588,033 active members*
5,538 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Max Tool Dia. Umbrella Changer
Results 1 to 3 of 3
    Dec 2006
    8
    Hello,
    I have a quick question regarding the max. tool diameter for an umbrella style changer on a Haas VF-2. The book says, 3.5"/ NA to adj. empty. Does this mean i can't increase my tool dia. by leaving the (2) adjacent slots open? I am trying to use a boring head for a 90 mm hole (3.54").
    Oct 2009
    192
    twitte,
    You can indeed use a larger diameter tool by leaving pockets next to that pocket empty. I know someone who uses a ten inch cutter - and it goes in the umberella tool changer nicely. Just be careful on weight thats all. To be honest I could not tell you a weight limit - but obviously the larger diameter tool you use - the heavier it is likely to be. If its too heavy then you could risk bending the disk.
    Hope this helps
    Dec 2006
    8
    Ok great, this is what I was looking for.
    Thanks for the reply.
  1. MIT 320 UMBRELLA TOOL CHANGE
    By richard booker in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-10-2012, 06:49 PM
  2. Hoss 16 Tool Automatic Tool Changer
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-03-2011, 10:29 PM
  3. Replies: 8
    Last Post: 02-01-2010, 04:45 PM
  4. Tool Change Recovery VF3 Umbrella
    By cncmaintenance in forum Haas Mills
    Last Post: 11-07-2008, 07:05 PM
  5. Tool Changer picks up wrong Tool?
    By KJ45 in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2008, 12:51 PM
