588,500 active members*
4,863 visitors online*
Thread: Hoss's G0704
Page 31 of 48 21293031323341
Results 601 to 620 of 945
  1. #601
    Quote Originally Posted by mwood3 View Post
    nice simple straight forward kit
    That's the phase 1 plan K.I.S.S.
    minimum parts, minimum tooling, minimum machining = simple and affordable.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #602
    Quote Originally Posted by photomankc View Post
    Sweet! I'll be looking to go to ball screws in the long run but getting going with the stock screws would be great. Any idea on when you think you'll have drawings out for it? I could likely make up my own but if I'm going to follow along I best wait up on the dimensions.
    probably not till after the ballscrews version is done, about a month.
    Want to make sure that the same parts work for both, they do on paper.
    Hoss
  3. #603
    Quote Originally Posted by rcazwillis View Post
    Hoss,
    Why the belt drive the for Z? Is this to reduce the overall height of the machine? Are you doing it now to clean up the appearance of the machine for the time when you put the X on the back?
    The belt drive will let someone use a smaller motor for the Z if they want or for a servo.
    Plus with a plastic cover, should look nice and clean.
    Hoss
  4. #604
    Dec 2009
    1416
    Quote Originally Posted by hoss2006 View Post
    Hoss
    I can understand that. I definitely appreciate the tack you've taken on this. Allows for a bit of bootstrapping for us one-mill wonders. Looking cool though. Thanks for the updates.
  5. #605
    Feb 2010
    3447
    Hey Hoss! I was recently watching a few mastercam X4 videos and saw there 5 axis machining videos.
    I saw they were using a trunnion table with a rotary axis centered in the middle. Since you have already made a trunnion table, and have successfully used a 4th axis, couldn't you modify the rotary table onto the trunnion table and then a person would have 5 axis machining, along with power draw bar, and auto tool changer? That sounds like it would be one hell of a powerful machine in the price range of most! Let me know your thoughts
    This is a good visual demo, just imagine it on the G0704
    http://www.youtube.com/watch?v=qLJxM...ayer_embedded#!
  6. #606
    Yeah the mechanicals aren't the hard part, it's the CAM software needed to make the parts
    that's the bi*ch.
    Hoss
  7. #607
    Feb 2010
    3447
    that's the bi*ch.
    Hoss
    I deff want that 5 axis beast
  8. #608
    Mar 2009
    97
    5-axis CAM
    I agree - looks cool as hell ... have you priced 5-axis CAM software (that was enough to scare me away) !!!! i would have imagine would be a steep learning curve - fabulous once you learned it though!!! talk about tool porn!!! id make all my friends come over and watch and it would be lost of them because they wouldnt even know that they were looking at!!!
    Not sure what your using for a breakout board - or maybe your doing something else - correct me if i am wrong but i believe most of the them are limited to 4 axis - could be you can extend them?? i think mach3 can handle 6 axis.
    if you did it would look something like this:
    [nomedia="http://www.youtube.com/watch?v=w0-tXDEvAqg"]YouTube- New CNC Trunnion Table can be 4th or 5th Axis made by HTS[/nomedia]
  9. #609
    Feb 2010
    3447
    That is exactly what im talking about!!
    http://www.hightechsystemsllc.com/trunnion.html
  10. #610
    Feb 2010
    3447
    This is true, and there might be a forum rule against it. I cleaned up my posts below.
    Dont want to waste any more of hoss's thread on tangents.
  11. #611
    Feb 2008
    23
    B5 20 Cnc mill
    Hello
    I have a ct129 Milling machine (bf20 style) and installed a phase one cnc kit on by bolting on some steppers and using the stock lead screws exaclty like you have done
    Now I need to move to phase 2 which is installing ball screws "exaclty" as you are planning
    I would like to purchase your ball screw kit for the bf20 kit immedialty when it is ready so please let me know when you have a kit for sale
    I look forward to your reply
    Steven G
  12. #612
    I keep buying the screw stock but then someone orders a kit for the X2 and I cut it up for them.
    3 kits going out Monday but I have plenty for the G0704 this time.
    Should be getting them on mine next weekend to try out first.
    Hoss
  13. #613
    Some video updates.
    [nomedia="http://www.youtube.com/watch?v=hCY47KN1tc8"]YouTube- G0704 Z Axis CNC with Stock Screws[/nomedia]
    [nomedia="http://www.youtube.com/watch?v=N3OagWaJC3I"]YouTube- G0704 V Belt Belt Drive[/nomedia]
    [nomedia="http://www.youtube.com/watch?v=QFzU9vtZi4U"]YouTube- G0704 Mach 3 Spindle Control[/nomedia]
    Hoss
    Attached Thumbnails Attached Thumbnails IMG_5111_800x600.jpg   IMG_5151_800x600.jpg
  14. #614
    Mar 2005
    305
    Exciting to see Mach control the spindle. Will you be sharing where you tied into the spindle control?
  15. #615
    Jun 2004
    822
    That is awesome - almost 7K RPM will be a HUGE improvement for guys that work with small cutters in aluminum (like myself). I guess spindle bearings should be first on my list. I'll be one of your first customers in line for the V pulleys as well!
  16. #616
    Feb 2010
    Most Bridgeport kneemills run 1.5-2 HP motors.
    The g0704 is a good mill but it's no kneemill.
    Anything more than 1.5 HP is definitely overkill, don't waste money on power
    that the mill could never take advantage of.
    A 454 big block in an S10 is for showing off not for practical use.
    Hoss
    ok good to know, i can get a nice vfd really cheap, figured it would be worthwhile. i am installing a sbc in my s10 by the way. thanks hoss
  17. #617
    Jul 2009
    46
    Is that Red Paint or Anodizing?
    Hoss,
    Did you paint that part red or are you experimenting with anodizing?
  18. #618
    Hooking up the C6 was a piece of cake with CNC4PC's wiring guide.
    http://cnc4pc.com/Tech_Docs/KBIC.pdf
    Hoss
  19. #619
    Pulleys will have to be DIY at least until I retire.
    Hoss
  20. #620
    Quote Originally Posted by TimGS View Post
    Hoss,
    It's candy apple red spray paint.
    Hoss
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-16-2024, 11:51 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
