588,616 active members*
5,688 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport 1st gen EZ-trak connection problem
Results 1 to 5 of 5
    Jul 2010
    Our shop has a very early Ez-trak, probably 1st generation, CNC mill that is only 2 axis, LED readouts and the only interface outside of the machine is a RS232 connection. I have tried to connect using a standard parallel to usb adapter and Bobcad, but keep getting a "connection failed" error message. Could I be using the wrong cable or the wrong DNC settings? Anyone else had success connecting to this old machine, and sending or receiving code?
    Feb 2005
    154
    RS 232 for EZtrak
    Try these guys, they at least can steer you in the right direction.
    http://www.emi-inc.net/Manufacturer.aspx?mId=26
    or these guys,
    http://www.bptparts.com/
    Pete
    Nov 2004
    3028
    This is actually a control made by Southwestern Industries in California.
    It has RS232 capability but not DNC. Check with them.
    I have yet to have success with a USB to Rs232 adapter. I have heard of people having some success with a PCMCIA adapter to RS232.
    George
    Jul 2010
    I have an older laptop with a parallel port. Do you think I could I use that, and would I need a null modem adapter in-line?
    Nov 2004
    3028
    Parallel port is for a printer. This control needs a serial port.
    George
  1. Bridgeport EZ-Vision Connection
    By Mikey1719 in forum Bridgeport / Hardinge Mills
    Last Post: 07-17-2010, 03:05 PM
  2. Bridgeport EZ Trak emergency stop problem
    By Craiga in forum Bridgeport / Hardinge Mills
    Last Post: 10-18-2009, 05:56 PM
  3. problem bridgeport ez-trak sx
    By Bill N in forum Bridgeport / Hardinge Mills
    Last Post: 06-19-2008, 05:17 PM
  4. Bridgeport EZ-TRAK
    By geno in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2007, 10:31 PM
  5. Bridgeport EZ-TRAK DX-2
    By zukes3140 in forum Bridgeport / Hardinge Mills
    Last Post: 06-21-2005, 03:58 AM
