587,299 active members*
3,780 visitors online*
Results 1 to 7 of 7
    Oct 2009
    51
    Red face Quill fit upwards tolerance, opinions???
    I know the factory quill fit is 0.0003-0.0005".
    After stripping my head and cleaning the bore, my 0.0001" increment dialtest measurement , with dialtest located w/i 1/2" from the housing, with the quill fully retracted, and fully extended is the same, and approximately 0.0008" for both x and y axis. Tells me the bore is not measurably tapered. Lateral force on the quill in both cases was about 15 lbs.
    Does Bridgeport advertise a service limit, or max recommended limit for this dimension?
    The difference between a great mill and a so-so mill is tolerance.
    Can I expect good cnc operation, or is this getting into "cheap" territory?
    I have lots of machine experience, but this is my first mill rebuild.
    Opinions highly valued.
    Oct 2009
    51
    Guys,
    Some feedback would be greatly appreciated, please.
    Getting ready to send out my spindle for rebearing and socket grind, so I need to determine if I am going to send out the head too.
    Mar 2004
    369
    Quote Originally Posted by rolfinator2002 View Post
    I'm not sure what you actually measured, here. If you can apply 15 Lbs radial force at the spindle in both directions and the indicator doesn't change, then the quill is a good fit in the bore. Is that what your .0008" reading is? Taper is not the issue, looseness is. Your .0008" could be deflection of the parts, not looseness in the fit. Depending on where you mounted the DTI from, this could easily be deflection of the head, ram, etc. Did you mount the DTI on the table? You should know that the head of a Bridgeport can be deflected .001" or so with relatively modest force applied to the spindle (I think maybe it takes 50 Lbs to do that). If you can mount the DTI onto the HEAD, you might get a smaller movement.
    Jon
    Oct 2009
    51
    quill fit for cnc usage
    Quote Originally Posted by jmelson View Post
    Jon
    It's clear taper is not issue. Dialtest was mounted to the head with the needle resting w/i 1/2" of the head bore on the quill, checked both with the table x and y axes. The dialtest was mounted directly to the bore housing in other words and as close as possible to the bore on the quill to avoid multiplication of lateral reading. This provides a total diametral clearance of 0.0008" between the quill (not spindle) and its bore. If I was using the mill for strictly manual usage, I wouldn't hesitate to leave it. I'm sure that the Chinese and cheaper Taiwan mills originally built with moglice are no better, BUT this unit is being rebuilt strictly for CNC usage, producing as many small parts as large ones. Since this is my first quill fit, I don't have a reference point for this effort.
    Feb 2008
    69
    I am not much help never owning one, but 0.0008 doesn't sound much to worry about. I think I have read in the Bridgeport manual that tightening the swivel head bolts can affect the quill by distorting it if done up to tight.
    My Chinese mill which is like the Grizzly 3617 has 0.006 after 1 1/2 years use so I am going to sleeve it, I would love to have your 0.0008.
    Dave
    Oct 2009
    51
    Quote Originally Posted by Davo J View Post
    Dave
    Thanks for all the feedback. I'll consider the topic closed then. I think I'll let it fly, and if I get errant finish or dimensions, then I'll rechrome the quill and bore the head to fit.
    Aug 2008
    406
    Re: Quill fit upwards tolerance, opinions???
    [QUOTE=rolfinator2002;826597]Thanks for all the feedback. I'll consider the topic closed then. I think I'll let it fly, and if I get errant finish or dimensions, then I'll rechrome the quill and bore the head to fit.[/QU
    Your supposed to check it the quill fully extended out of the quill housing then put your indicator on it and pull back and forth then push from side to side . Now what do you get ??
  1. Tolerance Using G64
    By audreys in forum G-Code Programing
    Last Post: 05-27-2014, 12:17 AM
  2. 1/4-20 Tap Tolerance
    By xander18 in forum MetalWork Discussion
    Last Post: 10-04-2011, 10:14 PM
  3. ISO Tolerance Help?
    By Billet Sean in forum MetalWork Discussion
    Last Post: 06-18-2008, 01:04 AM
  4. Q: Tolerance - How much is to much?
    By Deviant in forum Mechanical Calculations/Engineering Design
    Last Post: 03-28-2007, 09:23 PM
  5. tolerance
    By heilcnc in forum Benchtop Machines
    Last Post: 04-29-2006, 02:31 PM
