-18.178
    N6197 X42.184 Z-15.229
    N6198 X42.44 Z-13.521
    N6199 X42.798 Z-9.748
    N6200 X43.003 Z-8.618
    N6201 X43.217 Z-7.836
    N6202 X43.554 Z-6.906
    N6203 X43.779 Z-6.407
    N6204 X44.228 Z-5.548
    N6205 X44.677 Z-4.839
    N6206 X45.35 Z-3.957
    N6207 X45.799 Z-3.462
    N6208 X46.248 Z-3.014
    N6209 X46.697 Z-2.617
    N6210 X47.146 Z-2.26
    N6211 X47.595 Z-1.936
    N6212 X48.493 Z-1.385
    N6213 X49.391 Z-.942
    N6214 X50.289 Z-.593
    N6215 X51.187 Z-.33
    N6216 X52.085 Z-.145
    N6217 X52.984 Z-.036
    N6218 X53.882 Z0.
    N6219 Y56.975
    N6220 X52.984 Z-.036
    N6221 X52.085 Z-.145
    N6222 X51.187 Z-.33
    N6223 X50.289 Z-.593
    N6224 X49.391 Z-.942
    N6225 X48.493 Z-1.385
    N6226 X47.595 Z-1.936
    N6227 X47.146 Z-2.26
    N6228 X46.697 Z-2.617
    N6229 X46.248 Z-3.014
    N6230 X45.799 Z-3.462
    N6231 X45.35 Z-3.957
    N6232 X44.677 Z-4.838
    N6233 X44.228 Z-5.548
    N6234 X43.779 Z-6.407
    N6235 X43.554 Z-6.906
    N6236 X43.217 Z-7.836
    N6237 X43.003 Z-8.618
    N6238 X42.798 Z-9.748
    N6239 X42.44 Z-13.521
    N6240 X42.184 Z-15.229
    N6241 X41.571 Z-18.178
    N6242 X40.979 Z-20.339
    N6243 X40.491 Z-21.866
    N6244 X39.758 Z-23.846
    N6245 X39.033 Z-25.551
    N6246 X38.554 Z-26.583
    N6247 X38.074 Z-27.548
    N6248 X37.115 Z-29.312
    N6249 X36.156 Z-30.898
    N6250 X35.676 Z-31.638
    N6251 X34.839 Z-32.859
    N6252 X34.002 Z-33.989
    N6253 X33.166 Z-35.047
    N6254 X32.329 Z-36.043
    N6255 X31.408 Z-37.073
    N6256 X30.487 Z-38.035
    N6257 X29.566 Z-38.941
    N6258 X28.645 Z-39.796
    N6259 X27.77 Z-40.565
    N6260 X26.895 Z-41.292
    N6261 X26.02 Z-41.981
    N6262 X25.145 Z-42.634
    N6263 X24.233 Z-43.278
    N6264 X23.321 Z-43.886
    N6265 X22.41 Z-44.462
    N6266 X20.614 Z-45.507
    N6267 X18.845 Z-46.427
    N6268 X17.961 Z-46.848
    N6269 X16.151 Z-47.634
    N6270 X14.342 Z-48.323
    N6271 X12.559 Z-48.913
    N6272 X10.776 Z-49.418
    N6273 X8.958 Z-49.849
    N6274 X7.169 Z-50.192
    N6275 X5.362 Z-50.46
    N6276 X3.592 Z-50.648
    N6277 X1.797 Z-50.761
    N6278 X0. Z-50.8
    N6279 X-1.797 Z-50.761
    N6280 X-3.592 Z-50.648
    N6281 X-5.362 Z-50.46
    N6282 X-7.169 Z-50.192
    N6283 X-8.958 Z-49.849
    N6284 X-10.776 Z-49.418
    N6285 X-12.559 Z-48.913
    N6286 X-14.342 Z-48.323
    N6287 X-16.151 Z-47.634
    N6288 X-17.961 Z-46.848
    N6289 X-19.729 Z-45.98
    N6290 X-21.498 Z-45.007
    N6291 X-22.41 Z-44.462
    N6292 X-23.321 Z-43.886
    N6293 X-24.233 Z-43.278
    N6294 X-25.145 Z-42.634
    N6295 X-26.02 Z-41.981
    N6296 X-26.895 Z-41.292
    N6297 X-27.77 Z-40.565
    N6298 X-28.645 Z-39.796
    N6299 X-29.566 Z-38.941
    N6300 X-30.487 Z-38.035
    N6301 X-31.408 Z-37.073
    N6302 X-32.329 Z-36.043
    N6303 X-33.166 Z-35.047
    N6304 X-34.002 Z-33.989
    N6305 X-34.839 Z-32.859
    N6306 X-35.676 Z-31.638
    N6307 X-36.635 Z-30.125
    N6308 X-37.595 Z-28.455
    N6309 X-38.074 Z-27.548
    N6310 X-38.554 Z-26.583
    N6311 X-39.513 Z-24.44
    N6312 X-40.246 Z-22.554
    N6313 X-40.735 Z-21.126
    N6314 X-41.346 Z-19.058
    N6315 X-41.98 Z-16.328
    N6316 X-42.491 Z-13.111
    N6317 X-42.798 Z-9.748
    N6318 X-42.901 Z-9.104
    N6319 X-43.105 Z-8.22
    N6320 X-43.33 Z-7.496
    N6321 X-43.554 Z-6.906
    N6322 X-44.003 Z-5.952
    N6323 X-44.452 Z-5.184
    N6324 X-44.901 Z-4.527
    N6325 X-45.35 Z-3.957
    N6326 X-45.799 Z-3.462
    N6327 X-46.248 Z-3.014
    N6328 X-46.697 Z-2.617
    N6329 X-47.146 Z-2.26
    N6330 X-47.595 Z-1.936
    N6331 X-48.493 Z-1.385
    N6332 X-49.391 Z-.942
    N6333 X-50.289 Z-.593
    N6334 X-51.187 Z-.33
    N6335 X-52.085 Z-.145
    N6336 X-52.984 Z-.036
    N6337 X-53.882 Z0.
    N6338 Y55.775
    N6339 X-52.984 Z-.036
    N6340 X-52.085 Z-.145
    N6341 X-51.187 Z-.33
    N6342 X-50.289 Z-.593
    N6343 X-49.391 Z-.942
    N6344 X-48.493 Z-1.385
    N6345 X-47.595 Z-1.936
    N6346 X-47.146 Z-2.26
    N6347 X-46.697 Z-2.617
    N6348 X-46.248 Z-3.014
    N6349 X-45.799 Z-3.462
    N6350 X-45.35 Z-3.957
    N6351 X-44.901 Z-4.527
    N6352 X-44.452 Z-5.184
    N6353 X-44.003 Z-5.952
    N6354 X-43.554 Z-6.906
    N6355 X-43.33 Z-7.496
    N6356 X-43.105 Z-8.22
    N6357 X-42.901 Z-9.104
    N6358 X-42.798 Z-9.748
    N6359 X-42.491 Z-13.111
    N6360 X-41.98 Z-16.328
    N6361 X-41.346 Z-19.058
    N6362 X-40.491 Z-21.866
    N6363 X-39.758 Z-23.846
    N6364 X-39.033 Z-25.551
    N6365 X-38.554 Z-26.583
    N6366 X-38.074 Z-27.548
    N6367 X-37.595 Z-28.455
    N6368 X-36.635 Z-30.125
    N6369 X-35.676 Z-31.638
    N6370 X-34.839 Z-32.859
    N6371 X-34.002 Z-33.989
    N6372 X-33.166 Z-35.047
    N6373 X-32.329 Z-36.043
    N6374 X-31.408 Z-37.073
    N6375 X-30.487 Z-38.035
    N6376 X-29.566 Z-38.941
    N6377 X-28.645 Z-39.796
    N6378 X-27.77 Z-40.565
    N6379 X-26.895 Z-41.292
    N6380 X-26.02 Z-41.981
    N6381 X-25.145 Z-42.634
    N6382 X-24.233 Z-43.278
    N6383 X-23.321 Z-43.886
    N6384 X-22.41 Z-44.462
    N6385 X-21.498 Z-45.007
    N6386 X-19.729 Z-45.98
    N6387 X-17.961 Z-46.848
    N6388 X-16.151 Z-47.634
    N6389 X-14.342 Z-48.323
    N6390 X-12.559 Z-48.913
    N6391 X-10.776 Z-49.418
    N6392 X-8.958 Z-49.849
    N6393 X-7.169 Z-50.192
    N6394 X-5.362 Z-50.46
    N6395 X-3.592 Z-50.648
    N6396 X-1.797 Z-50.761
    N6397 X0. Z-50.8
    N6398 X1.797 Z-50.761
    N6399 X3.592 Z-50.648
    N6400 X5.362 Z-50.46
    N6401 X7.169 Z-50.192
    N6402 X8.958 Z-49.849
    N6403 X10.776 Z-49.418
    N6404 X12.559 Z-48.913
    N6405 X14.342 Z-48.323
    N6406 X16.151 Z-47.634
    N6407 X17.961 Z-46.848
    N6408 X18.845 Z-46.427
    N6409 X20.614 Z-45.507
    N6410 X22.41 Z-44.462
    N6411 X23.321 Z-43.886
    N6412 X24.233 Z-43.278
    N6413 X25.145 Z-42.634
    N6414 X26.02 Z-41.981
    N6415 X26.895 Z-41.292
    N6416 X27.77 Z-40.565
    N6417 X28.645 Z-39.796
    N6418 X29.566 Z-38.941
    N6419 X30.487 Z-38.035
    N6420 X31.408 Z-37.073
    N6421 X32.329 Z-36.043
    N6422 X33.166 Z-35.047
    N6423 X34.002 Z-33.989
    N6424 X34.839 Z-32.859
    N6425 X35.676 Z-31.638
    N6426 X36.156 Z-30.898
    N6427 X37.115 Z-29.312
    N6428 X38.074 Z-27.548
    N6429 X38.554 Z-26.583
    N6430 X39.033 Z-25.551
    N6431 X39.758 Z-23.846
    N6432 X40.491 Z-21.866
    N6433 X40.979 Z-20.339
    N6434 X41.571 Z-18.178
    N6435 X42.184 Z-15.229
    N6436 X42.44 Z-13.521
    N6437 X42.798 Z-9.748
    N6438 X43.003 Z-8.618
    N6439 X43.217 Z-7.836
    N6440 X43.554 Z-6.906
    N6441 X43.779 Z-6.407
    N6442 X44.228 Z-5.548
    N6443 X44.677 Z-4.838
    N6444 X45.35 Z-3.957
    N6445 X45.799 Z-3.462
    N6446 X46.248 Z-3.014
    N6447 X46.697 Z-2.617
    N6448 X47.146 Z-2.26
    N6449 X47.595 Z-1.936
    N6450 X48.493 Z-1.385
    N6451 X49.391 Z-.942
    N6452 X50.289 Z-.593
    N6453 X51.187 Z-.33
    N6454 X52.085 Z-.145
    N6455 X52.984 Z-.036
    N6456 X53.882 Z0.
    N6457 Y54.575
    N6458 X52.984 Z-.036
    N6459 X52.085 Z-.145
    N6460 X51.187 Z-.33
    N6461 X50.289 Z-.593
    N6462 X49.391 Z-.942
    N6463 X48.493 Z-1.385
    N6464 X47.595 Z-1.936
    N6465 X47.146 Z-2.26
    N6466 X46.697 Z-2.617
    N6467 X46.248 Z-3.014
    N6468 X45.799 Z-3.462
    N6469 X45.35 Z-3.957
    N6470 X44.677 Z-4.838
    N6471 X44.228 Z-5.548
    N6472 X43.779 Z-6.407
    N6473 X43.554 Z-6.906
    N6474 X43.217 Z-7.836
    N6475 X43.003 Z-8.618
    N6476 X42.798 Z-9.748
    N6477 X42.44 Z-13.521
    N6478 X42.184 Z-15.229
    N6479 X41.571 Z-18.178
    N6480 X40.979 Z-20.339
    N6481 X40.491 Z-21.866
    N6482 X39.758 Z-23.846
    N6483 X39.033 Z-25.551
    N6484 X38.554 Z-26.583
    N6485 X38.074 Z-27.548
    N6486 X37.115 Z-29.312
    N6487 X36.156 Z-30.898
    N6488 X35.676 Z-31.638
    N6489 X34.839 Z-32.859
    N6490 X34.002 Z-33.989
    N6491 X33.166 Z-35.047
    N6492 X32.329 Z-36.043
    N6493 X31.408 Z-37.073
    N6494 X30.487 Z-38.035
    N6495 X29.566 Z-38.941
    N6496 X28.645 Z-39.796
    N6497 X27.77 Z-40.565
    N6498 X26.895 Z-41.292
    N6499 X26.02 Z-41.981
    N6500 X25.145 Z-42.634
    N6501 X24.233 Z-43.278
    N6502 X23.321 Z-43.886
    N6503 X22.41 Z-44.462
    N6504 X20.614 Z-45.507
    N6505 X18.845 Z-46.427
    N6506 X17.961 Z-46.848
    N6507 X16.151 Z-47.634
    N6508 X14.342 Z-48.323
    N6509 X12.559 Z-48.913
    N6510 X10.776 Z-49.418
    N6511 X8.958 Z-49.849
    N6512 X7.169 Z-50.192
    N6513 X5.362 Z-50.46
    N6514 X3.592 Z-50.648
    N6515 X1.797 Z-50.761
    N6516 X0. Z-50.8
    N6517 X-1.797 Z-50.761
    N6518 X-3.592 Z-50.648
    N6519 X-5.362 Z-50.46
    N6520 X-7.169 Z-50.192
    N6521 X-8.958 Z-49.849
    N6522 X-10.776 Z-49.418
    N6523 X-12.559 Z-48.913
    N6524 X-14.342 Z-48.323
    N6525 X-16.151 Z-47.634
    N6526 X-17.961 Z-46.848
    N6527 X-19.729 Z-45.98
    N6528 X-21.498 Z-45.007
    N6529 X-22.41 Z-44.462
    N6530 X-23.321 Z-43.886
    N6531 X-24.233 Z-43.278
    N6532 X-25.145 Z-42.634
    N6533 X-26.02 Z-41.981
    N6534 X-26.895 Z-41.292
    N6535 X-27.77 Z-40.565
    N6536 X-28.645 Z-39.796
    N6537 X-29.566 Z-38.941
    N6538 X-30.487 Z-38.035
    N6539 X-31.408 Z-37.073
    N6540 X-32.329 Z-36.043
    N6541 X-33.166 Z-35.047
    N6542 X-34.002 Z-33.989
    N6543 X-34.839 Z-32.859
    N6544 X-35.676 Z-31.638
    N6545 X-36.635 Z-30.125
    N6546 X-37.595 Z-28.455
    N6547 X-38.074 Z-27.548
    N6548 X-38.554 Z-26.583
    N6549 X-39.033 Z-25.551
    N6550 X-39.758 Z-23.846
    N6551 X-40.491 Z-21.866
    N6552 X-41.346 Z-19.058
    N6553 X-41.98 Z-16.328
    N6554 X-42.491 Z-13.111
    N6555 X-42.798 Z-9.748
    N6556 X-42.901 Z-9.104
    N6557 X-43.105 Z-8.22
    N6558 X-43.33 Z-7.496
    N6559 X-43.554 Z-6.906
    N6560 X-44.003 Z-5.952
    N6561 X-44.452 Z-5.184
    N6562 X-44.901 Z-4.527
    N6563 X-45.35 Z-3.957
    N6564 X-45.799 Z-3.462
    N6565 X-46.248 Z-3.014
    N6566 X-46.697 Z-2.617
    N6567 X-47.146 Z-2.26
    N6568 X-47.595 Z-1.936
    N6569 X-48.493 Z-1.385
    N6570 X-49.391 Z-.942
    N6571 X-50.289 Z-.593
    N6572 X-51.187 Z-.33
    N6573 X-52.085 Z-.145
    N6574 X-52.984 Z-.036
    N6575 X-53.882 Z0.
    N6576 X-129.021 Y53.375
    N6577 X-53.126 Z-.03
    N6578 X-52.178 Z-.131
    N6579 X-51.229 Z-.319
    N6580 X-50.28 Z-.596
    N6581 X-49.332 Z-.968
    N6582 X-48.383 Z-1.447
    N6583 X-47.909 Z-1.732
    N6584 X-47.434 Z-2.05
    N6585 X-46.96 Z-2.402
    N6586 X-46.486 Z-2.802
    N6587 X-46.011 Z-3.242
    N6588 X-45.3 Z-4.018
    N6589 X-44.588 Z-4.97
    N6590 X-44.114 Z-5.746
    N6591 X-43.64 Z-6.706
    N6592 X-43.284 Z-7.633
    N6593 X-43.047 Z-8.441
    N6594 X-42.809 Z-9.668
    N6595 X-42.454 Z-13.422
    N6596 X-42.216 Z-15.03
    N6597 X-41.861 Z-16.905
    N6598 X-41.386 Z-18.901
    N6599 X-40.793 Z-20.949
    N6600 X-40.082 Z-23.003
    N6601 X-39.37 Z-24.785
    N6602 X-38.896 Z-25.853
    N6603 X-38.422 Z-26.851
    N6604 X-37.947 Z-27.788
    N6605 X-37.448 Z-28.718
    N6606 X-36.448 Z-30.432
    N6607 X-35.448 Z-31.982
    N6608 X-34.449 Z-33.393
    N6609 X-33.5 Z-34.636
    N6610 X-32.153 Z-36.247
    N6611 X-31.256 Z-37.234
    N6612 X-30.358 Z-38.165
    N6613 X-29.394 Z-39.106
    N6614 X-28.43 Z-39.992
    N6615 X-27.466 Z-40.821
    N6616 X-26.502 Z-41.603
    N6617 X-25.569 Z-42.318
    N6618 X-24.635 Z-42.994
    N6619 X-23.702 Z-43.634
    N6620 X-22.768 Z-44.238
    N6621 X-21.808 Z-44.824
    N6622 X-20.847 Z-45.377
    N6623 X-19.886 Z-45.897
    N6624 X-18.926 Z-46.387
    N6625 X-17.052 Z-47.255
    N6626 X-15.179 Z-48.016
    N6627 X-13.242 Z-48.699
    N6628 X-11.361 Z-49.263
    N6629 X-9.443 Z-49.744
    N6630 X-7.589 Z-50.12
    N6631 X-5.682 Z-50.42
    N6632 X-3.788 Z-50.631
    N6633 X-1.883 Z-50.758
    N6634 X0. Z-50.8
    N6635 X1.883 Z-50.758
    N6636 X3.788 Z-50.631
    N6637 X5.682 Z-50.42
    N6638 X7.589 Z-50.12
    N6639 X9.443 Z-49.744
    N6640 X11.361 Z-49.263
    N6641 X13.242 Z-48.699
    N6642 X15.179 Z-48.016
    N6643 X17.052 Z-47.255
    N6644 X18.926 Z-46.387
    N6645 X19.886 Z-45.897
    N6646 X20.847 Z-45.377
    N6647 X21.808 Z-44.824
    N6648 X22.768 Z-44.238
    N6649 X23.702 Z-43.634
    N6650 X24.635 Z-42.994
    N6651 X25.569 Z-42.318
    N6652 X26.502 Z-41.603
    N6653 X27.466 Z-40.821
    N6654 X28.43 Z-39.992
    N6655 X29.394 Z-39.106
    N6656 X30.358 Z-38.165
    N6657 X31.256 Z-37.234
    N6658 X32.153 Z-36.247
    N6659 X33.5 Z-34.636
    N6660 X34.949 Z-32.702
    N6661 X35.948 Z-31.226
    N6662 X36.948 Z-29.597
    N6663 X37.947 Z-27.788
    N6664 X38.422 Z-26.851
    N6665 X38.896 Z-25.853
    N6666 X39.37 Z-24.785
    N6667 X40.082 Z-23.003
    N6668 X40.793 Z-20.949
    N6669 X41.386 Z-18.901
    N6670 X41.979 Z-16.331
    N6671 X42.335 Z-14.287
    N6672 X42.572 Z-12.403
    N6673 X42.78 Z-9.898
    N6674 X42.987 Z-8.686
    N6675 X43.284 Z-7.633
    N6676 X43.64 Z-6.706
    N6677 X44.114 Z-5.746
    N6678 X44.588 Z-4.97
    N6679 X44.825 Z-4.629
    N6680 X45.3 Z-4.018
    N6681 X46.011 Z-3.242
    N6682 X46.486 Z-2.802
    N6683 X46.96 Z-2.402
    N6684 X47.434 Z-2.05
    N6685 X47.909 Z-1.731
    N6686 X48.383 Z-1.447
    N6687 X49.332 Z-.968
    N6688 X50.28 Z-.596
    N6689 X51.229 Z-.319
    N6690 X52.178 Z-.131
    N6691 X53.126 Z-.03
    N6692 X60.716 Z-.014
    N6693 X129.021 Z0.
    N6694 X129.944 Y52.175
    N6695 X128.869 Z-.048
    N6696 X127.794 Z-.125
    N6697 X53.834 Z-.131
    N6698 X52.906 Z-.145
    N6699 X51.978 Z-.231
    N6700 X51.05 Z-.407
    N6701 X50.121 Z-.675
    N6702 X49.657 Z-.843
    N6703 X48.729 Z-1.262
    N6704 X47.801 Z-1.799
    N6705 X46.873 Z-2.471
    N6706 X46.409 Z-2.87
    N6707 X45.945 Z-3.31
    N6708 X45.48 Z-3.807
    N6709 X44.784 Z-4.685
    N6710 X44.552 Z-5.026
    N6711 X44.088 Z-5.792
    N6712 X43.624 Z-6.741
    N6713 X43.276 Z-7.656
    N6714 X42.986 Z-8.692
    N6715 X42.783 Z-9.87
    N6716 X42.58 Z-12.324
    N6717 X42.348 Z-14.196
    N6718 X42. Z-16.231
    N6719 X41.768 Z-17.332
    N6720 X41.304 Z-19.21
    N6721 X40.84 Z-20.798
    N6722 X40.082 Z-23.004
    N6723 X39.323 Z-24.892
    N6724 X38.565 Z-26.559
    N6725 X37.807 Z-28.053
    N6726 X36.796 Z-29.853
    N6727 X35.951 Z-31.222
    N6728 X35.105 Z-32.477
    N6729 X34.26 Z-33.65
    N6730 X33.414 Z-34.742
    N6731 X32.462 Z-35.888
    N6732 X31.51 Z-36.962
    N6733 X30.558 Z-37.963
    N6734 X29.606 Z-38.903
    N6735 X28.702 Z-39.745
    N6736 X27.798 Z-40.541
    N6737 X26.893 Z-41.293
    N6738 X25.989 Z-42.005
    N6739 X25.046 Z-42.705
    N6740 X24.102 Z-43.365
    N6741 X23.159 Z-43.989
    N6742 X22.216 Z-44.579
    N6743 X21.303 Z-45.118
    N6744 X19.476 Z-46.108
    N6745 X17.627 Z-46.998
    N6746 X15.755 Z-47.791
    N6747 X14.819 Z-48.15
    N6748 X12.978 Z-48.782
    N6749 X11.138 Z-49.323
    N6750 X9.256 Z-49.786
    N6751 X7.406 Z-50.153
    N6752 X5.54 Z-50.439
    N6753 X3.713 Z-50.638
    N6754 X1.858 Z-50.759
    N6755 X0. Z-50.8
    N6756 X-1.858 Z-50.759
    N6757 X-3.713 Z-50.638
    N6758 X-5.54 Z-50.439
    N6759 X-7.406 Z-50.153
    N6760 X-9.256 Z-49.786
    N6761 X-11.138 Z-49.323
    N6762 X-12.978 Z-48.782
    N6763 X-14.819 Z-48.15
    N6764 X-16.691 Z-47.408
    N6765 X-18.563 Z-46.561
    N6766 X-20.39 Z-45.627
    N6767 X-21.303 Z-45.118
    N6768 X-22.216 Z-44.579
    N6769 X-23.159 Z-43.989
    N6770 X-24.102 Z-43.365
    N6771 X-25.046 Z-42.705
    N6772 X-25.989 Z-42.005
    N6773 X-26.893 Z-41.293
    N6774 X-27.798 Z-40.541
    N6775 X-28.702 Z-39.745
    N6776 X-29.606 Z-38.903
    N6777 X-30.558 Z-37.963
    N6778 X-31.51 Z-36.962
    N6779 X-32.462 Z-35.888
    N6780 X-33.414 Z-34.742
    N6781 X-34.26 Z-33.65
    N6782 X-35.105 Z-32.477
    N6783 X-35.951 Z-31.222
    N6784 X-36.796 Z-29.853
    N6785 X-38.06 Z-27.576
    N6786 X-38.818 Z-26.02
    N6787 X-39.323 Z-24.892
    N6788 X-40.082 Z-23.004
    N6789 X-40.587 Z-21.574
    N6790 X-41.072 Z-20.036
    N6791 X-41.536 Z-18.315
    N6792 X-41.768 Z-17.332
    N6793 X-42.232 Z-14.933
    N6794 X-42.464 Z-13.347
    N6795 X-42.812 Z-9.65
    N6796 X-43.044 Z-8.451
    N6797 X-43.392 Z-7.322
    N6798 X-43.624 Z-6.741
    N6799 X-44.088 Z-5.792
    N6800 X-44.552 Z-5.025
    N6801 X-45.016 Z-4.378
    N6802 X-45.48 Z-3.807
    N6803 X-45.945 Z-3.31
    N6804 X-46.409 Z-2.87
    N6805 X-46.873 Z-2.471
    N6806 X-47.801 Z-1.799
    N6807 X-48.729 Z-1.262
    N6808 X-49.657 Z-.843
    N6809 X-50.121 Z-.675
    N6810 X-51.05 Z-.407
    N6811 X-51.978 Z-.231
    N6812 X-52.906 Z-.145
    N6813 X-127.804 Z-.125
    N6814 X-128.874 Z-.048
    N6815 X-129.944 Z0.
    N6816 X-130.166 Y50.975
    N6817 X-129.236 Z-.039
    N6818 X-128.307 Z-.156
    N6819 X-127.132 Z-.384
    N6820 X-52.996 Z-.386
    N6821 X-52.066 Z-.435
    N6822 X-51.137 Z-.575
    N6823 X-50.672 Z-.678
    N6824 X-49.742 Z-.957
    N6825 X-48.812 Z-1.34
    N6826 X-48.347 Z-1.573
    N6827 X-47.418 Z-2.133
    N6828 X-46.953 Z-2.471
    N6829 X-46.488 Z-2.842
    N6830 X-46.023 Z-3.27
    N6831 X-45.558 Z-3.743
    N6832 X-45.093 Z-4.293
    N6833 X-44.628 Z-4.92
    N6834 X-44.164 Z-5.66
    N6835 X-43.931 Z-6.096
    N6836 X-43.582 Z-6.838
    N6837 X-43.234 Z-7.786
    N6838 X-43.001 Z-8.625
    N6839 X-42.827 Z-9.548
    N6840 X-42.478 Z-13.225
    N6841 X-42.188 Z-15.21
    N6842 X-41.839 Z-17.01
    N6843 X-41.374 Z-18.949
    N6844 X-40.909 Z-20.569
    N6845 X-40.148 Z-22.829
    N6846 X-39.386 Z-24.748
    N6847 X-38.879 Z-25.89
    N6848 X-38.371 Z-26.953
    N6849 X-37.863 Z-27.947
    N6850 X-36.848 Z-29.765
    N6851 X-36.004 Z-31.14
    N6852 X-34.738 Z-33.
    N6853 X-33.471 Z-34.672
    N6854 X-32.516 Z-35.825
    N6855 X-31.56 Z-36.907
    N6856 X-30.604 Z-37.917
    N6857 X-29.648 Z-38.862
    N6858 X-28.745 Z-39.706
    N6859 X-27.841 Z-40.503
    N6860 X-26.937 Z-41.257
    N6861 X-26.033 Z-41.97
    N6862 X-25.09 Z-42.673
    N6863 X-24.147 Z-43.336
    N6864 X-23.203 Z-43.961
    N6865 X-22.26 Z-44.552
    N6866 X-21.344 Z-45.095
    N6867 X-20.428 Z-45.607
    N6868 X-18.595 Z-46.546
    N6869 X-16.719 Z-47.396
    N6870 X-14.844 Z-48.14
    N6871 X-13. Z-48.775
    N6872 X-11.157 Z-49.318
    N6873 X-9.272 Z-49.782
    N6874 X-7.421 Z-50.151
    N6875 X-5.554 Z-50.438
    N6876 X-3.719 Z-50.637
    N6877 X-1.862 Z-50.759
    N6878 X0. Z-50.8
    N6879 X1.862 Z-50.759
    N6880 X3.719 Z-50.637
    N6881 X5.554 Z-50.438
    N6882 X7.421 Z-50.151
    N6883 X9.272 Z-49.782
    N6884 X11.157 Z-49.318
    N6885 X13. Z-48.775
    N6886 X14.844 Z-48.14
    N6887 X15.782 Z-47.781
    N6888 X17.657 Z-46.985
    N6889 X19.511 Z-46.09
    N6890 X21.344 Z-45.095
    N6891 X22.26 Z-44.552
    N6892 X23.203 Z-43.961
    N6893 X24.147 Z-43.336
    N6894 X25.09 Z-42.673
    N6895 X26.033 Z-41.97
    N6896 X26.937 Z-41.257
    N6897 X27.841 Z-40.503
    N6898 X28.745 Z-39.706
    N6899 X29.648 Z-38.862
    N6900 X30.604 Z-37.917
    N6901 X31.56 Z-36.907
    N6902 X32.516 Z-35.825
    N6903 X33.471 Z-34.672
    N6904 X34.738 Z-33.
    N6905 X36.004 Z-31.14
    N6906 X36.848 Z-29.765
    N6907 X37.863 Z-27.947
    N6908 X38.371 Z-26.953
    N6909 X38.879 Z-25.89
    N6910 X39.386 Z-24.748
    N6911 X40.148 Z-22.829
    N6912 X40.656 Z-21.367
    N6913 X41.374 Z-18.949
    N6914 X41.839 Z-17.01
    N6915 X42.188 Z-15.21
    N6916 X42.478 Z-13.225
    N6917 X42.798 Z-9.751
    N6918 X43.001 Z-8.625
    N6919 X43.234 Z-7.786
    N6920 X43.582 Z-6.838
    N6921 X44.164 Z-5.66
    N6922 X44.628 Z-4.92
    N6923 X44.861 Z-4.59
    N6924 X45.558 Z-3.743
    N6925 X46.023 Z-3.27
    N6926 X46.488 Z-2.842
    N6927 X46.953 Z-2.471
    N6928 X47.418 Z-2.133
    N6929 X48.347 Z-1.573
    N6930 X48.812 Z-1.34
    N6931 X49.742 Z-.957
    N6932 X50.207 Z-.808
    N6933 X51.137 Z-.574
    N6934 X52.066 Z-.435
    N6935 X52.996 Z-.386
    N6936 X127.132 Z-.384
    N6937 X128.307 Z-.156
    N6938 X129.236 Z-.039
    N6939 X130.166 Z0.
    N6940 X130.175 Y49.775
    N6941 X129.245 Z-.039
    N6942 X128.315 Z-.156
    N6943 X127.386 Z-.354
    N6944 X126.107 Z-.767
    N6945 X125.991 Z-.782
    N6946 X55.789 Z-.785
    N6947 X52.07 Z-.804
    N6948 X51.14 Z-.916
    N6949 X50.675 Z-1.008
    N6950 X49.745 Z-1.263
    N6951 X48.816 Z-1.625
    N6952 X48.351 Z-1.847
    N6953 X47.421 Z-2.389
    N6954 X46.956 Z-2.718
    N6955 X46.491 Z-3.082
    N6956 X46.026 Z-3.498
    N6957 X45.561 Z-3.967
    N6958 X45.096 Z-4.507
    N6959 X44.631 Z-5.127
    N6960 X44.167 Z-5.875
    N6961 X43.934 Z-6.295
    N6962 X43.585 Z-7.045
    N6963 X43.237 Z-8.014
    N6964 X42.946 Z-9.187
    N6965 X42.801 Z-10.257
    N6966 X42.481 Z-13.389
    N6967 X42.191 Z-15.222
    N6968 X41.842 Z-16.996
    N6969 X41.377 Z-18.938
    N6970 X40.658 Z-21.359
    N6971 X40.151 Z-22.822
    N6972 X39.389 Z-24.742
    N6973 X38.881 Z-25.885
    N6974 X38.373 Z-26.948
    N6975 X37.866 Z-27.943
    N6976 X36.85 Z-29.762
    N6977 X36.006 Z-31.137
    N6978 X34.74 Z-32.997
    N6979 X33.474 Z-34.669
    N6980 X32.518 Z-35.823
    N6981 X31.562 Z-36.905
    N6982 X30.606 Z-37.915
    N6983 X29.65 Z-38.861
    N6984 X28.746 Z-39.704
    N6985 X27.843 Z-40.502
    N6986 X26.939 Z-41.256
    N6987 X26.035 Z-41.969
    N6988 X25.092 Z-42.672
    N6989 X24.148 Z-43.334
    N6990 X23.205 Z-43.96
    N6991 X22.262 Z-44.551
    N6992 X21.345 Z-45.094
    N6993 X19.513 Z-46.09
    N6994 X17.658 Z-46.984
    N6995 X15.783 Z-47.781
    N6996 X14.845 Z-48.14
    N6997 X13.001 Z-48.775
    N6998 X11.158 Z-49.318
    N6999 X9.273 Z-49.782
    N7000 X7.422 Z-50.151
    N7001 X5.554 Z-50.437
    N7002 X3.719 Z-50.637
    N7003 X1.862 Z-50.759
    N7004 X0. Z-50.8
    N7005 X-1.862 Z-50.759
    N7006 X-3.719 Z-50.637
    N7007 X-5.554 Z-50.437
    N7008 X-7.422 Z-50.151
    N7009 X-9.273 Z-49.782
    N7010 X-11.158 Z-49.318
    N7011 X-13.001 Z-48.775
    N7012 X-14.845 Z-48.14
    N7013 X-16.721 Z-47.395
    N7014 X-18.596 Z-46.545
    N7015 X-20.429 Z-45.606
    N7016 X-21.345 Z-45.094
    N7017 X-22.262 Z-44.551
    N7018 X-23.205 Z-43.96
    N7019 X-24.148 Z-43.334
    N7020 X-25.092 Z-42.672
    N7021 X-26.035 Z-41.969
    N7022 X-26.939 Z-41.256
    N7023 X-27.843 Z-40.502
    N7024 X-28.746 Z-39.704
    N7025 X-29.65 Z-38.861
    N7026 X-30.606 Z-37.915
    N7027 X-31.562 Z-36.905
    N7028 X-32.518 Z-35.823
    N7029 X-33.474 Z-34.669
    N7030 X-34.74 Z-32.997
    N7031 X-36.006 Z-31.137
    N7032 X-36.85 Z-29.762
    N7033 X-37.866 Z-27.943
    N7034 X-38.373 Z-26.948
    N7035 X-38.881 Z-25.885
    N7036 X-39.389 Z-24.742
    N7037 X-40.151 Z-22.822
    N7038 X-41.028 Z-20.178
    N7039 X-41.377 Z-18.938
    N7040 X-41.842 Z-16.996
    N7041 X-42.191 Z-15.222
    N7042 X-42.656 Z-11.943
    N7043 X-42.888 Z-9.531
    N7044 X-43.004 Z-8.901
    N7045 X-43.237 Z-8.014
    N7046 X-43.585 Z-7.045
    N7047 X-43.934 Z-6.295
    N7048 X-44.399 Z-5.48
    N7049 X-44.631 Z-5.127
    N7050 X-45.096 Z-4.507
    N7051 X-45.561 Z-3.968
    N7052 X-46.026 Z-3.498
    N7053 X-46.491 Z-3.082
    N7054 X-46.956 Z-2.718
    N7055 X-47.421 Z-2.389
    N7056 X-48.351 Z-1.847
    N7057 X-49.281 Z-1.432
    N7058 X-49.745 Z-1.263
    N7059 X-50.675 Z-1.007
    N7060 X-51.14 Z-.916
    N7061 X-52.07 Z-.804
    N7062 X-55.789 Z-.785
    N7063 X-125.991 Z-.782
    N7064 X-126.107 Z-.767
    N7065 X-126.456 Z-.638
    N7066 X-127.386 Z-.354
    N7067 X-128.315 Z-.156
    N7068 X-129.245 Z-.039
    N7069 X-130.175 Z0.
    N7070 Y48.575
    N7071 X-129.245 Z-.039
    N7072 X-128.315 Z-.156
    N7073 X-127.386 Z-.354
    N7074 X-126.456 Z-.638
    N7075 X-125.554 Z-1.002
    N7076 X-124.878 Z-1.339
    N7077 X-52.07 Z-1.346
    N7078 X-51.14 Z-1.429
    N7079 X-50.675 Z-1.509
    N7080 X-49.745 Z-1.744
    N7081 X-49.281 Z-1.905
    N7082 X-48.351 Z-2.309
    N7083 X-47.421 Z-2.847
    N7084 X-46.956 Z-3.173
    N7085 X-46.491 Z-3.546
    N7086 X-46.026 Z-3.962
    N7087 X-45.561 Z-4.451
    N7088 X-45.096 Z-4.999
    N7089 X-44.864 Z-5.316
    N7090 X-44.399 Z-6.025
    N7091 X-43.934 Z-6.909
    N7092 X-43.702 Z-7.451
    N7093 X-43.469 Z-8.107
    N7094 X-43.237 Z-8.972
    N7095 X-43.12 Z-9.586
    N7096 X-42.83 Z-12.275
    N7097 X-42.539 Z-14.125
    N7098 X-42.191 Z-15.834
    N7099 X-41.61 Z-18.161
    N7100 X-40.912 Z-20.56
    N7101 X-40.151 Z-22.822
    N7102 X-39.389 Z-24.742
    N7103 X-38.881 Z-25.885
    N7104 X-38.373 Z-26.948
    N7105 X-37.866 Z-27.943
    N7106 X-36.85 Z-29.762
    N7107 X-36.006 Z-31.137
    N7108 X-34.74 Z-32.997
    N7109 X-33.474 Z-34.669
    N7110 X-32.518 Z-35.823
    N7111 X-31.562 Z-36.905
    N7112 X-30.606 Z-37.915
    N7113 X-29.65 Z-38.861
    N7114 X-28.746 Z-39.704
    N7115 X-27.843 Z-40.502
    N7116 X-26.939 Z-41.256
    N7117 X-26.035 Z-41.969
    N7118 X-25.092 Z-42.672
    N7119 X-24.148 Z-43.334
    N7120 X-23.205 Z-43.96
    N7121 X-22.262 Z-44.551
    N7122 X-21.345 Z-45.094
    N7123 X-20.429 Z-45.606
    N7124 X-18.596 Z-46.545
    N7125 X-16.721 Z-47.395
    N7126 X-14.845 Z-48.14
    N7127 X-13.001 Z-48.775
    N7128 X-11.158 Z-49.318
    N7129 X-9.273 Z-49.782
    N7130 X-7.422 Z-50.151
    N7131 X-5.554 Z-50.437
    N7132 X-3.719 Z-50.637
    N7133 X-1.862 Z-50.759
    N7134 X0. Z-50.8
    N7135 X1.862 Z-50.759
    N7136 X3.719 Z-50.637
    N7137 X5.554 Z-50.437
    N7138 X7.422 Z-50.151
    N7139 X9.273 Z-49.782
    N7140 X11.158 Z-49.318
    N7141 X13.001 Z-48.775
    N7142 X14.845 Z-48.14
    N7143 X15.783 Z-47.781
    N7144 X17.658 Z-46.984
    N7145 X19.513 Z-46.09
    N7146 X21.345 Z-45.094
    N7147 X22.262 Z-44.551
    N7148 X23.205 Z-43.96
    N7149 X24.148 Z-43.334
    N7150 X25.092 Z-42.672
    N7151 X26.035 Z-41.969
    N7152 X26.939 Z-41.256
    N7153 X27.843 Z-40.502
    N7154 X28.746 Z-39.704
    N7155 X29.65 Z-38.861
    N7156 X30.606 Z-37.915
    N7157 X31.562 Z-36.905
    N7158 X32.518 Z-35.823
    N7159 X33.474 Z-34.669
    N7160 X34.74 Z-32.997
    N7161 X36.006 Z-31.137
    N7162 X36.85 Z-29.762
    N7163 X37.866 Z-27.943
    N7164 X38.373 Z-26.948
    N7165 X38.881 Z-25.885
    N7166 X39.389 Z-24.742
    N7167 X40.151 Z-22.822
    N7168 X40.658 Z-21.359
    N7169 X41.145 Z-19.795
    N7170 X41.842 Z-17.278
    N7171 X42.307 Z-15.294
    N7172 X42.714 Z-13.092
    N7173 X43.12 Z-9.586
    N7174 X43.353 Z-8.507
    N7175 X43.585 Z-7.765
    N7176 X43.934 Z-6.909
    N7177 X44.399 Z-6.025
    N7178 X44.631 Z-5.66
    N7179 X45.096 Z-4.999
    N7180 X45.561 Z-4.451
    N7181 X46.026 Z-3.962
    N7182 X46.491 Z-3.546
    N7183 X46.956 Z-3.173
    N7184 X47.421 Z-2.847
    N7185 X48.351 Z-2.309
    N7186 X49.281 Z-1.906
    N7187 X49.745 Z-1.744
    N7188 X50.675 Z-1.509
    N7189 X51.14 Z-1.429
    N7190 X52.07 Z-1.347
    N7191 X124.878 Z-1.339
    N7192 X125.554 Z-1.002
    N7193 X126.456 Z-.638
    N7194 X127.386 Z-.354
    N7195 X128.315 Z-.156
    N7196 X129.245 Z-.039
    N7197 X130.175 Z0.
    N7198 Y47.375
    N7199 X129.245 Z-.039
    N7200 X128.315 Z-.156
    N7201 X127.386 Z-.354
    N7202 X126.456 Z-.638
    N7203 X125.526 Z-1.015
    N7204 X125.061 Z-1.24
    N7205 X124.596 Z-1.495
    N7206 X123.676 Z-2.087
    N7207 X51.605 Z-2.104
    N7208 X51.14 Z-2.141
    N7209 X50.21 Z-2.307
    N7210 X49.745 Z-2.428
    N7211 X49.281 Z-2.585
    N7212 X48.816 Z-2.771
    N7213 X48.351 Z-2.986
    N7214 X47.886 Z-3.245
    N7215 X47.421 Z-3.537
    N7216 X46.956 Z-3.872
    N7217 X46.491 Z-4.267
    N7218 X46.026 Z-4.706
    N7219 X45.561 Z-5.234
    N7220 X45.096 Z-5.838
    N7221 X44.631 Z-6.579
    N7222 X44.283 Z-7.265
    N7223 X43.934 Z-8.143
    N7224 X43.702 Z-8.941
    N7225 X43.498 Z-10.08
    N7226 X43.237 Z-12.274
    N7227 X42.888 Z-14.169
    N7228 X42.539 Z-15.654
    N7229 X41.842 Z-18.072
    N7230 X41.377 Z-19.484
    N7231 X40.397 Z-22.179
    N7232 X39.368 Z-24.791
    N7233 X38.853 Z-25.946
    N7234 X38.08 Z-27.536
    N7235 X37.308 Z-28.967
    N7236 X36.793 Z-29.858
    N7237 X35.963 Z-31.203
    N7238 X35.133 Z-32.437
    N7239 X34.304 Z-33.591
    N7240 X33.474 Z-34.669
    N7241 X32.518 Z-35.823
    N7242 X31.562 Z-36.905
    N7243 X30.606 Z-37.915
    N7244 X29.65 Z-38.861
    N7245 X28.746 Z-39.704
    N7246 X27.843 Z-40.502
    N7247 X26.939 Z-41.256
    N7248 X26.035 Z-41.969
    N7249 X25.092 Z-42.672
    N7250 X24.148 Z-43.334
    N7251 X23.205 Z-43.96
    N7252 X22.262 Z-44.551
    N7253 X21.345 Z-45.094
    N7254 X19.513 Z-46.09
    N7255 X17.658 Z-46.984
    N7256 X15.783 Z-47.781
    N7257 X14.845 Z-48.14
    N7258 X13.001 Z-48.775
    N7259 X11.158 Z-49.318
    N7260 X9.273 Z-49.782
    N7261 X7.422 Z-50.151
    N7262 X5.554 Z-50.437
    N7263 X3.719 Z-50.637
    N7264 X1.862 Z-50.759
    N7265 X0. Z-50.8
    N7266 X-1.862 Z-50.759
    N7267 X-3.719 Z-50.637
    N7268 X-5.554 Z-50.437
    N7269 X-7.422 Z-50.151
    N7270 X-9.273 Z-49.782
    N7271 X-11.158 Z-49.318
    N7272 X-13.001 Z-48.775
    N7273 X-14.845 Z-48.14
    N7274 X-16.721 Z-47.395
    N7275 X-18.596 Z-46.545
    N7276 X-20.429 Z-45.606
    N7277 X-21.345 Z-45.094
    N7278 X-22.262 Z-44.551
    N7279 X-23.205 Z-43.96
    N7280 X-24.148 Z-43.334
    N7281 X-25.092 Z-42.672
    N7282 X-26.035 Z-41.969
    N7283 X-26.939 Z-41.256
    N7284 X-27.843 Z-40.502
    N7285 X-28.746 Z-39.704
    N7286 X-29.65 Z-38.861
    N7287 X-30.606 Z-37.915
    N7288 X-31.562 Z-36.905
    N7289 X-32.518 Z-35.823
    N7290 X-33.474 Z-34.669
    N7291 X-34.304 Z-33.591
    N7292 X-35.133 Z-32.437
    N7293 X-35.963 Z-31.203
    N7294 X-36.793 Z-29.858
    N7295 X-37.308 Z-28.967
    N7296 X-38.08 Z-27.536
    N7297 X-38.853 Z-25.946
    N7298 X-39.368 Z-24.791
    N7299 X-39.882 Z-23.523
    N7300 X-40.912 Z-20.799
    N7301 X-41.61 Z-18.796
    N7302 X-42.307 Z-16.517
    N7303 X-42.772 Z-14.697
    N7304 X-43.12 Z-12.989
    N7305 X-43.411 Z-10.916
    N7306 X-43.585 Z-9.487
    N7307 X-43.818 Z-8.513
    N7308 X-44.167 Z-7.532
    N7309 X-44.399 Z-7.024
    N7310 X-44.631 Z-6.579
    N7311 X-45.096 Z-5.838
    N7312 X-45.794 Z-4.957
    N7313 X-46.026 Z-4.706
    N7314 X-46.491 Z-4.267
    N7315 X-46.956 Z-3.872
    N7316 X-47.421 Z-3.537
    N7317 X-47.886 Z-3.245
    N7318 X-48.351 Z-2.986
    N7319 X-48.816 Z-2.771
    N7320 X-49.281 Z-2.585
    N7321 X-49.745 Z-2.428
    N7322 X-50.675 Z-2.211
    N7323 X-51.14 Z-2.141
    N7324 X-51.605 Z-2.104
    N7325 X-123.676 Z-2.087
    N7326 X-124.07 Z-1.816
    N7327 X-124.596 Z-1.495
    N7328 X-125.061 Z-1.24
    N7329 X-125.526 Z-1.015
    N7330 X-126.456 Z-.638
    N7331 X-127.386 Z-.354
    N7332 X-128.315 Z-.156
    N7333 X-129.245 Z-.039
    N7334 X-130.175 Z0.
    N7335 Y46.175
    N7336 X-129.245 Z-.039
    N7337 X-128.315 Z-.156
    N7338 X-127.386 Z-.354
    N7339 X-126.456 Z-.638
    N7340 X-125.526 Z-1.015
    N7341 X-125.061 Z-1.24
    N7342 X-124.131 Z-1.776
    N7343 X-123.666 Z-2.094
    N7344 X-123.201 Z-2.444
    N7345 X-122.454 Z-3.082
    N7346 X-52.07 Z-3.083
    N7347 X-51.14 Z-3.107
    N7348 X-50.21 Z-3.247
    N7349 X-49.745 Z-3.366
    N7350 X-48.816 Z-3.711
    N7351 X-48.351 Z-3.936
    N7352 X-47.886 Z-4.213
    N7353 X-47.421 Z-4.524
    N7354 X-46.956 Z-4.893
    N7355 X-46.491 Z-5.336
    N7356 X-46.026 Z-5.838
    N7357 X-45.561 Z-6.454
    N7358 X-45.096 Z-7.223
    N7359 X-44.864 Z-7.698
    N7360 X-44.545 Z-8.511
    N7361 X-44.286 Z-9.476
    N7362 X-44.07 Z-11.052
    N7363 X-43.768 Z-12.877
    N7364 X-43.595 Z-13.667
    N7365 X-43.336 Z-14.71
    N7366 X-42.543 Z-17.262
    N7367 X-41.679 Z-19.562
    N7368 X-40.912 Z-21.397
    N7369 X-38.71 Z-26.25
    N7370 X-38.16 Z-27.377
    N7371 X-37.609 Z-28.427
    N7372 X-37.059 Z-29.41
    N7373 X-36.508 Z-30.335
    N7374 X-35.37 Z-32.097
    N7375 X-34.232 Z-33.687
    N7376 X-33.474 Z-34.669
    N7377 X-32.518 Z-35.823
    N7378 X-31.562 Z-36.905
    N7379 X-30.606 Z-37.915
    N7380 X-29.65 Z-38.861
    N7381 X-28.746 Z-39.704
    N7382 X-27.843 Z-40.502
    N7383 X-26.939 Z-41.256
    N7384 X-26.035 Z-41.969
    N7385 X-25.092 Z-42.672
    N7386 X-24.148 Z-43.334
    N7387 X-23.205 Z-43.96
    N7388 X-22.262 Z-44.551
    N7389 X-21.345 Z-45.094
    N7390 X-20.429 Z-45.606
    N7391 X-18.596 Z-46.545
    N7392 X-16.721 Z-47.395
    N7393 X-14.845 Z-48.14
    N7394 X-13.001 Z-48.775
    N7395 X-11.158 Z-49.318
    N7396 X-9.273 Z-49.782
    N7397 X-7.422 Z-50.151
    N7398 X-5.554 Z-50.437
    N7399 X-3.719 Z-50.637
    N7400 X-1.862 Z-50.759
    N7401 X0. Z-50.8
    N7402 X1.862 Z-50.759
    N7403 X3.719 Z-50.637
    N7404 X5.554 Z-50.437
    N7405 X7.422 Z-50.151
    N7406 X9.273 Z-49.782
    N7407 X11.158 Z-49.318
    N7408 X13.001 Z-48.775
    N7409 X14.845 Z-48.14
    N7410 X15.783 Z-47.781
    N7411 X17.658 Z-46.984
    N7412 X19.513 Z-46.09
    N7413 X21.345 Z-45.094
    N7414 X22.262 Z-44.551
    N7415 X23.205 Z-43.96
    N7416 X24.148 Z-43.334
    N7417 X25.092 Z-42.672
    N7418 X26.035 Z-41.969
    N7419 X26.939 Z-41.256
    N7420 X27.843 Z-40.502
    N7421 X28.746 Z-39.704
    N7422 X29.65 Z-38.861
    N7423 X30.606 Z-37.915
    N7424 X31.562 Z-36.905
    N7425 X32.518 Z-35.823
    N7426 X33.474 Z-34.669
    N7427 X34.232 Z-33.687
    N7428 X35.37 Z-32.097
    N7429 X36.508 Z-30.335
    N7430 X37.059 Z-29.41
    N7431 X37.609 Z-28.427
    N7432 X38.16 Z-27.377
    N7433 X38.71 Z-26.25
    N7434 X40.362 Z-22.641
    N7435 X41.401 Z-20.241
    N7436 X41.993 Z-18.76
    N7437 X42.778 Z-16.575
    N7438 X43.249 Z-15.015
    N7439 X43.768 Z-12.877
    N7440 X43.94 Z-11.932
    N7441 X44.243 Z-9.707
    N7442 X44.459 Z-8.784
    N7443 X44.748 Z-7.964
    N7444 X45.096 Z-7.223
    N7445 X45.561 Z-6.454
    N7446 X46.026 Z-5.838
    N7447 X46.259 Z-5.574
    N7448 X46.956 Z-4.893
    N7449 X47.421 Z-4.524
    N7450 X47.886 Z-4.213
    N7451 X48.351 Z-3.936
    N7452 X48.816 Z-3.71
    N7453 X49.745 Z-3.366
    N7454 X50.21 Z-3.247
    N7455 X51.14 Z-3.107
    N7456 X52.07 Z-3.083
    N7457 X122.454 Z-3.082
    N7458 X123.201 Z-2.444
    N7459 X123.666 Z-2.094
    N7460 X124.131 Z-1.776
    N7461 X125.061 Z-1.24
    N7462 X125.526 Z-1.015
    N7463 X126.456 Z-.638
    N7464 X127.386 Z-.354
    N7465 X128.315 Z-.156
    N7466 X129.245 Z-.039
    N7467 X130.175 Z0.
    N7468 Y44.975
    N7469 X129.245 Z-.039
    N7470 X128.315 Z-.156
    N7471 X127.386 Z-.354
    N7472 X126.456 Z-.638
    N7473 X125.526 Z-1.015
    N7474 X125.061 Z-1.24
    N7475 X124.131 Z-1.776
    N7476 X123.666 Z-2.094
    N7477 X123.201 Z-2.444
    N7478 X122.736 Z-2.837
    N7479 X122.272 Z-3.278
    N7480 X121.807 Z-3.769
    N7481 X121.284 Z-4.409
    N7482 X121.255 Z-4.429
    N7483 X51.14 Z-4.433
    N7484 X50.675 Z-4.468
    N7485 X50.21 Z-4.548
    N7486 X49.745 Z-4.673
    N7487 X49.281 Z-4.83
    N7488 X48.816 Z-5.033
    N7489 X48.351 Z-5.294
    N7490 X47.886 Z-5.606
    N7491 X47.421 Z-5.975
    N7492 X46.956 Z-6.432
    N7493 X46.491 Z-6.995
    N7494 X46.259 Z-7.329
    N7495 X45.91 Z-7.928
    N7496 X45.561 Z-8.721
    N7497 X45.329 Z-9.483
    N7498 X45.213 Z-10.07
    N7499 X44.864 Z-12.183
    N7500 X44.631 Z-13.173
    N7501 X44.24 Z-14.549
    N7502 X43.628 Z-16.31
    N7503 X42.965 Z-17.939
    N7504 X42.452 Z-19.093
    N7505 X41.425 Z-21.219
    N7506 X39.677 Z-24.552
    N7507 X37.207 Z-29.148
    N7508 X36.589 Z-30.202
    N7509 X35.972 Z-31.19
    N7510 X35.347 Z-32.13
    N7511 X34.723 Z-33.02
    N7512 X33.474 Z-34.669
    N7513 X32.518 Z-35.823
    N7514 X31.562 Z-36.905
    N7515 X30.606 Z-37.915
    N7516 X29.65 Z-38.861
    N7517 X28.746 Z-39.704
    N7518 X27.843 Z-40.502
    N7519 X26.939 Z-41.256
    N7520 X26.035 Z-41.969
    N7521 X25.092 Z-42.672
    N7522 X24.148 Z-43.334
    N7523 X23.205 Z-43.96
    N7524 X22.262 Z-44.551
    N7525 X21.345 Z-45.094
    N7526 X19.513 Z-46.09
    N7527 X17.658 Z-46.984
    N7528 X15.783 Z-47.781
    N7529 X14.845 Z-48.14
    N7530 X13.001 Z-48.775
    N7531 X11.158 Z-49.318
    N7532 X9.273 Z-49.782
    N7533 X7.422 Z-50.151
    N7534 X5.554 Z-50.437
    N7535 X3.719 Z-50.637
    N7536 X1.862 Z-50.759
    N7537 X0. Z-50.8
    N7538 X-1.862 Z-50.759
    N7539 X-3.719 Z-50.637
    N7540 X-5.554 Z-50.437
    N7541 X-7.422 Z-50.151
    N7542 X-9.273 Z-49.782
    N7543 X-11.158 Z-49.318
    N7544 X-13.001 Z-48.775
    N7545 X-14.845 Z-48.14
    N7546 X-16.721 Z-47.395
    N7547 X-18.596 Z-46.545
    N7548 X-20.429 Z-45.606
    N7549 X-21.345 Z-45.094
    N7550 X-22.262 Z-44.551
    N7551 X-23.205 Z-43.96
    N7552 X-24.148 Z-43.334
    N7553 X-25.092 Z-42.672
    N7554 X-26.035 Z-41.969
    N7555 X-26.939 Z-41.256
    N7556 X-27.843 Z-40.502
    N7557 X-28.746 Z-39.704
    N7558 X-29.65 Z-38.861
    N7559 X-30.606 Z-37.915
    N7560 X-31.562 Z-36.905
    N7561 X-32.518 Z-35.823
    N7562 X-33.474 Z-34.669
    N7563 X-34.723 Z-33.02
    N7564 X-35.347 Z-32.13
    N7565 X-35.972 Z-31.19
    N7566 X-36.589 Z-30.202
    N7567 X-37.207 Z-29.148
    N7568 X-40.912 Z-22.222
    N7569 X-41.939 Z-20.181
    N7570 X-42.452 Z-19.093
    N7571 X-43.186 Z-17.426
    N7572 X-43.849 Z-15.713
    N7573 X-44.24 Z-14.549
    N7574 X-44.748 Z-12.7
    N7575 X-45.096 Z-10.878
    N7576 X-45.271 Z-9.748
    N7577 X-45.445 Z-9.072
    N7578 X-45.677 Z-8.429
    N7579 X-46.026 Z-7.714
    N7580 X-46.259 Z-7.329
    N7581 X-46.724 Z-6.698
    N7582 X-46.956 Z-6.432
    N7583 X-47.421 Z-5.975
    N7584 X-47.886 Z-5.606
    N7585 X-48.351 Z-5.294
    N7586 X-48.816 Z-5.033
    N7587 X-49.281 Z-4.83
    N7588 X-49.745 Z-4.673
    N7589 X-50.21 Z-4.548
    N7590 X-50.675 Z-4.468
    N7591 X-51.14 Z-4.434
    N7592 X-121.255 Z-4.429
    N7593 X-121.284 Z-4.409
    N7594 X-121.807 Z-3.769
    N7595 X-122.272 Z-3.278
    N7596 X-122.736 Z-2.837
    N7597 X-123.201 Z-2.444
    N7598 X-123.666 Z-2.094
    N7599 X-124.131 Z-1.776
    N7600 X-125.061 Z-1.24
    N7601 X-125.526 Z-1.015
    N7602 X-126.456 Z-.638
    N7603 X-127.386 Z-.354
    N7604 X-128.315 Z-.156
    N7605 X-129.245 Z-.039
    N7606 X-130.175 Z0.
    N7607 Y43.775
    N7608 X-129.245 Z-.039
    N7609 X-128.315 Z-.156
    N7610 X-127.386 Z-.354
    N7611 X-126.456 Z-.638
    N7612 X-125.526 Z-1.015
    N7613 X-125.061 Z-1.24
    N7614 X-124.131 Z-1.776
    N7615 X-123.666 Z-2.094
    N7616 X-123.201 Z-2.444
    N7617 X-122.736 Z-2.837
    N7618 X-122.272 Z-3.278
    N7619 X-121.807 Z-3.769
    N7620 X-121.342 Z-4.335
    N7621 X-120.877 Z-4.981
    N7622 X-120.412 Z-5.739
    N7623 X-120.063 Z-6.409
    N7624 X-50.675 Z-6.427
    N7625 X-50.21 Z-6.495
    N7626 X-49.745 Z-6.629
    N7627 X-49.281 Z-6.827
    N7628 X-48.816 Z-7.099
    N7629 X-48.351 Z-7.455
    N7630 X-47.886 Z-7.93
    N7631 X-47.653 Z-8.227
    N7632 X-47.305 Z-8.785
    N7633 X-47.072 Z-9.293
    N7634 X-46.898 Z-9.814
    N7635 X-46.607 Z-11.232
    N7636 X-46.142 Z-12.948
    N7637 X-45.794 Z-13.948
    N7638 X-45.096 Z-15.651
    N7639 X-44.631 Z-16.645
    N7640 X-43.702 Z-18.456
    N7641 X-42.772 Z-20.121
    N7642 X-41.842 Z-21.681
    N7643 X-38.123 Z-27.654
    N7644 X-36.263 Z-30.727
    N7645 X-35.798 Z-31.453
    N7646 X-34.868 Z-32.817
    N7647 X-33.474 Z-34.669
    N7648 X-32.518 Z-35.823
    N7649 X-31.562 Z-36.905
    N7650 X-30.606 Z-37.915
    N7651 X-29.65 Z-38.861
    N7652 X-28.746 Z-39.704
    N7653 X-27.843 Z-40.502
    N7654 X-26.939 Z-41.256
    N7655 X-26.035 Z-41.969
    N7656 X-25.092 Z-42.672
    N7657 X-24.148 Z-43.334
    N7658 X-23.205 Z-43.96
    N7659 X-22.262 Z-44.551
    N7660 X-21.345 Z-45.094
    N7661 X-20.429 Z-45.606
    N7662 X-18.596 Z-46.545
    N7663 X-16.721 Z-47.395
    N7664 X-14.845 Z-48.14
    N7665 X-13.001 Z-48.775
    N7666 X-11.158 Z-49.318
    N7667 X-9.273 Z-49.782
    N7668 X-7.422 Z-50.151
    N7669 X-5.554 Z-50.437
    N7670 X-3.719 Z-50.637
    N7671 X-1.862 Z-50.759
    N7672 X0. Z-50.8
    N7673 X1.862 Z-50.759
    N7674 X3.719 Z-50.637
    N7675 X5.554 Z-50.437
    N7676 X7.422 Z-50.151
    N7677 X9.273 Z-49.782
    N7678 X11.158 Z-49.318
    N7679 X13.001 Z-48.775
    N7680 X14.845 Z-48.14
    N7681 X15.783 Z-47.781
    N7682 X17.658 Z-46.984
    N7683 X19.513 Z-46.09
    N7684 X21.345 Z-45.094
    N7685 X22.262 Z-44.551
    N7686 X23.205 Z-43.96
    N7687 X24.148 Z-43.334
    N7688 X25.092 Z-42.672
    N7689 X26.035 Z-41.969
    N7690 X26.939 Z-41.256
    N7691 X27.843 Z-40.502
    N7692 X28.746 Z-39.704
    N7693 X29.65 Z-38.861
    N7694 X30.606 Z-37.915
    N7695 X31.562 Z-36.905
    N7696 X32.518 Z-35.823
    N7697 X33.474 Z-34.669
    N7698 X34.403 Z-33.455
    N7699 X35.333 Z-32.15
    N7700 X36.263 Z-30.727
    N7701 X38.123 Z-27.654
    N7702 X40.912 Z-23.197
    N7703 X42.772 Z-20.121
    N7704 X43.702 Z-18.456
    N7705 X44.631 Z-16.645
    N7706 X45.096 Z-15.651
    N7707 X45.561 Z-14.548
    N7708 X46.026 Z-13.284
    N7709 X46.375 Z-12.162
    N7710 X46.607 Z-11.232
    N7711 X46.898 Z-9.814
    N7712 X47.072 Z-9.293
    N7713 X47.305 Z-8.785
    N7714 X47.653 Z-8.227
    N7715 X47.886 Z-7.93
    N7716 X48.351 Z-7.455
    N7717 X48.816 Z-7.1
    N7718 X49.281 Z-6.827
    N7719 X49.745 Z-6.629
    N7720 X50.21 Z-6.495
    N7721 X50.675 Z-6.427
    N7722 X120.063 Z-6.409
    N7723 X120.644 Z-5.343
    N7724 X121.109 Z-4.641
    N7725 X121.807 Z-3.769
    N7726 X122.272 Z-3.278
    N7727 X122.736 Z-2.837
    N7728 X123.201 Z-2.444
    N7729 X123.666 Z-2.094
    N7730 X124.131 Z-1.776
    N7731 X125.061 Z-1.24
    N7732 X125.526 Z-1.015
    N7733 X126.456 Z-.638
    N7734 X127.386 Z-.354
    N7735 X128.315 Z-.156
    N7736 X129.245 Z-.039
    N7737 X130.175 Z0.
    N7738 Y42.575
    N7739 X129.245 Z-.039
    N7740 X128.315 Z-.156
    N7741 X127.386 Z-.354
    N7742 X126.456 Z-.638
    N7743 X125.526 Z-1.015
    N7744 X125.061 Z-1.24
    N7745 X124.131 Z-1.776
    N7746 X123.666 Z-2.094
    N7747 X123.201 Z-2.444
    N7748 X122.736 Z-2.837
    N7749 X122.272 Z-3.278
    N7750 X121.807 Z-3.769
    N7751 X121.109 Z-4.641
    N7752 X120.644 Z-5.343
    N7753 X120.179 Z-6.185
    N7754 X119.947 Z-6.674
    N7755 X119.598 Z-7.568
    N7756 X119.308 Z-8.571
    N7757 X119.104 Z-9.653
    N7758 X119.01 Z-10.724
    N7759 X119.003 Z-12.378
    N7760 X50.443 Z-12.382
    N7761 X50.21 Z-12.43
    N7762 X49.978 Z-12.531
    N7763 X49.745 Z-12.68
    N7764 X49.513 Z-12.876
    N7765 X48.816 Z-13.619
    N7766 X48.351 Z-14.205
    N7767 X47.421 Z-15.444
    N7768 X44.631 Z-19.296
    N7769 X39.053 Z-26.787
    N7770 X37.193 Z-29.38
    N7771 X35.178 Z-32.373
    N7772 X33.99 Z-34.005
    N7773 X33.474 Z-34.669
    N7774 X32.518 Z-35.823
    N7775 X31.562 Z-36.905
    N7776 X30.606 Z-37.915
    N7777 X29.65 Z-38.861
    N7778 X28.746 Z-39.704
    N7779 X27.843 Z-40.502
    N7780 X26.939 Z-41.256
    N7781 X26.035 Z-41.969
    N7782 X25.092 Z-42.672
    N7783 X24.148 Z-43.334
    N7784 X23.205 Z-43.96
    N7785 X22.262 Z-44.551
    N7786 X21.345 Z-45.094
    N7787 X19.513 Z-46.09
    N7788 X17.658 Z-46.984
    N7789 X15.783 Z-47.781
    N7790 X14.845 Z-48.14
    N7791 X13.001 Z-48.775
    N7792 X11.158 Z-49.318
    N7793 X9.273 Z-49.782
    N7794 X7.422 Z-50.151
    N7795 X5.554 Z-50.437
    N7796 X3.719 Z-50.637
    N7797 X1.862 Z-50.759
    N7798 X0. Z-50.8
    N7799 X-1.862 Z-50.759
    N7800 X-3.719 Z-50.637
    N7801 X-5.554 Z-50.437
    N7802 X-7.422 Z-50.151
    N7803 X-9.273 Z-49.782
    N7804 X-11.158 Z-49.318
    N7805 X-13.001 Z-48.775
    N7806 X-14.845 Z-48.14
    N7807 X-16.721 Z-47.395
    N7808 X-18.596 Z-46.545
    N7809 X-20.429 Z-45.606
    N7810 X-21.345 Z-45.094
    N7811 X-22.262 Z-44.551
    N7812 X-23.205 Z-43.96
    N7813 X-24.148 Z-43.334
    N7814 X-25.092 Z-42.672
    N7815 X-26.035 Z-41.969
    N7816 X-26.939 Z-41.256
    N7817 X-27.843 Z-40.502
    N7818 X-28.746 Z-39.704
    N7819 X-29.65 Z-38.861
    N7820 X-30.606 Z-37.915
    N7821 X-31.562 Z-36.905
    N7822 X-32.518 Z-35.823
    N7823 X-33.474 Z-34.669
    N7824 X-34.506 Z-33.315
    N7825 X-35.178 Z-32.373
    N7826 X-37.193 Z-29.38
    N7827 X-39.053 Z-26.787
    N7828 X-44.631 Z-19.296
    N7829 X-47.421 Z-15.444
    N7830 X-48.351 Z-14.205
    N7831 X-48.816 Z-13.619
    N7832 X-49.513 Z-12.876
    N7833 X-49.745 Z-12.68
    N7834 X-49.978 Z-12.531
    N7835 X-50.21 Z-12.43
    N7836 X-50.443 Z-12.382
    N7837 X-119.003 Z-12.378
    N7838 X-119.046 Z-10.182
    N7839 X-119.133 Z-9.454
    N7840 X-119.366 Z-8.342
    N7841 X-119.598 Z-7.568
    N7842 X-119.947 Z-6.674
    N7843 X-120.412 Z-5.739
    N7844 X-120.877 Z-4.981
    N7845 X-121.342 Z-4.335
    N7846 X-121.807 Z-3.769
    N7847 X-122.272 Z-3.278
    N7848 X-122.736 Z-2.837
    N7849 X-123.201 Z-2.444
    N7850 X-123.666 Z-2.094
    N7851 X-124.131 Z-1.776
    N7852 X-125.061 Z-1.24
    N7853 X-125.526 Z-1.015
    N7854 X-126.456 Z-.638
    N7855 X-127.386 Z-.354
    N7856 X-128.315 Z-.156
    N7857 X-129.245 Z-.039
    N7858 X-130.175 Z0.
    N7859 Y41.375
    N7860 X-129.245 Z-.039
    N7861 X-128.315 Z-.156
    N7862 X-127.386 Z-.354
    N7863 X-126.456 Z-.638
    N7864 X-125.526 Z-1.015
    N7865 X-125.061 Z-1.24
    N7866 X-124.131 Z-1.776
    N7867 X-123.666 Z-2.094
    N7868 X-123.201 Z-2.444
    N7869 X-122.736 Z-2.837
    N7870 X-122.272 Z-3.278
    N7871 X-121.807 Z-3.769
    N7872 X-121.342 Z-4.335
    N7873 X-120.877 Z-4.981
    N7874 X-120.412 Z-5.739
    N7875 X-119.947 Z-6.674
    N7876 X-119.598 Z-7.568
    N7877 X-119.366 Z-8.342
    N7878 X-119.133 Z-9.454
    N7879 X-119.017 Z-10.557
    N7880 X-119.003 Z-18.946
    N7881 X-49.281
    N7882 X-48.816 Z-18.969
    N7883 X-48.351 Z-19.061
    N7884 X-47.886 Z-19.229
    N7885 X-47.421 Z-19.464
    N7886 X-46.956 Z-19.745
    N7887 X-46.491 Z-20.062
    N7888 X-45.561 Z-20.798
    N7889 X-44.631 Z-21.626
    N7890 X-43.702 Z-22.518
    N7891 X-42.772 Z-23.457
    N7892 X-40.912 Z-25.441
    N7893 X-39.053 Z-27.541
    N7894 X-37.193 Z-29.764
    N7895 X-36.263 Z-30.94
    N7896 X-35.333 Z-32.172
    N7897 X-34.403 Z-33.455
    N7898 X-33.474 Z-34.669
    N7899 X-32.518 Z-35.823
    N7900 X-31.562 Z-36.905
    N7901 X-30.606 Z-37.915
    N7902 X-29.65 Z-38.861
    N7903 X-28.746 Z-39.704
    N7904 X-27.843 Z-40.502
    N7905 X-26.939 Z-41.256
    N7906 X-26.035 Z-41.969
    N7907 X-25.092 Z-42.672
    N7908 X-24.148 Z-43.334
    N7909 X-23.205 Z-43.96
    N7910 X-22.262 Z-44.551
    N7911 X-21.345 Z-45.094
    N7912 X-20.429 Z-45.606
    N7913 X-18.596 Z-46.545
    N7914 X-16.721 Z-47.395
    N7915 X-14.845 Z-48.14
    N7916 X-13.001 Z-48.775
    N7917 X-11.158 Z-49.318
    N7918 X-9.273 Z-49.782
    N7919 X-7.422 Z-50.151
    N7920 X-5.554 Z-50.437
    N7921 X-3.719 Z-50.637
    N7922 X-1.862 Z-50.759
    N7923 X0. Z-50.8
    N7924 X1.862 Z-50.759
    N7925 X3.719 Z-50.637
    N7926 X5.554 Z-50.437
    N7927 X7.422 Z-50.151
    N7928 X9.273 Z-49.782
    N7929 X11.158 Z-49.318
    N7930 X13.001 Z-48.775
    N7931 X14.845 Z-48.14
    N7932 X15.783 Z-47.781
    N7933 X17.658 Z-46.984
    N7934 X19.513 Z-46.09
    N7935 X21.345 Z-45.094
    N7936 X22.262 Z-44.551
    N7937 X23.205 Z-43.96
    N7938 X24.148 Z-43.334
    N7939 X25.092 Z-42.672
    N7940 X26.035 Z-41.969
    N7941 X26.939 Z-41.256
    N7942 X27.843 Z-40.502
    N7943 X28.746 Z-39.704
    N7944 X29.65 Z-38.861
    N7945 X30.606 Z-37.915
    N7946 X31.562 Z-36.905
    N7947 X32.518 Z-35.823
    N7948 X33.474 Z-34.669
    N7949 X34.403 Z-33.455
    N7950 X35.333 Z-32.172
    N7951 X36.263 Z-30.94
    N7952 X37.193 Z-29.764
    N7953 X39.053 Z-27.541
    N7954 X40.912 Z-25.441
    N7955 X42.772 Z-23.457
    N7956 X43.702 Z-22.518
    N7957 X44.631 Z-21.626
    N7958 X45.561 Z-20.798
    N7959 X46.491 Z-20.062
    N7960 X46.956 Z-19.745
    N7961 X47.421 Z-19.464
    N7962 X47.886 Z-19.229
    N7963 X48.351 Z-19.061
    N7964 X48.816 Z-18.969
    N7965 X49.281 Z-18.946
    N7966 X119.003
    N7967 X119.01 Z-10.724
    N7968 X119.104 Z-9.653
    N7969 X119.308 Z-8.571
    N7970 X119.598 Z-7.568
    N7971 X119.947 Z-6.674
    N7972 X120.179 Z-6.185
    N7973 X120.644 Z-5.343
    N7974 X121.109 Z-4.641
    N7975 X121.807 Z-3.769
    N7976 X122.272 Z-3.278
    N7977 X122.736 Z-2.837
    N7978 X123.201 Z-2.444
    N7979 X123.666 Z-2.094
    N7980 X124.131 Z-1.776
    N7981 X125.061 Z-1.24
    N7982 X125.526 Z-1.015
    N7983 X126.456 Z-.638
    N7984 X127.386 Z-.354
    N7985 X128.315 Z-.156
    N7986 X129.245 Z-.039
    N7987 X130.175 Z0.
    N7988 Y40.175
    N7989 X129.245 Z-.039
    N7990 X128.315 Z-.156
    N7991 X127.386 Z-.354
    N7992 X126.456 Z-.638
    N7993 X125.526 Z-1.015
    N7994 X125.061 Z-1.24
    N7995 X124.131 Z-1.776
    N7996 X123.666 Z-2.094
    N7997 X123.201 Z-2.444
    N7998 X122.736 Z-2.837
    N7999 X122.272 Z-3.278
    N8000 X121.807 Z-3.769
    N8001 X121.109 Z-4.641
    N8002 X120.644 Z-5.343
    N8003 X120.179 Z-6.185
    N8004 X119.947 Z-6.674
    N8005 X119.598 Z-7.568
    N8006 X119.308 Z-8.571
    N8007 X119.104 Z-9.653
    N8008 X119.01 Z-10.724
    N8009 X119.003 Z-22.753
    N8010 X48.351
    N8011 X47.421 Z-22.767
    N8012 X46.956 Z-22.829
    N8013 X46.491 Z-22.946
    N8014 X46.026 Z-23.111
    N8015 X45.096 Z-23.553
    N8016 X44.631 Z-23.82
    N8017 X43.702 Z-24.425
    N8018 X42.772 Z-25.111
    N8019 X41.842 Z-25.861
    N8020 X40.912 Z-26.663
    N8021 X39.982 Z-27.51
    N8022 X39.053 Z-28.398
    N8023 X38.123 Z-29.326
    N8024 X37.193 Z-30.294
    N8025 X36.263 Z-31.306
    N8026 X35.333 Z-32.368
    N8027 X34.403 Z-33.489
    N8028 X33.474 Z-34.669
    N8029 X32.518 Z-35.823
    N8030 X31.562 Z-36.905
    N8031 X30.606 Z-37.915
    N8032 X29.65 Z-38.861
    N8033 X28.746 Z-39.704
    N8034 X27.843 Z-40.502
    N8035 X26.939 Z-41.256
    N8036 X26.035 Z-41.969
    N8037 X25.092 Z-42.672
    N8038 X24.148 Z-43.334
    N8039 X23.205 Z-43.96
    N8040 X22.262 Z-44.551
    N8041 X21.345 Z-45.094
    N8042 X19.513 Z-46.09
    N8043 X17.658 Z-46.984
    N8044 X15.783 Z-47.781
    N8045 X14.845 Z-48.14
    N8046 X13.001 Z-48.775
    N8047 X11.158 Z-49.318
    N8048 X9.273 Z-49.782
    N8049 X7.422 Z-50.151
    N8050 X5.554 Z-50.437
    N8051 X3.719 Z-50.637
    N8052 X1.862 Z-50.759
    N8053 X0. Z-50.8
    N8054 X-1.862 Z-50.759
    N8055 X-3.719 Z-50.637
    N8056 X-5.554 Z-50.437
    N8057 X-7.422 Z-50.151
    N8058 X-9.273 Z-49.782
    N8059 X-11.158 Z-49.318
    N8060 X-13.001 Z-48.775
    N8061 X-14.845 Z-48.14
    N8062 X-16.721 Z-47.395
    N8063 X-18.596 Z-46.545
    N8064 X-20.429 Z-45.606
    N8065 X-21.345 Z-45.094
    N8066 X-22.262 Z-44.551
    N8067 X-23.205 Z-43.96
    N8068 X-24.148 Z-43.334
    N8069 X-25.092 Z-42.672
    N8070 X-26.035 Z-41.969
    N8071 X-26.939 Z-41.256
    N8072 X-27.843 Z-40.502
    N8073 X-28.746 Z-39.704
    N8074 X-29.65 Z-38.861
    N8075 X-30.606 Z-37.915
    N8076 X-31.562 Z-36.905
    N8077 X-32.518 Z-35.823
    N8078 X-33.474 Z-34.669
    N8079 X-34.403 Z-33.489
    N8080 X-35.333 Z-32.368
    N8081 X-36.263 Z-31.306
    N8082 X-37.193 Z-30.294
    N8083 X-38.123 Z-29.326
    N8084 X-39.053 Z-28.398
    N8085 X-39.982 Z-27.51
    N8086 X-40.912 Z-26.663
    N8087 X-41.842 Z-25.861
    N8088 X-42.772 Z-25.111
    N8089 X-43.702 Z-24.425
    N8090 X-44.631 Z-23.82
    N8091 X-45.096 Z-23.553
    N8092 X-46.026 Z-23.111
    N8093 X-46.491 Z-22.946
    N8094 X-46.956 Z-22.829
    N8095 X-47.421 Z-22.767
    N8096 X-119.003 Z-22.753
    N8097 X-119.017 Z-10.557
    N8098 X-119.133 Z-9.454
    N8099 X-119.366 Z-8.342
    N8100 X-119.598 Z-7.568
    N8101 X-119.947 Z-6.674
    N8102 X-120.412 Z-5.739
    N8103 X-120.877 Z-4.981
    N8104 X-121.342 Z-4.335
    N8105 X-121.807 Z-3.769
    N8106 X-122.272 Z-3.278
    N8107 X-122.736 Z-2.837
    N8108 X-123.201 Z-2.444
    N8109 X-123.666 Z-2.094
    N8110 X-124.131 Z-1.776
    N8111 X-125.061 Z-1.24
    N8112 X-125.526 Z-1.015
    N8113 X-126.456 Z-.638
    N8114 X-127.386 Z-.354
    N8115 X-128.315 Z-.156
    N8116 X-129.245 Z-.039
    N8117 X-130.175 Z0.
    N8118 Y38.975
    N8119 X-129.245 Z-.039
    N8120 X-128.315 Z-.156
    N8121 X-127.386 Z-.354
    N8122 X-126.456 Z-.638
    N8123 X-125.526 Z-1.015
    N8124 X-125.061 Z-1.24
    N8125 X-124.131 Z-1.776
    N8126 X-123.666 Z-2.094
    N8127 X-123.201 Z-2.444
    N8128 X-122.736 Z-2.837
    N8129 X-122.272 Z-3.278
    N8130 X-121.807 Z-3.769
    N8131 X-121.342 Z-4.335
    N8132 X-120.877 Z-4.981
    N8133 X-120.412 Z-5.739
    N8134 X-119.947 Z-6.674
    N8135 X-119.598 Z-7.568
    N8136 X-119.366 Z-8.342
    N8137 X-119.133 Z-9.454
    N8138 X-119.017 Z-10.557
    N8139 X-119.003 Z-25.684
    N8140 X-46.026 Z-25.689
    N8141 X-45.561 Z-25.736
    N8142 X-45.096 Z-25.828
    N8143 X-44.631 Z-25.961
    N8144 X-43.702 Z-26.318
    N8145 X-43.237 Z-26.537
    N8146 X-41.842 Z-27.326
    N8147 X-40.912 Z-27.939
    N8148 X-39.982 Z-28.613
    N8149 X-39.053 Z-29.341
    N8150 X-38.123 Z-30.117
    N8151 X-37.193 Z-30.934
    N8152 X-36.263 Z-31.797
    N8153 X-35.333 Z-32.71
    N8154 X-34.403 Z-33.676
    N8155 X-33.474 Z-34.702
    N8156 X-32.5 Z-35.843
    N8157 X-31.527 Z-36.944
    N8158 X-30.553 Z-37.968
    N8159 X-29.58 Z-38.928
    N8160 X-28.693 Z-39.752
    N8161 X-27.807 Z-40.532
    N8162 X-26.921 Z-41.27
    N8163 X-26.035 Z-41.969
    N8164 X-25.092 Z-42.672
    N8165 X-24.148 Z-43.334
    N8166 X-23.205 Z-43.96
    N8167 X-22.262 Z-44.551
    N8168 X-21.345 Z-45.094
    N8169 X-20.429 Z-45.606
    N8170 X-18.596 Z-46.545
    N8171 X-16.721 Z-47.395
    N8172 X-14.845 Z-48.14
    N8173 X-13.001 Z-48.775
    N8174 X-11.158 Z-49.318
    N8175 X-9.273 Z-49.782
    N8176 X-7.422 Z-50.151
    N8177 X-5.554 Z-50.437
    N8178 X-3.719 Z-50.637
    N8179 X-1.862 Z-50.759
    N8180 X0. Z-50.8
    N8181 X1.862 Z-50.759
    N8182 X3.719 Z-50.637
    N8183 X5.554 Z-50.437
    N8184 X7.422 Z-50.151
    N8185 X9.273 Z-49.782
    N8186 X11.158 Z-49.318
    N8187 X13.001 Z-48.775
    N8188 X14.845 Z-48.14
    N8189 X15.783 Z-47.781
    N8190 X17.658 Z-46.984
    N8191 X19.513 Z-46.09
    N8192 X21.345 Z-45.094
    N8193 X22.262 Z-44.551
    N8194 X23.205 Z-43.96
    N8195 X24.148 Z-43.334
    N8196 X25.092 Z-42.672
    N8197 X26.035 Z-41.969
    N8198 X26.921 Z-41.27
    N8199 X27.807 Z-40.532
    N8200 X28.693 Z-39.752
    N8201 X29.58 Z-38.928
    N8202 X30.553 Z-37.968
    N8203 X31.527 Z-36.944
    N8204 X32.5 Z-35.843
    N8205 X33.474 Z-34.702
    N8206 X34.403 Z-33.676
    N8207 X35.333 Z-32.71
    N8208 X36.263 Z-31.797
    N8209 X37.193 Z-30.934
    N8210 X38.123 Z-30.117
    N8211 X39.053 Z-29.341
    N8212 X39.982 Z-28.613
    N8213 X40.912 Z-27.939
    N8214 X41.842 Z-27.326
    N8215 X42.307 Z-27.043
    N8216 X43.237 Z-26.537
    N8217 X43.702 Z-26.318
    N8218 X44.631 Z-25.961
    N8219 X45.096 Z-25.828
    N8220 X45.561 Z-25.736
    N8221 X46.026 Z-25.689
    N8222 X119.003 Z-25.684
    N8223 X119.01 Z-10.724
    N8224 X119.104 Z-9.653
    N8225 X119.308 Z-8.571
    N8226 X119.598 Z-7.568
    N8227 X119.947 Z-6.674
    N8228 X120.179 Z-6.185
    N8229 X120.644 Z-5.343
    N8230 X121.109 Z-4.641
    N8231 X121.807 Z-3.769
    N8232 X122.272 Z-3.278
    N8233 X122.736 Z-2.837
    N8234 X123.201 Z-2.444
    N8235 X123.666 Z-2.094
    N8236 X124.131 Z-1.776
    N8237 X125.061 Z-1.24
    N8238 X125.526 Z-1.015
    N8239 X126.456 Z-.638
    N8240 X127.386 Z-.354
    N8241 X128.315 Z-.156
    N8242 X129.245 Z-.039
    N8243 X130.175 Z0.
    N8244 Y37.775
    N8245 X129.245 Z-.039
    N8246 X128.315 Z-.156
    N8247 X127.386 Z-.354
    N8248 X126.456 Z-.638
    N8249 X125.526 Z-1.015
    N8250 X125.061 Z-1.24
    N8251 X124.131 Z-1.776
    N8252 X123.666 Z-2.094
    N8253 X123.201 Z-2.444
    N8254 X122.736 Z-2.837
    N8255 X122.272 Z-3.278
    N8256 X121.807 Z-3.769
    N8257 X121.109 Z-4.641
    N8258 X120.644 Z-5.343
    N8259 X120.179 Z-6.185
    N8260 X119.947 Z-6.674
    N8261 X119.598 Z-7.568
    N8262 X119.308 Z-8.571
    N8263 X119.104 Z-9.653
    N8264 X119.01 Z-10.724
    N8265 X119.003 Z-28.114
    N8266 X44.631 Z-28.119
    N8267 X44.167 Z-28.162
    N8268 X43.702 Z-28.239
    N8269 X43.237 Z-28.346
    N8270 X42.772 Z-28.484
    N8271 X41.842 Z-28.84
    N8272 X40.912 Z-29.28
    N8273 X39.982 Z-29.788
    N8274 X39.053 Z-30.364
    N8275 X38.123 Z-30.997
    N8276 X37.193 Z-31.674
    N8277 X36.263 Z-32.402
    N8278 X35.333 Z-33.182
    N8279 X34.403 Z-34.012
    N8280 X32.903 Z-35.463
    N8281 X31.193 Z-37.301
    N8282 X30.053 Z-38.472
    N8283 X28.912 Z-39.553
    N8284 X27.474 Z-40.815
    N8285 X26.035 Z-41.969
    N8286 X25.092 Z-42.672
    N8287 X24.148 Z-43.334
    N8288 X23.205 Z-43.96
    N8289 X22.262 Z-44.551
    N8290 X21.345 Z-45.094
    N8291 X19.513 Z-46.09
    N8292 X17.658 Z-46.984
    N8293 X15.783 Z-47.781
    N8294 X14.845 Z-48.14
    N8295 X13.001 Z-48.775
    N8296 X11.158 Z-49.318
    N8297 X9.273 Z-49.782
    N8298 X7.422 Z-50.151
    N8299 X5.554 Z-50.437
    N8300 X3.719 Z-50.637
    N8301 X1.862 Z-50.759
    N8302 X0. Z-50.8
    N8303 X-1.862 Z-50.759
    N8304 X-3.719 Z-50.637
    N8305 X-5.554 Z-50.437
    N8306 X-7.422 Z-50.151
    N8307 X-9.273 Z-49.782
    N8308 X-11.158 Z-49.318
    N8309 X-13.001 Z-48.775
    N8310 X-14.845 Z-48.14
    N8311 X-16.721 Z-47.395
    N8312 X-18.596 Z-46.545
    N8313 X-20.429 Z-45.606
    N8314 X-21.345 Z-45.094
    N8315 X-22.262 Z-44.551
    N8316 X-23.205 Z-43.96
    N8317 X-24.148 Z-43.334
    N8318 X-25.092 Z-42.672
    N8319 X-26.754 Z-41.405
    N8320 X-28.193 Z-40.198
    N8321 X-28.912 Z-39.553
    N8322 X-30.053 Z-38.472
    N8323 X-31.193 Z-37.301
    N8324 X-32.903 Z-35.463
    N8325 X-34.403 Z-34.012
    N8326 X-35.333 Z-33.182
    N8327 X-36.263 Z-32.402
    N8328 X-37.193 Z-31.674
    N8329 X-38.123 Z-30.997
    N8330 X-39.053 Z-30.364
    N8331 X-39.982 Z-29.788
    N8332 X-40.912 Z-29.28
    N8333 X-41.842 Z-28.84
    N8334 X-42.772 Z-28.484
    N8335 X-43.237 Z-28.346
    N8336 X-43.702 Z-28.239
    N8337 X-44.167 Z-28.162
    N8338 X-44.631 Z-28.119
    N8339 X-119.003 Z-28.114
    N8340 X-119.017 Z-10.557
    N8341 X-119.133 Z-9.454
    N8342 X-119.366 Z-8.342
    N8343 X-119.598 Z-7.568
    N8344 X-119.947 Z-6.674
    N8345 X-120.412 Z-5.739
    N8346 X-120.877 Z-4.981
    N8347 X-121.342 Z-4.335
    N8348 X-121.807 Z-3.769
    N8349 X-122.272 Z-3.278
    N8350 X-122.736 Z-2.837
    N8351 X-123.201 Z-2.444
    N8352 X-123.666 Z-2.094
    N8353 X-124.131 Z-1.776
    N8354 X-125.061 Z-1.24
    N8355 X-125.526 Z-1.015
    N8356 X-126.456 Z-.638
    N8357 X-127.386 Z-.354
    N8358 X-128.315 Z-.156
    N8359 X-129.245 Z-.039
    N8360 X-130.175 Z0.
    N8361 Y36.575
    N8362 X-129.245 Z-.039
    N8363 X-128.315 Z-.156
    N8364 X-127.386 Z-.354
    N8365 X-126.456 Z-.638
    N8366 X-125.526 Z-1.015
    N8367 X-125.061 Z-1.24
    N8368 X-124.131 Z-1.776
    N8369 X-123.666 Z-2.094
    N8370 X-123.201 Z-2.444
    N8371 X-122.736 Z-2.837
    N8372 X-122.272 Z-3.278
    N8373 X-121.807 Z-3.769
    N8374 X-121.342 Z-4.335
    N8375 X-120.877 Z-4.981
    N8376 X-120.412 Z-5.739
    N8377 X-119.947 Z-6.674
    N8378 X-119.598 Z-7.568
    N8379 X-119.366 Z-8.342
    N8380 X-119.133 Z-9.454
    N8381 X-119.017 Z-10.557
    N8382 X-119.003 Z-30.226
    N8383 X-43.702
    N8384 X-42.772 Z-30.259
    N8385 X-42.307 Z-30.322
    N8386 X-41.842 Z-30.417
    N8387 X-40.912 Z-30.685
    N8388 X-39.982 Z-31.037
    N8389 X-39.053 Z-31.463
    N8390 X-38.123 Z-31.958
    N8391 X-37.193 Z-32.503
    N8392 X-36.263 Z-33.105
    N8393 X-35.333 Z-33.761
    N8394 X-34.403 Z-34.465
    N8395 X-33.474 Z-35.218
    N8396 X-32.544 Z-36.027
    N8397 X-31.614 Z-36.898
    N8398 X-29.754 Z-38.761
    N8399 X-28.824 Z-39.633
    N8400 X-27.895 Z-40.457
    N8401 X-26.965 Z-41.234
    N8402 X-26.035 Z-41.969
    N8403 X-25.092 Z-42.672
    N8404 X-24.148 Z-43.334
    N8405 X-23.205 Z-43.96
    N8406 X-22.262 Z-44.551
    N8407 X-21.345 Z-45.094
    N8408 X-20.429 Z-45.606
    N8409 X-18.596 Z-46.545
    N8410 X-16.721 Z-47.395
    N8411 X-14.845 Z-48.14
    N8412 X-13.001 Z-48.775
    N8413 X-11.158 Z-49.318
    N8414 X-9.273 Z-49.782
    N8415 X-7.422 Z-50.151
    N8416 X-5.554 Z-50.437
    N8417 X-3.719 Z-50.637
    N8418 X-1.862 Z-50.759
    N8419 X0. Z-50.8
    N8420 X1.862 Z-50.759
    N8421 X3.719 Z-50.637
    N8422 X5.554 Z-50.437
    N8423 X7.422 Z-50.151
    N8424 X9.273 Z-49.782
    N8425 X11.158 Z-49.318
    N8426 X13.001 Z-48.775
    N8427 X14.845 Z-48.14
    N8428 X15.783 Z-47.781
    N8429 X17.658 Z-46.984
    N8430 X19.513 Z-46.09
    N8431 X21.345 Z-45.094
    N8432 X22.262 Z-44.551
    N8433 X23.205 Z-43.96
    N8434 X24.148 Z-43.334
    N8435 X25.092 Z-42.672
    N8436 X26.035 Z-41.969
    N8437 X26.965 Z-41.234
    N8438 X27.895 Z-40.457
    N8439 X28.824 Z-39.633
    N8440 X29.754 Z-38.761
    N8441 X31.614 Z-36.898
    N8442 X32.544 Z-36.027
    N8443 X33.474 Z-35.218
    N8444 X34.403 Z-34.465
    N8445 X35.333 Z-33.761
    N8446 X36.263 Z-33.105
    N8447 X37.193 Z-32.503
    N8448 X38.123 Z-31.958
    N8449 X39.053 Z-31.463
    N8450 X39.982 Z-31.037
    N8451 X40.912 Z-30.685
    N8452 X41.842 Z-30.417
    N8453 X42.307 Z-30.322
    N8454 X42.772 Z-30.259
    N8455 X43.702 Z-30.226
    N8456 X119.003
    N8457 X119.01 Z-10.724
    N8458 X119.104 Z-9.653
    N8459 X119.308 Z-8.571
    N8460 X119.598 Z-7.568
    N8461 X119.947 Z-6.674
    N8462 X120.179 Z-6.185
    N8463 X120.644 Z-5.343
    N8464 X121.109 Z-4.641
    N8465 X121.807 Z-3.769
    N8466 X122.272 Z-3.278
    N8467 X122.736 Z-2.837
    N8468 X123.201 Z-2.444
    N8469 X123.666 Z-2.094
    N8470 X124.131 Z-1.776
    N8471 X125.061 Z-1.24
    N8472 X125.526 Z-1.015
    N8473 X126.456 Z-.638
    N8474 X127.386 Z-.354
    N8475 X128.315 Z-.156
    N8476 X129.245 Z-.039
    N8477 X130.175 Z0.
    N8478 Y35.375
    N8479 X129.245 Z-.039
    N8480 X128.315 Z-.156
    N8481 X127.386 Z-.354
    N8482 X126.456 Z-.638
    N8483 X125.526 Z-1.015
    N8484 X125.061 Z-1.24
    N8485 X124.131 Z-1.776
    N8486 X123.666 Z-2.094
    N8487 X123.201 Z-2.444
    N8488 X122.736 Z-2.837
    N8489 X122.272 Z-3.278
    N8490 X121.807 Z-3.769
    N8491 X121.109 Z-4.641
    N8492 X120.644 Z-5.343
    N8493 X120.179 Z-6.185
    N8494 X119.947 Z-6.674
    N8495 X119.598 Z-7.568
    N8496 X119.308 Z-8.571
    N8497 X119.104 Z-9.653
    N8498 X119.01 Z-10.724
    N8499 X119.003 Z-32.09
    N8500 X41.842 Z-32.091
    N8501 X41.377 Z-32.115
    N8502 X40.912 Z-32.171
    N8503 X40.447 Z-32.256
    N8504 X39.982 Z-32.367
    N8505 X39.053 Z-32.641
    N8506 X38.123 Z-32.999
    N8507 X37.193 Z-33.416
    N8508 X36.263 Z-33.896
    N8509 X35.333 Z-34.434
    N8510 X34.403 Z-35.016
    N8511 X33.474 Z-35.654
    N8512 X32.544 Z-36.347
    N8513 X31.614 Z-37.089
    N8514 X30.684 Z-37.891
    N8515 X28.817 Z-39.64
    N8516 X27.88 Z-40.469
    N8517 X26.957 Z-41.24
    N8518 X26.035 Z-41.969
    N8519 X25.092 Z-42.672
    N8520 X24.148 Z-43.334
    N8521 X23.205 Z-43.96
    N8522 X22.262 Z-44.551
    N8523 X21.345 Z-45.094
    N8524 X19.513 Z-46.09
    N8525 X17.658 Z-46.984
    N8526 X15.783 Z-47.781
    N8527 X14.845 Z-48.14
    N8528 X13.001 Z-48.775
    N8529 X11.158 Z-49.318
    N8530 X9.273 Z-49.782
    N8531 X7.422 Z-50.151
    N8532 X5.554 Z-50.437
    N8533 X3.719 Z-50.637
    N8534 X1.862 Z-50.759
    N8535 X0. Z-50.8
    N8536 X-1.862 Z-50.759
    N8537 X-3.719 Z-50.637
    N8538 X-5.554 Z-50.437
    N8539 X-7.422 Z-50.151
    N8540 X-9.273 Z-49.782
    N8541 X-11.158 Z-49.318
    N8542 X-13.001 Z-48.775
    N8543 X-14.845 Z-48.14
    N8544 X-16.721 Z-47.395
    N8545 X-18.596 Z-46.545
    N8546 X-20.429 Z-45.606
    N8547 X-21.345 Z-45.094
    N8548 X-22.262 Z-44.551
    N8549 X-23.205 Z-43.96
    N8550 X-24.148 Z-43.334
    N8551 X-25.092 Z-42.672
    N8552 X-26.035 Z-41.969
    N8553 X-26.957 Z-41.24
    N8554 X-27.88 Z-40.469
    N8555 X-28.817 Z-39.64
    N8556 X-30.684 Z-37.891
    N8557 X-31.614 Z-37.089
    N8558 X-32.544 Z-36.347
    N8559 X-33.474 Z-35.654
    N8560 X-34.403 Z-35.016
    N8561 X-35.333 Z-34.434
    N8562 X-36.263 Z-33.896
    N8563 X-37.193 Z-33.416
    N8564 X-38.123 Z-32.999
    N8565 X-39.053 Z-32.641
    N8566 X-39.982 Z-32.367
    N8567 X-40.447 Z-32.256
    N8568 X-40.912 Z-32.171
    N8569 X-41.377 Z-32.115
    N8570 X-41.842 Z-32.091
    N8571 X-119.003 Z-32.09
    N8572 X-119.017 Z-10.557
    N8573 X-119.133 Z-9.454
    N8574 X-119.366 Z-8.342
    N8575 X-119.598 Z-7.568
    N8576 X-119.947 Z-6.674
    N8577 X-120.412 Z-5.739
    N8578 X-120.877 Z-4.981
    N8579 X-121.342 Z-4.335
    N8580 X-121.807 Z-3.769
    N8581 X-122.272 Z-3.278
    N8582 X-122.736 Z-2.837
    N8583 X-123.201 Z-2.444
    N8584 X-123.666 Z-2.094
    N8585 X-124.131 Z-1.776
    N8586 X-125.061 Z-1.24
    N8587 X-125.526 Z-1.015
    N8588 X-126.456 Z-.638
    N8589 X-127.386 Z-.354
    N8590 X-128.315 Z-.156
    N8591 X-129.245 Z-.039
    N8592 X-130.175 Z0.
    N8593 Y34.175
    N8594 X-129.245 Z-.039
    N8595 X-128.315 Z-.156
    N8596 X-127.386 Z-.354
    N8597 X-126.456 Z-.638
    N8598 X-125.526 Z-1.015
    N8599 X-125.061 Z-1.24
    N8600 X-124.131 Z-1.776
    N8601 X-123.666 Z-2.094
    N8602 X-123.201 Z-2.444
    N8603 X-122.736 Z-2.837
    N8604 X-122.272 Z-3.278
    N8605 X-121.807 Z-3.769
    N8606 X-121.342 Z-4.335
    N8607 X-120.877 Z-4.981
    N8608 X-120.412 Z-5.739
    N8609 X-119.947 Z-6.674
    N8610 X-119.598 Z-7.568
    N8611 X-119.366 Z-8.342
    N8612 X-119.133 Z-9.454
    N8613 X-119.017 Z-10.557
    N8614 X-119.003 Z-33.765
    N8615 X-40.912
    N8616 X-39.982 Z-33.785
    N8617 X-39.517 Z-33.833
    N8618 X-39.053 Z-33.908
    N8619 X-38.123 Z-34.124
    N8620 X-37.193 Z-34.413
    N8621 X-36.263 Z-34.771
    N8622 X-35.333 Z-35.19
    N8623 X-34.403 Z-35.662
    N8624 X-33.474 Z-36.191
    N8625 X-32.544 Z-36.768
    N8626 X-31.614 Z-37.398
    N8627 X-30.684 Z-38.085
    N8628 X-29.754 Z-38.827
    N8629 X-28.433 Z-39.989
    N8630 X-27.112 Z-41.113
    N8631 X-26.035 Z-41.969
    N8632 X-25.092 Z-42.672
    N8633 X-24.148 Z-43.334
    N8634 X-23.205 Z-43.96
    N8635 X-22.262 Z-44.551
    N8636 X-21.345 Z-45.094
    N8637 X-20.429 Z-45.606
    N8638 X-18.596 Z-46.545
    N8639 X-16.721 Z-47.395
    N8640 X-14.845 Z-48.14
    N8641 X-13.001 Z-48.775
    N8642 X-11.158 Z-49.318
    N8643 X-9.273 Z-49.782
    N8644 X-7.422 Z-50.151
    N8645 X-5.554 Z-50.437
    N8646 X-3.719 Z-50.637
    N8647 X-1.862 Z-50.759
    N8648 X0. Z-50.8
    N8649 X1.862 Z-50.759
    N8650 X3.719 Z-50.637
    N8651 X5.554 Z-50.437
    N8652 X7.422 Z-50.151
    N8653 X9.273 Z-49.782
    N8654 X11.158 Z-49.318
    N8655 X13.001 Z-48.775
    N8656 X14.845 Z-48.14
    N8657 X15.783 Z-47.781
    N8658 X17.658 Z-46.984
    N8659 X19.513 Z-46.09
    N8660 X21.345 Z-45.094
    N8661 X22.262 Z-44.551
    N8662 X23.205 Z-43.96
    N8663 X24.148 Z-43.334
    N8664 X25.092 Z-42.672
    N8665 X26.035 Z-41.969
    N8666 X27.112 Z-41.113
    N8667 X28.433 Z-39.989
    N8668 X29.754 Z-38.827
    N8669 X30.684 Z-38.085
    N8670 X31.614 Z-37.398
    N8671 X32.544 Z-36.768
    N8672 X33.474 Z-36.191
    N8673 X34.403 Z-35.662
    N8674 X35.333 Z-35.19
    N8675 X36.263 Z-34.771
    N8676 X37.193 Z-34.413
    N8677 X38.123 Z-34.124
    N8678 X39.053 Z-33.908
    N8679 X39.517 Z-33.833
    N8680 X39.982 Z-33.785
    N8681 X40.912 Z-33.765
    N8682 X119.003
    N8683 X119.01 Z-10.724
    N8684 X119.104 Z-9.653
    N8685 X119.308 Z-8.571
    N8686 X119.598 Z-7.568
    N8687 X119.947 Z-6.674
    N8688 X120.179 Z-6.185
    N8689 X120.644 Z-5.343
    N8690 X121.109 Z-4.641
    N8691 X121.807 Z-3.769
    N8692 X122.272 Z-3.278
    N8693 X122.736 Z-2.837
    N8694 X123.201 Z-2.444
    N8695 X123.666 Z-2.094
    N8696 X124.131 Z-1.776
    N8697 X125.061 Z-1.24
    N8698 X125.526 Z-1.015
    N8699 X126.456 Z-.638
    N8700 X127.386 Z-.354
    N8701 X128.315 Z-.156
    N8702 X129.245 Z-.039
    N8703 X130.175 Z0.
    N8704 Y32.975
    N8705 X129.245 Z-.039
    N8706 X128.315 Z-.156
    N8707 X127.386 Z-.354
    N8708 X126.456 Z-.638
    N8709 X125.526 Z-1.015
    N8710 X125.061 Z-1.24
    N8711 X124.131 Z-1.776
    N8712 X123.666 Z-2.094
    N8713 X123.201 Z-2.444
    N8714 X122.736 Z-2.837
    N8715 X122.272 Z-3.278
    N8716 X121.807 Z-3.769
    N8717 X121.109 Z-4.641
    N8718 X120.644 Z-5.343
    N8719 X120.179 Z-6.185
    N8720 X119.947 Z-6.674
    N8721 X119.598 Z-7.568
    N8722 X119.308 Z-8.571
    N8723 X119.104 Z-9.653
    N8724 X119.01 Z-10.724
    N8725 X119.003 Z-35.281
    N8726 X39.053 Z-35.283
    N8727 X38.123 Z-35.344
    N8728 X37.193 Z-35.499
    N8729 X36.263 Z-35.732
    N8730 X35.333 Z-36.033
    N8731 X34.403 Z-36.395
    N8732 X33.474 Z-36.816
    N8733 X32.544 Z-37.286
    N8734 X31.614 Z-37.814
    N8735 X30.684 Z-38.389
    N8736 X29.754 Z-39.019
    N8737 X28.824 Z-39.71
    N8738 X26.965 Z-41.234
    N8739 X26.035 Z-41.969
    N8740 X25.092 Z-42.672
    N8741 X24.148 Z-43.334
    N8742 X23.205 Z-43.96
    N8743 X22.262 Z-44.551
    N8744 X21.345 Z-45.094
    N8745 X19.513 Z-46.09
    N8746 X17.658 Z-46.984
    N8747 X15.783 Z-47.781
    N8748 X14.845 Z-48.14
    N8749 X13.001 Z-48.775
    N8750 X11.158 Z-49.318
    N8751 X9.273 Z-49.782
    N8752 X7.422 Z-50.151
    N8753 X5.554 Z-50.437
    N8754 X3.719 Z-50.637
    N8755 X1.862 Z-50.759
    N8756 X0. Z-50.8
    N8757 X-1.862 Z-50.759
    N8758 X-3.719 Z-50.637
    N8759 X-5.554 Z-50.437
    N8760 X-7.422 Z-50.151
    N8761 X-9.273 Z-49.782
    N8762 X-11.158 Z-49.318
    N8763 X-13.001 Z-48.775
    N8764 X-14.845 Z-48.14
    N8765 X-16.721 Z-47.395
    N8766 X-18.596 Z-46.545
    N8767 X-20.429 Z-45.606
    N8768 X-21.345 Z-45.094
    N8769 X-22.262 Z-44.551
    N8770 X-23.205 Z-43.96
    N8771 X-24.148 Z-43.334
    N8772 X-25.092 Z-42.672
    N8773 X-26.035 Z-41.969
    N8774 X-26.965 Z-41.234
    N8775 X-28.824 Z-39.71
    N8776 X-29.754 Z-39.019
    N8777 X-30.684 Z-38.389
    N8778 X-31.614 Z-37.814
    N8779 X-32.544 Z-37.286
    N8780 X-33.474 Z-36.816
    N8781 X-34.403 Z-36.395
    N8782 X-35.333 Z-36.033
    N8783 X-36.263 Z-35.732
    N8784 X-37.193 Z-35.499
    N8785 X-38.123 Z-35.344
    N8786 X-39.053 Z-35.283
    N8787 X-119.003 Z-35.281
    N8788 X-119.017 Z-10.557
    N8789 X-119.133 Z-9.454
    N8790 X-119.366 Z-8.342
    N8791 X-119.598 Z-7.568
    N8792 X-119.947 Z-6.674
    N8793 X-120.412 Z-5.739
    N8794 X-120.877 Z-4.981
    N8795 X-121.342 Z-4.335
    N8796 X-121.807 Z-3.769
    N8797 X-122.272 Z-3.278
    N8798 X-122.736 Z-2.837
    N8799 X-123.201 Z-2.444
    N8800 X-123.666 Z-2.094
    N8801 X-124.131 Z-1.776
    N8802 X-125.061 Z-1.24
    N8803 X-125.526 Z-1.015
    N8804 X-126.456 Z-.638
    N8805 X-127.386 Z-.354
    N8806 X-128.315 Z-.156
    N8807 X-129.245 Z-.039
    N8808 X-130.175 Z0.
    N8809 Y31.775
    N8810 X-129.245 Z-.039
    N8811 X-128.315 Z-.156
    N8812 X-127.386 Z-.354
    N8813 X-126.456 Z-.638
    N8814 X-125.526 Z-1.015
    N8815 X-125.061 Z-1.24
    N8816 X-124.131 Z-1.776
    N8817 X-123.666 Z-2.094
    N8818 X-123.201 Z-2.444
    N8819 X-122.736 Z-2.837
    N8820 X-122.272 Z-3.278
    N8821 X-121.807 Z-3.769
    N8822 X-121.342 Z-4.335
    N8823 X-120.877 Z-4.981
    N8824 X-120.412 Z-5.739
    N8825 X-119.947 Z-6.674
    N8826 X-119.598 Z-7.568
    N8827 X-119.366 Z-8.342
    N8828 X-119.133 Z-9.454
    N8829 X-119.017 Z-10.557
    N8830 X-119.003 Z-36.668
    N8831 X-37.193 Z-36.686
    N8832 X-36.263 Z-36.786
    N8833 X-35.333 Z-36.965
    N8834 X-34.403 Z-37.216
    N8835 X-33.474 Z-37.526
    N8836 X-32.544 Z-37.895
    N8837 X-31.614 Z-38.319
    N8838 X-30.684 Z-38.792
    N8839 X-29.754 Z-39.324
    N8840 X-28.824 Z-39.9
    N8841 X-27.895 Z-40.538
    N8842 X-26.035 Z-41.969
    N8843 X-25.092 Z-42.672
    N8844 X-24.148 Z-43.334
    N8845 X-23.205 Z-43.96
    N8846 X-22.262 Z-44.551
    N8847 X-21.345 Z-45.094
    N8848 X-20.429 Z-45.606
    N8849 X-18.596 Z-46.545
    N8850 X-16.721 Z-47.395
    N8851 X-14.845 Z-48.14
    N8852 X-13.001 Z-48.775
    N8853 X-11.158 Z-49.318
    N8854 X-9.273 Z-49.782
    N8855 X-7.422 Z-50.151
    N8856 X-5.554 Z-50.437
    N8857 X-3.719 Z-50.637
    N8858 X-1.862 Z-50.759
    N8859 X0. Z-50.8
    N8860 X1.862 Z-50.759
    N8861 X3.719 Z-50.637
    N8862 X5.554 Z-50.437
    N8863 X7.422 Z-50.151
    N8864 X9.273 Z-49.782
    N8865 X11.158 Z-49.318
    N8866 X13.001 Z-48.775
    N8867 X14.845 Z-48.14
    N8868 X15.783 Z-47.781
    N8869 X17.658 Z-46.984
    N8870 X19.513 Z-46.09
    N8871 X21.345 Z-45.094
    N8872 X22.262 Z-44.551
    N8873 X23.205 Z-43.96
    N8874 X24.148 Z-43.334
    N8875 X25.092 Z-42.672
    N8876 X27.895 Z-40.538
    N8877 X28.824 Z-39.9
    N8878 X29.754 Z-39.324
    N8879 X30.684 Z-38.792
    N8880 X31.614 Z-38.319
    N8881 X32.544 Z-37.895
    N8882 X33.474 Z-37.526
    N8883 X34.403 Z-37.216
    N8884 X35.333 Z-36.965
    N8885 X36.263 Z-36.786
    N8886 X37.193 Z-36.686
    N8887 X39.053 Z-36.668
    N8888 X119.003
    N8889 X119.01 Z-10.724
    N8890 X119.104 Z-9.653
    N8891 X119.308 Z-8.571
    N8892 X119.598 Z-7.568
    N8893 X119.947 Z-6.674
    N8894 X120.179 Z-6.185
    N8895 X120.644 Z-5.343
    N8896 X121.109 Z-4.641
    N8897 X121.807 Z-3.769
    N8898 X122.272 Z-3.278
    N8899 X122.736 Z-2.837
    N8900 X123.201 Z-2.444
    N8901 X123.666 Z-2.094
    N8902 X124.131 Z-1.776
    N8903 X125.061 Z-1.24
    N8904 X125.526 Z-1.015
    N8905 X126.456 Z-.638
    N8906 X127.386 Z-.354
    N8907 X128.315 Z-.156
    N8908 X129.245 Z-.039
    N8909 X130.175 Z0.
    N8910 Y30.575
    N8911 X129.245 Z-.039
    N8912 X128.315 Z-.156
    N8913 X127.386 Z-.354
    N8914 X126.456 Z-.638
    N8915 X125.526 Z-1.015
    N8916 X125.061 Z-1.24
    N8917 X124.131 Z-1.776
    N8918 X123.666 Z-2.094
    N8919 X123.201 Z-2.444
    N8920 X122.736 Z-2.837
    N8921 X122.272 Z-3.278
    N8922 X121.807 Z-3.769
    N8923 X121.109 Z-4.641
    N8924 X120.644 Z-5.343
    N8925 X120.179 Z-6.185
    N8926 X119.947 Z-6.674
    N8927 X119.598 Z-7.568
    N8928 X119.308 Z-8.571
    N8929 X119.104 Z-9.653
    N8930 X119.01 Z-10.724
    N8931 X119.003 Z-37.946
    N8932 X36.263
    N8933 X35.333 Z-37.993
    N8934 X34.403 Z-38.127
    N8935 X33.474 Z-38.325
    N8936 X32.544 Z-38.593
    N8937 X31.614 Z-38.911
    N8938 X30.684 Z-39.29
    N8939 X29.754 Z-39.718
    N8940 X28.824 Z-40.199
    N8941 X27.895 Z-40.734
    N8942 X26.965 Z-41.322
    N8943 X26.035 Z-41.974
    N8944 X25.087 Z-42.675
    N8945 X24.139 Z-43.341
    N8946 X23.19 Z-43.97
    N8947 X22.242 Z-44.563
    N8948 X21.331 Z-45.102
    N8949 X19.508 Z-46.092
    N8950 X17.658 Z-46.984
    N8951 X15.783 Z-47.781
    N8952 X13.923 Z-48.469
    N8953 X13.001 Z-48.775
    N8954 X11.158 Z-49.318
    N8955 X9.273 Z-49.782
    N8956 X7.422 Z-50.151
    N8957 X5.554 Z-50.437
    N8958 X3.719 Z-50.637
    N8959 X1.862 Z-50.759
    N8960 X0. Z-50.8
    N8961 X-1.862 Z-50.759
    N8962 X-3.719 Z-50.637
    N8963 X-5.554 Z-50.437
    N8964 X-7.422 Z-50.151
    N8965 X-9.273 Z-49.782
    N8966 X-11.158 Z-49.318
    N8967 X-13.001 Z-48.775
    N8968 X-14.845 Z-48.14
    N8969 X-16.721 Z-47.395
    N8970 X-18.596 Z-46.545
    N8971 X-20.419 Z-45.611
    N8972 X-21.331 Z-45.102
    N8973 X-22.242 Z-44.563
    N8974 X-23.19 Z-43.97
    N8975 X-24.139 Z-43.341
    N8976 X-25.087 Z-42.675
    N8977 X-26.035 Z-41.974
    N8978 X-26.965 Z-41.322
    N8979 X-27.895 Z-40.734
    N8980 X-28.824 Z-40.199
    N8981 X-29.754 Z-39.718
    N8982 X-30.684 Z-39.29
    N8983 X-31.614 Z-38.911
    N8984 X-32.544 Z-38.593
    N8985 X-33.474 Z-38.325
    N8986 X-34.403 Z-38.127
    N8987 X-35.333 Z-37.993
    N8988 X-36.263 Z-37.946
    N8989 X-119.003
    N8990 X-119.017 Z-10.557
    N8991 X-119.133 Z-9.454
    N8992 X-119.366 Z-8.342
    N8993 X-119.598 Z-7.568
    N8994 X-119.947 Z-6.674
    N8995 X-120.412 Z-5.739
    N8996 X-120.877 Z-4.981
    N8997 X-121.342 Z-4.335
    N8998 X-121.807 Z-3.769
    N8999 X-122.272 Z-3.278
    N9000 X-122.736 Z-2.837
    N9001 X-123.201 Z-2.444
    N9002 X-123.666 Z-2.094
    N9003 X-124.131 Z-1.776
    N9004 X-125.061 Z-1.24
    N9005 X-125.526 Z-1.015
    N9006 X-126.456 Z-.638
    N9007 X-127.386 Z-.354
    N9008 X-128.315 Z-.156
    N9009 X-129.245 Z-.039
    N9010 X-130.175 Z0.
    N9011 Y29.375
    N9012 X-129.245 Z-.039
    N9013 X-128.315 Z-.156
    N9014 X-127.386 Z-.354
    N9015 X-126.456 Z-.638
    N9016 X-125.526 Z-1.015
    N9017 X-125.061 Z-1.24
    N9018 X-124.131 Z-1.776
    N9019 X-123.666 Z-2.094
    N9020 X-123.201 Z-2.444
    N9021 X-122.736 Z-2.837
    N9022 X-122.272 Z-3.278
    N9023 X-121.807 Z-3.769
    N9024 X-121.342 Z-4.335
    N9025 X-120.877 Z-4.981
    N9026 X-120.412 Z-5.739
    N9027 X-119.947 Z-6.674
    N9028 X-119.598 Z-7.568
    N9029 X-119.366 Z-8.342
    N9030 X-119.133 Z-9.454
    N9031 X-119.017 Z-10.557
    N9032 X-119.003 Z-39.124
    N9033 X-34.403 Z-39.138
    N9034 X-33.474 Z-39.217
    N9035 X-32.544 Z-39.375
    N9036 X-31.614 Z-39.593
    N9037 X-30.684 Z-39.873
    N9038 X-29.754 Z-40.204
    N9039 X-28.824 Z-40.593
    N9040 X-27.895 Z-41.028
    N9041 X-26.965 Z-41.522
    N9042 X-26.035 Z-42.064
    N9043 X-24.965 Z-42.763
    N9044 X-23.896 Z-43.504
    N9045 X-22.826 Z-44.201
    N9046 X-21.756 Z-44.855
    N9047 X-20.176 Z-45.742
    N9048 X-18.596 Z-46.545
    N9049 X-16.721 Z-47.395
    N9050 X-14.845 Z-48.14
    N9051 X-13.001 Z-48.775
    N9052 X-11.158 Z-49.318
    N9053 X-9.273 Z-49.782
    N9054 X-7.422 Z-50.151
    N9055 X-5.554 Z-50.437
    N9056 X-3.719 Z-50.637
    N9057 X-1.862 Z-50.759
    N9058 X0. Z-50.8
    N9059 X1.862 Z-50.759
    N9060 X3.719 Z-50.637
    N9061 X5.554 Z-50.437
    N9062 X7.422 Z-50.151
    N9063 X9.273 Z-49.782
    N9064 X11.158 Z-49.318
    N9065 X13.001 Z-48.775
    N9066 X14.845 Z-48.14
    N9067 X16.721 Z-47.395
    N9068 X18.596 Z-46.545
    N9069 X20.176 Z-45.742
    N9070 X21.756 Z-44.855
    N9071 X22.826 Z-44.201
    N9072 X23.896 Z-43.504
    N9073 X24.965 Z-42.763
    N9074 X26.035 Z-42.064
    N9075 X26.965 Z-41.522
    N9076 X27.895 Z-41.028
    N9077 X28.824 Z-40.593
    N9078 X29.754 Z-40.204
    N9079 X30.684 Z-39.873
    N9080 X31.614 Z-39.593
    N9081 X32.544 Z-39.375
    N9082 X33.474 Z-39.217
    N9083 X34.403 Z-39.138
    N9084 X35.333 Z-39.124
    N9085 X119.003
    N9086 X119.01 Z-10.724
    N9087 X119.104 Z-9.653
    N9088 X119.308 Z-8.571
    N9089 X119.598 Z-7.568
    N9090 X119.947 Z-6.674
    N9091 X120.179 Z-6.185
    N9092 X120.644 Z-5.343
    N9093 X121.109 Z-4.641
    N9094 X121.807 Z-3.769
    N9095 X122.272 Z-3.278
    N9096 X122.736 Z-2.837
    N9097 X123.201 Z-2.444
    N9098 X123.666 Z-2.094
    N9099 X124.131 Z-1.776
    N9100 X125.061 Z-1.24
    N9101 X125.526 Z-1.015
    N9102 X126.456 Z-.638
    N9103 X127.386 Z-.354
    N9104 X128.315 Z-.156
    N9105 X129.245 Z-.039
    N9106 X130.175 Z0.
    N9107 Y28.175
    N9108 X129.245 Z-.039
    N9109 X128.315 Z-.156
    N9110 X127.386 Z-.354
    N9111 X126.456 Z-.638
    N9112 X125.526 Z-1.015
    N9113 X125.061 Z-1.24
    N9114 X124.131 Z-1.776
    N9115 X123.666 Z-2.094
    N9116 X123.201 Z-2.444
    N9117 X122.736 Z-2.837
    N9118 X122.272 Z-3.278
    N9119 X121.807 Z-3.769
    N9120 X121.109 Z-4.641
    N9121 X120.644 Z-5.343
    N9122 X120.179 Z-6.185
    N9123 X119.947 Z-6.674
    N9124 X119.598 Z-7.568
    N9125 X119.308 Z-8.571
    N9126 X119.104 Z-9.653
    N9127 X119.01 Z-10.724
    N9128 X119.003 Z-40.214
    N9129 X33.474
    N9130 X32.544 Z-40.252
    N9131 X31.614 Z-40.365
    N9132 X30.684 Z-40.541
    N9133 X29.754 Z-40.781
    N9134 X28.824 Z-41.07
    N9135 X27.895 Z-41.418
    N9136 X26.965 Z-41.813
    N9137 X26.035 Z-42.263
    N9138 X25.105 Z-42.766
    N9139 X24.175 Z-43.325
    N9140 X22.316 Z-44.519
    N9141 X21.386 Z-45.071
    N9142 X20.456 Z-45.592
    N9143 X19.526 Z-46.083
    N9144 X17.658 Z-46.984
    N9145 X15.783 Z-47.781
    N9146 X14.845 Z-48.14
    N9147 X13.001 Z-48.775
    N9148 X11.158 Z-49.318
    N9149 X9.273 Z-49.782
    N9150 X7.422 Z-50.151
    N9151 X5.554 Z-50.437
    N9152 X3.719 Z-50.637
    N9153 X1.862 Z-50.759
    N9154 X0. Z-50.8
    N9155 X-1.862 Z-50.759
    N9156 X-3.719 Z-50.637
    N9157 X-5.554 Z-50.437
    N9158 X-7.422 Z-50.151
    N9159 X-9.273 Z-49.782
    N9160 X-11.158 Z-49.318
    N9161 X-13.001 Z-48.775
    N9162 X-14.845 Z-48.14
    N9163 X-16.721 Z-47.395
    N9164 X-18.596 Z-46.545
    N9165 X-19.526 Z-46.083
    N9166 X-20.456 Z-45.592
    N9167 X-21.386 Z-45.071
    N9168 X-22.316 Z-44.519
    N9169 X-24.175 Z-43.325
    N9170 X-25.105 Z-42.766
    N9171 X-26.035 Z-42.263
    N9172 X-26.965 Z-41.813
    N9173 X-27.895 Z-41.418
    N9174 X-28.824 Z-41.07
    N9175 X-29.754 Z-40.781
    N9176 X-30.684 Z-40.541
    N9177 X-31.614 Z-40.365
    N9178 X-32.544 Z-40.252
    N9179 X-33.474 Z-40.214
    N9180 X-119.003
    N9181 X-119.017 Z-10.557
    N9182 X-119.133 Z-9.454
    N9183 X-119.366 Z-8.342
    N9184 X-119.598 Z-7.568
    N9185 X-119.947 Z-6.674
    N9186 X-120.412 Z-5.739
    N9187 X-120.877 Z-4.981
    N9188 X-121.342 Z-4.335
    N9189 X-121.807 Z-3.769
    N9190 X-122.272 Z-3.278
    N9191 X-122.736 Z-2.837
    N9192 X-123.201 Z-2.444
    N9193 X-123.666 Z-2.094
    N9194 X-124.131 Z-1.776
    N9195 X-125.061 Z-1.24
    N9196 X-125.526 Z-1.015
    N9197 X-126.456 Z-.638
    N9198 X-127.386 Z-.354
    N9199 X-128.315 Z-.156
    N9200 X-129.245 Z-.039
    N9201 X-130.175 Z0.
    N9202 Y26.975
    N9203 X-129.245 Z-.039
    N9204 X-128.315 Z-.156
    N9205 X-127.386 Z-.354
    N9206 X-126.456 Z-.638
    N9207 X-125.526 Z-1.015
    N9208 X-125.061 Z-1.24
    N9209 X-124.131 Z-1.776
    N9210 X-123.666 Z-2.094
    N9211 X-123.201 Z-2.444
    N9212 X-122.736 Z-2.837
    N9213 X-122.272 Z-3.278
    N9214 X-121.807 Z-3.769
    N9215 X-121.342 Z-4.335
    N9216 X-120.877 Z-4.981
    N9217 X-120.412 Z-5.739
    N9218 X-119.947 Z-6.674
    N9219 X-119.598 Z-7.568
    N9220 X-119.366 Z-8.342
    N9221 X-119.133 Z-9.454
    N9222 X-119.017 Z-10.557
    N9223 X-119.003 Z-41.226
    N9224 X-31.614 Z-41.236
    N9225 X-30.684 Z-41.302
    N9226 X-29.754 Z-41.441
    N9227 X-28.824 Z-41.637
    N9228 X-27.895 Z-41.892
    N9229 X-26.965 Z-42.198
    N9230 X-26.035 Z-42.557
    N9231 X-25.105 Z-42.966
    N9232 X-24.175 Z-43.431
    N9233 X-23.246 Z-43.948
    N9234 X-21.359 Z-45.086
    N9235 X-20.45 Z-45.595
    N9236 X-18.596 Z-46.545
    N9237 X-16.721 Z-47.395
    N9238 X-14.845 Z-48.14
    N9239 X-13.001 Z-48.775
    N9240 X-11.158 Z-49.318
    N9241 X-9.273 Z-49.782
    N9242 X-7.422 Z-50.151
    N9243 X-5.554 Z-50.437
    N9244 X-3.719 Z-50.637
    N9245 X-1.862 Z-50.759
    N9246 X0. Z-50.8
    N9247 X1.862 Z-50.759
    N9248 X3.719 Z-50.637
    N9249 X5.554 Z-50.437
    N9250 X7.422 Z-50.151
    N9251 X9.273 Z-49.782
    N9252 X11.158 Z-49.318
    N9253 X13.001 Z-48.775
    N9254 X14.845 Z-48.14
    N9255 X16.721 Z-47.395
    N9256 X18.596 Z-46.545
    N9257 X20.45 Z-45.595
    N9258 X21.359 Z-45.086
    N9259 X23.246 Z-43.948
    N9260 X24.175 Z-43.431
    N9261 X25.105 Z-42.966
    N9262 X26.035 Z-42.557
    N9263 X26.965 Z-42.198
    N9264 X27.895 Z-41.892
    N9265 X28.824 Z-41.637
    N9266 X29.754 Z-41.441
    N9267 X30.684 Z-41.302
    N9268 X31.614 Z-41.236
    N9269 X119.003 Z-41.226
    N9270 X119.01 Z-10.724
    N9271 X119.104 Z-9.653
    N9272 X119.308 Z-8.571
    N9273 X119.598 Z-7.568
    N9274 X119.947 Z-6.674
    N9275 X120.179 Z-6.185
    N9276 X120.644 Z-5.343
    N9277 X121.109 Z-4.641
    N9278 X121.807 Z-3.769
    N9279 X122.272 Z-3.278
    N9280 X122.736 Z-2.837
    N9281 X123.201 Z-2.444
    N9282 X123.666 Z-2.094
    N9283 X124.131 Z-1.776
    N9284 X125.061 Z-1.24
    N9285 X125.526 Z-1.015
    N9286 X126.456 Z-.638
    N9287 X127.386 Z-.354
    N9288 X128.315 Z-.156
    N9289 X129.245 Z-.039
    N9290 X130.175 Z0.
    N9291 Y25.775
    N9292 X129.245 Z-.039
    N9293 X128.315 Z-.156
    N9294 X127.386 Z-.354
    N9295 X126.456 Z-.638
    N9296 X125.526 Z-1.015
    N9297 X125.061 Z-1.24
    N9298 X124.131 Z-1.776
    N9299 X123.666 Z-2.094
    N9300 X123.201 Z-2.444
    N9301 X122.736 Z-2.837
    N9302 X122.272 Z-3.278
    N9303 X121.807 Z-3.769
    N9304 X121.109 Z-4.641
    N9305 X120.644 Z-5.343
    N9306 X120.179 Z-6.185
    N9307 X119.947 Z-6.674
    N9308 X119.598 Z-7.568
    N9309 X119.308 Z-8.571
    N9310 X119.104 Z-9.653
    N9311 X119.01 Z-10.724
    N9312 X119.003 Z-42.165
    N9313 X30.684
    N9314 X29.754 Z-42.194
    N9315 X28.824 Z-42.295
    N9316 X27.895 Z-42.451
    N9317 X26.965 Z-42.671
    N9318 X26.035 Z-42.937
    N9319 X25.105 Z-43.262
    N9320 X24.175 Z-43.631
    N9321 X23.246 Z-44.061
    N9322 X22.316 Z-44.537
    N9323 X20.258 Z-45.698
    N9324 X18.596 Z-46.545
    N9325 X16.721 Z-47.395
    N9326 X14.845 Z-48.14
    N9327 X13.001 Z-48.775
    N9328 X11.158 Z-49.318
    N9329 X9.273 Z-49.782
    N9330 X7.422 Z-50.151
    N9331 X5.554 Z-50.437
    N9332 X3.719 Z-50.637
    N9333 X1.862 Z-50.759
    N9334 X0. Z-50.8
    N9335 X-1.862 Z-50.759
    N9336 X-3.719 Z-50.637
    N9337 X-5.554 Z-50.437
    N9338 X-7.422 Z-50.151
    N9339 X-9.273 Z-49.782
    N9340 X-11.158 Z-49.318
    N9341 X-13.001 Z-48.775
    N9342 X-14.845 Z-48.14
    N9343 X-16.721 Z-47.395
    N9344 X-18.596 Z-46.545
    N9345 X-20.258 Z-45.698
    N9346 X-22.316 Z-44.537
    N9347 X-23.246 Z-44.061
    N9348 X-24.175 Z-43.631
    N9349 X-25.105 Z-43.262
    N9350 X-26.035 Z-42.937
    N9351 X-26.965 Z-42.671
    N9352 X-27.895 Z-42.451
    N9353 X-28.824 Z-42.295
    N9354 X-29.754 Z-42.194
    N9355 X-30.684 Z-42.165
    N9356 X-119.003
    N9357 X-119.017 Z-10.557
    N9358 X-119.133 Z-9.454
    N9359 X-119.366 Z-8.342
    N9360 X-119.598 Z-7.568
    N9361 X-119.947 Z-6.674
    N9362 X-120.412 Z-5.739
    N9363 X-120.877 Z-4.981
    N9364 X-121.342 Z-4.335
    N9365 X-121.807 Z-3.769
    N9366 X-122.272 Z-3.278
    N9367 X-122.736 Z-2.837
    N9368 X-123.201 Z-2.444
    N9369 X-123.666 Z-2.094
    N9370 X-124.131 Z-1.776
    N9371 X-125.061 Z-1.24
    N9372 X-125.526 Z-1.015
    N9373 X-126.456 Z-.638
    N9374 X-127.386 Z-.354
    N9375 X-128.315 Z-.156
    N9376 X-129.245 Z-.039
    N9377 X-130.175 Z0.
    N9378 Y24.575
    N9379 X-129.245 Z-.039
    N9380 X-128.315 Z-.156
    N9381 X-127.386 Z-.354
    N9382 X-126.456 Z-.638
    N9383 X-125.526 Z-1.015
    N9384 X-125.061 Z-1.24
    N9385 X-124.131 Z-1.776
    N9386 X-123.666 Z-2.094
    N9387 X-123.201 Z-2.444
    N9388 X-122.736 Z-2.837
    N9389 X-122.272 Z-3.278
    N9390 X-121.807 Z-3.769
    N9391 X-121.342 Z-4.335
    N9392 X-120.877 Z-4.981
    N9393 X-120.412 Z-5.739
    N9394 X-119.947 Z-6.674
    N9395 X-119.598 Z-7.568
    N9396 X-119.366 Z-8.342
    N9397 X-119.133 Z-9.454
    N9398 X-119.017 Z-10.557
    N9399 X-119.003 Z-43.037
    N9400 X-28.824 Z-43.043
    N9401 X-27.895 Z-43.103
    N9402 X-26.965 Z-43.225
    N9403 X-26.035 Z-43.407
    N9404 X-25.105 Z-43.639
    N9405 X-24.175 Z-43.927
    N9406 X-23.246 Z-44.262
    N9407 X-22.316 Z-44.654
    N9408 X-21.386 Z-45.094
    N9409 X-19.526 Z-46.083
    N9410 X-18.596 Z-46.545
    N9411 X-16.721 Z-47.395
    N9412 X-14.845 Z-48.14
    N9413 X-13.001 Z-48.775
    N9414 X-11.158 Z-49.318
    N9415 X-9.273 Z-49.782
    N9416 X-7.422 Z-50.151
    N9417 X-5.554 Z-50.437
    N9418 X-3.719 Z-50.637
    N9419 X-1.862 Z-50.759
    N9420 X0. Z-50.8
    N9421 X1.862 Z-50.759
    N9422 X3.719 Z-50.637
    N9423 X5.554 Z-50.437
    N9424 X7.422 Z-50.151
    N9425 X9.273 Z-49.782
    N9426 X11.158 Z-49.318
    N9427 X13.001 Z-48.775
    N9428 X14.845 Z-48.14
    N9429 X15.783 Z-47.781
    N9430 X17.658 Z-46.984
    N9431 X19.526 Z-46.083
    N9432 X21.386 Z-45.094
    N9433 X22.316 Z-44.654
    N9434 X23.246 Z-44.262
    N9435 X24.175 Z-43.927
    N9436 X25.105 Z-43.639
    N9437 X26.035 Z-43.407
    N9438 X26.965 Z-43.225
    N9439 X27.895 Z-43.103
    N9440 X28.824 Z-43.043
    N9441 X119.003 Z-43.037
    N9442 X119.01 Z-10.724
    N9443 X119.104 Z-9.653
    N9444 X119.308 Z-8.571
    N9445 X119.598 Z-7.568
    N9446 X119.947 Z-6.674
    N9447 X120.179 Z-6.185
    N9448 X120.644 Z-5.343
    N9449 X121.109 Z-4.641
    N9450 X121.807 Z-3.769
    N9451 X122.272 Z-3.278
    N9452 X122.736 Z-2.837
    N9453 X123.201 Z-2.444
    N9454 X123.666 Z-2.094
    N9455 X124.131 Z-1.776
    N9456 X125.061 Z-1.24
    N9457 X125.526 Z-1.015
    N9458 X126.456 Z-.638
    N9459 X127.386 Z-.354
    N9460 X128.315 Z-.156
    N9461 X129.245 Z-.039
    N9462 X130.175 Z0.
    N9463 Y23.375
    N9464 X129.245 Z-.039
    N9465 X128.315 Z-.156
    N9466 X127.386 Z-.354
    N9467 X126.456 Z-.638
    N9468 X125.526 Z-1.015
    N9469 X125.061 Z-1.24
    N9470 X124.131 Z-1.776
    N9471 X123.666 Z-2.094
    N9472 X123.201 Z-2.444
    N9473 X122.736 Z-2.837
    N9474 X122.272 Z-3.278
    N9475 X121.807 Z-3.769
    N9476 X121.109 Z-4.641
    N9477 X120.644 Z-5.343
    N9478 X120.179 Z-6.185
    N9479 X119.947 Z-6.674
    N9480 X119.598 Z-7.568
    N9481 X119.308 Z-8.571
    N9482 X119.104 Z-9.653
    N9483 X119.01 Z-10.724
    N9484 X119.003 Z-43.852
    N9485 X27.895
    N9486 X26.965 Z-43.873
    N9487 X26.035 Z-43.961
    N9488 X25.105 Z-44.106
    N9489 X24.175 Z-44.305
    N9490 X23.246 Z-44.557
    N9491 X22.316 Z-44.859
    N9492 X21.386 Z-45.215
    N9493 X20.456 Z-45.621
    N9494 X18.596 Z-46.545
    N9495 X16.721 Z-47.395
    N9496 X14.845 Z-48.14
    N9497 X13.001 Z-48.775
    N9498 X11.158 Z-49.318
    N9499 X9.273 Z-49.782
    N9500 X7.422 Z-50.151
    N9501 X5.554 Z-50.437
    N9502 X3.719 Z-50.637
    N9503 X1.862 Z-50.759
    N9504 X0. Z-50.8
    N9505 X-1.862 Z-50.759
    N9506 X-3.719 Z-50.637
    N9507 X-5.554 Z-50.437
    N9508 X-7.422 Z-50.151
    N9509 X-9.273 Z-49.782
    N9510 X-11.158 Z-49.318
    N9511 X-13.001 Z-48.775
    N9512 X-14.845 Z-48.14
    N9513 X-16.721 Z-47.395
    N9514 X-18.596 Z-46.545
    N9515 X-20.456 Z-45.621
    N9516 X-21.386 Z-45.215
    N9517 X-22.316 Z-44.859
    N9518 X-23.246 Z-44.557
    N9519 X-24.175 Z-44.305
    N9520 X-25.105 Z-44.106
    N9521 X-26.035 Z-43.961
    N9522 X-26.965 Z-43.873
    N9523 X-27.895 Z-43.852
    N9524 X-119.003
    N9525 X-119.017 Z-10.557
    N9526 X-119.133 Z-9.454
    N9527 X-119.366 Z-8.342
    N9528 X-119.598 Z-7.568
    N9529 X-119.947 Z-6.674
    N9530 X-120.412 Z-5.739
    N9531 X-120.877 Z-4.981
    N9532 X-121.342 Z-4.335
    N9533 X-121.807 Z-3.769
    N9534 X-122.272 Z-3.278
    N9535 X-122.736 Z-2.837
    N9536 X-123.201 Z-2.444
    N9537 X-123.666 Z-2.094
    N9538 X-124.131 Z-1.776
    N9539 X-125.061 Z-1.24
    N9540 X-125.526 Z-1.015
    N9541 X-126.456 Z-.638
    N9542 X-127.386 Z-.354
    N9543 X-128.315 Z-.156
    N9544 X-129.245 Z-.039
    N9545 X-130.175 Z0.
    N9546 Y22.175
    N9547 X-129.245 Z-.039
    N9548 X-128.315 Z-.156
    N9549 X-127.386 Z-.354
    N9550 X-126.456 Z-.638
    N9551 X-125.526 Z-1.015
    N9552 X-125.061 Z-1.24
    N9553 X-124.131 Z-1.776
    N9554 X-123.666 Z-2.094
    N9555 X-123.201 Z-2.444
    N9556 X-122.736 Z-2.837
    N9557 X-122.272 Z-3.278
    N9558 X-121.807 Z-3.769
    N9559 X-121.342 Z-4.335
    N9560 X-120.877 Z-4.981
    N9561 X-120.412 Z-5.739
    N9562 X-119.947 Z-6.674
    N9563 X-119.598 Z-7.568
    N9564 X-119.366 Z-8.342
    N9565 X-119.133 Z-9.454
    N9566 X-119.017 Z-10.557
    N9567 X-119.003 Z-44.603
    N9568 X-26.035 Z-44.606
    N9569 X-25.105 Z-44.661
    N9570 X-24.175 Z-44.769
    N9571 X-23.246 Z-44.937
    N9572 X-22.316 Z-45.155
    N9573 X-21.386 Z-45.424
    N9574 X-20.456 Z-45.745
    N9575 X-19.526 Z-46.118
    N9576 X-16.721 Z-47.395
    N9577 X-14.845 Z-48.14
    N9578 X-13.001 Z-48.775
    N9579 X-11.158 Z-49.318
    N9580 X-9.273 Z-49.782
    N9581 X-7.422 Z-50.151
    N9582 X-5.554 Z-50.437
    N9583 X-3.719 Z-50.637
    N9584 X-1.862 Z-50.759
    N9585 X0. Z-50.8
    N9586 X1.862 Z-50.759
    N9587 X3.719 Z-50.637
    N9588 X5.554 Z-50.437
    N9589 X7.422 Z-50.151
    N9590 X9.273 Z-49.782
    N9591 X11.158 Z-49.318
    N9592 X13.001 Z-48.775
    N9593 X14.845 Z-48.14
    N9594 X15.783 Z-47.781
    N9595 X17.658 Z-46.984
    N9596 X19.526 Z-46.118
    N9597 X20.456 Z-45.745
    N9598 X21.386 Z-45.424
    N9599 X22.316 Z-45.155
    N9600 X23.246 Z-44.937
    N9601 X24.175 Z-44.769
    N9602 X25.105 Z-44.661
    N9603 X26.035 Z-44.606
    N9604 X119.003 Z-44.603
    N9605 X119.01 Z-10.724
    N9606 X119.104 Z-9.653
    N9607 X119.308 Z-8.571
    N9608 X119.598 Z-7.568
    N9609 X119.947 Z-6.674
    N9610 X120.179 Z-6.185
    N9611 X120.644 Z-5.343
    N9612 X121.109 Z-4.641
    N9613 X121.807 Z-3.769
    N9614 X122.272 Z-3.278
    N9615 X122.736 Z-2.837
    N9616 X123.201 Z-2.444
    N9617 X123.666 Z-2.094
    N9618 X124.131 Z-1.776
    N9619 X125.061 Z-1.24
    N9620 X125.526 Z-1.015
    N9621 X126.456 Z-.638
    N9622 X127.386 Z-.354
    N9623 X128.315 Z-.156
    N9624 X129.245 Z-.039
    N9625 X130.175 Z0.
    N9626 Y20.975
    N9627 X129.245 Z-.039
    N9628 X128.315 Z-.156
    N9629 X127.386 Z-.354
    N9630 X126.456 Z-.638
    N9631 X125.526 Z-1.015
    N9632 X125.061 Z-1.24
    N9633 X124.131 Z-1.776
    N9634 X123.666 Z-2.094
    N9635 X123.201 Z-2.444
    N9636 X122.736 Z-2.837
    N9637 X122.272 Z-3.278
    N9638 X121.807 Z-3.769
    N9639 X121.109 Z-4.641
    N9640 X120.644 Z-5.343
    N9641 X120.179 Z-6.185
    N9642 X119.947 Z-6.674
    N9643 X119.598 Z-7.568
    N9644 X119.308 Z-8.571
    N9645 X119.104 Z-9.653
    N9646 X119.01 Z-10.724
    N9647 X119.003 Z-45.304
    N9648 X26.035
    N9649 X24.175 Z-45.326
    N9650 X23.246 Z-45.401
    N9651 X22.316 Z-45.536
    N9652 X21.386 Z-45.721
    N9653 X20.456 Z-45.959
    N9654 X19.526 Z-46.247
    N9655 X18.596 Z-46.587
    N9656 X16.58 Z-47.454
    N9657 X15.572 Z-47.863
    N9658 X14.564 Z-48.242
    N9659 X12.861 Z-48.819
    N9660 X11.158 Z-49.318
    N9661 X9.273 Z-49.782
    N9662 X7.422 Z-50.151
    N9663 X5.554 Z-50.437
    N9664 X3.719 Z-50.637
    N9665 X1.862 Z-50.759
    N9666 X0. Z-50.8
    N9667 X-1.862 Z-50.759
    N9668 X-3.719 Z-50.637
    N9669 X-5.554 Z-50.437
    N9670 X-7.422 Z-50.151
    N9671 X-9.273 Z-49.782
    N9672 X-11.158 Z-49.318
    N9673 X-12.861 Z-48.819
    N9674 X-14.564 Z-48.242
    N9675 X-15.572 Z-47.863
    N9676 X-16.58 Z-47.454
    N9677 X-18.596 Z-46.587
    N9678 X-19.526 Z-46.247
    N9679 X-20.456 Z-45.959
    N9680 X-21.386 Z-45.721
    N9681 X-22.316 Z-45.536
    N9682 X-23.246 Z-45.401
    N9683 X-24.175 Z-45.326
    N9684 X-26.035 Z-45.304
    N9685 X-119.003
    N9686 X-119.017 Z-10.557
    N9687 X-119.133 Z-9.454
    N9688 X-119.366 Z-8.342
    N9689 X-119.598 Z-7.568
    N9690 X-119.947 Z-6.674
    N9691 X-120.412 Z-5.739
    N9692 X-120.877 Z-4.981
    N9693 X-121.342 Z-4.335
    N9694 X-121.807 Z-3.769
    N9695 X-122.272 Z-3.278
    N9696 X-122.736 Z-2.837
    N9697 X-123.201 Z-2.444
    N9698 X-123.666 Z-2.094
    N9699 X-124.131 Z-1.776
    N9700 X-125.061 Z-1.24
    N9701 X-125.526 Z-1.015
    N9702 X-126.456 Z-.638
    N9703 X-127.386 Z-.354
    N9704 X-128.315 Z-.156
    N9705 X-129.245 Z-.039
    N9706 X-130.175 Z0.
    N9707 Y19.775
    N9708 X-129.245 Z-.039
    N9709 X-128.315 Z-.156
    N9710 X-127.386 Z-.354
    N9711 X-126.456 Z-.638
    N9712 X-125.526 Z-1.015
    N9713 X-125.061 Z-1.24
    N9714 X-124.131 Z-1.776
    N9715 X-123.666 Z-2.094
    N9716 X-123.201 Z-2.444
    N9717 X-122.736 Z-2.837
    N9718 X-122.272 Z-3.278
    N9719 X-121.807 Z-3.769
    N9720 X-121.342 Z-4.335
    N9721 X-120.877 Z-4.981
    N9722 X-120.412 Z-5.739
    N9723 X-119.947 Z-6.674
    N9724 X-119.598 Z-7.568
    N9725 X-119.366 Z-8.342
    N9726 X-119.133 Z-9.454
    N9727 X-119.017 Z-10.557
    N9728 X-119.003 Z-45.957
    N9729 X-23.246 Z-45.958
    N9730 X-22.316 Z-46.
    N9731 X-21.386 Z-46.105
    N9732 X-20.456 Z-46.257
    N9733 X-19.526 Z-46.465
    N9734 X-18.596 Z-46.72
    N9735 X-17.667 Z-47.029
    N9736 X-14.877 Z-48.128
    N9737 X-12.992 Z-48.778
    N9738 X-11.158 Z-49.318
    N9739 X-9.273 Z-49.782
    N9740 X-7.422 Z-50.151
    N9741 X-5.554 Z-50.437
    N9742 X-3.719 Z-50.637
    N9743 X-1.862 Z-50.759
    N9744 X0. Z-50.8
    N9745 X1.862 Z-50.759
    N9746 X3.719 Z-50.637
    N9747 X5.554 Z-50.437
    N9748 X7.422 Z-50.151
    N9749 X9.273 Z-49.782
    N9750 X11.158 Z-49.318
    N9751 X12.992 Z-48.778
    N9752 X14.877 Z-48.128
    N9753 X17.667 Z-47.029
    N9754 X18.596 Z-46.72
    N9755 X19.526 Z-46.465
    N9756 X20.456 Z-46.257
    N9757 X21.386 Z-46.105
    N9758 X22.316 Z-46.
    N9759 X23.246 Z-45.958
    N9760 X119.003 Z-45.957
    N9761 X119.01 Z-10.724
    N9762 X119.104 Z-9.653
    N9763 X119.308 Z-8.571
    N9764 X119.598 Z-7.568
    N9765 X119.947 Z-6.674
    N9766 X120.179 Z-6.185
    N9767 X120.644 Z-5.343
    N9768 X121.109 Z-4.641
    N9769 X121.807 Z-3.769
    N9770 X122.272 Z-3.278
    N9771 X122.736 Z-2.837
    N9772 X123.201 Z-2.444
    N9773 X123.666 Z-2.094
    N9774 X124.131 Z-1.776
    N9775 X125.061 Z-1.24
    N9776 X125.526 Z-1.015
    N9777 X126.456 Z-.638
    N9778 X127.386 Z-.354
    N9779 X128.315 Z-.156
    N9780 X129.245 Z-.039
    N9781 X130.175 Z0.
    N9782 Y18.575
    N9783 X129.245 Z-.039
    N9784 X128.315 Z-.156
    N9785 X127.386 Z-.354
    N9786 X126.456 Z-.638
    N9787 X125.526 Z-1.015
    N9788 X125.061 Z-1.24
    N9789 X124.131 Z-1.776
    N9790 X123.666 Z-2.094
    N9791 X123.201 Z-2.444
    N9792 X122.736 Z-2.837
    N9793 X122.272 Z-3.278
    N9794 X121.807 Z-3.769
    N9795 X121.109 Z-4.641
    N9796 X120.644 Z-5.343
    N9797 X120.179 Z-6.185
    N9798 X119.947 Z-6.674
    N9799 X119.598 Z-7.568
    N9800 X119.308 Z-8.571
    N9801 X119.104 Z-9.653
    N9802 X119.01 Z-10.724
    N9803 X119.003 Z-46.556
    N9804 X22.316
    N9805 X21.386 Z-46.57
    N9806 X20.456 Z-46.643
    N9807 X19.526 Z-46.764
    N9808 X18.596 Z-46.942
    N9809 X17.667 Z-47.166
    N9810 X16.737 Z-47.444
    N9811 X15.807 Z-47.772
    N9812 X14.877 Z-48.128
    N9813 X13.011 Z-48.772
    N9814 X11.158 Z-49.318
    N9815 X9.273 Z-49.782
    N9816 X7.422 Z-50.151
    N9817 X5.554 Z-50.437
    N9818 X3.719 Z-50.637
    N9819 X1.862 Z-50.759
    N9820 X0. Z-50.8
    N9821 X-1.862 Z-50.759
    N9822 X-3.719 Z-50.637
    N9823 X-5.554 Z-50.437
    N9824 X-7.422 Z-50.151
    N9825 X-9.273 Z-49.782
    N9826 X-11.158 Z-49.318
    N9827 X-13.011 Z-48.772
    N9828 X-14.877 Z-48.128
    N9829 X-15.807 Z-47.772
    N9830 X-16.737 Z-47.444
    N9831 X-17.667 Z-47.166
    N9832 X-18.596 Z-46.942
    N9833 X-19.526 Z-46.764
    N9834 X-20.456 Z-46.643
    N9835 X-21.386 Z-46.57
    N9836 X-119.003 Z-46.556
    N9837 X-119.017 Z-10.557
    N9838 X-119.133 Z-9.454
    N9839 X-119.366 Z-8.342
    N9840 X-119.598 Z-7.568
    N9841 X-119.947 Z-6.674
    N9842 X-120.412 Z-5.739
    N9843 X-120.877 Z-4.981
    N9844 X-121.342 Z-4.335
    N9845 X-121.807 Z-3.769
    N9846 X-122.272 Z-3.278
    N9847 X-122.736 Z-2.837
    N9848 X-123.201 Z-2.444
    N9849 X-123.666 Z-2.094
    N9850 X-124.131 Z-1.776
    N9851 X-125.061 Z-1.24
    N9852 X-125.526 Z-1.015
    N9853 X-126.456 Z-.638
    N9854 X-127.386 Z-.354
    N9855 X-128.315 Z-.156
    N9856 X-129.245 Z-.039
    N9857 X-130.175 Z0.
    N9858 Y17.375
    N9859 X-129.245 Z-.039
    N9860 X-128.315 Z-.156
    N9861 X-127.386 Z-.354
    N9862 X-126.456 Z-.638
    N9863 X-125.526 Z-1.015
    N9864 X-125.061 Z-1.24
    N9865 X-124.131 Z-1.776
    N9866 X-123.666 Z-2.094
    N9867 X-123.201 Z-2.444
    N9868 X-122.736 Z-2.837
    N9869 X-122.272 Z-3.278
    N9870 X-121.807 Z-3.769
    N9871 X-121.342 Z-4.335
    N9872 X-120.877 Z-4.981
    N9873 X-120.412 Z-5.739
    N9874 X-119.947 Z-6.674
    N9875 X-119.598 Z-7.568
    N9876 X-119.366 Z-8.342
    N9877 X-119.133 Z-9.454
    N9878 X-119.017 Z-10.557
    N9879 X-119.003 Z-47.111
    N9880 X-20.456 Z-47.112
    N9881 X-19.526 Z-47.153
    N9882 X-18.596 Z-47.244
    N9883 X-17.667 Z-47.393
    N9884 X-16.737 Z-47.586
    N9885 X-15.807 Z-47.834
    N9886 X-14.877 Z-48.13
    N9887 X-13.006 Z-48.773
    N9888 X-11.158 Z-49.318
    N9889 X-9.273 Z-49.782
    N9890 X-7.422 Z-50.151
    N9891 X-5.554 Z-50.437
    N9892 X-3.719 Z-50.637
    N9893 X-1.862 Z-50.759
    N9894 X0. Z-50.8
    N9895 X1.862 Z-50.759
    N9896 X3.719 Z-50.637
    N9897 X5.554 Z-50.437
    N9898 X7.422 Z-50.151
    N9899 X9.273 Z-49.782
    N9900 X11.158 Z-49.318
    N9901 X13.006 Z-48.773
    N9902 X14.877 Z-48.13
    N9903 X15.807 Z-47.834
    N9904 X16.737 Z-47.586
    N9905 X17.667 Z-47.393
    N9906 X18.596 Z-47.244
    N9907 X19.526 Z-47.153
    N9908 X20.456 Z-47.112
    N9909 X119.003 Z-47.111
    N9910 X119.01 Z-10.724
    N9911 X119.104 Z-9.653
    N9912 X119.308 Z-8.571
    N9913 X119.598 Z-7.568
    N9914 X119.947 Z-6.674
    N9915 X120.179 Z-6.185
    N9916 X120.644 Z-5.343
    N9917 X121.109 Z-4.641
    N9918 X121.807 Z-3.769
    N9919 X122.272 Z-3.278
    N9920 X122.736 Z-2.837
    N9921 X123.201 Z-2.444
    N9922 X123.666 Z-2.094
    N9923 X124.131 Z-1.776
    N9924 X125.061 Z-1.24
    N9925 X125.526 Z-1.015
    N9926 X126.456 Z-.638
    N9927 X127.386 Z-.354
    N9928 X128.315 Z-.156
    N9929 X129.245 Z-.039
    N9930 X130.175 Z0.
    N9931 Y16.175
    N9932 X129.245 Z-.039
    N9933 X128.315 Z-.156
    N9934 X127.386 Z-.354
    N9935 X126.456 Z-.638
    N9936 X125.526 Z-1.015
    N9937 X125.061 Z-1.24
    N9938 X124.131 Z-1.776
    N9939 X123.666 Z-2.094
    N9940 X123.201 Z-2.444
    N9941 X122.736 Z-2.837
    N9942 X122.272 Z-3.278
    N9943 X121.807 Z-3.769
    N9944 X121.109 Z-4.641
    N9945 X120.644 Z-5.343
    N9946 X120.179 Z-6.185
    N9947 X119.947 Z-6.674
    N9948 X119.598 Z-7.568
    N9949 X119.308 Z-8.571
    N9950 X119.104 Z-9.653
    N9951 X119.01 Z-10.724
    N9952 X119.003 Z-47.624
    N9953 X18.596 Z-47.636
    N9954 X17.667 Z-47.698
    N9955 X16.737 Z-47.817
    N9956 X15.807 Z-47.98
    N9957 X14.877 Z-48.199
    N9958 X13.947 Z-48.465
    N9959 X13.017 Z-48.77
    N9960 X11.158 Z-49.318
    N9961 X9.273 Z-49.782
    N9962 X7.422 Z-50.151
    N9963 X5.554 Z-50.437
    N9964 X3.719 Z-50.637
    N9965 X1.862 Z-50.759
    N9966 X0. Z-50.8
    N9967 X-1.862 Z-50.759
    N9968 X-3.719 Z-50.637
    N9969 X-5.554 Z-50.437
    N9970 X-7.422 Z-50.151
    N9971 X-9.273 Z-49.782
    N9972 X-11.158 Z-49.318
    N9973 X-14.877 Z-48.199
    N9974 X-15.807 Z-47.98
    N9975 X-16.737 Z-47.817
    N9976 X-17.667 Z-47.698
    N9977 X-18.596 Z-47.636
    N9978 X-119.003 Z-47.624
    N9979 X-119.017 Z-10.557
    N9980 X-119.133 Z-9.454
    N9981 X-119.366 Z-8.342
    N9982 X-119.598 Z-7.568
    N9983 X-119.947 Z-6.674
    N9984 X-120.412 Z-5.739
    N9985 X-120.877 Z-4.981
    N9986 X-121.342 Z-4.335
    N9987 X-121.807 Z-3.769
    N9988 X-122.272 Z-3.278
    N9989 X-122.736 Z-2.837
    N9990 X-123.201 Z-2.444
    N9991 X-123.666 Z-2.094
    N9992 X-124.131 Z-1.776
    N9993 X-125.061 Z-1.24
    N9994 X-125.526 Z-1.015
    N9995 X-126.456 Z-.638
    N9996 X-127.386 Z-.354
    N9997 X-128.315 Z-.156
    N9998 X-129.245 Z-.039
    N9999 X-130.175 Z0.
    N10000 Y14.975
    N10001 X-129.245 Z-.039
    N10002 X-128.315 Z-.156
    N10003 X-127.386 Z-.354
    N10004 X-126.456 Z-.638
    N10005 X-125.526 Z-1.015
    N10006 X-125.061 Z-1.24
    N10007 X-124.131 Z-1.776
    N10008 X-123.666 Z-2.094
    N10009 X-123.201 Z-2.444
    N10010 X-122.736 Z-2.837
    N10011 X-122.272 Z-3.278
    N10012 X-121.807 Z-3.769
    N10013 X-121.342 Z-4.335
    N10014 X-120.877 Z-4.981
    N10015 X-120.412 Z-5.739
    N10016 X-119.947 Z-6.674
    N10017 X-119.598 Z-7.568
    N10018 X-119.366 Z-8.342
    N10019 X-119.133 Z-9.454
    N10020 X-119.017 Z-10.557
    N10021 X-119.003 Z-48.093
    N10022 X-17.667 Z-48.093
    N10023 X-16.737 Z-48.125
    N10024 X-15.807 Z-48.215
    N10025 X-14.877 Z-48.35
    N10026 X-13.947 Z-48.54
    N10027 X-13.017 Z-48.776
    N10028 X-11.158 Z-49.318
    N10029 X-9.273 Z-49.782
    N10030 X-7.422 Z-50.151
    N10031 X-5.554 Z-50.437
    N10032 X-3.719 Z-50.637
    N10033 X-1.862 Z-50.759
    N10034 X0. Z-50.8
    N10035 X1.862 Z-50.759
    N10036 X3.719 Z-50.637
    N10037 X5.554 Z-50.437
    N10038 X7.422 Z-50.151
    N10039 X9.273 Z-49.782
    N10040 X11.158 Z-49.318
    N10041 X13.017 Z-48.776
    N10042 X13.947 Z-48.54
    N10043 X14.877 Z-48.35
    N10044 X15.807 Z-48.215
    N10045 X16.737 Z-48.125
    N10046 X17.667 Z-48.093
    N10047 X119.003 Z-48.093
    N10048 X119.01 Z-10.724
    N10049 X119.104 Z-9.653
    N10050 X119.308 Z-8.571
    N10051 X119.598 Z-7.568
    N10052 X119.947 Z-6.674
    N10053 X120.179 Z-6.185
    N10054 X120.644 Z-5.343
    N10055 X121.109 Z-4.641
    N10056 X121.807 Z-3.769
    N10057 X122.272 Z-3.278
    N10058 X122.736 Z-2.837
    N10059 X123.201 Z-2.444
    N10060 X123.666 Z-2.094
    N10061 X124.131 Z-1.776
    N10062 X125.061 Z-1.24
    N10063 X125.526 Z-1.015
    N10064 X126.456 Z-.638
    N10065 X127.386 Z-.354
    N10066 X128.315 Z-.156
    N10067 X129.245 Z-.039
    N10068 X130.175 Z0.
    N10069 Y13.775
    N10070 X129.245 Z-.039
    N10071 X128.315 Z-.156
    N10072 X127.386 Z-.354
    N10073 X126.456 Z-.638
    N10074 X125.526 Z-1.015
    N10075 X125.061 Z-1.24
    N10076 X124.131 Z-1.776
    N10077 X123.666 Z-2.094
    N10078 X123.201 Z-2.444
    N10079 X122.736 Z-2.837
    N10080 X122.272 Z-3.278
    N10081 X121.807 Z-3.769
    N10082 X121.109 Z-4.641
    N10083 X120.644 Z-5.343
    N10084 X120.179 Z-6.185
    N10085 X119.947 Z-6.674
    N10086 X119.598 Z-7.568
    N10087 X119.308 Z-8.571
    N10088 X119.104 Z-9.653
    N10089 X119.01 Z-10.724
    N10090 X119.003 Z-48.519
    N10091 X15.807 Z-48.529
    N10092 X14.877 Z-48.589
    N10093 X13.947 Z-48.695
    N10094 X13.017 Z-48.857
    N10095 X12.088 Z-49.064
    N10096 X11.158 Z-49.318
    N10097 X9.273 Z-49.782
    N10098 X7.422 Z-50.151
    N10099 X5.554 Z-50.437
    N10100 X3.719 Z-50.637
    N10101 X1.862 Z-50.759
    N10102 X0. Z-50.8
    N10103 X-1.862 Z-50.759
    N10104 X-3.719 Z-50.637
    N10105 X-5.554 Z-50.437
    N10106 X-7.422 Z-50.151
    N10107 X-9.273 Z-49.782
    N10108 X-11.158 Z-49.318
    N10109 X-12.088 Z-49.064
    N10110 X-13.017 Z-48.857
    N10111 X-13.947 Z-48.695
    N10112 X-14.877 Z-48.589
    N10113 X-15.807 Z-48.529
    N10114 X-119.003 Z-48.519
    N10115 X-119.017 Z-10.557
    N10116 X-119.133 Z-9.454
    N10117 X-119.366 Z-8.342
    N10118 X-119.598 Z-7.568
    N10119 X-119.947 Z-6.674
    N10120 X-120.412 Z-5.739
    N10121 X-120.877 Z-4.981
    N10122 X-121.342 Z-4.335
    N10123 X-121.807 Z-3.769
    N10124 X-122.272 Z-3.278
    N10125 X-122.736 Z-2.837
    N10126 X-123.201 Z-2.444
    N10127 X-123.666 Z-2.094
    N10128 X-124.131 Z-1.776
    N10129 X-125.061 Z-1.24
    N10130 X-125.526 Z-1.015
    N10131 X-126.456 Z-.638
    N10132 X-127.386 Z-.354
    N10133 X-128.315 Z-.156
    N10134 X-129.245 Z-.039
    N10135 X-130.175 Z0.
    N10136 Y12.575
    N10137 X-129.245 Z-.039
    N10138 X-128.315 Z-.156
    N10139 X-127.386 Z-.354
    N10140 X-126.456 Z-.638
    N10141 X-125.526 Z-1.015
    N10142 X-125.061 Z-1.24
    N10143 X-124.131 Z-1.776
    N10144 X-123.666 Z-2.094
    N10145 X-123.201 Z-2.444
    N10146 X-122.736 Z-2.837
    N10147 X-122.272 Z-3.278
    N10148 X-121.807 Z-3.769
    N10149 X-121.342 Z-4.335
    N10150 X-120.877 Z-4.981
    N10151 X-120.412 Z-5.739
    N10152 X-119.947 Z-6.674
    N10153 X-119.598 Z-7.568
    N10154 X-119.366 Z-8.342
    N10155 X-119.133 Z-9.454
    N10156 X-119.017 Z-10.557
    N10157 X-119.003 Z-48.908
    N10158 X-14.877 Z-48.908
    N10159 X-13.947 Z-48.939
    N10160 X-13.017 Z-49.018
    N10161 X-12.088 Z-49.152
    N10162 X-11.158 Z-49.33
    N10163 X-9.031 Z-49.833
    N10164 X-7.334 Z-50.165
    N10165 X-5.496 Z-50.444
    N10166 X-3.719 Z-50.637
    N10167 X-1.862 Z-50.759
    N10168 X0. Z-50.8
    N10169 X1.862 Z-50.759
    N10170 X3.719 Z-50.637
    N10171 X5.496 Z-50.444
    N10172 X7.334 Z-50.165
    N10173 X9.031 Z-49.833
    N10174 X11.158 Z-49.33
    N10175 X12.088 Z-49.152
    N10176 X13.017 Z-49.018
    N10177 X13.947 Z-48.939
    N10178 X14.877 Z-48.908
    N10179 X119.003 Z-48.908
    N10180 X119.01 Z-10.724
    N10181 X119.104 Z-9.653
    N10182 X119.308 Z-8.571
    N10183 X119.598 Z-7.568
    N10184 X119.947 Z-6.674
    N10185 X120.179 Z-6.185
    N10186 X120.644 Z-5.343
    N10187 X121.109 Z-4.641
    N10188 X121.807 Z-3.769
    N10189 X122.272 Z-3.278
    N10190 X122.736 Z-2.837
    N10191 X123.201 Z-2.444
    N10192 X123.666 Z-2.094
    N10193 X124.131 Z-1.776
    N10194 X125.061 Z-1.24
    N10195 X125.526 Z-1.015
    N10196 X126.456 Z-.638
    N10197 X127.386 Z-.354
    N10198 X128.315 Z-.156
    N10199 X129.245 Z-.039
    N10200 X130.175 Z0.
    N10201 Y11.375
    N10202 X129.245 Z-.039
    N10203 X128.315 Z-.156
    N10204 X127.386 Z-.354
    N10205 X126.456 Z-.638
    N10206 X125.526 Z-1.015
    N10207 X125.061 Z-1.24
    N10208 X124.131 Z-1.776
    N10209 X123.666 Z-2.094
    N10210 X123.201 Z-2.444
    N10211 X122.736 Z-2.837
    N10212 X122.272 Z-3.278
    N10213 X121.807 Z-3.769
    N10214 X121.109 Z-4.641
    N10215 X120.644 Z-5.343
    N10216 X120.179 Z-6.185
    N10217 X119.947 Z-6.674
    N10218 X119.598 Z-7.568
    N10219 X119.308 Z-8.571
    N10220 X119.104 Z-9.653
    N10221 X119.01 Z-10.724
    N10222 X119.003 Z-49.259
    N10223 X13.017 Z-49.266
    N10224 X12.088 Z-49.317
    N10225 X11.158 Z-49.424
    N10226 X9.906 Z-49.639
    N10227 X8.654 Z-49.913
    N10228 X7.354 Z-50.162
    N10229 X6.149 Z-50.353
    N10230 X5.062 Z-50.496
    N10231 X3.719 Z-50.637
    N10232 X1.862 Z-50.759
    N10233 X0. Z-50.8
    N10234 X-1.862 Z-50.759
    N10235 X-3.719 Z-50.637
    N10236 X-5.062 Z-50.496
    N10237 X-6.149 Z-50.353
    N10238 X-7.354 Z-50.162
    N10239 X-8.654 Z-49.913
    N10240 X-9.906 Z-49.639
    N10241 X-11.158 Z-49.424
    N10242 X-12.088 Z-49.317
    N10243 X-13.017 Z-49.266
    N10244 X-119.003 Z-49.259
    N10245 X-119.017 Z-10.557
    N10246 X-119.133 Z-9.454
    N10247 X-119.366 Z-8.342
    N10248 X-119.598 Z-7.568
    N10249 X-119.947 Z-6.674
    N10250 X-120.412 Z-5.739
    N10251 X-120.877 Z-4.981
    N10252 X-121.342 Z-4.335
    N10253 X-121.807 Z-3.769
    N10254 X-122.272 Z-3.278
    N10255 X-122.736 Z-2.837
    N10256 X-123.201 Z-2.444
    N10257 X-123.666 Z-2.094
    N10258 X-124.131 Z-1.776
    N10259 X-125.061 Z-1.24
    N10260 X-125.526 Z-1.015
    N10261 X-126.456 Z-.638
    N10262 X-127.386 Z-.354
    N10263 X-128.315 Z-.156
    N10264 X-129.245 Z-.039
    N10265 X-130.175 Z0.
    N10266 Y10.175
    N10267 X-129.245 Z-.039
    N10268 X-128.315 Z-.156
    N10269 X-127.386 Z-.354
    N10270 X-126.456 Z-.638
    N10271 X-125.526 Z-1.015
    N10272 X-125.061 Z-1.24
    N10273 X-124.131 Z-1.776
    N10274 X-123.666 Z-2.094
    N10275 X-123.201 Z-2.444
    N10276 X-122.736 Z-2.837
    N10277 X-122.272 Z-3.278
    N10278 X-121.807 Z-3.769
    N10279 X-121.342 Z-4.335
    N10280 X-120.877 Z-4.981
    N10281 X-120.412 Z-5.739
    N10282 X-119.947 Z-6.674
    N10283 X-119.598 Z-7.568
    N10284 X-119.366 Z-8.342
    N10285 X-119.133 Z-9.454
    N10286 X-119.017 Z-10.557
    N10287 X-119.003 Z-49.571
    N10288 X-11.158 Z-49.595
    N10289 X-10.228 Z-49.673
    N10290 X-9.298 Z-49.796
    N10291 X-7.439 Z-50.148
    N10292 X-5.58 Z-50.434
    N10293 X-3.719 Z-50.637
    N10294 X-1.862 Z-50.759
    N10295 X0. Z-50.8
    N10296 X1.862 Z-50.759
    N10297 X3.719 Z-50.637
    N10298 X5.58 Z-50.434
    N10299 X7.439 Z-50.148
    N10300 X9.298 Z-49.796
    N10301 X10.228 Z-49.673
    N10302 X11.158 Z-49.595
    N10303 X13.017 Z-49.571
    N10304 X119.003
    N10305 X119.01 Z-10.724
    N10306 X119.104 Z-9.653
    N10307 X119.308 Z-8.571
    N10308 X119.598 Z-7.568
    N10309 X119.947 Z-6.674
    N10310 X120.179 Z-6.185
    N10311 X120.644 Z-5.343
    N10312 X121.109 Z-4.641
    N10313 X121.807 Z-3.769
    N10314 X122.272 Z-3.278
    N10315 X122.736 Z-2.837
    N10316 X123.201 Z-2.444
    N10317 X123.666 Z-2.094
    N10318 X124.131 Z-1.776
    N10319 X125.061 Z-1.24
    N10320 X125.526 Z-1.015
    N10321 X126.456 Z-.638
    N10322 X127.386 Z-.354
    N10323 X128.315 Z-.156
    N10324 X129.245 Z-.039
    N10325 X130.175 Z0.
    N10326 Y8.975
    N10327 X129.245 Z-.039
    N10328 X128.315 Z-.156
    N10329 X127.386 Z-.354
    N10330 X126.456 Z-.638
    N10331 X125.526 Z-1.015
    N10332 X125.061 Z-1.24
    N10333 X124.131 Z-1.776
    N10334 X123.666 Z-2.094
    N10335 X123.201 Z-2.444
    N10336 X122.736 Z-2.837
    N10337 X122.272 Z-3.278
    N10338 X121.807 Z-3.769
    N10339 X121.109 Z-4.641
    N10340 X120.644 Z-5.343
    N10341 X120.179 Z-6.185
    N10342 X119.947 Z-6.674
    N10343 X119.598 Z-7.568
    N10344 X119.308 Z-8.571
    N10345 X119.104 Z-9.653
    N10346 X119.01 Z-10.724
    N10347 X119.003 Z-49.845
    N10348 X10.228 Z-49.851
    N10349 X9.298 Z-49.901
    N10350 X8.368 Z-49.998
    N10351 X5.589 Z-50.433
    N10352 X3.719 Z-50.637
    N10353 X1.862 Z-50.759
    N10354 X0. Z-50.8
    N10355 X-1.862 Z-50.759
    N10356 X-3.719 Z-50.637
    N10357 X-5.589 Z-50.433
    N10358 X-8.368 Z-49.998
    N10359 X-9.298 Z-49.901
    N10360 X-10.228 Z-49.851
    N10361 X-119.003 Z-49.845
    N10362 X-119.017 Z-10.557
    N10363 X-119.133 Z-9.454
    N10364 X-119.366 Z-8.342
    N10365 X-119.598 Z-7.568
    N10366 X-119.947 Z-6.674
    N10367 X-120.412 Z-5.739
    N10368 X-120.877 Z-4.981
    N10369 X-121.342 Z-4.335
    N10370 X-121.807 Z-3.769
    N10371 X-122.272 Z-3.278
    N10372 X-122.736 Z-2.837
    N10373 X-123.201 Z-2.444
    N10374 X-123.666 Z-2.094
    N10375 X-124.131 Z-1.776
    N10376 X-125.061 Z-1.24
    N10377 X-125.526 Z-1.015
    N10378 X-126.456 Z-.638
    N10379 X-127.386 Z-.354
    N10380 X-128.315 Z-.156
    N10381 X-129.245 Z-.039
    N10382 X-130.175 Z0.
    N10383 Y7.775
    N10384 X-129.245 Z-.039
    N10385 X-128.315 Z-.156
    N10386 X-127.386 Z-.354
    N10387 X-126.456 Z-.638
    N10388 X-125.526 Z-1.015
    N10389 X-125.061 Z-1.24
    N10390 X-124.131 Z-1.776
    N10391 X-123.666 Z-2.094
    N10392 X-123.201 Z-2.444
    N10393 X-122.736 Z-2.837
    N10394 X-122.272 Z-3.278
    N10395 X-121.807 Z-3.769
    N10396 X-121.342 Z-4.335
    N10397 X-120.877 Z-4.981
    N10398 X-120.412 Z-5.739
    N10399 X-119.947 Z-6.674
    N10400 X-119.598 Z-7.568
    N10401 X-119.366 Z-8.342
    N10402 X-119.133 Z-9.454
    N10403 X-119.017 Z-10.557
    N10404 X-119.003 Z-50.085
    N10405 X-9.298
    N10406 X-8.368 Z-50.108
    N10407 X-7.439 Z-50.178
    N10408 X-4.749 Z-50.534
    N10409 X-3.719 Z-50.637
    N10410 X-1.862 Z-50.759
    N10411 X0. Z-50.8
    N10412 X1.862 Z-50.759
    N10413 X3.719 Z-50.637
    N10414 X4.749 Z-50.534
    N10415 X7.439 Z-50.178
    N10416 X8.368 Z-50.108
    N10417 X9.298 Z-50.085
    N10418 X119.003
    N10419 X119.01 Z-10.724
    N10420 X119.104 Z-9.653
    N10421 X119.308 Z-8.571
    N10422 X119.598 Z-7.568
    N10423 X119.947 Z-6.674
    N10424 X120.179 Z-6.185
    N10425 X120.644 Z-5.343
    N10426 X121.109 Z-4.641
    N10427 X121.807 Z-3.769
    N10428 X122.272 Z-3.278
    N10429 X122.736 Z-2.837
    N10430 X123.201 Z-2.444
    N10431 X123.666 Z-2.094
    N10432 X124.131 Z-1.776
    N10433 X125.061 Z-1.24
    N10434 X125.526 Z-1.015
    N10435 X126.456 Z-.638
    N10436 X127.386 Z-.354
    N10437 X128.315 Z-.156
    N10438 X129.245 Z-.039
    N10439 X130.175 Z0.
    N10440 Y6.575
    N10441 X129.245 Z-.039
    N10442 X128.315 Z-.156
    N10443 X127.386 Z-.354
    N10444 X126.456 Z-.638
    N10445 X125.526 Z-1.015
    N10446 X125.061 Z-1.24
    N10447 X124.131 Z-1.776
    N10448 X123.666 Z-2.094
    N10449 X123.201 Z-2.444
    N10450 X122.736 Z-2.837
    N10451 X122.272 Z-3.278
    N10452 X121.807 Z-3.769
    N10453 X121.109 Z-4.641
    N10454 X120.644 Z-5.343
    N10455 X120.179 Z-6.185
    N10456 X119.947 Z-6.674
    N10457 X119.598 Z-7.568
    N10458 X119.308 Z-8.571
    N10459 X119.104 Z-9.653
    N10460 X119.01 Z-10.724
    N10461 X119.003 Z-50.291
    N10462 X7.439 Z-50.294
    N10463 X6.509 Z-50.337
    N10464 X3.719 Z-50.637
    N10465 X1.862 Z-50.759
    N10466 X0. Z-50.8
    N10467 X-1.862 Z-50.759
    N10468 X-3.719 Z-50.637
    N10469 X-6.509 Z-50.337
    N10470 X-7.439 Z-50.294
    N10471 X-119.003 Z-50.291
    N10472 X-119.017 Z-10.557
    N10473 X-119.133 Z-9.454
    N10474 X-119.366 Z-8.342
    N10475 X-119.598 Z-7.568
    N10476 X-119.947 Z-6.674
    N10477 X-120.412 Z-5.739
    N10478 X-120.877 Z-4.981
    N10479 X-121.342 Z-4.335
    N10480 X-121.807 Z-3.769
    N10481 X-122.272 Z-3.278
    N10482 X-122.736 Z-2.837
    N10483 X-123.201 Z-2.444
    N10484 X-123.666 Z-2.094
    N10485 X-124.131 Z-1.776
    N10486 X-125.061 Z-1.24
    N10487 X-125.526 Z-1.015
    N10488 X-126.456 Z-.638
    N10489 X-127.386 Z-.354
    N10490 X-128.315 Z-.156
    N10491 X-129.245 Z-.039
    N10492 X-130.175 Z0.
    N10493 Y5.375
    N10494 X-129.245 Z-.039
    N10495 X-128.315 Z-.156
    N10496 X-127.386 Z-.354
    N10497 X-126.456 Z-.638
    N10498 X-125.526 Z-1.015
    N10499 X-125.061 Z-1.24
    N10500 X-124.131 Z-1.776
    N10501 X-123.666 Z-2.094
    N10502 X-123.201 Z-2.444
    N10503 X-122.736 Z-2.837
    N10504 X-122.272 Z-3.278
    N10505 X-121.807 Z-3.769
    N10506 X-121.342 Z-4.335
    N10507 X-120.877 Z-4.981
    N10508 X-120.412 Z-5.739
    N10509 X-119.947 Z-6.674
    N10510 X-119.598 Z-7.568
    N10511 X-119.366 Z-8.342
    N10512 X-119.133 Z-9.454
    N10513 X-119.017 Z-10.557
    N10514 X-119.003 Z-50.459
    N10515 X-5.579 Z-50.477
    N10516 X-3.719 Z-50.637
    N10517 X-1.862 Z-50.759
    N10518 X0. Z-50.8
    N10519 X1.862 Z-50.759
    N10520 X3.719 Z-50.637
    N10521 X5.579 Z-50.477
    N10522 X7.439 Z-50.459
    N10523 X119.003
    N10524 X119.01 Z-10.724
    N10525 X119.104 Z-9.653
    N10526 X119.308 Z-8.571
    N10527 X119.598 Z-7.568
    N10528 X119.947 Z-6.674
    N10529 X120.179 Z-6.185
    N10530 X120.644 Z-5.343
    N10531 X121.109 Z-4.641
    N10532 X121.807 Z-3.769
    N10533 X122.272 Z-3.278
    N10534 X122.736 Z-2.837
    N10535 X123.201 Z-2.444
    N10536 X123.666 Z-2.094
    N10537 X124.131 Z-1.776
    N10538 X125.061 Z-1.24
    N10539 X125.526 Z-1.015
    N10540 X126.456 Z-.638
    N10541 X127.386 Z-.354
    N10542 X128.315 Z-.156
    N10543 X129.245 Z-.039
    N10544 X130.175 Z0.
    N10545 Y4.175
    N10546 X129.245 Z-.039
    N10547 X128.315 Z-.156
    N10548 X127.386 Z-.354
    N10549 X126.456 Z-.638
    N10550 X125.526 Z-1.015
    N10551 X125.061 Z-1.24
    N10552 X124.131 Z-1.776
    N10553 X123.666 Z-2.094
    N10554 X123.201 Z-2.444
    N10555 X122.736 Z-2.837
    N10556 X122.272 Z-3.278
    N10557 X121.807 Z-3.769
    N10558 X121.109 Z-4.641
    N10559 X120.644 Z-5.343
    N10560 X120.179 Z-6.185
    N10561 X119.947 Z-6.674
    N10562 X119.598 Z-7.568
    N10563 X119.308 Z-8.571
    N10564 X119.104 Z-9.653
    N10565 X119.01 Z-10.724
    N10566 X119.003 Z-50.593
    N10567 X4.649 Z-50.596
    N10568 X1.839 Z-50.76
    N10569 X0. Z-50.8
    N10570 X-1.839 Z-50.76
    N10571 X-4.649 Z-50.596
    N10572 X-119.003 Z-50.593
    N10573 X-119.017 Z-10.557
    N10574 X-119.133 Z-9.454
    N10575 X-119.366 Z-8.342
    N10576 X-119.598 Z-7.568
    N10577 X-119.947 Z-6.674
    N10578 X-120.412 Z-5.739
    N10579 X-120.877 Z-4.981
    N10580 X-121.342 Z-4.335
    N10581 X-121.807 Z-3.769
    N10582 X-122.272 Z-3.278
    N10583 X-122.736 Z-2.837
    N10584 X-123.201 Z-2.444
    N10585 X-123.666 Z-2.094
    N10586 X-124.131 Z-1.776
    N10587 X-125.061 Z-1.24
    N10588 X-125.526 Z-1.015
    N10589 X-126.456 Z-.638
    N10590 X-127.386 Z-.354
    N10591 X-128.315 Z-.156
    N10592 X-129.245 Z-.039
    N10593 X-130.175 Z0.
    N10594 Y2.975
    N10595 X-129.245 Z-.039
    N10596 X-128.315 Z-.156
    N10597 X-127.386 Z-.354
    N10598 X-126.456 Z-.638
    N10599 X-125.526 Z-1.015
    N10600 X-125.061 Z-1.24
    N10601 X-124.131 Z-1.776
    N10602 X-123.666 Z-2.094
    N10603 X-123.201 Z-2.444
    N10604 X-122.736 Z-2.837
    N10605 X-122.272 Z-3.278
    N10606 X-121.807 Z-3.769
    N10607 X-121.342 Z-4.335
    N10608 X-120.877 Z-4.981
    N10609 X-120.412 Z-5.739
    N10610 X-119.947 Z-6.674
    N10611 X-119.598 Z-7.568
    N10612 X-119.366 Z-8.342
    N10613 X-119.133 Z-9.454
    N10614 X-119.017 Z-10.557
    N10615 X-119.003 Z-50.694
    N10616 X-3.719
    N10617 X0. Z-50.8
    N10618 X3.719 Z-50.694
    N10619 X119.003
    N10620 X119.01 Z-10.724
    N10621 X119.104 Z-9.653
    N10622 X119.308 Z-8.571
    N10623 X119.598 Z-7.568
    N10624 X119.947 Z-6.674
    N10625 X120.179 Z-6.185
    N10626 X120.644 Z-5.343
    N10627 X121.109 Z-4.641
    N10628 X121.807 Z-3.769
    N10629 X122.272 Z-3.278
    N10630 X122.736 Z-2.837
    N10631 X123.201 Z-2.444
    N10632 X123.666 Z-2.094
    N10633 X124.131 Z-1.776
    N10634 X125.061 Z-1.24
    N10635 X125.526 Z-1.015
    N10636 X126.456 Z-.638
    N10637 X127.386 Z-.354
    N10638 X128.315 Z-.156
    N10639 X129.245 Z-.039
    N10640 X130.175 Z0.
    N10641 Y1.775
    N10642 X129.245 Z-.039
    N10643 X128.315 Z-.156
    N10644 X127.386 Z-.354
    N10645 X126.456 Z-.638
    N10646 X125.526 Z-1.015
    N10647 X125.061 Z-1.24
    N10648 X124.131 Z-1.776
    N10649 X123.666 Z-2.094
    N10650 X123.201 Z-2.444
    N10651 X122.736 Z-2.837
    N10652 X122.272 Z-3.278
    N10653 X121.807 Z-3.769
    N10654 X121.109 Z-4.641
    N10655 X120.644 Z-5.343
    N10656 X120.179 Z-6.185
    N10657 X119.947 Z-6.674
    N10658 X119.598 Z-7.568
    N10659 X119.308 Z-8.571
    N10660 X119.104 Z-9.653
    N10661 X119.01 Z-10.724
    N10662 X119.003 Z-50.762
    N10663 X1.86 Z-50.763
    N10664 X0. Z-50.8
    N10665 X-1.86 Z-50.763
    N10666 X-119.003 Z-50.762
    N10667 X-119.017 Z-10.557
    N10668 X-119.133 Z-9.454
    N10669 X-119.366 Z-8.342
    N10670 X-119.598 Z-7.568
    N10671 X-119.947 Z-6.674
    N10672 X-120.412 Z-5.739
    N10673 X-120.877 Z-4.981
    N10674 X-121.342 Z-4.335
    N10675 X-121.807 Z-3.769
    N10676 X-122.272 Z-3.278
    N10677 X-122.736 Z-2.837
    N10678 X-123.201 Z-2.444
    N10679 X-123.666 Z-2.094
    N10680 X-124.131 Z-1.776
    N10681 X-125.061 Z-1.24
    N10682 X-125.526 Z-1.015
    N10683 X-126.456 Z-.638
    N10684 X-127.386 Z-.354
    N10685 X-128.315 Z-.156
    N10686 X-129.245 Z-.039
    N10687 X-130.175 Z0.
    N10688 Y.575
    N10689 X-129.245 Z-.039
    N10690 X-128.315 Z-.156
    N10691 X-127.386 Z-.354
    N10692 X-126.456 Z-.638
    N10693 X-125.526 Z-1.015
    N10694 X-125.061 Z-1.24
    N10695 X-124.131 Z-1.776
    N10696 X-123.666 Z-2.094
    N10697 X-123.201 Z-2.444
    N10698 X-122.736 Z-2.837
    N10699 X-122.272 Z-3.278
    N10700 X-121.807 Z-3.769
    N10701 X-121.342 Z-4.335
    N10702 X-120.877 Z-4.981
    N10703 X-120.412 Z-5.739
    N10704 X-119.947 Z-6.674
    N10705 X-119.598 Z-7.568
    N10706 X-119.366 Z-8.342
    N10707 X-119.133 Z-9.454
    N10708 X-119.017 Z-10.557
    N10709 X-119.003 Z-50.793
    N10710 X119.003
    N10711 X119.01 Z-10.724
    N10712 X119.104 Z-9.653
    N10713 X119.308 Z-8.571
    N10714 X119.598 Z-7.568
    N10715 X119.947 Z-6.674
    N10716 X120.179 Z-6.185
    N10717 X120.644 Z-5.343
    N10718 X121.109 Z-4.641
    N10719 X121.807 Z-3.769
    N10720 X122.272 Z-3.278
    N10721 X122.736 Z-2.837
    N10722 X123.201 Z-2.444
    N10723 X123.666 Z-2.094
    N10724 X124.131 Z-1.776
    N10725 X125.061 Z-1.24
    N10726 X125.526 Z-1.015
    N10727 X126.456 Z-.638
    N10728 X127.386 Z-.354
    N10729 X128.315 Z-.156
    N10730 X129.245 Z-.039
    N10731 X130.175 Z0.
    N10732 Y-.625
    N10733 X129.245 Z-.039
    N10734 X128.315 Z-.156
    N10735 X127.386 Z-.354
    N10736 X126.456 Z-.638
    N10737 X125.526 Z-1.015
    N10738 X125.061 Z-1.24
    N10739 X124.131 Z-1.776
    N10740 X123.666 Z-2.094
    N10741 X123.201 Z-2.444
    N10742 X122.736 Z-2.837
    N10743 X122.272 Z-3.278
    N10744 X121.807 Z-3.769
    N10745 X121.109 Z-4.641
    N10746 X120.644 Z-5.343
    N10747 X120.179 Z-6.185
    N10748 X119.947 Z-6.674
    N10749 X119.598 Z-7.568
    N10750 X119.308 Z-8.571
    N10751 X119.104 Z-9.653
    N10752 X119.01 Z-10.724
    N10753 X119.003 Z-50.793
    N10754 X-119.003
    N10755 X-119.017 Z-10.557
    N10756 X-119.133 Z-9.454
    N10757 X-119.366 Z-8.342
    N10758 X-119.598 Z-7.568
    N10759 X-119.947 Z-6.674
    N10760 X-120.412 Z-5.739
    N10761 X-120.877 Z-4.981
    N10762 X-121.342 Z-4.335
    N10763 X-121.807 Z-3.769
    N10764 X-122.272 Z-3.278
    N10765 X-122.736 Z-2.837
    N10766 X-123.201 Z-2.444
    N10767 X-123.666 Z-2.094
    N10768 X-124.131 Z-1.776
    N10769 X-125.061 Z-1.24
    N10770 X-125.526 Z-1.015
    N10771 X-126.456 Z-.638
    N10772 X-127.386 Z-.354
    N10773 X-128.315 Z-.156
    N10774 X-129.245 Z-.039
    N10775 X-130.175 Z0.
    N10776 Y-1.825
    N10777 X-129.245 Z-.039
    N10778 X-128.315 Z-.156
    N10779 X-127.386 Z-.354
    N10780 X-126.456 Z-.638
    N10781 X-125.526 Z-1.015
    N10782 X-125.061 Z-1.24
    N10783 X-124.131 Z-1.776
    N10784 X-123.666 Z-2.094
    N10785 X-123.201 Z-2.444
    N10786 X-122.736 Z-2.837
    N10787 X-122.272 Z-3.278
    N10788 X-121.807 Z-3.769
    N10789 X-121.342 Z-4.335
    N10790 X-120.877 Z-4.981
    N10791 X-120.412 Z-5.739
    N10792 X-119.947 Z-6.674
    N10793 X-119.598 Z-7.568
    N10794 X-119.366 Z-8.342
    N10795 X-119.133 Z-9.454
    N10796 X-119.017 Z-10.557
    N10797 X-119.003 Z-50.761
    N10798 X-1.86 Z-50.762
    N10799 X0. Z-50.8
    N10800 X1.86 Z-50.762
    N10801 X119.003 Z-50.761
    N10802 X119.01 Z-10.724
    N10803 X119.104 Z-9.653
    N10804 X119.308 Z-8.571
    N10805 X119.598 Z-7.568
    N10806 X119.947 Z-6.674
    N10807 X120.179 Z-6.185
    N10808 X120.644 Z-5.343
    N10809 X121.109 Z-4.641
    N10810 X121.807 Z-3.769
    N10811 X122.272 Z-3.278
    N10812 X122.736 Z-2.837
    N10813 X123.201 Z-2.444
    N10814 X123.666 Z-2.094
    N10815 X124.131 Z-1.776
    N10816 X125.061 Z-1.24
    N10817 X125.526 Z-1.015
    N10818 X126.456 Z-.638
    N10819 X127.386 Z-.354
    N10820 X128.315 Z-.156
    N10821 X129.245 Z-.039
    N10822 X130.175 Z0.
    N10823 Y-3.025
    N10824 X129.245 Z-.039
    N10825 X128.315 Z-.156
    N10826 X127.386 Z-.354
    N10827 X126.456 Z-.638
    N10828 X125.526 Z-1.015
    N10829 X125.061 Z-1.24
    N10830 X124.131 Z-1.776
    N10831 X123.666 Z-2.094
    N10832 X123.201 Z-2.444
    N10833 X122.736 Z-2.837
    N10834 X122.272 Z-3.278
    N10835 X121.807 Z-3.769
    N10836 X121.109 Z-4.641
    N10837 X120.644 Z-5.343
    N10838 X120.179 Z-6.185
    N10839 X119.947 Z-6.674
    N10840 X119.598 Z-7.568
    N10841 X119.308 Z-8.571
    N10842 X119.104 Z-9.653
    N10843 X119.01 Z-10.724
    N10844 X119.003 Z-50.69
    N10845 X3.719
    N10846 X2.789 Z-50.71
    N10847 X1.86 Z-50.759
    N10848 X0. Z-50.8
    N10849 X-1.86 Z-50.759
    N10850 X-2.789 Z-50.71
    N10851 X-3.719 Z-50.69
    N10852 X-119.003
    N10853 X-119.017 Z-10.557
    N10854 X-119.133 Z-9.454
    N10855 X-119.366 Z-8.342
    N10856 X-119.598 Z-7.568
    N10857 X-119.947 Z-6.674
    N10858 X-120.412 Z-5.739
    N10859 X-120.877 Z-4.981
    N10860 X-121.342 Z-4.335
    N10861 X-121.807 Z-3.769
    N10862 X-122.272 Z-3.278
    N10863 X-122.736 Z-2.837
    N10864 X-123.201 Z-2.444
    N10865 X-123.666 Z-2.094
    N10866 X-124.131 Z-1.776
    N10867 X-125.061 Z-1.24
    N10868 X-125.526 Z-1.015
    N10869 X-126.456 Z-.638
    N10870 X-127.386 Z-.354
    N10871 X-128.315 Z-.156
    N10872 X-129.245 Z-.039
    N10873 X-130.175 Z0.
    N10874 Y-4.225
    N10875 X-129.245 Z-.039
    N10876 X-128.315 Z-.156
    N10877 X-127.386 Z-.354
    N10878 X-126.456 Z-.638
    N10879 X-125.526 Z-1.015
    N10880 X-125.061 Z-1.24
    N10881 X-124.131 Z-1.776
    N10882 X-123.666 Z-2.094
    N10883 X-123.201 Z-2.444
    N10884 X-122.736 Z-2.837
    N10885 X-122.272 Z-3.278
    N10886 X-121.807 Z-3.769
    N10887 X-121.342 Z-4.335
    N10888 X-120.877 Z-4.981
    N10889 X-120.412 Z-5.739
    N10890 X-119.947 Z-6.674
    N10891 X-119.598 Z-7.568
    N10892 X-119.366 Z-8.342
    N10893 X-119.133 Z-9.454
    N10894 X-119.017 Z-10.557
    N10895 X-119.003 Z-50.588
    N10896 X-4.649 Z-50.592
    N10897 X-1.845 Z-50.76
    N10898 X0. Z-50.8
    N10899 X1.845 Z-50.76
    N10900 X4.649 Z-50.592
    N10901 X119.003 Z-50.588
    N10902 X119.01 Z-10.724
    N10903 X119.104 Z-9.653
    N10904 X119.308 Z-8.571
    N10905 X119.598 Z-7.568
    N10906 X119.947 Z-6.674
    N10907 X120.179 Z-6.185
    N10908 X120.644 Z-5.343
    N10909 X121.109 Z-4.641
    N10910 X121.807 Z-3.769
    N10911 X122.272 Z-3.278
    N10912 X122.736 Z-2.837
    N10913 X123.201 Z-2.444
    N10914 X123.666 Z-2.094
    N10915 X124.131 Z-1.776
    N10916 X125.061 Z-1.24
    N10917 X125.526 Z-1.015
    N10918 X126.456 Z-.638
    N10919 X127.386 Z-.354
    N10920 X128.315 Z-.156
    N10921 X129.245 Z-.039
    N10922 X130.175 Z0.
    N10923 Y-5.425
    N10924 X129.245 Z-.039
    N10925 X128.315 Z-.156
    N10926 X127.386 Z-.354
    N10927 X126.456 Z-.638
    N10928 X125.526 Z-1.015
    N10929 X125.061 Z-1.24
    N10930 X124.131 Z-1.776
    N10931 X123.666 Z-2.094
    N10932 X123.201 Z-2.444
    N10933 X122.736 Z-2.837
    N10934 X122.272 Z-3.278
    N10935 X121.807 Z-3.769
    N10936 X121.109 Z-4.641
    N10937 X120.644 Z-5.343
    N10938 X120.179 Z-6.185
    N10939 X119.947 Z-6.674
    N10940 X119.598 Z-7.568
    N10941 X119.308 Z-8.571
    N10942 X119.104 Z-9.653
    N10943 X119.01 Z-10.724
    N10944 X119.003 Z-50.453
    N10945 X7.439
    N10946 X5.579 Z-50.473
    N10947 X3.719 Z-50.637
    N10948 X1.862 Z-50.759
    N10949 X0. Z-50.8
    N10950 X-1.862 Z-50.759
    N10951 X-3.719 Z-50.637
    N10952 X-5.579 Z-50.473
    N10953 X-7.439 Z-50.453
    N10954 X-119.003
    N10955 X-119.017 Z-10.557
    N10956 X-119.133 Z-9.454
    N10957 X-119.366 Z-8.342
    N10958 X-119.598 Z-7.568
    N10959 X-119.947 Z-6.674
    N10960 X-120.412 Z-5.739
    N10961 X-120.877 Z-4.981
    N10962 X-121.342 Z-4.335
    N10963 X-121.807 Z-3.769
    N10964 X-122.272 Z-3.278
    N10965 X-122.736 Z-2.837
    N10966 X-123.201 Z-2.444
    N10967 X-123.666 Z-2.094
    N10968 X-124.131 Z-1.776
    N10969 X-125.061 Z-1.24
    N10970 X-125.526 Z-1.015
    N10971 X-126.456 Z-.638
    N10972 X-127.386 Z-.354
    N10973 X-128.315 Z-.156
    N10974 X-129.245 Z-.039
    N10975 X-130.175 Z0.
    N10976 Y-6.625
    N10977 X-129.245 Z-.039
    N10978 X-128.315 Z-.156
    N10979 X-127.386 Z-.354
    N10980 X-126.456 Z-.638
    N10981 X-125.526 Z-1.015
    N10982 X-125.061 Z-1.24
    N10983 X-124.131 Z-1.776
    N10984 X-123.666 Z-2.094
    N10985 X-123.201 Z-2.444
    N10986 X-122.736 Z-2.837
    N10987 X-122.272 Z-3.278
    N10988 X-121.807 Z-3.769
    N10989 X-121.342 Z-4.335
    N10990 X-120.877 Z-4.981
    N10991 X-120.412 Z-5.739
    N10992 X-119.947 Z-6.674
    N10993 X-119.598 Z-7.568
    N10994 X-119.366 Z-8.342
    N10995 X-119.133 Z-9.454
    N10996 X-119.017 Z-10.557
    N10997 X-119.003 Z-50.282
    N10998 X-7.439 Z-50.288
    N10999 X-6.509 Z-50.334
    N11000 X-3.719 Z-50.637
    N11001 X-1.862 Z-50.759
    N11002 X0. Z-50.8
    N11003 X1.862 Z-50.759
    N11004 X3.719 Z-50.637
    N11005 X6.509 Z-50.334
    N11006 X7.439 Z-50.288
    N11007 X119.003 Z-50.282
    N11008 X119.01 Z-10.724
    N11009 X119.104 Z-9.653
    N11010 X119.308 Z-8.571
    N11011 X119.598 Z-7.568
    N11012 X119.947 Z-6.674
    N11013 X120.179 Z-6.185
    N11014 X120.644 Z-5.343
    N11015 X121.109 Z-4.641
    N11016 X121.807 Z-3.769
    N11017 X122.272 Z-3.278
    N11018 X122.736 Z-2.837
    N11019 X123.201 Z-2.444
    N11020 X123.666 Z-2.094
    N11021 X124.131 Z-1.776
    N11022 X125.061 Z-1.24
    N11023 X125.526 Z-1.015
    N11024 X126.456 Z-.638
    N11025 X127.386 Z-.354
    N11026 X128.315 Z-.156
    N11027 X129.245 Z-.039
    N11028 X130.175 Z0.
    N11029 Y-7.825
    N11030 X129.245 Z-.039
    N11031 X128.315 Z-.156
    N11032 X127.386 Z-.354
    N11033 X126.456 Z-.638
    N11034 X125.526 Z-1.015
    N11035 X125.061 Z-1.24
    N11036 X124.131 Z-1.776
    N11037 X123.666 Z-2.094
    N11038 X123.201 Z-2.444
    N11039 X122.736 Z-2.837
    N11040 X122.272 Z-3.278
    N11041 X121.807 Z-3.769
    N11042 X121.109 Z-4.641
    N11043 X120.644 Z-5.343
    N11044 X120.179 Z-6.185
    N11045 X119.947 Z-6.674
    N11046 X119.598 Z-7.568
    N11047 X119.308 Z-8.571
    N11048 X119.104 Z-9.653
    N11049 X119.01 Z-10.724
    N11050 X119.003 Z-50.075
    N11051 X9.298
    N11052 X8.368 Z-50.102
    N11053 X7.439 Z-50.175
    N11054 X4.898 Z-50.516
    N11055 X3.719 Z-50.637
    N11056 X1.862 Z-50.759
    N11057 X0. Z-50.8
    N11058 X-1.862 Z-50.759
    N11059 X-3.719 Z-50.637
    N11060 X-4.898 Z-50.516
    N11061 X-7.439 Z-50.175
    N11062 X-8.368 Z-50.102
    N11063 X-9.298 Z-50.075
    N11064 X-119.003
    N11065 X-119.017 Z-10.557
    N11066 X-119.133 Z-9.454
    N11067 X-119.366 Z-8.342
    N11068 X-119.598 Z-7.568
    N11069 X-119.947 Z-6.674
    N11070 X-120.412 Z-5.739
    N11071 X-120.877 Z-4.981
    N11072 X-121.342 Z-4.335
    N11073 X-121.807 Z-3.769
    N11074 X-122.272 Z-3.278
    N11075 X-122.736 Z-2.837
    N11076 X-123.201 Z-2.444
    N11077 X-123.666 Z-2.094
    N11078 X-124.131 Z-1.776
    N11079 X-125.061 Z-1.24
    N11080 X-125.526 Z-1.015
    N11081 X-126.456 Z-.638
    N11082 X-127.386 Z-.354
    N11083 X-128.315 Z-.156
    N11084 X-129.245 Z-.039
    N11085 X-130.175 Z0.
    N11086 Y-9.025
    N11087 X-129.245 Z-.039
    N11088 X-128.315 Z-.156
    N11089 X-127.386 Z-.354
    N11090 X-126.456 Z-.638
    N11091 X-125.526 Z-1.015
    N11092 X-125.061 Z-1.24
    N11093 X-124.131 Z-1.776
    N11094 X-123.666 Z-2.094
    N11095 X-123.201 Z-2.444
    N11096 X-122.736 Z-2.837
    N11097 X-122.272 Z-3.278
    N11098 X-121.807 Z-3.769
    N11099 X-121.342 Z-4.335
    N11100 X-120.877 Z-4.981
    N11101 X-120.412 Z-5.739
    N11102 X-119.947 Z-6.674
    N11103 X-119.598 Z-7.568
    N11104 X-119.366 Z-8.342
    N11105 X-119.133 Z-9.454
    N11106 X-119.017 Z-10.557
    N11107 X-119.003 Z-49.834
    N11108 X-10.228 Z-49.841
    N11109 X-9.298 Z-49.896
    N11110 X-8.368 Z-49.995
    N11111 X-5.589 Z-50.433
    N11112 X-3.719 Z-50.637
    N11113 X-1.862 Z-50.759
    N11114 X0. Z-50.8
    N11115 X1.862 Z-50.759
    N11116 X3.719 Z-50.637
    N11117 X5.589 Z-50.433
    N11118 X8.368 Z-49.995
    N11119 X9.298 Z-49.896
    N11120 X10.228 Z-49.841
    N11121 X119.003 Z-49.834
    N11122 X119.01 Z-10.724
    N11123 X119.104 Z-9.653
    N11124 X119.308 Z-8.571
    N11125 X119.598 Z-7.568
    N11126 X119.947 Z-6.674
    N11127 X120.179 Z-6.185
    N11128 X120.644 Z-5.343
    N11129 X121.109 Z-4.641
    N11130 X121.807 Z-3.769
    N11131 X122.272 Z-3.278
    N11132 X122.736 Z-2.837
    N11133 X123.201 Z-2.444
    N11134 X123.666 Z-2.094
    N11135 X124.131 Z-1.776
    N11136 X125.061 Z-1.24
    N11137 X125.526 Z-1.015
    N11138 X126.456 Z-.638
    N11139 X127.386 Z-.354
    N11140 X128.315 Z-.156
    N11141 X129.245 Z-.039
    N11142 X130.175 Z0.
    N11143 Y-10.225
    N11144 X129.245 Z-.039
    N11145 X128.315 Z-.156
    N11146 X127.386 Z-.354
    N11147 X126.456 Z-.638
    N11148 X125.526 Z-1.015
    N11149 X125.061 Z-1.24
    N11150 X124.131 Z-1.776
    N11151 X123.666 Z-2.094
    N11152 X123.201 Z-2.444
    N11153 X122.736 Z-2.837
    N11154 X122.272 Z-3.278
    N11155 X121.807 Z-3.769
    N11156 X121.109 Z-4.641
    N11157 X120.644 Z-5.343
    N11158 X120.179 Z-6.185
    N11159 X119.947 Z-6.674
    N11160 X119.598 Z-7.568
    N11161 X119.308 Z-8.571
    N11162 X119.104 Z-9.653
    N11163 X119.01 Z-10.724
    N11164 X119.003 Z-49.559
    N11165 X12.088
    N11166 X11.158 Z-49.586
    N11167 X10.228 Z-49.668
    N11168 X9.298 Z-49.794
    N11169 X7.439 Z-50.148
    N11170 X5.579 Z-50.434
    N11171 X3.719 Z-50.637
    N11172 X1.862 Z-50.759
    N11173 X0. Z-50.8
    N11174 X-1.862 Z-50.759
    N11175 X-3.719 Z-50.637
    N11176 X-5.579 Z-50.434
    N11177 X-7.439 Z-50.148
    N11178 X-9.298 Z-49.794
    N11179 X-10.228 Z-49.668
    N11180 X-11.158 Z-49.586
    N11181 X-12.088 Z-49.559
    N11182 X-119.003
    N11183 X-119.017 Z-10.557
    N11184 X-119.133 Z-9.454
    N11185 X-119.366 Z-8.342
    N11186 X-119.598 Z-7.568
    N11187 X-119.947 Z-6.674
    N11188 X-120.412 Z-5.739
    N11189 X-120.877 Z-4.981
    N11190 X-121.342 Z-4.335
    N11191 X-121.807 Z-3.769
    N11192 X-122.272 Z-3.278
    N11193 X-122.736 Z-2.837
    N11194 X-123.201 Z-2.444
    N11195 X-123.666 Z-2.094
    N11196 X-124.131 Z-1.776
    N11197 X-125.061 Z-1.24
    N11198 X-125.526 Z-1.015
    N11199 X-126.456 Z-.638
    N11200 X-127.386 Z-.354
    N11201 X-128.315 Z-.156
    N11202 X-129.245 Z-.039
    N11203 X-130.175 Z0.
    N11204 Y-11.425
    N11205 X-129.245 Z-.039
    N11206 X-128.315 Z-.156
    N11207 X-127.386 Z-.354
    N11208 X-126.456 Z-.638
    N11209 X-125.526 Z-1.015
    N11210 X-125.061 Z-1.24
    N11211 X-124.131 Z-1.776
    N11212 X-123.666 Z-2.094
    N11213 X-123.201 Z-2.444
    N11214 X-122.736 Z-2.837
    N11215 X-122.272 Z-3.278
    N11216 X-121.807 Z-3.769
    N11217 X-121.342 Z-4.335
    N11218 X-120.877 Z-4.981
    N11219 X-120.412 Z-5.739
    N11220 X-119.947 Z-6.674
    N11221 X-119.598 Z-7.568
    N11222 X-119.366 Z-8.342
    N11223 X-119.133 Z-9.454
    N11224 X-119.017 Z-10.557
    N11225 X-119.003 Z-49.245
    N11226 X-13.017 Z-49.254
    N11227 X-12.088 Z-49.309
    N11228 X-11.158 Z-49.418
    N11229 X-9.933 Z-49.632
    N11230 X-8.708 Z-49.902
    N11231 X-7.478 Z-50.141
    N11232 X-6.259 Z-50.337
    N11233 X-5.082 Z-50.494
    N11234 X-3.719 Z-50.637
    N11235 X-1.862 Z-50.759
    N11236 X0. Z-50.8
    N11237 X1.862 Z-50.759
    N11238 X3.719 Z-50.637
    N11239 X5.082 Z-50.494
    N11240 X6.259 Z-50.337
    N11241 X7.478 Z-50.141
    N11242 X8.708 Z-49.902
    N11243 X9.933 Z-49.632
    N11244 X11.158 Z-49.418
    N11245 X12.088 Z-49.309
    N11246 X13.017 Z-49.254
    N11247 X119.003 Z-49.245
    N11248 X119.01 Z-10.724
    N11249 X119.104 Z-9.653
    N11250 X119.308 Z-8.571
    N11251 X119.598 Z-7.568
    N11252 X119.947 Z-6.674
    N11253 X120.179 Z-6.185
    N11254 X120.644 Z-5.343
    N11255 X121.109 Z-4.641
    N11256 X121.807 Z-3.769
    N11257 X122.272 Z-3.278
    N11258 X122.736 Z-2.837
    N11259 X123.201 Z-2.444
    N11260 X123.666 Z-2.094
    N11261 X124.131 Z-1.776
    N11262 X125.061 Z-1.24
    N11263 X125.526 Z-1.015
    N11264 X126.456 Z-.638
    N11265 X127.386 Z-.354
    N11266 X128.315 Z-.156
    N11267 X129.245 Z-.039
    N11268 X130.175 Z0.
    N11269 Y-12.625
    N11270 X129.245 Z-.039
    N11271 X128.315 Z-.156
    N11272 X127.386 Z-.354
    N11273 X126.456 Z-.638
    N11274 X125.526 Z-1.015
    N11275 X125.061 Z-1.24
    N11276 X124.131 Z-1.776
    N11277 X123.666 Z-2.094
    N11278 X123.201 Z-2.444
    N11279 X122.736 Z-2.837
    N11280 X122.272 Z-3.278
    N11281 X121.807 Z-3.769
    N11282 X121.109 Z-4.641
    N11283 X120.644 Z-5.343
    N11284 X120.179 Z-6.185
    N11285 X119.947 Z-6.674
    N11286 X119.598 Z-7.568
    N11287 X119.308 Z-8.571
    N11288 X119.104 Z-9.653
    N11289 X119.01 Z-10.724
    N11290 X119.003 Z-48.892
    N11291 X14.877 Z-48.893
    N11292 X13.947 Z-48.927
    N11293 X13.017 Z-49.009
    N11294 X12.088 Z-49.146
    N11295 X11.158 Z-49.328
    N11296 X9.074 Z-49.824
    N11297 X7.348 Z-50.163
    N11298 X5.506 Z-50.443
    N11299 X3.719 Z-50.637
    N11300 X1.862 Z-50.759
    N11301 X0. Z-50.8
    N11302 X-1.862 Z-50.759
    N11303 X-3.719 Z-50.637
    N11304 X-5.506 Z-50.443
    N11305 X-7.348 Z-50.163
    N11306 X-9.074 Z-49.824
    N11307 X-11.158 Z-49.328
    N11308 X-12.088 Z-49.146
    N11309 X-13.017 Z-49.009
    N11310 X-13.947 Z-48.927
    N11311 X-14.877 Z-48.893
    N11312 X-119.003 Z-48.892
    N11313 X-119.017 Z-10.557
    N11314 X-119.133 Z-9.454
    N11315 X-119.366 Z-8.342
    N11316 X-119.598 Z-7.568
    N11317 X-119.947 Z-6.674
    N11318 X-120.412 Z-5.739
    N11319 X-120.877 Z-4.981
    N11320 X-121.342 Z-4.335
    N11321 X-121.807 Z-3.769
    N11322 X-122.272 Z-3.278
    N11323 X-122.736 Z-2.837
    N11324 X-123.201 Z-2.444
    N11325 X-123.666 Z-2.094
    N11326 X-124.131 Z-1.776
    N11327 X-125.061 Z-1.24
    N11328 X-125.526 Z-1.015
    N11329 X-126.456 Z-.638
    N11330 X-127.386 Z-.354
    N11331 X-128.315 Z-.156
    N11332 X-129.245 Z-.039
    N11333 X-130.175 Z0.
    N11334 Y-13.825
    N11335 X-129.245 Z-.039
    N11336 X-128.315 Z-.156
    N11337 X-127.386 Z-.354
    N11338 X-126.456 Z-.638
    N11339 X-125.526 Z-1.015
    N11340 X-125.061 Z-1.24
    N11341 X-124.131 Z-1.776
    N11342 X-123.666 Z-2.094
    N11343 X-123.201 Z-2.444
    N11344 X-122.736 Z-2.837
    N11345 X-122.272 Z-3.278
    N11346 X-121.807 Z-3.769
    N11347 X-121.342 Z-4.335
    N11348 X-120.877 Z-4.981
    N11349 X-120.412 Z-5.739
    N11350 X-119.947 Z-6.674
    N11351 X-119.598 Z-7.568
    N11352 X-119.366 Z-8.342
    N11353 X-119.133 Z-9.454
    N11354 X-119.017 Z-10.557
    N11355 X-119.003 Z-48.502
    N11356 X-15.807 Z-48.514
    N11357 X-14.877 Z-48.577
    N11358 X-13.947 Z-48.687
    N11359 X-13.017 Z-48.852
    N11360 X-12.088 Z-49.063
    N11361 X-11.158 Z-49.318
    N11362 X-9.273 Z-49.782
    N11363 X-7.422 Z-50.151
    N11364 X-5.554 Z-50.437
    N11365 X-3.719 Z-50.637
    N11366 X-1.862 Z-50.759
    N11367 X0. Z-50.8
    N11368 X1.862 Z-50.759
    N11369 X3.719 Z-50.637
    N11370 X5.554 Z-50.437
    N11371 X7.422 Z-50.151
    N11372 X9.273 Z-49.782
    N11373 X11.158 Z-49.318
    N11374 X12.088 Z-49.063
    N11375 X13.017 Z-48.852
    N11376 X13.947 Z-48.687
    N11377 X14.877 Z-48.577
    N11378 X15.807 Z-48.514
    N11379 X119.003 Z-48.502
    N11380 X119.01 Z-10.724
    N11381 X119.104 Z-9.653
    N11382 X119.308 Z-8.571
    N11383 X119.598 Z-7.568
    N11384 X119.947 Z-6.674
    N11385 X120.179 Z-6.185
    N11386 X120.644 Z-5.343
    N11387 X121.109 Z-4.641
    N11388 X121.807 Z-3.769
    N11389 X122.272 Z-3.278
    N11390 X122.736 Z-2.837
    N11391 X123.201 Z-2.444
    N11392 X123.666 Z-2.094
    N11393 X124.131 Z-1.776
    N11394 X125.061 Z-1.24
    N11395 X125.526 Z-1.015
    N11396 X126.456 Z-.638
    N11397 X127.386 Z-.354
    N11398 X128.315 Z-.156
    N11399 X129.245 Z-.039
    N11400 X130.175 Z0.
    N11401 Y-15.025
    N11402 X129.245 Z-.039
    N11403 X128.315 Z-.156
    N11404 X127.386 Z-.354
    N11405 X126.456 Z-.638
    N11406 X125.526 Z-1.015
    N11407 X125.061 Z-1.24
    N11408 X124.131 Z-1.776
    N11409 X123.666 Z-2.094
    N11410 X123.201 Z-2.444
    N11411 X122.736 Z-2.837
    N11412 X122.272 Z-3.278
    N11413 X121.807 Z-3.769
    N11414 X121.109 Z-4.641
    N11415 X120.644 Z-5.343
    N11416 X120.179 Z-6.185
    N11417 X119.947 Z-6.674
    N11418 X119.598 Z-7.568
    N11419 X119.308 Z-8.571
    N11420 X119.104 Z-9.653
    N11421 X119.01 Z-10.724
    N11422 X119.003 Z-48.074
    N11423 X17.667 Z-48.075
    N11424 X16.737 Z-48.111
    N11425 X15.807 Z-48.204
    N11426 X14.877 Z-48.342
    N11427 X13.947 Z-48.535
    N11428 X13.017 Z-48.775
    N11429 X11.158 Z-49.318
    N11430 X9.273 Z-49.782
    N11431 X7.422 Z-50.151
    N11432 X5.554 Z-50.437
    N11433 X3.719 Z-50.637
    N11434 X1.862 Z-50.759
    N11435 X0. Z-50.8
    N11436 X-1.862 Z-50.759
    N11437 X-3.719 Z-50.637
    N11438 X-5.554 Z-50.437
    N11439 X-7.422 Z-50.151
    N11440 X-9.273 Z-49.782
    N11441 X-11.158 Z-49.318
    N11442 X-13.017 Z-48.775
    N11443 X-13.947 Z-48.535
    N11444 X-14.877 Z-48.342
    N11445 X-15.807 Z-48.204
    N11446 X-16.737 Z-48.111
    N11447 X-17.667 Z-48.075
    N11448 X-119.003 Z-48.074
    N11449 X-119.017 Z-10.557
    N11450 X-119.133 Z-9.454
    N11451 X-119.366 Z-8.342
    N11452 X-119.598 Z-7.568
    N11453 X-119.947 Z-6.674
    N11454 X-120.412 Z-5.739
    N11455 X-120.877 Z-4.981
    N11456 X-121.342 Z-4.335
    N11457 X-121.807 Z-3.769
    N11458 X-122.272 Z-3.278
    N11459 X-122.736 Z-2.837
    N11460 X-123.201 Z-2.444
    N11461 X-123.666 Z-2.094
    N11462 X-124.131 Z-1.776
    N11463 X-125.061 Z-1.24
    N11464 X-125.526 Z-1.015
    N11465 X-126.456 Z-.638
    N11466 X-127.386 Z-.354
    N11467 X-128.315 Z-.156
    N11468 X-129.245 Z-.039
    N11469 X-130.175 Z0.
    N11470 Y-16.225
    N11471 X-129.245 Z-.039
    N11472 X-128.315 Z-.156
    N11473 X-127.386 Z-.354
    N11474 X-126.456 Z-.638
    N11475 X-125.526 Z-1.015
    N11476 X-125.061 Z-1.24
    N11477 X-124.131 Z-1.776
    N11478 X-123.666 Z-2.094
    N11479 X-123.201 Z-2.444
    N11480 X-122.736 Z-2.837
    N11481 X-122.272 Z-3.278
    N11482 X-121.807 Z-3.769
    N11483 X-121.342 Z-4.335
    N11484 X-120.877 Z-4.981
    N11485 X-120.412 Z-5.739
    N11486 X-119.947 Z-6.674
    N11487 X-119.598 Z-7.568
    N11488 X-119.366 Z-8.342
    N11489 X-119.133 Z-9.454
    N11490 X-119.017 Z-10.557
    N11491 X-119.003 Z-47.603
    N11492 X-18.596 Z-47.618
    N11493 X-17.667 Z-47.683
    N11494 X-16.737 Z-47.806
    N11495 X-15.807 Z-47.972
    N11496 X-14.877 Z-48.194
    N11497 X-13.947 Z-48.464
    N11498 X-13.017 Z-48.77
    N11499 X-11.158 Z-49.318
    N11500 X-9.273 Z-49.782
    N11501 X-7.422 Z-50.151
    N11502 X-5.554 Z-50.437
    N11503 X-3.719 Z-50.637
    N11504 X-1.862 Z-50.759
    N11505 X0. Z-50.8
    N11506 X1.862 Z-50.759
    N11507 X3.719 Z-50.637
    N11508 X5.554 Z-50.437
    N11509 X7.422 Z-50.151
    N11510 X9.273 Z-49.782
    N11511 X11.158 Z-49.318
    N11512 X13.017 Z-48.77
    N11513 X13.947 Z-48.464
    N11514 X14.877 Z-48.194
    N11515 X15.807 Z-47.972
    N11516 X16.737 Z-47.806
    N11517 X17.667 Z-47.683
    N11518 X18.596 Z-47.618
    N11519 X26.035 Z-47.603
    N11520 X119.003
    N11521 X119.01 Z-10.724
    N11522 X119.104 Z-9.653
    N11523 X119.308 Z-8.571
    N11524 X119.598 Z-7.568
    N11525 X119.947 Z-6.674
    N11526 X120.179 Z-6.185
    N11527 X120.644 Z-5.343
    N11528 X121.109 Z-4.641
    N11529 X121.807 Z-3.769
    N11530 X122.272 Z-3.278
    N11531 X122.736 Z-2.837
    N11532 X123.201 Z-2.444
    N11533 X123.666 Z-2.094
    N11534 X124.131 Z-1.776
    N11535 X125.061 Z-1.24
    N11536 X125.526 Z-1.015
    N11537 X126.456 Z-.638
    N11538 X127.386 Z-.354
    N11539 X128.315 Z-.156
    N11540 X129.245 Z-.039
    N11541 X130.175 Z0.
    N11542 Y-17.425
    N11543 X129.245 Z-.039
    N11544 X128.315 Z-.156
    N11545 X127.386 Z-.354
    N11546 X126.456 Z-.638
    N11547 X125.526 Z-1.015
    N11548 X125.061 Z-1.24
    N11549 X124.131 Z-1.776
    N11550 X123.666 Z-2.094
    N11551 X123.201 Z-2.444
    N11552 X122.736 Z-2.837
    N11553 X122.272 Z-3.278
    N11554 X121.807 Z-3.769
    N11555 X121.109 Z-4.641
    N11556 X120.644 Z-5.343
    N11557 X120.179 Z-6.185
    N11558 X119.947 Z-6.674
    N11559 X119.598 Z-7.568
    N11560 X119.308 Z-8.571
    N11561 X119.104 Z-9.653
    N11562 X119.01 Z-10.724
    N11563 X119.003 Z-47.088
    N11564 X20.456 Z-47.09
    N11565 X19.526 Z-47.135
    N11566 X18.596 Z-47.23
    N11567 X17.667 Z-47.381
    N11568 X16.737 Z-47.578
    N11569 X15.807 Z-47.83
    N11570 X14.877 Z-48.129
    N11571 X13.016 Z-48.771
    N11572 X11.158 Z-49.318
    N11573 X9.273 Z-49.782
    N11574 X7.422 Z-50.151
    N11575 X5.554 Z-50.437
    N11576 X3.719 Z-50.637
    N11577 X1.862 Z-50.759
    N11578 X0. Z-50.8
    N11579 X-1.862 Z-50.759
    N11580 X-3.719 Z-50.637
    N11581 X-5.554 Z-50.437
    N11582 X-7.422 Z-50.151
    N11583 X-9.273 Z-49.782
    N11584 X-11.158 Z-49.318
    N11585 X-13.016 Z-48.771
    N11586 X-14.877 Z-48.129
    N11587 X-15.807 Z-47.83
    N11588 X-16.737 Z-47.578
    N11589 X-17.667 Z-47.381
    N11590 X-18.596 Z-47.23
    N11591 X-19.526 Z-47.135
    N11592 X-20.456 Z-47.09
    N11593 X-119.003 Z-47.088
    N11594 X-119.017 Z-10.557
    N11595 X-119.133 Z-9.454
    N11596 X-119.366 Z-8.342
    N11597 X-119.598 Z-7.568
    N11598 X-119.947 Z-6.674
    N11599 X-120.412 Z-5.739
    N11600 X-120.877 Z-4.981
    N11601 X-121.342 Z-4.335
    N11602 X-121.807 Z-3.769
    N11603 X-122.272 Z-3.278
    N11604 X-122.736 Z-2.837
    N11605 X-123.201 Z-2.444
    N11606 X-123.666 Z-2.094
    N11607 X-124.131 Z-1.776
    N11608 X-125.061 Z-1.24
    N11609 X-125.526 Z-1.015
    N11610 X-126.456 Z-.638
    N11611 X-127.386 Z-.354
    N11612 X-128.315 Z-.156
    N11613 X-129.245 Z-.039
    N11614 X-130.175 Z0.
    N11615 Y-18.625
    N11616 X-129.245 Z-.039
    N11617 X-128.315 Z-.156
    N11618 X-127.386 Z-.354
    N11619 X-126.456 Z-.638
    N11620 X-125.526 Z-1.015
    N11621 X-125.061 Z-1.24
    N11622 X-124.131 Z-1.776
    N11623 X-123.666 Z-2.094
    N11624 X-123.201 Z-2.444
    N11625 X-122.736 Z-2.837
    N11626 X-122.272 Z-3.278
    N11627 X-121.807 Z-3.769
    N11628 X-121.342 Z-4.335
    N11629 X-120.877 Z-4.981
    N11630 X-120.412 Z-5.739
    N11631 X-119.947 Z-6.674
    N11632 X-119.598 Z-7.568
    N11633 X-119.366 Z-8.342
    N11634 X-119.133 Z-9.454
    N11635 X-119.017 Z-10.557
    N11636 X-119.003 Z-46.532
    N11637 X-22.316
    N11638 X-21.386 Z-46.549
    N11639 X-20.456 Z-46.626
    N11640 X-19.526 Z-46.75
    N11641 X-18.596 Z-46.931
    N11642 X-17.667 Z-47.158
    N11643 X-16.737 Z-47.44
    N11644 X-14.877 Z-48.128
    N11645 X-13.01 Z-48.772
    N11646 X-11.158 Z-49.318
    N11647 X-9.273 Z-49.782
    N11648 X-7.422 Z-50.151
    N11649 X-5.554 Z-50.437
    N11650 X-3.719 Z-50.637
    N11651 X-1.862 Z-50.759
    N11652 X0. Z-50.8
    N11653 X1.862 Z-50.759
    N11654 X3.719 Z-50.637
    N11655 X5.554 Z-50.437
    N11656 X7.422 Z-50.151
    N11657 X9.273 Z-49.782
    N11658 X11.158 Z-49.318
    N11659 X13.01 Z-48.772
    N11660 X14.877 Z-48.128
    N11661 X16.737 Z-47.44
    N11662 X17.667 Z-47.158
    N11663 X18.596 Z-46.931
    N11664 X19.526 Z-46.75
    N11665 X20.456 Z-46.626
    N11666 X21.386 Z-46.549
    N11667 X22.316 Z-46.532
    N11668 X119.003
    N11669 X119.01 Z-10.724
    N11670 X119.104 Z-9.653
    N11671 X119.308 Z-8.571
    N11672 X119.598 Z-7.568
    N11673 X119.947 Z-6.674
    N11674 X120.179 Z-6.185
    N11675 X120.644 Z-5.343
    N11676 X121.109 Z-4.641
    N11677 X121.807 Z-3.769
    N11678 X122.272 Z-3.278
    N11679 X122.736 Z-2.837
    N11680 X123.201 Z-2.444
    N11681 X123.666 Z-2.094
    N11682 X124.131 Z-1.776
    N11683 X125.061 Z-1.24
    N11684 X125.526 Z-1.015
    N11685 X126.456 Z-.638
    N11686 X127.386 Z-.354
    N11687 X128.315 Z-.156
    N11688 X129.245 Z-.039
    N11689 X130.175 Z0.
    N11690 Y-19.825
    N11691 X129.245 Z-.039
    N11692 X128.315 Z-.156
    N11693 X127.386 Z-.354
    N11694 X126.456 Z-.638
    N11695 X125.526 Z-1.015
    N11696 X125.061 Z-1.24
    N11697 X124.131 Z-1.776
    N11698 X123.666 Z-2.094
    N11699 X123.201 Z-2.444
    N11700 X122.736 Z-2.837
    N11701 X122.272 Z-3.278
    N11702 X121.807 Z-3.769
    N11703 X121.109 Z-4.641
    N11704 X120.644 Z-5.343
    N11705 X120.179 Z-6.185
    N11706 X119.947 Z-6.674
    N11707 X119.598 Z-7.568
    N11708 X119.308 Z-8.571
    N11709 X119.104 Z-9.653
    N11710 X119.01 Z-10.724
    N11711 X119.003 Z-45.93
    N11712 X23.246 Z-45.933
    N11713 X22.316 Z-45.979
    N11714 X21.386 Z-46.087
    N11715 X20.456 Z-46.243
    N11716 X19.526 Z-46.454
    N11717 X18.596 Z-46.713
    N11718 X17.667 Z-47.025
    N11719 X14.877 Z-48.128
    N11720 X12.991 Z-48.778
    N11721 X11.158 Z-49.318
    N11722 X9.273 Z-49.782
    N11723 X7.422 Z-50.151
    N11724 X5.554 Z-50.437
    N11725 X3.719 Z-50.637
    N11726 X1.862 Z-50.759
    N11727 X0. Z-50.8
    N11728 X-1.862 Z-50.759
    N11729 X-3.719 Z-50.637
    N11730 X-5.554 Z-50.437
    N11731 X-7.422 Z-50.151
    N11732 X-9.273 Z-49.782
    N11733 X-11.158 Z-49.318
    N11734 X-12.991 Z-48.778
    N11735 X-14.877 Z-48.128
    N11736 X-17.667 Z-47.025
    N11737 X-18.596 Z-46.713
    N11738 X-19.526 Z-46.454
    N11739 X-20.456 Z-46.243
    N11740 X-21.386 Z-46.087
    N11741 X-22.316 Z-45.979
    N11742 X-23.246 Z-45.933
    N11743 X-119.003 Z-45.93
    N11744 X-119.017 Z-10.557
    N11745 X-119.133 Z-9.454
    N11746 X-119.366 Z-8.342
    N11747 X-119.598 Z-7.568
    N11748 X-119.947 Z-6.674
    N11749 X-120.412 Z-5.739
    N11750 X-120.877 Z-4.981
    N11751 X-121.342 Z-4.335
    N11752 X-121.807 Z-3.769
    N11753 X-122.272 Z-3.278
    N11754 X-122.736 Z-2.837
    N11755 X-123.201 Z-2.444
    N11756 X-123.666 Z-2.094
    N11757 X-124.131 Z-1.776
    N11758 X-125.061 Z-1.24
    N11759 X-125.526 Z-1.015
    N11760 X-126.456 Z-.638
    N11761 X-127.386 Z-.354
    N11762 X-128.315 Z-.156
    N11763 X-129.245 Z-.039
    N11764 X-130.175 Z0.
    N11765 Y-21.025
    N11766 X-129.245 Z-.039
    N11767 X-128.315 Z-.156
    N11768 X-127.386 Z-.354
    N11769 X-126.456 Z-.638
    N11770 X-125.526 Z-1.015
    N11771 X-125.061 Z-1.24
    N11772 X-124.131 Z-1.776
    N11773 X-123.666 Z-2.094
    N11774 X-123.201 Z-2.444
    N11775 X-122.736 Z-2.837
    N11776 X-122.272 Z-3.278
    N11777 X-121.807 Z-3.769
    N11778 X-121.342 Z-4.335
    N11779 X-120.877 Z-4.981
    N11780 X-120.412 Z-5.739
    N11781 X-119.947 Z-6.674
    N11782 X-119.598 Z-7.568
    N11783 X-119.366 Z-8.342
    N11784 X-119.133 Z-9.454
    N11785 X-119.017 Z-10.557
    N11786 X-119.003 Z-45.276
    N11787 X-25.105
    N11788 X-24.175 Z-45.302
    N11789 X-23.246 Z-45.379
    N11790 X-22.316 Z-45.519
    N11791 X-21.386 Z-45.707
    N11792 X-20.456 Z-45.948
    N11793 X-19.526 Z-46.24
    N11794 X-18.596 Z-46.583
    N11795 X-16.595 Z-47.448
    N11796 X-15.594 Z-47.854
    N11797 X-14.593 Z-48.231
    N11798 X-12.876 Z-48.814
    N11799 X-11.158 Z-49.318
    N11800 X-9.273 Z-49.782
    N11801 X-7.422 Z-50.151
    N11802 X-5.554 Z-50.437
    N11803 X-3.719 Z-50.637
    N11804 X-1.862 Z-50.759
    N11805 X0. Z-50.8
    N11806 X1.862 Z-50.759
    N11807 X3.719 Z-50.637
    N11808 X5.554 Z-50.437
    N11809 X7.422 Z-50.151
    N11810 X9.273 Z-49.782
    N11811 X11.158 Z-49.318
    N11812 X12.876 Z-48.814
    N11813 X14.593 Z-48.231
    N11814 X15.594 Z-47.854
    N11815 X16.595 Z-47.448
    N11816 X18.596 Z-46.583
    N11817 X19.526 Z-46.24
    N11818 X20.456 Z-45.948
    N11819 X21.386 Z-45.707
    N11820 X22.316 Z-45.519
    N11821 X23.246 Z-45.379
    N11822 X24.175 Z-45.302
    N11823 X25.105 Z-45.276
    N11824 X119.003
    N11825 X119.01 Z-10.724
    N11826 X119.104 Z-9.653
    N11827 X119.308 Z-8.571
    N11828 X119.598 Z-7.568
    N11829 X119.947 Z-6.674
    N11830 X120.179 Z-6.185
    N11831 X120.644 Z-5.343
    N11832 X121.109 Z-4.641
    N11833 X121.807 Z-3.769
    N11834 X122.272 Z-3.278
    N11835 X122.736 Z-2.837
    N11836 X123.201 Z-2.444
    N11837 X123.666 Z-2.094
    N11838 X124.131 Z-1.776
    N11839 X125.061 Z-1.24
    N11840 X125.526 Z-1.015
    N11841 X126.456 Z-.638
    N11842 X127.386 Z-.354
    N11843 X128.315 Z-.156
    N11844 X129.245 Z-.039
    N11845 X130.175 Z0.
    N11846 Y-22.225
    N11847 X129.245 Z-.039
    N11848 X128.315 Z-.156
    N11849 X127.386 Z-.354
    N11850 X126.456 Z-.638
    N11851 X125.526 Z-1.015
    N11852 X125.061 Z-1.24
    N11853 X124.131 Z-1.776
    N11854 X123.666 Z-2.094
    N11855 X123.201 Z-2.444
    N11856 X122.736 Z-2.837
    N11857 X122.272 Z-3.278
    N11858 X121.807 Z-3.769
    N11859 X121.109 Z-4.641
    N11860 X120.644 Z-5.343
    N11861 X120.179 Z-6.185
    N11862 X119.947 Z-6.674
    N11863 X119.598 Z-7.568
    N11864 X119.308 Z-8.571
    N11865 X119.104 Z-9.653
    N11866 X119.01 Z-10.724
    N11867 X119.003 Z-44.573
    N11868 X26.035 Z-44.577
    N11869 X25.105 Z-44.636
    N11870 X24.175 Z-44.748
    N11871 X23.246 Z-44.919
    N11872 X22.316 Z-45.141
    N11873 X21.386 Z-45.414
    N11874 X20.456 Z-45.738
    N11875 X19.526 Z-46.114
    N11876 X17.658 Z-46.984
    N11877 X15.783 Z-47.781
    N11878 X14.845 Z-48.14
    N11879 X13.001 Z-48.775
    N11880 X11.158 Z-49.318
    N11881 X9.273 Z-49.782
    N11882 X7.422 Z-50.151
    N11883 X5.554 Z-50.437
    N11884 X3.719 Z-50.637
    N11885 X1.862 Z-50.759
    N11886 X0. Z-50.8
    N11887 X-1.862 Z-50.759
    N11888 X-3.719 Z-50.637
    N11889 X-5.554 Z-50.437
    N11890 X-7.422 Z-50.151
    N11891 X-9.273 Z-49.782
    N11892 X-11.158 Z-49.318
    N11893 X-13.001 Z-48.775
    N11894 X-14.845 Z-48.14
    N11895 X-16.721 Z-47.395
    N11896 X-19.526 Z-46.114
    N11897 X-20.456 Z-45.738
    N11898 X-21.386 Z-45.414
    N11899 X-22.316 Z-45.141
    N11900 X-23.246 Z-44.919
    N11901 X-24.175 Z-44.748
    N11902 X-25.105 Z-44.636
    N11903 X-26.035 Z-44.577
    N11904 X-119.003 Z-44.573
    N11905 X-119.017 Z-10.557
    N11906 X-119.133 Z-9.454
    N11907 X-119.366 Z-8.342
    N11908 X-119.598 Z-7.568
    N11909 X-119.947 Z-6.674
    N11910 X-120.412 Z-5.739
    N11911 X-120.877 Z-4.981
    N11912 X-121.342 Z-4.335
    N11913 X-121.807 Z-3.769
    N11914 X-122.272 Z-3.278
    N11915 X-122.736 Z-2.837
    N11916 X-123.201 Z-2.444
    N11917 X-123.666 Z-2.094
    N11918 X-124.131 Z-1.776
    N11919 X-125.061 Z-1.24
    N11920 X-125.526 Z-1.015
    N11921 X-126.456 Z-.638
    N11922 X-127.386 Z-.354
    N11923 X-128.315 Z-.156
    N11924 X-129.245 Z-.039
    N11925 X-130.175 Z0.
    N11926 Y-23.425
    N11927 X-129.245 Z-.039
    N11928 X-128.315 Z-.156
    N11929 X-127.386 Z-.354
    N11930 X-126.456 Z-.638
    N11931 X-125.526 Z-1.015
    N11932 X-125.061 Z-1.24
    N11933 X-124.131 Z-1.776
    N11934 X-123.666 Z-2.094
    N11935 X-123.201 Z-2.444
    N11936 X-122.736 Z-2.837
    N11937 X-122.272 Z-3.278
    N11938 X-121.807 Z-3.769
    N11939 X-121.342 Z-4.335
    N11940 X-120.877 Z-4.981
    N11941 X-120.412 Z-5.739
    N11942 X-119.947 Z-6.674
    N11943 X-119.598 Z-7.568
    N11944 X-119.366 Z-8.342
    N11945 X-119.133 Z-9.454
    N11946 X-119.017 Z-10.557
    N11947 X-119.003 Z-43.819
    N11948 X-27.895
    N11949 X-26.965 Z-43.844
    N11950 X-26.035 Z-43.936
    N11951 X-25.105 Z-44.085
    N11952 X-24.175 Z-44.287
    N11953 X-23.246 Z-44.544
    N11954 X-22.316 Z-44.849
    N11955 X-21.386 Z-45.208
    N11956 X-20.456 Z-45.617
    N11957 X-18.596 Z-46.545
    N11958 X-16.721 Z-47.395
    N11959 X-14.845 Z-48.14
    N11960 X-13.001 Z-48.775
    N11961 X-11.158 Z-49.318
    N11962 X-9.273 Z-49.782
    N11963 X-7.422 Z-50.151
    N11964 X-5.554 Z-50.437
    N11965 X-3.719 Z-50.637
    N11966 X-1.862 Z-50.759
    N11967 X0. Z-50.8
    N11968 X1.862 Z-50.759
    N11969 X3.719 Z-50.637
    N11970 X5.554 Z-50.437
    N11971 X7.422 Z-50.151
    N11972 X9.273 Z-49.782
    N11973 X11.158 Z-49.318
    N11974 X13.001 Z-48.775
    N11975 X14.845 Z-48.14
    N11976 X16.721 Z-47.395
    N11977 X18.596 Z-46.545
    N11978 X20.456 Z-45.617
    N11979 X21.386 Z-45.208
    N11980 X22.316 Z-44.849
    N11981 X23.246 Z-44.544
    N11982 X24.175 Z-44.287
    N11983 X25.105 Z-44.085
    N11984 X26.035 Z-43.936
    N11985 X26.965 Z-43.844
    N11986 X27.895 Z-43.819
    N11987 X119.003
    N11988 X119.01 Z-10.724
    N11989 X119.104 Z-9.653
    N11990 X119.308 Z-8.571
    N11991 X119.598 Z-7.568
    N11992 X119.947 Z-6.674
    N11993 X120.179 Z-6.185
    N11994 X120.644 Z-5.343
    N11995 X121.109 Z-4.641
    N11996 X121.807 Z-3.769
    N11997 X122.272 Z-3.278
    N11998 X122.736 Z-2.837
    N11999 X123.201 Z-2.444
    N12000 X123.666 Z-2.094
    N12001 X124.131 Z-1.776
    N12002 X125.061 Z-1.24
    N12003 X125.526 Z-1.015
    N12004 X126.456 Z-.638
    N12005 X127.386 Z-.354
    N12006 X128.315 Z-.156
    N12007 X129.245 Z-.039
    N12008 X130.175 Z0.
    N12009 Y-24.625
    N12010 X129.245 Z-.039
    N12011 X128.315 Z-.156
    N12012 X127.386 Z-.354
    N12013 X126.456 Z-.638
    N12014 X125.526 Z-1.015
    N12015 X125.061 Z-1.24
    N12016 X124.131 Z-1.776
    N12017 X123.666 Z-2.094
    N12018 X123.201 Z-2.444
    N12019 X122.736 Z-2.837
    N12020 X122.272 Z-3.278
    N12021 X121.807 Z-3.769
    N12022 X121.109 Z-4.641
    N12023 X120.644 Z-5.343
    N12024 X120.179 Z-6.185
    N12025 X119.947 Z-6.674
    N12026 X119.598 Z-7.568
    N12027 X119.308 Z-8.571
    N12028 X119.104 Z-9.653
    N12029 X119.01 Z-10.724
    N12030 X119.003 Z-43.002
    N12031 X28.824 Z-43.01
    N12032 X27.895 Z-43.075
    N12033 X26.965 Z-43.2
    N12034 X26.035 Z-43.386
    N12035 X25.105 Z-43.621
    N12036 X24.175 Z-43.914
    N12037 X23.246 Z-44.252
    N12038 X22.316 Z-44.647
    N12039 X18.596 Z-46.545
    N12040 X16.721 Z-47.395
    N12041 X14.845 Z-48.14
    N12042 X13.001 Z-48.775
    N12043 X11.158 Z-49.318
    N12044 X9.273 Z-49.782
    N12045 X7.422 Z-50.151
    N12046 X5.554 Z-50.437
    N12047 X3.719 Z-50.637
    N12048 X1.862 Z-50.759
    N12049 X0. Z-50.8
    N12050 X-1.862 Z-50.759
    N12051 X-3.719 Z-50.637
    N12052 X-5.554 Z-50.437
    N12053 X-7.422 Z-50.151
    N12054 X-9.273 Z-49.782
    N12055 X-11.158 Z-49.318
    N12056 X-13.001 Z-48.775
    N12057 X-14.845 Z-48.14
    N12058 X-16.721 Z-47.395
    N12059 X-18.596 Z-46.545
    N12060 X-22.316 Z-44.647
    N12061 X-23.246 Z-44.252
    N12062 X-24.175 Z-43.914
    N12063 X-25.105 Z-43.621
    N12064 X-26.035 Z-43.386
    N12065 X-26.965 Z-43.2
    N12066 X-27.895 Z-43.075
    N12067 X-28.824 Z-43.01
    N12068 X-119.003 Z-43.002
    N12069 X-119.017 Z-10.557
    N12070 X-119.133 Z-9.454
    N12071 X-119.366 Z-8.342
    N12072 X-119.598 Z-7.568
    N12073 X-119.947 Z-6.674
    N12074 X-120.412 Z-5.739
    N12075 X-120.877 Z-4.981
    N12076 X-121.342 Z-4.335
    N12077 X-121.807 Z-3.769
    N12078 X-122.272 Z-3.278
    N12079 X-122.736 Z-2.837
    N12080 X-123.201 Z-2.444
    N12081 X-123.666 Z-2.094
    N12082 X-124.131 Z-1.776
    N12083 X-125.061 Z-1.24
    N12084 X-125.526 Z-1.015
    N12085 X-126.456 Z-.638
    N12086 X-127.386 Z-.354
    N12087 X-128.315 Z-.156
    N12088 X-129.245 Z-.039
    N12089 X-130.175 Z0.
    N12090 Y-25.825
    N12091 X-129.245 Z-.039
    N12092 X-128.315 Z-.156
    N12093 X-127.386 Z-.354
    N12094 X-126.456 Z-.638
    N12095 X-125.526 Z-1.015
    N12096 X-125.061 Z-1.24
    N12097 X-124.131 Z-1.776
    N12098 X-123.666 Z-2.094
    N12099 X-123.201 Z-2.444
    N12100 X-122.736 Z-2.837
    N12101 X-122.272 Z-3.278
    N12102 X-121.807 Z-3.769
    N12103 X-121.342 Z-4.335
    N12104 X-120.877 Z-4.981
    N12105 X-120.412 Z-5.739
    N12106 X-119.947 Z-6.674
    N12107 X-119.598 Z-7.568
    N12108 X-119.366 Z-8.342
    N12109 X-119.133 Z-9.454
    N12110 X-119.017 Z-10.557
    N12111 X-119.003 Z-42.128
    N12112 X-30.684
    N12113 X-29.754 Z-42.16
    N12114 X-28.824 Z-42.267
    N12115 X-27.895 Z-42.426
    N12116 X-26.965 Z-42.649
    N12117 X-26.035 Z-42.919
    N12118 X-25.105 Z-43.248
    N12119 X-24.175 Z-43.621
    N12120 X-23.246 Z-44.054
    N12121 X-22.316 Z-44.534
    N12122 X-20.297 Z-45.677
    N12123 X-18.596 Z-46.545
    N12124 X-16.721 Z-47.395
    N12125 X-14.845 Z-48.14
    N12126 X-13.001 Z-48.775
    N12127 X-11.158 Z-49.318
    N12128 X-9.273 Z-49.782
    N12129 X-7.422 Z-50.151
    N12130 X-5.554 Z-50.437
    N12131 X-3.719 Z-50.637
    N12132 X-1.862 Z-50.759
    N12133 X0. Z-50.8
    N12134 X1.862 Z-50.759
    N12135 X3.719 Z-50.637
    N12136 X5.554 Z-50.437
    N12137 X7.422 Z-50.151
    N12138 X9.273 Z-49.782
    N12139 X11.158 Z-49.318
    N12140 X13.001 Z-48.775
    N12141 X14.845 Z-48.14
    N12142 X16.721 Z-47.395
    N12143 X18.596 Z-46.545
    N12144 X20.297 Z-45.677
    N12145 X22.316 Z-44.534
    N12146 X23.246 Z-44.054
    N12147 X24.175 Z-43.621
    N12148 X25.105 Z-43.248
    N12149 X26.035 Z-42.919
    N12150 X26.965 Z-42.649
    N12151 X27.895 Z-42.426
    N12152 X28.824 Z-42.267
    N12153 X29.754 Z-42.16
    N12154 X30.684 Z-42.128
    N12155 X119.003
    N12156 X119.01 Z-10.724
    N12157 X119.104 Z-9.653
    N12158 X119.308 Z-8.571
    N12159 X119.598 Z-7.568
    N12160 X119.947 Z-6.674
    N12161 X120.179 Z-6.185
    N12162 X120.644 Z-5.343
    N12163 X121.109 Z-4.641
    N12164 X121.807 Z-3.769
    N12165 X122.272 Z-3.278
    N12166 X122.736 Z-2.837
    N12167 X123.201 Z-2.444
    N12168 X123.666 Z-2.094
    N12169 X124.131 Z-1.776
    N12170 X125.061 Z-1.24
    N12171 X125.526 Z-1.015
    N12172 X126.456 Z-.638
    N12173 X127.386 Z-.354
    N12174 X128.315 Z-.156
    N12175 X129.245 Z-.039
    N12176 X130.175 Z0.
    N12177 Y-27.025
    N12178 X129.245 Z-.039
    N12179 X128.315 Z-.156
    N12180 X127.386 Z-.354
    N12181 X126.456 Z-.638
    N12182 X125.526 Z-1.015
    N12183 X125.061 Z-1.24
    N12184 X124.131 Z-1.776
    N12185 X123.666 Z-2.094
    N12186 X123.201 Z-2.444
    N12187 X122.736 Z-2.837
    N12188 X122.272 Z-3.278
    N12189 X121.807 Z-3.769
    N12190 X121.109 Z-4.641
    N12191 X120.644 Z-5.343
    N12192 X120.179 Z-6.185
    N12193 X119.947 Z-6.674
    N12194 X119.598 Z-7.568
    N12195 X119.308 Z-8.571
    N12196 X119.104 Z-9.653
    N12197 X119.01 Z-10.724
    N12198 X119.003 Z-41.185
    N12199 X31.614 Z-41.197
    N12200 X30.684 Z-41.269
    N12201 X29.754 Z-41.412
    N12202 X28.824 Z-41.612
    N12203 X27.895 Z-41.87
    N12204 X26.965 Z-42.18
    N12205 X26.035 Z-42.543
    N12206 X25.105 Z-42.956
    N12207 X24.175 Z-43.425
    N12208 X23.246 Z-43.945
    N12209 X21.356 Z-45.088
    N12210 X20.449 Z-45.596
    N12211 X18.596 Z-46.545
    N12212 X16.721 Z-47.395
    N12213 X14.845 Z-48.14
    N12214 X13.001 Z-48.775
    N12215 X11.158 Z-49.318
    N12216 X9.273 Z-49.782
    N12217 X7.422 Z-50.151
    N12218 X5.554 Z-50.437
    N12219 X3.719 Z-50.637
    N12220 X1.862 Z-50.759
    N12221 X0. Z-50.8
    N12222 X-1.862 Z-50.759
    N12223 X-3.719 Z-50.637
    N12224 X-5.554 Z-50.437
    N12225 X-7.422 Z-50.151
    N12226 X-9.273 Z-49.782
    N12227 X-11.158 Z-49.318
    N12228 X-13.001 Z-48.775
    N12229 X-14.845 Z-48.14
    N12230 X-16.721 Z-47.395
    N12231 X-18.596 Z-46.545
    N12232 X-20.449 Z-45.596
    N12233 X-21.356 Z-45.088
    N12234 X-23.246 Z-43.945
    N12235 X-24.175 Z-43.425
    N12236 X-25.105 Z-42.956
    N12237 X-26.035 Z-42.543
    N12238 X-26.965 Z-42.18
    N12239 X-27.895 Z-41.87
    N12240 X-28.824 Z-41.612
    N12241 X-29.754 Z-41.412
    N12242 X-30.684 Z-41.269
    N12243 X-31.614 Z-41.197
    N12244 X-119.003 Z-41.185
    N12245 X-119.017 Z-10.557
    N12246 X-119.133 Z-9.454
    N12247 X-119.366 Z-8.342
    N12248 X-119.598 Z-7.568
    N12249 X-119.947 Z-6.674
    N12250 X-120.412 Z-5.739
    N12251 X-120.877 Z-4.981
    N12252 X-121.342 Z-4.335
    N12253 X-121.807 Z-3.769
    N12254 X-122.272 Z-3.278
    N12255 X-122.736 Z-2.837
    N12256 X-123.201 Z-2.444
    N12257 X-123.666 Z-2.094
    N12258 X-124.131 Z-1.776
    N12259 X-125.061 Z-1.24
    N12260 X-125.526 Z-1.015
    N12261 X-126.456 Z-.638
    N12262 X-127.386 Z-.354
    N12263 X-128.315 Z-.156
    N12264 X-129.245 Z-.039
    N12265 X-130.175 Z0.
    N12266 Y-28.225
    N12267 X-129.245 Z-.039
    N12268 X-128.315 Z-.156
    N12269 X-127.386 Z-.354
    N12270 X-126.456 Z-.638
    N12271 X-125.526 Z-1.015
    N12272 X-125.061 Z-1.24
    N12273 X-124.131 Z-1.776
    N12274 X-123.666 Z-2.094
    N12275 X-123.201 Z-2.444
    N12276 X-122.736 Z-2.837
    N12277 X-122.272 Z-3.278
    N12278 X-121.807 Z-3.769
    N12279 X-121.342 Z-4.335
    N12280 X-120.877 Z-4.981
    N12281 X-120.412 Z-5.739
    N12282 X-119.947 Z-6.674
    N12283 X-119.598 Z-7.568
    N12284 X-119.366 Z-8.342
    N12285 X-119.133 Z-9.454
    N12286 X-119.017 Z-10.557
    N12287 X-119.003 Z-40.17
    N12288 X-33.474
    N12289 X-32.544 Z-40.213
    N12290 X-31.614 Z-40.332
    N12291 X-30.684 Z-40.511
    N12292 X-29.754 Z-40.755
    N12293 X-28.824 Z-41.049
    N12294 X-27.895 Z-41.4
    N12295 X-26.965 Z-41.799
    N12296 X-26.035 Z-42.254
    N12297 X-25.105 Z-42.76
    N12298 X-24.175 Z-43.323
    N12299 X-22.316 Z-44.519
    N12300 X-21.386 Z-45.071
    N12301 X-20.456 Z-45.592
    N12302 X-19.526 Z-46.083
    N12303 X-18.596 Z-46.545
    N12304 X-16.721 Z-47.395
    N12305 X-14.845 Z-48.14
    N12306 X-13.001 Z-48.775
    N12307 X-11.158 Z-49.318
    N12308 X-9.273 Z-49.782
    N12309 X-7.422 Z-50.151
    N12310 X-5.554 Z-50.437
    N12311 X-3.719 Z-50.637
    N12312 X-1.862 Z-50.759
    N12313 X0. Z-50.8
    N12314 X1.862 Z-50.759
    N12315 X3.719 Z-50.637
    N12316 X5.554 Z-50.437
    N12317 X7.422 Z-50.151
    N12318 X9.273 Z-49.782
    N12319 X11.158 Z-49.318
    N12320 X13.001 Z-48.775
    N12321 X14.845 Z-48.14
    N12322 X15.783 Z-47.781
    N12323 X17.658 Z-46.984
    N12324 X19.526 Z-46.083
    N12325 X20.456 Z-45.592
    N12326 X21.386 Z-45.071
    N12327 X22.316 Z-44.519
    N12328 X24.175 Z-43.323
    N12329 X25.105 Z-42.76
    N12330 X26.035 Z-42.254
    N12331 X26.965 Z-41.799
    N12332 X27.895 Z-41.4
    N12333 X28.824 Z-41.049
    N12334 X29.754 Z-40.755
    N12335 X30.684 Z-40.511
    N12336 X31.614 Z-40.332
    N12337 X32.544 Z-40.213
    N12338 X33.474 Z-40.17
    N12339 X119.003
    N12340 X119.01 Z-10.724
    N12341 X119.104 Z-9.653
    N12342 X119.308 Z-8.571
    N12343 X119.598 Z-7.568
    N12344 X119.947 Z-6.674
    N12345 X120.179 Z-6.185
    N12346 X120.644 Z-5.343
    N12347 X121.109 Z-4.641
    N12348 X121.807 Z-3.769
    N12349 X122.272 Z-3.278
    N12350 X122.736 Z-2.837
    N12351 X123.201 Z-2.444
    N12352 X123.666 Z-2.094
    N12353 X124.131 Z-1.776
    N12354 X125.061 Z-1.24
    N12355 X125.526 Z-1.015
    N12356 X126.456 Z-.638
    N12357 X127.386 Z-.354
    N12358 X128.315 Z-.156
    N12359 X129.245 Z-.039
    N12360 X130.175 Z0.
    N12361 Y-29.425
    N12362 X129.245 Z-.039
    N12363 X128.315 Z-.156
    N12364 X127.386 Z-.354
    N12365 X126.456 Z-.638
    N12366 X125.526 Z-1.015
    N12367 X125.061 Z-1.24
    N12368 X124.131 Z-1.776
    N12369 X123.666 Z-2.094
    N12370 X123.201 Z-2.444
    N12371 X122.736 Z-2.837
    N12372 X122.272 Z-3.278
    N12373 X121.807 Z-3.769
    N12374 X121.109 Z-4.641
    N12375 X120.644 Z-5.343
    N12376 X120.179 Z-6.185
    N12377 X119.947 Z-6.674
    N12378 X119.598 Z-7.568
    N12379 X119.308 Z-8.571
    N12380 X119.104 Z-9.653
    N12381 X119.01 Z-10.724
    N12382 X119.003 Z-39.076
    N12383 X35.333
    N12384 X34.403 Z-39.093
    N12385 X33.474 Z-39.178
    N12386 X32.544 Z-39.34
    N12387 X31.614 Z-39.563
    N12388 X30.684 Z-39.847
    N12389 X29.754 Z-40.182
    N12390 X28.824 Z-40.575
    N12391 X27.895 Z-41.014
    N12392 X26.965 Z-41.512
    N12393 X26.035 Z-42.057
    N12394 X24.976 Z-42.755
    N12395 X23.917 Z-43.489
    N12396 X22.858 Z-44.18
    N12397 X21.799 Z-44.829
    N12398 X20.198 Z-45.73
    N12399 X18.596 Z-46.545
    N12400 X16.721 Z-47.395
    N12401 X14.845 Z-48.14
    N12402 X13.001 Z-48.775
    N12403 X11.158 Z-49.318
    N12404 X9.273 Z-49.782
    N12405 X7.422 Z-50.151
    N12406 X5.554 Z-50.437
    N12407 X3.719 Z-50.637
    N12408 X1.862 Z-50.759
    N12409 X0. Z-50.8
    N12410 X-1.862 Z-50.759
    N12411 X-3.719 Z-50.637
    N12412 X-5.554 Z-50.437
    N12413 X-7.422 Z-50.151
    N12414 X-9.273 Z-49.782
    N12415 X-11.158 Z-49.318
    N12416 X-13.001 Z-48.775
    N12417 X-14.845 Z-48.14
    N12418 X-16.721 Z-47.395
    N12419 X-18.596 Z-46.545
    N12420 X-20.198 Z-45.73
    N12421 X-21.799 Z-44.829
    N12422 X-22.858 Z-44.18
    N12423 X-23.917 Z-43.489
    N12424 X-24.976 Z-42.755
    N12425 X-26.035 Z-42.057
    N12426 X-26.965 Z-41.512
    N12427 X-27.895 Z-41.014
    N12428 X-28.824 Z-40.575
    N12429 X-29.754 Z-40.182
    N12430 X-30.684 Z-39.847
    N12431 X-31.614 Z-39.563
    N12432 X-32.544 Z-39.34
    N12433 X-33.474 Z-39.178
    N12434 X-34.403 Z-39.093
    N12435 X-119.003 Z-39.076
    N12436 X-119.017 Z-10.557
    N12437 X-119.133 Z-9.454
    N12438 X-119.366 Z-8.342
    N12439 X-119.598 Z-7.568
    N12440 X-119.947 Z-6.674
    N12441 X-120.412 Z-5.739
    N12442 X-120.877 Z-4.981
    N12443 X-121.342 Z-4.335
    N12444 X-121.807 Z-3.769
    N12445 X-122.272 Z-3.278
    N12446 X-122.736 Z-2.837
    N12447 X-123.201 Z-2.444
    N12448 X-123.666 Z-2.094
    N12449 X-124.131 Z-1.776
    N12450 X-125.061 Z-1.24
    N12451 X-125.526 Z-1.015
    N12452 X-126.456 Z-.638
    N12453 X-127.386 Z-.354
    N12454 X-128.315 Z-.156
    N12455 X-129.245 Z-.039
    N12456 X-130.175 Z0.
    N12457 Y-30.625
    N12458 X-129.245 Z-.039
    N12459 X-128.315 Z-.156
    N12460 X-127.386 Z-.354
    N12461 X-126.456 Z-.638
    N12462 X-125.526 Z-1.015
    N12463 X-125.061 Z-1.24
    N12464 X-124.131 Z-1.776
    N12465 X-123.666 Z-2.094
    N12466 X-123.201 Z-2.444
    N12467 X-122.736 Z-2.837
    N12468 X-122.272 Z-3.278
    N12469 X-121.807 Z-3.769
    N12470 X-121.342 Z-4.335
    N12471 X-120.877 Z-4.981
    N12472 X-120.412 Z-5.739
    N12473 X-119.947 Z-6.674
    N12474 X-119.598 Z-7.568
    N12475 X-119.366 Z-8.342
    N12476 X-119.133 Z-9.454
    N12477 X-119.017 Z-10.557
    N12478 X-119.003 Z-37.896
    N12479 X-36.965
    N12480 X-35.634 Z-37.921
    N12481 X-35.094 Z-37.977
    N12482 X-34.554 Z-38.061
    N12483 X-33.474 Z-38.289
    N12484 X-32.544 Z-38.562
    N12485 X-31.614 Z-38.885
    N12486 X-30.684 Z-39.268
    N12487 X-29.754 Z-39.699
    N12488 X-28.824 Z-40.185
    N12489 X-27.895 Z-40.724
    N12490 X-26.965 Z-41.316
    N12491 X-26.035 Z-41.973
    N12492 X-25.088 Z-42.675
    N12493 X-24.141 Z-43.34
    N12494 X-23.193 Z-43.968
    N12495 X-22.246 Z-44.561
    N12496 X-21.334 Z-45.1
    N12497 X-20.421 Z-45.61
    N12498 X-18.596 Z-46.545
    N12499 X-16.721 Z-47.395
    N12500 X-14.845 Z-48.14
    N12501 X-13.001 Z-48.775
    N12502 X-11.158 Z-49.318
    N12503 X-9.273 Z-49.782
    N12504 X-7.422 Z-50.151
    N12505 X-5.554 Z-50.437
    N12506 X-3.719 Z-50.637
    N12507 X-1.862 Z-50.759
    N12508 X0. Z-50.8
    N12509 X1.862 Z-50.759
    N12510 X3.719 Z-50.637
    N12511 X5.554 Z-50.437
    N12512 X7.422 Z-50.151
    N12513 X9.273 Z-49.782
    N12514 X11.158 Z-49.318
    N12515 X13.001 Z-48.775
    N12516 X14.845 Z-48.14
    N12517 X15.783 Z-47.781
    N12518 X17.658 Z-46.984
    N12519 X19.509 Z-46.092
    N12520 X21.334 Z-45.1
    N12521 X22.246 Z-44.561
    N12522 X23.193 Z-43.968
    N12523 X24.141 Z-43.34
    N12524 X25.088 Z-42.675
    N12525 X26.035 Z-41.973
    N12526 X26.965 Z-41.316
    N12527 X27.895 Z-40.724
    N12528 X28.824 Z-40.185
    N12529 X29.754 Z-39.699
    N12530 X30.684 Z-39.268
    N12531 X31.614 Z-38.885
    N12532 X32.544 Z-38.562
    N12533 X33.474 Z-38.289
    N12534 X34.403 Z-38.088
    N12535 X35.333 Z-37.948
    N12536 X36.263 Z-37.896
    N12537 X119.003 Z-37.896
    N12538 X119.01 Z-10.724
    N12539 X119.104 Z-9.653
    N12540 X119.308 Z-8.571
    N12541 X119.598 Z-7.568
    N12542 X119.947 Z-6.674
    N12543 X120.179 Z-6.185
    N12544 X120.644 Z-5.343
    N12545 X121.109 Z-4.641
    N12546 X121.807 Z-3.769
    N12547 X122.272 Z-3.278
    N12548 X122.736 Z-2.837
    N12549 X123.201 Z-2.444
    N12550 X123.666 Z-2.094
    N12551 X124.131 Z-1.776
    N12552 X125.061 Z-1.24
    N12553 X125.526 Z-1.015
    N12554 X126.456 Z-.638
    N12555 X127.386 Z-.354
    N12556 X128.315 Z-.156
    N12557 X129.245 Z-.039
    N12558 X130.175 Z0.
    N12559 Y-31.825
    N12560 X129.245 Z-.039
    N12561 X128.315 Z-.156
    N12562 X127.386 Z-.354
    N12563 X126.456 Z-.638
    N12564 X125.526 Z-1.015
    N12565 X125.061 Z-1.24
    N12566 X124.131 Z-1.776
    N12567 X123.666 Z-2.094
    N12568 X123.201 Z-2.444
    N12569 X122.736 Z-2.837
    N12570 X122.272 Z-3.278
    N12571 X121.807 Z-3.769
    N12572 X121.109 Z-4.641
    N12573 X120.644 Z-5.343
    N12574 X120.179 Z-6.185
    N12575 X119.947 Z-6.674
    N12576 X119.598 Z-7.568
    N12577 X119.308 Z-8.571
    N12578 X119.104 Z-9.653
    N12579 X119.01 Z-10.724
    N12580 X119.003 Z-36.612
    N12581 X39.053
    N12582 X37.193 Z-36.633
    N12583 X36.263 Z-36.74
    N12584 X35.333 Z-36.924
    N12585 X34.403 Z-37.18
    N12586 X33.474 Z-37.494
    N12587 X32.544 Z-37.868
    N12588 X31.614 Z-38.296
    N12589 X30.684 Z-38.774
    N12590 X29.754 Z-39.309
    N12591 X28.824 Z-39.89
    N12592 X27.895 Z-40.532
    N12593 X26.035 Z-41.969
    N12594 X25.092 Z-42.672
    N12595 X24.148 Z-43.334
    N12596 X23.205 Z-43.96
    N12597 X22.262 Z-44.551
    N12598 X21.345 Z-45.094
    N12599 X19.513 Z-46.09
    N12600 X17.658 Z-46.984
    N12601 X15.783 Z-47.781
    N12602 X14.845 Z-48.14
    N12603 X13.001 Z-48.775
    N12604 X11.158 Z-49.318
    N12605 X9.273 Z-49.782
    N12606 X7.422 Z-50.151
    N12607 X5.554 Z-50.437
    N12608 X3.719 Z-50.637
    N12609 X1.862 Z-50.759
    N12610 X0. Z-50.8
    N12611 X-1.862 Z-50.759
    N12612 X-3.719 Z-50.637
    N12613 X-5.554 Z-50.437
    N12614 X-7.422 Z-50.151
    N12615 X-9.273 Z-49.782
    N12616 X-11.158 Z-49.318
    N12617 X-13.001 Z-48.775
    N12618 X-14.845 Z-48.14
    N12619 X-16.721 Z-47.395
    N12620 X-18.596 Z-46.545
    N12621 X-20.429 Z-45.606
    N12622 X-21.345 Z-45.094
    N12623 X-22.262 Z-44.551
    N12624 X-23.205 Z-43.96
    N12625 X-24.148 Z-43.334
    N12626 X-25.092 Z-42.672
    N12627 X-26.035 Z-41.969
    N12628 X-27.895 Z-40.532
    N12629 X-28.824 Z-39.89
    N12630 X-29.754 Z-39.309
    N12631 X-30.684 Z-38.774
    N12632 X-31.614 Z-38.296
    N12633 X-32.544 Z-37.868
    N12634 X-33.474 Z-37.494
    N12635 X-34.403 Z-37.18
    N12636 X-35.333 Z-36.924
    N12637 X-36.263 Z-36.74
    N12638 X-37.193 Z-36.633
    N12639 X-40.912 Z-36.612
    N12640 X-119.003
    N12641 X-119.017 Z-10.557
    N12642 X-119.133 Z-9.454
    N12643 X-119.366 Z-8.342
    N12644 X-119.598 Z-7.568
    N12645 X-119.947 Z-6.674
    N12646 X-120.412 Z-5.739
    N12647 X-120.877 Z-4.981
    N12648 X-121.342 Z-4.335
    N12649 X-121.807 Z-3.769
    N12650 X-122.272 Z-3.278
    N12651 X-122.736 Z-2.837
    N12652 X-123.201 Z-2.444
    N12653 X-123.666 Z-2.094
    N12654 X-124.131 Z-1.776
    N12655 X-125.061 Z-1.24
    N12656 X-125.526 Z-1.015
    N12657 X-126.456 Z-.638
    N12658 X-127.386 Z-.354
    N12659 X-128.315 Z-.156
    N12660 X-129.245 Z-.039
    N12661 X-130.175 Z0.
    N12662 Y-33.025
    N12663 X-129.245 Z-.039
    N12664 X-128.315 Z-.156
    N12665 X-127.386 Z-.354
    N12666 X-126.456 Z-.638
    N12667 X-125.526 Z-1.015
    N12668 X-125.061 Z-1.24
    N12669 X-124.131 Z-1.776
    N12670 X-123.666 Z-2.094
    N12671 X-123.201 Z-2.444
    N12672 X-122.736 Z-2.837
    N12673 X-122.272 Z-3.278
    N12674 X-121.807 Z-3.769
    N12675 X-121.342 Z-4.335
    N12676 X-120.877 Z-4.981
    N12677 X-120.412 Z-5.739
    N12678 X-119.947 Z-6.674
    N12679 X-119.598 Z-7.568
    N12680 X-119.366 Z-8.342
    N12681 X-119.133 Z-9.454
    N12682 X-119.017 Z-10.557
    N12683 X-119.003 Z-35.22
    N12684 X-39.053 Z-35.222
    N12685 X-38.123 Z-35.291
    N12686 X-37.193 Z-35.451
    N12687 X-36.263 Z-35.691
    N12688 X-35.333 Z-35.996
    N12689 X-34.403 Z-36.363
    N12690 X-33.474 Z-36.788
    N12691 X-32.544 Z-37.263
    N12692 X-31.614 Z-37.795
    N12693 X-30.684 Z-38.374
    N12694 X-29.754 Z-39.008
    N12695 X-28.824 Z-39.705
    N12696 X-26.965 Z-41.234
    N12697 X-26.035 Z-41.969
    N12698 X-25.092 Z-42.672
    N12699 X-24.148 Z-43.334
    N12700 X-23.205 Z-43.96
    N12701 X-22.262 Z-44.551
    N12702 X-21.345 Z-45.094
    N12703 X-20.429 Z-45.606
    N12704 X-18.596 Z-46.545
    N12705 X-16.721 Z-47.395
    N12706 X-14.845 Z-48.14
    N12707 X-13.001 Z-48.775
    N12708 X-11.158 Z-49.318
    N12709 X-9.273 Z-49.782
    N12710 X-7.422 Z-50.151
    N12711 X-5.554 Z-50.437
    N12712 X-3.719 Z-50.637
    N12713 X-1.862 Z-50.759
    N12714 X0. Z-50.8
    N12715 X1.862 Z-50.759
    N12716 X3.719 Z-50.637
    N12717 X5.554 Z-50.437
    N12718 X7.422 Z-50.151
    N12719 X9.273 Z-49.782
    N12720 X11.158 Z-49.318
    N12721 X13.001 Z-48.775
    N12722 X14.845 Z-48.14
    N12723 X15.783 Z-47.781
    N12724 X17.658 Z-46.984
    N12725 X19.513 Z-46.09
    N12726 X21.345 Z-45.094
    N12727 X22.262 Z-44.551
    N12728 X23.205 Z-43.96
    N12729 X24.148 Z-43.334
    N12730 X25.092 Z-42.672
    N12731 X26.035 Z-41.969
    N12732 X26.965 Z-41.234
    N12733 X28.824 Z-39.705
    N12734 X29.754 Z-39.008
    N12735 X30.684 Z-38.374
    N12736 X31.614 Z-37.795
    N12737 X32.544 Z-37.263
    N12738 X33.474 Z-36.788
    N12739 X34.403 Z-36.363
    N12740 X35.333 Z-35.996
    N12741 X36.263 Z-35.691
    N12742 X37.193 Z-35.451
    N12743 X38.123 Z-35.291
    N12744 X39.053 Z-35.222
    N12745 X119.003 Z-35.22
    N12746 X119.01 Z-10.724
    N12747 X119.104 Z-9.653
    N12748 X119.308 Z-8.571
    N12749 X119.598 Z-7.568
    N12750 X119.947 Z-6.674
    N12751 X120.179 Z-6.185
    N12752 X120.644 Z-5.343
    N12753 X121.109 Z-4.641
    N12754 X121.807 Z-3.769
    N12755 X122.272 Z-3.278
    N12756 X122.736 Z-2.837
    N12757 X123.201 Z-2.444
    N12758 X123.666 Z-2.094
    N12759 X124.131 Z-1.776
    N12760 X125.061 Z-1.24
    N12761 X125.526 Z-1.015
    N12762 X126.456 Z-.638
    N12763 X127.386 Z-.354
    N12764 X128.315 Z-.156
    N12765 X129.245 Z-.039
    N12766 X130.175 Z0.
    N12767 Y-34.225
    N12768 X129.245 Z-.039
    N12769 X128.315 Z-.156
    N12770 X127.386 Z-.354
    N12771 X126.456 Z-.638
    N12772 X125.526 Z-1.015
    N12773 X125.061 Z-1.24
    N12774 X124.131 Z-1.776
    N12775 X123.666 Z-2.094
    N12776 X123.201 Z-2.444
    N12777 X122.736 Z-2.837
    N12778 X122.272 Z-3.278
    N12779 X121.807 Z-3.769
    N12780 X121.109 Z-4.641
    N12781 X120.644 Z-5.343
    N12782 X120.179 Z-6.185
    N12783 X119.947 Z-6.674
    N12784 X119.598 Z-7.568
    N12785 X119.308 Z-8.571
    N12786 X119.104 Z-9.653
    N12787 X119.01 Z-10.724
    N12788 X119.003 Z-33.697
    N12789 X40.912
    N12790 X39.982 Z-33.724
    N12791 X39.517 Z-33.775
    N12792 X39.053 Z-33.853
    N12793 X38.123 Z-34.076
    N12794 X37.193 Z-34.369
    N12795 X36.263 Z-34.733
    N12796 X35.333 Z-35.157
    N12797 X34.403 Z-35.633
    N12798 X33.474 Z-36.168
    N12799 X32.544 Z-36.748
    N12800 X31.614 Z-37.383
    N12801 X30.684 Z-38.076
    N12802 X29.754 Z-38.822
    N12803 X28.495 Z-39.933
    N12804 X27.236 Z-41.01
    N12805 X26.035 Z-41.969
    N12806 X25.092 Z-42.672
    N12807 X24.148 Z-43.334
    N12808 X23.205 Z-43.96
    N12809 X22.262 Z-44.551
    N12810 X21.345 Z-45.094
    N12811 X19.513 Z-46.09
    N12812 X17.658 Z-46.984
    N12813 X15.783 Z-47.781
    N12814 X14.845 Z-48.14
    N12815 X13.001 Z-48.775
    N12816 X11.158 Z-49.318
    N12817 X9.273 Z-49.782
    N12818 X7.422 Z-50.151
    N12819 X5.554 Z-50.437
    N12820 X3.719 Z-50.637
    N12821 X1.862 Z-50.759
    N12822 X0. Z-50.8
    N12823 X-1.862 Z-50.759
    N12824 X-3.719 Z-50.637
    N12825 X-5.554 Z-50.437
    N12826 X-7.422 Z-50.151
    N12827 X-9.273 Z-49.782
    N12828 X-11.158 Z-49.318
    N12829 X-13.001 Z-48.775
    N12830 X-14.845 Z-48.14
    N12831 X-16.721 Z-47.395
    N12832 X-18.596 Z-46.545
    N12833 X-20.429 Z-45.606
    N12834 X-21.345 Z-45.094
    N12835 X-22.262 Z-44.551
    N12836 X-23.205 Z-43.96
    N12837 X-24.148 Z-43.334
    N12838 X-25.092 Z-42.672
    N12839 X-26.035 Z-41.969
    N12840 X-27.236 Z-41.01
    N12841 X-28.495 Z-39.933
    N12842 X-29.754 Z-38.822
    N12843 X-30.684 Z-38.076
    N12844 X-31.614 Z-37.383
    N12845 X-32.544 Z-36.748
    N12846 X-33.474 Z-36.168
    N12847 X-34.403 Z-35.633
    N12848 X-35.333 Z-35.157
    N12849 X-36.263 Z-34.733
    N12850 X-37.193 Z-34.369
    N12851 X-38.123 Z-34.076
    N12852 X-39.053 Z-33.853
    N12853 X-39.517 Z-33.775
    N12854 X-39.982 Z-33.724
    N12855 X-40.912 Z-33.697
    N12856 X-119.003
    N12857 X-119.017 Z-10.557
    N12858 X-119.133 Z-9.454
    N12859 X-119.366 Z-8.342
    N12860 X-119.598 Z-7.568
    N12861 X-119.947 Z-6.674
    N12862 X-120.412 Z-5.739
    N12863 X-120.877 Z-4.981
    N12864 X-121.342 Z-4.335
    N12865 X-121.807 Z-3.769
    N12866 X-122.272 Z-3.278
    N12867 X-122.736 Z-2.837
    N12868 X-123.201 Z-2.444
    N12869 X-123.666 Z-2.094
    N12870 X-124.131 Z-1.776
    N12871 X-125.061 Z-1.24
    N12872 X-125.526 Z-1.015
    N12873 X-126.456 Z-.638
    N12874 X-127.386 Z-.354
    N12875 X-128.315 Z-.156
    N12876 X-129.245 Z-.039
    N12877 X-130.175 Z0.
    N12878 Y-35.425
    N12879 X-129.245 Z-.039
    N12880 X-128.315 Z-.156
    N12881 X-127.386 Z-.354
    N12882 X-126.456 Z-.638
    N12883 X-125.526 Z-1.015
    N12884 X-125.061 Z-1.24
    N12885 X-124.131 Z-1.776
    N12886 X-123.666 Z-2.094
    N12887 X-123.201 Z-2.444
    N12888 X-122.736 Z-2.837
    N12889 X-122.272 Z-3.278
    N12890 X-121.807 Z-3.769
    N12891 X-121.342 Z-4.335
    N12892 X-120.877 Z-4.981
    N12893 X-120.412 Z-5.739
    N12894 X-119.947 Z-6.674
    N12895 X-119.598 Z-7.568
    N12896 X-119.366 Z-8.342
    N12897 X-119.133 Z-9.454
    N12898 X-119.017 Z-10.557
    N12899 X-119.003 Z-32.017
    N12900 X-41.842 Z-32.02
    N12901 X-41.377 Z-32.048
    N12902 X-40.912 Z-32.107
    N12903 X-40.447 Z-32.195
    N12904 X-39.982 Z-32.309
    N12905 X-39.053 Z-32.59
    N12906 X-38.123 Z-32.955
    N12907 X-37.193 Z-33.376
    N12908 X-36.263 Z-33.861
    N12909 X-35.333 Z-34.404
    N12910 X-34.403 Z-34.991
    N12911 X-33.474 Z-35.634
    N12912 X-32.544 Z-36.332
    N12913 X-31.614 Z-37.078
    N12914 X-30.684 Z-37.885
    N12915 X-28.816 Z-39.641
    N12916 X-27.877 Z-40.472
    N12917 X-26.956 Z-41.241
    N12918 X-26.035 Z-41.969
    N12919 X-25.092 Z-42.672
    N12920 X-24.148 Z-43.334
    N12921 X-23.205 Z-43.96
    N12922 X-22.262 Z-44.551
    N12923 X-21.345 Z-45.094
    N12924 X-20.429 Z-45.606
    N12925 X-18.596 Z-46.545
    N12926 X-16.721 Z-47.395
    N12927 X-14.845 Z-48.14
    N12928 X-13.001 Z-48.775
    N12929 X-11.158 Z-49.318
    N12930 X-9.273 Z-49.782
    N12931 X-7.422 Z-50.151
    N12932 X-5.554 Z-50.437
    N12933 X-3.719 Z-50.637
    N12934 X-1.862 Z-50.759
    N12935 X0. Z-50.8
    N12936 X1.862 Z-50.759
    N12937 X3.719 Z-50.637
    N12938 X5.554 Z-50.437
    N12939 X7.422 Z-50.151
    N12940 X9.273 Z-49.782
    N12941 X11.158 Z-49.318
    N12942 X13.001 Z-48.775
    N12943 X14.845 Z-48.14
    N12944 X15.783 Z-47.781
    N12945 X17.658 Z-46.984
    N12946 X19.513 Z-46.09
    N12947 X21.345 Z-45.094
    N12948 X22.262 Z-44.551
    N12949 X23.205 Z-43.96
    N12950 X24.148 Z-43.334
    N12951 X25.092 Z-42.672
    N12952 X26.035 Z-41.969
    N12953 X26.956 Z-41.241
    N12954 X27.877 Z-40.472
    N12955 X28.816 Z-39.641
    N12956 X30.684 Z-37.885
    N12957 X31.614 Z-37.078
    N12958 X32.544 Z-36.332
    N12959 X33.474 Z-35.634
    N12960 X34.403 Z-34.991
    N12961 X35.333 Z-34.404
    N12962 X36.263 Z-33.861
    N12963 X37.193 Z-33.376
    N12964 X38.123 Z-32.955
    N12965 X39.053 Z-32.59
    N12966 X39.982 Z-32.309
    N12967 X40.447 Z-32.195
    N12968 X40.912 Z-32.107
    N12969 X41.395 Z-32.046
    N12970 X41.878 Z-32.02
    N12971 X119.003 Z-32.017
    N12972 X119.01 Z-10.724
    N12973 X119.104 Z-9.653
    N12974 X119.308 Z-8.571
    N12975 X119.598 Z-7.568
    N12976 X119.947 Z-6.674
    N12977 X120.179 Z-6.185
    N12978 X120.644 Z-5.343
    N12979 X121.109 Z-4.641
    N12980 X121.807 Z-3.769
    N12981 X122.272 Z-3.278
    N12982 X122.736 Z-2.837
    N12983 X123.201 Z-2.444
    N12984 X123.666 Z-2.094
    N12985 X124.131 Z-1.776
    N12986 X125.061 Z-1.24
    N12987 X125.526 Z-1.015
    N12988 X126.456 Z-.638
    N12989 X127.386 Z-.354
    N12990 X128.315 Z-.156
    N12991 X129.245 Z-.039
    N12992 X130.175 Z0.
    N12993 Y-36.625
    N12994 X129.245 Z-.039
    N12995 X128.315 Z-.156
    N12996 X127.386 Z-.354
    N12997 X126.456 Z-.638
    N12998 X125.526 Z-1.015
    N12999 X125.061 Z-1.24
    N13000 X124.131 Z-1.776
    N13001 X123.666 Z-2.094
    N13002 X123.201 Z-2.444
    N13003 X122.736 Z-2.837
    N13004 X122.272 Z-3.278
    N13005 X121.807 Z-3.769
    N13006 X121.109 Z-4.641
    N13007 X120.644 Z-5.343
    N13008 X120.179 Z-6.185
    N13009 X119.947 Z-6.674
    N13010 X119.598 Z-7.568
    N13011 X119.308 Z-8.571
    N13012 X119.104 Z-9.653
    N13013 X119.01 Z-10.724
    N13014 X119.003 Z-30.142
    N13015 X43.237 Z-30.149
    N13016 X42.772 Z-30.184
    N13017 X42.307 Z-30.251
    N13018 X41.842 Z-30.349
    N13019 X40.912 Z-30.626
    N13020 X39.982 Z-30.983
    N13021 X39.053 Z-31.415
    N13022 X38.123 Z-31.917
    N13023 X37.193 Z-32.467
    N13024 X36.263 Z-33.074
    N13025 X35.333 Z-33.735
    N13026 X34.403 Z-34.444
    N13027 X33.474 Z-35.202
    N13028 X32.544 Z-36.016
    N13029 X31.614 Z-36.893
    N13030 X29.754 Z-38.761
    N13031 X28.824 Z-39.633
    N13032 X27.895 Z-40.457
    N13033 X26.965 Z-41.234
    N13034 X26.035 Z-41.969
    N13035 X25.092 Z-42.672
    N13036 X24.148 Z-43.334
    N13037 X23.205 Z-43.96
    N13038 X22.262 Z-44.551
    N13039 X21.345 Z-45.094
    N13040 X19.513 Z-46.09
    N13041 X17.658 Z-46.984
    N13042 X15.783 Z-47.781
    N13043 X14.845 Z-48.14
    N13044 X13.001 Z-48.775
    N13045 X11.158 Z-49.318
    N13046 X9.273 Z-49.782
    N13047 X7.422 Z-50.151
    N13048 X5.554 Z-50.437
    N13049 X3.719 Z-50.637
    N13050 X1.862 Z-50.759
    N13051 X0. Z-50.8
    N13052 X-1.862 Z-50.759
    N13053 X-3.719 Z-50.637
    N13054 X-5.554 Z-50.437
    N13055 X-7.422 Z-50.151
    N13056 X-9.273 Z-49.782
    N13057 X-11.158 Z-49.318
    N13058 X-13.001 Z-48.775
    N13059 X-14.845 Z-48.14
    N13060 X-16.721 Z-47.395
    N13061 X-18.596 Z-46.545
    N13062 X-20.429 Z-45.606
    N13063 X-21.345 Z-45.094
    N13064 X-22.262 Z-44.551
    N13065 X-23.205 Z-43.96
    N13066 X-24.148 Z-43.334
    N13067 X-25.092 Z-42.672
    N13068 X-26.035 Z-41.969
    N13069 X-26.965 Z-41.234
    N13070 X-27.895 Z-40.457
    N13071 X-28.824 Z-39.633
    N13072 X-29.754 Z-38.761
    N13073 X-31.614 Z-36.893
    N13074 X-32.544 Z-36.016
    N13075 X-33.474 Z-35.202
    N13076 X-34.403 Z-34.444
    N13077 X-35.333 Z-33.735
    N13078 X-36.263 Z-33.074
    N13079 X-37.193 Z-32.467
    N13080 X-38.123 Z-31.917
    N13081 X-39.053 Z-31.415
    N13082 X-39.982 Z-30.983
    N13083 X-40.912 Z-30.626
    N13084 X-41.427 Z-30.462
    N13085 X-41.943 Z-30.326
    N13086 X-42.458 Z-30.226
    N13087 X-42.973 Z-30.166
    N13088 X-48.351 Z-30.142
    N13089 X-119.003
    N13090 X-119.017 Z-10.557
    N13091 X-119.133 Z-9.454
    N13092 X-119.366 Z-8.342
    N13093 X-119.598 Z-7.568
    N13094 X-119.947 Z-6.674
    N13095 X-120.412 Z-5.739
    N13096 X-120.877 Z-4.981
    N13097 X-121.342 Z-4.335
    N13098 X-121.807 Z-3.769
    N13099 X-122.272 Z-3.278
    N13100 X-122.736 Z-2.837
    N13101 X-123.201 Z-2.444
    N13102 X-123.666 Z-2.094
    N13103 X-124.131 Z-1.776
    N13104 X-125.061 Z-1.24
    N13105 X-125.526 Z-1.015
    N13106 X-126.456 Z-.638
    N13107 X-127.386 Z-.354
    N13108 X-128.315 Z-.156
    N13109 X-129.245 Z-.039
    N13110 X-130.175 Z0.
    N13111 Y-37.825
    N13112 X-129.245 Z-.039
    N13113 X-128.315 Z-.156
    N13114 X-127.386 Z-.354
    N13115 X-126.456 Z-.638
    N13116 X-125.526 Z-1.015
    N13117 X-125.061 Z-1.24
    N13118 X-124.131 Z-1.776
    N13119 X-123.666 Z-2.094
    N13120 X-123.201 Z-2.444
    N13121 X-122.736 Z-2.837
    N13122 X-122.272 Z-3.278
    N13123 X-121.807 Z-3.769
    N13124 X-121.342 Z-4.335
    N13125 X-120.877 Z-4.981
    N13126 X-120.412 Z-5.739
    N13127 X-119.947 Z-6.674
    N13128 X-119.598 Z-7.568
    N13129 X-119.366 Z-8.342
    N13130 X-119.133 Z-9.454
    N13131 X-119.017 Z-10.557
    N13132 X-119.003 Z-28.02
    N13133 X-44.631 Z-28.027
    N13134 X-44.167 Z-28.075
    N13135 X-43.237 Z-28.27
    N13136 X-42.772 Z-28.412
    N13137 X-41.842 Z-28.777
    N13138 X-40.912 Z-29.222
    N13139 X-39.982 Z-29.738
    N13140 X-39.053 Z-30.32
    N13141 X-38.123 Z-30.958
    N13142 X-37.193 Z-31.641
    N13143 X-36.263 Z-32.375
    N13144 X-35.333 Z-33.16
    N13145 X-34.403 Z-33.996
    N13146 X-32.91 Z-35.449
    N13147 X-31.221 Z-37.271
    N13148 X-30.095 Z-38.429
    N13149 X-28.969 Z-39.502
    N13150 X-28.235 Z-40.161
    N13151 X-26.768 Z-41.394
    N13152 X-25.092 Z-42.672
    N13153 X-24.148 Z-43.334
    N13154 X-23.205 Z-43.96
    N13155 X-22.262 Z-44.551
    N13156 X-21.345 Z-45.094
    N13157 X-20.429 Z-45.606
    N13158 X-18.596 Z-46.545
    N13159 X-16.721 Z-47.395
    N13160 X-14.845 Z-48.14
    N13161 X-13.001 Z-48.775
    N13162 X-11.158 Z-49.318
    N13163 X-9.273 Z-49.782
    N13164 X-7.422 Z-50.151
    N13165 X-5.554 Z-50.437
    N13166 X-3.719 Z-50.637
    N13167 X-1.862 Z-50.759
    N13168 X0. Z-50.8
    N13169 X1.862 Z-50.759
    N13170 X3.719 Z-50.637
    N13171 X5.554 Z-50.437
    N13172 X7.422 Z-50.151
    N13173 X9.273 Z-49.782
    N13174 X11.158 Z-49.318
    N13175 X13.001 Z-48.775
    N13176 X14.845 Z-48.14
    N13177 X15.783 Z-47.781
    N13178 X17.658 Z-46.984
    N13179 X19.513 Z-46.09
    N13180 X21.345 Z-45.094
    N13181 X22.262 Z-44.551
    N13182 X23.205 Z-43.96
    N13183 X24.148 Z-43.334
    N13184 X25.092 Z-42.672
    N13185 X26.035 Z-41.969
    N13186 X27.502 Z-40.792
    N13187 X28.969 Z-39.502
    N13188 X30.095 Z-38.429
    N13189 X30.658 Z-37.863
    N13190 X32.91 Z-35.449
    N13191 X34.403 Z-33.996
    N13192 X35.333 Z-33.16
    N13193 X36.263 Z-32.375
    N13194 X37.193 Z-31.641
    N13195 X38.123 Z-30.958
    N13196 X39.053 Z-30.32
    N13197 X39.982 Z-29.738
    N13198 X40.912 Z-29.222
    N13199 X41.842 Z-28.777
    N13200 X42.772 Z-28.412
    N13201 X43.237 Z-28.27
    N13202 X44.167 Z-28.075
    N13203 X44.631 Z-28.027
    N13204 X119.003 Z-28.02
    N13205 X119.01 Z-10.724
    N13206 X119.104 Z-9.653
    N13207 X119.308 Z-8.571
    N13208 X119.598 Z-7.568
    N13209 X119.947 Z-6.674
    N13210 X120.179 Z-6.185
    N13211 X120.644 Z-5.343
    N13212 X121.109 Z-4.641
    N13213 X121.807 Z-3.769
    N13214 X122.272 Z-3.278
    N13215 X122.736 Z-2.837
    N13216 X123.201 Z-2.444
    N13217 X123.666 Z-2.094
    N13218 X124.131 Z-1.776
    N13219 X125.061 Z-1.24
    N13220 X125.526 Z-1.015
    N13221 X126.456 Z-.638
    N13222 X127.386 Z-.354
    N13223 X128.315 Z-.156
    N13224 X129.245 Z-.039
    N13225 X130.175 Z0.
    N13226 Y-39.025
    N13227 X129.245 Z-.039
    N13228 X128.315 Z-.156
    N13229 X127.386 Z-.354
    N13230 X126.456 Z-.638
    N13231 X125.526 Z-1.015
    N13232 X125.061 Z-1.24
    N13233 X124.131 Z-1.776
    N13234 X123.666 Z-2.094
    N13235 X123.201 Z-2.444
    N13236 X122.736 Z-2.837
    N13237 X122.272 Z-3.278
    N13238 X121.807 Z-3.769
    N13239 X121.109 Z-4.641
    N13240 X120.644 Z-5.343
    N13241 X120.179 Z-6.185
    N13242 X119.947 Z-6.674
    N13243 X119.598 Z-7.568
    N13244 X119.308 Z-8.571
    N13245 X119.104 Z-9.653
    N13246 X119.01 Z-10.724
    N13247 X119.003 Z-25.57
    N13248 X46.491
    N13249 X46.026 Z-25.584
    N13250 X45.561 Z-25.637
    N13251 X45.096 Z-25.733
    N13252 X44.631 Z-25.871
    N13253 X43.702 Z-26.239
    N13254 X43.237 Z-26.462
    N13255 X42.772 Z-26.714
    N13256 X41.842 Z-27.263
    N13257 X40.912 Z-27.885
    N13258 X39.982 Z-28.567
    N13259 X39.053 Z-29.301
    N13260 X38.123 Z-30.082
    N13261 X37.193 Z-30.904
    N13262 X36.263 Z-31.774
    N13263 X35.333 Z-32.693
    N13264 X34.403 Z-33.665
    N13265 X33.474 Z-34.698
    N13266 X32.503 Z-35.84
    N13267 X31.532 Z-36.939
    N13268 X30.561 Z-37.961
    N13269 X29.59 Z-38.919
    N13270 X28.701 Z-39.746
    N13271 X27.812 Z-40.528
    N13272 X26.924 Z-41.268
    N13273 X26.035 Z-41.969
    N13274 X25.092 Z-42.672
    N13275 X24.148 Z-43.334
    N13276 X23.205 Z-43.96
    N13277 X22.262 Z-44.551
    N13278 X21.345 Z-45.094
    N13279 X19.513 Z-46.09
    N13280 X17.658 Z-46.984
    N13281 X15.783 Z-47.781
    N13282 X14.845 Z-48.14
    N13283 X13.001 Z-48.775
    N13284 X11.158 Z-49.318
    N13285 X9.273 Z-49.782
    N13286 X7.422 Z-50.151
    N13287 X5.554 Z-50.437
    N13288 X3.719 Z-50.637
    N13289 X1.862 Z-50.759
    N13290 X0. Z-50.8
    N13291 X-1.862 Z-50.759
    N13292 X-3.719 Z-50.637
    N13293 X-5.554 Z-50.437
    N13294 X-7.422 Z-50.151
    N13295 X-9.273 Z-49.782
    N13296 X-11.158 Z-49.318
    N13297 X-13.001 Z-48.775
    N13298 X-14.845 Z-48.14
    N13299 X-16.721 Z-47.395
    N13300 X-18.596 Z-46.545
    N13301 X-20.429 Z-45.606
    N13302 X-21.345 Z-45.094
    N13303 X-22.262 Z-44.551
    N13304 X-23.205 Z-43.96
    N13305 X-24.148 Z-43.334
    N13306 X-25.092 Z-42.672
    N13307 X-26.035 Z-41.969
    N13308 X-26.924 Z-41.268
    N13309 X-27.812 Z-40.528
    N13310 X-28.701 Z-39.746
    N13311 X-29.59 Z-38.919
    N13312 X-30.561 Z-37.961
    N13313 X-31.532 Z-36.939
    N13314 X-32.503 Z-35.84
    N13315 X-33.474 Z-34.698
    N13316 X-34.403 Z-33.665
    N13317 X-35.333 Z-32.693
    N13318 X-36.263 Z-31.774
    N13319 X-37.193 Z-30.904
    N13320 X-38.123 Z-30.082
    N13321 X-39.053 Z-29.301
    N13322 X-39.982 Z-28.567
    N13323 X-40.912 Z-27.885
    N13324 X-41.842 Z-27.263
    N13325 X-42.772 Z-26.714
    N13326 X-43.237 Z-26.462
    N13327 X-43.702 Z-26.239
    N13328 X-44.631 Z-25.871
    N13329 X-45.096 Z-25.733
    N13330 X-45.561 Z-25.637
    N13331 X-46.026 Z-25.584
    N13332 X-119.003 Z-25.57
    N13333 X-119.017 Z-10.557
    N13334 X-119.133 Z-9.454
    N13335 X-119.366 Z-8.342
    N13336 X-119.598 Z-7.568
    N13337 X-119.947 Z-6.674
    N13338 X-120.412 Z-5.739
    N13339 X-120.877 Z-4.981
    N13340 X-121.342 Z-4.335
    N13341 X-121.807 Z-3.769
    N13342 X-122.272 Z-3.278
    N13343 X-122.736 Z-2.837
    N13344 X-123.201 Z-2.444
    N13345 X-123.666 Z-2.094
    N13346 X-124.131 Z-1.776
    N13347 X-125.061 Z-1.24
    N13348 X-125.526 Z-1.015
    N13349 X-126.456 Z-.638
    N13350 X-127.386 Z-.354
    N13351 X-128.315 Z-.156
    N13352 X-129.245 Z-.039
    N13353 X-130.175 Z0.
    N13354 Y-40.225
    N13355 X-129.245 Z-.039
    N13356 X-128.315 Z-.156
    N13357 X-127.386 Z-.354
    N13358 X-126.456 Z-.638
    N13359 X-125.526 Z-1.015
    N13360 X-125.061 Z-1.24
    N13361 X-124.131 Z-1.776
    N13362 X-123.666 Z-2.094
    N13363 X-123.201 Z-2.444
    N13364 X-122.736 Z-2.837
    N13365 X-122.272 Z-3.278
    N13366 X-121.807 Z-3.769
    N13367 X-121.342 Z-4.335
    N13368 X-120.877 Z-4.981
    N13369 X-120.412 Z-5.739
    N13370 X-119.947 Z-6.674
    N13371 X-119.598 Z-7.568
    N13372 X-119.366 Z-8.342
    N13373 X-119.133 Z-9.454
    N13374 X-119.017 Z-10.557
    N13375 X-119.003 Z-22.613
    N13376 X-48.351
    N13377 X-47.421 Z-22.632
    N13378 X-46.956 Z-22.709
    N13379 X-46.491 Z-22.831
    N13380 X-46.026 Z-23.002
    N13381 X-45.096 Z-23.458
    N13382 X-44.631 Z-23.729
    N13383 X-43.702 Z-24.346
    N13384 X-42.772 Z-25.043
    N13385 X-41.842 Z-25.802
    N13386 X-40.912 Z-26.612
    N13387 X-39.982 Z-27.466
    N13388 X-39.053 Z-28.361
    N13389 X-38.123 Z-29.295
    N13390 X-37.193 Z-30.269
    N13391 X-36.263 Z-31.287
    N13392 X-35.333 Z-32.356
    N13393 X-34.403 Z-33.484
    N13394 X-33.474 Z-34.669
    N13395 X-32.518 Z-35.823
    N13396 X-31.562 Z-36.905
    N13397 X-30.606 Z-37.915
    N13398 X-29.65 Z-38.861
    N13399 X-28.746 Z-39.704
    N13400 X-27.843 Z-40.502
    N13401 X-26.939 Z-41.256
    N13402 X-26.035 Z-41.969
    N13403 X-25.092 Z-42.672
    N13404 X-24.148 Z-43.334
    N13405 X-23.205 Z-43.96
    N13406 X-22.262 Z-44.551
    N13407 X-21.345 Z-45.094
    N13408 X-20.429 Z-45.606
    N13409 X-18.596 Z-46.545
    N13410 X-16.721 Z-47.395
    N13411 X-14.845 Z-48.14
    N13412 X-13.001 Z-48.775
    N13413 X-11.158 Z-49.318
    N13414 X-9.273 Z-49.782
    N13415 X-7.422 Z-50.151
    N13416 X-5.554 Z-50.437
    N13417 X-3.719 Z-50.637
    N13418 X-1.862 Z-50.759
    N13419 X0. Z-50.8
    N13420 X1.862 Z-50.759
    N13421 X3.719 Z-50.637
    N13422 X5.554 Z-50.437
    N13423 X7.422 Z-50.151
    N13424 X9.273 Z-49.782
    N13425 X11.158 Z-49.318
    N13426 X13.001 Z-48.775
    N13427 X14.845 Z-48.14
    N13428 X15.783 Z-47.781
    N13429 X17.658 Z-46.984
    N13430 X19.513 Z-46.09
    N13431 X21.345 Z-45.094
    N13432 X22.262 Z-44.551
    N13433 X23.205 Z-43.96
    N13434 X24.148 Z-43.334
    N13435 X25.092 Z-42.672
    N13436 X26.035 Z-41.969
    N13437 X26.939 Z-41.256
    N13438 X27.843 Z-40.502
    N13439 X28.746 Z-39.704
    N13440 X29.65 Z-38.861
    N13441 X30.606 Z-37.915
    N13442 X31.562 Z-36.905
    N13443 X32.518 Z-35.823
    N13444 X33.474 Z-34.669
    N13445 X34.403 Z-33.484
    N13446 X35.333 Z-32.356
    N13447 X36.263 Z-31.287
    N13448 X37.193 Z-30.269
    N13449 X38.123 Z-29.295
    N13450 X39.053 Z-28.361
    N13451 X39.982 Z-27.466
    N13452 X40.912 Z-26.612
    N13453 X41.842 Z-25.802
    N13454 X42.772 Z-25.043
    N13455 X43.702 Z-24.346
    N13456 X44.631 Z-23.729
    N13457 X45.096 Z-23.458
    N13458 X46.026 Z-23.002
    N13459 X46.491 Z-22.831
    N13460 X46.956 Z-22.709
    N13461 X47.421 Z-22.632
    N13462 X48.351 Z-22.613
    N13463 X119.003
    N13464 X119.01 Z-10.724
    N13465 X119.104 Z-9.653
    N13466 X119.308 Z-8.571
    N13467 X119.598 Z-7.568
    N13468 X119.947 Z-6.674
    N13469 X120.179 Z-6.185
    N13470 X120.644 Z-5.343
    N13471 X121.109 Z-4.641
    N13472 X121.807 Z-3.769
    N13473 X122.272 Z-3.278
    N13474 X122.736 Z-2.837
    N13475 X123.201 Z-2.444
    N13476 X123.666 Z-2.094
    N13477 X124.131 Z-1.776
    N13478 X125.061 Z-1.24
    N13479 X125.526 Z-1.015
    N13480 X126.456 Z-.638
    N13481 X127.386 Z-.354
    N13482 X128.315 Z-.156
    N13483 X129.245 Z-.039
    N13484 X130.175 Z0.
    N13485 Y-41.425
    N13486 X129.245 Z-.039
    N13487 X128.315 Z-.156
    N13488 X127.386 Z-.354
    N13489 X126.456 Z-.638
    N13490 X125.526 Z-1.015
    N13491 X125.061 Z-1.24
    N13492 X124.131 Z-1.776
    N13493 X123.666 Z-2.094
    N13494 X123.201 Z-2.444
    N13495 X122.736 Z-2.837
    N13496 X122.272 Z-3.278
    N13497 X121.807 Z-3.769
    N13498 X121.109 Z-4.641
    N13499 X120.644 Z-5.343
    N13500 X120.179 Z-6.185
    N13501 X119.947 Z-6.674
    N13502 X119.598 Z-7.568
    N13503 X119.308 Z-8.571
    N13504 X119.104 Z-9.653
    N13505 X119.01 Z-10.724
    N13506 X119.003 Z-18.75
    N13507 X49.282
    N13508 X48.816 Z-18.78
    N13509 X48.351 Z-18.897
    N13510 X47.886 Z-19.072
    N13511 X47.421 Z-19.314
    N13512 X46.491 Z-19.935
    N13513 X45.561 Z-20.689
    N13514 X44.631 Z-21.532
    N13515 X43.702 Z-22.437
    N13516 X41.842 Z-24.374
    N13517 X39.982 Z-26.434
    N13518 X38.123 Z-28.608
    N13519 X37.193 Z-29.746
    N13520 X36.263 Z-30.928
    N13521 X35.333 Z-32.168
    N13522 X34.403 Z-33.455
    N13523 X33.474 Z-34.669
    N13524 X32.518 Z-35.823
    N13525 X31.562 Z-36.905
    N13526 X30.606 Z-37.915
    N13527 X29.65 Z-38.861
    N13528 X28.746 Z-39.704
    N13529 X27.843 Z-40.502
    N13530 X26.939 Z-41.256
    N13531 X26.035 Z-41.969
    N13532 X25.092 Z-42.672
    N13533 X24.148 Z-43.334
    N13534 X23.205 Z-43.96
    N13535 X22.262 Z-44.551
    N13536 X21.345 Z-45.094
    N13537 X19.513 Z-46.09
    N13538 X17.658 Z-46.984
    N13539 X15.783 Z-47.781
    N13540 X14.845 Z-48.14
    N13541 X13.001 Z-48.775
    N13542 X11.158 Z-49.318
    N13543 X9.273 Z-49.782
    N13544 X7.422 Z-50.151
    N13545 X5.554 Z-50.437
    N13546 X3.719 Z-50.637
    N13547 X1.862 Z-50.759
    N13548 X0. Z-50.8
    N13549 X-1.862 Z-50.759
    N13550 X-3.719 Z-50.637
    N13551 X-5.554 Z-50.437
    N13552 X-7.422 Z-50.151
    N13553 X-9.273 Z-49.782
    N13554 X-11.158 Z-49.318
    N13555 X-13.001 Z-48.775
    N13556 X-14.845 Z-48.14
    N13557 X-16.721 Z-47.395
    N13558 X-18.596 Z-46.545
    N13559 X-20.429 Z-45.606
    N13560 X-21.345 Z-45.094
    N13561 X-22.262 Z-44.551
    N13562 X-23.205 Z-43.96
    N13563 X-24.148 Z-43.334
    N13564 X-25.092 Z-42.672
    N13565 X-26.035 Z-41.969
    N13566 X-26.939 Z-41.256
    N13567 X-27.843 Z-40.502
    N13568 X-28.746 Z-39.704
    N13569 X-29.65 Z-38.861
    N13570 X-30.606 Z-37.915
    N13571 X-31.562 Z-36.905
    N13572 X-32.996 Z-35.256
    N13573 X-33.474 Z-34.669
    N13574 X-34.403 Z-33.455
    N13575 X-35.333 Z-32.168
    N13576 X-36.263 Z-30.928
    N13577 X-37.193 Z-29.746
    N13578 X-39.053 Z-27.507
    N13579 X-40.912 Z-25.39
    N13580 X-42.772 Z-23.388
    N13581 X-43.702 Z-22.437
    N13582 X-44.631 Z-21.532
    N13583 X-45.561 Z-20.689
    N13584 X-46.491 Z-19.935
    N13585 X-47.421 Z-19.314
    N13586 X-47.886 Z-19.072
    N13587 X-48.351 Z-18.897
    N13588 X-48.816 Z-18.78
    N13589 X-49.282 Z-18.75
    N13590 X-119.003
    N13591 X-119.017 Z-10.557
    N13592 X-119.133 Z-9.454
    N13593 X-119.366 Z-8.342
    N13594 X-119.598 Z-7.568
    N13595 X-119.947 Z-6.674
    N13596 X-120.412 Z-5.739
    N13597 X-120.877 Z-4.981
    N13598 X-121.342 Z-4.335
    N13599 X-121.807 Z-3.769
    N13600 X-122.272 Z-3.278
    N13601 X-122.736 Z-2.837
    N13602 X-123.201 Z-2.444
    N13603 X-123.666 Z-2.094
    N13604 X-124.131 Z-1.776
    N13605 X-125.061 Z-1.24
    N13606 X-125.526 Z-1.015
    N13607 X-126.456 Z-.638
    N13608 X-127.386 Z-.354
    N13609 X-128.315 Z-.156
    N13610 X-129.245 Z-.039
    N13611 X-130.175 Z0.
    N13612 Y-42.625
    N13613 X-129.245 Z-.039
    N13614 X-128.315 Z-.156
    N13615 X-127.386 Z-.354
    N13616 X-126.456 Z-.638
    N13617 X-125.526 Z-1.015
    N13618 X-125.061 Z-1.24
    N13619 X-124.131 Z-1.776
    N13620 X-123.666 Z-2.094
    N13621 X-123.201 Z-2.444
    N13622 X-122.736 Z-2.837
    N13623 X-122.272 Z-3.278
    N13624 X-121.807 Z-3.769
    N13625 X-121.342 Z-4.335
    N13626 X-120.877 Z-4.981
    N13627 X-120.412 Z-5.739
    N13628 X-119.947 Z-6.674
    N13629 X-119.598 Z-7.568
    N13630 X-119.366 Z-8.342
    N13631 X-119.133 Z-9.454
    N13632 X-119.046 Z-10.182
    N13633 X-119.003 Z-11.833
    N13634 X-50.443 Z-11.848
    N13635 X-50.21 Z-11.927
    N13636 X-49.978 Z-12.071
    N13637 X-49.513 Z-12.486
    N13638 X-49.281 Z-12.733
    N13639 X-48.583 Z-13.613
    N13640 X-46.411 Z-16.693
    N13641 X-44.471 Z-19.412
    N13642 X-39.053 Z-26.76
    N13643 X-37.193 Z-29.367
    N13644 X-35.223 Z-32.308
    N13645 X-34.566 Z-33.233
    N13646 X-33.474 Z-34.669
    N13647 X-32.518 Z-35.823
    N13648 X-31.562 Z-36.905
    N13649 X-30.606 Z-37.915
    N13650 X-29.65 Z-38.861
    N13651 X-28.746 Z-39.704
    N13652 X-27.843 Z-40.502
    N13653 X-26.939 Z-41.256
    N13654 X-26.035 Z-41.969
    N13655 X-25.092 Z-42.672
    N13656 X-24.148 Z-43.334
    N13657 X-23.205 Z-43.96
    N13658 X-22.262 Z-44.551
    N13659 X-21.345 Z-45.094
    N13660 X-20.429 Z-45.606
    N13661 X-18.596 Z-46.545
    N13662 X-16.721 Z-47.395
    N13663 X-14.845 Z-48.14
    N13664 X-13.001 Z-48.775
    N13665 X-11.158 Z-49.318
    N13666 X-9.273 Z-49.782
    N13667 X-7.422 Z-50.151
    N13668 X-5.554 Z-50.437
    N13669 X-3.719 Z-50.637
    N13670 X-1.862 Z-50.759
    N13671 X0. Z-50.8
    N13672 X1.862 Z-50.759
    N13673 X3.719 Z-50.637
    N13674 X5.554 Z-50.437
    N13675 X7.422 Z-50.151
    N13676 X9.273 Z-49.782
    N13677 X11.158 Z-49.318
    N13678 X13.001 Z-48.775
    N13679 X14.845 Z-48.14
    N13680 X15.783 Z-47.781
    N13681 X17.658 Z-46.984
    N13682 X19.513 Z-46.09
    N13683 X21.345 Z-45.094
    N13684 X22.262 Z-44.551
    N13685 X23.205 Z-43.96
    N13686 X24.148 Z-43.334
    N13687 X25.092 Z-42.672
    N13688 X26.035 Z-41.969
    N13689 X26.939 Z-41.256
    N13690 X27.843 Z-40.502
    N13691 X28.746 Z-39.704
    N13692 X29.65 Z-38.861
    N13693 X30.606 Z-37.915
    N13694 X31.562 Z-36.905
    N13695 X32.518 Z-35.823
    N13696 X33.474 Z-34.669
    N13697 X34.02 Z-33.966
    N13698 X35.223 Z-32.308
    N13699 X36.536 Z-30.332
    N13700 X38.123 Z-28.045
    N13701 X44.471 Z-19.412
    N13702 X46.411 Z-16.693
    N13703 X47.381 Z-15.298
    N13704 X48.645 Z-13.53
    N13705 X49.234 Z-12.788
    N13706 X49.528 Z-12.471
    N13707 X49.822 Z-12.201
    N13708 X50.117 Z-11.978
    N13709 X50.264 Z-11.903
    N13710 X50.411 Z-11.855
    N13711 X50.705 Z-11.833
    N13712 X119.003
    N13713 X119.01 Z-10.724
    N13714 X119.104 Z-9.653
    N13715 X119.308 Z-8.571
    N13716 X119.598 Z-7.568
    N13717 X119.947 Z-6.674
    N13718 X120.179 Z-6.185
    N13719 X120.644 Z-5.343
    N13720 X121.109 Z-4.641
    N13721 X121.807 Z-3.769
    N13722 X122.272 Z-3.278
    N13723 X122.736 Z-2.837
    N13724 X123.201 Z-2.444
    N13725 X123.666 Z-2.094
    N13726 X124.131 Z-1.776
    N13727 X125.061 Z-1.24
    N13728 X125.526 Z-1.015
    N13729 X126.456 Z-.638
    N13730 X127.386 Z-.354
    N13731 X128.315 Z-.156
    N13732 X129.245 Z-.039
    N13733 X130.175 Z0.
    N13734 Y-43.825
    N13735 X129.245 Z-.039
    N13736 X128.315 Z-.156
    N13737 X127.386 Z-.354
    N13738 X126.456 Z-.638
    N13739 X125.526 Z-1.015
    N13740 X125.061 Z-1.24
    N13741 X124.131 Z-1.776
    N13742 X123.666 Z-2.094
    N13743 X123.201 Z-2.444
    N13744 X122.736 Z-2.837
    N13745 X122.272 Z-3.278
    N13746 X121.807 Z-3.769
    N13747 X121.109 Z-4.641
    N13748 X120.644 Z-5.343
    N13749 X120.121 Z-6.299
    N13750 X120.063 Z-6.306
    N13751 X51.14 Z-6.312
    N13752 X50.675 Z-6.326
    N13753 X50.21 Z-6.393
    N13754 X49.745 Z-6.523
    N13755 X49.281 Z-6.72
    N13756 X48.816 Z-6.984
    N13757 X48.351 Z-7.333
    N13758 X47.886 Z-7.795
    N13759 X47.653 Z-8.075
    N13760 X47.421 Z-8.416
    N13761 X47.188 Z-8.818
    N13762 X46.898 Z-9.511
    N13763 X46.724 Z-10.175
    N13764 X46.491 Z-11.364
    N13765 X46.259 Z-12.284
    N13766 X46.026 Z-13.064
    N13767 X45.445 Z-14.675
    N13768 X45.096 Z-15.505
    N13769 X44.631 Z-16.528
    N13770 X43.702 Z-18.367
    N13771 X42.772 Z-20.047
    N13772 X40.912 Z-23.154
    N13773 X38.123 Z-27.641
    N13774 X36.263 Z-30.727
    N13775 X35.333 Z-32.15
    N13776 X34.403 Z-33.455
    N13777 X33.474 Z-34.669
    N13778 X32.518 Z-35.823
    N13779 X31.562 Z-36.905
    N13780 X30.606 Z-37.915
    N13781 X29.65 Z-38.861
    N13782 X28.746 Z-39.704
    N13783 X27.843 Z-40.502
    N13784 X26.939 Z-41.256
    N13785 X26.035 Z-41.969
    N13786 X25.092 Z-42.672
    N13787 X24.148 Z-43.334
    N13788 X23.205 Z-43.96
    N13789 X22.262 Z-44.551
    N13790 X21.345 Z-45.094
    N13791 X19.513 Z-46.09
    N13792 X17.658 Z-46.984
    N13793 X15.783 Z-47.781
    N13794 X14.845 Z-48.14
    N13795 X13.001 Z-48.775
    N13796 X11.158 Z-49.318
    N13797 X9.273 Z-49.782
    N13798 X7.422 Z-50.151
    N13799 X5.554 Z-50.437
    N13800 X3.719 Z-50.637
    N13801 X1.862 Z-50.759
    N13802 X0. Z-50.8
    N13803 X-1.862 Z-50.759
    N13804 X-3.719 Z-50.637
    N13805 X-5.554 Z-50.437
    N13806 X-7.422 Z-50.151
    N13807 X-9.273 Z-49.782
    N13808 X-11.158 Z-49.318
    N13809 X-13.001 Z-48.775
    N13810 X-14.845 Z-48.14
    N13811 X-16.721 Z-47.395
    N13812 X-18.596 Z-46.545
    N13813 X-20.429 Z-45.606
    N13814 X-21.345 Z-45.094
    N13815 X-22.262 Z-44.551
    N13816 X-23.205 Z-43.96
    N13817 X-24.148 Z-43.334
    N13818 X-25.092 Z-42.672
    N13819 X-26.035 Z-41.969
    N13820 X-26.939 Z-41.256
    N13821 X-27.843 Z-40.502
    N13822 X-28.746 Z-39.704
    N13823 X-29.65 Z-38.861
    N13824 X-30.606 Z-37.915
    N13825 X-31.562 Z-36.905
    N13826 X-32.518 Z-35.823
    N13827 X-33.474 Z-34.669
    N13828 X-34.868 Z-32.817
    N13829 X-35.798 Z-31.453
    N13830 X-36.263 Z-30.727
    N13831 X-38.123 Z-27.641
    N13832 X-40.912 Z-23.154
    N13833 X-42.772 Z-20.047
    N13834 X-43.702 Z-18.367
    N13835 X-44.631 Z-16.528
    N13836 X-45.445 Z-14.675
    N13837 X-45.794 Z-13.751
    N13838 X-46.317 Z-12.087
    N13839 X-46.527 Z-11.218
    N13840 X-46.84 Z-9.698
    N13841 X-46.956 Z-9.35
    N13842 X-47.188 Z-8.818
    N13843 X-47.421 Z-8.416
    N13844 X-47.653 Z-8.075
    N13845 X-48.118 Z-7.547
    N13846 X-48.351 Z-7.333
    N13847 X-48.816 Z-6.984
    N13848 X-49.281 Z-6.72
    N13849 X-49.745 Z-6.523
    N13850 X-50.21 Z-6.393
    N13851 X-50.675 Z-6.327
    N13852 X-120.121 Z-6.299
    N13853 X-120.412 Z-5.739
    N13854 X-120.877 Z-4.981
    N13855 X-121.342 Z-4.335
    N13856 X-121.807 Z-3.769
    N13857 X-122.272 Z-3.278
    N13858 X-122.736 Z-2.837
    N13859 X-123.201 Z-2.444
    N13860 X-123.666 Z-2.094
    N13861 X-124.131 Z-1.776
    N13862 X-125.061 Z-1.24
    N13863 X-125.526 Z-1.015
    N13864 X-126.456 Z-.638
    N13865 X-127.386 Z-.354
    N13866 X-128.315 Z-.156
    N13867 X-129.245 Z-.039
    N13868 X-130.175 Z0.
    N13869 Y-45.025
    N13870 X-129.245 Z-.039
    N13871 X-128.315 Z-.156
    N13872 X-127.386 Z-.354
    N13873 X-126.456 Z-.638
    N13874 X-125.526 Z-1.015
    N13875 X-125.061 Z-1.24
    N13876 X-124.131 Z-1.776
    N13877 X-123.666 Z-2.094
    N13878 X-123.201 Z-2.444
    N13879 X-122.736 Z-2.837
    N13880 X-122.215 Z-3.337
    N13881 X-121.694 Z-3.899
    N13882 X-121.303 Z-4.365
    N13883 X-51.14 Z-4.37
    N13884 X-50.675 Z-4.405
    N13885 X-50.21 Z-4.483
    N13886 X-49.745 Z-4.608
    N13887 X-49.281 Z-4.767
    N13888 X-48.816 Z-4.967
    N13889 X-48.351 Z-5.224
    N13890 X-47.886 Z-5.537
    N13891 X-47.421 Z-5.901
    N13892 X-46.956 Z-6.353
    N13893 X-46.724 Z-6.613
    N13894 X-46.259 Z-7.231
    N13895 X-46.026 Z-7.61
    N13896 X-45.794 Z-8.043
    N13897 X-45.561 Z-8.575
    N13898 X-45.445 Z-8.898
    N13899 X-45.271 Z-9.505
    N13900 X-44.864 Z-11.947
    N13901 X-44.439 Z-13.731
    N13902 X-43.861 Z-15.569
    N13903 X-43.42 Z-16.749
    N13904 X-42.72 Z-18.432
    N13905 X-41.945 Z-20.111
    N13906 X-40.912 Z-22.186
    N13907 X-37.532 Z-28.567
    N13908 X-36.611 Z-30.166
    N13909 X-35.996 Z-31.153
    N13910 X-35.366 Z-32.104
    N13911 X-34.735 Z-33.003
    N13912 X-33.474 Z-34.669
    N13913 X-32.518 Z-35.823
    N13914 X-31.562 Z-36.905
    N13915 X-30.606 Z-37.915
    N13916 X-29.65 Z-38.861
    N13917 X-28.746 Z-39.704
    N13918 X-27.843 Z-40.502
    N13919 X-26.939 Z-41.256
    N13920 X-26.035 Z-41.969
    N13921 X-25.092 Z-42.672
    N13922 X-24.148 Z-43.334
    N13923 X-23.205 Z-43.96
    N13924 X-22.262 Z-44.551
    N13925 X-21.345 Z-45.094
    N13926 X-20.429 Z-45.606
    N13927 X-18.596 Z-46.545
    N13928 X-16.721 Z-47.395
    N13929 X-14.845 Z-48.14
    N13930 X-13.001 Z-48.775
    N13931 X-11.158 Z-49.318
    N13932 X-9.273 Z-49.782
    N13933 X-7.422 Z-50.151
    N13934 X-5.554 Z-50.437
    N13935 X-3.719 Z-50.637
    N13936 X-1.862 Z-50.759
    N13937 X0. Z-50.8
    N13938 X1.862 Z-50.759
    N13939 X3.719 Z-50.637
    N13940 X5.554 Z-50.437
    N13941 X7.422 Z-50.151
    N13942 X9.273 Z-49.782
    N13943 X11.158 Z-49.318
    N13944 X13.001 Z-48.775
    N13945 X14.845 Z-48.14
    N13946 X15.783 Z-47.781
    N13947 X17.658 Z-46.984
    N13948 X19.513 Z-46.09
    N13949 X21.345 Z-45.094
    N13950 X22.262 Z-44.551
    N13951 X23.205 Z-43.96
    N13952 X24.148 Z-43.334
    N13953 X25.092 Z-42.672
    N13954 X26.035 Z-41.969
    N13955 X26.939 Z-41.256
    N13956 X27.843 Z-40.502
    N13957 X28.746 Z-39.704
    N13958 X29.65 Z-38.861
    N13959 X30.606 Z-37.915
    N13960 X31.562 Z-36.905
    N13961 X32.518 Z-35.823
    N13962 X33.474 Z-34.669
    N13963 X34.735 Z-33.003
    N13964 X35.366 Z-32.104
    N13965 X35.996 Z-31.153
    N13966 X36.611 Z-30.166
    N13967 X37.225 Z-29.115
    N13968 X39.683 Z-24.52
    N13969 X41.429 Z-21.167
    N13970 X42.462 Z-19.004
    N13971 X43.199 Z-17.306
    N13972 X43.861 Z-15.569
    N13973 X44.15 Z-14.705
    N13974 X44.631 Z-12.996
    N13975 X44.98 Z-11.308
    N13976 X45.154 Z-10.11
    N13977 X45.329 Z-9.282
    N13978 X45.561 Z-8.575
    N13979 X45.794 Z-8.043
    N13980 X46.026 Z-7.61
    N13981 X46.259 Z-7.231
    N13982 X46.491 Z-6.907
    N13983 X46.956 Z-6.353
    N13984 X47.421 Z-5.901
    N13985 X47.886 Z-5.537
    N13986 X48.351 Z-5.225
    N13987 X48.816 Z-4.967
    N13988 X49.281 Z-4.767
    N13989 X49.745 Z-4.608
    N13990 X50.21 Z-4.483
    N13991 X50.675 Z-4.405
    N13992 X51.14 Z-4.37
    N13993 X121.303 Z-4.365
    N13994 X121.694 Z-3.899
    N13995 X122.215 Z-3.337
    N13996 X122.736 Z-2.837
    N13997 X123.201 Z-2.444
    N13998 X123.666 Z-2.094
    N13999 X124.131 Z-1.776
    N14000 X125.061 Z-1.24
    N14001 X125.526 Z-1.015
    N14002 X126.456 Z-.638
    N14003 X127.386 Z-.354
    N14004 X128.315 Z-.156
    N14005 X129.245 Z-.039
    N14006 X130.175 Z0.
    N14007 Y-46.225
    N14008 X129.245 Z-.039
    N14009 X128.315 Z-.156
    N14010 X127.386 Z-.354
    N14011 X126.456 Z-.638
    N14012 X125.526 Z-1.015
    N14013 X125.061 Z-1.24
    N14014 X124.131 Z-1.776
    N14015 X123.666 Z-2.094
    N14016 X123.201 Z-2.444
    N14017 X122.504 Z-3.035
    N14018 X52.07 Z-3.036
    N14019 X51.14 Z-3.06
    N14020 X50.21 Z-3.202
    N14021 X49.745 Z-3.32
    N14022 X49.281 Z-3.479
    N14023 X48.816 Z-3.666
    N14024 X48.351 Z-3.89
    N14025 X47.886 Z-4.165
    N14026 X47.421 Z-4.477
    N14027 X46.956 Z-4.842
    N14028 X46.491 Z-5.282
    N14029 X46.026 Z-5.78
    N14030 X45.561 Z-6.391
    N14031 X45.096 Z-7.148
    N14032 X44.748 Z-7.873
    N14033 X44.456 Z-8.671
    N14034 X44.238 Z-9.542
    N14035 X43.844 Z-12.297
    N14036 X43.319 Z-14.661
    N14037 X42.767 Z-16.529
    N14038 X41.985 Z-18.729
    N14039 X41.355 Z-20.315
    N14040 X40.364 Z-22.615
    N14041 X38.72 Z-26.229
    N14042 X38.172 Z-27.352
    N14043 X37.624 Z-28.4
    N14044 X37.076 Z-29.382
    N14045 X36.146 Z-30.914
    N14046 X35.382 Z-32.08
    N14047 X34.237 Z-33.681
    N14048 X32.996 Z-35.256
    N14049 X31.562 Z-36.905
    N14050 X30.606 Z-37.915
    N14051 X29.65 Z-38.861
    N14052 X28.746 Z-39.704
    N14053 X27.843 Z-40.502
    N14054 X26.939 Z-41.256
    N14055 X26.035 Z-41.969
    N14056 X25.092 Z-42.672
    N14057 X24.148 Z-43.334
    N14058 X23.205 Z-43.96
    N14059 X22.262 Z-44.551
    N14060 X21.345 Z-45.094
    N14061 X19.513 Z-46.09
    N14062 X17.658 Z-46.984
    N14063 X15.783 Z-47.781
    N14064 X14.845 Z-48.14
    N14065 X13.001 Z-48.775
    N14066 X11.158 Z-49.318
    N14067 X9.273 Z-49.782
    N14068 X7.422 Z-50.151
    N14069 X5.554 Z-50.437
    N14070 X3.719 Z-50.637
    N14071 X1.862 Z-50.759
    N14072 X0. Z-50.8
    N14073 X-1.862 Z-50.759
    N14074 X-3.719 Z-50.637
    N14075 X-5.554 Z-50.437
    N14076 X-7.422 Z-50.151
    N14077 X-9.273 Z-49.782
    N14078 X-11.158 Z-49.318
    N14079 X-13.001 Z-48.775
    N14080 X-14.845 Z-48.14
    N14081 X-16.721 Z-47.395
    N14082 X-18.596 Z-46.545
    N14083 X-20.429 Z-45.606
    N14084 X-21.345 Z-45.094
    N14085 X-22.262 Z-44.551
    N14086 X-23.205 Z-43.96
    N14087 X-24.148 Z-43.334
    N14088 X-25.092 Z-42.672
    N14089 X-26.035 Z-41.969
    N14090 X-26.939 Z-41.256
    N14091 X-27.843 Z-40.502
    N14092 X-28.746 Z-39.704
    N14093 X-29.65 Z-38.861
    N14094 X-30.606 Z-37.915
    N14095 X-31.562 Z-36.905
    N14096 X-32.518 Z-35.823
    N14097 X-33.474 Z-34.669
    N14098 X-34.237 Z-33.681
    N14099 X-35.382 Z-32.08
    N14100 X-36.528 Z-30.304
    N14101 X-37.076 Z-29.382
    N14102 X-37.624 Z-28.4
    N14103 X-38.446 Z-26.803
    N14104 X-40.364 Z-22.615
    N14105 X-41.355 Z-20.315
    N14106 X-41.985 Z-18.729
    N14107 X-42.767 Z-16.529
    N14108 X-43.494 Z-13.968
    N14109 X-43.888 Z-12.062
    N14110 X-44.019 Z-11.2
    N14111 X-44.238 Z-9.542
    N14112 X-44.456 Z-8.671
    N14113 X-44.748 Z-7.873
    N14114 X-45.096 Z-7.148
    N14115 X-45.561 Z-6.391
    N14116 X-46.026 Z-5.78
    N14117 X-46.491 Z-5.282
    N14118 X-46.956 Z-4.842
    N14119 X-47.421 Z-4.477
    N14120 X-47.886 Z-4.165
    N14121 X-48.351 Z-3.89
    N14122 X-48.816 Z-3.666
    N14123 X-49.281 Z-3.479
    N14124 X-49.745 Z-3.32
    N14125 X-50.21 Z-3.202
    N14126 X-51.14 Z-3.06
    N14127 X-52.07 Z-3.036
    N14128 X-122.504 Z-3.035
    N14129 X-123.201 Z-2.444
    N14130 X-123.666 Z-2.094
    N14131 X-124.131 Z-1.776
    N14132 X-125.061 Z-1.24
    N14133 X-125.526 Z-1.015
    N14134 X-126.456 Z-.638
    N14135 X-127.386 Z-.354
    N14136 X-128.315 Z-.156
    N14137 X-129.245 Z-.039
    N14138 X-130.175 Z0.
    N14139 Y-47.425
    N14140 X-129.245 Z-.039
    N14141 X-128.315 Z-.156
    N14142 X-127.386 Z-.354
    N14143 X-126.456 Z-.638
    N14144 X-125.526 Z-1.015
    N14145 X-125.061 Z-1.24
    N14146 X-124.098 Z-1.798
    N14147 X-123.724 Z-2.053
    N14148 X-52.07 Z-2.057
    N14149 X-51.14 Z-2.107
    N14150 X-50.675 Z-2.177
    N14151 X-49.745 Z-2.395
    N14152 X-49.281 Z-2.551
    N14153 X-48.351 Z-2.953
    N14154 X-47.886 Z-3.211
    N14155 X-47.421 Z-3.504
    N14156 X-46.956 Z-3.837
    N14157 X-46.491 Z-4.231
    N14158 X-46.026 Z-4.669
    N14159 X-45.794 Z-4.918
    N14160 X-45.096 Z-5.795
    N14161 X-44.631 Z-6.53
    N14162 X-44.399 Z-6.97
    N14163 X-44.167 Z-7.47
    N14164 X-43.934 Z-8.07
    N14165 X-43.702 Z-8.844
    N14166 X-43.527 Z-9.693
    N14167 X-43.353 Z-11.263
    N14168 X-43.12 Z-12.861
    N14169 X-42.772 Z-14.612
    N14170 X-42.307 Z-16.46
    N14171 X-41.61 Z-18.764
    N14172 X-40.912 Z-20.782
    N14173 X-39.884 Z-23.52
    N14174 X-39.369 Z-24.787
    N14175 X-38.855 Z-25.94
    N14176 X-38.341 Z-27.013
    N14177 X-37.57 Z-28.501
    N14178 X-36.798 Z-29.85
    N14179 X-35.967 Z-31.197
    N14180 X-34.72 Z-33.023
    N14181 X-33.474 Z-34.669
    N14182 X-32.518 Z-35.823
    N14183 X-31.562 Z-36.905
    N14184 X-30.606 Z-37.915
    N14185 X-29.65 Z-38.861
    N14186 X-28.746 Z-39.704
    N14187 X-27.843 Z-40.502
    N14188 X-26.939 Z-41.256
    N14189 X-26.035 Z-41.969
    N14190 X-25.092 Z-42.672
    N14191 X-24.148 Z-43.334
    N14192 X-23.205 Z-43.96
    N14193 X-22.262 Z-44.551
    N14194 X-21.345 Z-45.094
    N14195 X-20.429 Z-45.606
    N14196 X-18.596 Z-46.545
    N14197 X-16.721 Z-47.395
    N14198 X-14.845 Z-48.14
    N14199 X-13.001 Z-48.775
    N14200 X-11.158 Z-49.318
    N14201 X-9.273 Z-49.782
    N14202 X-7.422 Z-50.151
    N14203 X-5.554 Z-50.437
    N14204 X-3.719 Z-50.637
    N14205 X-1.862 Z-50.759
    N14206 X0. Z-50.8
    N14207 X1.862 Z-50.759
    N14208 X3.719 Z-50.637
    N14209 X5.554 Z-50.437
    N14210 X7.422 Z-50.151
    N14211 X9.273 Z-49.782
    N14212 X11.158 Z-49.318
    N14213 X13.001 Z-48.775
    N14214 X14.845 Z-48.14
    N14215 X15.783 Z-47.781
    N14216 X17.658 Z-46.984
    N14217 X19.513 Z-46.09
    N14218 X21.345 Z-45.094
    N14219 X22.262 Z-44.551
    N14220 X23.205 Z-43.96
    N14221 X24.148 Z-43.334
    N14222 X25.092 Z-42.672
    N14223 X26.035 Z-41.969
    N14224 X26.939 Z-41.256
    N14225 X27.843 Z-40.502
    N14226 X28.746 Z-39.704
    N14227 X29.65 Z-38.861
    N14228 X30.606 Z-37.915
    N14229 X31.562 Z-36.905
    N14230 X32.518 Z-35.823
    N14231 X33.474 Z-34.669
    N14232 X34.72 Z-33.023
    N14233 X35.967 Z-31.197
    N14234 X36.798 Z-29.85
    N14235 X37.313 Z-28.959
    N14236 X38.084 Z-27.529
    N14237 X38.855 Z-25.94
    N14238 X39.627 Z-24.164
    N14239 X40.912 Z-20.782
    N14240 X41.377 Z-19.455
    N14241 X41.842 Z-18.033
    N14242 X42.539 Z-15.584
    N14243 X42.888 Z-14.082
    N14244 X43.237 Z-12.143
    N14245 X43.527 Z-9.693
    N14246 X43.702 Z-8.844
    N14247 X43.934 Z-8.07
    N14248 X44.167 Z-7.47
    N14249 X44.399 Z-6.97
    N14250 X44.631 Z-6.53
    N14251 X45.096 Z-5.795
    N14252 X45.561 Z-5.193
    N14253 X46.026 Z-4.669
    N14254 X46.491 Z-4.231
    N14255 X46.956 Z-3.837
    N14256 X47.421 Z-3.503
    N14257 X47.886 Z-3.211
    N14258 X48.351 Z-2.953
    N14259 X49.281 Z-2.551
    N14260 X49.745 Z-2.395
    N14261 X50.675 Z-2.177
    N14262 X51.14 Z-2.107
    N14263 X52.07 Z-2.057
    N14264 X123.724 Z-2.053
    N14265 X124.098 Z-1.798
    N14266 X125.061 Z-1.24
    N14267 X125.526 Z-1.015
    N14268 X126.456 Z-.638
    N14269 X127.386 Z-.354
    N14270 X128.315 Z-.156
    N14271 X129.245 Z-.039
    N14272 X130.175 Z0.
    N14273 Y-48.625
    N14274 X129.245 Z-.039
    N14275 X128.315 Z-.156
    N14276 X127.386 Z-.354
    N14277 X126.456 Z-.638
    N14278 X125.589 Z-.987
    N14279 X124.938 Z-1.306
    N14280 X52.07 Z-1.32
    N14281 X51.14 Z-1.404
    N14282 X50.675 Z-1.484
    N14283 X49.745 Z-1.721
    N14284 X49.281 Z-1.881
    N14285 X48.351 Z-2.286
    N14286 X47.421 Z-2.824
    N14287 X46.956 Z-3.149
    N14288 X46.491 Z-3.523
    N14289 X46.026 Z-3.937
    N14290 X45.561 Z-4.426
    N14291 X45.096 Z-4.972
    N14292 X44.399 Z-5.995
    N14293 X43.934 Z-6.873
    N14294 X43.585 Z-7.721
    N14295 X43.353 Z-8.452
    N14296 X43.12 Z-9.501
    N14297 X42.714 Z-13.008
    N14298 X42.307 Z-15.252
    N14299 X41.842 Z-17.255
    N14300 X41.145 Z-19.79
    N14301 X40.658 Z-21.359
    N14302 X40.151 Z-22.822
    N14303 X39.389 Z-24.742
    N14304 X38.881 Z-25.885
    N14305 X38.373 Z-26.948
    N14306 X37.866 Z-27.943
    N14307 X36.85 Z-29.762
    N14308 X36.006 Z-31.137
    N14309 X34.74 Z-32.997
    N14310 X33.474 Z-34.669
    N14311 X32.518 Z-35.823
    N14312 X31.562 Z-36.905
    N14313 X30.606 Z-37.915
    N14314 X29.65 Z-38.861
    N14315 X28.746 Z-39.704
    N14316 X27.843 Z-40.502
    N14317 X26.939 Z-41.256
    N14318 X26.035 Z-41.969
    N14319 X25.092 Z-42.672
    N14320 X24.148 Z-43.334
    N14321 X23.205 Z-43.96
    N14322 X22.262 Z-44.551
    N14323 X21.345 Z-45.094
    N14324 X19.513 Z-46.09
    N14325 X17.658 Z-46.984
    N14326 X15.783 Z-47.781
    N14327 X14.845 Z-48.14
    N14328 X13.001 Z-48.775
    N14329 X11.158 Z-49.318
    N14330 X9.273 Z-49.782
    N14331 X7.422 Z-50.151
    N14332 X5.554 Z-50.437
    N14333 X3.719 Z-50.637
    N14334 X1.862 Z-50.759
    N14335 X0. Z-50.8
    N14336 X-1.862 Z-50.759
    N14337 X-3.719 Z-50.637
    N14338 X-5.554 Z-50.437
    N14339 X-7.422 Z-50.151
    N14340 X-9.273 Z-49.782
    N14341 X-11.158 Z-49.318
    N14342 X-13.001 Z-48.775
    N14343 X-14.845 Z-48.14
    N14344 X-16.721 Z-47.395
    N14345 X-18.596 Z-46.545
    N14346 X-20.429 Z-45.606
    N14347 X-21.345 Z-45.094
    N14348 X-22.262 Z-44.551
    N14349 X-23.205 Z-43.96
    N14350 X-24.148 Z-43.334
    N14351 X-25.092 Z-42.672
    N14352 X-26.035 Z-41.969
    N14353 X-26.939 Z-41.256
    N14354 X-27.843 Z-40.502
    N14355 X-28.746 Z-39.704
    N14356 X-29.65 Z-38.861
    N14357 X-30.606 Z-37.915
    N14358 X-31.562 Z-36.905
    N14359 X-32.996 Z-35.256
    N14360 X-33.474 Z-34.669
    N14361 X-34.74 Z-32.997
    N14362 X-36.006 Z-31.137
    N14363 X-36.85 Z-29.762
    N14364 X-37.866 Z-27.943
    N14365 X-38.373 Z-26.948
    N14366 X-38.881 Z-25.885
    N14367 X-39.389 Z-24.742
    N14368 X-40.151 Z-22.822
    N14369 X-40.912 Z-20.56
    N14370 X-41.61 Z-18.145
    N14371 X-42.191 Z-15.794
    N14372 X-42.539 Z-14.07
    N14373 X-42.83 Z-12.182
    N14374 X-43.12 Z-9.501
    N14375 X-43.237 Z-8.908
    N14376 X-43.469 Z-8.06
    N14377 X-43.702 Z-7.412
    N14378 X-43.934 Z-6.873
    N14379 X-44.399 Z-5.995
    N14380 X-44.864 Z-5.287
    N14381 X-45.096 Z-4.972
    N14382 X-45.561 Z-4.426
    N14383 X-46.026 Z-3.937
    N14384 X-46.491 Z-3.523
    N14385 X-46.956 Z-3.149
    N14386 X-47.421 Z-2.824
    N14387 X-48.351 Z-2.286
    N14388 X-49.281 Z-1.881
    N14389 X-49.745 Z-1.721
    N14390 X-50.675 Z-1.484
    N14391 X-51.14 Z-1.404
    N14392 X-52.07 Z-1.32
    N14393 X-124.721 Z-1.316
    N14394 X-126.456 Z-.638
    N14395 X-127.386 Z-.354
    N14396 X-128.315 Z-.156
    N14397 X-129.245 Z-.039
    N14398 X-130.175 Z0.
    N14399 Y-49.825
    N14400 X-129.245 Z-.039
    N14401 X-128.315 Z-.156
    N14402 X-127.386 Z-.354
    N14403 X-126.107 Z-.762
    N14404 X-55.789 Z-.765
    N14405 X-52.07 Z-.786
    N14406 X-51.14 Z-.899
    N14407 X-50.675 Z-.99
    N14408 X-49.745 Z-1.247
    N14409 X-49.281 Z-1.415
    N14410 X-48.351 Z-1.831
    N14411 X-47.421 Z-2.374
    N14412 X-46.956 Z-2.703
    N14413 X-46.491 Z-3.068
    N14414 X-46.026 Z-3.483
    N14415 X-45.561 Z-3.954
    N14416 X-45.096 Z-4.491
    N14417 X-44.631 Z-5.113
    N14418 X-44.399 Z-5.464
    N14419 X-43.934 Z-6.279
    N14420 X-43.585 Z-7.028
    N14421 X-43.237 Z-7.991
    N14422 X-43.004 Z-8.873
    N14423 X-42.888 Z-9.495
    N14424 X-42.656 Z-11.894
    N14425 X-42.191 Z-15.213
    N14426 X-41.842 Z-16.996
    N14427 X-41.377 Z-18.938
    N14428 X-40.912 Z-20.56
    N14429 X-40.151 Z-22.822
    N14430 X-39.389 Z-24.742
    N14431 X-38.881 Z-25.885
    N14432 X-38.373 Z-26.948
    N14433 X-37.866 Z-27.943
    N14434 X-36.85 Z-29.762
    N14435 X-36.006 Z-31.137
    N14436 X-34.74 Z-32.997
    N14437 X-33.474 Z-34.669
    N14438 X-32.518 Z-35.823
    N14439 X-31.562 Z-36.905
    N14440 X-30.606 Z-37.915
    N14441 X-29.65 Z-38.861
    N14442 X-28.746 Z-39.704
    N14443 X-27.843 Z-40.502
    N14444 X-26.939 Z-41.256
    N14445 X-26.035 Z-41.969
    N14446 X-25.092 Z-42.672
    N14447 X-24.148 Z-43.334
    N14448 X-23.205 Z-43.96
    N14449 X-22.262 Z-44.551
    N14450 X-21.345 Z-45.094
    N14451 X-20.429 Z-45.606
    N14452 X-18.596 Z-46.545
    N14453 X-16.721 Z-47.395
    N14454 X-14.845 Z-48.14
    N14455 X-13.001 Z-48.775
    N14456 X-11.158 Z-49.318
    N14457 X-9.273 Z-49.782
    N14458 X-7.422 Z-50.151
    N14459 X-5.554 Z-50.437
    N14460 X-3.719 Z-50.637
    N14461 X-1.862 Z-50.759
    N14462 X0. Z-50.8
    N14463 X1.862 Z-50.759
    N14464 X3.719 Z-50.637
    N14465 X5.554 Z-50.437
    N14466 X7.422 Z-50.151
    N14467 X9.273 Z-49.782
    N14468 X11.158 Z-49.318
    N14469 X13.001 Z-48.775
    N14470 X14.845 Z-48.14
    N14471 X15.783 Z-47.781
    N14472 X17.658 Z-46.984
    N14473 X19.513 Z-46.09
    N14474 X21.345 Z-45.094
    N14475 X22.262 Z-44.551
    N14476 X23.205 Z-43.96
    N14477 X24.148 Z-43.334
    N14478 X25.092 Z-42.672
    N14479 X26.035 Z-41.969
    N14480 X26.939 Z-41.256
    N14481 X27.843 Z-40.502
    N14482 X28.746 Z-39.704
    N14483 X29.65 Z-38.861
    N14484 X30.606 Z-37.915
    N14485 X31.562 Z-36.905
    N14486 X32.518 Z-35.823
    N14487 X33.474 Z-34.669
    N14488 X34.74 Z-32.997
    N14489 X36.006 Z-31.137
    N14490 X36.85 Z-29.762
    N14491 X37.866 Z-27.943
    N14492 X38.373 Z-26.948
    N14493 X38.881 Z-25.885
    N14494 X39.389 Z-24.742
    N14495 X40.151 Z-22.822
    N14496 X40.658 Z-21.359
    N14497 X41.377 Z-18.938
    N14498 X41.842 Z-16.996
    N14499 X42.307 Z-14.517
    N14500 X42.597 Z-12.443
    N14501 X42.801 Z-10.197
    N14502 X42.946 Z-9.154
    N14503 X43.237 Z-7.991
    N14504 X43.585 Z-7.028
    N14505 X43.934 Z-6.279
    N14506 X44.167 Z-5.86
    N14507 X44.631 Z-5.113
    N14508 X45.096 Z-4.492
    N14509 X45.561 Z-3.954
    N14510 X46.026 Z-3.483
    N14511 X46.491 Z-3.068
    N14512 X46.956 Z-2.703
    N14513 X47.421 Z-2.374
    N14514 X48.351 Z-1.831
    N14515 X48.816 Z-1.611
    N14516 X49.745 Z-1.247
    N14517 X50.675 Z-.99
    N14518 X51.14 Z-.899
    N14519 X52.07 Z-.786
    N14520 X55.789 Z-.765
    N14521 X126.107 Z-.762
    N14522 X127.386 Z-.354
    N14523 X128.315 Z-.156
    N14524 X129.245 Z-.039
    N14525 X130.175 Z0.
    N14526 X130.165 Y-51.025
    N14527 X129.058 Z-.055
    N14528 X128.505 Z-.126
    N14529 X127.952 Z-.223
    N14530 X127.289 Z-.37
    N14531 X52.996 Z-.373
    N14532 X52.066 Z-.423
    N14533 X51.136 Z-.564
    N14534 X50.671 Z-.668
    N14535 X49.741 Z-.948
    N14536 X48.812 Z-1.332
    N14537 X48.347 Z-1.565
    N14538 X47.417 Z-2.126
    N14539 X46.952 Z-2.465
    N14540 X46.487 Z-2.837
    N14541 X46.022 Z-3.265
    N14542 X45.558 Z-3.739
    N14543 X44.86 Z-4.588
    N14544 X44.628 Z-4.918
    N14545 X44.163 Z-5.66
    N14546 X43.582 Z-6.839
    N14547 X43.233 Z-7.788
    N14548 X43.001 Z-8.627
    N14549 X42.797 Z-9.755
    N14550 X42.478 Z-13.23
    N14551 X42.187 Z-15.213
    N14552 X41.839 Z-17.013
    N14553 X41.374 Z-18.951
    N14554 X40.655 Z-21.368
    N14555 X40.147 Z-22.831
    N14556 X39.386 Z-24.749
    N14557 X38.878 Z-25.891
    N14558 X38.371 Z-26.954
    N14559 X37.863 Z-27.948
    N14560 X36.848 Z-29.766
    N14561 X36.004 Z-31.141
    N14562 X34.737 Z-33.
    N14563 X33.471 Z-34.672
    N14564 X32.515 Z-35.826
    N14565 X31.56 Z-36.908
    N14566 X30.604 Z-37.917
    N14567 X29.648 Z-38.863
    N14568 X28.744 Z-39.706
    N14569 X27.841 Z-40.503
    N14570 X26.937 Z-41.257
    N14571 X26.033 Z-41.971
    N14572 X25.09 Z-42.674
    N14573 X24.146 Z-43.336
    N14574 X23.203 Z-43.961
    N14575 X22.26 Z-44.552
    N14576 X21.343 Z-45.095
    N14577 X19.511 Z-46.09
    N14578 X17.657 Z-46.985
    N14579 X15.781 Z-47.781
    N14580 X13.922 Z-48.47
    N14581 X13. Z-48.775
    N14582 X11.157 Z-49.318
    N14583 X9.272 Z-49.782
    N14584 X7.421 Z-50.151
    N14585 X5.553 Z-50.438
    N14586 X3.719 Z-50.637
    N14587 X1.861 Z-50.759
    N14588 X0. Z-50.8
    N14589 X-1.861 Z-50.759
    N14590 X-3.719 Z-50.637
    N14591 X-5.553 Z-50.438
    N14592 X-7.421 Z-50.151
    N14593 X-9.272 Z-49.782
    N14594 X-11.157 Z-49.318
    N14595 X-13. Z-48.775
    N14596 X-14.844 Z-48.14
    N14597 X-16.719 Z-47.396
    N14598 X-18.595 Z-46.546
    N14599 X-20.427 Z-45.607
    N14600 X-21.343 Z-45.095
    N14601 X-22.26 Z-44.552
    N14602 X-23.203 Z-43.961
    N14603 X-24.146 Z-43.336
    N14604 X-25.09 Z-42.674
    N14605 X-26.033 Z-41.971
    N14606 X-26.937 Z-41.257
    N14607 X-27.841 Z-40.503
    N14608 X-28.744 Z-39.706
    N14609 X-29.648 Z-38.863
    N14610 X-30.604 Z-37.917
    N14611 X-31.56 Z-36.908
    N14612 X-32.515 Z-35.826
    N14613 X-33.471 Z-34.672
    N14614 X-34.737 Z-33.
    N14615 X-36.004 Z-31.141
    N14616 X-36.848 Z-29.766
    N14617 X-37.863 Z-27.948
    N14618 X-38.371 Z-26.954
    N14619 X-38.878 Z-25.891
    N14620 X-39.64 Z-24.132
    N14621 X-40.147 Z-22.831
    N14622 X-40.909 Z-20.571
    N14623 X-41.374 Z-18.951
    N14624 X-41.839 Z-17.013
    N14625 X-42.187 Z-15.213
    N14626 X-42.478 Z-13.23
    N14627 X-42.826 Z-9.551
    N14628 X-43.001 Z-8.627
    N14629 X-43.233 Z-7.788
    N14630 X-43.582 Z-6.839
    N14631 X-43.931 Z-6.096
    N14632 X-44.163 Z-5.66
    N14633 X-44.628 Z-4.918
    N14634 X-45.093 Z-4.29
    N14635 X-45.558 Z-3.739
    N14636 X-46.022 Z-3.265
    N14637 X-46.487 Z-2.837
    N14638 X-46.952 Z-2.465
    N14639 X-47.417 Z-2.126
    N14640 X-48.347 Z-1.565
    N14641 X-48.812 Z-1.332
    N14642 X-49.741 Z-.948
    N14643 X-50.671 Z-.668
    N14644 X-51.136 Z-.564
    N14645 X-52.066 Z-.423
    N14646 X-52.996 Z-.372
    N14647 X-127.289 Z-.37
    N14648 X-127.952 Z-.223
    N14649 X-128.505 Z-.126
    N14650 X-129.058 Z-.055
    N14651 X-130.165 Z0.
    N14652 X-129.925 Y-52.225
    N14653 X-127.777 Z-.118
    N14654 X-52.898 Z-.138
    N14655 X-51.97 Z-.226
    N14656 X-51.042 Z-.404
    N14657 X-50.114 Z-.675
    N14658 X-49.65 Z-.844
    N14659 X-48.722 Z-1.265
    N14660 X-47.794 Z-1.804
    N14661 X-46.866 Z-2.477
    N14662 X-46.402 Z-2.876
    N14663 X-45.938 Z-3.317
    N14664 X-45.474 Z-3.814
    N14665 X-45.01 Z-4.386
    N14666 X-44.546 Z-5.036
    N14667 X-44.082 Z-5.805
    N14668 X-43.618 Z-6.756
    N14669 X-43.386 Z-7.339
    N14670 X-43.038 Z-8.477
    N14671 X-42.806 Z-9.695
    N14672 X-42.574 Z-12.391
    N14673 X-42.342 Z-14.242
    N14674 X-41.994 Z-16.262
    N14675 X-41.646 Z-17.863
    N14676 X-41.065 Z-20.057
    N14677 X-40.581 Z-21.593
    N14678 X-40.076 Z-23.02
    N14679 X-39.318 Z-24.904
    N14680 X-38.813 Z-26.031
    N14681 X-38.055 Z-27.585
    N14682 X-36.792 Z-29.861
    N14683 X-35.946 Z-31.229
    N14684 X-35.1 Z-32.484
    N14685 X-34.255 Z-33.657
    N14686 X-33.409 Z-34.748
    N14687 X-32.458 Z-35.893
    N14688 X-31.506 Z-36.967
    N14689 X-30.554 Z-37.967
    N14690 X-29.603 Z-38.906
    N14691 X-28.698 Z-39.748
    N14692 X-27.794 Z-40.544
    N14693 X-26.889 Z-41.296
    N14694 X-25.985 Z-42.008
    N14695 X-25.042 Z-42.707
    N14696 X-24.098 Z-43.368
    N14697 X-23.155 Z-43.992
    N14698 X-22.212 Z-44.581
    N14699 X-21.299 Z-45.12
    N14700 X-20.386 Z-45.629
    N14701 X-18.561 Z-46.562
    N14702 X-16.689 Z-47.409
    N14703 X-14.816 Z-48.15
    N14704 X-12.976 Z-48.783
    N14705 X-11.136 Z-49.324
    N14706 X-9.254 Z-49.786
    N14707 X-7.405 Z-50.153
    N14708 X-5.538 Z-50.439
    N14709 X-3.712 Z-50.638
    N14710 X-1.858 Z-50.759
    N14711 X0. Z-50.8
    N14712 X1.858 Z-50.759
    N14713 X3.712 Z-50.638
    N14714 X5.538 Z-50.439
    N14715 X7.405 Z-50.153
    N14716 X9.254 Z-49.786
    N14717 X11.136 Z-49.324
    N14718 X12.976 Z-48.783
    N14719 X14.816 Z-48.15
    N14720 X15.752 Z-47.792
    N14721 X17.625 Z-46.999
    N14722 X19.473 Z-46.11
    N14723 X21.299 Z-45.12
    N14724 X22.212 Z-44.581
    N14725 X23.155 Z-43.992
    N14726 X24.098 Z-43.368
    N14727 X25.042 Z-42.707
    N14728 X25.985 Z-42.008
    N14729 X26.889 Z-41.296
    N14730 X27.794 Z-40.544
    N14731 X28.698 Z-39.748
    N14732 X29.603 Z-38.906
    N14733 X30.554 Z-37.967
    N14734 X31.506 Z-36.967
    N14735 X32.458 Z-35.893
    N14736 X33.409 Z-34.748
    N14737 X34.255 Z-33.657
    N14738 X35.523 Z-31.868
    N14739 X36.369 Z-30.558
    N14740 X37.297 Z-28.987
    N14741 X38.055 Z-27.585
    N14742 X39.065 Z-25.479
    N14743 X39.823 Z-23.678
    N14744 X40.581 Z-21.593
    N14745 X41.065 Z-20.057
    N14746 X41.53 Z-18.339
    N14747 X41.994 Z-16.262
    N14748 X42.342 Z-14.242
    N14749 X42.574 Z-12.391
    N14750 X42.777 Z-9.927
    N14751 X42.98 Z-8.721
    N14752 X43.27 Z-7.676
    N14753 X43.618 Z-6.756
    N14754 X44.082 Z-5.805
    N14755 X44.314 Z-5.407
    N14756 X44.778 Z-4.695
    N14757 X45.474 Z-3.814
    N14758 X45.938 Z-3.317
    N14759 X46.402 Z-2.876
    N14760 X46.866 Z-2.477
    N14761 X47.794 Z-1.804
    N14762 X48.722 Z-1.265
    N14763 X49.65 Z-.844
    N14764 X50.114 Z-.675
    N14765 X51.042 Z-.404
    N14766 X51.97 Z-.226
    N14767 X52.898 Z-.138
    N14768 X53.826 Z-.124
    N14769 X127.784 Z-.118
    N14770 X129.925 Z0.
    N14771 X128.948 Y-53.425
    N14772 X60.682 Z-.012
    N14773 X53.096 Z-.03
    N14774 X52.148 Z-.135
    N14775 X51.2 Z-.327
    N14776 X50.252 Z-.606
    N14777 X49.304 Z-.981
    N14778 X48.356 Z-1.463
    N14779 X47.882 Z-1.748
    N14780 X47.407 Z-2.069
    N14781 X46.933 Z-2.423
    N14782 X46.459 Z-2.825
    N14783 X45.985 Z-3.268
    N14784 X45.511 Z-3.772
    N14785 X44.8 Z-4.664
    N14786 X44.326 Z-5.387
    N14787 X44.089 Z-5.791
    N14788 X43.615 Z-6.762
    N14789 X43.259 Z-7.708
    N14790 X42.963 Z-8.798
    N14791 X42.785 Z-9.852
    N14792 X42.565 Z-12.466
    N14793 X42.328 Z-14.331
    N14794 X41.956 Z-16.446
    N14795 X41.363 Z-18.993
    N14796 X40.77 Z-21.019
    N14797 X40.059 Z-23.062
    N14798 X39.348 Z-24.835
    N14799 X38.874 Z-25.9
    N14800 X38.4 Z-26.895
    N14801 X37.926 Z-27.829
    N14802 X36.927 Z-29.632
    N14803 X35.928 Z-31.256
    N14804 X34.93 Z-32.729
    N14805 X33.482 Z-34.658
    N14806 X32.136 Z-36.267
    N14807 X31.238 Z-37.253
    N14808 X30.341 Z-38.182
    N14809 X29.378 Z-39.121
    N14810 X28.415 Z-40.005
    N14811 X27.453 Z-40.832
    N14812 X26.49 Z-41.613
    N14813 X25.556 Z-42.328
    N14814 X24.623 Z-43.003
    N14815 X23.689 Z-43.642
    N14816 X22.756 Z-44.246
    N14817 X21.795 Z-44.832
    N14818 X20.835 Z-45.384
    N14819 X19.875 Z-45.903
    N14820 X18.915 Z-46.392
    N14821 X17.043 Z-47.259
    N14822 X15.17 Z-48.02
    N14823 X13.234 Z-48.702
    N14824 X11.354 Z-49.265
    N14825 X9.438 Z-49.745
    N14826 X7.585 Z-50.121
    N14827 X5.678 Z-50.42
    N14828 X3.786 Z-50.631
    N14829 X1.882 Z-50.758
    N14830 X0. Z-50.8
    N14831 X-1.882 Z-50.758
    N14832 X-3.786 Z-50.631
    N14833 X-5.678 Z-50.42
    N14834 X-7.585 Z-50.121
    N14835 X-9.438 Z-49.745
    N14836 X-11.354 Z-49.265
    N14837 X-13.234 Z-48.702
    N14838 X-15.17 Z-48.02
    N14839 X-17.043 Z-47.259
    N14840 X-18.915 Z-46.392
    N14841 X-19.875 Z-45.903
    N14842 X-20.835 Z-45.384
    N14843 X-21.795 Z-44.832
    N14844 X-22.756 Z-44.246
    N14845 X-23.689 Z-43.642
    N14846 X-24.623 Z-43.003
    N14847 X-25.556 Z-42.328
    N14848 X-26.49 Z-41.613
    N14849 X-27.453 Z-40.832
    N14850 X-28.415 Z-40.005
    N14851 X-29.378 Z-39.121
    N14852 X-30.341 Z-38.182
    N14853 X-31.238 Z-37.253
    N14854 X-32.136 Z-36.267
    N14855 X-33.482 Z-34.658
    N14856 X-34.43 Z-33.418
    N14857 X-35.429 Z-32.011
    N14858 X-36.428 Z-30.464
    N14859 X-37.427 Z-28.756
    N14860 X-37.926 Z-27.829
    N14861 X-38.4 Z-26.895
    N14862 X-38.874 Z-25.9
    N14863 X-39.348 Z-24.835
    N14864 X-40.059 Z-23.062
    N14865 X-40.77 Z-21.019
    N14866 X-41.363 Z-18.993
    N14867 X-41.837 Z-17.02
    N14868 X-42.193 Z-15.179
    N14869 X-42.463 Z-13.351
    N14870 X-42.667 Z-11.358
    N14871 X-42.785 Z-9.852
    N14872 X-43.022 Z-8.538
    N14873 X-43.259 Z-7.708
    N14874 X-43.615 Z-6.762
    N14875 X-44.089 Z-5.791
    N14876 X-44.563 Z-5.009
    N14877 X-45.037 Z-4.351
    N14878 X-45.511 Z-3.772
    N14879 X-45.985 Z-3.268
    N14880 X-46.459 Z-2.825
    N14881 X-46.933 Z-2.423
    N14882 X-47.407 Z-2.069
    N14883 X-47.882 Z-1.748
    N14884 X-48.356 Z-1.463
    N14885 X-49.304 Z-.981
    N14886 X-50.252 Z-.606
    N14887 X-51.2 Z-.327
    N14888 X-52.148 Z-.135
    N14889 X-53.096 Z-.03
    N14890 X-128.948 Z0.
    N14891 X-53.882 Y-54.625
    N14892 X-52.984 Z-.036
    N14893 X-52.085 Z-.145
    N14894 X-51.187 Z-.33
    N14895 X-50.289 Z-.593
    N14896 X-49.391 Z-.942
    N14897 X-48.493 Z-1.385
    N14898 X-47.595 Z-1.936
    N14899 X-47.146 Z-2.26
    N14900 X-46.697 Z-2.617
    N14901 X-46.248 Z-3.014
    N14902 X-45.799 Z-3.462
    N14903 X-45.35 Z-3.957
    N14904 X-44.901 Z-4.527
    N14905 X-44.452 Z-5.184
    N14906 X-44.003 Z-5.952
    N14907 X-43.554 Z-6.906
    N14908 X-43.33 Z-7.496
    N14909 X-43.105 Z-8.22
    N14910 X-42.901 Z-9.104
    N14911 X-42.798 Z-9.748
    N14912 X-42.491 Z-13.111
    N14913 X-41.98 Z-16.328
    N14914 X-41.346 Z-19.058
    N14915 X-40.491 Z-21.866
    N14916 X-39.758 Z-23.846
    N14917 X-39.033 Z-25.551
    N14918 X-38.554 Z-26.583
    N14919 X-38.074 Z-27.548
    N14920 X-37.595 Z-28.455
    N14921 X-36.635 Z-30.125
    N14922 X-35.676 Z-31.638
    N14923 X-34.839 Z-32.859
    N14924 X-34.002 Z-33.989
    N14925 X-33.166 Z-35.047
    N14926 X-32.329 Z-36.043
    N14927 X-31.408 Z-37.073
    N14928 X-30.487 Z-38.035
    N14929 X-29.566 Z-38.941
    N14930 X-28.645 Z-39.796
    N14931 X-27.77 Z-40.565
    N14932 X-26.895 Z-41.292
    N14933 X-26.02 Z-41.981
    N14934 X-25.145 Z-42.634
    N14935 X-24.233 Z-43.278
    N14936 X-23.321 Z-43.886
    N14937 X-22.41 Z-44.462
    N14938 X-21.498 Z-45.007
    N14939 X-19.729 Z-45.98
    N14940 X-17.961 Z-46.848
    N14941 X-16.151 Z-47.634
    N14942 X-14.342 Z-48.323
    N14943 X-12.559 Z-48.913
    N14944 X-10.776 Z-49.418
    N14945 X-8.958 Z-49.849
    N14946 X-7.169 Z-50.192
    N14947 X-5.362 Z-50.46
    N14948 X-3.592 Z-50.648
    N14949 X-1.797 Z-50.761
    N14950 X0. Z-50.8
    N14951 X1.797 Z-50.761
    N14952 X3.592 Z-50.648
    N14953 X5.362 Z-50.46
    N14954 X7.169 Z-50.192
    N14955 X8.958 Z-49.849
    N14956 X10.776 Z-49.418
    N14957 X12.559 Z-48.913
    N14958 X14.342 Z-48.323
    N14959 X16.151 Z-47.634
    N14960 X17.961 Z-46.848
    N14961 X18.845 Z-46.427
    N14962 X20.614 Z-45.507
    N14963 X22.41 Z-44.462
    N14964 X23.321 Z-43.886
    N14965 X24.233 Z-43.278
    N14966 X25.145 Z-42.634
    N14967 X26.02 Z-41.981
    N14968 X26.895 Z-41.292
    N14969 X27.77 Z-40.565
    N14970 X28.645 Z-39.796
    N14971 X29.566 Z-38.941
    N14972 X30.487 Z-38.035
    N14973 X31.408 Z-37.073
    N14974 X32.329 Z-36.043
    N14975 X33.166 Z-35.047
    N14976 X34.002 Z-33.989
    N14977 X34.839 Z-32.859
    N14978 X35.676 Z-31.638
    N14979 X36.156 Z-30.898
    N14980 X37.115 Z-29.312
    N14981 X38.074 Z-27.548
    N14982 X38.554 Z-26.583
    N14983 X39.033 Z-25.551
    N14984 X39.758 Z-23.846
    N14985 X40.491 Z-21.866
    N14986 X40.979 Z-20.339
    N14987 X41.571 Z-18.178
    N14988 X42.184 Z-15.229
    N14989 X42.44 Z-13.521
    N14990 X42.798 Z-9.748
    N14991 X43.003 Z-8.618
    N14992 X43.217 Z-7.836
    N14993 X43.554 Z-6.906
    N14994 X43.779 Z-6.407
    N14995 X44.228 Z-5.548
    N14996 X44.677 Z-4.838
    N14997 X45.35 Z-3.957
    N14998 X45.799 Z-3.462
    N14999 X46.248 Z-3.014
    N15000 X46.697 Z-2.617
    N15001 X47.146 Z-2.26
    N15002 X47.595 Z-1.936
    N15003 X48.493 Z-1.385
    N15004 X49.391 Z-.942
    N15005 X50.289 Z-.593
    N15006 X51.187 Z-.33
    N15007 X52.085 Z-.145
    N15008 X52.984 Z-.036
    N15009 X53.882 Z0.
    N15010 Y-55.825
    N15011 X52.984 Z-.036
    N15012 X52.085 Z-.145
    N15013 X51.187 Z-.33
    N15014 X50.289 Z-.593
    N15015 X49.391 Z-.942
    N15016 X48.493 Z-1.385
    N15017 X47.595 Z-1.936
    N15018 X47.146 Z-2.26
    N15019 X46.697 Z-2.617
    N15020 X46.248 Z-3.014
    N15021 X45.799 Z-3.462
    N15022 X45.35 Z-3.957
    N15023 X44.677 Z-4.838
    N15024 X44.228 Z-5.548
    N15025 X43.779 Z-6.407
    N15026 X43.554 Z-6.906
    N15027 X43.217 Z-7.836
    N15028 X43.003 Z-8.618
    N15029 X42.798 Z-9.748
    N15030 X42.44 Z-13.521
    N15031 X42.184 Z-15.229
    N15032 X41.571 Z-18.178
    N15033 X40.979 Z-20.339
    N15034 X40.491 Z-21.866
    N15035 X39.758 Z-23.846
    N15036 X39.033 Z-25.551
    N15037 X38.554 Z-26.583
    N15038 X38.074 Z-27.548
    N15039 X37.115 Z-29.312
    N15040 X36.156 Z-30.898
    N15041 X35.676 Z-31.638
    N15042 X34.839 Z-32.859
    N15043 X34.002 Z-33.989
    N15044 X33.166 Z-35.047
    N15045 X32.329 Z-36.043
    N15046 X31.408 Z-37.073
    N15047 X30.487 Z-38.035
    N15048 X29.566 Z-38.941
    N15049 X28.645 Z-39.796
    N15050 X27.77 Z-40.565
    N15051 X26.895 Z-41.292
    N15052 X26.02 Z-41.981
    N15053 X25.145 Z-42.634
    N15054 X24.233 Z-43.278
    N15055 X23.321 Z-43.886
    N15056 X22.41 Z-44.462
    N15057 X20.614 Z-45.507
    N15058 X18.845 Z-46.427
    N15059 X17.961 Z-46.848
    N15060 X16.151 Z-47.634
    N15061 X14.342 Z-48.323
    N15062 X12.559 Z-48.913
    N15063 X10.776 Z-49.418
    N15064 X8.958 Z-49.849
    N15065 X7.169 Z-50.192
    N15066 X5.362 Z-50.46
    N15067 X3.592 Z-50.648
    N15068 X1.797 Z-50.761
    N15069 X0. Z-50.8
    N15070 X-1.797 Z-50.761
    N15071 X-3.592 Z-50.648
    N15072 X-5.362 Z-50.46
    N15073 X-7.169 Z-50.192
    N15074 X-8.958 Z-49.849
    N15075 X-10.776 Z-49.418
    N15076 X-12.559 Z-48.913
    N15077 X-14.342 Z-48.323
    N15078 X-16.151 Z-47.634
    N15079 X-17.961 Z-46.848
    N15080 X-19.729 Z-45.98
    N15081 X-21.498 Z-45.007
    N15082 X-22.41 Z-44.462
    N15083 X-23.321 Z-43.886
    N15084 X-24.233 Z-43.278
    N15085 X-25.145 Z-42.634
    N15086 X-26.02 Z-41.981
    N15087 X-26.895 Z-41.292
    N15088 X-27.77 Z-40.565
    N15089 X-28.645 Z-39.796
    N15090 X-29.566 Z-38.941
    N15091 X-30.487 Z-38.035
    N15092 X-31.408 Z-37.073
    N15093 X-32.329 Z-36.043
    N15094 X-33.166 Z-35.047
    N15095 X-34.002 Z-33.989
    N15096 X-34.839 Z-32.859
    N15097 X-35.676 Z-31.638
    N15098 X-36.635 Z-30.125
    N15099 X-37.595 Z-28.455
    N15100 X-38.074 Z-27.548
    N15101 X-38.554 Z-26.583
    N15102 X-39.033 Z-25.551
    N15103 X-39.758 Z-23.846
    N15104 X-40.491 Z-21.866
    N15105 X-41.346 Z-19.058
    N15106 X-41.98 Z-16.328
    N15107 X-42.491 Z-13.111
    N15108 X-42.798 Z-9.748
    N15109 X-42.901 Z-9.104
    N15110 X-43.105 Z-8.22
    N15111 X-43.33 Z-7.496
    N15112 X-43.554 Z-6.906
    N15113 X-44.003 Z-5.952
    N15114 X-44.452 Z-5.184
    N15115 X-44.901 Z-4.527
    N15116 X-45.35 Z-3.957
    N15117 X-45.799 Z-3.462
    N15118 X-46.248 Z-3.014
    N15119 X-46.697 Z-2.617
    N15120 X-47.146 Z-2.26
    N15121 X-47.595 Z-1.936
    N15122 X-48.493 Z-1.385
    N15123 X-49.391 Z-.942
    N15124 X-50.289 Z-.593
    N15125 X-51.187 Z-.33
    N15126 X-52.085 Z-.145
    N15127 X-52.984 Z-.036
    N15128 X-53.882 Z0.
    N15129 Y-57.025
    N15130 X-52.984 Z-.036
    N15131 X-52.085 Z-.145
    N15132 X-51.187 Z-.33
    N15133 X-50.289 Z-.593
    N15134 X-49.391 Z-.942
    N15135 X-48.493 Z-1.385
    N15136 X-47.595 Z-1.936
    N15137 X-47.146 Z-2.26
    N15138 X-46.697 Z-2.617
    N15139 X-46.248 Z-3.014
    N15140 X-45.799 Z-3.462
    N15141 X-45.35 Z-3.957
    N15142 X-44.901 Z-4.527
    N15143 X-44.452 Z-5.184
    N15144 X-44.003 Z-5.952
    N15145 X-43.554 Z-6.906
    N15146 X-43.33 Z-7.496
    N15147 X-43.105 Z-8.22
    N15148 X-42.901 Z-9.104
    N15149 X-42.798 Z-9.748
    N15150 X-42.491 Z-13.111
    N15151 X-41.98 Z-16.328
    N15152 X-41.346 Z-19.058
    N15153 X-40.491 Z-21.866
    N15154 X-39.758 Z-23.846
    N15155 X-39.033 Z-25.551
    N15156 X-38.554 Z-26.583
    N15157 X-38.074 Z-27.548
    N15158 X-37.595 Z-28.455
    N15159 X-36.635 Z-30.125
    N15160 X-35.676 Z-31.638
    N15161 X-34.839 Z-32.859
    N15162 X-34.002 Z-33.989
    N15163 X-33.166 Z-35.047
    N15164 X-32.329 Z-36.043
    N15165 X-31.408 Z-37.073
    N15166 X-30.487 Z-38.035
    N15167 X-29.566 Z-38.941
    N15168 X-28.645 Z-39.796
    N15169 X-27.77 Z-40.565
    N15170 X-26.895 Z-41.292
    N15171 X-26.02 Z-41.981
    N15172 X-25.145 Z-42.634
    N15173 X-24.233 Z-43.278
    N15174 X-23.321 Z-43.886
    N15175 X-22.41 Z-44.462
    N15176 X-21.498 Z-45.007
    N15177 X-19.729 Z-45.98
    N15178 X-17.961 Z-46.848
    N15179 X-16.151 Z-47.634
    N15180 X-14.342 Z-48.323
    N15181 X-12.559 Z-48.913
    N15182 X-10.776 Z-49.418
    N15183 X-8.958 Z-49.849
    N15184 X-7.169 Z-50.192
    N15185 X-5.362 Z-50.46
    N15186 X-3.592 Z-50.648
    N15187 X-1.797 Z-50.761
    N15188 X0. Z-50.8
    N15189 X1.797 Z-50.761
    N15190 X3.592 Z-50.648
    N15191 X5.362 Z-50.46
    N15192 X7.169 Z-50.192
    N15193 X8.958 Z-49.849
    N15194 X10.776 Z-49.418
    N15195 X12.559 Z-48.913
    N15196 X14.342 Z-48.323
    N15197 X16.151 Z-47.634
    N15198 X17.961 Z-46.848
    N15199 X18.845 Z-46.427
    N15200 X20.614 Z-45.507
    N15201 X22.41 Z-44.462
    N15202 X23.321 Z-43.886
    N15203 X24.233 Z-43.278
    N15204 X25.145 Z-42.634
    N15205 X26.02 Z-41.981
    N15206 X26.895 Z-41.292
    N15207 X27.77 Z-40.565
    N15208 X28.645 Z-39.796
    N15209 X29.566 Z-38.941
    N15210 X30.487 Z-38.035
    N15211 X31.408 Z-37.073
    N15212 X32.329 Z-36.043
    N15213 X33.166 Z-35.047
    N15214 X34.002 Z-33.989
    N15215 X34.839 Z-32.859
    N15216 X35.676 Z-31.638
    N15217 X36.156 Z-30.898
    N15218 X37.115 Z-29.312
    N15219 X38.074 Z-27.548
    N15220 X38.554 Z-26.583
    N15221 X39.033 Z-25.551
    N15222 X39.758 Z-23.846
    N15223 X40.491 Z-21.866
    N15224 X40.979 Z-20.339
    N15225 X41.571 Z-18.178
    N15226 X42.184 Z-15.229
    N15227 X42.44 Z-13.521
    N15228 X42.798 Z-9.748
    N15229 X43.003 Z-8.618
    N15230 X43.217 Z-7.836
    N15231 X43.554 Z-6.906
    N15232 X43.779 Z-6.407
    N15233 X44.228 Z-5.548
    N15234 X44.677 Z-4.838
    N15235 X45.35 Z-3.957
    N15236 X45.799 Z-3.462
    N15237 X46.248 Z-3.014
    N15238 X46.697 Z-2.617
    N15239 X47.146 Z-2.26
    N15240 X47.595 Z-1.936
    N15241 X48.493 Z-1.385
    N15242 X49.391 Z-.942
    N15243 X50.289 Z-.593
    N15244 X51.187 Z-.33
    N15245 X52.085 Z-.145
    N15246 X52.984 Z-.036
    N15247 X53.882 Z0.
    N15248 Y-58.225
    N15249 X52.984 Z-.036
    N15250 X52.085 Z-.145
    N15251 X51.187 Z-.33
    N15252 X50.289 Z-.593
    N15253 X49.391 Z-.942
    N15254 X48.493 Z-1.385
    N15255 X47.595 Z-1.936
    N15256 X47.146 Z-2.26
    N15257 X46.697 Z-2.617
    N15258 X46.248 Z-3.014
    N15259 X45.799 Z-3.462
    N15260 X45.35 Z-3.957
    N15261 X44.677 Z-4.839
    N15262 X44.228 Z-5.548
    N15263 X43.779 Z-6.407
    N15264 X43.554 Z-6.906
    N15265 X43.217 Z-7.836
    N15266 X43.003 Z-8.618
    N15267 X42.798 Z-9.748
    N15268 X42.44 Z-13.521
    N15269 X42.184 Z-15.229
    N15270 X41.571 Z-18.178
    N15271 X40.979 Z-20.339
    N15272 X40.491 Z-21.866
    N15273 X39.758 Z-23.846
    N15274 X39.033 Z-25.551
    N15275 X38.554 Z-26.583
    N15276 X38.074 Z-27.548
    N15277 X37.115 Z-29.312
    N15278 X36.156 Z-30.898
    N15279 X35.676 Z-31.638
    N15280 X34.839 Z-32.859
    N15281 X34.002 Z-33.989
    N15282 X33.166 Z-35.047
    N15283 X32.329 Z-36.043
    N15284 X31.408 Z-37.073
    N15285 X30.487 Z-38.035
    N15286 X29.566 Z-38.941
    N15287 X28.645 Z-39.796
    N15288 X27.77 Z-40.565
    N15289 X26.895 Z-41.292
    N15290 X26.02 Z-41.981
    N15291 X25.145 Z-42.634
    N15292 X24.233 Z-43.278
    N15293 X23.321 Z-43.886
    N15294 X22.41 Z-44.462
    N15295 X20.614 Z-45.507
    N15296 X18.845 Z-46.427
    N15297 X17.961 Z-46.848
    N15298 X16.151 Z-47.634
    N15299 X14.342 Z-48.323
    N15300 X12.559 Z-48.913
    N15301 X10.776 Z-49.418
    N15302 X8.958 Z-49.849
    N15303 X7.169 Z-50.192
    N15304 X5.362 Z-50.46
    N15305 X3.592 Z-50.648
    N15306 X1.797 Z-50.761
    N15307 X0. Z-50.8
    N15308 X-1.797 Z-50.761
    N15309 X-3.592 Z-50.648
    N15310 X-5.362 Z-50.46
    N15311 X-7.169 Z-50.192
    N15312 X-8.958 Z-49.849
    N15313 X-10.776 Z-49.418
    N15314 X-12.559 Z-48.913
    N15315 X-14.342 Z-48.323
    N15316 X-16.151 Z-47.634
    N15317 X-17.961 Z-46.848
    N15318 X-19.729 Z-45.98
    N15319 X-21.498 Z-45.007
    N15320 X-22.41 Z-44.462
    N15321 X-23.321 Z-43.886
    N15322 X-24.233 Z-43.278
    N15323 X-25.145 Z-42.634
    N15324 X-26.02 Z-41.981
    N15325 X-26.895 Z-41.292
    N15326 X-27.77 Z-40.565
    N15327 X-28.645 Z-39.796
    N15328 X-29.566 Z-38.941
    N15329 X-30.487 Z-38.035
    N15330 X-31.408 Z-37.073
    N15331 X-32.329 Z-36.043
    N15332 X-33.166 Z-35.047
    N15333 X-34.002 Z-33.989
    N15334 X-34.839 Z-32.859
    N15335 X-35.676 Z-31.638
    N15336 X-36.635 Z-30.125
    N15337 X-37.595 Z-28.455
    N15338 X-38.074 Z-27.548
    N15339 X-38.554 Z-26.583
    N15340 X-39.033 Z-25.551
    N15341 X-39.758 Z-23.846
    N15342 X-40.491 Z-21.866
    N15343 X-41.346 Z-19.058
    N15344 X-41.98 Z-16.328
    N15345 X-42.491 Z-13.111
    N15346 X-42.798 Z-9.748
    N15347 X-42.901 Z-9.105
    N15348 X-43.105 Z-8.22
    N15349 X-43.33 Z-7.496
    N15350 X-43.554 Z-6.906
    N15351 X-44.003 Z-5.952
    N15352 X-44.452 Z-5.184
    N15353 X-44.901 Z-4.527
    N15354 X-45.35 Z-3.957
    N15355 X-45.799 Z-3.462
    N15356 X-46.248 Z-3.014
    N15357 X-46.697 Z-2.617
    N15358 X-47.146 Z-2.26
    N15359 X-47.595 Z-1.936
    N15360 X-48.493 Z-1.385
    N15361 X-49.391 Z-.942
    N15362 X-50.289 Z-.593
    N15363 X-51.187 Z-.33
    N15364 X-52.085 Z-.145
    N15365 X-52.984 Z-.036
    N15366 X-53.882 Z0.
    N15367 Y-59.425
    N15368 X-52.984 Z-.036
    N15369 X-52.085 Z-.145
    N15370 X-51.187 Z-.33
    N15371 X-50.289 Z-.593
    N15372 X-49.391 Z-.942
    N15373 X-48.493 Z-1.385
    N15374 X-47.595 Z-1.936
    N15375 X-47.146 Z-2.26
    N15376 X-46.697 Z-2.617
    N15377 X-46.248 Z-3.014
    N15378 X-45.799 Z-3.462
    N15379 X-45.35 Z-3.957
    N15380 X-44.901 Z-4.527
    N15381 X-44.452 Z-5.184
    N15382 X-44.003 Z-5.952
    N15383 X-43.554 Z-6.906
    N15384 X-43.33 Z-7.496
    N15385 X-43.105 Z-8.22
    N15386 X-42.901 Z-9.105
    N15387 X-42.798 Z-9.748
    N15388 X-42.491 Z-13.111
    N15389 X-41.98 Z-16.328
    N15390 X-41.346 Z-19.058
    N15391 X-40.491 Z-21.866
    N15392 X-39.758 Z-23.846
    N15393 X-39.033 Z-25.551
    N15394 X-38.554 Z-26.583
    N15395 X-38.074 Z-27.548
    N15396 X-37.595 Z-28.455
    N15397 X-36.635 Z-30.125
    N15398 X-35.676 Z-31.638
    N15399 X-34.839 Z-32.859
    N15400 X-34.002 Z-33.989
    N15401 X-33.166 Z-35.047
    N15402 X-32.329 Z-36.043
    N15403 X-31.408 Z-37.073
    N15404 X-30.487 Z-38.035
    N15405 X-29.566 Z-38.941
    N15406 X-28.645 Z-39.796
    N15407 X-27.77 Z-40.565
    N15408 X-26.895 Z-41.292
    N15409 X-26.02 Z-41.981
    N15410 X-25.145 Z-42.634
    N15411 X-24.233 Z-43.278
    N15412 X-23.321 Z-43.886
    N15413 X-22.41 Z-44.462
    N15414 X-21.498 Z-45.007
    N15415 X-19.729 Z-45.98
    N15416 X-17.961 Z-46.848
    N15417 X-16.151 Z-47.634
    N15418 X-14.342 Z-48.323
    N15419 X-12.559 Z-48.913
    N15420 X-10.776 Z-49.418
    N15421 X-8.958 Z-49.849
    N15422 X-7.169 Z-50.192
    N15423 X-5.362 Z-50.46
    N15424 X-3.592 Z-50.648
    N15425 X-1.797 Z-50.761
    N15426 X0. Z-50.8
    N15427 X1.797 Z-50.761
    N15428 X3.592 Z-50.648
    N15429 X5.362 Z-50.46
    N15430 X7.169 Z-50.192
    N15431 X8.958 Z-49.849
    N15432 X10.776 Z-49.418
    N15433 X12.559 Z-48.913
    N15434 X14.342 Z-48.323
    N15435 X16.151 Z-47.634
    N15436 X17.961 Z-46.848
    N15437 X18.845 Z-46.427
    N15438 X20.614 Z-45.507
    N15439 X22.41 Z-44.462
    N15440 X23.321 Z-43.886
    N15441 X24.233 Z-43.278
    N15442 X25.145 Z-42.634
    N15443 X26.02 Z-41.981
    N15444 X26.895 Z-41.292
    N15445 X27.77 Z-40.565
    N15446 X28.645 Z-39.796
    N15447 X29.566 Z-38.941
    N15448 X30.487 Z-38.035
    N15449 X31.408 Z-37.073
    N15450 X32.329 Z-36.043
    N15451 X33.166 Z-35.047
    N15452 X34.002 Z-33.989
    N15453 X34.839 Z-32.859
    N15454 X35.676 Z-31.638
    N15455 X36.156 Z-30.898
    N15456 X37.115 Z-29.312
    N15457 X38.074 Z-27.548
    N15458 X38.554 Z-26.583
    N15459 X39.033 Z-25.551
    N15460 X39.758 Z-23.846
    N15461 X40.491 Z-21.866
    N15462 X40.979 Z-20.339
    N15463 X41.571 Z-18.178
    N15464 X42.184 Z-15.229
    N15465 X42.44 Z-13.521
    N15466 X42.798 Z-9.748
    N15467 X43.003 Z-8.618
    N15468 X43.217 Z-7.836
    N15469 X43.554 Z-6.906
    N15470 X43.779 Z-6.407
    N15471 X44.228 Z-5.548
    N15472 X44.677 Z-4.839
    N15473 X45.35 Z-3.957
    N15474 X45.799 Z-3.462
    N15475 X46.248 Z-3.014
    N15476 X46.697 Z-2.617
    N15477 X47.146 Z-2.26
    N15478 X47.595 Z-1.936
    N15479 X48.493 Z-1.385
    N15480 X49.391 Z-.942
    N15481 X50.289 Z-.593
    N15482 X51.187 Z-.33
    N15483 X52.085 Z-.145
    N15484 X52.984 Z-.036
    N15485 X53.882 Z0.
    N15486 Y-60.625
    N15487 X52.984 Z-.036
    N15488 X52.085 Z-.145
    N15489 X51.187 Z-.33
    N15490 X50.289 Z-.593
    N15491 X49.391 Z-.942
    N15492 X48.493 Z-1.385
    N15493 X47.595 Z-1.936
    N15494 X47.146 Z-2.26
    N15495 X46.697 Z-2.617
    N15496 X46.248 Z-3.014
    N15497 X45.799 Z-3.462
    N15498 X45.35 Z-3.957
    N15499 X44.677 Z-4.839
    N15500 X44.228 Z-5.548
    N15501 X43.779 Z-6.407
    N15502 X43.554 Z-6.906
    N15503 X43.217 Z-7.836
    N15504 X43.003 Z-8.618
    N15505 X42.798 Z-9.748
    N15506 X42.44 Z-13.521
    N15507 X42.184 Z-15.229
    N15508 X41.571 Z-18.178
    N15509 X40.979 Z-20.339
    N15510 X40.491 Z-21.866
    N15511 X39.758 Z-23.846
    N15512 X39.033 Z-25.551
    N15513 X38.554 Z-26.583
    N15514 X38.074 Z-27.548
    N15515 X37.115 Z-29.312
    N15516 X36.156 Z-30.898
    N15517 X35.676 Z-31.638
    N15518 X34.839 Z-32.859
    N15519 X34.002 Z-33.989
    N15520 X33.166 Z-35.047
    N15521 X32.329 Z-36.043
    N15522 X31.408 Z-37.073
    N15523 X30.487 Z-38.035
    N15524 X29.566 Z-38.941
    N15525 X28.645 Z-39.796
    N15526 X27.77 Z-40.565
    N15527 X26.895 Z-41.292
    N15528 X26.02 Z-41.981
    N15529 X25.145 Z-42.634
    N15530 X24.233 Z-43.278
    N15531 X23.321 Z-43.886
    N15532 X22.41 Z-44.462
    N15533 X20.614 Z-45.507
    N15534 X18.845 Z-46.427
    N15535 X17.961 Z-46.848
    N15536 X16.151 Z-47.634
    N15537 X14.342 Z-48.323
    N15538 X12.559 Z-48.913
    N15539 X10.776 Z-49.418
    N15540 X8.958 Z-49.849
    N15541 X7.169 Z-50.192
    N15542 X5.362 Z-50.46
    N15543 X3.592 Z-50.648
    N15544 X1.797 Z-50.761
    N15545 X0. Z-50.8
    N15546 X-1.797 Z-50.761
    N15547 X-3.592 Z-50.648
    N15548 X-5.362 Z-50.46
    N15549 X-7.169 Z-50.192
    N15550 X-8.958 Z-49.849
    N15551 X-10.776 Z-49.418
    N15552 X-12.559 Z-48.913
    N15553 X-14.342 Z-48.323
    N15554 X-16.151 Z-47.634
    N15555 X-17.961 Z-46.848
    N15556 X-19.729 Z-45.98
    N15557 X-21.498 Z-45.007
    N15558 X-22.41 Z-44.462
    N15559 X-23.321 Z-43.886
    N15560 X-24.233 Z-43.278
    N15561 X-25.145 Z-42.634
    N15562 X-26.02 Z-41.981
    N15563 X-26.895 Z-41.292
    N15564 X-27.77 Z-40.565
    N15565 X-28.645 Z-39.796
    N15566 X-29.566 Z-38.941
    N15567 X-30.487 Z-38.035
    N15568 X-31.408 Z-37.073
    N15569 X-32.329 Z-36.043
    N15570 X-33.166 Z-35.047
    N15571 X-34.002 Z-33.989
    N15572 X-34.839 Z-32.859
    N15573 X-35.676 Z-31.638
    N15574 X-36.635 Z-30.125
    N15575 X-37.595 Z-28.455
    N15576 X-38.074 Z-27.548
    N15577 X-38.554 Z-26.583
    N15578 X-39.033 Z-25.551
    N15579 X-39.758 Z-23.846
    N15580 X-40.491 Z-21.866
    N15581 X-41.346 Z-19.058
    N15582 X-41.98 Z-16.328
    N15583 X-42.491 Z-13.111
    N15584 X-42.798 Z-9.748
    N15585 X-42.901 Z-9.105
    N15586 X-43.105 Z-8.22
    N15587 X-43.33 Z-7.496
    N15588 X-43.554 Z-6.906
    N15589 X-44.003 Z-5.952
    N15590 X-44.452 Z-5.184
    N15591 X-44.901 Z-4.527
    N15592 X-45.35 Z-3.957
    N15593 X-45.799 Z-3.462
    N15594 X-46.248 Z-3.014
    N15595 X-46.697 Z-2.617
    N15596 X-47.146 Z-2.26
    N15597 X-47.595 Z-1.936
    N15598 X-48.493 Z-1.385
    N15599 X-49.391 Z-.942
    N15600 X-50.289 Z-.593
    N15601 X-51.187 Z-.33
    N15602 X-52.085 Z-.145
    N15603 X-52.984 Z-.036
    N15604 X-53.882 Z0.
    N15605 Y-61.825
    N15606 X-52.984 Z-.036
    N15607 X-52.085 Z-.145
    N15608 X-51.187 Z-.33
    N15609 X-50.289 Z-.593
    N15610 X-49.391 Z-.942
    N15611 X-48.493 Z-1.385
    N15612 X-47.595 Z-1.936
    N15613 X-47.146 Z-2.26
    N15614 X-46.697 Z-2.617
    N15615 X-46.248 Z-3.014
    N15616 X-45.799 Z-3.462
    N15617 X-45.35 Z-3.957
    N15618 X-44.901 Z-4.527
    N15619 X-44.452 Z-5.184
    N15620 X-44.003 Z-5.952
    N15621 X-43.554 Z-6.906
    N15622 X-43.33 Z-7.496
    N15623 X-43.105 Z-8.22
    N15624 X-42.901 Z-9.105
    N15625 X-42.798 Z-9.748
    N15626 X-42.491 Z-13.111
    N15627 X-41.98 Z-16.328
    N15628 X-41.346 Z-19.058
    N15629 X-40.491 Z-21.866
    N15630 X-39.758 Z-23.846
    N15631 X-39.033 Z-25.551
    N15632 X-38.554 Z-26.583
    N15633 X-38.074 Z-27.548
    N15634 X-37.595 Z-28.455
    N15635 X-36.635 Z-30.125
    N15636 X-35.676 Z-31.638
    N15637 X-34.839 Z-32.859
    N15638 X-34.002 Z-33.989
    N15639 X-33.166 Z-35.047
    N15640 X-32.329 Z-36.043
    N15641 X-31.408 Z-37.073
    N15642 X-30.487 Z-38.035
    N15643 X-29.566 Z-38.941
    N15644 X-28.645 Z-39.796
    N15645 X-27.77 Z-40.565
    N15646 X-26.895 Z-41.292
    N15647 X-26.02 Z-41.981
    N15648 X-25.145 Z-42.634
    N15649 X-24.233 Z-43.278
    N15650 X-23.321 Z-43.886
    N15651 X-22.41 Z-44.462
    N15652 X-21.498 Z-45.007
    N15653 X-19.729 Z-45.98
    N15654 X-17.961 Z-46.848
    N15655 X-16.151 Z-47.634
    N15656 X-14.342 Z-48.323
    N15657 X-12.559 Z-48.913
    N15658 X-10.776 Z-49.418
    N15659 X-8.958 Z-49.849
    N15660 X-7.169 Z-50.192
    N15661 X-5.362 Z-50.46
    N15662 X-3.592 Z-50.648
    N15663 X-1.797 Z-50.761
    N15664 X0. Z-50.8
    N15665 X1.797 Z-50.761
    N15666 X3.592 Z-50.648
    N15667 X5.362 Z-50.46
    N15668 X7.169 Z-50.192
    N15669 X8.958 Z-49.849
    N15670 X10.776 Z-49.418
    N15671 X12.559 Z-48.913
    N15672 X14.342 Z-48.323
    N15673 X16.151 Z-47.634
    N15674 X17.961 Z-46.848
    N15675 X18.845 Z-46.427
    N15676 X20.614 Z-45.507
    N15677 X22.41 Z-44.462
    N15678 X23.321 Z-43.886
    N15679 X24.233 Z-43.278
    N15680 X25.145 Z-42.634
    N15681 X26.02 Z-41.981
    N15682 X26.895 Z-41.292
    N15683 X27.77 Z-40.565
    N15684 X28.645 Z-39.796
    N15685 X29.566 Z-38.941
    N15686 X30.487 Z-38.035
    N15687 X31.408 Z-37.073
    N15688 X32.329 Z-36.043
    N15689 X33.166 Z-35.047
    N15690 X34.002 Z-33.989
    N15691 X34.839 Z-32.859
    N15692 X35.676 Z-31.638
    N15693 X36.156 Z-30.898
    N15694 X37.115 Z-29.312
    N15695 X38.074 Z-27.548
    N15696 X38.554 Z-26.583
    N15697 X39.033 Z-25.551
    N15698 X39.758 Z-23.846
    N15699 X40.491 Z-21.866
    N15700 X40.979 Z-20.339
    N15701 X41.571 Z-18.178
    N15702 X42.184 Z-15.229
    N15703 X42.44 Z-13.521
    N15704 X42.798 Z-9.748
    N15705 X43.003 Z-8.618
    N15706 X43.217 Z-7.836
    N15707 X43.554 Z-6.906
    N15708 X43.779 Z-6.407
    N15709 X44.228 Z-5.548
    N15710 X44.677 Z-4.839
    N15711 X45.35 Z-3.957
    N15712 X45.799 Z-3.462
    N15713 X46.248 Z-3.014
    N15714 X46.697 Z-2.617
    N15715 X47.146 Z-2.26
    N15716 X47.595 Z-1.937
    N15717 X48.493 Z-1.385
    N15718 X49.391 Z-.942
    N15719 X50.289 Z-.593
    N15720 X51.187 Z-.33
    N15721 X52.085 Z-.145
    N15722 X52.984 Z-.036
    N15723 X53.882 Z0.
    N15724 Y-63.025
    N15725 X52.984 Z-.036
    N15726 X52.085 Z-.145
    N15727 X51.187 Z-.33
    N15728 X50.289 Z-.593
    N15729 X49.391 Z-.942
    N15730 X48.493 Z-1.385
    N15731 X47.595 Z-1.937
    N15732 X47.146 Z-2.26
    N15733 X46.697 Z-2.617
    N15734 X46.248 Z-3.014
    N15735 X45.799 Z-3.462
    N15736 X45.35 Z-3.957
    N15737 X44.677 Z-4.839
    N15738 X44.228 Z-5.548
    N15739 X43.779 Z-6.406
    N15740 X43.554 Z-6.907
    N15741 X43.217 Z-7.836
    N15742 X43.003 Z-8.618
    N15743 X42.798 Z-9.748
    N15744 X42.44 Z-13.521
    N15745 X42.184 Z-15.229
    N15746 X41.571 Z-18.178
    N15747 X40.979 Z-20.339
    N15748 X40.491 Z-21.866
    N15749 X39.758 Z-23.846
    N15750 X39.033 Z-25.551
    N15751 X38.554 Z-26.583
    N15752 X38.074 Z-27.548
    N15753 X37.115 Z-29.312
    N15754 X36.156 Z-30.898
    N15755 X35.676 Z-31.638
    N15756 X34.839 Z-32.859
    N15757 X34.002 Z-33.989
    N15758 X33.166 Z-35.047
    N15759 X32.329 Z-36.043
    N15760 X31.408 Z-37.073
    N15761 X30.487 Z-38.035
    N15762 X29.566 Z-38.941
    N15763 X28.645 Z-39.796
    N15764 X27.77 Z-40.565
    N15765 X26.895 Z-41.292
    N15766 X26.02 Z-41.981
    N15767 X25.145 Z-42.634
    N15768 X24.233 Z-43.278
    N15769 X23.321 Z-43.886
    N15770 X22.41 Z-44.462
    N15771 X20.614 Z-45.507
    N15772 X18.845 Z-46.427
    N15773 X17.961 Z-46.848
    N15774 X16.151 Z-47.634
    N15775 X14.342 Z-48.323
    N15776 X12.559 Z-48.913
    N15777 X10.776 Z-49.418
    N15778 X8.958 Z-49.849
    N15779 X7.169 Z-50.192
    N15780 X5.362 Z-50.46
    N15781 X3.592 Z-50.648
    N15782 X1.797 Z-50.761
    N15783 X0. Z-50.8
    N15784 X-1.797 Z-50.761
    N15785 X-3.592 Z-50.648
    N15786 X-5.362 Z-50.46
    N15787 X-7.169 Z-50.192
    N15788 X-8.958 Z-49.849
    N15789 X-10.776 Z-49.418
    N15790 X-12.559 Z-48.913
    N15791 X-14.342 Z-48.323
    N15792 X-16.151 Z-47.634
    N15793 X-17.961 Z-46.848
    N15794 X-19.729 Z-45.98
    N15795 X-21.498 Z-45.007
    N15796 X-22.41 Z-44.462
    N15797 X-23.321 Z-43.886
    N15798 X-24.233 Z-43.278
    N15799 X-25.145 Z-42.634
    N15800 X-26.02 Z-41.981
    N15801 X-26.895 Z-41.292
    N15802 X-27.77 Z-40.565
    N15803 X-28.645 Z-39.796
    N15804 X-29.566 Z-38.941
    N15805 X-30.487 Z-38.035
    N15806 X-31.408 Z-37.073
    N15807 X-32.329 Z-36.043
    N15808 X-33.166 Z-35.047
    N15809 X-34.002 Z-33.989
    N15810 X-34.839 Z-32.859
    N15811 X-35.676 Z-31.638
    N15812 X-36.635 Z-30.125
    N15813 X-37.595 Z-28.455
    N15814 X-38.074 Z-27.548
    N15815 X-38.554 Z-26.583
    N15816 X-39.033 Z-25.551
    N15817 X-39.758 Z-23.846
    N15818 X-40.491 Z-21.866
    N15819 X-41.346 Z-19.058
    N15820 X-41.98 Z-16.328
    N15821 X-42.491 Z-13.111
    N15822 X-42.798 Z-9.748
    N15823 X-42.901 Z-9.106
    N15824 X-43.105 Z-8.22
    N15825 X-43.33 Z-7.496
    N15826 X-43.554 Z-6.907
    N15827 X-44.003 Z-5.952
    N15828 X-44.452 Z-5.184
    N15829 X-44.901 Z-4.527
    N15830 X-45.35 Z-3.957
    N15831 X-45.799 Z-3.462
    N15832 X-46.248 Z-3.014
    N15833 X-46.697 Z-2.617
    N15834 X-47.146 Z-2.26
    N15835 X-47.595 Z-1.937
    N15836 X-48.493 Z-1.385
    N15837 X-49.391 Z-.942
    N15838 X-50.289 Z-.593
    N15839 X-51.187 Z-.33
    N15840 X-52.085 Z-.145
    N15841 X-52.984 Z-.036
    N15842 X-53.882 Z0.
    N15843 Y-64.225
    N15844 X-52.984 Z-.036
    N15845 X-52.085 Z-.145
    N15846 X-51.187 Z-.33
    N15847 X-50.289 Z-.593
    N15848 X-49.391 Z-.942
    N15849 X-48.493 Z-1.385
    N15850 X-47.595 Z-1.937
    N15851 X-47.146 Z-2.26
    N15852 X-46.697 Z-2.617
    N15853 X-46.248 Z-3.014
    N15854 X-45.799 Z-3.462
    N15855 X-45.35 Z-3.957
    N15856 X-44.901 Z-4.527
    N15857 X-44.452 Z-5.184
    N15858 X-44.003 Z-5.952
    N15859 X-43.554 Z-6.907
    N15860 X-43.33 Z-7.496
    N15861 X-43.105 Z-8.22
    N15862 X-42.901 Z-9.106
    N15863 X-42.798 Z-9.748
    N15864 X-42.491 Z-13.111
    N15865 X-41.98 Z-16.328
    N15866 X-41.346 Z-19.058
    N15867 X-40.491 Z-21.866
    N15868 X-39.758 Z-23.846
    N15869 X-39.033 Z-25.551
    N15870 X-38.554 Z-26.583
    N15871 X-38.074 Z-27.548
    N15872 X-37.595 Z-28.455
    N15873 X-36.635 Z-30.125
    N15874 X-35.676 Z-31.638
    N15875 X-34.839 Z-32.859
    N15876 X-34.002 Z-33.989
    N15877 X-33.166 Z-35.047
    N15878 X-32.329 Z-36.043
    N15879 X-31.408 Z-37.073
    N15880 X-30.487 Z-38.035
    N15881 X-29.566 Z-38.941
    N15882 X-28.645 Z-39.796
    N15883 X-27.77 Z-40.565
    N15884 X-26.895 Z-41.292
    N15885 X-26.02 Z-41.981
    N15886 X-25.145 Z-42.634
    N15887 X-24.233 Z-43.278
    N15888 X-23.321 Z-43.886
    N15889 X-22.41 Z-44.462
    N15890 X-21.498 Z-45.007
    N15891 X-19.729 Z-45.98
    N15892 X-17.961 Z-46.848
    N15893 X-16.151 Z-47.634
    N15894 X-14.342 Z-48.323
    N15895 X-12.559 Z-48.913
    N15896 X-10.776 Z-49.418
    N15897 X-8.958 Z-49.849
    N15898 X-7.169 Z-50.192
    N15899 X-5.362 Z-50.46
    N15900 X-3.592 Z-50.648
    N15901 X-1.797 Z-50.761
    N15902 X0. Z-50.8
    N15903 X1.797 Z-50.761
    N15904 X3.592 Z-50.648
    N15905 X5.362 Z-50.46
    N15906 X7.169 Z-50.192
    N15907 X8.958 Z-49.849
    N15908 X10.776 Z-49.418
    N15909 X12.559 Z-48.913
    N15910 X14.342 Z-48.323
    N15911 X16.151 Z-47.634
    N15912 X17.961 Z-46.848
    N15913 X18.845 Z-46.427
    N15914 X20.614 Z-45.507
    N15915 X22.41 Z-44.462
    N15916 X23.321 Z-43.886
    N15917 X24.233 Z-43.278
    N15918 X25.145 Z-42.634
    N15919 X26.02 Z-41.981
    N15920 X26.895 Z-41.292
    N15921 X27.77 Z-40.565
    N15922 X28.645 Z-39.796
    N15923 X29.566 Z-38.941
    N15924 X30.487 Z-38.035
    N15925 X31.408 Z-37.073
    N15926 X32.329 Z-36.043
    N15927 X33.166 Z-35.047
    N15928 X34.002 Z-33.989
    N15929 X34.839 Z-32.859
    N15930 X35.676 Z-31.638
    N15931 X36.156 Z-30.898
    N15932 X37.115 Z-29.312
    N15933 X38.074 Z-27.548
    N15934 X38.554 Z-26.583
    N15935 X39.033 Z-25.551
    N15936 X39.758 Z-23.846
    N15937 X40.491 Z-21.866
    N15938 X40.979 Z-20.339
    N15939 X41.571 Z-18.178
    N15940 X42.184 Z-15.229
    N15941 X42.44 Z-13.521
    N15942 X42.798 Z-9.748
    N15943 X43.003 Z-8.618
    N15944 X43.217 Z-7.836
    N15945 X43.554 Z-6.907
    N15946 X43.779 Z-6.406
    N15947 X44.228 Z-5.548
    N15948 X44.677 Z-4.839
    N15949 X45.35 Z-3.957
    N15950 X45.799 Z-3.462
    N15951 X46.248 Z-3.014
    N15952 X46.697 Z-2.617
    N15953 X47.146 Z-2.26
    N15954 X47.595 Z-1.937
    N15955 X48.493 Z-1.385
    N15956 X49.391 Z-.942
    N15957 X50.289 Z-.593
    N15958 X51.187 Z-.33
    N15959 X52.085 Z-.145
    N15960 X52.984 Z-.036
    N15961 X53.882 Z0.
    N15962 Y-65.425
    N15963 X52.984 Z-.036
    N15964 X52.085 Z-.145
    N15965 X51.187 Z-.33
    N15966 X50.289 Z-.593
    N15967 X49.391 Z-.942
    N15968 X48.493 Z-1.386
    N15969 X47.595 Z-1.937
    N15970 X47.146 Z-2.26
    N15971 X46.697 Z-2.617
    N15972 X46.248 Z-3.014
    N15973 X45.799 Z-3.462
    N15974 X45.35 Z-3.957
    N15975 X44.677 Z-4.839
    N15976 X44.228 Z-5.548
    N15977 X43.779 Z-6.406
    N15978 X43.554 Z-6.907
    N15979 X43.217 Z-7.836
    N15980 X43.003 Z-8.618
    N15981 X42.798 Z-9.748
    N15982 X42.44 Z-13.521
    N15983 X42.184 Z-15.229
    N15984 X41.571 Z-18.178
    N15985 X40.979 Z-20.339
    N15986 X40.491 Z-21.866
    N15987 X39.758 Z-23.846
    N15988 X39.033 Z-25.551
    N15989 X38.554 Z-26.583
    N15990 X38.074 Z-27.548
    N15991 X37.115 Z-29.312
    N15992 X36.156 Z-30.898
    N15993 X35.676 Z-31.638
    N15994 X34.839 Z-32.859
    N15995 X34.002 Z-33.989
    N15996 X33.166 Z-35.047
    N15997 X32.329 Z-36.043
    N15998 X31.408 Z-37.073
    N15999 X30.487 Z-38.035
    N16000 X29.566 Z-38.941
    N16001 X28.645 Z-39.796
    N16002 X27.77 Z-40.565
    N16003 X26.895 Z-41.292
    N16004 X26.02 Z-41.981
    N16005 X25.145 Z-42.634
    N16006 X24.233 Z-43.278
    N16007 X23.321 Z-43.886
    N16008 X22.41 Z-44.462
    N16009 X20.614 Z-45.507
    N16010 X18.845 Z-46.427
    N16011 X17.961 Z-46.848
    N16012 X16.151 Z-47.634
    N16013 X14.342 Z-48.323
    N16014 X12.559 Z-48.913
    N16015 X10.776 Z-49.418
    N16016 X8.958 Z-49.849
    N16017 X7.169 Z-50.192
    N16018 X5.362 Z-50.46
    N16019 X3.592 Z-50.648
    N16020 X1.797 Z-50.761
    N16021 X0. Z-50.8
    N16022 X-1.797 Z-50.761
    N16023 X-3.592 Z-50.648
    N16024 X-5.362 Z-50.46
    N16025 X-7.169 Z-50.192
    N16026 X-8.958 Z-49.849
    N16027 X-10.776 Z-49.418
    N16028 X-12.559 Z-48.913
    N16029 X-14.342 Z-48.323
    N16030 X-16.151 Z-47.634
    N16031 X-17.961 Z-46.848
    N16032 X-19.729 Z-45.98
    N16033 X-21.498 Z-45.007
    N16034 X-22.41 Z-44.462
    N16035 X-23.321 Z-43.886
    N16036 X-24.233 Z-43.278
    N16037 X-25.145 Z-42.634
    N16038 X-26.02 Z-41.981
    N16039 X-26.895 Z-41.292
    N16040 X-27.77 Z-40.565
    N16041 X-28.645 Z-39.796
    N16042 X-29.566 Z-38.941
    N16043 X-30.487 Z-38.035
    N16044 X-31.408 Z-37.073
    N16045 X-32.329 Z-36.043
    N16046 X-33.166 Z-35.047
    N16047 X-34.002 Z-33.989
    N16048 X-34.839 Z-32.859
    N16049 X-35.676 Z-31.638
    N16050 X-36.635 Z-30.125
    N16051 X-37.595 Z-28.455
    N16052 X-38.074 Z-27.548
    N16053 X-38.554 Z-26.583
    N16054 X-39.033 Z-25.551
    N16055 X-39.758 Z-23.846
    N16056 X-40.491 Z-21.866
    N16057 X-41.346 Z-19.058
    N16058 X-41.98 Z-16.328
    N16059 X-42.491 Z-13.111
    N16060 X-42.798 Z-9.748
    N16061 X-42.901 Z-9.106
    N16062 X-43.105 Z-8.22
    N16063 X-43.33 Z-7.496
    N16064 X-43.554 Z-6.907
    N16065 X-44.003 Z-5.952
    N16066 X-44.452 Z-5.184
    N16067 X-44.901 Z-4.527
    N16068 X-45.35 Z-3.957
    N16069 X-45.799 Z-3.462
    N16070 X-46.248 Z-3.014
    N16071 X-46.697 Z-2.617
    N16072 X-47.146 Z-2.26
    N16073 X-47.595 Z-1.937
    N16074 X-48.493 Z-1.385
    N16075 X-49.391 Z-.942
    N16076 X-50.289 Z-.593
    N16077 X-51.187 Z-.33
    N16078 X-52.085 Z-.145
    N16079 X-52.984 Z-.036
    N16080 X-53.882 Z0.
    N16081 Y-66.625
    N16082 X-52.984 Z-.036
    N16083 X-52.085 Z-.145
    N16084 X-51.187 Z-.33
    N16085 X-50.289 Z-.594
    N16086 X-49.391 Z-.943
    N16087 X-48.493 Z-1.386
    N16088 X-47.595 Z-1.937
    N16089 X-47.146 Z-2.26
    N16090 X-46.697 Z-2.617
    N16091 X-46.248 Z-3.014
    N16092 X-45.799 Z-3.462
    N16093 X-45.35 Z-3.957
    N16094 X-44.901 Z-4.527
    N16095 X-44.452 Z-5.183
    N16096 X-44.003 Z-5.952
    N16097 X-43.554 Z-6.907
    N16098 X-43.33 Z-7.496
    N16099 X-43.105 Z-8.22
    N16100 X-42.901 Z-9.106
    N16101 X-42.798 Z-9.748
    N16102 X-42.491 Z-13.111
    N16103 X-41.98 Z-16.328
    N16104 X-41.346 Z-19.058
    N16105 X-40.491 Z-21.866
    N16106 X-39.758 Z-23.846
    N16107 X-39.033 Z-25.551
    N16108 X-38.554 Z-26.583
    N16109 X-38.074 Z-27.548
    N16110 X-37.595 Z-28.455
    N16111 X-36.635 Z-30.125
    N16112 X-35.676 Z-31.638
    N16113 X-34.839 Z-32.859
    N16114 X-34.002 Z-33.989
    N16115 X-33.166 Z-35.047
    N16116 X-32.329 Z-36.043
    N16117 X-31.408 Z-37.073
    N16118 X-30.487 Z-38.035
    N16119 X-29.566 Z-38.941
    N16120 X-28.645 Z-39.796
    N16121 X-27.77 Z-40.565
    N16122 X-26.895 Z-41.292
    N16123 X-26.02 Z-41.981
    N16124 X-25.145 Z-42.634
    N16125 X-24.233 Z-43.278
    N16126 X-23.321 Z-43.886
    N16127 X-22.41 Z-44.462
    N16128 X-21.498 Z-45.007
    N16129 X-19.729 Z-45.98
    N16130 X-17.961 Z-46.848
    N16131 X-16.151 Z-47.634
    N16132 X-14.342 Z-48.323
    N16133 X-12.559 Z-48.913
    N16134 X-10.776 Z-49.418
    N16135 X-8.958 Z-49.849
    N16136 X-7.169 Z-50.192
    N16137 X-5.362 Z-50.46
    N16138 X-3.592 Z-50.648
    N16139 X-1.797 Z-50.761
    N16140 X0. Z-50.8
    N16141 X1.797 Z-50.761
    N16142 X3.592 Z-50.648
    N16143 X5.362 Z-50.46
    N16144 X7.169 Z-50.192
    N16145 X8.958 Z-49.849
    N16146 X10.776 Z-49.418
    N16147 X12.559 Z-48.913
    N16148 X14.342 Z-48.323
    N16149 X16.151 Z-47.634
    N16150 X17.961 Z-46.848
    N16151 X18.845 Z-46.427
    N16152 X20.614 Z-45.507
    N16153 X22.41 Z-44.462
    N16154 X23.321 Z-43.886
    N16155 X24.233 Z-43.278
    N16156 X25.145 Z-42.634
    N16157 X26.02 Z-41.981
    N16158 X26.895 Z-41.292
    N16159 X27.77 Z-40.565
    N16160 X28.645 Z-39.796
    N16161 X29.566 Z-38.941
    N16162 X30.487 Z-38.035
    N16163 X31.408 Z-37.073
    N16164 X32.329 Z-36.043
    N16165 X33.166 Z-35.047
    N16166 X34.002 Z-33.989
    N16167 X34.839 Z-32.859
    N16168 X35.676 Z-31.638
    N16169 X36.156 Z-30.898
    N16170 X37.115 Z-29.312
    N16171 X38.074 Z-27.548
    N16172 X38.554 Z-26.583
    N16173 X39.033 Z-25.551
    N16174 X39.758 Z-23.846
    N16175 X40.491 Z-21.866
    N16176 X40.979 Z-20.339
    N16177 X41.571 Z-18.178
    N16178 X42.184 Z-15.229
    N16179 X42.44 Z-13.52
    N16180 X42.798 Z-9.748
    N16181 X43.003 Z-8.618
    N16182 X43.217 Z-7.836
    N16183 X43.554 Z-6.907
    N16184 X43.779 Z-6.406
    N16185 X44.228 Z-5.548
    N16186 X44.677 Z-4.839
    N16187 X45.35 Z-3.957
    N16188 X45.799 Z-3.462
    N16189 X46.248 Z-3.014
    N16190 X46.697 Z-2.617
    N16191 X47.146 Z-2.26
    N16192 X47.595 Z-1.937
    N16193 X48.493 Z-1.386
    N16194 X49.391 Z-.943
    N16195 X50.289 Z-.594
    N16196 X51.187 Z-.33
    N16197 X52.085 Z-.145
    N16198 X52.984 Z-.036
    N16199 X53.882 Z0.
    N16200 Y-67.825
    N16201 X52.984 Z-.036
    N16202 X52.085 Z-.145
    N16203 X51.187 Z-.33
    N16204 X50.289 Z-.594
    N16205 X49.391 Z-.943
    N16206 X48.493 Z-1.386
    N16207 X47.595 Z-1.937
    N16208 X47.146 Z-2.26
    N16209 X46.697 Z-2.618
    N16210 X46.248 Z-3.014
    N16211 X45.799 Z-3.462
    N16212 X45.35 Z-3.957
    N16213 X44.677 Z-4.839
    N16214 X44.228 Z-5.548
    N16215 X43.779 Z-6.406
    N16216 X43.554 Z-6.907
    N16217 X43.217 Z-7.836
    N16218 X43.003 Z-8.618
    N16219 X42.798 Z-9.748
    N16220 X42.44 Z-13.52
    N16221 X42.184 Z-15.229
    N16222 X41.571 Z-18.178
    N16223 X40.979 Z-20.339
    N16224 X40.491 Z-21.866
    N16225 X39.758 Z-23.846
    N16226 X39.033 Z-25.551
    N16227 X38.554 Z-26.583
    N16228 X38.074 Z-27.548
    N16229 X37.115 Z-29.312
    N16230 X36.156 Z-30.898
    N16231 X35.258 Z-32.259
    N16232 X34.839 Z-32.859
    N16233 X34.002 Z-33.989
    N16234 X33.166 Z-35.047
    N16235 X32.329 Z-36.043
    N16236 X31.408 Z-37.073
    N16237 X30.487 Z-38.035
    N16238 X29.566 Z-38.941
    N16239 X28.645 Z-39.796
    N16240 X27.77 Z-40.565
    N16241 X26.895 Z-41.292
    N16242 X26.02 Z-41.981
    N16243 X25.145 Z-42.634
    N16244 X24.233 Z-43.278
    N16245 X23.321 Z-43.886
    N16246 X22.41 Z-44.462
    N16247 X20.614 Z-45.507
    N16248 X18.845 Z-46.427
    N16249 X17.961 Z-46.848
    N16250 X16.151 Z-47.634
    N16251 X14.342 Z-48.323
    N16252 X12.559 Z-48.913
    N16253 X10.776 Z-49.418
    N16254 X8.958 Z-49.849
    N16255 X7.169 Z-50.192
    N16256 X5.362 Z-50.46
    N16257 X3.592 Z-50.648
    N16258 X1.797 Z-50.761
    N16259 X0. Z-50.8
    N16260 X-1.797 Z-50.761
    N16261 X-3.592 Z-50.648
    N16262 X-5.362 Z-50.46
    N16263 X-7.169 Z-50.192
    N16264 X-8.958 Z-49.849
    N16265 X-10.776 Z-49.418
    N16266 X-12.559 Z-48.913
    N16267 X-14.342 Z-48.323
    N16268 X-16.151 Z-47.634
    N16269 X-17.961 Z-46.848
    N16270 X-19.729 Z-45.98
    N16271 X-21.498 Z-45.007
    N16272 X-22.41 Z-44.462
    N16273 X-23.321 Z-43.886
    N16274 X-24.233 Z-43.278
    N16275 X-25.145 Z-42.634
    N16276 X-26.02 Z-41.981
    N16277 X-26.895 Z-41.292
    N16278 X-27.77 Z-40.565
    N16279 X-28.645 Z-39.796
    N16280 X-29.566 Z-38.941
    N16281 X-30.487 Z-38.035
    N16282 X-31.408 Z-37.073
    N16283 X-32.329 Z-36.043
    N16284 X-33.166 Z-35.047
    N16285 X-34.002 Z-33.989
    N16286 X-34.839 Z-32.859
    N16287 X-35.676 Z-31.638
    N16288 X-36.635 Z-30.125
    N16289 X-37.595 Z-28.455
    N16290 X-38.074 Z-27.548
    N16291 X-38.554 Z-26.583
    N16292 X-39.033 Z-25.551
    N16293 X-39.758 Z-23.846
    N16294 X-40.491 Z-21.866
    N16295 X-41.346 Z-19.058
    N16296 X-41.98 Z-16.328
    N16297 X-42.491 Z-13.111
    N16298 X-42.798 Z-9.748
    N16299 X-42.901 Z-9.106
    N16300 X-43.105 Z-8.22
    N16301 X-43.33 Z-7.496
    N16302 X-43.554 Z-6.907
    N16303 X-44.003 Z-5.952
    N16304 X-44.452 Z-5.183
    N16305 X-44.901 Z-4.527
    N16306 X-45.35 Z-3.957
    N16307 X-45.799 Z-3.462
    N16308 X-46.248 Z-3.014
    N16309 X-46.697 Z-2.617
    N16310 X-47.146 Z-2.26
    N16311 X-47.595 Z-1.937
    N16312 X-48.493 Z-1.386
    N16313 X-49.391 Z-.943
    N16314 X-50.289 Z-.594
    N16315 X-51.187 Z-.33
    N16316 X-52.085 Z-.145
    N16317 X-52.984 Z-.036
    N16318 X-53.882 Z0.
    N16319 Y-69.025
    N16320 X-52.984 Z-.036
    N16321 X-52.085 Z-.145
    N16322 X-51.187 Z-.33
    N16323 X-50.289 Z-.594
    N16324 X-49.391 Z-.943
    N16325 X-48.493 Z-1.386
    N16326 X-47.595 Z-1.937
    N16327 X-47.146 Z-2.26
    N16328 X-46.697 Z-2.617
    N16329 X-46.248 Z-3.014
    N16330 X-45.799 Z-3.462
    N16331 X-45.35 Z-3.957
    N16332 X-44.901 Z-4.527
    N16333 X-44.452 Z-5.183
    N16334 X-44.003 Z-5.952
    N16335 X-43.554 Z-6.907
    N16336 X-43.33 Z-7.496
    N16337 X-43.105 Z-8.22
    N16338 X-42.901 Z-9.107
    N16339 X-42.798 Z-9.748
    N16340 X-42.491 Z-13.111
    N16341 X-41.98 Z-16.328
    N16342 X-41.346 Z-19.058
    N16343 X-40.491 Z-21.866
    N16344 X-39.758 Z-23.846
    N16345 X-39.033 Z-25.551
    N16346 X-38.554 Z-26.583
    N16347 X-38.074 Z-27.548
    N16348 X-37.595 Z-28.455
    N16349 X-36.635 Z-30.125
    N16350 X-35.676 Z-31.638
    N16351 X-34.839 Z-32.859
    N16352 X-34.002 Z-33.989
    N16353 X-33.166 Z-35.047
    N16354 X-32.329 Z-36.043
    N16355 X-31.408 Z-37.073
    N16356 X-30.487 Z-38.035
    N16357 X-29.566 Z-38.941
    N16358 X-28.645 Z-39.796
    N16359 X-27.77 Z-40.565
    N16360 X-26.895 Z-41.292
    N16361 X-26.02 Z-41.981
    N16362 X-25.145 Z-42.634
    N16363 X-24.233 Z-43.278
    N16364 X-23.321 Z-43.886
    N16365 X-22.41 Z-44.462
    N16366 X-21.498 Z-45.007
    N16367 X-19.729 Z-45.98
    N16368 X-17.961 Z-46.848
    N16369 X-16.151 Z-47.634
    N16370 X-14.342 Z-48.323
    N16371 X-12.559 Z-48.913
    N16372 X-10.776 Z-49.418
    N16373 X-8.958 Z-49.849
    N16374 X-7.169 Z-50.192
    N16375 X-5.362 Z-50.46
    N16376 X-3.592 Z-50.648
    N16377 X-1.797 Z-50.761
    N16378 X0. Z-50.8
    N16379 X1.797 Z-50.761
    N16380 X3.592 Z-50.648
    N16381 X5.362 Z-50.46
    N16382 X7.169 Z-50.192
    N16383 X8.958 Z-49.849
    N16384 X10.776 Z-49.418
    N16385 X12.559 Z-48.913
    N16386 X14.342 Z-48.323
    N16387 X16.151 Z-47.634
    N16388 X17.961 Z-46.848
    N16389 X18.845 Z-46.427
    N16390 X20.614 Z-45.507
    N16391 X22.41 Z-44.462
    N16392 X23.321 Z-43.886
    N16393 X24.233 Z-43.278
    N16394 X25.145 Z-42.634
    N16395 X26.02 Z-41.981
    N16396 X26.895 Z-41.292
    N16397 X27.77 Z-40.565
    N16398 X28.645 Z-39.796
    N16399 X29.566 Z-38.941
    N16400 X30.487 Z-38.035
    N16401 X31.408 Z-37.073
    N16402 X32.329 Z-36.043
    N16403 X33.166 Z-35.047
    N16404 X34.002 Z-33.989
    N16405 X34.839 Z-32.859
    N16406 X35.258 Z-32.259
    N16407 X36.156 Z-30.898
    N16408 X37.115 Z-29.312
    N16409 X38.074 Z-27.548
    N16410 X38.554 Z-26.583
    N16411 X39.033 Z-25.551
    N16412 X39.758 Z-23.846
    N16413 X40.491 Z-21.866
    N16414 X40.979 Z-20.339
    N16415 X41.571 Z-18.178
    N16416 X42.184 Z-15.229
    N16417 X42.44 Z-13.52
    N16418 X42.798 Z-9.748
    N16419 X43.003 Z-8.618
    N16420 X43.217 Z-7.836
    N16421 X43.554 Z-6.907
    N16422 X43.779 Z-6.406
    N16423 X44.228 Z-5.548
    N16424 X44.677 Z-4.839
    N16425 X45.35 Z-3.957
    N16426 X45.799 Z-3.462
    N16427 X46.248 Z-3.014
    N16428 X46.697 Z-2.618
    N16429 X47.146 Z-2.259
    N16430 X47.595 Z-1.937
    N16431 X48.493 Z-1.386
    N16432 X49.391 Z-.943
    N16433 X50.289 Z-.594
    N16434 X51.187 Z-.33
    N16435 X52.085 Z-.145
    N16436 X52.984 Z-.036
    N16437 X53.882 Z0.
    N16438 Y-70.225
    N16439 X52.984 Z-.036
    N16440 X52.085 Z-.145
    N16441 X51.187 Z-.33
    N16442 X50.289 Z-.594
    N16443 X49.391 Z-.943
    N16444 X48.493 Z-1.386
    N16445 X47.595 Z-1.937
    N16446 X47.146 Z-2.259
    N16447 X46.697 Z-2.618
    N16448 X46.248 Z-3.014
    N16449 X45.799 Z-3.462
    N16450 X45.35 Z-3.957
    N16451 X44.677 Z-4.839
    N16452 X44.228 Z-5.548
    N16453 X43.779 Z-6.406
    N16454 X43.554 Z-6.907
    N16455 X43.217 Z-7.836
    N16456 X43.003 Z-8.618
    N16457 X42.798 Z-9.748
    N16458 X42.44 Z-13.52
    N16459 X42.184 Z-15.229
    N16460 X41.571 Z-18.178
    N16461 X40.979 Z-20.339
    N16462 X40.491 Z-21.866
    N16463 X39.758 Z-23.846
    N16464 X39.033 Z-25.551
    N16465 X38.554 Z-26.583
    N16466 X38.074 Z-27.548
    N16467 X37.115 Z-29.312
    N16468 X36.156 Z-30.898
    N16469 X35.676 Z-31.638
    N16470 X34.839 Z-32.859
    N16471 X34.002 Z-33.989
    N16472 X33.166 Z-35.047
    N16473 X32.329 Z-36.043
    N16474 X31.408 Z-37.073
    N16475 X30.487 Z-38.035
    N16476 X29.566 Z-38.941
    N16477 X28.645 Z-39.796
    N16478 X27.77 Z-40.565
    N16479 X26.895 Z-41.292
    N16480 X26.02 Z-41.981
    N16481 X25.145 Z-42.634
    N16482 X24.233 Z-43.278
    N16483 X23.321 Z-43.886
    N16484 X22.41 Z-44.462
    N16485 X20.614 Z-45.507
    N16486 X18.845 Z-46.427
    N16487 X17.961 Z-46.848
    N16488 X16.151 Z-47.634
    N16489 X14.342 Z-48.323
    N16490 X12.559 Z-48.913
    N16491 X10.776 Z-49.418
    N16492 X8.958 Z-49.849
    N16493 X7.169 Z-50.192
    N16494 X5.362 Z-50.46
    N16495 X3.592 Z-50.648
    N16496 X1.797 Z-50.761
    N16497 X0. Z-50.8
    N16498 X-1.797 Z-50.761
    N16499 X-3.592 Z-50.648
    N16500 X-5.362 Z-50.46
    N16501 X-7.169 Z-50.192
    N16502 X-8.958 Z-49.849
    N16503 X-10.776 Z-49.418
    N16504 X-12.559 Z-48.913
    N16505 X-14.342 Z-48.323
    N16506 X-16.151 Z-47.634
    N16507 X-17.961 Z-46.848
    N16508 X-19.729 Z-45.98
    N16509 X-21.498 Z-45.007
    N16510 X-22.41 Z-44.462
    N16511 X-23.321 Z-43.886
    N16512 X-24.233 Z-43.278
    N16513 X-25.145 Z-42.634
    N16514 X-26.02 Z-41.981
    N16515 X-26.895 Z-41.292
    N16516 X-27.77 Z-40.565
    N16517 X-28.645 Z-39.796
    N16518 X-29.566 Z-38.941
    N16519 X-30.487 Z-38.035
    N16520 X-31.408 Z-37.073
    N16521 X-32.329 Z-36.043
    N16522 X-33.166 Z-35.047
    N16523 X-34.002 Z-33.989
    N16524 X-34.839 Z-32.859
    N16525 X-35.676 Z-31.638
    N16526 X-36.635 Z-30.125
    N16527 X-37.595 Z-28.455
    N16528 X-38.074 Z-27.548
    N16529 X-38.554 Z-26.583
    N16530 X-39.033 Z-25.551
    N16531 X-39.758 Z-23.846
    N16532 X-40.491 Z-21.866
    N16533 X-41.346 Z-19.058
    N16534 X-41.98 Z-16.328
    N16535 X-42.491 Z-13.111
    N16536 X-42.798 Z-9.748
    N16537 X-42.901 Z-9.107
    N16538 X-43.105 Z-8.22
    N16539 X-43.33 Z-7.496
    N16540 X-43.554 Z-6.907
    N16541 X-44.003 Z-5.952
    N16542 X-44.452 Z-5.183
    N16543 X-44.901 Z-4.527
    N16544 X-45.35 Z-3.957
    N16545 X-45.799 Z-3.462
    N16546 X-46.248 Z-3.014
    N16547 X-46.697 Z-2.618
    N16548 X-47.146 Z-2.26
    N16549 X-47.595 Z-1.937
    N16550 X-48.493 Z-1.386
    N16551 X-49.391 Z-.943
    N16552 X-50.289 Z-.594
    N16553 X-51.187 Z-.33
    N16554 X-52.085 Z-.145
    N16555 X-52.984 Z-.036
    N16556 X-53.882 Z0.
    N16557 Y-71.425
    N16558 X-52.984 Z-.036
    N16559 X-52.085 Z-.145
    N16560 X-51.187 Z-.33
    N16561 X-50.289 Z-.594
    N16562 X-49.391 Z-.943
    N16563 X-48.493 Z-1.386
    N16564 X-47.595 Z-1.937
    N16565 X-47.146 Z-2.26
    N16566 X-46.697 Z-2.618
    N16567 X-46.248 Z-3.014
    N16568 X-45.799 Z-3.462
    N16569 X-45.35 Z-3.957
    N16570 X-44.901 Z-4.527
    N16571 X-44.452 Z-5.183
    N16572 X-44.003 Z-5.952
    N16573 X-43.554 Z-6.907
    N16574 X-43.33 Z-7.496
    N16575 X-43.105 Z-8.22
    N16576 X-42.901 Z-9.107
    N16577 X-42.798 Z-9.748
    N16578 X-42.491 Z-13.111
    N16579 X-41.98 Z-16.328
    N16580 X-41.346 Z-19.058
    N16581 X-40.491 Z-21.866
    N16582 X-39.758 Z-23.846
    N16583 X-39.033 Z-25.551
    N16584 X-38.554 Z-26.583
    N16585 X-38.074 Z-27.548
    N16586 X-37.595 Z-28.455
    N16587 X-36.635 Z-30.125
    N16588 X-35.676 Z-31.638
    N16589 X-34.839 Z-32.859
    N16590 X-34.002 Z-33.989
    N16591 X-33.166 Z-35.047
    N16592 X-32.329 Z-36.043
    N16593 X-31.408 Z-37.073
    N16594 X-30.487 Z-38.035
    N16595 X-29.566 Z-38.941
    N16596 X-28.645 Z-39.796
    N16597 X-27.77 Z-40.565
    N16598 X-26.895 Z-41.292
    N16599 X-26.02 Z-41.981
    N16600 X-25.145 Z-42.634
    N16601 X-24.233 Z-43.278
    N16602 X-23.321 Z-43.886
    N16603 X-22.41 Z-44.462
    N16604 X-21.498 Z-45.007
    N16605 X-19.729 Z-45.98
    N16606 X-17.961 Z-46.848
    N16607 X-16.151 Z-47.634
    N16608 X-14.342 Z-48.323
    N16609 X-12.559 Z-48.913
    N16610 X-10.776 Z-49.418
    N16611 X-8.958 Z-49.849
    N16612 X-7.169 Z-50.192
    N16613 X-5.362 Z-50.46
    N16614 X-3.592 Z-50.648
    N16615 X-1.797 Z-50.761
    N16616 X0. Z-50.8
    N16617 X1.797 Z-50.761
    N16618 X3.592 Z-50.648
    N16619 X5.362 Z-50.46
    N16620 X7.169 Z-50.192
    N16621 X8.958 Z-49.849
    N16622 X10.776 Z-49.418
    N16623 X12.559 Z-48.913
    N16624 X14.342 Z-48.323
    N16625 X16.151 Z-47.634
    N16626 X17.961 Z-46.848
    N16627 X18.845 Z-46.427
    N16628 X20.614 Z-45.507
    N16629 X22.41 Z-44.462
    N16630 X23.321 Z-43.886
    N16631 X24.233 Z-43.278
    N16632 X25.145 Z-42.634
    N16633 X26.02 Z-41.981
    N16634 X26.895 Z-41.292
    N16635 X27.77 Z-40.565
    N16636 X28.645 Z-39.796
    N16637 X29.566 Z-38.941
    N16638 X30.487 Z-38.035
    N16639 X31.408 Z-37.073
    N16640 X32.329 Z-36.043
    N16641 X33.166 Z-35.047
    N16642 X34.002 Z-33.989
    N16643 X34.839 Z-32.859
    N16644 X35.676 Z-31.638
    N16645 X36.156 Z-30.898
    N16646 X37.115 Z-29.312
    N16647 X38.074 Z-27.548
    N16648 X38.554 Z-26.583
    N16649 X39.033 Z-25.551
    N16650 X39.758 Z-23.846
    N16651 X40.491 Z-21.866
    N16652 X40.979 Z-20.339
    N16653 X41.571 Z-18.178
    N16654 X42.184 Z-15.229
    N16655 X42.44 Z-13.52
    N16656 X42.798 Z-9.748
    N16657 X43.003 Z-8.618
    N16658 X43.217 Z-7.836
    N16659 X43.554 Z-6.907
    N16660 X43.779 Z-6.406
    N16661 X44.228 Z-5.548
    N16662 X44.677 Z-4.839
    N16663 X45.35 Z-3.957
    N16664 X45.799 Z-3.462
    N16665 X46.248 Z-3.014
    N16666 X46.697 Z-2.618
    N16667 X47.146 Z-2.259
    N16668 X47.595 Z-1.937
    N16669 X48.493 Z-1.386
    N16670 X49.391 Z-.943
    N16671 X50.289 Z-.594
    N16672 X51.187 Z-.33
    N16673 X52.085 Z-.145
    N16674 X52.984 Z-.036
    N16675 X53.882 Z0.
    N16676 Y-72.625
    N16677 X52.984 Z-.036
    N16678 X52.085 Z-.145
    N16679 X51.187 Z-.33
    N16680 X50.289 Z-.594
    N16681 X49.391 Z-.943
    N16682 X48.493 Z-1.386
    N16683 X47.595 Z-1.937
    N16684 X47.146 Z-2.259
    N16685 X46.697 Z-2.618
    N16686 X46.248 Z-3.014
    N16687 X45.799 Z-3.462
    N16688 X45.35 Z-3.957
    N16689 X44.677 Z-4.839
    N16690 X44.228 Z-5.548
    N16691 X43.779 Z-6.406
    N16692 X43.554 Z-6.907
    N16693 X43.217 Z-7.836
    N16694 X43.003 Z-8.618
    N16695 X42.798 Z-9.748
    N16696 X42.44 Z-13.52
    N16697 X42.184 Z-15.229
    N16698 X41.571 Z-18.178
    N16699 X40.979 Z-20.339
    N16700 X40.491 Z-21.866
    N16701 X39.758 Z-23.846
    N16702 X39.033 Z-25.551
    N16703 X38.554 Z-26.583
    N16704 X38.074 Z-27.548
    N16705 X37.115 Z-29.312
    N16706 X36.156 Z-30.898
    N16707 X35.676 Z-31.638
    N16708 X34.839 Z-32.859
    N16709 X34.002 Z-33.989
    N16710 X33.166 Z-35.047
    N16711 X32.329 Z-36.043
    N16712 X31.408 Z-37.073
    N16713 X30.487 Z-38.035
    N16714 X29.566 Z-38.941
    N16715 X28.645 Z-39.796
    N16716 X27.77 Z-40.565
    N16717 X26.895 Z-41.292
    N16718 X26.02 Z-41.981
    N16719 X25.145 Z-42.634
    N16720 X24.233 Z-43.278
    N16721 X23.321 Z-43.886
    N16722 X22.41 Z-44.462
    N16723 X20.614 Z-45.507
    N16724 X18.845 Z-46.427
    N16725 X17.961 Z-46.848
    N16726 X16.151 Z-47.634
    N16727 X14.342 Z-48.323
    N16728 X12.559 Z-48.913
    N16729 X10.776 Z-49.418
    N16730 X8.958 Z-49.849
    N16731 X7.169 Z-50.192
    N16732 X5.362 Z-50.46
    N16733 X3.592 Z-50.648
    N16734 X1.797 Z-50.761
    N16735 X0. Z-50.8
    N16736 X-1.797 Z-50.761
    N16737 X-3.592 Z-50.648
    N16738 X-5.362 Z-50.46
    N16739 X-7.169 Z-50.192
    N16740 X-8.958 Z-49.849
    N16741 X-10.776 Z-49.418
    N16742 X-12.559 Z-48.913
    N16743 X-14.342 Z-48.323
    N16744 X-16.151 Z-47.634
    N16745 X-17.961 Z-46.848
    N16746 X-19.729 Z-45.98
    N16747 X-21.498 Z-45.007
    N16748 X-22.41 Z-44.462
    N16749 X-23.321 Z-43.886
    N16750 X-24.233 Z-43.278
    N16751 X-25.145 Z-42.634
    N16752 X-26.02 Z-41.981
    N16753 X-26.895 Z-41.292
    N16754 X-27.77 Z-40.565
    N16755 X-28.645 Z-39.796
    N16756 X-29.566 Z-38.941
    N16757 X-30.487 Z-38.035
    N16758 X-31.408 Z-37.073
    N16759 X-32.329 Z-36.043
    N16760 X-33.166 Z-35.047
    N16761 X-34.002 Z-33.989
    N16762 X-34.839 Z-32.859
    N16763 X-35.676 Z-31.638
    N16764 X-36.635 Z-30.125
    N16765 X-37.595 Z-28.455
    N16766 X-38.074 Z-27.548
    N16767 X-38.554 Z-26.583
    N16768 X-39.033 Z-25.551
    N16769 X-39.758 Z-23.846
    N16770 X-40.491 Z-21.866
    N16771 X-41.346 Z-19.058
    N16772 X-41.98 Z-16.328
    N16773 X-42.491 Z-13.111
    N16774 X-42.798 Z-9.748
    N16775 X-42.901 Z-9.107
    N16776 X-43.105 Z-8.22
    N16777 X-43.33 Z-7.496
    N16778 X-43.554 Z-6.907
    N16779 X-44.003 Z-5.953
    N16780 X-44.452 Z-5.183
    N16781 X-44.901 Z-4.527
    N16782 X-45.35 Z-3.957
    N16783 X-45.799 Z-3.462
    N16784 X-46.248 Z-3.014
    N16785 X-46.697 Z-2.618
    N16786 X-47.146 Z-2.259
    N16787 X-47.595 Z-1.937
    N16788 X-48.493 Z-1.386
    N16789 X-49.391 Z-.943
    N16790 X-50.289 Z-.594
    N16791 X-51.187 Z-.33
    N16792 X-52.085 Z-.145
    N16793 X-52.984 Z-.036
    N16794 X-53.882 Z0.
    N16795 Y-73.825
    N16796 X-52.984 Z-.036
    N16797 X-52.085 Z-.145
    N16798 X-51.187 Z-.33
    N16799 X-50.289 Z-.594
    N16800 X-49.391 Z-.943
    N16801 X-48.493 Z-1.386
    N16802 X-47.595 Z-1.937
    N16803 X-47.146 Z-2.259
    N16804 X-46.697 Z-2.618
    N16805 X-46.248 Z-3.014
    N16806 X-45.799 Z-3.462
    N16807 X-45.35 Z-3.957
    N16808 X-44.901 Z-4.527
    N16809 X-44.452 Z-5.183
    N16810 X-44.003 Z-5.953
    N16811 X-43.554 Z-6.907
    N16812 X-43.33 Z-7.496
    N16813 X-43.105 Z-8.22
    N16814 X-42.901 Z-9.108
    N16815 X-42.798 Z-9.748
    N16816 X-42.491 Z-13.111
    N16817 X-41.98 Z-16.328
    N16818 X-41.346 Z-19.058
    N16819 X-40.491 Z-21.866
    N16820 X-39.758 Z-23.846
    N16821 X-39.033 Z-25.551
    N16822 X-38.554 Z-26.583
    N16823 X-38.074 Z-27.548
    N16824 X-37.595 Z-28.455
    N16825 X-36.635 Z-30.125
    N16826 X-35.676 Z-31.638
    N16827 X-34.839 Z-32.859
    N16828 X-34.002 Z-33.989
    N16829 X-33.166 Z-35.047
    N16830 X-32.329 Z-36.043
    N16831 X-31.408 Z-37.073
    N16832 X-30.487 Z-38.035
    N16833 X-29.566 Z-38.941
    N16834 X-28.645 Z-39.796
    N16835 X-27.77 Z-40.565
    N16836 X-26.895 Z-41.292
    N16837 X-26.02 Z-41.981
    N16838 X-25.145 Z-42.634
    N16839 X-24.233 Z-43.278
    N16840 X-23.321 Z-43.886
    N16841 X-22.41 Z-44.462
    N16842 X-21.498 Z-45.007
    N16843 X-19.729 Z-45.98
    N16844 X-17.961 Z-46.848
    N16845 X-16.151 Z-47.634
    N16846 X-14.342 Z-48.323
    N16847 X-12.559 Z-48.913
    N16848 X-10.776 Z-49.418
    N16849 X-8.958 Z-49.849
    N16850 X-7.169 Z-50.192
    N16851 X-5.362 Z-50.46
    N16852 X-3.592 Z-50.648
    N16853 X-1.797 Z-50.761
    N16854 X0. Z-50.8
    N16855 X1.797 Z-50.761
    N16856 X3.592 Z-50.648
    N16857 X5.362 Z-50.46
    N16858 X7.169 Z-50.192
    N16859 X8.958 Z-49.849
    N16860 X10.776 Z-49.418
    N16861 X12.559 Z-48.913
    N16862 X14.342 Z-48.323
    N16863 X16.151 Z-47.634
    N16864 X17.961 Z-46.848
    N16865 X18.845 Z-46.427
    N16866 X20.614 Z-45.507
    N16867 X22.41 Z-44.462
    N16868 X23.321 Z-43.886
    N16869 X24.233 Z-43.278
    N16870 X25.145 Z-42.634
    N16871 X26.02 Z-41.981
    N16872 X26.895 Z-41.292
    N16873 X27.77 Z-40.565
    N16874 X28.645 Z-39.796
    N16875 X29.566 Z-38.941
    N16876 X30.487 Z-38.035
    N16877 X31.408 Z-37.073
    N16878 X32.329 Z-36.043
    N16879 X33.166 Z-35.047
    N16880 X34.002 Z-33.989
    N16881 X34.839 Z-32.859
    N16882 X35.676 Z-31.638
    N16883 X36.156 Z-30.898
    N16884 X37.115 Z-29.312
    N16885 X38.074 Z-27.548
    N16886 X38.554 Z-26.583
    N16887 X39.033 Z-25.551
    N16888 X39.758 Z-23.846
    N16889 X40.491 Z-21.866
    N16890 X40.979 Z-20.339
    N16891 X41.571 Z-18.178
    N16892 X42.184 Z-15.229
    N16893 X42.44 Z-13.52
    N16894 X42.798 Z-9.748
    N16895 X43.003 Z-8.618
    N16896 X43.217 Z-7.836
    N16897 X43.554 Z-6.907
    N16898 X43.779 Z-6.405
    N16899 X44.228 Z-5.548
    N16900 X44.677 Z-4.839
    N16901 X45.35 Z-3.957
    N16902 X45.799 Z-3.462
    N16903 X46.248 Z-3.014
    N16904 X46.697 Z-2.618
    N16905 X47.146 Z-2.259
    N16906 X47.595 Z-1.937
    N16907 X48.493 Z-1.386
    N16908 X49.391 Z-.943
    N16909 X50.289 Z-.594
    N16910 X51.187 Z-.33
    N16911 X52.085 Z-.145
    N16912 X52.984 Z-.036
    N16913 X53.882 Z0.
    N16914 Y-75.025
    N16915 X52.984 Z-.036
    N16916 X52.085 Z-.145
    N16917 X51.187 Z-.33
    N16918 X50.289 Z-.594
    N16919 X49.391 Z-.943
    N16920 X48.493 Z-1.386
    N16921 X47.595 Z-1.937
    N16922 X47.146 Z-2.259
    N16923 X46.697 Z-2.618
    N16924 X46.248 Z-3.014
    N16925 X45.799 Z-3.462
    N16926 X45.35 Z-3.957
    N16927 X44.677 Z-4.839
    N16928 X44.228 Z-5.548
    N16929 X43.779 Z-6.405
    N16930 X43.554 Z-6.907
    N16931 X43.217 Z-7.836
    N16932 X43.003 Z-8.618
    N16933 X42.798 Z-9.748
    N16934 X42.44 Z-13.52
    N16935 X42.184 Z-15.229
    N16936 X41.571 Z-18.178
    N16937 X40.979 Z-20.339
    N16938 X40.491 Z-21.866
    N16939 X39.758 Z-23.846
    N16940 X39.033 Z-25.551
    N16941 X38.554 Z-26.583
    N16942 X38.074 Z-27.548
    N16943 X37.115 Z-29.312
    N16944 X36.156 Z-30.898
    N16945 X35.676 Z-31.638
    N16946 X34.839 Z-32.859
    N16947 X34.002 Z-33.989
    N16948 X33.166 Z-35.047
    N16949 X32.329 Z-36.043
    N16950 X31.408 Z-37.073
    N16951 X30.487 Z-38.035
    N16952 X29.566 Z-38.941
    N16953 X28.645 Z-39.796
    N16954 X27.77 Z-40.565
    N16955 X26.895 Z-41.292
    N16956 X26.02 Z-41.981
    N16957 X25.145 Z-42.634
    N16958 X24.233 Z-43.278
    N16959 X23.321 Z-43.886
    N16960 X22.41 Z-44.462
    N16961 X20.614 Z-45.507
    N16962 X18.845 Z-46.427
    N16963 X17.961 Z-46.848
    N16964 X16.151 Z-47.634
    N16965 X14.342 Z-48.323
    N16966 X12.559 Z-48.913
    N16967 X10.776 Z-49.418
    N16968 X8.958 Z-49.849
    N16969 X7.169 Z-50.192
    N16970 X5.362 Z-50.46
    N16971 X3.592 Z-50.648
    N16972 X1.797 Z-50.761
    N16973 X0. Z-50.8
    N16974 X-1.797 Z-50.761
    N16975 X-3.592 Z-50.648
    N16976 X-5.362 Z-50.46
    N16977 X-7.169 Z-50.192
    N16978 X-8.958 Z-49.849
    N16979 X-10.776 Z-49.418
    N16980 X-12.559 Z-48.913
    N16981 X-14.342 Z-48.323
    N16982 X-16.151 Z-47.634
    N16983 X-17.961 Z-46.848
    N16984 X-19.729 Z-45.98
    N16985 X-21.498 Z-45.007
    N16986 X-22.41 Z-44.462
    N16987 X-23.321 Z-43.886
    N16988 X-24.233 Z-43.278
    N16989 X-25.145 Z-42.634
    N16990 X-26.02 Z-41.981
    N16991 X-26.895 Z-41.292
    N16992 X-27.77 Z-40.565
    N16993 X-28.645 Z-39.796
    N16994 X-29.566 Z-38.941
    N16995 X-30.487 Z-38.035
    N16996 X-31.408 Z-37.073
    N16997 X-32.329 Z-36.043
    N16998 X-33.166 Z-35.047
    N16999 X-34.002 Z-33.989
    N17000 X-34.839 Z-32.859
    N17001 X-35.676 Z-31.638
    N17002 X-36.635 Z-30.125
    N17003 X-37.595 Z-28.455
    N17004 X-38.074 Z-27.548
    N17005 X-38.554 Z-26.583
    N17006 X-39.033 Z-25.551
    N17007 X-39.758 Z-23.846
    N17008 X-40.491 Z-21.866
    N17009 X-41.346 Z-19.058
    N17010 X-41.98 Z-16.328
    N17011 X-42.491 Z-13.111
    N17012 X-42.798 Z-9.748
    N17013 X-42.901 Z-9.108
    N17014 X-43.105 Z-8.22
    N17015 X-43.33 Z-7.496
    N17016 X-43.554 Z-6.907
    N17017 X-44.003 Z-5.953
    N17018 X-44.452 Z-5.183
    N17019 X-44.901 Z-4.527
    N17020 X-45.35 Z-3.957
    N17021 X-45.799 Z-3.462
    N17022 X-46.248 Z-3.014
    N17023 X-46.697 Z-2.618
    N17024 X-47.146 Z-2.259
    N17025 X-47.595 Z-1.937
    N17026 X-48.493 Z-1.386
    N17027 X-49.391 Z-.943
    N17028 X-50.289 Z-.594
    N17029 X-51.187 Z-.33
    N17030 X-52.085 Z-.145
    N17031 X-52.984 Z-.036
    N17032 X-53.882 Z0.
    N17033 Y-76.225
    N17034 X-52.984 Z-.036
    N17035 X-52.085 Z-.145
    N17036 X-51.187 Z-.33
    N17037 X-50.289 Z-.594
    N17038 X-49.391 Z-.943
    N17039 X-48.493 Z-1.386
    N17040 X-47.595 Z-1.937
    N17041 X-47.146 Z-2.259
    N17042 X-46.697 Z-2.618
    N17043 X-46.248 Z-3.014
    N17044 X-45.799 Z-3.462
    N17045 X-45.35 Z-3.957
    N17046 X-44.901 Z-4.527
    N17047 X-44.452 Z-5.183
    N17048 X-44.003 Z-5.953
    N17049 X-43.554 Z-6.907
    N17050 X-43.33 Z-7.496
    N17051 X-43.105 Z-8.22
    N17052 X-42.901 Z-9.108
    N17053 X-42.798 Z-9.748
    N17054 X-42.491 Z-13.111
    N17055 X-41.98 Z-16.328
    N17056 X-41.346 Z-19.058
    N17057 X-40.491 Z-21.866
    N17058 X-39.758 Z-23.846
    N17059 X-39.033 Z-25.551
    N17060 X-38.554 Z-26.583
    N17061 X-38.074 Z-27.548
    N17062 X-37.595 Z-28.455
    N17063 X-36.635 Z-30.125
    N17064 X-35.676 Z-31.638
    N17065 X-34.839 Z-32.859
    N17066 X-34.002 Z-33.989
    N17067 X-33.166 Z-35.047
    N17068 X-32.329 Z-36.043
    N17069 X-31.408 Z-37.073
    N17070 X-30.487 Z-38.035
    N17071 X-29.566 Z-38.941
    N17072 X-28.645 Z-39.796
    N17073 X-27.77 Z-40.565
    N17074 X-26.895 Z-41.292
    N17075 X-26.02 Z-41.981
    N17076 X-25.145 Z-42.634
    N17077 X-24.233 Z-43.278
    N17078 X-23.321 Z-43.886
    N17079 X-22.41 Z-44.462
    N17080 X-21.498 Z-45.007
    N17081 X-19.729 Z-45.98
    N17082 X-17.961 Z-46.848
    N17083 X-16.151 Z-47.634
    N17084 X-14.342 Z-48.323
    N17085 X-12.559 Z-48.913
    N17086 X-10.776 Z-49.418
    N17087 X-8.958 Z-49.849
    N17088 X-7.169 Z-50.192
    N17089 X-5.362 Z-50.46
    N17090 X-3.592 Z-50.648
    N17091 X-1.797 Z-50.761
    N17092 X0. Z-50.8
    N17093 X1.797 Z-50.761
    N17094 X3.592 Z-50.648
    N17095 X5.362 Z-50.46
    N17096 X7.169 Z-50.192
    N17097 X8.958 Z-49.849
    N17098 X10.776 Z-49.418
    N17099 X12.559 Z-48.913
    N17100 X14.342 Z-48.323
    N17101 X16.151 Z-47.634
    N17102 X17.961 Z-46.848
    N17103 X18.845 Z-46.427
    N17104 X20.614 Z-45.507
    N17105 X22.41 Z-44.462
    N17106 X23.321 Z-43.886
    N17107 X24.233 Z-43.278
    N17108 X25.145 Z-42.634
    N17109 X26.02 Z-41.981
    N17110 X26.895 Z-41.292
    N17111 X27.77 Z-40.565
    N17112 X28.645 Z-39.796
    N17113 X29.566 Z-38.941
    N17114 X30.487 Z-38.035
    N17115 X31.408 Z-37.073
    N17116 X32.329 Z-36.043
    N17117 X33.166 Z-35.047
    N17118 X34.002 Z-33.989
    N17119 X34.839 Z-32.859
    N17120 X35.676 Z-31.638
    N17121 X36.156 Z-30.898
    N17122 X37.115 Z-29.312
    N17123 X38.074 Z-27.548
    N17124 X38.554 Z-26.583
    N17125 X39.033 Z-25.551
    N17126 X39.758 Z-23.846
    N17127 X40.491 Z-21.866
    N17128 X40.979 Z-20.339
    N17129 X41.571 Z-18.178
    N17130 X42.184 Z-15.229
    N17131 X42.44 Z-13.52
    N17132 X42.798 Z-9.748
    N17133 X43.003 Z-8.618
    N17134 X43.217 Z-7.837
    N17135 X43.554 Z-6.907
    N17136 X43.779 Z-6.405
    N17137 X44.228 Z-5.548
    N17138 X44.677 Z-4.839
    N17139 X45.35 Z-3.957
    N17140 X45.799 Z-3.462
    N17141 X46.248 Z-3.014
    N17142 X46.697 Z-2.618
    N17143 X47.146 Z-2.259
    N17144 X47.595 Z-1.937
    N17145 X48.493 Z-1.386
    N17146 X49.391 Z-.943
    N17147 X50.289 Z-.594
    N17148 X51.187 Z-.33
    N17149 X52.085 Z-.145
    N17150 X52.984 Z-.036
    N17151 X53.882 Z0.
    N17152 Y-77.425
    N17153 X52.984 Z-.036
    N17154 X52.085 Z-.145
    N17155 X51.187 Z-.33
    N17156 X50.289 Z-.594
    N17157 X49.391 Z-.943
    N17158 X48.493 Z-1.386
    N17159 X47.595 Z-1.937
    N17160 X47.146 Z-2.259
    N17161 X46.697 Z-2.618
    N17162 X46.248 Z-3.014
    N17163 X45.799 Z-3.462
    N17164 X45.35 Z-3.957
    N17165 X44.677 Z-4.839
    N17166 X44.228 Z-5.548
    N17167 X43.779 Z-6.405
    N17168 X43.554 Z-6.907
    N17169 X43.217 Z-7.837
    N17170 X43.003 Z-8.618
    N17171 X42.798 Z-9.748
    N17172 X42.44 Z-13.52
    N17173 X42.184 Z-15.229
    N17174 X41.571 Z-18.178
    N17175 X40.979 Z-20.339
    N17176 X40.491 Z-21.866
    N17177 X39.758 Z-23.846
    N17178 X39.033 Z-25.551
    N17179 X38.554 Z-26.583
    N17180 X38.074 Z-27.548
    N17181 X37.115 Z-29.312
    N17182 X36.156 Z-30.898
    N17183 X35.676 Z-31.638
    N17184 X34.839 Z-32.859
    N17185 X34.002 Z-33.989
    N17186 X33.166 Z-35.047
    N17187 X32.329 Z-36.043
    N17188 X31.408 Z-37.073
    N17189 X30.487 Z-38.035
    N17190 X29.566 Z-38.941
    N17191 X28.645 Z-39.796
    N17192 X27.77 Z-40.565
    N17193 X26.895 Z-41.292
    N17194 X26.02 Z-41.981
    N17195 X25.145 Z-42.634
    N17196 X24.233 Z-43.278
    N17197 X23.321 Z-43.886
    N17198 X22.41 Z-44.462
    N17199 X20.614 Z-45.507
    N17200 X18.845 Z-46.427
    N17201 X17.961 Z-46.848
    N17202 X16.151 Z-47.634
    N17203 X14.342 Z-48.323
    N17204 X12.559 Z-48.913
    N17205 X10.776 Z-49.418
    N17206 X8.958 Z-49.849
    N17207 X7.169 Z-50.192
    N17208 X5.362 Z-50.46
    N17209 X3.592 Z-50.648
    N17210 X1.797 Z-50.761
    N17211 X0. Z-50.8
    N17212 X-1.797 Z-50.761
    N17213 X-3.592 Z-50.648
    N17214 X-5.362 Z-50.46
    N17215 X-7.169 Z-50.192
    N17216 X-8.958 Z-49.849
    N17217 X-10.776 Z-49.418
    N17218 X-12.559 Z-48.913
    N17219 X-14.342 Z-48.323
    N17220 X-16.151 Z-47.634
    N17221 X-17.961 Z-46.848
    N17222 X-19.729 Z-45.98
    N17223 X-21.498 Z-45.007
    N17224 X-22.41 Z-44.462
    N17225 X-23.321 Z-43.886
    N17226 X-24.233 Z-43.278
    N17227 X-25.145 Z-42.634
    N17228 X-26.02 Z-41.981
    N17229 X-26.895 Z-41.292
    N17230 X-27.77 Z-40.565
    N17231 X-28.645 Z-39.796
    N17232 X-29.566 Z-38.941
    N17233 X-30.487 Z-38.035
    N17234 X-31.408 Z-37.073
    N17235 X-32.329 Z-36.043
    N17236 X-33.166 Z-35.047
    N17237 X-34.002 Z-33.989
    N17238 X-34.839 Z-32.859
    N17239 X-35.676 Z-31.638
    N17240 X-36.635 Z-30.125
    N17241 X-37.595 Z-28.455
    N17242 X-38.074 Z-27.548
    N17243 X-38.554 Z-26.583
    N17244 X-39.033 Z-25.551
    N17245 X-39.758 Z-23.846
    N17246 X-40.491 Z-21.866
    N17247 X-41.346 Z-19.058
    N17248 X-41.98 Z-16.328
    N17249 X-42.491 Z-13.111
    N17250 X-42.798 Z-9.748
    N17251 X-42.901 Z-9.108
    N17252 X-43.105 Z-8.22
    N17253 X-43.33 Z-7.496
    N17254 X-43.554 Z-6.907
    N17255 X-44.003 Z-5.953
    N17256 X-44.452 Z-5.183
    N17257 X-44.901 Z-4.527
    N17258 X-45.35 Z-3.957
    N17259 X-45.799 Z-3.462
    N17260 X-46.248 Z-3.014
    N17261 X-46.697 Z-2.618
    N17262 X-47.146 Z-2.259
    N17263 X-47.595 Z-1.937
    N17264 X-48.493 Z-1.386
    N17265 X-49.391 Z-.943
    N17266 X-50.289 Z-.594
    N17267 X-51.187 Z-.33
    N17268 X-52.085 Z-.145
    N17269 X-52.984 Z-.036
    N17270 X-53.882 Z0.
    N17271 Y-78.625
    N17272 X-52.984 Z-.036
    N17273 X-52.085 Z-.145
    N17274 X-51.187 Z-.33
    N17275 X-50.289 Z-.594
    N17276 X-49.391 Z-.943
    N17277 X-48.493 Z-1.386
    N17278 X-47.595 Z-1.937
    N17279 X-47.146 Z-2.259
    N17280 X-46.697 Z-2.618
    N17281 X-46.248 Z-3.014
    N17282 X-45.799 Z-3.462
    N17283 X-45.35 Z-3.957
    N17284 X-44.901 Z-4.527
    N17285 X-44.452 Z-5.183
    N17286 X-44.003 Z-5.953
    N17287 X-43.554 Z-6.908
    N17288 X-43.33 Z-7.496
    N17289 X-43.105 Z-8.22
    N17290 X-42.901 Z-9.108
    N17291 X-42.798 Z-9.748
    N17292 X-42.491 Z-13.111
    N17293 X-41.98 Z-16.328
    N17294 X-41.346 Z-19.058
    N17295 X-40.491 Z-21.866
    N17296 X-39.758 Z-23.846
    N17297 X-39.033 Z-25.551
    N17298 X-38.554 Z-26.583
    N17299 X-38.074 Z-27.548
    N17300 X-37.595 Z-28.455
    N17301 X-36.635 Z-30.125
    N17302 X-35.676 Z-31.638
    N17303 X-34.839 Z-32.859
    N17304 X-34.002 Z-33.989
    N17305 X-33.166 Z-35.047
    N17306 X-32.329 Z-36.043
    N17307 X-31.408 Z-37.073
    N17308 X-30.487 Z-38.035
    N17309 X-29.566 Z-38.941
    N17310 X-28.645 Z-39.796
    N17311 X-27.77 Z-40.565
    N17312 X-26.895 Z-41.292
    N17313 X-26.02 Z-41.981
    N17314 X-25.145 Z-42.634
    N17315 X-24.233 Z-43.278
    N17316 X-23.321 Z-43.886
    N17317 X-22.41 Z-44.462
    N17318 X-21.498 Z-45.007
    N17319 X-19.729 Z-45.98
    N17320 X-17.961 Z-46.848
    N17321 X-16.151 Z-47.634
    N17322 X-14.342 Z-48.323
    N17323 X-12.559 Z-48.913
    N17324 X-10.776 Z-49.418
    N17325 X-8.958 Z-49.849
    N17326 X-7.169 Z-50.192
    N17327 X-5.362 Z-50.46
    N17328 X-3.592 Z-50.648
    N17329 X-1.797 Z-50.761
    N17330 X0. Z-50.8
    N17331 X1.797 Z-50.761
    N17332 X3.592 Z-50.648
    N17333 X5.362 Z-50.46
    N17334 X7.169 Z-50.192
    N17335 X8.958 Z-49.849
    N17336 X10.776 Z-49.418
    N17337 X12.559 Z-48.913
    N17338 X14.342 Z-48.323
    N17339 X16.151 Z-47.634
    N17340 X17.961 Z-46.848
    N17341 X18.845 Z-46.427
    N17342 X20.614 Z-45.507
    N17343 X22.41 Z-44.462
    N17344 X23.321 Z-43.886
    N17345 X24.233 Z-43.278
    N17346 X25.145 Z-42.634
    N17347 X26.02 Z-41.981
    N17348 X26.895 Z-41.292
    N17349 X27.77 Z-40.565
    N17350 X28.645 Z-39.796
    N17351 X29.566 Z-38.941
    N17352 X30.487 Z-38.035
    N17353 X31.408 Z-37.073
    N17354 X32.329 Z-36.043
    N17355 X33.166 Z-35.047
    N17356 X34.002 Z-33.989
    N17357 X34.839 Z-32.859
    N17358 X35.676 Z-31.638
    N17359 X36.156 Z-30.898
    N17360 X37.115 Z-29.312
    N17361 X38.074 Z-27.548
    N17362 X38.554 Z-26.583
    N17363 X39.033 Z-25.551
    N17364 X39.758 Z-23.846
    N17365 X40.491 Z-21.866
    N17366 X40.979 Z-20.339
    N17367 X41.571 Z-18.178
    N17368 X42.184 Z-15.229
    N17369 X42.44 Z-13.52
    N17370 X42.798 Z-9.748
    N17371 X43.003 Z-8.618
    N17372 X43.217 Z-7.837
    N17373 X43.554 Z-6.908
    N17374 X43.779 Z-6.405
    N17375 X44.228 Z-5.548
    N17376 X44.677 Z-4.839
    N17377 X45.35 Z-3.957
    N17378 X45.799 Z-3.462
    N17379 X46.248 Z-3.014
    N17380 X46.697 Z-2.618
    N17381 X47.146 Z-2.259
    N17382 X47.595 Z-1.937
    N17383 X48.493 Z-1.386
    N17384 X49.391 Z-.943
    N17385 X50.289 Z-.594
    N17386 X51.187 Z-.33
    N17387 X52.085 Z-.145
    N17388 X52.984 Z-.036
    N17389 X53.882 Z0.
    N17390 Y-79.825
    N17391 X52.984 Z-.036
    N17392 X52.085 Z-.145
    N17393 X51.187 Z-.33
    N17394 X50.289 Z-.594
    N17395 X49.391 Z-.943
    N17396 X48.493 Z-1.386
    N17397 X47.595 Z-1.937
    N17398 X47.146 Z-2.259
    N17399 X46.697 Z-2.618
    N17400 X46.248 Z-3.014
    N17401 X45.799 Z-3.462
    N17402 X45.35 Z-3.957
    N17403 X44.677 Z-4.839
    N17404 X44.228 Z-5.548
    N17405 X43.779 Z-6.405
    N17406 X43.554 Z-6.908
    N17407 X43.217 Z-7.837
    N17408 X43.003 Z-8.618
    N17409 X42.798 Z-9.748
    N17410 X42.44 Z-13.52
    N17411 X42.184 Z-15.229
    N17412 X41.571 Z-18.178
    N17413 X40.979 Z-20.339
    N17414 X40.491 Z-21.866
    N17415 X39.758 Z-23.846
    N17416 X39.033 Z-25.551
    N17417 X38.554 Z-26.583
    N17418 X38.074 Z-27.548
    N17419 X37.115 Z-29.312
    N17420 X36.156 Z-30.898
    N17421 X35.676 Z-31.638
    N17422 X34.839 Z-32.859
    N17423 X34.002 Z-33.989
    N17424 X33.166 Z-35.047
    N17425 X32.329 Z-36.043
    N17426 X31.408 Z-37.073
    N17427 X30.487 Z-38.035
    N17428 X29.566 Z-38.941
    N17429 X28.645 Z-39.796
    N17430 X27.77 Z-40.565
    N17431 X26.895 Z-41.292
    N17432 X26.02 Z-41.981
    N17433 X25.145 Z-42.634
    N17434 X24.233 Z-43.278
    N17435 X23.321 Z-43.886
    N17436 X22.41 Z-44.462
    N17437 X20.614 Z-45.507
    N17438 X18.845 Z-46.427
    N17439 X17.961 Z-46.848
    N17440 X16.151 Z-47.634
    N17441 X14.342 Z-48.323
    N17442 X12.559 Z-48.913
    N17443 X10.776 Z-49.418
    N17444 X8.958 Z-49.849
    N17445 X7.169 Z-50.192
    N17446 X5.362 Z-50.46
    N17447 X3.592 Z-50.648
    N17448 X1.797 Z-50.761
    N17449 X0. Z-50.8
    N17450 X-1.797 Z-50.761
    N17451 X-3.592 Z-50.648
    N17452 X-5.362 Z-50.46
    N17453 X-7.169 Z-50.192
    N17454 X-8.958 Z-49.849
    N17455 X-10.776 Z-49.418
    N17456 X-12.559 Z-48.913
    N17457 X-14.342 Z-48.323
    N17458 X-16.151 Z-47.634
    N17459 X-17.961 Z-46.848
    N17460 X-19.729 Z-45.98
    N17461 X-21.498 Z-45.007
    N17462 X-22.41 Z-44.462
    N17463 X-23.321 Z-43.886
    N17464 X-24.233 Z-43.278
    N17465 X-25.145 Z-42.634
    N17466 X-26.02 Z-41.981
    N17467 X-26.895 Z-41.292
    N17468 X-27.77 Z-40.565
    N17469 X-28.645 Z-39.796
    N17470 X-29.566 Z-38.941
    N17471 X-30.487 Z-38.035
    N17472 X-31.408 Z-37.073
    N17473 X-32.329 Z-36.043
    N17474 X-33.166 Z-35.047
    N17475 X-34.002 Z-33.989
    N17476 X-34.839 Z-32.859
    N17477 X-35.676 Z-31.638
    N17478 X-36.635 Z-30.125
    N17479 X-37.595 Z-28.455
    N17480 X-38.074 Z-27.548
    N17481 X-38.554 Z-26.583
    N17482 X-39.033 Z-25.551
    N17483 X-39.758 Z-23.846
    N17484 X-40.491 Z-21.866
    N17485 X-41.346 Z-19.058
    N17486 X-41.98 Z-16.328
    N17487 X-42.491 Z-13.111
    N17488 X-42.798 Z-9.748
    N17489 X-42.901 Z-9.109
    N17490 X-43.105 Z-8.22
    N17491 X-43.33 Z-7.496
    N17492 X-43.554 Z-6.908
    N17493 X-44.003 Z-5.953
    N17494 X-44.452 Z-5.183
    N17495 X-44.901 Z-4.527
    N17496 X-45.35 Z-3.957
    N17497 X-45.799 Z-3.462
    N17498 X-46.248 Z-3.014
    N17499 X-46.697 Z-2.618
    N17500 X-47.146 Z-2.259
    N17501 X-47.595 Z-1.937
    N17502 X-48.493 Z-1.386
    N17503 X-49.391 Z-.943
    N17504 X-50.289 Z-.594
    N17505 X-51.187 Z-.33
    N17506 X-52.085 Z-.145
    N17507 X-52.984 Z-.036
    N17508 X-53.882 Z0.
    N17509 Y-81.025
    N17510 X-52.984 Z-.036
    N17511 X-52.085 Z-.145
    N17512 X-51.187 Z-.33
    N17513 X-50.289 Z-.594
    N17514 X-49.391 Z-.943
    N17515 X-48.493 Z-1.386
    N17516 X-47.595 Z-1.937
    N17517 X-47.146 Z-2.259
    N17518 X-46.697 Z-2.618
    N17519 X-46.248 Z-3.014
    N17520 X-45.799 Z-3.462
    N17521 X-45.35 Z-3.957
    N17522 X-44.901 Z-4.527
    N17523 X-44.452 Z-5.183
    N17524 X-44.003 Z-5.953
    N17525 X-43.554 Z-6.908
    N17526 X-43.33 Z-7.496
    N17527 X-43.105 Z-8.22
    N17528 X-42.901 Z-9.109
    N17529 X-42.798 Z-9.748
    N17530 X-42.491 Z-13.111
    N17531 X-41.98 Z-16.328
    N17532 X-41.346 Z-19.058
    N17533 X-40.491 Z-21.866
    N17534 X-39.758 Z-23.846
    N17535 X-39.033 Z-25.551
    N17536 X-38.554 Z-26.583
    N17537 X-38.074 Z-27.548
    N17538 X-37.595 Z-28.455
    N17539 X-36.635 Z-30.125
    N17540 X-35.676 Z-31.638
    N17541 X-34.839 Z-32.859
    N17542 X-34.002 Z-33.989
    N17543 X-33.166 Z-35.047
    N17544 X-32.329 Z-36.043
    N17545 X-31.408 Z-37.073
    N17546 X-30.487 Z-38.035
    N17547 X-29.566 Z-38.941
    N17548 X-28.645 Z-39.796
    N17549 X-27.77 Z-40.565
    N17550 X-26.895 Z-41.292
    N17551 X-26.02 Z-41.981
    N17552 X-25.145 Z-42.634
    N17553 X-24.233 Z-43.278
    N17554 X-23.321 Z-43.886
    N17555 X-22.41 Z-44.462
    N17556 X-21.498 Z-45.007
    N17557 X-19.729 Z-45.98
    N17558 X-17.961 Z-46.848
    N17559 X-16.151 Z-47.634
    N17560 X-14.342 Z-48.323
    N17561 X-12.559 Z-48.913
    N17562 X-10.776 Z-49.418
    N17563 X-8.958 Z-49.849
    N17564 X-7.169 Z-50.192
    N17565 X-5.362 Z-50.46
    N17566 X-3.592 Z-50.648
    N17567 X-1.797 Z-50.761
    N17568 X0. Z-50.8
    N17569 X1.797 Z-50.761
    N17570 X3.592 Z-50.648
    N17571 X5.362 Z-50.46
    N17572 X7.169 Z-50.192
    N17573 X8.958 Z-49.849
    N17574 X10.776 Z-49.418
    N17575 X12.559 Z-48.913
    N17576 X14.342 Z-48.323
    N17577 X16.151 Z-47.634
    N17578 X17.961 Z-46.848
    N17579 X18.845 Z-46.427
    N17580 X20.614 Z-45.507
    N17581 X22.41 Z-44.462
    N17582 X23.321 Z-43.886
    N17583 X24.233 Z-43.278
    N17584 X25.145 Z-42.634
    N17585 X26.02 Z-41.981
    N17586 X26.895 Z-41.292
    N17587 X27.77 Z-40.565
    N17588 X28.645 Z-39.796
    N17589 X29.566 Z-38.941
    N17590 X30.487 Z-38.035
    N17591 X31.408 Z-37.073
    N17592 X32.329 Z-36.043
    N17593 X33.166 Z-35.047
    N17594 X34.002 Z-33.989
    N17595 X34.839 Z-32.859
    N17596 X35.676 Z-31.638
    N17597 X36.156 Z-30.898
    N17598 X37.115 Z-29.312
    N17599 X38.074 Z-27.548
    N17600 X38.554 Z-26.583
    N17601 X39.033 Z-25.551
    N17602 X39.758 Z-23.846
    N17603 X40.491 Z-21.866
    N17604 X40.979 Z-20.339
    N17605 X41.571 Z-18.178
    N17606 X42.184 Z-15.229
    N17607 X42.44 Z-13.52
    N17608 X42.798 Z-9.748
    N17609 X43.003 Z-8.618
    N17610 X43.217 Z-7.837
    N17611 X43.554 Z-6.908
    N17612 X43.779 Z-6.405
    N17613 X44.228 Z-5.548
    N17614 X44.677 Z-4.839
    N17615 X45.35 Z-3.957
    N17616 X45.799 Z-3.462
    N17617 X46.248 Z-3.014
    N17618 X46.697 Z-2.618
    N17619 X47.146 Z-2.259
    N17620 X47.595 Z-1.937
    N17621 X48.493 Z-1.386
    N17622 X49.391 Z-.943
    N17623 X50.289 Z-.594
    N17624 X51.187 Z-.33
    N17625 X52.085 Z-.145
    N17626 X52.984 Z-.036
    N17627 X53.882 Z0.
    N17628 Y-82.225
    N17629 X52.984 Z-.036
    N17630 X52.085 Z-.145
    N17631 X51.187 Z-.33
    N17632 X50.289 Z-.594
    N17633 X49.391 Z-.943
    N17634 X48.493 Z-1.386
    N17635 X47.595 Z-1.937
    N17636 X47.146 Z-2.259
    N17637 X46.697 Z-2.618
    N17638 X46.248 Z-3.014
    N17639 X45.799 Z-3.462
    N17640 X45.35 Z-3.957
    N17641 X44.677 Z-4.839
    N17642 X44.228 Z-5.547
    N17643 X43.779 Z-6.405
    N17644 X43.554 Z-6.908
    N17645 X43.217 Z-7.837
    N17646 X43.003 Z-8.618
    N17647 X42.798 Z-9.748
    N17648 X42.44 Z-13.52
    N17649 X42.184 Z-15.229
    N17650 X41.571 Z-18.178
    N17651 X40.979 Z-20.339
    N17652 X40.491 Z-21.866
    N17653 X39.758 Z-23.846
    N17654 X39.033 Z-25.551
    N17655 X38.554 Z-26.583
    N17656 X38.074 Z-27.548
    N17657 X37.115 Z-29.312
    N17658 X36.156 Z-30.898
    N17659 X35.676 Z-31.638
    N17660 X34.839 Z-32.859
    N17661 X34.002 Z-33.989
    N17662 X33.166 Z-35.047
    N17663 X32.329 Z-36.043
    N17664 X31.408 Z-37.073
    N17665 X30.487 Z-38.035
    N17666 X29.566 Z-38.941
    N17667 X28.645 Z-39.796
    N17668 X27.77 Z-40.565
    N17669 X26.895 Z-41.292
    N17670 X26.02 Z-41.981
    N17671 X25.145 Z-42.634
    N17672 X24.233 Z-43.278
    N17673 X23.321 Z-43.886
    N17674 X22.41 Z-44.462
    N17675 X20.614 Z-45.507
    N17676 X18.845 Z-46.427
    N17677 X17.961 Z-46.848
    N17678 X16.151 Z-47.634
    N17679 X14.342 Z-48.323
    N17680 X12.559 Z-48.913
    N17681 X10.776 Z-49.418
    N17682 X8.958 Z-49.849
    N17683 X7.169 Z-50.192
    N17684 X5.362 Z-50.46
    N17685 X3.592 Z-50.648
    N17686 X1.797 Z-50.761
    N17687 X0. Z-50.8
    N17688 X-1.797 Z-50.761
    N17689 X-3.592 Z-50.648
    N17690 X-5.362 Z-50.46
    N17691 X-7.169 Z-50.192
    N17692 X-8.958 Z-49.849
    N17693 X-10.776 Z-49.418
    N17694 X-12.559 Z-48.913
    N17695 X-14.342 Z-48.323
    N17696 X-16.151 Z-47.634
    N17697 X-17.961 Z-46.848
    N17698 X-19.729 Z-45.98
    N17699 X-21.498 Z-45.007
    N17700 X-22.41 Z-44.462
    N17701 X-23.321 Z-43.886
    N17702 X-24.233 Z-43.278
    N17703 X-25.145 Z-42.634
    N17704 X-26.02 Z-41.981
    N17705 X-26.895 Z-41.292
    N17706 X-27.77 Z-40.565
    N17707 X-28.645 Z-39.796
    N17708 X-29.566 Z-38.941
    N17709 X-30.487 Z-38.035
    N17710 X-31.408 Z-37.073
    N17711 X-32.329 Z-36.043
    N17712 X-33.166 Z-35.047
    N17713 X-34.002 Z-33.989
    N17714 X-34.839 Z-32.859
    N17715 X-35.676 Z-31.638
    N17716 X-36.635 Z-30.125
    N17717 X-37.595 Z-28.455
    N17718 X-38.074 Z-27.548
    N17719 X-38.554 Z-26.583
    N17720 X-39.033 Z-25.551
    N17721 X-39.758 Z-23.846
    N17722 X-40.491 Z-21.866
    N17723 X-41.346 Z-19.058
    N17724 X-41.98 Z-16.328
    N17725 X-42.491 Z-13.111
    N17726 X-42.798 Z-9.748
    N17727 X-42.901 Z-9.109
    N17728 X-43.105 Z-8.221
    N17729 X-43.33 Z-7.496
    N17730 X-43.554 Z-6.908
    N17731 X-44.003 Z-5.953
    N17732 X-44.452 Z-5.183
    N17733 X-44.901 Z-4.527
    N17734 X-45.35 Z-3.957
    N17735 X-45.799 Z-3.462
    N17736 X-46.248 Z-3.014
    N17737 X-46.697 Z-2.618
    N17738 X-47.146 Z-2.259
    N17739 X-47.595 Z-1.937
    N17740 X-48.493 Z-1.386
    N17741 X-49.391 Z-.943
    N17742 X-50.289 Z-.594
    N17743 X-51.187 Z-.33
    N17744 X-52.085 Z-.145
    N17745 X-52.984 Z-.036
    N17746 X-53.882 Z0.
    N17747 Y-83.425
    N17748 X-52.984 Z-.036
    N17749 X-52.085 Z-.145
    N17750 X-51.187 Z-.33
    N17751 X-50.289 Z-.594
    N17752 X-49.391 Z-.943
    N17753 X-48.493 Z-1.386
    N17754 X-47.595 Z-1.937
    N17755 X-47.146 Z-2.259
    N17756 X-46.697 Z-2.618
    N17757 X-46.248 Z-3.014
    N17758 X-45.799 Z-3.462
    N17759 X-45.35 Z-3.957
    N17760 X-44.901 Z-4.527
    N17761 X-44.452 Z-5.183
    N17762 X-44.003 Z-5.953
    N17763 X-43.554 Z-6.908
    N17764 X-43.33 Z-7.496
    N17765 X-43.105 Z-8.221
    N17766 X-42.901 Z-9.109
    N17767 X-42.798 Z-9.749
    N17768 X-42.491 Z-13.111
    N17769 X-41.98 Z-16.328
    N17770 X-41.346 Z-19.058
    N17771 X-40.491 Z-21.866
    N17772 X-39.758 Z-23.846
    N17773 X-39.033 Z-25.551
    N17774 X-38.554 Z-26.583
    N17775 X-38.074 Z-27.548
    N17776 X-37.595 Z-28.455
    N17777 X-36.635 Z-30.125
    N17778 X-35.676 Z-31.638
    N17779 X-34.839 Z-32.859
    N17780 X-34.002 Z-33.989
    N17781 X-33.166 Z-35.047
    N17782 X-32.329 Z-36.043
    N17783 X-31.408 Z-37.073
    N17784 X-30.487 Z-38.035
    N17785 X-29.566 Z-38.941
    N17786 X-28.645 Z-39.796
    N17787 X-27.77 Z-40.565
    N17788 X-26.895 Z-41.292
    N17789 X-26.02 Z-41.981
    N17790 X-25.145 Z-42.634
    N17791 X-24.233 Z-43.278
    N17792 X-23.321 Z-43.886
    N17793 X-22.41 Z-44.462
    N17794 X-21.498 Z-45.007
    N17795 X-19.729 Z-45.98
    N17796 X-17.961 Z-46.848
    N17797 X-16.151 Z-47.634
    N17798 X-14.342 Z-48.323
    N17799 X-12.559 Z-48.913
    N17800 X-10.776 Z-49.418
    N17801 X-8.958 Z-49.849
    N17802 X-7.169 Z-50.192
    N17803 X-5.362 Z-50.46
    N17804 X-3.592 Z-50.648
    N17805 X-1.797 Z-50.761
    N17806 X0. Z-50.8
    N17807 X1.797 Z-50.761
    N17808 X3.592 Z-50.648
    N17809 X5.362 Z-50.46
    N17810 X7.169 Z-50.192
    N17811 X8.958 Z-49.849
    N17812 X10.776 Z-49.418
    N17813 X12.559 Z-48.913
    N17814 X14.342 Z-48.323
    N17815 X16.151 Z-47.634
    N17816 X17.961 Z-46.848
    N17817 X18.845 Z-46.427
    N17818 X20.614 Z-45.507
    N17819 X22.41 Z-44.462
    N17820 X23.321 Z-43.886
    N17821 X24.233 Z-43.278
    N17822 X25.145 Z-42.634
    N17823 X26.02 Z-41.981
    N17824 X26.895 Z-41.292
    N17825 X27.77 Z-40.565
    N17826 X28.645 Z-39.796
    N17827 X29.566 Z-38.941
    N17828 X30.487 Z-38.035
    N17829 X31.408 Z-37.073
    N17830 X32.329 Z-36.043
    N17831 X33.166 Z-35.047
    N17832 X34.002 Z-33.989
    N17833 X34.839 Z-32.859
    N17834 X35.676 Z-31.638
    N17835 X36.156 Z-30.898
    N17836 X37.115 Z-29.312
    N17837 X38.074 Z-27.548
    N17838 X38.554 Z-26.583
    N17839 X39.033 Z-25.551
    N17840 X39.758 Z-23.846
    N17841 X40.491 Z-21.866
    N17842 X40.979 Z-20.339
    N17843 X41.571 Z-18.178
    N17844 X42.184 Z-15.229
    N17845 X42.44 Z-13.52
    N17846 X42.798 Z-9.749
    N17847 X43.003 Z-8.618
    N17848 X43.217 Z-7.837
    N17849 X43.554 Z-6.908
    N17850 X43.779 Z-6.405
    N17851 X44.228 Z-5.547
    N17852 X44.677 Z-4.839
    N17853 X45.35 Z-3.957
    N17854 X45.799 Z-3.462
    N17855 X46.248 Z-3.014
    N17856 X46.697 Z-2.618
    N17857 X47.146 Z-2.259
    N17858 X47.595 Z-1.938
    N17859 X48.493 Z-1.386
    N17860 X49.391 Z-.943
    N17861 X50.289 Z-.594
    N17862 X51.187 Z-.33
    N17863 X52.085 Z-.145
    N17864 X52.984 Z-.036
    N17865 X53.882 Z0.
    N17866 Y-84.625
    N17867 X52.984 Z-.036
    N17868 X52.085 Z-.145
    N17869 X51.187 Z-.33
    N17870 X50.289 Z-.594
    N17871 X49.391 Z-.943
    N17872 X48.493 Z-1.387
    N17873 X47.595 Z-1.938
    N17874 X47.146 Z-2.259
    N17875 X46.697 Z-2.618
    N17876 X46.248 Z-3.014
    N17877 X45.799 Z-3.462
    N17878 X45.35 Z-3.957
    N17879 X44.677 Z-4.839
    N17880 X44.228 Z-5.547
    N17881 X43.779 Z-6.404
    N17882 X43.554 Z-6.908
    N17883 X43.217 Z-7.837
    N17884 X43.003 Z-8.618
    N17885 X42.798 Z-9.749
    N17886 X42.44 Z-13.52
    N17887 X42.184 Z-15.229
    N17888 X41.571 Z-18.178
    N17889 X40.979 Z-20.339
    N17890 X40.491 Z-21.866
    N17891 X39.758 Z-23.846
    N17892 X39.033 Z-25.551
    N17893 X38.554 Z-26.583
    N17894 X38.074 Z-27.548
    N17895 X37.115 Z-29.312
    N17896 X36.156 Z-30.898
    N17897 X35.676 Z-31.638
    N17898 X34.839 Z-32.859
    N17899 X34.002 Z-33.989
    N17900 X33.166 Z-35.047
    N17901 X32.329 Z-36.043
    N17902 X31.408 Z-37.073
    N17903 X30.487 Z-38.035
    N17904 X29.566 Z-38.941
    N17905 X28.645 Z-39.796
    N17906 X27.77 Z-40.565
    N17907 X26.895 Z-41.292
    N17908 X26.02 Z-41.981
    N17909 X25.145 Z-42.634
    N17910 X24.233 Z-43.278
    N17911 X23.321 Z-43.886
    N17912 X22.41 Z-44.462
    N17913 X20.614 Z-45.507
    N17914 X18.845 Z-46.427
    N17915 X17.961 Z-46.848
    N17916 X16.151 Z-47.634
    N17917 X14.342 Z-48.323
    N17918 X12.559 Z-48.913
    N17919 X10.776 Z-49.418
    N17920 X8.958 Z-49.849
    N17921 X7.169 Z-50.192
    N17922 X5.362 Z-50.46
    N17923 X3.592 Z-50.648
    N17924 X1.797 Z-50.761
    N17925 X0. Z-50.8
    N17926 X-1.797 Z-50.761
    N17927 X-3.592 Z-50.648
    N17928 X-5.362 Z-50.46
    N17929 X-7.169 Z-50.192
    N17930 X-8.958 Z-49.849
    N17931 X-10.776 Z-49.418
    N17932 X-12.559 Z-48.913
    N17933 X-14.342 Z-48.323
    N17934 X-16.151 Z-47.634
    N17935 X-17.961 Z-46.848
    N17936 X-19.729 Z-45.98
    N17937 X-21.498 Z-45.007
    N17938 X-22.41 Z-44.462
    N17939 X-23.321 Z-43.886
    N17940 X-24.233 Z-43.278
    N17941 X-25.145 Z-42.634
    N17942 X-26.02 Z-41.981
    N17943 X-26.895 Z-41.292
    N17944 X-27.77 Z-40.565
    N17945 X-28.645 Z-39.796
    N17946 X-29.566 Z-38.941
    N17947 X-30.487 Z-38.035
    N17948 X-31.408 Z-37.073
    N17949 X-32.329 Z-36.043
    N17950 X-33.166 Z-35.047
    N17951 X-34.002 Z-33.989
    N17952 X-34.839 Z-32.859
    N17953 X-35.676 Z-31.638
    N17954 X-36.635 Z-30.125
    N17955 X-37.595 Z-28.455
    N17956 X-38.074 Z-27.548
    N17957 X-38.554 Z-26.583
    N17958 X-39.033 Z-25.551
    N17959 X-39.758 Z-23.846
    N17960 X-40.491 Z-21.866
    N17961 X-41.346 Z-19.058
    N17962 X-41.98 Z-16.328
    N17963 X-42.491 Z-13.111
    N17964 X-42.798 Z-9.749
    N17965 X-42.901 Z-9.11
    N17966 X-43.105 Z-8.221
    N17967 X-43.33 Z-7.496
    N17968 X-43.554 Z-6.908
    N17969 X-44.003 Z-5.953
    N17970 X-44.452 Z-5.183
    N17971 X-44.901 Z-4.527
    N17972 X-45.35 Z-3.957
    N17973 X-45.799 Z-3.462
    N17974 X-46.248 Z-3.014
    N17975 X-46.697 Z-2.618
    N17976 X-47.146 Z-2.259
    N17977 X-47.595 Z-1.938
    N17978 X-48.493 Z-1.387
    N17979 X-49.391 Z-.943
    N17980 X-50.289 Z-.594
    N17981 X-51.187 Z-.33
    N17982 X-52.085 Z-.145
    N17983 X-52.984 Z-.036
    N17984 X-53.882 Z0.
    N17985 Y-85.825
    N17986 X-52.984 Z-.036
    N17987 X-52.085 Z-.145
    N17988 X-51.187 Z-.33
    N17989 X-50.289 Z-.594
    N17990 X-49.391 Z-.944
    N17991 X-48.493 Z-1.387
    N17992 X-47.595 Z-1.938
    N17993 X-47.146 Z-2.259
    N17994 X-46.697 Z-2.618
    N17995 X-46.248 Z-3.014
    N17996 X-45.799 Z-3.462
    N17997 X-45.35 Z-3.957
    N17998 X-44.901 Z-4.527
    N17999 X-44.452 Z-5.183
    N18000 X-44.003 Z-5.953
    N18001 X-43.554 Z-6.908
    N18002 X-43.33 Z-7.496
    N18003 X-43.105 Z-8.221
    N18004 X-42.901 Z-9.11
    N18005 X-42.798 Z-9.749
    N18006 X-42.491 Z-13.111
    N18007 X-41.98 Z-16.328
    N18008 X-41.346 Z-19.058
    N18009 X-40.491 Z-21.866
    N18010 X-39.758 Z-23.846
    N18011 X-39.033 Z-25.551
    N18012 X-38.554 Z-26.583
    N18013 X-38.074 Z-27.548
    N18014 X-37.595 Z-28.455
    N18015 X-36.635 Z-30.125
    N18016 X-35.676 Z-31.638
    N18017 X-34.839 Z-32.859
    N18018 X-34.002 Z-33.989
    N18019 X-33.166 Z-35.047
    N18020 X-32.329 Z-36.043
    N18021 X-31.408 Z-37.073
    N18022 X-30.487 Z-38.035
    N18023 X-29.566 Z-38.941
    N18024 X-28.645 Z-39.796
    N18025 X-27.77 Z-40.565
    N18026 X-26.895 Z-41.292
    N18027 X-26.02 Z-41.981
    N18028 X-25.145 Z-42.634
    N18029 X-24.233 Z-43.278
    N18030 X-23.321 Z-43.886
    N18031 X-22.41 Z-44.462
    N18032 X-21.498 Z-45.007
    N18033 X-19.729 Z-45.98
    N18034 X-17.961 Z-46.848
    N18035 X-16.151 Z-47.634
    N18036 X-14.342 Z-48.323
    N18037 X-12.559 Z-48.913
    N18038 X-10.776 Z-49.418
    N18039 X-8.958 Z-49.849
    N18040 X-7.169 Z-50.192
    N18041 X-5.362 Z-50.46
    N18042 X-3.592 Z-50.648
    N18043 X-1.797 Z-50.761
    N18044 X0. Z-50.8
    N18045 X1.797 Z-50.761
    N18046 X3.592 Z-50.648
    N18047 X5.362 Z-50.46
    N18048 X7.169 Z-50.192
    N18049 X8.958 Z-49.849
    N18050 X10.776 Z-49.418
    N18051 X12.559 Z-48.913
    N18052 X14.342 Z-48.323
    N18053 X16.151 Z-47.634
    N18054 X17.961 Z-46.848
    N18055 X18.845 Z-46.427
    N18056 X20.614 Z-45.507
    N18057 X22.41 Z-44.462
    N18058 X23.321 Z-43.886
    N18059 X24.233 Z-43.278
    N18060 X25.145 Z-42.634
    N18061 X26.02 Z-41.981
    N18062 X26.895 Z-41.292
    N18063 X27.77 Z-40.565
    N18064 X28.645 Z-39.796
    N18065 X29.566 Z-38.941
    N18066 X30.487 Z-38.035
    N18067 X31.408 Z-37.073
    N18068 X32.329 Z-36.043
    N18069 X33.166 Z-35.047
    N18070 X34.002 Z-33.989
    N18071 X34.839 Z-32.859
    N18072 X35.676 Z-31.638
    N18073 X36.156 Z-30.898
    N18074 X37.115 Z-29.312
    N18075 X38.074 Z-27.548
    N18076 X38.554 Z-26.583
    N18077 X39.033 Z-25.551
    N18078 X39.758 Z-23.846
    N18079 X40.491 Z-21.866
    N18080 X40.979 Z-20.339
    N18081 X41.571 Z-18.178
    N18082 X42.184 Z-15.229
    N18083 X42.44 Z-13.52
    N18084 X42.798 Z-9.749
    N18085 X43.003 Z-8.618
    N18086 X43.217 Z-7.837
    N18087 X43.554 Z-6.908
    N18088 X43.779 Z-6.404
    N18089 X44.228 Z-5.547
    N18090 X44.677 Z-4.839
    N18091 X45.35 Z-3.957
    N18092 X45.799 Z-3.462
    N18093 X46.248 Z-3.014
    N18094 X46.697 Z-2.618
    N18095 X47.146 Z-2.259
    N18096 X47.595 Z-1.938
    N18097 X48.493 Z-1.387
    N18098 X49.391 Z-.944
    N18099 X50.289 Z-.594
    N18100 X51.187 Z-.33
    N18101 X52.085 Z-.145
    N18102 X52.984 Z-.036
    N18103 X53.882 Z0.
    N18104 Y-87.025
    N18105 X52.984 Z-.036
    N18106 X52.085 Z-.145
    N18107 X51.187 Z-.33
    N18108 X50.289 Z-.594
    N18109 X49.391 Z-.944
    N18110 X48.493 Z-1.387
    N18111 X47.595 Z-1.938
    N18112 X47.146 Z-2.259
    N18113 X46.697 Z-2.618
    N18114 X46.248 Z-3.014
    N18115 X45.799 Z-3.462
    N18116 X45.35 Z-3.957
    N18117 X44.677 Z-4.839
    N18118 X44.228 Z-5.547
    N18119 X43.779 Z-6.404
    N18120 X43.554 Z-6.908
    N18121 X43.217 Z-7.837
    N18122 X43.003 Z-8.618
    N18123 X42.798 Z-9.749
    N18124 X42.44 Z-13.52
    N18125 X42.184 Z-15.229
    N18126 X41.571 Z-18.178
    N18127 X40.979 Z-20.339
    N18128 X40.491 Z-21.866
    N18129 X39.758 Z-23.846
    N18130 X39.033 Z-25.551
    N18131 X38.554 Z-26.583
    N18132 X38.074 Z-27.548
    N18133 X37.115 Z-29.312
    N18134 X36.156 Z-30.898
    N18135 X35.676 Z-31.638
    N18136 X34.839 Z-32.859
    N18137 X34.002 Z-33.989
    N18138 X33.166 Z-35.047
    N18139 X32.329 Z-36.043
    N18140 X31.408 Z-37.073
    N18141 X30.487 Z-38.035
    N18142 X29.566 Z-38.941
    N18143 X28.645 Z-39.796
    N18144 X27.77 Z-40.565
    N18145 X26.895 Z-41.292
    N18146 X26.02 Z-41.981
    N18147 X25.145 Z-42.634
    N18148 X24.233 Z-43.278
    N18149 X23.321 Z-43.886
    N18150 X22.41 Z-44.462
    N18151 X20.614 Z-45.507
    N18152 X18.845 Z-46.427
    N18153 X17.961 Z-46.848
    N18154 X16.151 Z-47.634
    N18155 X14.342 Z-48.323
    N18156 X12.559 Z-48.913
    N18157 X10.776 Z-49.418
    N18158 X8.958 Z-49.849
    N18159 X7.169 Z-50.192
    N18160 X5.362 Z-50.46
    N18161 X3.592 Z-50.648
    N18162 X1.797 Z-50.761
    N18163 X0. Z-50.8
    N18164 X-1.797 Z-50.761
    N18165 X-3.592 Z-50.648
    N18166 X-5.362 Z-50.46
    N18167 X-7.169 Z-50.192
    N18168 X-8.958 Z-49.849
    N18169 X-10.776 Z-49.418
    N18170 X-12.559 Z-48.913
    N18171 X-14.342 Z-48.323
    N18172 X-16.151 Z-47.634
    N18173 X-17.961 Z-46.848
    N18174 X-19.729 Z-45.98
    N18175 X-21.498 Z-45.007
    N18176 X-22.41 Z-44.462
    N18177 X-23.321 Z-43.886
    N18178 X-24.233 Z-43.278
    N18179 X-25.145 Z-42.634
    N18180 X-26.02 Z-41.981
    N18181 X-26.895 Z-41.292
    N18182 X-27.77 Z-40.565
    N18183 X-28.645 Z-39.796
    N18184 X-29.566 Z-38.941
    N18185 X-30.487 Z-38.035
    N18186 X-31.408 Z-37.073
    N18187 X-32.329 Z-36.043
    N18188 X-33.166 Z-35.047
    N18189 X-34.002 Z-33.989
    N18190 X-34.839 Z-32.859
    N18191 X-35.676 Z-31.638
    N18192 X-36.635 Z-30.125
    N18193 X-37.595 Z-28.455
    N18194 X-38.074 Z-27.548
    N18195 X-38.554 Z-26.583
    N18196 X-39.033 Z-25.551
    N18197 X-39.758 Z-23.846
    N18198 X-40.491 Z-21.866
    N18199 X-41.346 Z-19.058
    N18200 X-41.98 Z-16.328
    N18201 X-42.491 Z-13.111
    N18202 X-42.798 Z-9.749
    N18203 X-42.901 Z-9.11
    N18204 X-43.105 Z-8.221
    N18205 X-43.33 Z-7.496
    N18206 X-43.554 Z-6.908
    N18207 X-44.003 Z-5.953
    N18208 X-44.452 Z-5.183
    N18209 X-44.901 Z-4.527
    N18210 X-45.35 Z-3.957
    N18211 X-45.799 Z-3.462
    N18212 X-46.248 Z-3.014
    N18213 X-46.697 Z-2.618
    N18214 X-47.146 Z-2.259
    N18215 X-47.595 Z-1.938
    N18216 X-48.493 Z-1.387
    N18217 X-49.391 Z-.944
    N18218 X-50.289 Z-.594
    N18219 X-51.187 Z-.33
    N18220 X-52.085 Z-.146
    N18221 X-52.984 Z-.036
    N18222 X-53.882 Z0.
    N18223 Y-88.225
    N18224 X-52.984 Z-.036
    N18225 X-52.085 Z-.146
    N18226 X-51.187 Z-.33
    N18227 X-50.289 Z-.594
    N18228 X-49.391 Z-.944
    N18229 X-48.493 Z-1.387
    N18230 X-47.595 Z-1.938
    N18231 X-47.146 Z-2.259
    N18232 X-46.697 Z-2.618
    N18233 X-46.248 Z-3.014
    N18234 X-45.799 Z-3.462
    N18235 X-45.35 Z-3.957
    N18236 X-44.901 Z-4.526
    N18237 X-44.452 Z-5.183
    N18238 X-44.003 Z-5.953
    N18239 X-43.554 Z-6.908
    N18240 X-43.33 Z-7.496
    N18241 X-43.105 Z-8.221
    N18242 X-42.901 Z-9.11
    N18243 X-42.798 Z-9.749
    N18244 X-42.491 Z-13.111
    N18245 X-42.082 Z-15.789
    N18246 X-41.346 Z-19.058
    N18247 X-40.491 Z-21.866
    N18248 X-39.758 Z-23.846
    N18249 X-39.033 Z-25.551
    N18250 X-38.554 Z-26.583
    N18251 X-38.074 Z-27.548
    N18252 X-37.595 Z-28.455
    N18253 X-36.635 Z-30.125
    N18254 X-35.676 Z-31.638
    N18255 X-34.839 Z-32.859
    N18256 X-34.002 Z-33.989
    N18257 X-33.166 Z-35.047
    N18258 X-32.329 Z-36.043
    N18259 X-31.408 Z-37.073
    N18260 X-30.487 Z-38.035
    N18261 X-29.566 Z-38.941
    N18262 X-28.645 Z-39.796
    N18263 X-27.77 Z-40.565
    N18264 X-26.895 Z-41.292
    N18265 X-26.02 Z-41.981
    N18266 X-25.145 Z-42.634
    N18267 X-24.233 Z-43.278
    N18268 X-23.321 Z-43.886
    N18269 X-22.41 Z-44.462
    N18270 X-21.498 Z-45.007
    N18271 X-19.729 Z-45.98
    N18272 X-17.961 Z-46.848
    N18273 X-16.151 Z-47.634
    N18274 X-14.342 Z-48.323
    N18275 X-12.559 Z-48.913
    N18276 X-10.776 Z-49.418
    N18277 X-8.958 Z-49.849
    N18278 X-7.169 Z-50.192
    N18279 X-5.362 Z-50.46
    N18280 X-3.592 Z-50.648
    N18281 X-1.797 Z-50.761
    N18282 X0. Z-50.8
    N18283 X1.797 Z-50.761
    N18284 X3.592 Z-50.648
    N18285 X5.362 Z-50.46
    N18286 X7.169 Z-50.192
    N18287 X8.958 Z-49.849
    N18288 X10.776 Z-49.418
    N18289 X12.559 Z-48.913
    N18290 X14.342 Z-48.323
    N18291 X16.151 Z-47.634
    N18292 X17.961 Z-46.848
    N18293 X18.845 Z-46.427
    N18294 X20.614 Z-45.507
    N18295 X22.41 Z-44.462
    N18296 X23.321 Z-43.886
    N18297 X24.233 Z-43.278
    N18298 X25.145 Z-42.634
    N18299 X26.02 Z-41.981
    N18300 X26.895 Z-41.292
    N18301 X27.77 Z-40.565
    N18302 X28.645 Z-39.796
    N18303 X29.566 Z-38.941
    N18304 X30.487 Z-38.035
    N18305 X31.408 Z-37.073
    N18306 X32.329 Z-36.043
    N18307 X33.166 Z-35.047
    N18308 X34.002 Z-33.989
    N18309 X34.839 Z-32.859
    N18310 X35.676 Z-31.638
    N18311 X36.156 Z-30.898
    N18312 X37.115 Z-29.312
    N18313 X38.074 Z-27.548
    N18314 X38.554 Z-26.583
    N18315 X39.033 Z-25.551
    N18316 X39.758 Z-23.846
    N18317 X40.491 Z-21.866
    N18318 X40.979 Z-20.339
    N18319 X41.571 Z-18.178
    N18320 X42.184 Z-15.229
    N18321 X42.44 Z-13.52
    N18322 X42.798 Z-9.749
    N18323 X43.003 Z-8.619
    N18324 X43.217 Z-7.837
    N18325 X43.554 Z-6.908
    N18326 X43.779 Z-6.404
    N18327 X44.228 Z-5.547
    N18328 X44.677 Z-4.839
    N18329 X45.35 Z-3.957
    N18330 X45.799 Z-3.462
    N18331 X46.248 Z-3.014
    N18332 X46.697 Z-2.618
    N18333 X47.146 Z-2.259
    N18334 X47.595 Z-1.938
    N18335 X48.044 Z-1.647
    N18336 X48.493 Z-1.387
    N18337 X49.391 Z-.944
    N18338 X50.289 Z-.594
    N18339 X51.187 Z-.33
    N18340 X52.085 Z-.146
    N18341 X52.984 Z-.036
    N18342 X53.882 Z0.
    N18343 Y-89.425
    N18344 X52.984 Z-.036
    N18345 X52.085 Z-.146
    N18346 X51.187 Z-.33
    N18347 X50.289 Z-.594
    N18348 X49.391 Z-.944
    N18349 X48.493 Z-1.387
    N18350 X48.044 Z-1.647
    N18351 X47.146 Z-2.259
    N18352 X46.697 Z-2.618
    N18353 X46.248 Z-3.014
    N18354 X45.799 Z-3.462
    N18355 X45.35 Z-3.957
    N18356 X44.677 Z-4.839
    N18357 X44.228 Z-5.547
    N18358 X43.779 Z-6.404
    N18359 X43.554 Z-6.908
    N18360 X43.217 Z-7.837
    N18361 X43.003 Z-8.619
    N18362 X42.798 Z-9.749
    N18363 X42.44 Z-13.521
    N18364 X42.184 Z-15.229
    N18365 X41.571 Z-18.178
    N18366 X40.979 Z-20.339
    N18367 X40.491 Z-21.866
    N18368 X39.758 Z-23.846
    N18369 X39.033 Z-25.551
    N18370 X38.554 Z-26.583
    N18371 X38.074 Z-27.548
    N18372 X37.115 Z-29.312
    N18373 X36.156 Z-30.898
    N18374 X35.676 Z-31.638
    N18375 X34.839 Z-32.859
    N18376 X34.002 Z-33.989
    N18377 X33.166 Z-35.047
    N18378 X32.329 Z-36.043
    N18379 X31.408 Z-37.073
    N18380 X30.487 Z-38.035
    N18381 X29.566 Z-38.941
    N18382 X28.645 Z-39.796
    N18383 X27.77 Z-40.565
    N18384 X26.895 Z-41.292
    N18385 X26.02 Z-41.981
    N18386 X25.145 Z-42.634
    N18387 X24.233 Z-43.278
    N18388 X23.321 Z-43.886
    N18389 X22.41 Z-44.462
    N18390 X20.614 Z-45.507
    N18391 X18.845 Z-46.427
    N18392 X17.961 Z-46.848
    N18393 X16.151 Z-47.634
    N18394 X14.342 Z-48.323
    N18395 X12.559 Z-48.913
    N18396 X10.776 Z-49.418
    N18397 X8.958 Z-49.849
    N18398 X7.169 Z-50.192
    N18399 X5.362 Z-50.46
    N18400 X3.592 Z-50.648
    N18401 X1.797 Z-50.761
    N18402 X0. Z-50.8
    N18403 X-1.797 Z-50.761
    N18404 X-3.592 Z-50.648
    N18405 X-5.362 Z-50.46
    N18406 X-7.169 Z-50.192
    N18407 X-8.958 Z-49.849
    N18408 X-10.776 Z-49.418
    N18409 X-12.559 Z-48.913
    N18410 X-14.342 Z-48.323
    N18411 X-16.151 Z-47.634
    N18412 X-17.961 Z-46.848
    N18413 X-19.729 Z-45.98
    N18414 X-21.498 Z-45.007
    N18415 X-22.41 Z-44.462
    N18416 X-23.321 Z-43.886
    N18417 X-24.233 Z-43.278
    N18418 X-25.145 Z-42.634
    N18419 X-26.02 Z-41.981
    N18420 X-26.895 Z-41.292
    N18421 X-27.77 Z-40.565
    N18422 X-28.645 Z-39.796
    N18423 X-29.566 Z-38.941
    N18424 X-30.487 Z-38.035
    N18425 X-31.408 Z-37.073
    N18426 X-32.329 Z-36.043
    N18427 X-33.166 Z-35.047
    N18428 X-34.002 Z-33.989
    N18429 X-34.839 Z-32.859
    N18430 X-35.676 Z-31.638
    N18431 X-36.635 Z-30.125
    N18432 X-37.595 Z-28.455
    N18433 X-38.074 Z-27.548
    N18434 X-38.554 Z-26.583
    N18435 X-39.033 Z-25.551
    N18436 X-39.758 Z-23.846
    N18437 X-40.491 Z-21.866
    N18438 X-41.346 Z-19.058
    N18439 X-42.082 Z-15.789
    N18440 X-42.491 Z-13.111
    N18441 X-42.798 Z-9.749
    N18442 X-42.901 Z-9.111
    N18443 X-43.105 Z-8.221
    N18444 X-43.33 Z-7.496
    N18445 X-43.554 Z-6.908
    N18446 X-44.003 Z-5.953
    N18447 X-44.452 Z-5.183
    N18448 X-44.901 Z-4.526
    N18449 X-45.35 Z-3.957
    N18450 X-45.799 Z-3.462
    N18451 X-46.248 Z-3.014
    N18452 X-46.697 Z-2.618
    N18453 X-47.146 Z-2.259
    N18454 X-47.595 Z-1.938
    N18455 X-48.044 Z-1.647
    N18456 X-48.942 Z-1.152
    N18457 X-49.391 Z-.944
    N18458 X-50.289 Z-.594
    N18459 X-51.187 Z-.33
    N18460 X-52.085 Z-.146
    N18461 X-52.984 Z-.036
    N18462 X-53.882 Z0.
    N18463 Y-90.625
    N18464 X-52.984 Z-.036
    N18465 X-52.085 Z-.146
    N18466 X-51.187 Z-.33
    N18467 X-50.289 Z-.594
    N18468 X-49.391 Z-.944
    N18469 X-48.942 Z-1.152
    N18470 X-48.044 Z-1.647
    N18471 X-47.146 Z-2.259
    N18472 X-46.697 Z-2.618
    N18473 X-46.248 Z-3.014
    N18474 X-45.799 Z-3.462
    N18475 X-45.35 Z-3.957
    N18476 X-44.901 Z-4.526
    N18477 X-44.452 Z-5.183
    N18478 X-44.003 Z-5.953
    N18479 X-43.554 Z-6.908
    N18480 X-43.33 Z-7.496
    N18481 X-43.105 Z-8.221
    N18482 X-42.901 Z-9.111
    N18483 X-42.798 Z-9.749
    N18484 X-42.491 Z-13.111
    N18485 X-42.082 Z-15.789
    N18486 X-41.346 Z-19.058
    N18487 X-40.491 Z-21.866
    N18488 X-39.758 Z-23.846
    N18489 X-39.033 Z-25.551
    N18490 X-38.554 Z-26.583
    N18491 X-38.074 Z-27.548
    N18492 X-37.595 Z-28.455
    N18493 X-36.635 Z-30.125
    N18494 X-35.676 Z-31.638
    N18495 X-34.839 Z-32.859
    N18496 X-34.002 Z-33.989
    N18497 X-33.166 Z-35.047
    N18498 X-32.329 Z-36.043
    N18499 X-31.408 Z-37.073
    N18500 X-30.487 Z-38.035
    N18501 X-29.566 Z-38.941
    N18502 X-28.645 Z-39.796
    N18503 X-27.77 Z-40.565
    N18504 X-26.895 Z-41.292
    N18505 X-26.02 Z-41.981
    N18506 X-25.145 Z-42.634
    N18507 X-24.233 Z-43.278
    N18508 X-23.321 Z-43.886
    N18509 X-22.41 Z-44.462
    N18510 X-21.498 Z-45.007
    N18511 X-19.729 Z-45.98
    N18512 X-17.961 Z-46.848
    N18513 X-16.151 Z-47.634
    N18514 X-14.342 Z-48.323
    N18515 X-12.559 Z-48.913
    N18516 X-10.776 Z-49.418
    N18517 X-8.958 Z-49.849
    N18518 X-7.169 Z-50.192
    N18519 X-5.362 Z-50.46
    N18520 X-3.592 Z-50.648
    N18521 X-1.797 Z-50.761
    N18522 X0. Z-50.8
    N18523 X1.797 Z-50.761
    N18524 X3.592 Z-50.648
    N18525 X5.362 Z-50.46
    N18526 X7.169 Z-50.192
    N18527 X8.958 Z-49.849
    N18528 X10.776 Z-49.418
    N18529 X12.559 Z-48.913
    N18530 X14.342 Z-48.323
    N18531 X16.151 Z-47.634
    N18532 X17.961 Z-46.848
    N18533 X18.845 Z-46.427
    N18534 X20.614 Z-45.507
    N18535 X22.41 Z-44.462
    N18536 X23.321 Z-43.886
    N18537 X24.233 Z-43.278
    N18538 X25.145 Z-42.634
    N18539 X26.02 Z-41.981
    N18540 X26.895 Z-41.292
    N18541 X27.77 Z-40.565
    N18542 X28.645 Z-39.796
    N18543 X29.566 Z-38.941
    N18544 X30.487 Z-38.035
    N18545 X31.408 Z-37.073
    N18546 X32.329 Z-36.043
    N18547 X33.166 Z-35.047
    N18548 X34.002 Z-33.989
    N18549 X34.839 Z-32.859
    N18550 X35.676 Z-31.638
    N18551 X36.156 Z-30.898
    N18552 X37.115 Z-29.312
    N18553 X38.074 Z-27.548
    N18554 X38.554 Z-26.583
    N18555 X39.033 Z-25.551
    N18556 X39.758 Z-23.846
    N18557 X40.491 Z-21.866
    N18558 X40.979 Z-20.339
    N18559 X41.571 Z-18.178
    N18560 X42.184 Z-15.229
    N18561 X42.44 Z-13.521
    N18562 X42.798 Z-9.749
    N18563 X43.003 Z-8.619
    N18564 X43.217 Z-7.837
    N18565 X43.554 Z-6.908
    N18566 X43.779 Z-6.404
    N18567 X44.228 Z-5.547
    N18568 X44.677 Z-4.839
    N18569 X45.35 Z-3.957
    N18570 X45.799 Z-3.462
    N18571 X46.248 Z-3.014
    N18572 X46.697 Z-2.618
    N18573 X47.146 Z-2.259
    N18574 X48.044 Z-1.647
    N18575 X48.493 Z-1.387
    N18576 X49.391 Z-.944
    N18577 X50.289 Z-.594
    N18578 X51.187 Z-.33
    N18579 X52.085 Z-.146
    N18580 X52.984 Z-.036
    N18581 X53.882 Z0.
    N18582 Y-91.825
    N18583 X52.984 Z-.036
    N18584 X52.085 Z-.146
    N18585 X51.187 Z-.33
    N18586 X50.289 Z-.594
    N18587 X49.391 Z-.944
    N18588 X48.493 Z-1.387
    N18589 X48.044 Z-1.647
    N18590 X47.146 Z-2.259
    N18591 X46.697 Z-2.619
    N18592 X46.248 Z-3.014
    N18593 X45.799 Z-3.462
    N18594 X45.35 Z-3.957
    N18595 X44.677 Z-4.839
    N18596 X44.228 Z-5.547
    N18597 X43.779 Z-6.404
    N18598 X43.554 Z-6.909
    N18599 X43.217 Z-7.837
    N18600 X43.003 Z-8.619
    N18601 X42.798 Z-9.749
    N18602 X42.44 Z-13.521
    N18603 X42.184 Z-15.229
    N18604 X41.571 Z-18.178
    N18605 X40.979 Z-20.339
    N18606 X40.491 Z-21.866
    N18607 X39.758 Z-23.846
    N18608 X39.033 Z-25.551
    N18609 X38.554 Z-26.583
    N18610 X38.074 Z-27.548
    N18611 X37.115 Z-29.312
    N18612 X36.156 Z-30.898
    N18613 X35.676 Z-31.638
    N18614 X34.839 Z-32.859
    N18615 X34.002 Z-33.989
    N18616 X33.166 Z-35.047
    N18617 X32.329 Z-36.043
    N18618 X31.408 Z-37.073
    N18619 X30.487 Z-38.035
    N18620 X29.566 Z-38.941
    N18621 X28.645 Z-39.796
    N18622 X27.77 Z-40.565
    N18623 X26.895 Z-41.292
    N18624 X26.02 Z-41.981
    N18625 X25.145 Z-42.634
    N18626 X24.233 Z-43.278
    N18627 X23.321 Z-43.886
    N18628 X22.41 Z-44.462
    N18629 X20.614 Z-45.507
    N18630 X18.845 Z-46.427
    N18631 X17.961 Z-46.848
    N18632 X16.151 Z-47.634
    N18633 X14.342 Z-48.323
    N18634 X12.559 Z-48.913
    N18635 X10.776 Z-49.418
    N18636 X8.958 Z-49.849
    N18637 X7.169 Z-50.192
    N18638 X5.362 Z-50.46
    N18639 X3.592 Z-50.648
    N18640 X1.797 Z-50.761
    N18641 X0. Z-50.8
    N18642 X-1.797 Z-50.761
    N18643 X-3.592 Z-50.648
    N18644 X-5.362 Z-50.46
    N18645 X-7.169 Z-50.192
    N18646 X-8.958 Z-49.849
    N18647 X-10.776 Z-49.418
    N18648 X-12.559 Z-48.913
    N18649 X-14.342 Z-48.323
    N18650 X-16.151 Z-47.634
    N18651 X-17.961 Z-46.848
    N18652 X-19.729 Z-45.98
    N18653 X-21.498 Z-45.007
    N18654 X-22.41 Z-44.462
    N18655 X-23.321 Z-43.886
    N18656 X-24.233 Z-43.278
    N18657 X-25.145 Z-42.634
    N18658 X-26.02 Z-41.981
    N18659 X-26.895 Z-41.292
    N18660 X-27.77 Z-40.565
    N18661 X-28.645 Z-39.796
    N18662 X-29.566 Z-38.941
    N18663 X-30.487 Z-38.035
    N18664 X-31.408 Z-37.073
    N18665 X-32.329 Z-36.043
    N18666 X-33.166 Z-35.047
    N18667 X-34.002 Z-33.989
    N18668 X-34.839 Z-32.859
    N18669 X-35.676 Z-31.638
    N18670 X-36.635 Z-30.125
    N18671 X-37.595 Z-28.455
    N18672 X-38.074 Z-27.548
    N18673 X-38.554 Z-26.583
    N18674 X-39.033 Z-25.551
    N18675 X-39.758 Z-23.846
    N18676 X-40.491 Z-21.866
    N18677 X-41.346 Z-19.058
    N18678 X-42.082 Z-15.789
    N18679 X-42.491 Z-13.111
    N18680 X-42.798 Z-9.749
    N18681 X-42.901 Z-9.111
    N18682 X-43.105 Z-8.221
    N18683 X-43.33 Z-7.496
    N18684 X-43.554 Z-6.908
    N18685 X-44.003 Z-5.953
    N18686 X-44.452 Z-5.183
    N18687 X-44.901 Z-4.526
    N18688 X-45.35 Z-3.957
    N18689 X-45.799 Z-3.462
    N18690 X-46.248 Z-3.014
    N18691 X-46.697 Z-2.618
    N18692 X-47.146 Z-2.259
    N18693 X-48.044 Z-1.647
    N18694 X-48.942 Z-1.152
    N18695 X-49.391 Z-.944
    N18696 X-50.289 Z-.595
    N18697 X-51.187 Z-.33
    N18698 X-52.085 Z-.146
    N18699 X-52.984 Z-.036
    N18700 X-53.882 Z0.
    N18701 Y-93.025
    N18702 X-52.984 Z-.036
    N18703 X-52.085 Z-.146
    N18704 X-51.187 Z-.33
    N18705 X-50.289 Z-.595
    N18706 X-49.391 Z-.944
    N18707 X-48.942 Z-1.152
    N18708 X-48.044 Z-1.647
    N18709 X-47.146 Z-2.259
    N18710 X-46.697 Z-2.619
    N18711 X-46.248 Z-3.014
    N18712 X-45.799 Z-3.462
    N18713 X-45.35 Z-3.957
    N18714 X-44.901 Z-4.526
    N18715 X-44.452 Z-5.183
    N18716 X-44.003 Z-5.954
    N18717 X-43.554 Z-6.909
    N18718 X-43.33 Z-7.496
    N18719 X-43.105 Z-8.221
    N18720 X-42.901 Z-9.111
    N18721 X-42.798 Z-9.749
    N18722 X-42.491 Z-13.111
    N18723 X-42.082 Z-15.789
    N18724 X-41.346 Z-19.058
    N18725 X-40.491 Z-21.866
    N18726 X-39.758 Z-23.846
    N18727 X-39.033 Z-25.551
    N18728 X-38.554 Z-26.583
    N18729 X-38.074 Z-27.548
    N18730 X-37.595 Z-28.455
    N18731 X-36.635 Z-30.125
    N18732 X-35.676 Z-31.638
    N18733 X-34.839 Z-32.859
    N18734 X-34.002 Z-33.989
    N18735 X-33.166 Z-35.047
    N18736 X-32.329 Z-36.043
    N18737 X-31.408 Z-37.073
    N18738 X-30.487 Z-38.035
    N18739 X-29.566 Z-38.941
    N18740 X-28.645 Z-39.796
    N18741 X-27.77 Z-40.565
    N18742 X-26.895 Z-41.292
    N18743 X-26.02 Z-41.981
    N18744 X-25.145 Z-42.634
    N18745 X-24.233 Z-43.278
    N18746 X-23.321 Z-43.886
    N18747 X-22.41 Z-44.462
    N18748 X-21.498 Z-45.007
    N18749 X-19.729 Z-45.98
    N18750 X-17.961 Z-46.848
    N18751 X-16.151 Z-47.634
    N18752 X-14.342 Z-48.323
    N18753 X-12.559 Z-48.913
    N18754 X-10.776 Z-49.418
    N18755 X-8.958 Z-49.849
    N18756 X-7.169 Z-50.192
    N18757 X-5.362 Z-50.46
    N18758 X-3.592 Z-50.648
    N18759 X-1.797 Z-50.761
    N18760 X0. Z-50.8
    N18761 X1.797 Z-50.761
    N18762 X3.592 Z-50.648
    N18763 X5.362 Z-50.46
    N18764 X7.169 Z-50.192
    N18765 X8.958 Z-49.849
    N18766 X10.776 Z-49.418
    N18767 X12.559 Z-48.913
    N18768 X14.342 Z-48.323
    N18769 X16.151 Z-47.634
    N18770 X17.961 Z-46.848
    N18771 X18.845 Z-46.427
    N18772 X20.614 Z-45.507
    N18773 X22.41 Z-44.462
    N18774 X23.321 Z-43.886
    N18775 X24.233 Z-43.278
    N18776 X25.145 Z-42.634
    N18777 X26.02 Z-41.981
    N18778 X26.895 Z-41.292
    N18779 X27.77 Z-40.565
    N18780 X28.645 Z-39.796
    N18781 X29.566 Z-38.941
    N18782 X30.487 Z-38.035
    N18783 X31.408 Z-37.073
    N18784 X32.329 Z-36.043
    N18785 X33.166 Z-35.047
    N18786 X34.002 Z-33.989
    N18787 X34.839 Z-32.859
    N18788 X35.676 Z-31.638
    N18789 X36.156 Z-30.898
    N18790 X37.115 Z-29.312
    N18791 X38.074 Z-27.548
    N18792 X38.554 Z-26.583
    N18793 X39.033 Z-25.551
    N18794 X39.758 Z-23.846
    N18795 X40.491 Z-21.866
    N18796 X40.979 Z-20.339
    N18797 X41.571 Z-18.178
    N18798 X42.184 Z-15.229
    N18799 X42.44 Z-13.521
    N18800 X42.798 Z-9.749
    N18801 X43.003 Z-8.619
    N18802 X43.217 Z-7.837
    N18803 X43.554 Z-6.909
    N18804 X43.779 Z-6.404
    N18805 X44.228 Z-5.547
    N18806 X44.677 Z-4.839
    N18807 X45.35 Z-3.957
    N18808 X45.799 Z-3.462
    N18809 X46.248 Z-3.014
    N18810 X46.697 Z-2.619
    N18811 X47.146 Z-2.259
    N18812 X48.044 Z-1.647
    N18813 X48.493 Z-1.387
    N18814 X49.391 Z-.944
    N18815 X50.289 Z-.595
    N18816 X51.187 Z-.33
    N18817 X52.085 Z-.146
    N18818 X52.984 Z-.036
    N18819 X53.882 Z0.
    N18820 Y-94.225
    N18821 X52.984 Z-.036
    N18822 X52.085 Z-.146
    N18823 X51.187 Z-.33
    N18824 X50.289 Z-.595
    N18825 X49.391 Z-.944
    N18826 X48.493 Z-1.387
    N18827 X48.044 Z-1.647
    N18828 X47.146 Z-2.259
    N18829 X46.697 Z-2.619
    N18830 X46.248 Z-3.014
    N18831 X45.799 Z-3.462
    N18832 X45.35 Z-3.957
    N18833 X44.677 Z-4.839
    N18834 X44.228 Z-5.547
    N18835 X43.779 Z-6.403
    N18836 X43.554 Z-6.909
    N18837 X43.217 Z-7.837
    N18838 X43.003 Z-8.619
    N18839 X42.798 Z-9.749
    N18840 X42.44 Z-13.521
    N18841 X42.184 Z-15.229
    N18842 X41.571 Z-18.178
    N18843 X40.979 Z-20.339
    N18844 X40.491 Z-21.866
    N18845 X39.758 Z-23.846
    N18846 X39.033 Z-25.551
    N18847 X38.554 Z-26.583
    N18848 X38.074 Z-27.548
    N18849 X37.115 Z-29.312
    N18850 X36.156 Z-30.898
    N18851 X35.676 Z-31.638
    N18852 X34.839 Z-32.859
    N18853 X34.002 Z-33.989
    N18854 X33.166 Z-35.047
    N18855 X32.329 Z-36.043
    N18856 X31.408 Z-37.073
    N18857 X30.487 Z-38.035
    N18858 X29.566 Z-38.941
    N18859 X28.645 Z-39.796
    N18860 X27.77 Z-40.565
    N18861 X26.895 Z-41.292
    N18862 X26.02 Z-41.981
    N18863 X25.145 Z-42.634
    N18864 X24.233 Z-43.278
    N18865 X23.321 Z-43.886
    N18866 X22.41 Z-44.462
    N18867 X20.614 Z-45.507
    N18868 X18.845 Z-46.427
    N18869 X17.961 Z-46.848
    N18870 X16.151 Z-47.634
    N18871 X14.342 Z-48.323
    N18872 X12.559 Z-48.913
    N18873 X10.776 Z-49.418
    N18874 X8.958 Z-49.849
    N18875 X7.169 Z-50.192
    N18876 X5.362 Z-50.46
    N18877 X3.592 Z-50.648
    N18878 X1.797 Z-50.761
    N18879 X0. Z-50.8
    N18880 X-1.797 Z-50.761
    N18881 X-3.592 Z-50.648
    N18882 X-5.362 Z-50.46
    N18883 X-7.169 Z-50.192
    N18884 X-8.958 Z-49.849
    N18885 X-10.776 Z-49.418
    N18886 X-12.559 Z-48.913
    N18887 X-14.342 Z-48.323
    N18888 X-16.151 Z-47.634
    N18889 X-17.961 Z-46.848
    N18890 X-19.729 Z-45.98
    N18891 X-21.498 Z-45.007
    N18892 X-22.41 Z-44.462
    N18893 X-23.321 Z-43.886
    N18894 X-24.233 Z-43.278
    N18895 X-25.145 Z-42.634
    N18896 X-26.02 Z-41.981
    N18897 X-26.895 Z-41.292
    N18898 X-27.77 Z-40.565
    N18899 X-28.645 Z-39.796
    N18900 X-29.566 Z-38.941
    N18901 X-30.487 Z-38.035
    N18902 X-31.408 Z-37.073
    N18903 X-32.329 Z-36.043
    N18904 X-33.166 Z-35.047
    N18905 X-34.002 Z-33.989
    N18906 X-34.839 Z-32.859
    N18907 X-35.676 Z-31.638
    N18908 X-36.635 Z-30.125
    N18909 X-37.595 Z-28.455
    N18910 X-38.074 Z-27.548
    N18911 X-38.554 Z-26.583
    N18912 X-39.033 Z-25.551
    N18913 X-39.758 Z-23.846
    N18914 X-40.491 Z-21.866
    N18915 X-41.346 Z-19.058
    N18916 X-41.98 Z-16.328
    N18917 X-42.491 Z-13.111
    N18918 X-42.798 Z-9.749
    N18919 X-42.901 Z-9.111
    N18920 X-43.105 Z-8.221
    N18921 X-43.33 Z-7.496
    N18922 X-43.554 Z-6.909
    N18923 X-44.003 Z-5.954
    N18924 X-44.452 Z-5.183
    N18925 X-44.901 Z-4.526
    N18926 X-45.35 Z-3.957
    N18927 X-45.799 Z-3.462
    N18928 X-46.248 Z-3.014
    N18929 X-46.697 Z-2.619
    N18930 X-47.146 Z-2.259
    N18931 X-48.044 Z-1.647
    N18932 X-48.942 Z-1.152
    N18933 X-49.391 Z-.944
    N18934 X-50.289 Z-.595
    N18935 X-51.187 Z-.33
    N18936 X-52.085 Z-.146
    N18937 X-52.984 Z-.036
    N18938 X-53.882 Z0.
    N18939 Y-95.425
    N18940 X-52.984 Z-.036
    N18941 X-52.085 Z-.146
    N18942 X-51.187 Z-.33
    N18943 X-50.289 Z-.595
    N18944 X-49.391 Z-.944
    N18945 X-48.942 Z-1.152
    N18946 X-48.044 Z-1.647
    N18947 X-47.146 Z-2.259
    N18948 X-46.697 Z-2.619
    N18949 X-46.248 Z-3.014
    N18950 X-45.799 Z-3.462
    N18951 X-45.35 Z-3.957
    N18952 X-44.901 Z-4.526
    N18953 X-44.452 Z-5.183
    N18954 X-44.003 Z-5.954
    N18955 X-43.554 Z-6.909
    N18956 X-43.33 Z-7.496
    N18957 X-43.105 Z-8.221
    N18958 X-42.901 Z-9.112
    N18959 X-42.798 Z-9.749
    N18960 X-42.491 Z-13.111
    N18961 X-41.98 Z-16.328
    N18962 X-41.346 Z-19.058
    N18963 X-40.491 Z-21.866
    N18964 X-39.758 Z-23.846
    N18965 X-39.033 Z-25.551
    N18966 X-38.554 Z-26.583
    N18967 X-38.074 Z-27.548
    N18968 X-37.595 Z-28.455
    N18969 X-36.635 Z-30.125
    N18970 X-35.676 Z-31.638
    N18971 X-34.839 Z-32.859
    N18972 X-34.002 Z-33.989
    N18973 X-33.166 Z-35.047
    N18974 X-32.329 Z-36.043
    N18975 X-31.408 Z-37.073
    N18976 X-30.487 Z-38.035
    N18977 X-29.566 Z-38.941
    N18978 X-28.645 Z-39.796
    N18979 X-27.77 Z-40.565
    N18980 X-26.895 Z-41.292
    N18981 X-26.02 Z-41.981
    N18982 X-25.145 Z-42.634
    N18983 X-24.233 Z-43.278
    N18984 X-23.321 Z-43.886
    N18985 X-22.41 Z-44.462
    N18986 X-21.498 Z-45.007
    N18987 X-19.729 Z-45.98
    N18988 X-17.961 Z-46.848
    N18989 X-16.151 Z-47.634
    N18990 X-14.342 Z-48.323
    N18991 X-12.559 Z-48.913
    N18992 X-10.776 Z-49.418
    N18993 X-8.958 Z-49.849
    N18994 X-7.169 Z-50.192
    N18995 X-5.362 Z-50.46
    N18996 X-3.592 Z-50.648
    N18997 X-1.797 Z-50.761
    N18998 X0. Z-50.8
    N18999 X1.797 Z-50.761
    N19000 X3.592 Z-50.648
    N19001 X5.362 Z-50.46
    N19002 X7.169 Z-50.192
    N19003 X8.958 Z-49.849
    N19004 X10.776 Z-49.418
    N19005 X12.559 Z-48.913
    N19006 X14.342 Z-48.323
    N19007 X16.151 Z-47.634
    N19008 X17.961 Z-46.848
    N19009 X18.845 Z-46.427
    N19010 X20.614 Z-45.507
    N19011 X22.41 Z-44.462
    N19012 X23.321 Z-43.886
    N19013 X24.233 Z-43.278
    N19014 X25.145 Z-42.634
    N19015 X26.02 Z-41.981
    N19016 X26.895 Z-41.292
    N19017 X27.77 Z-40.565
    N19018 X28.645 Z-39.796
    N19019 X29.566 Z-38.941
    N19020 X30.487 Z-38.035
    N19021 X31.408 Z-37.073
    N19022 X32.329 Z-36.043
    N19023 X33.166 Z-35.047
    N19024 X34.002 Z-33.989
    N19025 X34.839 Z-32.859
    N19026 X35.676 Z-31.638
    N19027 X36.156 Z-30.898
    N19028 X37.115 Z-29.312
    N19029 X38.074 Z-27.548
    N19030 X38.554 Z-26.583
    N19031 X39.033 Z-25.551
    N19032 X39.758 Z-23.846
    N19033 X40.491 Z-21.866
    N19034 X40.979 Z-20.339
    N19035 X41.571 Z-18.178
    N19036 X42.184 Z-15.229
    N19037 X42.44 Z-13.521
    N19038 X42.798 Z-9.749
    N19039 X43.003 Z-8.619
    N19040 X43.217 Z-7.837
    N19041 X43.554 Z-6.909
    N19042 X43.779 Z-6.403
    N19043 X44.228 Z-5.547
    N19044 X44.677 Z-4.839
    N19045 X45.35 Z-3.957
    N19046 X45.799 Z-3.462
    N19047 X46.248 Z-3.014
    N19048 X46.697 Z-2.619
    N19049 X47.146 Z-2.259
    N19050 X48.044 Z-1.647
    N19051 X48.493 Z-1.387
    N19052 X49.391 Z-.944
    N19053 X50.289 Z-.595
    N19054 X51.187 Z-.33
    N19055 X52.085 Z-.146
    N19056 X52.984 Z-.036
    N19057 X53.882 Z0.
    N19058 Y-96.625
    N19059 X52.984 Z-.036
    N19060 X52.085 Z-.146
    N19061 X51.187 Z-.33
    N19062 X50.289 Z-.595
    N19063 X49.391 Z-.944
    N19064 X48.493 Z-1.387
    N19065 X48.044 Z-1.647
    N19066 X47.146 Z-2.259
    N19067 X46.697 Z-2.619
    N19068 X46.248 Z-3.014
    N19069 X45.799 Z-3.462
    N19070 X45.35 Z-3.957
    N19071 X44.677 Z-4.839
    N19072 X44.228 Z-5.547
    N19073 X43.779 Z-6.403
    N19074 X43.554 Z-6.909
    N19075 X43.217 Z-7.837
    N19076 X43.003 Z-8.619
    N19077 X42.798 Z-9.749
    N19078 X42.44 Z-13.521
    N19079 X42.184 Z-15.229
    N19080 X41.571 Z-18.178
    N19081 X40.979 Z-20.339
    N19082 X40.491 Z-21.866
    N19083 X39.758 Z-23.846
    N19084 X39.033 Z-25.551
    N19085 X38.554 Z-26.583
    N19086 X38.074 Z-27.548
    N19087 X37.115 Z-29.312
    N19088 X36.156 Z-30.898
    N19089 X35.676 Z-31.638
    N19090 X34.839 Z-32.859
    N19091 X34.002 Z-33.989
    N19092 X33.166 Z-35.047
    N19093 X32.329 Z-36.043
    N19094 X31.408 Z-37.073
    N19095 X30.487 Z-38.035
    N19096 X29.566 Z-38.941
    N19097 X28.645 Z-39.796
    N19098 X27.77 Z-40.565
    N19099 X26.895 Z-41.292
    N19100 X26.02 Z-41.981
    N19101 X25.145 Z-42.634
    N19102 X24.233 Z-43.278
    N19103 X23.321 Z-43.886
    N19104 X22.41 Z-44.462
    N19105 X20.614 Z-45.507
    N19106 X18.845 Z-46.427
    N19107 X17.961 Z-46.848
    N19108 X16.151 Z-47.634
    N19109 X14.342 Z-48.323
    N19110 X12.559 Z-48.913
    N19111 X10.776 Z-49.418
    N19112 X8.958 Z-49.849
    N19113 X7.169 Z-50.192
    N19114 X5.362 Z-50.46
    N19115 X3.592 Z-50.648
    N19116 X1.797 Z-50.761
    N19117 X0. Z-50.8
    N19118 X-1.797 Z-50.761
    N19119 X-3.592 Z-50.648
    N19120 X-5.362 Z-50.46
    N19121 X-7.169 Z-50.192
    N19122 X-8.958 Z-49.849
    N19123 X-10.776 Z-49.418
    N19124 X-12.559 Z-48.913
    N19125 X-14.342 Z-48.323
    N19126 X-16.151 Z-47.634
    N19127 X-17.961 Z-46.848
    N19128 X-19.729 Z-45.98
    N19129 X-21.498 Z-45.007
    N19130 X-22.41 Z-44.462
    N19131 X-23.321 Z-43.886
    N19132 X-24.233 Z-43.278
    N19133 X-25.145 Z-42.634
    N19134 X-26.02 Z-41.981
    N19135 X-26.895 Z-41.292
    N19136 X-27.77 Z-40.565
    N19137 X-28.645 Z-39.796
    N19138 X-29.566 Z-38.941
    N19139 X-30.487 Z-38.035
    N19140 X-31.408 Z-37.073
    N19141 X-32.329 Z-36.043
    N19142 X-33.166 Z-35.047
    N19143 X-34.002 Z-33.989
    N19144 X-34.839 Z-32.859
    N19145 X-35.676 Z-31.638
    N19146 X-36.635 Z-30.125
    N19147 X-37.595 Z-28.455
    N19148 X-38.074 Z-27.548
    N19149 X-38.554 Z-26.583
    N19150 X-39.033 Z-25.551
    N19151 X-39.758 Z-23.846
    N19152 X-40.491 Z-21.866
    N19153 X-41.346 Z-19.058
    N19154 X-41.98 Z-16.328
    N19155 X-42.491 Z-13.111
    N19156 X-42.798 Z-9.749
    N19157 X-42.901 Z-9.112
    N19158 X-43.105 Z-8.222
    N19159 X-43.33 Z-7.496
    N19160 X-43.554 Z-6.909
    N19161 X-44.003 Z-5.954
    N19162 X-44.452 Z-5.184
    N19163 X-44.901 Z-4.526
    N19164 X-45.35 Z-3.957
    N19165 X-45.799 Z-3.462
    N19166 X-46.248 Z-3.014
    N19167 X-46.697 Z-2.619
    N19168 X-47.146 Z-2.259
    N19169 X-48.044 Z-1.647
    N19170 X-48.942 Z-1.152
    N19171 X-49.391 Z-.944
    N19172 X-50.289 Z-.595
    N19173 X-51.187 Z-.33
    N19174 X-52.085 Z-.146
    N19175 X-52.984 Z-.036
    N19176 X-53.882 Z0.
    N19177 Y-97.825
    N19178 X-52.984 Z-.036
    N19179 X-52.085 Z-.146
    N19180 X-51.187 Z-.33
    N19181 X-50.289 Z-.595
    N19182 X-49.391 Z-.944
    N19183 X-48.942 Z-1.152
    N19184 X-48.044 Z-1.647
    N19185 X-47.146 Z-2.259
    N19186 X-46.697 Z-2.619
    N19187 X-46.248 Z-3.014
    N19188 X-45.799 Z-3.462
    N19189 X-45.35 Z-3.957
    N19190 X-44.901 Z-4.526
    N19191 X-44.452 Z-5.184
    N19192 X-44.003 Z-5.954
    N19193 X-43.554 Z-6.909
    N19194 X-43.33 Z-7.496
    N19195 X-43.105 Z-8.222
    N19196 X-42.901 Z-9.112
    N19197 X-42.798 Z-9.749
    N19198 X-42.491 Z-13.111
    N19199 X-41.98 Z-16.328
    N19200 X-41.346 Z-19.058
    N19201 X-40.491 Z-21.866
    N19202 X-39.758 Z-23.846
    N19203 X-39.033 Z-25.551
    N19204 X-38.554 Z-26.583
    N19205 X-38.074 Z-27.548
    N19206 X-37.595 Z-28.455
    N19207 X-36.635 Z-30.125
    N19208 X-35.676 Z-31.638
    N19209 X-34.839 Z-32.859
    N19210 X-34.002 Z-33.989
    N19211 X-33.166 Z-35.047
    N19212 X-32.329 Z-36.043
    N19213 X-31.408 Z-37.073
    N19214 X-30.487 Z-38.035
    N19215 X-29.566 Z-38.941
    N19216 X-28.645 Z-39.796
    N19217 X-27.77 Z-40.565
    N19218 X-26.895 Z-41.292
    N19219 X-26.02 Z-41.981
    N19220 X-25.145 Z-42.634
    N19221 X-24.233 Z-43.278
    N19222 X-23.321 Z-43.886
    N19223 X-22.41 Z-44.462
    N19224 X-21.498 Z-45.007
    N19225 X-19.729 Z-45.98
    N19226 X-17.961 Z-46.848
    N19227 X-16.151 Z-47.634
    N19228 X-14.342 Z-48.323
    N19229 X-12.559 Z-48.913
    N19230 X-10.776 Z-49.418
    N19231 X-8.958 Z-49.849
    N19232 X-7.169 Z-50.192
    N19233 X-5.362 Z-50.46
    N19234 X-3.592 Z-50.648
    N19235 X-1.797 Z-50.761
    N19236 X0. Z-50.8
    N19237 X1.797 Z-50.761
    N19238 X3.592 Z-50.648
    N19239 X5.362 Z-50.46
    N19240 X7.169 Z-50.192
    N19241 X8.958 Z-49.849
    N19242 X10.776 Z-49.418
    N19243 X12.559 Z-48.913
    N19244 X14.342 Z-48.323
    N19245 X16.151 Z-47.634
    N19246 X17.961 Z-46.848
    N19247 X18.845 Z-46.427
    N19248 X20.614 Z-45.507
    N19249 X22.41 Z-44.462
    N19250 X23.321 Z-43.886
    N19251 X24.233 Z-43.278
    N19252 X25.145 Z-42.634
    N19253 X26.02 Z-41.981
    N19254 X26.895 Z-41.292
    N19255 X27.77 Z-40.565
    N19256 X28.645 Z-39.796
    N19257 X29.566 Z-38.941
    N19258 X30.487 Z-38.035
    N19259 X31.408 Z-37.073
    N19260 X32.329 Z-36.043
    N19261 X33.166 Z-35.047
    N19262 X34.002 Z-33.989
    N19263 X34.839 Z-32.859
    N19264 X35.676 Z-31.638
    N19265 X36.156 Z-30.898
    N19266 X37.115 Z-29.312
    N19267 X38.074 Z-27.548
    N19268 X38.554 Z-26.583
    N19269 X39.033 Z-25.551
    N19270 X39.758 Z-23.846
    N19271 X40.491 Z-21.866
    N19272 X40.979 Z-20.339
    N19273 X41.571 Z-18.178
    N19274 X42.184 Z-15.229
    N19275 X42.44 Z-13.521
    N19276 X42.798 Z-9.749
    N19277 X43.003 Z-8.619
    N19278 X43.217 Z-7.837
    N19279 X43.554 Z-6.909
    N19280 X43.779 Z-6.403
    N19281 X44.228 Z-5.547
    N19282 X44.677 Z-4.839
    N19283 X45.35 Z-3.957
    N19284 X45.799 Z-3.462
    N19285 X46.248 Z-3.014
    N19286 X46.697 Z-2.619
    N19287 X47.146 Z-2.259
    N19288 X48.044 Z-1.647
    N19289 X48.493 Z-1.387
    N19290 X49.391 Z-.944
    N19291 X50.289 Z-.595
    N19292 X51.187 Z-.33
    N19293 X52.085 Z-.146
    N19294 X52.984 Z-.036
    N19295 X53.882 Z0.
    N19296 Y-99.025
    N19297 X52.984 Z-.036
    N19298 X52.085 Z-.146
    N19299 X51.187 Z-.33
    N19300 X50.289 Z-.595
    N19301 X49.391 Z-.944
    N19302 X48.493 Z-1.387
    N19303 X48.044 Z-1.647
    N19304 X47.146 Z-2.259
    N19305 X46.697 Z-2.619
    N19306 X46.248 Z-3.014
    N19307 X45.799 Z-3.462
    N19308 X45.35 Z-3.957
    N19309 X44.677 Z-4.839
    N19310 X44.228 Z-5.547
    N19311 X43.779 Z-6.403
    N19312 X43.554 Z-6.909
    N19313 X43.217 Z-7.837
    N19314 X43.003 Z-8.619
    N19315 X42.798 Z-9.749
    N19316 X42.44 Z-13.521
    N19317 X42.184 Z-15.229
    N19318 X41.571 Z-18.178
    N19319 X40.979 Z-20.339
    N19320 X40.491 Z-21.866
    N19321 X39.758 Z-23.846
    N19322 X39.033 Z-25.551
    N19323 X38.554 Z-26.583
    N19324 X38.074 Z-27.548
    N19325 X37.115 Z-29.312
    N19326 X36.156 Z-30.898
    N19327 X35.676 Z-31.638
    N19328 X34.839 Z-32.859
    N19329 X34.002 Z-33.989
    N19330 X33.166 Z-35.047
    N19331 X32.329 Z-36.043
    N19332 X31.408 Z-37.073
    N19333 X30.487 Z-38.035
    N19334 X29.566 Z-38.941
    N19335 X28.645 Z-39.796
    N19336 X27.77 Z-40.565
    N19337 X26.895 Z-41.292
    N19338 X26.02 Z-41.981
    N19339 X25.145 Z-42.634
    N19340 X24.233 Z-43.278
    N19341 X23.321 Z-43.886
    N19342 X22.41 Z-44.462
    N19343 X20.614 Z-45.507
    N19344 X18.845 Z-46.427
    N19345 X17.961 Z-46.848
    N19346 X16.151 Z-47.634
    N19347 X14.342 Z-48.323
    N19348 X12.559 Z-48.913
    N19349 X10.776 Z-49.418
    N19350 X8.958 Z-49.849
    N19351 X7.169 Z-50.192
    N19352 X5.362 Z-50.46
    N19353 X3.592 Z-50.648
    N19354 X1.797 Z-50.761
    N19355 X0. Z-50.8
    N19356 X-1.797 Z-50.761
    N19357 X-3.592 Z-50.648
    N19358 X-5.362 Z-50.46
    N19359 X-7.169 Z-50.192
    N19360 X-8.958 Z-49.849
    N19361 X-10.776 Z-49.418
    N19362 X-12.559 Z-48.913
    N19363 X-14.342 Z-48.323
    N19364 X-16.151 Z-47.634
    N19365 X-17.961 Z-46.848
    N19366 X-19.729 Z-45.98
    N19367 X-21.498 Z-45.007
    N19368 X-22.41 Z-44.462
    N19369 X-23.321 Z-43.886
    N19370 X-24.233 Z-43.278
    N19371 X-25.145 Z-42.634
    N19372 X-26.02 Z-41.981
    N19373 X-26.895 Z-41.292
    N19374 X-27.77 Z-40.565
    N19375 X-28.645 Z-39.796
    N19376 X-29.566 Z-38.941
    N19377 X-30.487 Z-38.035
    N19378 X-31.408 Z-37.073
    N19379 X-32.329 Z-36.043
    N19380 X-33.166 Z-35.047
    N19381 X-34.002 Z-33.989
    N19382 X-34.839 Z-32.859
    N19383 X-35.676 Z-31.638
    N19384 X-36.635 Z-30.125
    N19385 X-37.595 Z-28.455
    N19386 X-38.074 Z-27.548
    N19387 X-38.554 Z-26.583
    N19388 X-39.033 Z-25.551
    N19389 X-39.758 Z-23.846
    N19390 X-40.491 Z-21.866
    N19391 X-41.346 Z-19.058
    N19392 X-41.98 Z-16.328
    N19393 X-42.491 Z-13.111
    N19394 X-42.798 Z-9.749
    N19395 X-42.901 Z-9.112
    N19396 X-43.105 Z-8.222
    N19397 X-43.33 Z-7.496
    N19398 X-43.554 Z-6.909
    N19399 X-44.003 Z-5.954
    N19400 X-44.452 Z-5.184
    N19401 X-44.901 Z-4.526
    N19402 X-45.35 Z-3.957
    N19403 X-45.799 Z-3.462
    N19404 X-46.248 Z-3.014
    N19405 X-46.697 Z-2.619
    N19406 X-47.146 Z-2.259
    N19407 X-48.044 Z-1.647
    N19408 X-48.942 Z-1.152
    N19409 X-49.391 Z-.944
    N19410 X-50.289 Z-.595
    N19411 X-51.187 Z-.33
    N19412 X-52.085 Z-.146
    N19413 X-52.984 Z-.036
    N19414 X-53.882 Z0.
    N19415 Y-100.225
    N19416 X-52.984 Z-.036
    N19417 X-52.085 Z-.146
    N19418 X-51.187 Z-.331
    N19419 X-50.289 Z-.595
    N19420 X-49.391 Z-.944
    N19421 X-48.942 Z-1.152
    N19422 X-48.044 Z-1.647
    N19423 X-47.146 Z-2.259
    N19424 X-46.697 Z-2.619
    N19425 X-46.248 Z-3.014
    N19426 X-45.799 Z-3.462
    N19427 X-45.35 Z-3.957
    N19428 X-44.901 Z-4.526
    N19429 X-44.452 Z-5.184
    N19430 X-44.003 Z-5.954
    N19431 X-43.554 Z-6.909
    N19432 X-43.33 Z-7.496
    N19433 X-43.105 Z-8.222
    N19434 X-42.901 Z-9.113
    N19435 X-42.798 Z-9.749
    N19436 X-42.491 Z-13.111
    N19437 X-41.98 Z-16.328
    N19438 X-41.346 Z-19.058
    N19439 X-40.491 Z-21.866
    N19440 X-39.758 Z-23.846
    N19441 X-39.033 Z-25.551
    N19442 X-38.554 Z-26.583
    N19443 X-38.074 Z-27.548
    N19444 X-37.595 Z-28.455
    N19445 X-36.635 Z-30.125
    N19446 X-35.676 Z-31.638
    N19447 X-34.839 Z-32.859
    N19448 X-34.002 Z-33.989
    N19449 X-33.166 Z-35.047
    N19450 X-32.329 Z-36.043
    N19451 X-31.408 Z-37.073
    N19452 X-30.487 Z-38.035
    N19453 X-29.566 Z-38.941
    N19454 X-28.645 Z-39.796
    N19455 X-27.77 Z-40.565
    N19456 X-26.895 Z-41.292
    N19457 X-26.02 Z-41.981
    N19458 X-25.145 Z-42.634
    N19459 X-24.233 Z-43.278
    N19460 X-23.321 Z-43.886
    N19461 X-22.41 Z-44.462
    N19462 X-21.498 Z-45.007
    N19463 X-19.729 Z-45.98
    N19464 X-17.961 Z-46.848
    N19465 X-16.151 Z-47.634
    N19466 X-14.342 Z-48.323
    N19467 X-12.559 Z-48.913
    N19468 X-10.776 Z-49.418
    N19469 X-8.958 Z-49.849
    N19470 X-7.169 Z-50.192
    N19471 X-5.362 Z-50.46
    N19472 X-3.592 Z-50.648
    N19473 X-1.797 Z-50.761
    N19474 X0. Z-50.8
    N19475 X1.797 Z-50.761
    N19476 X3.592 Z-50.648
    N19477 X5.362 Z-50.46
    N19478 X7.169 Z-50.192
    N19479 X8.958 Z-49.849
    N19480 X10.776 Z-49.418
    N19481 X12.559 Z-48.913
    N19482 X14.342 Z-48.323
    N19483 X16.151 Z-47.634
    N19484 X17.961 Z-46.848
    N19485 X18.845 Z-46.427
    N19486 X20.614 Z-45.507
    N19487 X22.41 Z-44.462
    N19488 X23.321 Z-43.886
    N19489 X24.233 Z-43.278
    N19490 X25.145 Z-42.634
    N19491 X26.02 Z-41.981
    N19492 X26.895 Z-41.292
    N19493 X27.77 Z-40.565
    N19494 X28.645 Z-39.796
    N19495 X29.566 Z-38.941
    N19496 X30.487 Z-38.035
    N19497 X31.408 Z-37.073
    N19498 X32.329 Z-36.043
    N19499 X33.166 Z-35.047
    N19500 X34.002 Z-33.989
    N19501 X34.839 Z-32.859
    N19502 X35.676 Z-31.638
    N19503 X36.156 Z-30.898
    N19504 X37.115 Z-29.312
    N19505 X38.074 Z-27.548
    N19506 X38.554 Z-26.583
    N19507 X39.033 Z-25.551
    N19508 X39.758 Z-23.846
    N19509 X40.491 Z-21.866
    N19510 X40.979 Z-20.339
    N19511 X41.571 Z-18.178
    N19512 X42.184 Z-15.229
    N19513 X42.44 Z-13.521
    N19514 X42.798 Z-9.749
    N19515 X43.003 Z-8.619
    N19516 X43.217 Z-7.837
    N19517 X43.554 Z-6.909
    N19518 X43.779 Z-6.403
    N19519 X44.228 Z-5.547
    N19520 X44.677 Z-4.839
    N19521 X45.35 Z-3.957
    N19522 X45.799 Z-3.462
    N19523 X46.248 Z-3.014
    N19524 X46.697 Z-2.619
    N19525 X47.146 Z-2.259
    N19526 X48.044 Z-1.647
    N19527 X48.493 Z-1.387
    N19528 X49.391 Z-.944
    N19529 X50.289 Z-.595
    N19530 X51.187 Z-.33
    N19531 X52.085 Z-.146
    N19532 X52.984 Z-.036
    N19533 X53.882 Z0.
    N19534 Y-101.425
    N19535 X52.984 Z-.036
    N19536 X52.085 Z-.146
    N19537 X51.187 Z-.331
    N19538 X50.289 Z-.595
    N19539 X49.391 Z-.944
    N19540 X48.493 Z-1.387
    N19541 X48.044 Z-1.647
    N19542 X47.146 Z-2.259
    N19543 X46.697 Z-2.619
    N19544 X46.248 Z-3.013
    N19545 X45.799 Z-3.462
    N19546 X45.35 Z-3.957
    N19547 X44.677 Z-4.839
    N19548 X44.228 Z-5.547
    N19549 X43.779 Z-6.403
    N19550 X43.554 Z-6.909
    N19551 X43.217 Z-7.837
    N19552 X43.003 Z-8.619
    N19553 X42.798 Z-9.75
    N19554 X42.44 Z-13.521
    N19555 X42.184 Z-15.229
    N19556 X41.571 Z-18.178
    N19557 X40.979 Z-20.339
    N19558 X40.491 Z-21.866
    N19559 X39.758 Z-23.846
    N19560 X39.033 Z-25.551
    N19561 X38.554 Z-26.583
    N19562 X38.074 Z-27.548
    N19563 X37.115 Z-29.312
    N19564 X36.156 Z-30.898
    N19565 X35.676 Z-31.638
    N19566 X34.839 Z-32.859
    N19567 X34.002 Z-33.989
    N19568 X33.166 Z-35.047
    N19569 X32.329 Z-36.043
    N19570 X31.408 Z-37.073
    N19571 X30.487 Z-38.035
    N19572 X29.566 Z-38.941
    N19573 X28.645 Z-39.796
    N19574 X27.77 Z-40.565
    N19575 X26.895 Z-41.292
    N19576 X26.02 Z-41.981
    N19577 X25.145 Z-42.634
    N19578 X24.233 Z-43.278
    N19579 X23.321 Z-43.886
    N19580 X22.41 Z-44.462
    N19581 X20.614 Z-45.507
    N19582 X18.845 Z-46.427
    N19583 X17.961 Z-46.848
    N19584 X16.151 Z-47.634
    N19585 X14.342 Z-48.323
    N19586 X12.559 Z-48.913
    N19587 X10.776 Z-49.418
    N19588 X8.958 Z-49.849
    N19589 X7.169 Z-50.192
    N19590 X5.362 Z-50.46
    N19591 X3.592 Z-50.648
    N19592 X1.797 Z-50.761
    N19593 X0. Z-50.8
    N19594 X-1.797 Z-50.761
    N19595 X-3.592 Z-50.648
    N19596 X-5.362 Z-50.46
    N19597 X-7.169 Z-50.192
    N19598 X-8.958 Z-49.849
    N19599 X-10.776 Z-49.418
    N19600 X-12.559 Z-48.913
    N19601 X-14.342 Z-48.323
    N19602 X-16.151 Z-47.634
    N19603 X-17.961 Z-46.848
    N19604 X-19.729 Z-45.98
    N19605 X-21.498 Z-45.007
    N19606 X-22.41 Z-44.462
    N19607 X-23.321 Z-43.886
    N19608 X-24.233 Z-43.278
    N19609 X-25.145 Z-42.634
    N19610 X-26.02 Z-41.981
    N19611 X-26.895 Z-41.292
    N19612 X-27.77 Z-40.565
    N19613 X-28.645 Z-39.796
    N19614 X-29.566 Z-38.941
    N19615 X-30.487 Z-38.035
    N19616 X-31.408 Z-37.073
    N19617 X-32.329 Z-36.043
    N19618 X-33.166 Z-35.047
    N19619 X-34.002 Z-33.989
    N19620 X-34.839 Z-32.859
    N19621 X-35.676 Z-31.638
    N19622 X-36.635 Z-30.125
    N19623 X-37.595 Z-28.455
    N19624 X-38.074 Z-27.548
    N19625 X-38.554 Z-26.583
    N19626 X-39.033 Z-25.551
    N19627 X-39.758 Z-23.846
    N19628 X-40.491 Z-21.866
    N19629 X-41.346 Z-19.058
    N19630 X-41.98 Z-16.328
    N19631 X-42.491 Z-13.111
    N19632 X-42.798 Z-9.75
    N19633 X-43.003 Z-8.619
    N19634 X-43.33 Z-7.496
    N19635 X-43.554 Z-6.909
    N19636 X-44.003 Z-5.954
    N19637 X-44.452 Z-5.184
    N19638 X-44.901 Z-4.526
    N19639 X-45.35 Z-3.957
    N19640 X-45.799 Z-3.462
    N19641 X-46.248 Z-3.014
    N19642 X-46.697 Z-2.619
    N19643 X-47.146 Z-2.259
    N19644 X-48.044 Z-1.647
    N19645 X-48.942 Z-1.152
    N19646 X-49.391 Z-.944
    N19647 X-50.289 Z-.595
    N19648 X-51.187 Z-.331
    N19649 X-52.085 Z-.146
    N19650 X-52.984 Z-.036
    N19651 X-53.882 Z0.
    N19652 Y-102.625
    N19653 X-52.984 Z-.036
    N19654 X-52.085 Z-.146
    N19655 X-51.187 Z-.331
    N19656 X-50.289 Z-.595
    N19657 X-49.391 Z-.944
    N19658 X-48.942 Z-1.152
    N19659 X-48.044 Z-1.647
    N19660 X-47.146 Z-2.259
    N19661 X-46.697 Z-2.619
    N19662 X-46.248 Z-3.014
    N19663 X-45.799 Z-3.462
    N19664 X-45.35 Z-3.957
    N19665 X-44.901 Z-4.526
    N19666 X-44.452 Z-5.184
    N19667 X-44.003 Z-5.954
    N19668 X-43.554 Z-6.909
    N19669 X-43.33 Z-7.496
    N19670 X-43.003 Z-8.619
    N19671 X-42.798 Z-9.75
    N19672 X-42.491 Z-13.111
    N19673 X-41.98 Z-16.328
    N19674 X-41.346 Z-19.058
    N19675 X-40.491 Z-21.866
    N19676 X-39.758 Z-23.846
    N19677 X-39.033 Z-25.551
    N19678 X-38.554 Z-26.583
    N19679 X-38.074 Z-27.548
    N19680 X-37.595 Z-28.455
    N19681 X-36.635 Z-30.125
    N19682 X-35.676 Z-31.638
    N19683 X-34.839 Z-32.859
    N19684 X-34.002 Z-33.989
    N19685 X-33.166 Z-35.047
    N19686 X-32.329 Z-36.043
    N19687 X-31.408 Z-37.073
    N19688 X-30.487 Z-38.035
    N19689 X-29.566 Z-38.941
    N19690 X-28.645 Z-39.796
    N19691 X-27.77 Z-40.565
    N19692 X-26.895 Z-41.292
    N19693 X-26.02 Z-41.981
    N19694 X-25.145 Z-42.634
    N19695 X-24.233 Z-43.278
    N19696 X-23.321 Z-43.886
    N19697 X-22.41 Z-44.462
    N19698 X-21.498 Z-45.007
    N19699 X-19.729 Z-45.98
    N19700 X-17.961 Z-46.848
    N19701 X-16.151 Z-47.634
    N19702 X-14.342 Z-48.323
    N19703 X-12.559 Z-48.913
    N19704 X-10.776 Z-49.418
    N19705 X-8.958 Z-49.849
    N19706 X-7.169 Z-50.192
    N19707 X-5.362 Z-50.46
    N19708 X-3.592 Z-50.648
    N19709 X-1.797 Z-50.761
    N19710 X0. Z-50.8
    N19711 X1.797 Z-50.761
    N19712 X3.592 Z-50.648
    N19713 X5.362 Z-50.46
    N19714 X7.169 Z-50.192
    N19715 X8.958 Z-49.849
    N19716 X10.776 Z-49.418
    N19717 X12.559 Z-48.913
    N19718 X14.342 Z-48.323
    N19719 X16.151 Z-47.634
    N19720 X17.961 Z-46.848
    N19721 X18.845 Z-46.427
    N19722 X20.614 Z-45.507
    N19723 X22.41 Z-44.462
    N19724 X23.321 Z-43.886
    N19725 X24.233 Z-43.278
    N19726 X25.145 Z-42.634
    N19727 X26.02 Z-41.981
    N19728 X26.895 Z-41.292
    N19729 X27.77 Z-40.565
    N19730 X28.645 Z-39.796
    N19731 X29.566 Z-38.941
    N19732 X30.487 Z-38.035
    N19733 X31.408 Z-37.073
    N19734 X32.329 Z-36.043
    N19735 X33.166 Z-35.047
    N19736 X34.002 Z-33.989
    N19737 X34.839 Z-32.859
    N19738 X35.676 Z-31.638
    N19739 X36.156 Z-30.898
    N19740 X37.115 Z-29.312
    N19741 X38.074 Z-27.548
    N19742 X38.554 Z-26.583
    N19743 X39.033 Z-25.551
    N19744 X39.758 Z-23.846
    N19745 X40.491 Z-21.866
    N19746 X40.979 Z-20.339
    N19747 X41.571 Z-18.178
    N19748 X42.184 Z-15.229
    N19749 X42.44 Z-13.521
    N19750 X42.798 Z-9.75
    N19751 X43.003 Z-8.619
    N19752 X43.217 Z-7.838
    N19753 X43.554 Z-6.909
    N19754 X43.779 Z-6.403
    N19755 X44.228 Z-5.547
    N19756 X44.677 Z-4.839
    N19757 X45.35 Z-3.957
    N19758 X45.799 Z-3.462
    N19759 X46.248 Z-3.013
    N19760 X46.697 Z-2.619
    N19761 X47.146 Z-2.259
    N19762 X48.044 Z-1.647
    N19763 X48.942 Z-1.152
    N19764 X49.391 Z-.944
    N19765 X50.289 Z-.595
    N19766 X51.187 Z-.331
    N19767 X52.085 Z-.146
    N19768 X52.984 Z-.036
    N19769 X53.882 Z0.
    N19770 Y-103.825
    N19771 X52.984 Z-.036
    N19772 X52.085 Z-.146
    N19773 X51.187 Z-.331
    N19774 X50.289 Z-.595
    N19775 X49.391 Z-.945
    N19776 X48.942 Z-1.152
    N19777 X48.044 Z-1.647
    N19778 X47.146 Z-2.259
    N19779 X46.697 Z-2.619
    N19780 X46.248 Z-3.013
    N19781 X45.799 Z-3.462
    N19782 X45.35 Z-3.958
    N19783 X44.677 Z-4.839
    N19784 X44.228 Z-5.547
    N19785 X43.779 Z-6.403
    N19786 X43.554 Z-6.909
    N19787 X43.217 Z-7.838
    N19788 X43.003 Z-8.619
    N19789 X42.798 Z-9.75
    N19790 X42.44 Z-13.521
    N19791 X42.184 Z-15.229
    N19792 X41.571 Z-18.178
    N19793 X40.979 Z-20.339
    N19794 X40.491 Z-21.866
    N19795 X39.758 Z-23.846
    N19796 X39.033 Z-25.551
    N19797 X38.554 Z-26.583
    N19798 X38.074 Z-27.548
    N19799 X37.115 Z-29.312
    N19800 X36.156 Z-30.898
    N19801 X35.676 Z-31.638
    N19802 X34.839 Z-32.859
    N19803 X34.002 Z-33.989
    N19804 X33.166 Z-35.047
    N19805 X32.329 Z-36.043
    N19806 X31.408 Z-37.073
    N19807 X30.487 Z-38.035
    N19808 X29.566 Z-38.941
    N19809 X28.645 Z-39.796
    N19810 X27.77 Z-40.565
    N19811 X26.895 Z-41.292
    N19812 X26.02 Z-41.981
    N19813 X25.145 Z-42.634
    N19814 X24.233 Z-43.278
    N19815 X23.321 Z-43.886
    N19816 X22.41 Z-44.462
    N19817 X20.614 Z-45.507
    N19818 X18.845 Z-46.427
    N19819 X17.961 Z-46.848
    N19820 X16.151 Z-47.634
    N19821 X14.342 Z-48.323
    N19822 X12.559 Z-48.913
    N19823 X10.776 Z-49.418
    N19824 X8.958 Z-49.849
    N19825 X7.169 Z-50.192
    N19826 X5.362 Z-50.46
    N19827 X3.592 Z-50.648
    N19828 X1.797 Z-50.761
    N19829 X0. Z-50.8
    N19830 X-1.797 Z-50.761
    N19831 X-3.592 Z-50.648
    N19832 X-5.362 Z-50.46
    N19833 X-7.169 Z-50.192
    N19834 X-8.958 Z-49.849
    N19835 X-10.776 Z-49.418
    N19836 X-12.559 Z-48.913
    N19837 X-14.342 Z-48.323
    N19838 X-16.151 Z-47.634
    N19839 X-17.961 Z-46.848
    N19840 X-19.729 Z-45.98
    N19841 X-21.498 Z-45.007
    N19842 X-22.41 Z-44.462
    N19843 X-23.321 Z-43.886
    N19844 X-24.233 Z-43.278
    N19845 X-25.145 Z-42.634
    N19846 X-26.02 Z-41.981
    N19847 X-26.895 Z-41.292
    N19848 X-27.77 Z-40.565
    N19849 X-28.645 Z-39.796
    N19850 X-29.566 Z-38.941
    N19851 X-30.487 Z-38.035
    N19852 X-31.408 Z-37.073
    N19853 X-32.329 Z-36.043
    N19854 X-33.166 Z-35.047
    N19855 X-34.002 Z-33.989
    N19856 X-34.839 Z-32.859
    N19857 X-35.676 Z-31.638
    N19858 X-36.635 Z-30.125
    N19859 X-37.595 Z-28.455
    N19860 X-38.074 Z-27.548
    N19861 X-38.554 Z-26.583
    N19862 X-39.033 Z-25.551
    N19863 X-39.758 Z-23.846
    N19864 X-40.491 Z-21.866
    N19865 X-41.346 Z-19.058
    N19866 X-41.98 Z-16.328
    N19867 X-42.491 Z-13.111
    N19868 X-42.798 Z-9.75
    N19869 X-43.003 Z-8.619
    N19870 X-43.33 Z-7.496
    N19871 X-43.554 Z-6.909
    N19872 X-44.003 Z-5.954
    N19873 X-44.452 Z-5.184
    N19874 X-44.901 Z-4.526
    N19875 X-45.35 Z-3.957
    N19876 X-45.799 Z-3.462
    N19877 X-46.248 Z-3.013
    N19878 X-46.697 Z-2.619
    N19879 X-47.146 Z-2.259
    N19880 X-48.044 Z-1.647
    N19881 X-48.942 Z-1.152
    N19882 X-49.391 Z-.945
    N19883 X-50.289 Z-.595
    N19884 X-51.187 Z-.331
    N19885 X-52.085 Z-.146
    N19886 X-52.984 Z-.036
    N19887 X-53.882 Z0.
    N19888 Y-105.025
    N19889 X-52.984 Z-.036
    N19890 X-52.085 Z-.146
    N19891 X-51.187 Z-.331
    N19892 X-50.289 Z-.595
    N19893 X-49.391 Z-.945
    N19894 X-48.942 Z-1.152
    N19895 X-48.044 Z-1.647
    N19896 X-47.146 Z-2.259
    N19897 X-46.697 Z-2.619
    N19898 X-46.248 Z-3.013
    N19899 X-45.799 Z-3.462
    N19900 X-45.35 Z-3.958
    N19901 X-44.901 Z-4.526
    N19902 X-44.452 Z-5.184
    N19903 X-44.003 Z-5.954
    N19904 X-43.554 Z-6.909
    N19905 X-43.33 Z-7.496
    N19906 X-43.003 Z-8.619
    N19907 X-42.798 Z-9.75
    N19908 X-42.491 Z-13.111
    N19909 X-41.98 Z-16.328
    N19910 X-41.346 Z-19.058
    N19911 X-40.491 Z-21.866
    N19912 X-39.758 Z-23.846
    N19913 X-39.033 Z-25.551
    N19914 X-38.554 Z-26.583
    N19915 X-38.074 Z-27.548
    N19916 X-37.595 Z-28.455
    N19917 X-36.635 Z-30.125
    N19918 X-35.676 Z-31.638
    N19919 X-34.839 Z-32.859
    N19920 X-34.002 Z-33.989
    N19921 X-33.166 Z-35.047
    N19922 X-32.329 Z-36.043
    N19923 X-31.408 Z-37.073
    N19924 X-30.487 Z-38.035
    N19925 X-29.566 Z-38.941
    N19926 X-28.645 Z-39.796
    N19927 X-27.77 Z-40.565
    N19928 X-26.895 Z-41.292
    N19929 X-26.02 Z-41.981
    N19930 X-25.145 Z-42.634
    N19931 X-24.233 Z-43.278
    N19932 X-23.321 Z-43.886
    N19933 X-22.41 Z-44.462
    N19934 X-21.498 Z-45.007
    N19935 X-19.729 Z-45.98
    N19936 X-17.961 Z-46.848
    N19937 X-16.151 Z-47.634
    N19938 X-14.342 Z-48.323
    N19939 X-12.559 Z-48.913
    N19940 X-10.776 Z-49.418
    N19941 X-8.958 Z-49.849
    N19942 X-7.169 Z-50.192
    N19943 X-5.362 Z-50.46
    N19944 X-3.592 Z-50.648
    N19945 X-1.797 Z-50.761
    N19946 X0. Z-50.8
    N19947 X1.797 Z-50.761
    N19948 X3.592 Z-50.648
    N19949 X5.362 Z-50.46
    N19950 X7.169 Z-50.192
    N19951 X8.958 Z-49.849
    N19952 X10.776 Z-49.418
    N19953 X12.559 Z-48.913
    N19954 X14.342 Z-48.323
    N19955 X16.151 Z-47.634
    N19956 X17.961 Z-46.848
    N19957 X18.845 Z-46.427
    N19958 X20.614 Z-45.507
    N19959 X22.41 Z-44.462
    N19960 X23.321 Z-43.886
    N19961 X24.233 Z-43.278
    N19962 X25.145 Z-42.634
    N19963 X26.02 Z-41.981
    N19964 X26.895 Z-41.292
    N19965 X27.77 Z-40.565
    N19966 X28.645 Z-39.796
    N19967 X29.566 Z-38.941
    N19968 X30.487 Z-38.035
    N19969 X31.408 Z-37.073
    N19970 X32.329 Z-36.043
    N19971 X33.166 Z-35.047
    N19972 X34.002 Z-33.989
    N19973 X34.839 Z-32.859
    N19974 X35.676 Z-31.638
    N19975 X36.156 Z-30.898
    N19976 X37.115 Z-29.312
    N19977 X38.074 Z-27.548
    N19978 X38.554 Z-26.583
    N19979 X39.033 Z-25.551
    N19980 X39.758 Z-23.846
    N19981 X40.491 Z-21.866
    N19982 X40.979 Z-20.339
    N19983 X41.571 Z-18.178
    N19984 X42.184 Z-15.229
    N19985 X42.44 Z-13.521
    N19986 X42.798 Z-9.75
    N19987 X43.003 Z-8.619
    N19988 X43.217 Z-7.838
    N19989 X43.554 Z-6.909
    N19990 X43.779 Z-6.402
    N19991 X44.228 Z-5.547
    N19992 X44.677 Z-4.839
    N19993 X45.35 Z-3.958
    N19994 X45.799 Z-3.462
    N19995 X46.248 Z-3.013
    N19996 X46.697 Z-2.619
    N19997 X47.146 Z-2.259
    N19998 X48.044 Z-1.647
    N19999 X48.942 Z-1.152
    N20000 X49.391 Z-.945
    N20001 X50.289 Z-.595
    N20002 X51.187 Z-.331
    N20003 X52.085 Z-.146
    N20004 X52.984 Z-.036
    N20005 X53.882 Z0.
    N20006 Y-106.225
    N20007 X52.984 Z-.036
    N20008 X52.085 Z-.146
    N20009 X51.187 Z-.331
    N20010 X50.289 Z-.595
    N20011 X49.391 Z-.945
    N20012 X48.942 Z-1.152
    N20013 X48.044 Z-1.647
    N20014 X47.146 Z-2.258
    N20015 X46.697 Z-2.619
    N20016 X46.248 Z-3.013
    N20017 X45.799 Z-3.462
    N20018 X45.35 Z-3.958
    N20019 X44.677 Z-4.839
    N20020 X44.228 Z-5.547
    N20021 X43.779 Z-6.402
    N20022 X43.554 Z-6.91
    N20023 X43.217 Z-7.838
    N20024 X42.952 Z-8.853
    N20025 X42.773 Z-9.981
    N20026 X42.44 Z-13.521
    N20027 X42.184 Z-15.229
    N20028 X41.571 Z-18.178
    N20029 X40.979 Z-20.339
    N20030 X40.491 Z-21.866
    N20031 X39.758 Z-23.846
    N20032 X39.033 Z-25.551
    N20033 X38.554 Z-26.583
    N20034 X38.074 Z-27.548
    N20035 X37.115 Z-29.312
    N20036 X36.156 Z-30.898
    N20037 X35.676 Z-31.638
    N20038 X34.839 Z-32.859
    N20039 X34.002 Z-33.989
    N20040 X33.166 Z-35.047
    N20041 X32.329 Z-36.043
    N20042 X31.408 Z-37.073
    N20043 X30.487 Z-38.035
    N20044 X29.566 Z-38.941
    N20045 X28.645 Z-39.796
    N20046 X27.77 Z-40.565
    N20047 X26.895 Z-41.292
    N20048 X26.02 Z-41.981
    N20049 X25.145 Z-42.634
    N20050 X24.233 Z-43.278
    N20051 X23.321 Z-43.886
    N20052 X22.41 Z-44.462
    N20053 X20.614 Z-45.507
    N20054 X18.845 Z-46.427
    N20055 X17.961 Z-46.848
    N20056 X16.151 Z-47.634
    N20057 X14.342 Z-48.323
    N20058 X12.559 Z-48.913
    N20059 X10.776 Z-49.418
    N20060 X8.958 Z-49.849
    N20061 X7.169 Z-50.192
    N20062 X5.362 Z-50.46
    N20063 X3.592 Z-50.648
    N20064 X1.797 Z-50.761
    N20065 X0. Z-50.8
    N20066 X-1.797 Z-50.761
    N20067 X-3.592 Z-50.648
    N20068 X-5.362 Z-50.46
    N20069 X-7.169 Z-50.192
    N20070 X-8.958 Z-49.849
    N20071 X-10.776 Z-49.418
    N20072 X-12.559 Z-48.913
    N20073 X-14.342 Z-48.323
    N20074 X-16.151 Z-47.634
    N20075 X-17.961 Z-46.848
    N20076 X-19.729 Z-45.98
    N20077 X-21.498 Z-45.007
    N20078 X-22.41 Z-44.462
    N20079 X-23.321 Z-43.886
    N20080 X-24.233 Z-43.278
    N20081 X-25.145 Z-42.634
    N20082 X-26.02 Z-41.981
    N20083 X-26.895 Z-41.292
    N20084 X-27.77 Z-40.565
    N20085 X-28.645 Z-39.796
    N20086 X-29.566 Z-38.941
    N20087 X-30.487 Z-38.035
    N20088 X-31.408 Z-37.073
    N20089 X-32.329 Z-36.043
    N20090 X-33.166 Z-35.047
    N20091 X-34.002 Z-33.989
    N20092 X-34.839 Z-32.859
    N20093 X-35.676 Z-31.638
    N20094 X-36.635 Z-30.125
    N20095 X-37.595 Z-28.455
    N20096 X-38.074 Z-27.548
    N20097 X-38.554 Z-26.583
    N20098 X-39.033 Z-25.551
    N20099 X-39.758 Z-23.846
    N20100 X-40.491 Z-21.866
    N20101 X-41.346 Z-19.058
    N20102 X-41.98 Z-16.328
    N20103 X-42.491 Z-13.111
    N20104 X-42.798 Z-9.75
    N20105 X-43.003 Z-8.619
    N20106 X-43.33 Z-7.496
    N20107 X-43.554 Z-6.91
    N20108 X-44.003 Z-5.954
    N20109 X-44.452 Z-5.184
    N20110 X-44.901 Z-4.526
    N20111 X-45.35 Z-3.958
    N20112 X-45.799 Z-3.462
    N20113 X-46.248 Z-3.013
    N20114 X-46.697 Z-2.619
    N20115 X-47.146 Z-2.259
    N20116 X-48.044 Z-1.647
    N20117 X-48.942 Z-1.152
    N20118 X-49.84 Z-.757
    N20119 X-50.289 Z-.595
    N20120 X-51.187 Z-.331
    N20121 X-52.085 Z-.146
    N20122 X-52.984 Z-.036
    N20123 X-53.882 Z0.
    N20124 Y-107.425
    N20125 X-52.984 Z-.036
    N20126 X-52.085 Z-.146
    N20127 X-51.187 Z-.331
    N20128 X-50.289 Z-.595
    N20129 X-49.84 Z-.757
    N20130 X-48.942 Z-1.152
    N20131 X-48.044 Z-1.647
    N20132 X-47.146 Z-2.259
    N20133 X-46.697 Z-2.619
    N20134 X-46.248 Z-3.013
    N20135 X-45.799 Z-3.462
    N20136 X-45.35 Z-3.958
    N20137 X-44.901 Z-4.526
    N20138 X-44.452 Z-5.184
    N20139 X-44.003 Z-5.954
    N20140 X-43.554 Z-6.91
    N20141 X-43.33 Z-7.496
    N20142 X-43.003 Z-8.619
    N20143 X-42.798 Z-9.75
    N20144 X-42.491 Z-13.111
    N20145 X-41.98 Z-16.329
    N20146 X-41.346 Z-19.058
    N20147 X-40.491 Z-21.866
    N20148 X-39.758 Z-23.846
    N20149 X-39.033 Z-25.551
    N20150 X-38.554 Z-26.583
    N20151 X-38.074 Z-27.548
    N20152 X-37.595 Z-28.455
    N20153 X-36.635 Z-30.125
    N20154 X-35.676 Z-31.638
    N20155 X-34.839 Z-32.859
    N20156 X-34.002 Z-33.989
    N20157 X-33.166 Z-35.047
    N20158 X-32.329 Z-36.043
    N20159 X-31.408 Z-37.073
    N20160 X-30.487 Z-38.035
    N20161 X-29.566 Z-38.941
    N20162 X-28.645 Z-39.796
    N20163 X-27.77 Z-40.565
    N20164 X-26.895 Z-41.292
    N20165 X-26.02 Z-41.981
    N20166 X-25.145 Z-42.634
    N20167 X-24.233 Z-43.278
    N20168 X-23.321 Z-43.886
    N20169 X-22.41 Z-44.462
    N20170 X-21.498 Z-45.007
    N20171 X-19.729 Z-45.98
    N20172 X-17.961 Z-46.848
    N20173 X-16.151 Z-47.634
    N20174 X-14.342 Z-48.323
    N20175 X-12.559 Z-48.913
    N20176 X-10.776 Z-49.418
    N20177 X-8.958 Z-49.849
    N20178 X-7.169 Z-50.192
    N20179 X-5.362 Z-50.46
    N20180 X-3.592 Z-50.648
    N20181 X-1.797 Z-50.761
    N20182 X0. Z-50.8
    N20183 X1.797 Z-50.761
    N20184 X3.592 Z-50.648
    N20185 X5.362 Z-50.46
    N20186 X7.169 Z-50.192
    N20187 X8.958 Z-49.849
    N20188 X10.776 Z-49.418
    N20189 X12.559 Z-48.913
    N20190 X14.342 Z-48.323
    N20191 X16.151 Z-47.634
    N20192 X17.961 Z-46.848
    N20193 X18.845 Z-46.427
    N20194 X20.614 Z-45.507
    N20195 X22.41 Z-44.462
    N20196 X23.321 Z-43.886
    N20197 X24.233 Z-43.278
    N20198 X25.145 Z-42.634
    N20199 X26.02 Z-41.981
    N20200 X26.895 Z-41.292
    N20201 X27.77 Z-40.565
    N20202 X28.645 Z-39.796
    N20203 X29.566 Z-38.941
    N20204 X30.487 Z-38.035
    N20205 X31.408 Z-37.073
    N20206 X32.329 Z-36.043
    N20207 X33.166 Z-35.047
    N20208 X34.002 Z-33.989
    N20209 X34.839 Z-32.859
    N20210 X35.676 Z-31.638
    N20211 X36.156 Z-30.898
    N20212 X37.115 Z-29.312
    N20213 X38.074 Z-27.548
    N20214 X38.554 Z-26.583
    N20215 X39.033 Z-25.551
    N20216 X39.758 Z-23.846
    N20217 X40.491 Z-21.866
    N20218 X40.979 Z-20.339
    N20219 X41.571 Z-18.178
    N20220 X42.184 Z-15.229
    N20221 X42.44 Z-13.521
    N20222 X42.773 Z-9.981
    N20223 X42.952 Z-8.853
    N20224 X43.217 Z-7.838
    N20225 X43.554 Z-6.91
    N20226 X43.779 Z-6.402
    N20227 X44.228 Z-5.547
    N20228 X44.677 Z-4.839
    N20229 X45.35 Z-3.958
    N20230 X45.799 Z-3.463
    N20231 X46.248 Z-3.013
    N20232 X46.697 Z-2.619
    N20233 X47.146 Z-2.258
    N20234 X48.044 Z-1.647
    N20235 X48.942 Z-1.152
    N20236 X49.391 Z-.945
    N20237 X50.289 Z-.595
    N20238 X51.187 Z-.331
    N20239 X52.085 Z-.146
    N20240 X52.984 Z-.036
    N20241 X53.882 Z0.
    N20242 Y-108.625
    N20243 X52.984 Z-.036
    N20244 X52.085 Z-.146
    N20245 X51.187 Z-.331
    N20246 X50.289 Z-.595
    N20247 X49.391 Z-.945
    N20248 X48.942 Z-1.152
    N20249 X48.044 Z-1.647
    N20250 X47.146 Z-2.258
    N20251 X46.697 Z-2.619
    N20252 X46.248 Z-3.013
    N20253 X45.799 Z-3.463
    N20254 X45.35 Z-3.958
    N20255 X44.677 Z-4.839
    N20256 X44.228 Z-5.547
    N20257 X43.779 Z-6.402
    N20258 X43.554 Z-6.91
    N20259 X43.217 Z-7.838
    N20260 X42.952 Z-8.854
    N20261 X42.798 Z-9.75
    N20262 X42.44 Z-13.521
    N20263 X42.184 Z-15.229
    N20264 X41.57 Z-18.178
    N20265 X40.979 Z-20.339
    N20266 X40.491 Z-21.866
    N20267 X39.758 Z-23.846
    N20268 X39.033 Z-25.551
    N20269 X38.554 Z-26.583
    N20270 X38.074 Z-27.548
    N20271 X37.115 Z-29.312
    N20272 X36.156 Z-30.898
    N20273 X35.676 Z-31.638
    N20274 X34.839 Z-32.859
    N20275 X34.002 Z-33.989
    N20276 X33.166 Z-35.047
    N20277 X32.329 Z-36.043
    N20278 X31.408 Z-37.073
    N20279 X30.487 Z-38.035
    N20280 X29.566 Z-38.941
    N20281 X28.645 Z-39.796
    N20282 X27.77 Z-40.565
    N20283 X26.895 Z-41.292
    N20284 X26.02 Z-41.981
    N20285 X25.145 Z-42.634
    N20286 X24.233 Z-43.278
    N20287 X23.321 Z-43.886
    N20288 X22.41 Z-44.462
    N20289 X20.614 Z-45.507
    N20290 X18.845 Z-46.427
    N20291 X17.961 Z-46.848
    N20292 X16.151 Z-47.634
    N20293 X14.342 Z-48.323
    N20294 X12.559 Z-48.913
    N20295 X10.776 Z-49.418
    N20296 X8.958 Z-49.849
    N20297 X7.169 Z-50.192
    N20298 X5.362 Z-50.46
    N20299 X3.592 Z-50.648
    N20300 X1.797 Z-50.761
    N20301 X0. Z-50.8
    N20302 X-1.797 Z-50.761
    N20303 X-3.592 Z-50.648
    N20304 X-5.362 Z-50.46
    N20305 X-7.169 Z-50.192
    N20306 X-8.958 Z-49.849
    N20307 X-10.776 Z-49.418
    N20308 X-12.559 Z-48.913
    N20309 X-14.342 Z-48.323
    N20310 X-16.151 Z-47.634
    N20311 X-17.961 Z-46.848
    N20312 X-19.729 Z-45.98
    N20313 X-21.498 Z-45.007
    N20314 X-22.41 Z-44.462
    N20315 X-23.321 Z-43.886
    N20316 X-24.233 Z-43.278
    N20317 X-25.145 Z-42.634
    N20318 X-26.02 Z-41.981
    N20319 X-26.895 Z-41.292
    N20320 X-27.77 Z-40.565
    N20321 X-28.645 Z-39.796
    N20322 X-29.566 Z-38.941
    N20323 X-30.487 Z-38.035
    N20324 X-31.408 Z-37.073
    N20325 X-32.329 Z-36.043
    N20326 X-33.166 Z-35.047
    N20327 X-34.002 Z-33.989
    N20328 X-34.839 Z-32.859
    N20329 X-35.676 Z-31.638
    N20330 X-36.635 Z-30.125
    N20331 X-37.595 Z-28.455
    N20332 X-38.074 Z-27.548
    N20333 X-38.554 Z-26.583
    N20334 X-39.033 Z-25.551
    N20335 X-39.758 Z-23.846
    N20336 X-40.491 Z-21.866
    N20337 X-41.346 Z-19.058
    N20338 X-41.98 Z-16.329
    N20339 X-42.491 Z-13.112
    N20340 X-42.798 Z-9.75
    N20341 X-43.003 Z-8.619
    N20342 X-43.33 Z-7.496
    N20343 X-43.554 Z-6.91
    N20344 X-43.779 Z-6.402
    N20345 X-44.228 Z-5.547
    N20346 X-44.677 Z-4.839
    N20347 X-45.35 Z-3.958
    N20348 X-45.799 Z-3.463
    N20349 X-46.248 Z-3.013
    N20350 X-46.697 Z-2.619
    N20351 X-47.146 Z-2.258
    N20352 X-48.044 Z-1.647
    N20353 X-48.942 Z-1.152
    N20354 X-49.84 Z-.757
    N20355 X-50.289 Z-.595
    N20356 X-51.187 Z-.331
    N20357 X-52.085 Z-.146
    N20358 X-52.984 Z-.036
    N20359 X-53.882 Z0.
    N20360 Y-109.825
    N20361 X-52.984 Z-.036
    N20362 X-52.085 Z-.146
    N20363 X-51.187 Z-.331
    N20364 X-50.289 Z-.595
    N20365 X-49.84 Z-.757
    N20366 X-48.942 Z-1.152
    N20367 X-48.044 Z-1.647
    N20368 X-47.146 Z-2.258
    N20369 X-46.697 Z-2.619
    N20370 X-46.248 Z-3.013
    N20371 X-45.799 Z-3.463
    N20372 X-45.35 Z-3.958
    N20373 X-44.677 Z-4.839
    N20374 X-44.228 Z-5.547
    N20375 X-43.779 Z-6.402
    N20376 X-43.554 Z-6.91
    N20377 X-43.33 Z-7.496
    N20378 X-43.003 Z-8.619
    N20379 X-42.798 Z-9.75
    N20380 X-42.491 Z-13.112
    N20381 X-41.98 Z-16.329
    N20382 X-41.346 Z-19.058
    N20383 X-40.491 Z-21.866
    N20384 X-39.758 Z-23.846
    N20385 X-39.033 Z-25.551
    N20386 X-38.554 Z-26.583
    N20387 X-38.074 Z-27.548
    N20388 X-37.595 Z-28.455
    N20389 X-36.635 Z-30.125
    N20390 X-35.676 Z-31.638
    N20391 X-34.839 Z-32.859
    N20392 X-34.002 Z-33.989
    N20393 X-33.166 Z-35.047
    N20394 X-32.329 Z-36.043
    N20395 X-31.408 Z-37.073
    N20396 X-30.487 Z-38.035
    N20397 X-29.566 Z-38.941
    N20398 X-28.645 Z-39.796
    N20399 X-27.77 Z-40.565
    N20400 X-26.895 Z-41.292
    N20401 X-26.02 Z-41.981
    N20402 X-25.145 Z-42.634
    N20403 X-24.233 Z-43.278
    N20404 X-23.321 Z-43.886
    N20405 X-22.41 Z-44.462
    N20406 X-21.498 Z-45.007
    N20407 X-19.729 Z-45.98
    N20408 X-17.961 Z-46.848
    N20409 X-16.151 Z-47.634
    N20410 X-14.342 Z-48.323
    N20411 X-12.559 Z-48.913
    N20412 X-10.776 Z-49.418
    N20413 X-8.958 Z-49.849
    N20414 X-7.169 Z-50.192
    N20415 X-5.362 Z-50.46
    N20416 X-3.592 Z-50.648
    N20417 X-1.797 Z-50.761
    N20418 X0. Z-50.8
    N20419 X1.797 Z-50.761
    N20420 X3.592 Z-50.648
    N20421 X5.362 Z-50.46
    N20422 X7.169 Z-50.192
    N20423 X8.958 Z-49.849
    N20424 X10.776 Z-49.418
    N20425 X12.559 Z-48.913
    N20426 X14.342 Z-48.323
    N20427 X16.151 Z-47.634
    N20428 X17.961 Z-46.848
    N20429 X18.845 Z-46.427
    N20430 X20.614 Z-45.507
    N20431 X22.41 Z-44.462
    N20432 X23.321 Z-43.886
    N20433 X24.233 Z-43.278
    N20434 X25.145 Z-42.634
    N20435 X26.02 Z-41.981
    N20436 X26.895 Z-41.292
    N20437 X27.77 Z-40.565
    N20438 X28.645 Z-39.796
    N20439 X29.566 Z-38.941
    N20440 X30.487 Z-38.035
    N20441 X31.408 Z-37.073
    N20442 X32.329 Z-36.043
    N20443 X33.166 Z-35.047
    N20444 X34.002 Z-33.989
    N20445 X34.839 Z-32.859
    N20446 X35.676 Z-31.638
    N20447 X36.156 Z-30.898
    N20448 X37.115 Z-29.312
    N20449 X38.074 Z-27.548
    N20450 X38.554 Z-26.583
    N20451 X39.033 Z-25.551
    N20452 X39.758 Z-23.846
    N20453 X40.491 Z-21.866
    N20454 X40.979 Z-20.339
    N20455 X41.57 Z-18.178
    N20456 X42.184 Z-15.229
    N20457 X42.44 Z-13.521
    N20458 X42.798 Z-9.75
    N20459 X42.952 Z-8.854
    N20460 X43.217 Z-7.838
    N20461 X43.554 Z-6.91
    N20462 X43.779 Z-6.402
    N20463 X44.228 Z-5.547
    N20464 X44.677 Z-4.839
    N20465 X45.35 Z-3.958
    N20466 X45.799 Z-3.463
    N20467 X46.248 Z-3.013
    N20468 X46.697 Z-2.619
    N20469 X47.146 Z-2.258
    N20470 X48.044 Z-1.646
    N20471 X48.942 Z-1.151
    N20472 X49.391 Z-.945
    N20473 X50.289 Z-.595
    N20474 X51.187 Z-.331
    N20475 X52.085 Z-.146
    N20476 X52.984 Z-.036
    N20477 X53.882 Z0.
    N20478 Y-111.025
    N20479 X52.984 Z-.036
    N20480 X52.085 Z-.146
    N20481 X51.187 Z-.331
    N20482 X50.289 Z-.595
    N20483 X49.391 Z-.945
    N20484 X48.942 Z-1.151
    N20485 X48.044 Z-1.646
    N20486 X47.146 Z-2.258
    N20487 X46.248 Z-3.013
    N20488 X45.799 Z-3.463
    N20489 X45.35 Z-3.958
    N20490 X44.677 Z-4.839
    N20491 X44.228 Z-5.547
    N20492 X43.779 Z-6.402
    N20493 X43.554 Z-6.91
    N20494 X43.217 Z-7.838
    N20495 X42.952 Z-8.854
    N20496 X42.798 Z-9.75
    N20497 X42.44 Z-13.521
    N20498 X42.184 Z-15.229
    N20499 X41.57 Z-18.178
    N20500 X40.979 Z-20.339
    N20501 X40.491 Z-21.866
    N20502 X39.758 Z-23.846
    N20503 X39.033 Z-25.551
    N20504 X38.554 Z-26.583
    N20505 X38.074 Z-27.548
    N20506 X37.115 Z-29.312
    N20507 X36.156 Z-30.898
    N20508 X35.676 Z-31.638
    N20509 X34.839 Z-32.859
    N20510 X34.002 Z-33.989
    N20511 X33.166 Z-35.047
    N20512 X32.329 Z-36.043
    N20513 X31.408 Z-37.073
    N20514 X30.487 Z-38.035
    N20515 X29.566 Z-38.941
    N20516 X28.645 Z-39.796
    N20517 X27.77 Z-40.565
    N20518 X26.895 Z-41.292
    N20519 X26.02 Z-41.981
    N20520 X25.145 Z-42.634
    N20521 X24.233 Z-43.278
    N20522 X23.321 Z-43.886
    N20523 X22.41 Z-44.462
    N20524 X20.614 Z-45.507
    N20525 X18.845 Z-46.427
    N20526 X17.961 Z-46.848
    N20527 X16.151 Z-47.634
    N20528 X14.342 Z-48.323
    N20529 X12.559 Z-48.913
    N20530 X10.776 Z-49.418
    N20531 X8.958 Z-49.849
    N20532 X7.169 Z-50.192
    N20533 X5.362 Z-50.46
    N20534 X3.592 Z-50.648
    N20535 X1.797 Z-50.761
    N20536 X0. Z-50.8
    N20537 X-1.797 Z-50.761
    N20538 X-3.592 Z-50.648
    N20539 X-5.362 Z-50.46
    N20540 X-7.169 Z-50.192
    N20541 X-8.958 Z-49.849
    N20542 X-10.776 Z-49.418
    N20543 X-12.559 Z-48.913
    N20544 X-14.342 Z-48.323
    N20545 X-16.151 Z-47.634
    N20546 X-17.961 Z-46.848
    N20547 X-19.729 Z-45.98
    N20548 X-21.498 Z-45.007
    N20549 X-22.41 Z-44.462
    N20550 X-23.321 Z-43.886
    N20551 X-24.233 Z-43.278
    N20552 X-25.145 Z-42.634
    N20553 X-26.02 Z-41.981
    N20554 X-26.895 Z-41.292
    N20555 X-27.77 Z-40.565
    N20556 X-28.645 Z-39.796
    N20557 X-29.566 Z-38.941
    N20558 X-30.487 Z-38.035
    N20559 X-31.408 Z-37.073
    N20560 X-32.329 Z-36.043
    N20561 X-33.166 Z-35.047
    N20562 X-34.002 Z-33.989
    N20563 X-34.839 Z-32.859
    N20564 X-35.676 Z-31.638
    N20565 X-36.635 Z-30.125
    N20566 X-37.595 Z-28.455
    N20567 X-38.074 Z-27.548
    N20568 X-38.554 Z-26.583
    N20569 X-39.033 Z-25.551
    N20570 X-39.758 Z-23.846
    N20571 X-40.491 Z-21.866
    N20572 X-41.346 Z-19.058
    N20573 X-41.98 Z-16.329
    N20574 X-42.491 Z-13.112
    N20575 X-42.798 Z-9.75
    N20576 X-43.003 Z-8.619
    N20577 X-43.33 Z-7.496
    N20578 X-43.554 Z-6.91
    N20579 X-43.779 Z-6.402
    N20580 X-44.228 Z-5.547
    N20581 X-44.677 Z-4.839
    N20582 X-45.35 Z-3.958
    N20583 X-45.799 Z-3.463
    N20584 X-46.248 Z-3.013
    N20585 X-46.697 Z-2.619
    N20586 X-47.146 Z-2.258
    N20587 X-48.044 Z-1.646
    N20588 X-48.942 Z-1.151
    N20589 X-49.84 Z-.757
    N20590 X-50.289 Z-.595
    N20591 X-51.187 Z-.331
    N20592 X-52.085 Z-.146
    N20593 X-52.984 Z-.036
    N20594 X-53.882 Z0.
    N20595 Y-112.225
    N20596 X-52.984 Z-.036
    N20597 X-52.085 Z-.146
    N20598 X-51.187 Z-.331
    N20599 X-50.289 Z-.595
    N20600 X-49.84 Z-.757
    N20601 X-48.942 Z-1.151
    N20602 X-48.044 Z-1.646
    N20603 X-47.146 Z-2.258
    N20604 X-46.248 Z-3.013
    N20605 X-45.799 Z-3.463
    N20606 X-45.35 Z-3.958
    N20607 X-44.677 Z-4.839
    N20608 X-44.228 Z-5.547
    N20609 X-43.779 Z-6.402
    N20610 X-43.554 Z-6.91
    N20611 X-43.33 Z-7.496
    N20612 X-43.003 Z-8.619
    N20613 X-42.798 Z-9.75
    N20614 X-42.491 Z-13.112
    N20615 X-41.98 Z-16.329
    N20616 X-41.346 Z-19.058
    N20617 X-40.491 Z-21.866
    N20618 X-39.758 Z-23.846
    N20619 X-39.033 Z-25.551
    N20620 X-38.554 Z-26.583
    N20621 X-38.074 Z-27.548
    N20622 X-37.595 Z-28.455
    N20623 X-36.635 Z-30.125
    N20624 X-35.676 Z-31.638
    N20625 X-34.839 Z-32.859
    N20626 X-34.002 Z-33.989
    N20627 X-33.166 Z-35.047
    N20628 X-32.329 Z-36.043
    N20629 X-31.408 Z-37.073
    N20630 X-30.487 Z-38.035
    N20631 X-29.566 Z-38.941
    N20632 X-28.645 Z-39.796
    N20633 X-27.77 Z-40.565
    N20634 X-26.895 Z-41.292
    N20635 X-26.02 Z-41.981
    N20636 X-25.145 Z-42.634
    N20637 X-24.233 Z-43.278
    N20638 X-23.321 Z-43.886
    N20639 X-22.41 Z-44.462
    N20640 X-21.498 Z-45.007
    N20641 X-19.729 Z-45.98
    N20642 X-17.961 Z-46.848
    N20643 X-16.151 Z-47.634
    N20644 X-14.342 Z-48.323
    N20645 X-12.559 Z-48.913
    N20646 X-10.776 Z-49.418
    N20647 X-8.958 Z-49.849
    N20648 X-7.169 Z-50.192
    N20649 X-5.362 Z-50.46
    N20650 X-3.592 Z-50.648
    N20651 X-1.797 Z-50.761
    N20652 X0. Z-50.8
    N20653 X1.797 Z-50.761
    N20654 X3.592 Z-50.648
    N20655 X5.362 Z-50.46
    N20656 X7.169 Z-50.192
    N20657 X8.958 Z-49.849
    N20658 X10.776 Z-49.418
    N20659 X12.559 Z-48.913
    N20660 X14.342 Z-48.323
    N20661 X16.151 Z-47.634
    N20662 X17.961 Z-46.848
    N20663 X18.845 Z-46.427
    N20664 X20.614 Z-45.507
    N20665 X22.41 Z-44.462
    N20666 X23.321 Z-43.886
    N20667 X24.233 Z-43.278
    N20668 X25.145 Z-42.634
    N20669 X26.02 Z-41.981
    N20670 X26.895 Z-41.292
    N20671 X27.77 Z-40.565
    N20672 X28.645 Z-39.796
    N20673 X29.566 Z-38.941
    N20674 X30.487 Z-38.035
    N20675 X31.408 Z-37.073
    N20676 X32.329 Z-36.043
    N20677 X33.166 Z-35.047
    N20678 X34.002 Z-33.989
    N20679 X34.839 Z-32.859
    N20680 X35.676 Z-31.638
    N20681 X36.156 Z-30.898
    N20682 X37.115 Z-29.312
    N20683 X38.074 Z-27.548
    N20684 X38.554 Z-26.583
    N20685 X39.033 Z-25.551
    N20686 X39.758 Z-23.846
    N20687 X40.491 Z-21.866
    N20688 X40.979 Z-20.339
    N20689 X41.57 Z-18.178
    N20690 X42.184 Z-15.229
    N20691 X42.44 Z-13.521
    N20692 X42.798 Z-9.75
    N20693 X42.952 Z-8.854
    N20694 X43.217 Z-7.838
    N20695 X43.554 Z-6.91
    N20696 X43.779 Z-6.402
    N20697 X44.228 Z-5.547
    N20698 X44.677 Z-4.839
    N20699 X45.35 Z-3.958
    N20700 X45.799 Z-3.463
    N20701 X46.248 Z-3.013
    N20702 X47.146 Z-2.258
    N20703 X48.044 Z-1.646
    N20704 X48.942 Z-1.151
    N20705 X49.391 Z-.945
    N20706 X50.289 Z-.595
    N20707 X51.187 Z-.331
    N20708 X52.085 Z-.146
    N20709 X52.984 Z-.036
    N20710 X53.882 Z0.
    N20711 Y-113.425
    N20712 X52.984 Z-.036
    N20713 X52.085 Z-.146
    N20714 X51.187 Z-.331
    N20715 X50.289 Z-.595
    N20716 X49.391 Z-.945
    N20717 X48.942 Z-1.151
    N20718 X48.044 Z-1.646
    N20719 X47.146 Z-2.258
    N20720 X46.248 Z-3.013
    N20721 X45.799 Z-3.463
    N20722 X45.35 Z-3.958
    N20723 X44.677 Z-4.839
    N20724 X44.228 Z-5.547
    N20725 X43.779 Z-6.402
    N20726 X43.554 Z-6.91
    N20727 X43.217 Z-7.838
    N20728 X42.952 Z-8.854
    N20729 X42.798 Z-9.751
    N20730 X42.44 Z-13.521
    N20731 X42.184 Z-15.229
    N20732 X41.57 Z-18.179
    N20733 X40.979 Z-20.339
    N20734 X40.491 Z-21.866
    N20735 X39.758 Z-23.846
    N20736 X39.033 Z-25.551
    N20737 X38.554 Z-26.583
    N20738 X38.074 Z-27.548
    N20739 X37.115 Z-29.312
    N20740 X36.156 Z-30.898
    N20741 X35.676 Z-31.638
    N20742 X34.839 Z-32.859
    N20743 X34.002 Z-33.989
    N20744 X33.166 Z-35.047
    N20745 X32.329 Z-36.043
    N20746 X31.408 Z-37.073
    N20747 X30.487 Z-38.035
    N20748 X29.566 Z-38.941
    N20749 X28.645 Z-39.796
    N20750 X27.77 Z-40.565
    N20751 X26.895 Z-41.292
    N20752 X26.02 Z-41.981
    N20753 X25.145 Z-42.634
    N20754 X24.233 Z-43.278
    N20755 X23.321 Z-43.886
    N20756 X22.41 Z-44.462
    N20757 X20.614 Z-45.507
    N20758 X18.845 Z-46.427
    N20759 X17.961 Z-46.848
    N20760 X16.151 Z-47.634
    N20761 X14.342 Z-48.323
    N20762 X12.559 Z-48.913
    N20763 X10.776 Z-49.418
    N20764 X8.958 Z-49.849
    N20765 X7.169 Z-50.192
    N20766 X5.362 Z-50.46
    N20767 X3.592 Z-50.648
    N20768 X1.797 Z-50.761
    N20769 X0. Z-50.8
    N20770 X-1.797 Z-50.761
    N20771 X-3.592 Z-50.648
    N20772 X-5.362 Z-50.46
    N20773 X-7.169 Z-50.192
    N20774 X-8.958 Z-49.849
    N20775 X-10.776 Z-49.418
    N20776 X-12.559 Z-48.913
    N20777 X-14.342 Z-48.323
    N20778 X-16.151 Z-47.634
    N20779 X-17.961 Z-46.848
    N20780 X-19.729 Z-45.98
    N20781 X-21.498 Z-45.007
    N20782 X-22.41 Z-44.462
    N20783 X-23.321 Z-43.886
    N20784 X-24.233 Z-43.278
    N20785 X-25.145 Z-42.634
    N20786 X-26.02 Z-41.981
    N20787 X-26.895 Z-41.292
    N20788 X-27.77 Z-40.565
    N20789 X-28.645 Z-39.796
    N20790 X-29.566 Z-38.941
    N20791 X-30.487 Z-38.035
    N20792 X-31.408 Z-37.073
    N20793 X-32.329 Z-36.043
    N20794 X-33.166 Z-35.047
    N20795 X-34.002 Z-33.989
    N20796 X-34.839 Z-32.859
    N20797 X-35.676 Z-31.638
    N20798 X-36.635 Z-30.125
    N20799 X-37.595 Z-28.455
    N20800 X-38.074 Z-27.548
    N20801 X-38.554 Z-26.583
    N20802 X-39.033 Z-25.551
    N20803 X-39.758 Z-23.846
    N20804 X-40.491 Z-21.866
    N20805 X-41.346 Z-19.058
    N20806 X-41.98 Z-16.329
    N20807 X-42.491 Z-13.112
    N20808 X-42.798 Z-9.751
    N20809 X-43.003 Z-8.619
    N20810 X-43.33 Z-7.496
    N20811 X-43.554 Z-6.91
    N20812 X-43.779 Z-6.402
    N20813 X-44.228 Z-5.547
    N20814 X-44.677 Z-4.839
    N20815 X-45.35 Z-3.958
    N20816 X-45.799 Z-3.463
    N20817 X-46.248 Z-3.013
    N20818 X-47.146 Z-2.258
    N20819 X-48.044 Z-1.646
    N20820 X-48.942 Z-1.151
    N20821 X-49.84 Z-.757
    N20822 X-50.289 Z-.596
    N20823 X-51.187 Z-.331
    N20824 X-52.085 Z-.146
    N20825 X-52.984 Z-.036
    N20826 X-53.882 Z0.
    N20827 Y-114.625
    N20828 X-52.984 Z-.036
    N20829 X-52.085 Z-.146
    N20830 X-51.187 Z-.331
    N20831 X-50.289 Z-.596
    N20832 X-49.84 Z-.757
    N20833 X-48.942 Z-1.151
    N20834 X-48.044 Z-1.646
    N20835 X-47.146 Z-2.258
    N20836 X-46.248 Z-3.013
    N20837 X-45.799 Z-3.463
    N20838 X-45.35 Z-3.958
    N20839 X-44.677 Z-4.839
    N20840 X-44.228 Z-5.547
    N20841 X-43.779 Z-6.402
    N20842 X-43.554 Z-6.91
    N20843 X-43.33 Z-7.496
    N20844 X-43.003 Z-8.619
    N20845 X-42.798 Z-9.751
    N20846 X-42.491 Z-13.112
    N20847 X-41.98 Z-16.329
    N20848 X-41.346 Z-19.058
    N20849 X-40.491 Z-21.866
    N20850 X-39.758 Z-23.846
    N20851 X-39.033 Z-25.551
    N20852 X-38.554 Z-26.583
    N20853 X-38.074 Z-27.548
    N20854 X-37.595 Z-28.455
    N20855 X-36.635 Z-30.125
    N20856 X-35.676 Z-31.638
    N20857 X-34.839 Z-32.859
    N20858 X-34.002 Z-33.989
    N20859 X-33.166 Z-35.047
    N20860 X-32.329 Z-36.043
    N20861 X-31.408 Z-37.073
    N20862 X-30.487 Z-38.035
    N20863 X-29.566 Z-38.941
    N20864 X-28.645 Z-39.796
    N20865 X-27.77 Z-40.565
    N20866 X-26.895 Z-41.292
    N20867 X-26.02 Z-41.981
    N20868 X-25.145 Z-42.634
    N20869 X-24.233 Z-43.278
    N20870 X-23.321 Z-43.886
    N20871 X-22.41 Z-44.462
    N20872 X-21.498 Z-45.007
    N20873 X-19.729 Z-45.98
    N20874 X-17.961 Z-46.848
    N20875 X-16.151 Z-47.634
    N20876 X-14.342 Z-48.323
    N20877 X-12.559 Z-48.913
    N20878 X-10.776 Z-49.418
    N20879 X-8.958 Z-49.849
    N20880 X-7.169 Z-50.192
    N20881 X-5.362 Z-50.46
    N20882 X-3.592 Z-50.648
    N20883 X-1.797 Z-50.761
    N20884 X0. Z-50.8
    N20885 X1.797 Z-50.761
    N20886 X3.592 Z-50.648
    N20887 X5.362 Z-50.46
    N20888 X7.169 Z-50.192
    N20889 X8.958 Z-49.849
    N20890 X10.776 Z-49.418
    N20891 X12.559 Z-48.913
    N20892 X14.342 Z-48.323
    N20893 X16.151 Z-47.634
    N20894 X17.961 Z-46.848
    N20895 X18.845 Z-46.427
    N20896 X20.614 Z-45.507
    N20897 X22.41 Z-44.462
    N20898 X23.321 Z-43.886
    N20899 X24.233 Z-43.278
    N20900 X25.145 Z-42.634
    N20901 X26.02 Z-41.981
    N20902 X26.895 Z-41.292
    N20903 X27.77 Z-40.565
    N20904 X28.645 Z-39.796
    N20905 X29.566 Z-38.941
    N20906 X30.487 Z-38.035
    N20907 X31.408 Z-37.073
    N20908 X32.329 Z-36.043
    N20909 X33.166 Z-35.047
    N20910 X34.002 Z-33.989
    N20911 X34.839 Z-32.859
    N20912 X35.676 Z-31.638
    N20913 X36.156 Z-30.898
    N20914 X37.115 Z-29.312
    N20915 X38.074 Z-27.548
    N20916 X38.554 Z-26.583
    N20917 X39.033 Z-25.551
    N20918 X39.758 Z-23.846
    N20919 X40.491 Z-21.866
    N20920 X40.979 Z-20.339
    N20921 X41.57 Z-18.179
    N20922 X42.184 Z-15.229
    N20923 X42.44 Z-13.521
    N20924 X42.798 Z-9.751
    N20925 X42.952 Z-8.854
    N20926 X43.217 Z-7.838
    N20927 X43.554 Z-6.91
    N20928 X43.779 Z-6.402
    N20929 X44.228 Z-5.547
    N20930 X44.677 Z-4.839
    N20931 X45.35 Z-3.958
    N20932 X45.799 Z-3.463
    N20933 X46.248 Z-3.013
    N20934 X47.146 Z-2.258
    N20935 X48.044 Z-1.646
    N20936 X48.942 Z-1.151
    N20937 X49.391 Z-.945
    N20938 X50.289 Z-.596
    N20939 X51.187 Z-.331
    N20940 X52.085 Z-.146
    N20941 X52.984 Z-.036
    N20942 X53.882 Z0.
    N20943 Y-115.825
    N20944 X52.984 Z-.036
    N20945 X52.085 Z-.146
    N20946 X51.187 Z-.331
    N20947 X50.289 Z-.596
    N20948 X49.391 Z-.945
    N20949 X48.942 Z-1.151
    N20950 X48.044 Z-1.646
    N20951 X47.146 Z-2.258
    N20952 X46.248 Z-3.013
    N20953 X45.799 Z-3.463
    N20954 X45.35 Z-3.958
    N20955 X44.677 Z-4.839
    N20956 X44.228 Z-5.547
    N20957 X43.779 Z-6.401
    N20958 X43.554 Z-6.91
    N20959 X43.217 Z-7.838
    N20960 X42.952 Z-8.854
    N20961 X42.798 Z-9.751
    N20962 X42.44 Z-13.521
    N20963 X42.184 Z-15.229
    N20964 X41.57 Z-18.179
    N20965 X40.979 Z-20.339
    N20966 X40.491 Z-21.866
    N20967 X39.758 Z-23.846
    N20968 X39.033 Z-25.551
    N20969 X38.554 Z-26.583
    N20970 X38.074 Z-27.548
    N20971 X37.115 Z-29.312
    N20972 X36.156 Z-30.898
    N20973 X35.676 Z-31.638
    N20974 X34.839 Z-32.859
    N20975 X34.002 Z-33.989
    N20976 X33.166 Z-35.047
    N20977 X32.329 Z-36.043
    N20978 X31.408 Z-37.073
    N20979 X30.487 Z-38.035
    N20980 X29.566 Z-38.941
    N20981 X28.645 Z-39.796
    N20982 X27.77 Z-40.565
    N20983 X26.895 Z-41.292
    N20984 X26.02 Z-41.981
    N20985 X25.145 Z-42.634
    N20986 X24.233 Z-43.278
    N20987 X23.321 Z-43.886
    N20988 X22.41 Z-44.462
    N20989 X20.614 Z-45.507
    N20990 X18.845 Z-46.427
    N20991 X17.961 Z-46.848
    N20992 X16.151 Z-47.634
    N20993 X14.342 Z-48.323
    N20994 X12.559 Z-48.913
    N20995 X10.776 Z-49.418
    N20996 X8.958 Z-49.849
    N20997 X7.169 Z-50.192
    N20998 X5.362 Z-50.46
    N20999 X3.592 Z-50.648
    N21000 X1.797 Z-50.761
    N21001 X0. Z-50.8
    N21002 X-1.797 Z-50.761
    N21003 X-3.592 Z-50.648
    N21004 X-5.362 Z-50.46
    N21005 X-7.169 Z-50.192
    N21006 X-8.958 Z-49.849
    N21007 X-10.776 Z-49.418
    N21008 X-12.559 Z-48.913
    N21009 X-14.342 Z-48.323
    N21010 X-16.151 Z-47.634
    N21011 X-17.961 Z-46.848
    N21012 X-19.729 Z-45.98
    N21013 X-21.498 Z-45.007
    N21014 X-22.41 Z-44.462
    N21015 X-23.321 Z-43.886
    N21016 X-24.233 Z-43.278
    N21017 X-25.145 Z-42.634
    N21018 X-26.02 Z-41.981
    N21019 X-26.895 Z-41.292
    N21020 X-27.77 Z-40.565
    N21021 X-28.645 Z-39.796
    N21022 X-29.566 Z-38.941
    N21023 X-30.487 Z-38.035
    N21024 X-31.408 Z-37.073
    N21025 X-32.329 Z-36.043
    N21026 X-33.166 Z-35.047
    N21027 X-34.002 Z-33.989
    N21028 X-34.839 Z-32.859
    N21029 X-35.676 Z-31.638
    N21030 X-36.635 Z-30.125
    N21031 X-37.595 Z-28.455
    N21032 X-38.074 Z-27.548
    N21033 X-38.554 Z-26.583
    N21034 X-39.033 Z-25.551
    N21035 X-39.758 Z-23.846
    N21036 X-40.491 Z-21.866
    N21037 X-41.346 Z-19.058
    N21038 X-41.98 Z-16.329
    N21039 X-42.491 Z-13.112
    N21040 X-42.798 Z-9.751
    N21041 X-43.003 Z-8.619
    N21042 X-43.33 Z-7.496
    N21043 X-43.554 Z-6.91
    N21044 X-43.779 Z-6.401
    N21045 X-44.228 Z-5.547
    N21046 X-44.677 Z-4.839
    N21047 X-45.35 Z-3.958
    N21048 X-45.799 Z-3.463
    N21049 X-46.248 Z-3.013
    N21050 X-47.146 Z-2.258
    N21051 X-48.044 Z-1.646
    N21052 X-48.942 Z-1.151
    N21053 X-49.84 Z-.757
    N21054 X-50.289 Z-.596
    N21055 X-51.187 Z-.331
    N21056 X-52.085 Z-.146
    N21057 X-52.984 Z-.036
    N21058 X-53.882 Z0.
    N21059 Y-117.025
    N21060 X-52.984 Z-.036
    N21061 X-52.085 Z-.146
    N21062 X-51.187 Z-.331
    N21063 X-50.289 Z-.596
    N21064 X-49.84 Z-.757
    N21065 X-48.942 Z-1.151
    N21066 X-48.044 Z-1.646
    N21067 X-47.146 Z-2.258
    N21068 X-46.248 Z-3.013
    N21069 X-45.799 Z-3.463
    N21070 X-45.35 Z-3.958
    N21071 X-44.677 Z-4.839
    N21072 X-44.228 Z-5.547
    N21073 X-43.779 Z-6.401
    N21074 X-43.554 Z-6.91
    N21075 X-43.33 Z-7.496
    N21076 X-43.003 Z-8.619
    N21077 X-42.798 Z-9.751
    N21078 X-42.491 Z-13.112
    N21079 X-41.98 Z-16.329
    N21080 X-41.346 Z-19.058
    N21081 X-40.491 Z-21.866
    N21082 X-39.758 Z-23.846
    N21083 X-39.033 Z-25.551
    N21084 X-38.554 Z-26.583
    N21085 X-38.074 Z-27.548
    N21086 X-37.595 Z-28.455
    N21087 X-36.635 Z-30.125
    N21088 X-35.676 Z-31.638
    N21089 X-34.839 Z-32.859
    N21090 X-34.002 Z-33.989
    N21091 X-33.166 Z-35.047
    N21092 X-32.329 Z-36.043
    N21093 X-31.408 Z-37.073
    N21094 X-30.487 Z-38.035
    N21095 X-29.566 Z-38.941
    N21096 X-28.645 Z-39.796
    N21097 X-27.77 Z-40.565
    N21098 X-26.895 Z-41.292
    N21099 X-26.02 Z-41.981
    N21100 X-25.145 Z-42.634
    N21101 X-24.233 Z-43.278
    N21102 X-23.321 Z-43.886
    N21103 X-22.41 Z-44.462
    N21104 X-21.498 Z-45.007
    N21105 X-19.729 Z-45.98
    N21106 X-17.961 Z-46.848
    N21107 X-16.151 Z-47.634
    N21108 X-14.342 Z-48.323
    N21109 X-12.559 Z-48.913
    N21110 X-10.776 Z-49.418
    N21111 X-8.958 Z-49.849
    N21112 X-7.169 Z-50.192
    N21113 X-5.362 Z-50.46
    N21114 X-3.592 Z-50.648
    N21115 X-1.797 Z-50.761
    N21116 X0. Z-50.8
    N21117 X1.797 Z-50.761
    N21118 X3.592 Z-50.648
    N21119 X5.362 Z-50.46
    N21120 X7.169 Z-50.192
    N21121 X8.958 Z-49.849
    N21122 X10.776 Z-49.418
    N21123 X12.559 Z-48.913
    N21124 X14.342 Z-48.323
    N21125 X16.151 Z-47.634
    N21126 X17.961 Z-46.848
    N21127 X18.845 Z-46.427
    N21128 X20.614 Z-45.507
    N21129 X22.41 Z-44.462
    N21130 X23.321 Z-43.886
    N21131 X24.233 Z-43.278
    N21132 X25.145 Z-42.634
    N21133 X26.02 Z-41.981
    N21134 X26.895 Z-41.292
    N21135 X27.77 Z-40.565
    N21136 X28.645 Z-39.796
    N21137 X29.566 Z-38.941
    N21138 X30.487 Z-38.035
    N21139 X31.408 Z-37.073
    N21140 X32.329 Z-36.043
    N21141 X33.166 Z-35.047
    N21142 X34.002 Z-33.989
    N21143 X34.839 Z-32.859
    N21144 X35.676 Z-31.638
    N21145 X36.156 Z-30.898
    N21146 X37.115 Z-29.312
    N21147 X38.074 Z-27.548
    N21148 X38.554 Z-26.583
    N21149 X39.033 Z-25.551
    N21150 X39.758 Z-23.846
    N21151 X40.491 Z-21.866
    N21152 X40.979 Z-20.339
    N21153 X41.57 Z-18.179
    N21154 X42.184 Z-15.229
    N21155 X42.44 Z-13.521
    N21156 X42.798 Z-9.751
    N21157 X42.952 Z-8.854
    N21158 X43.217 Z-7.838
    N21159 X43.554 Z-6.91
    N21160 X43.779 Z-6.401
    N21161 X44.228 Z-5.547
    N21162 X44.677 Z-4.839
    N21163 X45.35 Z-3.958
    N21164 X45.799 Z-3.463
    N21165 X46.248 Z-3.013
    N21166 X47.146 Z-2.258
    N21167 X48.044 Z-1.646
    N21168 X48.942 Z-1.151
    N21169 X49.84 Z-.757
    N21170 X50.289 Z-.596
    N21171 X51.187 Z-.331
    N21172 X52.085 Z-.146
    N21173 X52.984 Z-.036
    N21174 X53.882 Z0.
    N21175 Y-118.225
    N21176 X52.984 Z-.036
    N21177 X52.085 Z-.146
    N21178 X51.187 Z-.331
    N21179 X50.289 Z-.596
    N21180 X49.84 Z-.757
    N21181 X48.942 Z-1.151
    N21182 X48.044 Z-1.646
    N21183 X47.146 Z-2.258
    N21184 X46.248 Z-3.013
    N21185 X45.799 Z-3.463
    N21186 X45.35 Z-3.958
    N21187 X44.677 Z-4.839
    N21188 X44.228 Z-5.547
    N21189 X43.779 Z-6.401
    N21190 X43.554 Z-6.911
    N21191 X43.217 Z-7.839
    N21192 X42.952 Z-8.854
    N21193 X42.798 Z-9.751
    N21194 X42.44 Z-13.521
    N21195 X42.184 Z-15.23
    N21196 X41.57 Z-18.179
    N21197 X40.979 Z-20.339
    N21198 X40.491 Z-21.866
    N21199 X39.757 Z-23.846
    N21200 X39.033 Z-25.551
    N21201 X38.554 Z-26.583
    N21202 X38.074 Z-27.548
    N21203 X37.115 Z-29.312
    N21204 X36.156 Z-30.898
    N21205 X35.676 Z-31.638
    N21206 X34.839 Z-32.859
    N21207 X34.002 Z-33.989
    N21208 X33.166 Z-35.047
    N21209 X32.329 Z-36.043
    N21210 X31.408 Z-37.073
    N21211 X30.487 Z-38.035
    N21212 X29.566 Z-38.941
    N21213 X28.645 Z-39.796
    N21214 X27.77 Z-40.565
    N21215 X26.895 Z-41.292
    N21216 X26.02 Z-41.981
    N21217 X25.145 Z-42.634
    N21218 X24.233 Z-43.278
    N21219 X23.321 Z-43.886
    N21220 X22.41 Z-44.462
    N21221 X20.614 Z-45.507
    N21222 X18.845 Z-46.427
    N21223 X17.961 Z-46.848
    N21224 X16.151 Z-47.634
    N21225 X14.342 Z-48.323
    N21226 X12.559 Z-48.913
    N21227 X10.776 Z-49.418
    N21228 X8.958 Z-49.849
    N21229 X7.169 Z-50.192
    N21230 X5.362 Z-50.46
    N21231 X3.592 Z-50.648
    N21232 X1.797 Z-50.761
    N21233 X0. Z-50.8
    N21234 X-1.797 Z-50.761
    N21235 X-3.592 Z-50.648
    N21236 X-5.362 Z-50.46
    N21237 X-7.169 Z-50.192
    N21238 X-8.958 Z-49.849
    N21239 X-10.776 Z-49.418
    N21240 X-12.559 Z-48.913
    N21241 X-14.342 Z-48.323
    N21242 X-16.151 Z-47.634
    N21243 X-17.961 Z-46.848
    N21244 X-19.729 Z-45.98
    N21245 X-21.498 Z-45.007
    N21246 X-22.41 Z-44.462
    N21247 X-23.321 Z-43.886
    N21248 X-24.233 Z-43.278
    N21249 X-25.145 Z-42.634
    N21250 X-26.02 Z-41.981
    N21251 X-26.895 Z-41.292
    N21252 X-27.77 Z-40.565
    N21253 X-28.645 Z-39.796
    N21254 X-29.566 Z-38.941
    N21255 X-30.487 Z-38.035
    N21256 X-31.408 Z-37.073
    N21257 X-32.329 Z-36.043
    N21258 X-33.166 Z-35.047
    N21259 X-34.002 Z-33.989
    N21260 X-34.839 Z-32.859
    N21261 X-35.676 Z-31.638
    N21262 X-36.635 Z-30.125
    N21263 X-37.595 Z-28.455
    N21264 X-38.074 Z-27.548
    N21265 X-38.554 Z-26.583
    N21266 X-39.033 Z-25.551
    N21267 X-39.757 Z-23.846
    N21268 X-40.491 Z-21.866
    N21269 X-41.346 Z-19.058
    N21270 X-41.98 Z-16.329
    N21271 X-42.491 Z-13.112
    N21272 X-42.798 Z-9.751
    N21273 X-43.003 Z-8.619
    N21274 X-43.33 Z-7.496
    N21275 X-43.554 Z-6.911
    N21276 X-43.779 Z-6.401
    N21277 X-44.228 Z-5.547
    N21278 X-44.677 Z-4.839
    N21279 X-45.35 Z-3.958
    N21280 X-45.799 Z-3.463
    N21281 X-46.248 Z-3.013
    N21282 X-47.146 Z-2.258
    N21283 X-48.044 Z-1.646
    N21284 X-48.942 Z-1.151
    N21285 X-49.84 Z-.757
    N21286 X-50.289 Z-.596
    N21287 X-51.187 Z-.331
    N21288 X-52.085 Z-.146
    N21289 X-52.984 Z-.036
    N21290 X-53.882 Z0.
    N21291 Y-119.425
    N21292 X-52.984 Z-.036
    N21293 X-52.085 Z-.146
    N21294 X-51.187 Z-.331
    N21295 X-50.289 Z-.596
    N21296 X-49.84 Z-.757
    N21297 X-48.942 Z-1.151
    N21298 X-48.044 Z-1.646
    N21299 X-47.146 Z-2.258
    N21300 X-46.248 Z-3.013
    N21301 X-45.799 Z-3.463
    N21302 X-45.35 Z-3.958
    N21303 X-44.677 Z-4.839
    N21304 X-44.228 Z-5.547
    N21305 X-43.779 Z-6.401
    N21306 X-43.554 Z-6.911
    N21307 X-43.33 Z-7.496
    N21308 X-43.133 Z-8.127
    N21309 X-43.105 Z-8.134
    N21310 X43.105
    N21311 X43.133 Z-8.127
    N21312 X43.554 Z-6.911
    N21313 X43.779 Z-6.401
    N21314 X44.228 Z-5.547
    N21315 X44.677 Z-4.839
    N21316 X45.35 Z-3.958
    N21317 X45.799 Z-3.463
    N21318 X46.248 Z-3.013
    N21319 X47.146 Z-2.258
    N21320 X48.044 Z-1.646
    N21321 X48.942 Z-1.151
    N21322 X49.84 Z-.757
    N21323 X50.289 Z-.596
    N21324 X51.187 Z-.331
    N21325 X52.085 Z-.146
    N21326 X52.984 Z-.036
    N21327 X53.882 Z0.
    N21328 Y-120.625
    N21329 X52.984 Z-.036
    N21330 X52.085 Z-.146
    N21331 X51.187 Z-.331
    N21332 X50.289 Z-.596
    N21333 X49.84 Z-.757
    N21334 X48.942 Z-1.151
    N21335 X48.044 Z-1.646
    N21336 X47.146 Z-2.258
    N21337 X46.248 Z-3.013
    N21338 X45.799 Z-3.463
    N21339 X45.35 Z-3.958
    N21340 X44.677 Z-4.839
    N21341 X44.34 Z-5.361
    N21342 X44.228 Z-5.374
    N21343 X-44.31
    N21344 X-44.335 Z-5.37
    N21345 X-44.708 Z-4.794
    N21346 X-45.106 Z-4.263
    N21347 X-45.504 Z-3.78
    N21348 X-46.299 Z-2.966
    N21349 X-47.146 Z-2.258
    N21350 X-48.044 Z-1.646
    N21351 X-48.942 Z-1.151
    N21352 X-49.84 Z-.757
    N21353 X-50.289 Z-.596
    N21354 X-51.187 Z-.331
    N21355 X-52.085 Z-.146
    N21356 X-52.984 Z-.036
    N21357 X-53.882 Z0.
    N21358 Y-121.825
    N21359 X-52.984 Z-.036
    N21360 X-52.085 Z-.146
    N21361 X-51.187 Z-.331
    N21362 X-50.289 Z-.596
    N21363 X-49.84 Z-.757
    N21364 X-48.942 Z-1.151
    N21365 X-48.044 Z-1.646
    N21366 X-47.146 Z-2.258
    N21367 X-46.697 Z-2.62
    N21368 X-45.985 Z-3.27
    N21369 X-45.541 Z-3.739
    N21370 X-45.452 Z-3.748
    N21371 X45.519
    N21372 X46.248 Z-3.013
    N21373 X47.146 Z-2.258
    N21374 X48.044 Z-1.646
    N21375 X48.942 Z-1.151
    N21376 X49.84 Z-.757
    N21377 X50.289 Z-.596
    N21378 X51.187 Z-.331
    N21379 X52.085 Z-.146
    N21380 X52.984 Z-.036
    N21381 X53.882 Z0.
    N21382 Y-123.025
    N21383 X52.984 Z-.036
    N21384 X52.085 Z-.146
    N21385 X51.187 Z-.331
    N21386 X50.289 Z-.596
    N21387 X49.84 Z-.756
    N21388 X48.942 Z-1.151
    N21389 X48.044 Z-1.646
    N21390 X47.595 Z-1.94
    N21391 X46.697 Z-2.591
    N21392 X-46.697
    N21393 X-47.595 Z-1.94
    N21394 X-48.044 Z-1.646
    N21395 X-48.942 Z-1.151
    N21396 X-49.84 Z-.757
    N21397 X-50.289 Z-.596
    N21398 X-51.187 Z-.331
    N21399 X-52.085 Z-.146
    N21400 X-52.984 Z-.036
    N21401 X-53.882 Z0.
    N21402 Y-124.225
    N21403 X-52.984 Z-.036
    N21404 X-52.085 Z-.146
    N21405 X-51.187 Z-.331
    N21406 X-50.289 Z-.596
    N21407 X-49.84 Z-.756
    N21408 X-48.942 Z-1.151
    N21409 X-47.936 Z-1.713
    N21410 X47.924 Z-1.716
    N21411 X48.942 Z-1.151
    N21412 X49.84 Z-.756
    N21413 X50.289 Z-.596
    N21414 X51.187 Z-.331
    N21415 X52.085 Z-.146
    N21416 X52.984 Z-.036
    N21417 X53.882 Z0.
    N21418 Y-125.425
    N21419 X52.984 Z-.036
    N21420 X52.085 Z-.146
    N21421 X51.187 Z-.331
    N21422 X50.289 Z-.596
    N21423 X49.84 Z-.756
    N21424 X49.167 Z-1.045
    N21425 X-48.942 Z-1.06
    N21426 X-49.167 Z-1.045
    N21427 X-49.84 Z-.756
    N21428 X-50.289 Z-.596
    N21429 X-51.187 Z-.331
    N21430 X-52.085 Z-.146
    N21431 X-52.984 Z-.036
    N21432 X-53.882 Z0.
    N21433 Y-126.625
    N21434 X-52.984 Z-.036
    N21435 X-52.085 Z-.146
    N21436 X-51.187 Z-.331
    N21437 X-50.289 Z-.582
    N21438 X50.289
    N21439 X51.187 Z-.331
    N21440 X52.085 Z-.146
    N21441 X52.984 Z-.036
    N21442 X53.882 Z0.
    N21443 X53.817 Y-127.825
    N21444 X52.92 Z-.036
    N21445 X52.023 Z-.146
    N21446 X51.446 Z-.241
    N21447 X-51.352 Z-.244
    N21448 X-52.262 Z-.112
    N21449 X-53.04 Z-.028
    N21450 X-53.817 Z0.
    N21451 X-53.372 Y-129.025
    N21452 X-51.323 Z-.056
    N21453 X51.593 Z-.052
    N21454 X53.372 Z0.
    N21455 X50.74 Y-130.174
    N21456 X-50.74
    N21457 G00 Z2.6
    N21458 M09
    N21459 M05
    N21460 G91 G28 Z0.
    N21461 G91 G28 X0. Y0.
    N21462 M02
    N21463 M30
    Thanks once more
    Sven.
    Mar 2005
    988
    I would say that the M2 control cannot take a 5-digit "N" number. You must limit it to 4 digits (N9999 is max). Try that....
    It's just a part..... cutter still goes round and round....
    Nov 2005
    57
    Okey I accept that but whot can I do
    the program have more than 20000 lines?
    Thank you Sven.
    Feb 2007
    198
    the use of the sequence number (aka "N word") is OPTIONAL. many people these days only use it on the tool change line to flag the tool change and leave it out. if you insist on using it, you have to start the count over once you max it out. it is using up valuable program memory without adding any value to the machining.
    jim
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. MAZATROL CAM T1
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-26-2012, 05:59 PM
  3. Sm1 well versed with mazatrol 640m or atleast ne mazatrol
    By naren1608 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-22-2010, 11:29 AM
  4. Mazatrol cam T2
    By hikerlight in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-19-2009, 05:34 AM
  5. Mazatrol T-3
    By robind in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2009, 06:52 PM
